Home » Modeling » UML2 » Primitive types and Java types in XMI
Primitive types and Java types in XMI [message #477293] |
Wed, 30 April 2008 05:21  |
Originally posted by: swt.magellium.fr
Hello all !
I managed to import XMI 2.1 files generated by other uml tools
(Enterprise Architect & Bouml) into eclipse, and it works well (at least
with Bouml) except for primitive types and java types.
For instance, in Bouml, if I define a class attribute with type "int",
the resulting XMI declaration becomes :
<ownedAttribute xmi:type="uml:Property" name="myIntAttribute"
xmi:id="BOUML_0x1f482_1" visibility="private">
<type xmi:type="uml:Class" xmi:idref="BOUML_datatype_0"/>
</ownedAttribute>
Where "BOUML_datatype_0" is defined as :
<packagedElement xmi:type="uml:DataType" xmi:id="BOUML_datatype_0"
name="int"/>
After importing that into eclipse, I get an "int" class definition.
If I use EMF to generate the corresponding model classes, it will result
in creating a "int" class (public class int extends EObject) !
Of course, I'd like to use the primitive java type int instead of this
class !
The same kind of problem appear with other java classes such as
java.util.Date...
So I'd like to know how to work around this problem... Can I do
something with my UML tool such as using "special" stereotypes which
would be recognized when importing into eclipse ?
Or should I use some transformation (xsl) on my XMI files in order to
change types declarations into ECore/XML types declarations ?
Maybe there's a way under Eclipse, to switch attribute types from "fake
classes" to ECore classes ?
Any advice would be really appreciated. I already tried a lot of
different things, but I can't find any working solution... I hope this
is a "well known newbie problem" so that someone will tell me the right
thing to do in no time :)
Thanks in advance !
Stephane
Re: Primitive types and Java types in XMI [message #477294 is a reply to message #477293] |
Wed, 30 April 2008 07:58   |
--------------040303020009020802070604
Stephane,
If I look at Ecore.uml it looks like as below, so I imagine you need to
apply the Ecore profile and set the Instance Class Name
SWT wrote:
> Hello all !
> least with Bouml) except for primitive types and java types.
> </ownedAttribute>
> name="int"/>
> result in creating a "int" class (public class int extends EObject) !
> class !
> java.util.Date...
> "fake classes" to ECore classes ?
> right thing to do in no time :)
> Thanks in advance !
> Stephane
Content-Type: multipart/related;
boundary="------------010504060308020405060403"
--------------010504060308020405060403
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Stephane,<br>
<br>
apply the Ecore profile and set the Instance Class Name<br>
<br>
<blockquote><img src="cid:part1.01070906.02080900@ca.ibm.com" alt=""><br>
</blockquote>
<br>
<br>
SWT wrote:
<blockquote cite="mid:fv9dne$18j$1@build.eclipse.org" type="cite">Hello
all !
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</ownedAttribute>
<br>
<br>
<br>
<br>
name="int"/>
<br>
<br>
<br>
<br>
class !
<br>
java.util.Date...
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thanks in advance !
<br>
Stephane
<br>
</blockquote>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="moz-screenshot-8.jpg"
Content-ID: <part1.01070906.02080900@ca.ibm.com>
Content-Disposition: inline;
filename="moz-screenshot-8.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDABALDA4MChAODQ4SERATGCgaGBYW GDEjJR0oOjM9
PDkzODdASFxOQERXRTc4UG1RV19iZ2hnPk1xeXBkeFxlZ2P/2wBDARESEhgV GC8aGi9jQjhC
Y2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj Y2NjY2P/wAAR
CAHdAxMDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDr8iw06Qx4LohYkj7zAdTV e61sQSBUgdxj
JLK644Y/3f8AZ/zg0t7JmyuB/wBM2/lWdqLXDzqTbRsQvULv7N3KHvj8/fIi o2o3RcEm9Tov
MqnaazaXjRiFpcSjMbSQPGr8Z+UsADxzgdgT2pfMrF0y1ng0mzmke4uJre3V oraTYgV/LxjI
UEcEr8xPXnmrIOl8ymC6ja4eAN+8RVdlx0DEgH/x0/lXI28l2rvG8t5JYhka RlinR8ESZC7i
ZD8wiztOPb72bMf2hL83Crdm1WGLcGB81gHlI56nGVJX7xBGcnKsAdR5lHmV yV5PqX9oSNaG
ZJn8xBH5cjIAI22NuY+XywQ8AEZwT1zFNLI1zNFYzXyW4EJl84Tuyg+bkgEh +SE+6e3pmgDr
bq9itIDNOzBAQvyqWJJIAAABJ5Iotr1LqMvGJVAOP3kTRn8mAP41z9x9oPh6 NXkneRZo23rE
fMCiZSCFO48KM85PHPOakmuLmSyg+wSzyXKzEK91E0an5WJ8wBV+XB4wPvbf egDofMpkF1Hc
28c8Lbo5VDo2MZBGQa5OzmkadhE+otcJNAEExkIEflxFw/8ABuwXJzzk8c4o 077XFb2kbLdp
coLdYlw4jEQVPMDD7mf9Z975umP4aAOv8yjzK40rqItrIfaLuNvssZX5JZWM xyX3YYAc7eJP
l+gBrb0syLBKZjKXa4mP7xiePMYLjPQbQMAcUAW59VSC7eF4pdkcaySzDGyN WLAFuc/wnJAw
OpwOaj+221/dJA9q7o8byQzsF2uoKglTncPvDBwM9QSMGqs90y6tFthlZ4Y9 0RRSFlZsgqz4
wqjAYg8k7SBlcEgumbVpd0MqvNHulLqSsTLgBVfGGU5LADkHcSMtgAEtzbtb ZdWLw55B6oPr
3H+eetR1e8yqM0YgJdB+67j+5/8AW/l9OgAVUSaf7WyOuEGSc9AvY5/z3q3V K78oySCSQodi
7cNjJye3ftSZMu5cVlZQykEHoQaaJUMzQhv3iKGIx0BJA/8AQTUNiFETYcsx b5s9jgf0xUEl
tNLq0zpPPbp5EY3RqpDHdJx8ynpkdPWhaoad1cuQTx3CK8RLI6K6ttIBB6df 5VJXOCO+W0tY
1M8US21uJMI524WTIAUhs52Zwc9M8VYhW8RJmc3EuLdFQsHXgu+W2hskhdp6 7+AMgmmM26Y8
qRvGrthpG2oMdTgn+QNYNuNQYyCN7hjHHP5DMrxgttj25Dkk8l8bie/pxYaA Ty2y25v1hE+W
aTeCP3cgOC/zDOQM9ORjBzQBskAggjIPUGmRE/MpOdjYyfz/AK1jx/bPtCwF pcyN8m5iNqRT
HJOeTuRkGeSe/rWvF9+b/f8A/ZRQBIAT098DBJ4x6A+oobKY3K2PXYwA/MVL a+Y02yB0SXax
BdCwH3e2R6HvU11HeraubmaCRMrgRxFDncO5Y1dlYi7uU4gDfRAjPyt/T/P+ NWW5UvFGrIjA
Mduc8gHGPT156Y55qvD/AMf0X+439P8AP9D0p98I0wWYBZGBdTt2vjB/iOM9 B3yPXAJwqNqN
0axSb1J1aEsq7CpPA3Rlcn05HX8+h6/xMuAAigDA3HH5L/n/AB61BD5fmvPb LbrHGuGUFMkc
55BOOg68dffM85DRqwzhmJ5GD0X/AD/jRTnzBKNjHEt2iutxfW0c4J8uFbRm Mw7bP3gz79Nv
fjDG7bCcW6fajGZsfP5YIXPtnmpKK0JKNxcTJetH53kRCNWVvsUs+5iWyMoR jGF6+tFvcTPe
rH53nxGNmZvsUsG1gVwMuTnOW6elXqKAKl9Lco1tHaJvlml2Y2BjjYzcAso/ h7moZ21e1VJJ
4CsRljRi0CKAGcL1E7Hv6GrU4nW4tLi3SOR7eUuUkcoCCjL1AP8Ae9Kdf3eo X9utu9nbRIZY
3Z1uWYgK6twNgz09aABhtmRhxvO1h68ZB/SprZggaViNzEjJ7KDjH6Z//VUU v34f9/8A9lNV
bhma1kiVtrNvA/76NVFXZnVlyxuakE/2hCIryBpgMmMLk5xnA+bnr1FKtwTk MpVl4ZT2NZOl
2l4dQSdhOsQkLlmZCCCg/PPTI/nVu7m231wM/wAQ/wDQRQ4crVmZqbcW2rEh 1aAXLW485pFY
K22F2UEgHlgMDgjvVnz/AHrmobgxarcl5LlRJMCqLCTG37tRkttOOR6jpTGm uP8ASDG1z9t/
e7eT5ePm2fe+Tps6c56/xU7C5jqPP96PP965aOSRryEQNd/ZBKpPmNIDkLJn O75tufL9v1o0
qa5jl3XM0zkoBKpifAckdCWI9fuAL3OBiiwcx1Pn+9MmvEghkmlbbHGpZjjO ABk1yt7c3n2Z
