Home » Modeling » UML2 » Template Parameter upper/lower bound spec
Template Parameter upper/lower bound spec [message #477337] Sat, 03 May 2008 11:31 Go to next message
Fascinated I read the UML templates article again. It somehow suggests that it
is _not_ possible to specify an upper/lower bound for a template parameter in
'native' UML. Do I understand that right?
Felix
Re: Template Parameter upper/lower bound spec [message #477364 is a reply to message #477337] Wed, 07 May 2008 12:50 Go to previous messageGo to next message
Hi Felix,
Sorry about the delayed response...
Yes, to my knowledge there is no way of explicitly setting the kinds of
upper and lower bounds such as Java's wildards allows you to do.
Of the type List < ? extends Car> or List<? super Car>.
For type parameters, UML has a concept of
ClassifierTemplateParameter::constrainingClassifier but currently the
multiplicity is [1], whereas Java allows multiplicity [*] on such things.
There do appear to be some "holes" in the current spec. in this area. Some
issues have been raised with the OMG and will make their way into the next
version of the spec.
- James.
"Felix Dorner" <felix_do@web.de> wrote in message
news:fvi0gv$7rs$1@build.eclipse.org...
> Hello,
> that it is _not_ possible to specify an upper/lower bound for a template
> parameter in 'native' UML. Do I understand that right?
> Felix
Re: Template Parameter upper/lower bound spec [message #477365 is a reply to message #477364] Wed, 07 May 2008 12:54 Go to previous message
.... A discusson of this was done at EclipseCon2008 , you may find other
useful info here:
http://www.eclipse.org/modeling/mdt/uml2/docs/presentations/ EclipseCon2008_LongTalk_NewFeaturesOfUML2_files/frame.htm
- James.
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fvsmlb$obb$1@build.eclipse.org...
> Hi Felix,
> Some issues have been raised with the OMG and will make their way into the
> next version of the spec.
> Cheers,
> - James.
>> Hello,
>> Thanks,
>> Felix
Re: Template Parameter upper/lower bound spec [message #626543 is a reply to message #477337] Wed, 07 May 2008 12:50 Go to previous message
Hi Felix,
- James.
> Hello,
> Felix
Re: Template Parameter upper/lower bound spec [message #626544 is a reply to message #477364] Wed, 07 May 2008 12:54 Go to previous message
useful info here:
- James.
> Hi Felix,
> Cheers,
> - James.
>> Hello,
>> Thanks,
>> Felix
Previous Topic:[Announce] MDT UML2 2.2.0M7 is available
Next Topic:UML2 from eclipse and customer requirements
Current Time: Fri Jul 25 23:12:36 EDT 2025
Powered by FUDForum. Page generated in 0.04756 seconds