oYhc+ask7F1zjBWQoM9+q4xnBAHBxTb4XAguo4jcOpLxKpdnyhhJ75z8/fr2 zjigLnX+f71T
g1cSxQv5E8clwge3iYLumBGQVwSPrkjaOTgc1D5/vUVhqappzRbLpUuQz3Dp mNrZmHIjUjLE
dSR1JJGSdoGhwknuW4pIryIyiJreXe6tkAMGVipzg4PIPc0oYhtj43diOjD/ AD2qjZ3Ia2UB
QiqSigIUBUEgEKeVBABx2zUzShhgn369DRygqtnZlqiooZg/ysRu/nUtQbp3 1QUUUUDCiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKAJPMo8ytSw/wCPOP8AH+ZqMSXE 5DpBFtjkYDdL
gnBK/wB04/CgDP8AMo8yte2lM0O9lCsGZSAcjIJHX8KqxXM1xHvI8kgldisD yDg5OPUdqmUl
FXY0rlLzKPMq1cyyyrHA0LFjJE4ZAWU4kBbnHGAM8+vetCSRIo2kkdURAWZm OAoHUk1XS4ut
jDcrIjJIoZGBDKwyCPQ0y3igtUKW0McKE5KxoFBPrxWzHf2c3k+VdwP5+7yt sgPmbfvbfXHf
FFpf2d7v+x3cFxsxu8qQPtz0zj6GgDL8yjzK1Fv7N/P2XcDfZ8+diQHysZzu 9Oh6+hqu+qwt
PbJbvBLFcIzLN5w2fK6JgEA5Pz8e4x3yACipVSxVQC5yxA6nAGT+AA/CneZW lDqVhcRyyQXt
tKkI3SMkqsEHPJIPHQ/lTmv7NPI33cC/aMeTmQDzc4xt9eo6eooAy/Mo8yto yIJFjLqHYFgu
eSBjJx7ZH5iqp1bTRuzqFoNiB2zMvCnGCeeh3Dn3HrQBn+ZR5lXDfXUs9zDa WkcjQS+WWkm2
LjYjdlJz8+MYxweRwDYtb2G5tLW4Vti3SK0auQGOV3Y+uMnj0NAGX5lHmVpP qVhHJ5b3tsr4
ZtplUHC53HGe21s+mD6UQXqXF7JBHtZFgjmWVWyHDlwMf98Zz70AYxi2nMLB B/d25X8qjZS2
4SQbtwAO1gR+uK6G5laGHeqhmLKoBOBkkDr+NNe6iW5jgDo0jtgqGGVG0nOP w/WldBYwIv3S
bY7dwOvUf40/zG/54yfmv+Nb8c8MoBjljcE7QVYHJxnH5U7zE2F967Vzls8D HWgLWOe8xv8A
njJ+a/40eY3/ADxk/Nf8a3jc24iEpnjEbHAcuME/Wmfa0WWVZGjjWM4LM+M8 Kc/+PY/L1oug
MTzG/wCeMn5r/jR5jf8APGT81/xrfE8JRHEsZVztVtwwx9B60omiMpiEiGRR koGGQPpTuBzi
hUkeRLUrJJjewCgtjpk55pUZ1ZyYX+ZsjlfQD19q6IzRCURGRBIwyELDJH0p jXdsqK7XEQV8
7WLjBx1xSuBgs2771uxx67f8aQYByLUg/wDAf8a6CGVpHmVlCmN9vBzkYBB/ WpqdwOcjfEwk
aOUFVIAAU5z/AMCHpVk3n/TOX/vhf/i/f/OTnaooAwHkR5/NZJzwBtKrtOCS D97tmia43qAs
MpO4k5Cjrj/aPpW/RSSS2Hc5vzG/54yfmv8AjR5jf88ZPzX/ABrpKKYjm/Mb /njJ+a/40eY3
/PGT81/xrpKKAOb8xv8AnjJ+a/40eY3/ADxk/Nf8a37gAxgEZBZcg/7wrmpd dtIdSj095Yhc
OMgeWuAewJxwT2H+IyASM7NLEDGy/MeTj+6fQ1Uc5dvZm/mabYsWvL0k8/bT /wCilra0D793
/v8A9Wqk7GdSPMkjD8qP+4v5U5VCjCgAewrr7gZt5RjOUPGM54+h/kfpUlHM uxn7FvqcbRXZ
UU+cX1fzONorsqpiS4nIdIItscjAbpcE4JX+6cfhRzh9X8zmaK622lM0O9lC sGZSAcjIJHX8
KxrzUZ4RIVllLhzhAFAx5uwY+Uk9ewP6imncToW6mXRWy1xeSSyRpOEZyJI9 67cKWULkHlcY
IKkZbJwR/DieMv8AkLRf9cB/6E1UtXYzqw9nHmuOorD+zS/aPI2fvO65Hy8Z OfTHfPTBz0pB
BM0DTLE5iU4Zwp2g+5/EVVjm9o+xuVMlzKvBw49+D+f/ANasa7so4XnSCZpW t2IlDJt4ztyO
TkZx6Hke+I4rC6leNBC6mRGePcpG8Bd3HHPH8xScUzSNacHZI6H7Yv8Azzf9 P8aPti/885P0
/wAa5oW8gjSaWOVbdmx5gTIPrjsTweM9qlu7WOGRY7eSWZigkOY9uAVDdiex 59MVPs0X9bna
9joPti/885P0/wAaPti/885P0/xrmxZ3TRtIttMUUZZghwBjPJ+hBpBbTmNJ PKZY5G2rIwwp
P+8ePWn7Ndw+tz/lOl+2L/zzk/T/ABo+2L/zzk/T/GuZEEpeRNhDxgllPBGO vHt/Q+lR0ezQ
vrkux1X2xf8AnnJ+n+NH2xf+ecn6f41gx2aLHM93I8XlOiFUQOcsCefmGMba bLYyRuTtleHb
uWRY89U3gH0OMZ54560uRdyvrU+x0H2xf+ecn6f40fbF/wCecn6f41zclndR BjLbTIEALFkI
wCcDP41NLp80eCI5mDg+WBGc5D7MMOxz9eoHej2a7i+tT/lN77Yv/POT9P8A Gj7Yv/POT9P8
a5mOCaUqIoncuSFCqTkgZOPwoVFWfZcF4wpIbCZYH6EjvT9mhfW59jpvti/8 85P0/wAaPti/
885P0/xrnr21W3upoYWeUQkh2KbcEHHqeM4596Y9ndJE0r20yxqcFyhABzjr 9eKXs13G8XNd
DpPti/8APOT9P8aPti/885P0/wAa5sWdzmMGB180Zj3LjfxnjPX8PUUlrD9p u4YN23zXVN2M
4ycZp+zQfW59jpfti/8APOT9P8aPti/885P0/wAa59be3mk2W88rYR3JeIL9 1S2OGPXFNhsr
iWSJfLZRK6xq7KQuWwRz9CD9KXs0H1qfY6L7Yv8Azzk/T/Gj7Yv/ADzk/T/G svw2rJ4ht0dS
rKXBBGCDtNd7UySizoo1JVI32OW+2L/zzk/T/Gj7Yv8Azzk/T/GupoqdDa0u /wDX3nLfbF/5
5yfp/jR9sX/nnJ+n+NdTRRoFpd/6+85b7Yv/ADzk/T/Gj7Yv/POT9P8AGupo o0C0u/8AX3nL
fbF/55yfp/jR9sX/AJ5yfp/jXU0UaBaXf+vvOW+2L/zzk/T/ABo+2L/zzk/T /Gupoo0C0u/9
fect9sX/AJ5yfp/jR9sX/nnJ+n+NdTRRoFpd/wCvvOW+2L/zzk/T/Gj7Yv8A zzk/T/Gupoo0
C0u/9fect9sX/nnJ+n+NH2xf+ecn6f411NFGgWl3/r7zlvti/wDPOT9P8aPt i/8APOT9P8a6
mijQLS7/ANfect9sX/nnJ+n+NH2xf+ecn6f411NFGgWl3/r7zlvti/8APOT9 P8aPti/885P0
/wAa6mijQLS7/wBfect9sX/nnJ+n+NFdTRRoFpd/6+8r2H/HnH+P8zVGbTIp ZM3Om2N0xdts
ko3EAszY+4cdT3/nV6w/484/x/maklOHh5xl/Xr8p9/8fp3CKIre1AhInjjZ 2ZieNwwSxxkj
0Yj8TWQ9wZ7mYMqzCRFxCdvJyeOe4wvXgY9zXQVDNceVIkaxSSM4LAJjgDHq R6iolFtpp7FJ
pJpowJ7O2NxFE9vGkrOitGAAdpC56fVuR+fFbepWz3Vp5cZUOskcq7uASjhw Ce2duM84z0PS
ks7oSrCmx8PFvSTcrK4GOQQx9RUs8/lFUVdztkgE4GB1JP4j86SXI5Sb3Y2+ ZJJGLcaPcTG9
uLl44vtNvOkixBpTGXSJRt4BfiInoDk4GetTaTLeXWpXN5LaLDG8cUXLOPum QkgOik8svbHP
UkEUl9rxtZvJC24dSm4yTEY3N0xtz0Gc9s5we+hpt6t/aCZQgO5lZVfcAQcd eO2D+NUpJ7Cc
WldmNbeHp4YI0/d77ZI1idrmWTzNjo/3W4iB8sZChsZ/2cGxc6VeXd1BcyLa QurhnWMk9JYG
+9gbjtiPOB1Uds1uUVRJzenabfXGl2JuYIImt7JYUjZ3yxPln5uAY2HljBG4 gnP8PLp9BuJj
mTypDNAIpgJ5IVHzOSxVMCXPmHOduSCeN2B0VFAGfc29493BdQCBZY0lh2ux KhWZSH4HJGwf
Lx1PzcZNHS9EubOOzWR4iYJ0kbaTyBaiE44/vDP0/Kt6igDm7XR9StLNLULa Twts86NpmQPt
hiQAnYcrlGJGBkbc8ZB1LqC8nFtMI4BPbS+YsZlO18xlSC23IwXPY52jpnjQ ooA5+30S8QSm
WWBnklikJXIB23TzHjnHyuMDJ5796uaVps1leXc0rRlZs7QpOR++mfnj0kX8 Qa1KKAK19n7O
CFZsSRsQoJOA4J4FV5rKaVfIzGIt8jb8nd8wb+HHbd69q0aKTVx3KC2cgSR8 Kk3ylCZWk5Gc
ZY9uSCAOhPrUktqWtPs6HhdrBixBYhsnJHTOOvuat0UcqC5QjtZoXE0aRl/m BRpWPXbzuIJP
3R2HX25hmspo28xFjbDrhVBUdYu3OB8h9cCtWilyoLlBrWZyzkRB5HywJJCj AGM4+YYXkEDO
eoxmiOzkjnLgK213kUtK3JOeNvQdevP054v0UcqC5Te2laVwNnlySpKWJOQV 28Yxz93rnv7V
Unimgt/IRPMkktlhOA2AQCMg7SO/fHSteihxC5Wtc+bdNtYAy8ZBGcKo/mDV miiqQgooooAK
KKKACiiigAooooAragZxZu1ssbTDBUSMVXgjqQD/AJ9Otc8Ydb/546f/AN/3 /wDiPb/ODjpp
/wDUt/n/AD/nkdap9PbH+f6fp2x8oBgWtnc2kjm78oST3BkxExIA2bepA/um tbQPv3f+/wD1
aor7/j4g+v8ARv8AP+HQS6B9+7/3/wCrU0TLdf10NW4GbeUYzlDxjOePof5H 6VJUV0AbWYNj
aUbOemMfUfzFS0igooooAKyZtMilkzc6bY3TF22ySjcQCzNj7hx1Pf8AnWtU cpw8POMv69fl
Pv8A4/TuACK3tQISJ442dmYnjcMEscZI9GI/E1RNvcAurJclfNZ12iEry+4E bufQ/WteoZrj
ypEjWKSRnBYBMcAY9SPUU07CauUGiu5HQEXWPMQnzPJxgMDzt5rE8VzNb65b yoAWWEEZ/wB5
vy+o5Haunt523JBJDIj7MgsQQcYB6MT3HWq2rNZxGJri2tppXyq+aBkKAST0 JwPp3qlLUyqU
nONkzh0mhR5YwH+zygA9N69/xwe3AOOxxixHqCLYpFkq6RtGAIkO4MW53nkf e6Aduozx1sKa
PLBHIbexQugbaypkZGasR2GmSrujtLR16ZWNSKrnRzrCzWzOIvLu3aW7ktjK xumO7zEC7BuD
YGCcnIHPH054sf2larC0aKyq7fdWFV8tSjr94HLkb++M47Zro7VbK6nZY9Dx Esjx+e0cOzKE
qeN27qpHSrUtnpcTwpJZ2waZ9iDyRydpbHT0U/lRzof1ad73OM+2W40+WFFK u8aptEK8EMpJ
L53HOCcY4zjtRBMk2opJkJEIVjlLsAQvlhGI9TjJAGT7V2/9mWH/AD423/fp f8KP7MsP+fG2
/wC/S/4Uc6F9Wnpqcct7bmK1uJCyvBOWSJQGyFWMLuORjO3rj147VFLfxS2w jLMhZEicLCnA
Xbzv+833c44+vHPYWdrpt5ZQXUdhAEnjWRQ0K5AIyM/nVfUW0fTXjW5soFDj dv8AKQKo3omS
T05kB+gNHOhvDz7nH/akNyszKwESgRKG546bm4P4j0wMDGIorh4rkTqF3ht2 MYH4Y6fhjHbF
d20OlDUUsfsdsZ3iabAiThQQOe/Jbj6H0qSWz0uJ4Uks7YNM+xB5I5O0tjp6 Kfyo9oiPqk+5
xEd79mgnSzkniMjowIbBAAbIJHXlh9cZ46UsN8qxKJd7vmcs3XJeMKP1HNdl fW+nWVsZm02G
X50QJHEm5izBQBnA6kdTRaW+nXO9TpsMMyY3wyRJuUHoeMgg4PIJHBHUEA50 V9Vn3OSl1GF5
pHCvhpLlxwOkiBV7+vWnXOqRyvPJF5qOysqHpj995gOc8HqPwHrx17WelrcJ bmztvNdGdV8k
chSAT0/2h+dSf2ZYf8+Nt/36X/CjnQ/q8+5xS6lGJnAjEcLx7cLErBWLBmOw 8HkYHsF9KpXk
32i5aQEkYCglQvAAHQcDp07e/WvQv7MsP+fG2/79L/hR/Zlh/wA+Nt/36X/C jnRLws2rNnEp
PFPeX878W028sC4V+W3KAOecgA8HGfxqS4vYXWK6dybh4ZVMaKNoLtJ1Ocj7 2cY9PWuy/syw
/wCfG2/79L/hR/Zlh/z423/fpf8ACjnRX1afc4q81CG7Lbi4SSTzXRIkTBwc DcOW643HpycH
NVobz/iaRXkw4WVXYKOwI9ep9ycnua77+zLD/nxtv+/S/wCFH9mWH/Pjbf8A fpf8KOdCeGm3
e5wzXcYuPNa5ubkmKSMmVcEZUgY+Y8ZNSRaosV0JiruEhhjRSe6FCR7AlW/O u1/syw/58bb/
AL9L/hR/Zlh/z423/fpf8KOdB9Wmtmcb4b2jxDbhCSuXwSMEjae1d7VeKxs4 ZBJFawRuOjLG
AR+NWKiUrs6KFJ042YUUUVJsFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQBXsP8Ajzj/AB/maklOHh5xl/Xr8p9/8fp3Edh/x5x/j/M1JKCX hwW4fnBP909e
P8P6UASVSv4DLImY5nj2MreTL5bAkqRyGB/h7GrtRTXEcLKr7yzAkBUZjgYz 0HuKAMzRrD7L
BaQqs5jig2mSSXdvPyY2/McD5eg4p+pv5IRIs7gyZZizEAsF479AT6ZAJ71d t7lZNkR8zzdm
TvRlzjGeSBnrSXbWSlfthtwTnb5u3n1xmonFyVkOMlF3ZlTQxXG59squXALb mABAZvl7cMPw
9qvaIgTTwQWO53OCc4+Yj+mfqTRPd2X2bbGsNzGrAFEwwXOccdulXYggiXyg ojx8oUYGKxhT
5aju+hpKfNDQwLrSpZ7i6BsVaOWeJnZ3B8xRKjEf7QCqeGGV5VSyni1Y2bQ6 izy2GZ/Nkdr3
eo3oxYqvB3NgFRtYADbkH5VzeudRtbUyCZ2BiCFlVGY/OxVcAA5yQRgVH/a9 mLeSZmlURlQy
NBIr/Mdq4QjccngEDkg+hrpMi9RUNrcx3UZkjWVQDjEsLxn8mAP41Ha6ja3c hjgdicblLIyh
1/vISAGHI5XI5HqKALVFFNSRJFLRurgErlTnkHBH4EEUAOooqOWeOJ4UkbDT PsQY6naWx+Sn
8qAJKKhkuoo7iOByweQ7U+Q4Y4Y4zjHRGP5eozNQAUUUyR1ijaRzhUBYn0Ao AfRURnjG3c23
chf5gRgDGSc9Oo60z7ZDtJy4IONpjYMfouMnoe3Y+lK6AsUVXa8hUIcu28Eg LGzHjg5AHGM9
6kaWNIvNdgiYBy/y4+uelF0BJRUXnx/Z/tG791s37sHpjOaYLuLAJEigsF+a JhyenUUXQFii
iimAUUUUAFFFFABRRRQAUUUUAFFFFAEc/wDqW/z/AJ/zyOtU+ntj/P8AT9O2 PluT/wCpb/P+
f88jrVPp7Y/z/T9O2PlAKN9/x8QfX+jf5/w6CXQPv3f+/wD1aor7/j4g+v8A Rv8AP+HQS6B9
+7/3/wCrU0TLdf10NW4OLeU5xhDznGOPqP5j61JUdwCbeUAsCUOCpIPTtgH+ VSUigooooAKj
lOHh5xl/Xr8p9/8AH6dxJUcoJeHBbh+cE/3T14/w/pQBJVK/gMsiZjmePYyt 5MvlsCSpHIYH
+Hsau0UAZ1pa+XOm2K6SNVYkz3BkOSUwASxOPl6dPzqtrNhJJLbTRLLIsayI yqdzfMFXPJ9A
e/Ug4PNbVFAHNRi8itooR5v7sKpAhlHRQPvY6Z7YrW0nzPIkMquCXHLqQT8i gnnnqDVwE+cw
527Rj0zk+307/l3V3WNGdzhVGSfQU27jbuY+kW8trdzCSyvFMk8zeabgNDta RmUhN/HGOi5y
frVOz0e6SW0e5tldYZIZFUlT5SBZFWIc4byy4beeTnuQBW79th/6a/8Afl/8 Kcl3C7qgLhm6
bo2XPfuKQjmLbQLpYdjx3Pmkwi4kMkSCUiWNmdSgDtwrEM5DDPGSxxck0por uTdpq3WnLI/l
WiCPauUiwwRiFGGWX3y545JreaeNbhLct+9dGdVx1CkAn/x4fnUlAHJ6fod5 FPZPcRz+bEkG
10aHbEqogZCxBkHKvwvynd1GWNN/sSaRrWN9KUOkaJdzt5ZF0wmhZmPO5shH PzAHn1OK66qd
5qdtZTRxT+fvk+55dvJIGPJwCqkZwCcdcDNAGSdFvUkdknZrh7O4gW5aQ7l/ 1YiyfvdFLHH8
RYjrUdlorxSwSC0lWGK5SQwzeQvIV13qkYCDBdTnO47f9lc9NRQByJ0zUVuj OtlKXJSS4VPI
RJZFnifKYIY8CTBk5wfUmtaa3u7hL26Fv5b3EUcP2eTYzbFZix6lNxDsACSO Bk8kDYooA5fT
tKvbefzo7bb5Xnrarc+WPKLpHhiI/lVdyODt5+bpyTVzw9YzWVxdjyJ4LZ0j 2JKIV+cF9xCx
fL02cnk49hWxFPHK8yRtloX2OMdDtDY/Jh+dEU8M2PKljkyiuNrA5U5wfocH B9qAJKKKrvfW
8cV1I8mEtM+cdp+TChz9flIPFAFiiiigAooooAKKr3d7BabBKZCz52pHG0jE DqdqgnAyOenI
9RU0ciSxrJG6ujgMrKchgehBoAdRRUdxPHbW8txM22KJC7tjOABknigCSiqZ 1SyEzxtNs2bs
u6lY8rksA5G0kYOQDkbT6GmjV7Mxs5aVSCB5bQSCQ5zjCEbj0bkD+FvQ4AL1 FU01WxeaCFbm
MzXGfLi/jOM5yvUY2sDnGCMdeKkmvreC8trSWTbPc7vKXaTu2jLc9Bx60AWK KrvfW6Xi2jSY
nfGF2nnIcjnp0jf8vcUS31vDK0ckm118vI2njzGKJ+bAj+dAFiiq93ewWmwS mQs+dqRxtIxA
6naoJwMjnpyPUVNHIksayRuro4DKynIYHoQaAHUVHBPHcIXibcodkJxjlWKk fmDUlABRRVe6
vre03faJNm2J5j8pPyJjcePTcPzoAsUU1XDM4AbKHBypHYHjPXr1H07ULIjs 6o6sUO1gDnac
A4PpwQfxoAdRRRQAUUUUAFFFFABRRRQAUUUUAV7D/jzj/H+ZqSUZeHjOH9On yn2/w+vYx2H/
AB5x/j/M0+b/AFkHIHznqBz8rev9P5ZoAlqjfhjPHtknhzG6+bDHvZTlD0Ks OcHqKvVHLPDB
jzpY489N7AZoAydEtZbaCyt3mnkaC32M7RbQuNnyqSoyPlPXn3qv4ojjaG2i laNmLFg8wHAA
AI4A6kg/hW1aXEEsaJHLEWCDKIRx+AJxVik720dgtF/Ero4SyQRzLHDLCBKw UpGxXcei557E
5rrNGn8+wX/pmSn4dR+hA/CrNzcx2sYeUnBOBipQcjIrGMP3l3K7L91Q5Yxs jnLmO6v/AD5x
bz27v9ijYBctG6TlnxkYYKGB3YKn3waNRtLiL7WC93Of9DYXIiDSYE5JACrt O0Dd90n5ucjA
G0mpWEl0bWO9tnuASvlLKpfI6jGc8YNWI5EljWSN1dHAZWU5DA9CDW5BX06U S2oxJcylSQXu
YTE7d+hVfXqBWTBFdNbz2Fg93FF9keNBcx+X9mkwBGqOFG4D5ssC/wB0HPPP QVDJHbX1u0ci
RXEJJVlYB1JU8gjpwR+YoAwWmurqCO+T7cIbqUTQRRn5lUogXO0kKchmAbMf JD4JBEM9teQp
5Ye5ghNzcvKUjmkyzSBo8CNg2ChJ4O3OcjdXRXd/Z2Wz7ZdwW+/O3zZAm7HX GfqKsUAc3Ba3
0tyv2qS+JkuEilIkeMeWLYMSAjbV/ejqp65GSCQbDzXAsNCuryKdpUdXuNkD MykwOCSqjI+Y
gdOM1uUUAczqbtd6nbzvHqH2EGJv3cUyMp23AJAUBhyUB9iM8GnQC/C3cjpd uot1SEM0nCNN
L82AQS4j8sn+PjGQTXSU2ORJY1kjdXRwGVlOQwPQg0AcraQandGaBZ7sKsVy tvK6zQqGKRbS
d5LHBaTG4nocdBjUt5pLvR769bzFhu0M0CSHLJGYlAyASBkgnAPf1yK1J4Ib mFobiKOaJvvJ
IoZT35BpXaNm8lyhZ1J2EjLKMA8dxyPzFJgVTI5uvNMMn7mOQEAZzypXHrkL 26dDUfyygzuJ
xKCMskTDZwcYBHzdSOh6544xfVVRQqgKoGAAMACnUrDuZjmUyW8kjTphJBvj i3Ejcu3I2nGQ
M9B+HSr6lmYOCPLK/dKENn/PbFSUU0rBcpQx7tKjt5Eky1vtKgYP3QCOeAee 9QtnY2zzfJ8y
Hb5u7O7zBn73PTb7frWnTHjSTbvRW2ncMjOD60rBcfRRRVCCiiigAooooAKK KKACiiigAooo
oAjn/wBS3+f8/wCeR1qn09sf5/p+nbHy3J/9S3+f8/55HWqfT2x/n+n6dsfK AUb7/j4g+v8A
Rv8AP+HQS6B9+7/3/wCrVFff8fEH1/o3+f8ADoJdA+/d/wC//VqaJluv66Gr cDNvKMZyh4xn
PH0P8j9KkqK65tZuQPkbkgEDj34/OpaRQUUUUAFRyjLw8Zw/p0+U+3+H17GS qk93bCaMG5hB
RzuBZcjgjuePw/xoAt0U2ORJUDxurqejKcg1Sl1SOFXd4pBGjFTIWRV4OO7D vTSuJuxforPk
1aGMSkxyHynKHA64Kg/j83A6nsDkZ0KVhkbRZcurshIAyoHv6j3/AE+uYbuC SS0nRJGZmRgq
nGCSDgdPcfkPfNqigDnxaXoneRYbhNxP3PKzyc9SxqXT7O6iuojJC6orZLHa P4WHZjk5IrTt
L+zvd/2O7guNmN3lSB9uemcfQ1Yp8zK5mYusxxnVbKS4S8MKwTKWtRLkMWjw CY+eQD144qi8
mqi4sGn8+O6T7OkipFK6yAlfMYlT5S9XHKk/LkHlcdNJIkUbSSOqIgLMzHAU DqSahtL+zvd/
2O7guNmN3lSB9uemcfQ0iTn5RftaOqSXyJ9oHnvIkjNt2tnCoQ+d2wHyzs4B XgsBehiuTDox
lMszR3LszvGVITy5QpIJJHBUfMc8jPJNbVFAHM63JeodUSGaVPJje83rIQFj Nu0aoOc58xS2
MY4znPFNuRdMriwkvo9P3x72mSd5AcSbsAkSkZ8n7px17bq6JbS2WOaNbeIJ OWaVQgxIT1LD
vnvmpqAM+wS8/seNRP8A6RztknhP3dxxlN277uOrbu55yKdZxut7cPEjRWpJ +RxjdJn5mUfw
g9/7x5AHV5ru/s7LZ9su4Lffnb5sgTdjrjP1FSCeEwpMJY/KfbsfcNrbsBcH vnIx65oAxXtr
mO+vrqI3Ic38ARFzsKFYVdsD73G4ZOQNuRg5NZa2smn6fC0ovIsW1nbsUeTO VnxKo2nP8QC4
6gnZxmuyqFpLaeOEs8UiSlWiyQQ5HzAr69MjHpmgDNsZTBFczGO+kij3tbI4 kLtGFQsCG5Lb
92N3PpxR9imMNvZTLua5cz3siglWxglAe4JKqA3WNWHatio554baFpriWOGJ fvPIwVR25JoA
5+5i1gpdLFJJw8sCHL5PmsSrj2TdEM/wgS9cCi5i1gpdLFJJw8sCHL5PmsSr j2TdEM/wgS9c
Ct61u7a8jMlpcRToDtLROGAPpkfWpqAObuYtYKXSxSScPLAhy+T5rEq49k3R DP8ACBL1wKva
mt3cT24tHlSKUSW0hG5SmSpL9OMKjhW/vMvUGtamySJFG0kjqiICzMxwFA6k mgDFhnvI7Sd7
83cTzy8PawmTyiqopAUqxCsyuwOCMHJIJFDLLHo+nwPDPDHDsju47cSbkAiP ClcsQHKDKk98
nG6tKDUrC5Vmt722lClVYxyq2CxwoOD3PA9atUAczGmokXEjG82LHEEG58+S biTdx1L+SF5+
+OO5p1jm9kuLGL7W1mbvLm58wkRrHETGd/PzM3Q8Fd/tXQTwQ3MLQ3EUc0Tf eSRQynvyDRBB
DbQrDbxRwxL91I1CqO/AFAGDqjNqyXlt5FyJUjmjtozbuqs+xl3mQjbyCQoz jByeSApOzTaz
HqaQXP2WIxBibdw/CTg4QjceZU5A7+xx0VVYdSsLiOWSC9tpUhG6RklVgg55 JB46H8qAM22g
mC6axikA/tC4mOVIKo4nKkjt95evQnB5p08Ut1JNI9szPPJ9mg3qwEKLkmQ4 5GWUkFSM4i5U
8jYaREZFd1UudqgnG44JwPXgE/hTqAObvtOmnkt7IrJ5iXf2gXgQsCxjl2O3 bcrKoI+7jaBg
EKIXtLmGW7u57eUyzmynmCIXwVnYlRtzu2IFBx1xnvXVUUAY95cQXHk3UZ1K 3ZN8YmitGLAH
aSpRkJwcA7tuPlxkdDDM128kLX6XkcjW0ZjSy3YWf5t4OCV/uY8w7fw3VvUU AcybbUbe1aWx
Nz9qlubtQjfcVT5zJ8p+UZcIdx55xnBxTbW2upZIImuL6S1a4G8hJ4CMRy55 dzJjPl+i5xjJ
JrqKKAOXQ6iLELKLvE9vbyTSMJWaKRt5kIVCH6qg2KQF3ZxjOc++sb6+slkl 02O7kWyu4xLN
G6ycSAR4VlLbtuCoJyctznJPcUUAc7BaXc2rtBN9pt7NQ/7uCRkjGI7faqsA MAHfjGOjf7Qq
x4cjuQtxPfJKtzcCGV94IB/coDx0B3K4I4PAzxitqigAooooAKKKKACiiigA ooooAKKKKAK9
h/x5x/j/ADNSSnDw84y/r1+U+/8Aj9O4jsP+POP8f5mpJd2+HHTfz16bT6fh 14/HFAElUL+R
o7mIpcQwOYnCvMu5c7k7ZGeM96v0UAYmitcmKxjubqGe5S2Icp8xX/V5DHcc twfm7+lQeKIP
OitlcB5gxKlWKALgbu574P8Annfh5hj4I+UcEkkce/P51HdQ2siBruOF1ToZ VBC5+tJtpaOw
WjLSWxx1jHPbOY0BVJiAw8wOWIztHI45I/Wur0mcT2CeqfJ+XT9MU6GysDtl htrY4OVdI16j
0IqxFFHCu2KNI1JzhVAGayUJc/O3cv3Iw5ImJp1nc3UDrJcRC0W/mk8tYT5m UuGYfPux95R/
D0496o6Vqklvo1pbtNtmL2SQptyfJZYQxxj7uS43HvxnOBXWUVsQc3p2pXc9 3AsV5HdXMlo8
s9nI6IsEgaP5TtUsuNzjDZPHPrUZ1LUWXVJhd7UsYpJlTy1+crNOApOPu7Y1 BxzwMEc53rXT
7e1kMkfms5G3dNM8pA7gFicZwM464HoKtUAZOoXdtZ67ZSXdxFAhtp1DSuFB O6LjJ+lZs9ze
2NlaRJNHZQO87iSeQQhV8z90mWRgPkbhMAgL22kV1FFAHM2+qXTXbLLfqbsT wILFVUBkZIi7
BSvmcbnbk8beehFV7bVdWlh3G8thLIYQ8YPmm3dpY1KsoRdnDMCrMW44PBNd VFBHE8zxrhpn
3uc9TtC5/JR+VSUAc7JfzRXclpdam1tbwyOv2xxGrM2yJlUkrs58x+AAcIPQ 5o6Pf3wGmwLc
QRxrFbIkDvhpUMaFmCbCzdWG4MANvIwpz2FFAHLxalqMdhYSzXfmNeWizSP5 aqIBviVmXjss
jMS2Rlc4AyKdd6pdRIgsb9byMxyHz2VQMCSEFi4XadodzuA2jHIJU101FAHM rqd2tlE8moxE
GcqksQEvmjC4G7Yqv8xOVQBiAQp3KQemoooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigCOf/Ut/n/P+eR1qn09sf5/p+nbHy3J/wDUt/n/AD/nkdap9PbH+f6f p2x8oBRvv+Pi
D6/0b/P+HQS6B9+7/wB/+rVFff8AHxB9f6N/n/DoJdA+/d/7/wDVqaJluv66 GrcHFvKc4wh5
zjHH1H8x9akqO43fZ5dn3thx1649ufy5qSkUFFFFABXP3Mt159sLXULSBEuZ TKkgyR/rOW+d
cjJXjHXBzxXQUx/vx8E/N2J44Pp/X+eKAK1kXe3ZopI9pkkKnbuz87c9fp+v rxmS2v2nefJu
DiVgWQrggTb+DuBB4xkY/HArfrOkbTWkcvbK77iGb7MWyc887eaqLJkQsDFM kiQXEeTHFmRk
YY3jkncSTzgE5x2xk1o3bTpayNaorzAfKrd/1GfpkZ6ZHUUvN0qBmcRQI0TH kRDI2kBmHHQE
8ntg+hrTokxpGTLKBp8BS5lNmxP2i5LHzF5Oc9NnOQxGNnQBeqVbi/vh4gMC 3EEcayxokDvh
pUIUswTYWbqw3BgBt5GFOegoqRnN6LPDd2egLZyxyy20Si48tgTGnkkFWI6Z fZ8p6lc4+U4o
3Gp3F5K8BulETlLgqJEaW0CTxZ3KEGzaGJIbdjb14OeyooA59dVnPiOO3E8f lSyvEbZ5V8xA
qMd2wIGAJQEEsQQw45GJIZ5LbQp7iNtoivZnkbGcRi5YyH/vjd7+nNblQ3Vr FdxiOcMyA5Kh
yA3swB+YeoOQfSgDm59UvIprnzb9oJ1gM1passam4Jkl2KVK7jlVjGBhufWp odQupdUniu7u
CO3DzJLD5214ol3YfAQMmQFO8vj5uMZXHQLBGtw9wF/euiozZ6hSSB/48fzq SgDJaaf+zUeW
SVJ/MxbELiSbg7d0fA5Gcg4wPm+Qj5b073S2LPDFGbrZnZuyue+CcZ74ztz6 rnIsUUAYJEsu
o6cdPu1J+zXBaW5jaQn54twIyu057cYwRgdBGzXWnXMkEd0xVTbOyhFCs89y 3mHkEjjIAzwD
3PNdFRQBy9jqF/5FrLLeSTForOVg6IAxnfYwOFHC4yMYOTySOKh0u5vpkQre NFcahJEWJjU4
zZZEgXHd0+nyY9a66igDm7rVNRe0Fyhjs4nlWBvMkULCVVjIxkKsB+8xHypB 28feBGxpMs0+
mxSXDxySHPzx5KsASAQcDORg5AAPUcEVcooAwbO6ez8O6FPlhAI4Vn2puJUx EKAACTlyg45/
DNVbPUb1ZxFdahm/jlt4msf3fzBki8xsAbjjc7ZBwNvoDXRTWsVxJE8oZjEd yrvIXPGCVzg4
IBGQcHkU6KCOJ5njXDTPvc56naFz+Sj8qAOb03Ubq5SQ6hfRopiDyJBJult5 dy7U2iMbTkkb
GLliMc4bOlqrTv4Uv2ukVJjZy7lXt8h9zj6ZOOmT1OtRQBgz3qXemgDULO9d Ly2ybUYCgzJj
I3N6HvVPUZ9Qm0q5zM0/2qS8tEgWIcKqzbcY5LZQD0wemea6qigDm/7RvTrE cUV9A0IeJY1e
QbriMqpaQIsZLdW+ZWVRt5GAc1TrF5sjMOoLLcSW2+5t2MYFo/mRBs4Xcm0O /wB/djbkg4Nd
dVW10+3tZDJH5rORt3TTPKQO4BYnGcDOOuB6CgDm5rnUL2wntjdLcq9ndlfs +JPPwsYUbtih
sF2+4B0AOSDVjW7u2vo7qSzuIrlItLu1kaFw4Qt5eASOmdrY+h9K6aigDl59 Wu4WI068/tKM
ZKSbUfzH8mZvLygAOCkZwOfm64Iot9Tu/KxNqcBtTKqveRSpJ5IKuTl/LWMc qgwQT83+0tdJ
LBHK8LyLloX3oc9DtK5/Jj+dSUAYumMZNaklN00yPZxiN9gUTBZJPm6c4BXl cKd4OMFcbVFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFew/wCPOP8A H+ZqSUZeHjOH
9Onyn2/w+vYx2H/HnH+P8zT5v9ZBwD856kcfK3r/AE/lmgCWqF/G0lzEEt4Z 3ETlUmbaudyd
8HHGe1X6jlghnx50UcmOm9QcUAZGirciKxkubWGC5e2JcJ8pb/V5LDaMNyfl 7etWrycx3EBm
AXCOwCsTz8o9BzyR+PvirNpBbxxpJDFGpZB8wVQSPqvH5cUtxaQXWzzkyUOV YMVI9eRzUTi5
RsiotJ6mVO05jkeKPa79MXDA5weSBxkAevatOwuXu7fzWiEfzEABt2cfgO+R +FRvpyCPEDsj
Zzl2aQdCOhPuams7f7LbLDu3YyScYySSf61lTjUjPXYuUouOm5yV5PeromrW aN8sz3kySYHy
RrJJ5i478hRnr++4+5Wta2ST+INQmk0+zlCXK/6RIcyoRDGRtG098fxDqfx2 jBCYXhMUflPu
3ptG1t2S2R3zk59c1C+m2El0LqSytnuAQ3mtEpfI6HOM8YFdBkZ8VpYW/iO+ umt7aIx20Upl
KKu0lptzZ7ZA5PtVfSL+Vbpmkhud95G0zxSQNFtlHSNS4AY7MLwQP3Rb+Imt 54IZPM8yKNvN
TY+5Qd688H1HJ49zTmjR2RnRWKHcpIztOCMj04JH40AcvdpPc3h8gtBcHVFd A7Yw4swwViue
MjDY6jNRyOmpXDFLWK4DauVaC5OF3LaYYNww4IPQEZHHrXVeRDv3+VHv3792 0Z3bdufrt4z6
cUeRDv3+VHv37920Z3bdufrt4z6cUANtIEt7WOKOCK3Cj/VQj5FJ5OOB3z2F TUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBHP8A6lv8 /wCf88jrVPp7
Y/z/AE/Ttj5bk/8AqW/z/n/PI61T6e2P8/0/Ttj5QCjff8fEH1/o3+f8Ogl0 D793/v8A9WqK
+/4+IPr/AEb/AD/h0Eugffu/9/8Aq1NEy3X9dDVuBm3lGM5Q8Yznj6H+R+lS VFdcWs3APyNw
SADx78fnUtIoKKKKACufuYrrz7Y2un2k6PcyiV5Dgn/WcN8jYGQvOeuBjmug qrLaWhlQtbxF
nc5OxfmOCec9fw5/DNADbIOluyxRx7RJIFG7bj5246fT9fTnJurcXSSRl5Np lYMvkuwGJ9xI
4KngEcg9unOegjjSJAkaKijoqjAFUZBpyyOGugjbiWUXTLgk88buOauLJkVS IlmDfvJBI0as
JbdhvbePnJwADgDpjpznAxqXcz29rJLHC0zoMhF7/lk/kCfQE8VW8qxQlmmY +XIAd87EBsjA
IJ9Sv5ir9KTQ1fqZstxKlraot0r/AGk4N4FGxd3I2jkc5wucjpkscBq82qXw 1aSKK2U2kM8c
EjsVGSwU53FwRjePlCHOMZ541jBCYXhMUflPu3ptG1t2S2R3zk59c01rS2e6 S6e3ia4QbVlK
Auo54B6jqfzqRmDosENpZ6A1nFHFLcxKbjy1AMieSSWYDrh9nzHoWxn5jmO6 1e+n2Rx/u4rl
4pbW48vaCnnxDkCQlgRIM52ccY546C0sLOy3/Y7SC3343eVGE3Y6Zx9TTV02 wWSaRbK2Dzhl
lYRLmQHqGOOc980AZ7ajLPqa2z26zadcyPbBmjAG5VbcCS5LcowwUA9z3h05 YdL0ie4tLaCI
/bXWVljCgRi5ZSTjHCoSeeAB6VsfYLP7Z9s+yQfav+e3ljf0x97r04pt1YRX Nq1tuaKGQnzU
iCjzA2dynjvk5IwfegDHOs37JeXCfZhBaQNcbTGxMyeZKF2tuwMpGpBwR82e nFTQalf3V80R
h8m0kllt0lGwMpTcNwJcljlD8uwYz1IHOhJpdnNqP26aCOWcIioZEDeXtLEF cjIOW/QVI1hZ
tNLM1pAZZk2SOYxudemCe44HB9KAKf26Z9L+1+ZGjRvwwU+XcjoNo5YBs8Yy c4xvGN1ye4ki
sWuFtpGkCbvJ/iB9DjPTvjJ44BOAZmjR2RnRWKHcpIztOCMj04JH406gDnb6 3N5f6YGhs9UL
W08mZyFjOWiO5cK3rge3c9wSXNgfsUi2zxRG3fyyhbYZbkgKpyOEAAXgdAeM YreSCFGDJFGr
DdghQCNxy35nk+poeCF2LPFGzHbklQSdpyv5HkehoAwbPWb94raWf7MweO2l dUjZcidtgAJY
42kEk87s4wvWqumXt5NBE8SWm6aWNbeN0OyBjZb/AJeflXOBgDgFuueOmFpb KoVbeIBQigBB
wEOVH4HkelCWlsjRslvEpjAVCEA2gAgAemAzD8T60AY82tXcqI9jaMRNIkMa yIN4fYzvkFlB
wAFxuBDB+uMHQtManpgGoW0TFiyyRNtdSVYjkAsOozjJweMnFWJLS2lt2t5L eJ4XJZo2QFWJ
O4kjp15+tSRxpFGscaKiIAqqowFA6ACgDB0qWHSvD+jOkcFvbzJGbmQgKq5i J3k8DJYKMnrn
HpRZ6tqTxC4uVgRElt4ZIPKZXDSLFk7i3GGk6bf4cZ71rTWEUq28YZo4ICpE EYUI20grnjI2
kAgAj3yOKbFpdnHfzX3kRtdSvu81kBZPkC4U4yBgfqaAMuw1W/vYfMuFjsoZ rf7TFK+wBANp
wRvJdcNy2EwPQkYtarM9x4Uv5ZIWhd7OUlG7fIfXB/MA+oB4q8lhZxtIyWkC tK4eQrGAXYHI
J9SDzn1qaSNJY2jkRXRwVZWGQwPUEUAZ+nwwaeFV7GzsZbmTYq2vIfClhk7F 7Buo/HmsmLVb
iw8Pae1pF532fT457hNgOE2cfMXXGdr9A3Tp0zuJpOmxwyQpp9osUuPMRYVC vjkZGOcVJd2F
ne7PtlpBcbM7fNjD7c9cZ+goAotqssNxJFcIqC2MktxJsbaIAMqV75OVHTBK SY6Cs83V1fX9
tp2q2qgeerOjxqFkRopiAVDuDhoweT1xwMZPSCNBI0gRQ7AKWxyQM4GfbJ/M 1VTSdNjhkhTT
7RYpceYiwqFfHIyMc4oAy7k2umanELIRx7bedFijG5VkZ4AqhcgDJZTjKj5s kjJNCazfeUyz
RwQzQSlZvNGPlCo2dqs21fnAL5bbwSME7dhLCzSEQpaQLEEZAgjAUK3LDHoe 4702PTbCKNY4
7K2REkEqqsSgK46MBjr79aAIbS9mm1GeGRoPLG7ywhOSFO0kHo3OQRwUIwQQ Q1aFRpBDHNJM
kUayy48x1UBnxwMnvipKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
igCvYf8AHnH+P8zUkpw8POMv69flPv8A4/TuI7D/AI84/wAf5mpJSQ8OA3L8 4B/unrz/AI/1
oAkqjflhPHtjnmxG7eVDJsZjlB1LKOMnqavVFNbxzMrPvDKCAVdlODjPQ+wo ApWrv9qjJt7u
DcjgxzShycFPm4dh3PfPWnXkoMsSTKUjKM7K+MHG3r1HGT+I+hqxb28abJcy M+zGXZz1xnhi
cdBTbyxjuzGzs6PGTtZCO/bBBHYH8KiabjZFRaT1M6S4lhgdrZLhAfuKBHtz jjjqBxnGPWtO
zulu4TIiOgzj5wOfyP8AnBqs9i6qVileVwQ2JcAdGHBC+9T2kf2GwCzMPkDO xHIHJNY0lUUr
S2LnyuN1uZr69NGJnazj8qPz3yJzuMcL7XONv3umFzg85IxzJNrv2dXuJrb/ AEMPNGro+ZC0
YctlcAAfu3wdx7cDJxafTbF0dGgJV0lRhluRK25x+J/Ltimx2GnzSyyiLzMs yvG7MUVjw37s
naCQTk45DHruOekyM2bVryy1KcXNspkkjgSGGGV5UyTMSxwm4cIeinoO3Iua Xey3uozu8csI
+zQnyZAw2tvmBIBAPO0ckAkYyB0qZdFshvO2dnfbmRrmRnG3ONrFsr95uhH3 j61YtrG3tGLQ
R7WZAjHcSSAWPOepy7EnqSec0AWKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKAI5/9S3+f8/55HWqfT2x/n+n6dsfLcn/1Lf5/ z/nkdap9PbH+
f6fp2x8oBRvv+PiD6/0b/P8Ah0Eugffu/wDf/q1RX3/HxB9f6N/n/DoJdA+/ d/7/APVqaJlu
v66GrcHFvKc4wh5zjHH1H8x9akqO4JFvKQGJCHAUEnp2wR/OpKRQUUUUAFRT sVMZAJO4/KDg
t8p46j+v9RLUcpIeHAbl+cA/3T15/wAf60ABkYZ/cyHGehXnr7+w/Me+MC7Z nSSOO8iizKwI
MoRlPn5JPIONuehHfrkY6Oqn2IqW8u6mRWYttAQgEnJ6r6mqi7EtGYUtTPhp radZdqsqSAEs
zjdtGSQp6kZOfbnOxd3KWdrJcSBikYyQv/1+B9TgDqSBzUJtMkeZdzOqup2n YBkEEdF9cVco
kxq5RlubmKOCFhF9suCQp58tOp6nBbA7DBbBOFGSteXWmXVms47OWVI5Fikk VHOGYA54UrgB
gTlgevHTN77Db/Y/snl4gHRQx+XnI2nquD0xjGBjGBTX061kuhcMjb8hiA7B GYdGKZ2kjAwS
MjA9BUjMnSS9vZ6JMJ55GvkVZxNM0gJMLPuG4nacr2wME5HTDbrxBMzNDbRK HaSMwSZfZKnn
RofmZAOQ45XcMEnPTOtY6XaWGPs6SDamxfMleTYvou4naOBwMdB6CoxolgrF hFJ9wooMzlYx
kHCDOEwVUjbjGBjGKAIX1VZdT/s9omMMxaJZ4mkHzBSWG7aFGNrD5XJBHQc4 h06QWGnSXBae
dnvWt/3tw74H2gxrjcTjAI6dcc1oDS7QXi3QSQSI5dQJX2BiCCQmduTuPOO5 PU02704TafLZ
QOsMU5fzsqWJVyS+3ngksSDyB6UAUW16bN26WcZgs0eSZjOQ21ZJEO1duCcR E4JHUDPepIdZ
lur6S1gtZFTfJEk5jkZVdMglvlC7cqRw5PTgZOJn0W1kvTM4YReRHCsCMyJt UscFQQGBDYwR
jA96mOl2nnPLskDNuOBK4VS2csozhWOT8wweTzyaAIzfyNYvcqkam3dhOjP8 pC53bXOBx1ye
OCDtOdtie8jgsWu2WTywm/G3a2PcHG33zgDvgA05rWBo4Y/KURwlTGg4UY+7 wOOOoHYgHqBU
1AGDqRuXv7CKeK5mLQTu8VjcGLBDR45LruwCRnvnOB0BHfXNsBaXULMIzC24 3BDqJLgrGpwD
naoG47jkjHOSa1obG3gaJoo9phRkj+Y4VWIJAHp8owOwGBgUS2NvNK0kke52 8vJ3Hny2Lp+T
En+dAGXaa9NMkEk1nHGkqQSNsnLFVmbbHj5Rk7s5HGByCelVbDV7maFHS2aU NIi20f2khgTa
eZtYkfNzxlieWzxtFbSaXZIiIsOFRIkUbjwIm3IOvY/n3zRBpdlbmEww7PJ2 7AGOAVQoDjPJ
2kjJ5Ix6DABRn8QxhA9pA1wjmNInAf5nZDIQQFLDCBTkKfvY4wSL0DjU9NVp op7fzOGTc8Tg
g9j8rAHGR0JB5AzinPp1q9v5JRlTzGlBR2VldiSSGByMlm6HoSOnFTQQR20K xQrtRffJJPJJ
J5JJySTySc0AZOjTm20nR9xlme+Cb3lmZyGMJcn5s/3OgwOabZa9NdRJcGzj S1LwxswnJcNK
sZGF24IBkAzkdCcdquXOlRz2dvYDy1sYtgaFk3lghBVck9PlGcg5Hp1oTSIB f3F3K0kjSyrK
ELsEUhFUZTO0nK5yRkcegoAq6frVxqan7PZtEHjEsLypIEZcj5WJUAEg8bS4 6nnAzNqN75/h
i8vLZpIybSR0bOGUhTyCP0IJB6gkYNTLo9iquohYow27GkZlVcg7FBOFU4GV GAQACMVauII7
m3lt5l3RSoUdc4yCMEcUAU9NSOBSWju7Z5X2LHd3XmsxAJ+X52HTPTnj2rNj 1xrDQtNmkRrk
/Y0muDl2dV2g7uFYc4blioJB5641BpNr5bITcsCQwZ7qVmUjPKsWyvBIOCMg 4NF1o9jdRiOS
FlQR+VthkaIFOykKRkDJwDwMn1NAEY1dBceRIixukkom3PgRRoM7ycYOQ0Rx 23/7JrPGqyal
c29jLFLalpwJQjSR7kMcrDDMqMPmj5wMdsnJFbjWsDySyPErmaMRSBuQyDdg EdP4m/Oqq6LZ
Deds7O+3MjXMjONucbWLZX7zdCPvH1oAzWmu4LtLa0ZpRFqPlIk07DKG1LkM +GJ+Yk857egw
5/EIjlbbaSNcHbFtDuy7w0wYYVScDym+YLk5XIGONJtIs2gSIrLhJPNDieQS b8Fclwdx+U45
PTjtUY0W18+RsMEaONVCsyurKZCW3g7snzDk5yeck5NAEcGrXNyQsGntvSMS TRyuY2ALMo2B
l5zsYjds4K9MnFjSLie5tpnuNpK3MyIQeqLIyjIwMYxjv0znmhtHsWVFMLAK NpAkYeYMkkPg
/Pkkk7s53N6nNqGCODf5S7Q7lyAeMnqQO2evHck9SaAJKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKAK9h/wAecf4/zNSSjLw8Zw/p0+U+3+H17GOw /wCPOP8AH+Zp
8xAkgzjJc4z67W9v8P6EAlooooAjtxi3iGMYQcYxjj6D+Q+lSVFakG1hK42l FxjpjH0H8hUt
AELMI53Yq3KDlUJ6bj2H9fwGeYr6VTY3K4fPluPuHHQ98ex/T1FTKR9qkHG7 YufXGW9vr3/L
u28RpLKdEXc7RsFHqcUAZ2oX81te+Wkj/MQEQKCDwOOme9OQh/EqSQSM0b2j iUBiVDBk25HY
4Lfr71OhLXPmNp1yGYjLM6FV98bz+gqKwtZ47xXkiKKkPl5JByfl6YPtUVJt OKivUIQ+Jt+h
JrEt1BHbyW00cafaIkkDR7mYNIi4BzgcE9j+HWqtxeXS3VxMs7KlveQ2whCr sdX8rJJxuz+8
OMEDgcdc6l1bJdRLHIWAWRJPl9UYMP1UVXl0uKS6aYyyhHkWWSEbdjuuNrE4 3DG1eAQPl6cn
NgZukS6hPDFHeXV9BeTW4fbcRQ7eNu9lCjII3AAP/eGQcEVCNUnNwtq93eLF mQrNHa7p22iI
gOmw7eZG6oOAh75bWGlKGLteXbuEKQszjdCCQcAgZblV+/uzjnOTlo0dVbzU vLlLoli1yNm9
8hQQQV29EToo+77nIA671W30/ToLm4mjlEu1VaNlRZCRnILNtAwCeW9sk4zX TxHbShWggnmQ
opLpsKhmdkVc7uSXUrkZXoc45q02lxfZoYIpZYRblTbsm0mHCbMDIOeCfvZ+ 8fbDf7IhJLPN
O7t5O5mYEkxyGQHp3ZjkDjHAAoAamt2zPHHslEkhCqhAyzbyjgc87CpLYyAO eRV+QOUIjZVb
sWXI/LIqguiWyzCXfKXWTzEYkZjJkaRtvHG7dtb1UAVpUAV7V5JbCFyw8x4l O4jjJHXFJbF/
MlUyNLGuAHYDO7nI4A6cfjn8HLbhbdYFkkVVj8sEEZ6YznHWlghMK7fNd1AA AYKAo9sAVOoy
aiiiqEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBHP/AKlv8/5/ zyOtU+ntj/P9
P07Y+W5P/qW/z/n/ADyOtU+ntj/P9P07Y+UAo33/AB8QfX+jf5/w6CXQPv3f +/8A1aor7/j4
g+v9G/z/AIdBLoH37v8A3/6tTRMt1/XQ1bgZt5RjOUPGM54+h/kfpUlRXRAt Zi2NoRs56Yx9
D/I1LSKCiiigArCu9REFxbrNJds0s8ijyrfeEA8zBBCHJ+XGM5wSelbtUnsw JI8XDj96zqCE
+ViGJ25UnPJ/AmgB9tOfJPmtI7K7jdsJyAzAdBjov8vUVj3dtNKkjQWyMzys BJsBOfOwckg4
AXPOD39Od6CIQRbAzNyWLNjJJJJ6fWqLaVl3bFq252bMlvubkk9d3vVxdiZK 5Wlsj5ji4V1j
lKsxRs7XZ1BAP8XQckArxjtt15547aFpZm2ovtkkngAAckk4AA5JOKorpWHR sWq7XVsx2+1u
CD13e1aEkaSxtHIiujgqysMhgeoIpSsCv1Kr3kiQxhrf/S5s+Xb78nHqxHAA BG48gE4G4kZr
z6/YwaoNPd/3u9Yyd6DDNjaNpO45yvIUjnrwcWmsUe1SBpZSYzujlLZkjPOC D3wDjnORw2cn
LTp6/bGnS4njWRxJJEjALIwAAJON3RV4BAOORycyUZ+lXN2lrpM1xdSXX9oI oYSKi+WxiMmV
2gcfKRg56jkYOS68RxLJNb20e+6hlRPL3xsXBlVGxtf5T8wxu28n2OLlhpKW Swqbme5W3QJA
JtuIgBjjaoyccZOTjOOpzCNAhBQG6uWSGPy7dCUxAAyMu35cnBjTG4npznmg CSTVrdtTbSvM
aK4YEI6vGxzt3cLksMDJyy449xmHTrmW3sZLi8up7nddtbqGVBt/fmJT8oHs Tn049KsLpKJe
RzrcziOKV5kg+XYHYMGOdu7nex69/Tim3enOdMls7TbmaR2MkjYMRdi+9cDk qxyBx0HI60AR
tr8IeYC1uWjtwzTSgJtjVXdCSC2TzGx4BOPfihPEFpNqD2FuVa4BdEDSKAzq DlSAS69DyVxx
xnIy19CV7uYCaSKzlt0heFCCZfmkLbywJ539QQSSSTnmrSaaI5HaK7uY0Yu6 xKV2o7ZJYfLk
8sThiRk9OBgAd9v3W/nRwSN5b7Z4v+WkXHPyjOSMg4HUHK7uAZnuoI7UXJlU wkAq6/Nuz0xj
rnIwB1yMVG2nwNapagMIActGDnzOuQxPJyTk8898gkGxJGksbRyIro4KsrDI YHqCKAMXUb24
W7so5JbuyWWKZ2S2iE75DIFB+RscMc44zxk8Euh1WRY1gukuVlUxnzQiDKPM Uj3A8gsBlhtG
OehwK0IrFI54ZjLLI8MbxKXbPysVPJ6nGwAE8+uTzTbjTYbid5naQM/k5AIx +6cuvb1PPt6U
AVbbX4bhYWNrcxJKI23OE+VZDiMnDH7xyBjJGOcDmqtprxki8xo7uSNXUQlE QvODbebtYA/e
6/dAGSoHGavR6JbRxRxq8uI47eMZI6QsWXt3J5/pRaaJbWn2fynlxAUZQSDu ZYjFk8d1I6cf
KOnOQBt5r9jaKzl/MT5Arq6BHLAsFDkhQdq7uSOCuM5FWILhNV01ZrS4kiWT pJHtLKQcEDIZ
TyCM8j0PQ1GNHt0t1igeSFklM0ciBdyEgjjIIwFOwAg4UAdhVyCLyIVj8ySQ jq8hyzE8kn/A
YA6AAcUAZukXki6Xpkl3PLcTX4UhmVBtYxlyPlA4+U+p5otdfhugjpa3KwMY lM7BNqtIqsoI
Dbv41HAxk+nNOuNLY2Nlp8B2wW+wGYyFZUCYHy7QOWXKkgrgMevSmw6KFu7h mmZbVp45Y7WM
KE+REC5+XIwyA4BxgD3FADbPxFbai0kdgvnSqnmInmpmRAQCRgnaeRgPtyTj jkixqN9jQLy9
s5PmS3kdG28qyqeoPQgjkEcEYNEOlLDD5KXl35IQRxoHCiJOPlBAB6ADcSWA 6EEk1YuLKGfT
pbHb5cEkRhxGANqkY47DigDN+0SxWHnxXt5MWuYIv9KtxGVBlUNgbFPIbGef atC7vRbSRxJB
LcTSBmWOLaDtXAJyxA4LL3zz9ahk0x5rZ4Z9Ru5dzo6uwiDRlGDAjCAdQOoP ShtMdtjnUbv7
Qm4LPiLcFbGVxs24yoPTPHWgCOHXrWd/3Uc7Q740M+zCAyKpTqcnO8DgZHfA wTJZ6sl5cRRL
bTok0TTQyvt2yICvIwxI++p5Aoi0a1ht2t4vMSIyxShQ2dpjCBQM9v3a9eev NVdJ0u7tr2OW
4dUhggaCCBZRIEUlTgHYp4CAc7ifUY5ANqiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKAK9h/wAecf4/zNSSnDw84y/r1+U+/wDj9O4j sP8Ajzj/AB/m
aklOHh5xl/Xr8p9/8fp3ABJRRRQBHbnNvEc5yg5znPH1P8z9akqO3ObeI5zl BznOePqf5n61
JQBC0qRzvvkVRsH3mx/ePr6A9u3U44VriBQS00YC5zlhxjOf/QT+R9KVT/pD jP8AAvGfc+/9
PxPaSgDlINas3uistvalHYEszAsNzEkkkdsj6e9b9iGikkty+9EVWXI5GSeP pxWTbaK0N8rM
l0Y0ddvzx7cKx2k85xjHGM9etW9MikW+3GJ0Ahw5ZCoL/L69e/NRVlGMoqC3 FRjUcZc7LOqX
VzaJA8EUTo88ccjO5BUNIq8ADn7x7jHv0qvPqNyl1MyeV9nguYrZoypLuX2f MGzgY8wcYOdv
UZ4vX1r9rgWPfs2yxyZxn7jq+Px24/Gqs2lvJdSMLhVt5p47iSMx5cum3GGz gD92uRgnrzyM
WMp6Pqd9qNqknn23nSwLIsT2ksW3OMsCzHzAuf4euRyM5qM68+6OF77T4Qxk 23rj9zMFEf3R
vHeQj7x5jPrxoDT7sz+fJfq0sUbRwOIAOCVJ3jOGzsUHbt6tjGRiNdKuY7g3 kd3EL1y29mgJ
jIYIOF3ZHESfxH+L1GADQNwIxbrcbUlnOwKpLDftLEA4HZTyQOlVW1uwWVo/ NkLLnO2FyAQz
JjIGMlkYAdSRxnIpv9lvHaWkFvcKpsiv2dnj3YAjKfOARu4LHjb29Oa8GgGE SbrxpC8kblmj
AJ2XDzc445344A6Zx2oAuWmoC7v5ooirQpBHIpwQ25mkVgQemNgGMZBzmppp ZY7mBAqeXIxU
sSc52sen4dc1X07TPsN1cTedv87PG3GP3ssnr/01x+Hvxbli8x4Wzjy33Yx1 +Uj+tJgJOZQu
Y3jjUAlnkBIA+mR+ee1OhdpIY3ZCjMoJU9VOOlRTwzSlCssY2kna0ZIPPHcd P58+lTruCjcQ
WxyQMAmjqMdRRRTEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBH P/qW/wA/5/zy
OtU+ntj/AD/T9O2PluT/AOpb/P8An/PI61T6e2P8/wBP07Y+UAo33/HxB9f6 N/n/AA6CXQPv
3f8Av/1aor7/AI+IPr/Rv8/4dBLoH37v/f8A6tTRMt1/XQ1bg4t5TnGEPOcY 4+o/mPrUlR3B
xbynOMIec4xx9R/MfWpKRQUUUUAFYt3rEVtPClzf2lu0krqqvwVA3jc3zjg7 SM46kVtVQeyl
8yIh42EczyxkxnKFg3J+YZ4Yjp3oAmt7oGEmeSNXVmB52jALDOCfRSfwNY97 NcIsjRiZnMhC
nzHwczBMABgOAe5Hb3xuW0Rhh2MwZizMSBgZJJ6fjVD7DcK0mFDBnZgRdyJ1 YnoBgdauLsTI
gdLhpZEeaaESlZATzsLMoAOOMjGBg4/vD+9sySJFG0kjqiICzMxwFA6kms37 DcM0eVChXViT
dyP0YHoRg9K0J4I7mFopl3I3vggjkEEcgg4II5BGaUgRC18iWqTtFKDIdscR XEkh5wAO2QM8
4wOWxg4H1G1juhbs7b8hSQjFFY9FL42gnIwCcnI9RTXs5HhjLXH+lw58u42Y OPRgOCCANw4B
IyNpAxVl0OJ9Wa9xbEvIsrM9sryhlAACuT8o+UdieTgjIxJQ3TNQvJINOmvT A66gilBDGUMb
FC+DljkYB545A4OeJrzWre1R/klZ45EQo0TqWBkVCyZX58bh93PUeopunaVN bRWcd1cxzpZI
FgEcRjwQuzc3zHJ2kjsOTweMU4/DOyfzRPAGRMI622JHYOjq0rbvnOYxnpnJ 6ZoA1pLyM3DW
iO0dwQQjSQvsLYzweA3HOAc4B9Dirp19cG1kuNRmgK/aGt08qFl5EpjGcs2c nHpjNRroe3WI
77zID5cry7jB++bcrDaZN3KjdwMcBVHbNOu7GWLSJbW3VpppJ3ljcYURO0hk VmyeQrYzjJOO
h6UATNrdgsrRmWQlc72ELlUAZlJZgMKMo3JIHBPSpDqduZnhj8ySVdwUBCFk YZyiucKW4PGe
MHOMHGa+iTm5uoIplSzuLZYpndNzyEvKXIIICn58/dIy3A4xU0OhLb30l1Ab RXLySI5tQZd7
5J3PnJUFjwNpwAM9cgF5tQgW1S6BYwE4aQDHl9clgeRgjB4474AJFiSRIo2k kdURAWZmOAoH
Uk1V+wbbfyY55F8x908v/LSXjn5hjBOAMjoBhdvBEz2sElqLYxKIQAFRfl24 6Yx0xgYI6YGK
AMvUNXeGezUXNtp8c8cr775Ou0oFGN64yGJwefUA5qS21mOWFFkkVJ8rlhE7 I6GXy1YEcDfj
K8nAOeQM1ajs5Bd29xNcea8MUkWdmC4ZkIJxxkBBnAwSc4HSo7rTPtN1JN52 3f8AZ+NuceVK
ZPXvnHt70AFvrdhc+V5UsmJcbS8LoMH7pJIGA3QE8MeBkiqsHiC3eJpJZlWO Irul8l9symDz
cr/d4ycHJAHqwp0OheVBFH9pz5cVpHnZ18hy+ev8Wce3vRYaF9i+yBbnesDp IcpgsywGE9+A
RtOOcEHk54AL1xqNrbSNHK7eYoU7ERnY7t2MAAk/cY4HQAnpTvNa7s/MsZo1 ZvuvJGWAIOCC
uQcjBGMgg9emKzW8OwfYEtl8pjHP5qCaLzIzhSiqyk87UwOo5UE986VharZW cduvlgLk4jjE
agkknCjoOfc+pJ5oAq6VfSzadYz30sXm3oVo1ijZQMpv28k9AG54p0Gt2Fw6 rFLIQ2zDmFwm
WUMoLkbQSGXgnPIHWq82nzxadpljbGQy23lhbtdoEYUBWOCTyyFwBhhk8461 HbaNNHPPAGjh
08XEMkcYQs7CNItuH3cDcgGCCeDzyDQBeXVrWRXMPmylRuAWJhvTIBZMgbwM g5XPUYzkZdqF
75GjXN9bNHJ5du80ZzlWwpI6dRVHT9AGnKRayW0JEYiSWK0VZNuRku2TubA6 8DJJKngC9c6f
HLpFxp8J8pJYnj3feILA5Y5OSckkknJPegCmmozCyNwl9Y3ym4hhDW8ZCruk VWz87ZOGyOmP
etC7vYLTYJTIWfO1I42kYgdTtUE4GRz05HqKqz2V/dWjxT3ltvEkckbJbMAp Rw3ILnOcDuKG
sr9pIrg3lt9qjDoG+zNs2NtJG3fnOUHO7GM8d6AJE1jT5LjyY7lXfKglQSo3 AFcsBgbgwwSe
TwMniq9zrtvs2WjM00hQRs8LhGDSIm8EgBwC6ng8jvzmi30NLaya1jnbZ58E qllyQIhEAD65
8rrx16cVn2mlX1w8Ecytb29lAI7fzUXfkPGybtsjBv8AVDP3OvHXgAuXGp3d h58dyYpniNu2
+KFhlJJShATLEkBSRg85HHHNr+17QsreftXY5aN4XEmQUGMHkH51wuMtvXHv DNpVzOk0kt3F
9qkMO11gIQCKTeuV3EnJJz8w4x6c1bnQZLq73XDxy+cjvK/l4j8wNBsGwkkq RDyM888jIwAa
R1ezEauGlYkkeWsEhkGMZygG4dV5I/iX1GXWOoR3091HEMrA6gSLysgZFcEH GP4ugJ7HuKpw
aLJaeXLaS2kFwu8EJabYsNszhFYHP7teSx7+wF6zszay3D+c0onKuxcDdvCh ScjA5Crxgc59
QAAWqKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAK9h /wAecf4/zNSS
jLw8Zw/p0+U+3+H17GOw/wCPOP8AH+ZqSUZeHjOH9Onyn2/w+vYgElFFFAEd uMW8QxjCDjGM
cfQfyH0qSo7cYt4hjGEHGMY4+g/kPpUlAEaj/SHOP4F5x7n2/r+A7x3/APyD 7n/rk38jTmiS
Sd98asNg+8uf7w9PQnv36DPMV/FEthcvsQEROd2Bxwef1P5mgCG6v1tp2jaF CARzu5PA7Y9/
WmxySW+vC0XZ9mngecKAcqwZAcfXcSf/ANeYpBpt5fLI97bSEsNiK4yTxx15 6dMd6bpjCTUl
bIdltyGOclCSuR7cjp7e1RUqRi4xS3CEJPmb2Re1G+axEBFtJMssqRs6soWP c6rk5Of4uwPT
nHWoZtUeO6kUW6tbwzx28khkw4d9uMLjBH7xcnIPXjgZsajbPdWyRxlQVnhk +b0SRWP6Kapz
6dcvdTKnlfZ57mK5aQsQ6FNnyhcYOfLHORjd0OObAj0rWp9UtTPBBZyExq3l w3m90ZsYDjYN
vfPU8HANSSapdpbXMv2W2Bsywud9wwVcIr5UiMlvlbngcjv1ojs79Z45glnE bWBoYUjLbJAS
h5GB5fEeABuxu745bb6VMkUUbLBDAbsTvbRE7I1VflVDgf8ALRVc8DqevcA0 BdLDYpc33l2n
yKZBJINsZOOC3TqcZpralYIyK97bKXj81QZVG5ME7hzyMAnPTiq+rWM18kW0 KDbz+Yiid4vM
Gwry6jKcsemc49+KcWhzRhtpiUMbdivmO2Clw8r/ADNknhup6nPC0AbAu7Zl DLcREMEYEOOQ
5wp/E8D1p8jFELKjOR/CuMn8yKxE0S5W6ScvFiOdpAgJ2yBp3c+YMc7VYFPR 8mt6gCGGYy2k
c4Q5dA+wHnkZxSQzO0jxSoqOoDfK24YOcc4HoabDHNDZRxJ5ZdItuSTjcAAP wpbVJUVhKiAk
5LByxY9yeB7f/WxU6jLFFFFUIKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigCOf8A
1Lf5/wA/55HWqfT2x/n+n6dsfLcn/wBS3+f8/wCeR1qn09sf5/p+nbHygFG+ /wCPiD6/0b/P
+HQU5LeJSWaV13HOOOp9OKuX3/HxB9f6N/n/AA6Cug3NvJILSBAfQbsUXsJp Pcg8mL+/P/37
P+FHkxf35/8Av2f8KtLNA19Jagy5XcAxI5Kg+3tVi5iWGXYrZGM89qFK6uEq Si7SRm+TF/fn
/wC/Z/wo8mL+/P8A9+z/AIU+TUbaOZ4naQGMgOwiconAPLYwOCD14q1Tuxck exS8mL+/P/37
P+FHkxf35/8Av2f8KtJKkjyKjZaNtrjHQ4B/kRRDKk8Mc0Tbo5FDKcYyCMii 7Dkj2Kvkxf35
/wDv2f8ACjyYv78//fs/4Vdoouw5I9iiY4QQDJMCeg2df0pfJi/vz/8Afs/4 VZg+aMSH7zjP
4dhTkZ5UaSKGR4lzmQDjjrjufwBoV2JxguhU8mL+/P8A9+z/AIUeTF/fn/79 n/CrgIZQykEH
kEU0SoZmhDfvEUMRjoCSB/6CaLsfJHsVfJi/vz/9+z/hR5MX9+f/AL9n/Crt FF2HJHsUvJi/
vz/9+z/hR5MX9+f/AL9n/CrRlQTLCW/eOpYDHUAgH/0IU+i7Dkj2KXkxf35/ +/Z/wpBHC2ds
kxwcHCdD+VW5SflUHG9sZH5/0qW3ijcYeSRSZREiRhf7oPcdhk/hScmHJHsU PJi/vz/9+z/h
R5MX9+f/AL9n/Cr8sT283lvkq2SjHGSB64+oqG4njtoTLKSEBA+VSxySAAAO TyRQpNg4RXQr
eTF/fn/79n/CjyYv78//AH7P+FWYJ47hC0ZPBwQylWU+hB5HY8+oqSndhyR7 FLyYv78//fs/
4UeTF/fn/wC/Z/wq0kqSPIqNlo22uMdDgH+RFPouw5I9il5MX9+f/v2f8KPJ i/vz/wDfs/4V
aaVFYqWyw25VRkjJwDgduvPsfSn0XYckexS8mL+/P/37P+FJ5cO7b5k27Gcb OcflVyRtkbPj
O0E4qvcPLAkKw7GllkCZfOCT3pq7dhOMV0GeTF/fn/79n/CjyYv78/8A37P+ FSxR38zlIrjT
ZHAyVWQk4pbKZri1SVwAzZyB04OKbTSvcSUX0IfJi/vz/wDfs/4UeTF/fn/7 9n/CpIb+3mkC
Iz5b7rGNlV+/ysRhuOeD05qzU3ZXJHsUvJi/vz/9+z/hR5MX9+f/AL9n/Crt MllSFA0jYUsq
g47kgD9SKLsOSPYq+TF/fn/79n/CkMcK43STDJwMp1P5VeqJWXDzOQACRknh QOv8s/8A6qLs
OSPYr+TF/fn/AO/Z/wAKPJi/vz/9+z/hTYry5miSdYofIaJnLCQsQew6D3/z 1uyI0NwsZYsG
TdyR7egHrUTqck1B7scacZK6RU8mL+/P/wB+z/hR5MX9+f8A79n/AAqZ72BL jyWc78gE7CVB
PQFsYBORwTnkeoqeruxckexS8mL+/P8A9+z/AIUeTF/fn/79n/CrtMSVJHkV Gy0bbXGOhwD/
ACIouw5I9ir5MX9+f/v2f8KPJi/vz/8Afs/4VdpHYIjOckKMnaCT+AHJouw5 I9in5MX9+f8A
79n/AAo8mL+/P/37P+FXabI2yNnxnaCcUXYckexT8uHdt8ybdjONnOPypfJi /vz/APfs/wCF
WlAjT5mGf4mPGTSptkiZvNIcE4RWXkCsqlb2au7lRpRl0RU8mL+/P/37P+FH kxf35/8Av2f8
KtxMXiRyMFlBxUaXULx27q+VuMeUcH5sqW/DgHrWildXJcIroQeTF/fn/wC/ Z/wo8mL+/P8A
9+z/AIVa81BD5zNsj27iXG3AxnnPT8afTuw5I9il5MX9+f8A79n/AAoMUKgk yTgDuU/+tV2p
LFFkvGL8iEAgH1PQ/hj9aLsOSPYorab1DKLplIyCIjgj/vml+xH+5d/9+T/8 TWm2pXO9glmW
UOVDZbnBI/u+1SRX87TIktq0auSNxJ9Ce4HpT1Fyx7GR9iP9y7/78n/4miui 8yildj5I9hLD
/jzj/H+Zp8wBkgzjIc4z67W9/wDH+oZYf8ecf4/zNSSnDw84y/r1+U+/+P07 hFElFFFAEVqA
LWELjaEXGOmMfU/zNS1HbnNvEc5yg5znPH1P8z9akoAiUD7VIeN2xc+uMt7/ AF7fn2lqFlEk
7qWbhBwrkddw7H+n4nHCtAjAgmTnPSRh1z7+5/T0FAGZFqcU1wY/tk6ksNpE Y2kMTtAJX0A6
+tX7OaV90U64lQAkjGGBzg/Xg1ydrpmNQWOSaBdsiKSLhgxKsQQB1ycfhkYr f0+aRr/5m3eb
AHPHTGMAf99GoqyhCUUm9SaPtJxbkti5e38ViYRKsrGaRY12RlgCzBRk9F5Y dT9M1HLqkUd0
0JilKJIsUkw27EdsbVIzuOdy8gEfN14OHapBJcWqJEu5hcQORnHCyqxP5A1R uLO6a6uIVgZk
uLyG5EwZdiKnlZBGd2f3ZxgEcjnriyixa6s11arcrpt4sTxiSMnyz5m7G0AK 5IznqcAdyKH1
fbBJILG5JhJE67ol8nADfMS4H3WByCffFU7GyksZ1kstIW0SGAxyRLIg+0Nl MEEHLYCvgvtP
zDpkkOhsLhoPJaCSO2uLsNIksgeRYgg4dsndudADkt8jY47AGxby+fbxTeXJ H5iBtkgwy5Gc
EdjUlZ+opO8ltNFbySfZLjeUDKGkBjZcrkgdX7kdD7ZxYtEupJJprqyi81pE wdyvhDdStIAT
zgxuM8DIOMdRQB0i3KNey2oDb440kJ7YYsB/6Af0oe4SOeOEh90hwCFOOhPX p2rN0WxuLS8u
mmj2RFAkXzAgKJpioAHQBGTA7DjtWjOjPLbsoyEkLN7Daw/mRSYDpZTHgLFJ IT2TH8yQKdG6
yxrIhyrgMD6g1BcvMQqpDIUYneUZQ2B0xkjGfXr9D0njAEagJsAAwvHy+3FH UY+iiimIKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigCOf/Ut/n/P+eR1qn09sf5/ p+nbHy3J/wDU
t/n/AD/nkdap9PbH+f6fp2x8oBRvv+PiD6/0b/P+HQVk/wBWg9ZwP/IlWb7/ AI+IPr/Rv8/4
dBVU7o2RoDIu9v7uD8x9TQBf3W/2uZVTDkMud5LZAPXnpwf09eI51ZbiRXzn cSM+nb9KpeTD
/wA+I/75T/GpI8RAiO1KA9doUf1pRTSs3cbd3oUlsXuLnUBLNOkEsoBiAULI vloDyRnnkcEd
PWodsi7TdfbPIaWct5ZkLbvMxH935gu0Hp8vTvitXzG/54yfmv8AjR5jf88Z PzX/ABpiMS1S
5WdjKtyL5pYSxAfyyNkYkJx8nZ/y47VHYRXyNZq7zx7EhCRiJyNgRdwJ3BBz v+8N3p/DW/5j
f88ZPzX/ABo8xv8AnjJ+a/40AYtrFeRxW7E3ZdY7Zjvd2+ZmxLkE8/KBwfu9 Rir+l+Z++En2
j73WbPJ78Hv2O35OAVxkgW/Mb/njJ+a/40eY3/PGT81/xoASEZtYxnGUHP4V HHG6/Z/9Xvh2
Ebg3G2PbgYGMbst1Gc44p8TOkSIYXyqgHBX/ABp3mN/zxk/Nf8aqMrEyjcdE gjiSNc4VQBn2
rL33Ehu7gW0iM0EUTKd2VYF9+MYLbQ2cr1xwc1peY3/PGT81/wAaPMb/AJ4y fmv+NSUY9qb9
IHkiaSUxymKNZY5FDKyrhirEscP3JOF3Y7CluRdQ3tukT3H7poowSsknmpkB mZgdgOC2cjPG
e4xr+Y3/ADxk/Nf8aPMb/njJ+a/40AYAScyQuFvPtAgIumYSYBLx7wmeOgfG z047VYG/ePN+
2/YNzeXt83zM4TGcfPjPm9eOn+zWv5jf88ZPzX/GjzG/54yfmv8AjQAwbtlt v37sjO/G7O09
ccZ+nFPWSJRKWlRXjkJKZG50MYBAHfscdCVFNdnZkIhf5WyeV9CPX3p3mN/z xk/Nf8aNegAu
1bYsk8DJAMKkTKc5JJ6KME8YHfHvmq+q5+xghXbbNExCKWOBIpPA5PANS9Zf MNvJuxjOR7+/
ufzp/mN/zxk/Nf8AGogpK/M7lNroZtyLiZbq6tRJGJEijUsjB9quxc7eG6Mc dGODjsTDEsyp
GLmS8ktMvgxxyo+fl28AmTH+s+9/LbWx5jf88ZPzX/GjzG/54yfmv+NWSYsq 3A85WW4jV5g5
l2OzZEUYwRERnPzcg7QVx6UQm9awle4FwJJWiDsRJ+7HlKSQikH7+QduOpzw MVteY3/PGT81
/wAaPMb/AJ4yfmv+NAGFbJeEiZxcGRvKjVtrrlFuGzkHkfIV+9zgnk/NTgt6 0USxteJKRGLp
ju4k8yPJXdxjHmfd+XHXjFbfmN/zxk/Nf8aPMb/njJ+a/wCNAFWFZI4b6JvM MaMREZCWJXYp
PJ5PzFv5dqkviyLBMFDCGUOQWC8DPc1JKzvE6CF8spAyV/xp3mN/zxk/Nf8A GmnZ3E1dFJde
gM4Agn3Kc83h28fjg1Y09Gjso1YYPJ6g8EkjpUvmN/zxk/Nf8aPMb/njJ+a/ 41UpXVkhKNjN
tpp49HSzghnF7FbbBmIhVcJj7zfKeQBwT+WTUQjlluokt3vUszIu4uZA2dkm 4Zf5gP8AV+2e
mDWv5jf88ZPzX/GjzG/54yfmv+NQUZcX2kT24f7WdsjovXG0OwBJ6H5QM7+o OVO7OYFS5dIB
tuWfMRuhIHI8wSxnK54x/rPucY/CtvzG/wCeMn5r/jR5jf8APGT81/xoAy9G W8E2bmWVmMf7
5WidVEmR0LMQf4vuAL/47V2bzjZsts4SVpdqsegy+PQ/yqfzG/54yfmv+NRg ExFJLdnUsSQd
pHXPrQgI/sN9aiFLp0MLkxlVcEY2ngAIuOnrVkI3mb5JXkYDALY4H4AegqFI oo2DJZBWHQhU
B/nUvmN/zxk/Nf8AGiSUpczQRulYozb4r8/ZhcCSSRC6eXmKQcBm3Y4IUdMj lRwc81ZReyPJ
HHLOvkT7HdGznfLG4wOfuoSDkYGccjNbHmN/zxk/Nf8AGmQhYIxHDamONeio FAH4A0AZrrJH
cPFP9sNkjsFMZkZydsZHK/MRkye3bsKI4LlJJ7gG5En2mEBW7qViVyQvB4yC eQMcYrV8xv8A
njJ+a/40eY3/ADxk/Nf8aAMQLdpYwhvtnn/ZEMGDIf35yW3/AI7Pv8de2aW6 jvUspZYnu2me
S4TGWO1MSFMDtyEwevIAOMCtrzG/54yfmv8AjR5jf88ZPzX/ABoAx5xM8l21 sbyJwdu1xKyl
d43sM8dM7QhBx05OFt2Kyrps4lkkkHzbDJGyHGPRiW65+9/LFXfMb/njJ+a/ 402VneJ0EL5Z
SBkr/jQBKW2vGf8Apon/AKEKbIZ0TDhwWfC72J/hb1dv6U1mLqVe3ZlPY7SP 50xURGDJabWH
cBQf50NJxafUNU7k0aeXGqZztAGfWsays7iKDR2eW4cJjdE6KBH+5YdlBGDx ye9a/mN/zxk/
Nf8AGjzG/wCeMn5r/jQlbQDC8q8nsfJZbtppLHaQ5IG4x45z8vLHvhwR3U8W T5v2keX9r3+Z
F5GfM2+Thd27PGf9Z975untWp5jf88ZPzX/GjzG/54yfmv8AjQBj2y3arZQF 5/Mmghdt8hyh
Rw0u7JzzvAwM+hwBW9ZNtup/91P61WUKkjyJalZJMb2AUFsdMnPNPgLCaR2Q qGCgZx2z6UAW
I7lEG11fIkfP7pjxk4/gP8zTmuFkmhEatw5JPllcDae5QfzpvmUeZTuKxa8y iqvmUUhmpYf8
ecf4/wAzUkoJeHBbh+cE/wB09eP8P6VHYf8AHnH+P8zUkoy8PGcP6dPlPt/h 9exAJKKKKAI7
cEW8QJYkIMliSenfIH8qkqO3GLeIYxhBxjGOPoP5D6VJQBGoP2hzlsbF4ycd T7f19Pxc7BEZ
zkhRk7QSfwA5NRshad8MyfIPmUDn73qPfPX8PVWV0BcPI+MnYNvPXj9R37D3 yAc7a+ILqSdm
lCiIKhKiIjqexJ68jrxx9a0dJ1C0u53WC18mQhmJAX5gGxyR3rCtYYJ2O60e NJLtYvmIKx4B
+UZO7dz6Y/UVo6LYwW+pIyqCfJLoSo+XJHt15xmqqzpRlyNamsXGcOaJtXd7 BabBKZCz52pH
G0jEDqdqgnAyOenI9RRbX1vdsVgk3MqB2G0ggEsOc9DlGBHUEc4qrfubbVbW 7eOVoVgliYxR
NIQzNGR8qgnojc4xx7is+4t7u61eTULKOW3lNtFCjyRj7jPKGODxx+7kwefl CnG41Jka0mqW
iIH3yPud0CxxO7Eo21vlUE4BGM4xyPUU2TV7ONYTulczBiixQSO3ykBshQSM EgEHGDxWTp1u
NJ+yMbadLWD7ZCoSJ5GUNOCnABbBVSc9OnPIy62sbqS6tGWS5tAReSeYiLnD zqyg71OMg5wQ
Dx7GgDoI3EkayKGAYAgMpU8+oPI+hqva6ja3chjgdicblLIyh1/vISAGHI5X I5HqKtVk6Zcr
f3v2mWK5imEZWOOS3kjESEjILMoBYkLnBIGMDoWYA0mnjW4S3LfvXRnVcdQp AJ/8eH51HFfW
80qxxybnbzMDaefLYI/5MQP5VVv3NtqtrdvHK0KwSxMYomkIZmjI+VQT0Ruc Y49xWSbG6aaz
uYoJPOg+2XMIYbclplZVOeFLoWHPIyTjIoA6D7db+f5PmfvPN8nG0/f2eZj/ AL55/wDr1Yrl
4LR9LmVpI55VTU/NkljgZi5a1wzhVBOC5PTgE47Vqajcy3WlSmw8+OQ7CS0E isE34fAOGJ2h
uBhumOSDQBqUVzMCzrHELyXUJbHMmDFFPG+75NvAZpcf637xxn221Mftn2wb vt32rzYfJ3Z2
eThPM37P3W7/AFvXnpj+GgDoKqpqNrJdG3V235KglGCMw6qHxtJGDkA5GD6G ubMOqC1sB9ov
Im+xxlP3csrmc5L7sOAOdnEmV7cANWheXM15LcLDFcx3NuJRZobdwplCsocu V2c5IUZxg5OS
QFAN6iuXt0uki+ee+lsTKvm7YZ43A2vnbuZpT83lZ24H/j9SXf2nY3lf2ln7 P/oGd+fN3P8A
6zbxjHlf63t1530AdJRXL3UV/wCWhaa7ihe4uWkOyeVs+ZiIARsGC7AcY+X2 yQa6KzEosoBc
MzTCNfMLKAS2OcgEgc+hIoAWGeKcMYZFkCnaSpyM4z1/GiOeKWR445FZo8bg DnHX/A1HDlJb
pmVgGlGODz8qj+dKisL+ZsHaYkAOOCcv/iKVxliiiimIKKKKACiiigAooooA jn/1Lf5/z/nk
dap9PbH+f6fp2x8tyf8A1Lf5/wA/55HWqfT2x/n+n6dsfKAUb7/j4g+v9G/z /h0CWjslpIUY
qfN6g47tS33/AB8QfX+jf5/w6COF1SykLsFHndScd2oAhm1G/wDtr29sqybI 1dmkuGT7xYYG
FP8AdpYdZilthcfbQibEdg8oBQMMru54zmqstrZXGoSXFytrMhiREEgVipBY nr/vD8qZJERO
88c1uzi5EyI0mAR5QjwTg47noeg9eADQOqxK8aG/QPKAY1Mwy4PQjnnNOOpI skkZvVEka73U
y8qvqRngcisAW8vmXluGt9lzBiSQyEBC7ykhePmxv9u3TPDp9NEi3CCaEh/O ZHa5c/M4bjZ9
1cbzzz06c8AG1BqyXEskcd2SyMqj9597K7gRzyCM/kfSp0upJEV0nZkYZVlf II9RWJd/u7ot
BLG0slws0RwSq/II33dsBckcjJ47c6Nsbe2tordJlKRIEUswzgDHNAFzz5v+ esn/AH0aPPm/
56yf99Gq/nw/89Y/++hR58P/AD1j/wC+hQBY8+b/AJ6yf99Gjz5v+esn/fRq v58P/PWP/voU
efD/AM9Y/wDvoUAWPPm/56yf99Gjz5v+esn/AH0ar+fD/wA9Y/8AvoUefD/z 1j/76FAFjz5v
+esn/fRo8+b/AJ6yf99Gq/nw/wDPWP8A76FHnw/89Y/++hQBY8+b/nrJ/wB9 Gjz5v+esn/fR
qv58P/PWP/voUefD/wA9Y/8AvoUAWPPm/wCesn/fRo8+b/nrJ/30ar+fD/z1 j/76FHnw/wDP
WP8A76FAFjz5v+esn/fRo8+b/nrJ/wB9Gq/nw/8APWP/AL6FHnw/89Y/++hQ BY8+b/nrJ/30
aPPm/wCesn/fRqv58P8Az1j/AO+hR58P/PWP/voUAWPPm/56yf8AfRo8+b/n rJ/30ar+fD/z
1j/76FHnw/8APWP/AL6FAFjz5v8AnrJ/30aPPm/56yf99Gq/nw/89Y/++hR5 8P8Az1j/AO+h
QBY8+b/nrJ/30aPPm/56yf8AfRqv58P/AD1j/wC+hR58P/PWP/voUAWPPm/5 6yf99Gjz5v8A
nrJ/30ar+fD/AM9Y/wDvoUefD/z1j/76FAFjz5v+esn/AH0aPPm/56yf99Gq /nw/89Y/++hR
58P/AD1j/wC+hQBY8+b/AJ6yf99Gjz5v+esn/fRqv58P/PWP/voUefD/AM9Y /wDvoUAWPPm/
56yf99Gjz5v+esn/AH0ar+fD/wA9Y/8AvoUefD/z1j/76FAFjz5v+esn/fRo 8+b/AJ6yf99G
q/nw/wDPWP8A76FHnw/89Y/++hQBY8+b/nrJ/wB9Gjz5v+esn/fRqv58P/PW P/voUefD/wA9
Y/8AvoUAWPPm/wCesn/fRo8+b/nrJ/30ar+fD/z1j/76FHnw/wDPWP8A76FA Fjz5v+esn/fR
o8+b/nrJ/wB9Gq/nw/8APWP/AL6FHnw/89Y/++hQBY8+b/nrJ/30aPPm/wCe sn/fRqv58P8A
z1j/AO+hR58P/PWP/voUAWPPm/56yf8AfRqlqU0rCzUyuVN7b5BY4P7xal8+ H/nrH/30KqX8
sbtZBHVj9tg4Bz/y0WgC7c381v5RLyFHkCM28/LngH3y20fjntTDqhSS48yc xwwbQ0ryYAY8
459ivP8Ate1MuTb3Nu8LzKAwxuVhlT2I9CDyD6iqbRMLFVW4iM7P5k4ExQSE 9QHHzAA4x3wo
HSgC/HqhkuzCJyVMaOjiT7+7fwPXhCae2pIjIr3qq0jFEBlxuYHBA55OeKwr axkt5EnE1sZI
23qhnJB+abguRnpKOcHJB+tNOmsd/mT28pmDLJi4eNQDI7Z2qfm4f7pI6dec 0AdL583/AD1k
/wC+jR583/PWT/vo1X8+H/nrH/30KPPh/wCesf8A30KALHnzf89ZP++jR583 /PWT/vo1X8+H
/nrH/wB9Cjz4f+esf/fQoAsefN/z1k/76NFV/Ph/56x/99CigDcsP+POP8f5 mnzf6yDkD5z1
A5+VvX+n8s0yw/484/x/maklOHh5xl/Xr8p9/wDH6dwASUUUUARWvFrDyD8i 8gAA8e3H5VLU
duc28RznKDnOc8fU/wAz9akoAiX/AI+pOR9xeMDPVvx/z9ae7rGjO7BUUZZm OAB6mo23mdwj
qCEH3hn+92z647duvorF0BeSSMRrksSuMDnvn6fkfXgAwrXXkuLzi0i2FkJY NkqxypYnH93A
+g61tQ2cEEhkjQhiMZLE4HoMnisPS49PF8Ftp3mDALslA4xvH+Bwecc/S7aX R/tFI1QJHMu4
KOgGM59j0qK06amlbrY0+JXhsaN1d21nGJLu4igQnaGlcKCfTJ+lOinhmx5U scmUVxtYHKnO
D9Dg4PtWffzw2ms2dxdSxwQC3mQySMFXcWiIGTxkhWOPY+lZsjy/21NeaOFc G2iQJtby38yS
bEmB1+faxb+6XIzkVZmb01/Z28PnT3cEUW8pveQKu4ZBGT34PHsabNqVhbxx ST3ttEkw3Rs8
qqHHHIJPPUfnWDpbQ6Y9m11c7YIvt0JuLiQDc32hcbmPBYhWPvg06zW5e9s2 tJYoy4vpFeWI
yKyNcIQQAy9QQQc4x9aANiPTdKlkW8jsrN3ciVZ1iUlieQwbH45pz/2bqvmW 8n2S88h/njbb
J5bcjkc4PUfnVysXSbuw1G9jntLi22wQNHBbxOu4RkrlmUfd+6oA7DrycKAa VtBZ2WLe1igt
9+XEcahN2MAnA+qjP0qRJ4XYKksbMd2AGBJ2nDfkeD6Gs+/nhtNZs7i6ljgg FvMhkkYKu4tE
QMnjJCscex9Kx185bmyu7fzGMX264VEyfPjM6nAA+9lGyvYnaelAHUefDv2e bHv37Nu4Z3bd
2Prt5x6c1JXJwN/Z90r6jcxqw1XdNI8mEVms8kAnooJwM9sCtjUdTU6VLPpt xBK42fOsgKoj
PtLk8gAAMckEDacg4IoA1KK5mDUrho4lvNVigtmMmL2J0YMRs2rvZAhzuk+6 v8GM5VqmOpXH
2wK13ifzYUjtPLCefGwTfJsYbxjdJ0OBs56NkA6CoVu7Z7p7VLiJrhBuaIOC 6jjkjqOo/OuX
OqaoLWwb7bEryWcc6tOyp58jZJQKIyXx8o2ptb5hySQRcur+wnllSG/trP7C ZpF27Wk80K4d
/L6kLuc9MseegywB0VNMiCRYy6h2BYLnkgYyce2R+Yrl59V1LE0ryNaywQXE 72gCOEaNYiqM
2PmBDFiVwfnxnirlnLK3iQQTStMbaOeNZHADMCLZ+cADq5HAHAH1oA3GZVGW IAyBye56UMyo
pZiFUDJJOABVa/jRo43ZFLJLHtYjkZdc4pNSWKXT7kMEcxox5AO1tvH0PNJs ZcooopiCiiig
AooooAKKKKACiiigCOf/AFLf5/z/AJ5HWqfT2x/n+n6dsfLcn/1Lf5/z/nkd ap9PbH+f6fp2
x8oBRvv+PiD6/wBG/wA/4dBTNpbXSD7TbxTbXfb5iBsfMemauX3/AB8QfX+j f5/w6CGD7h/3
2/8AQjQBXXSLB5BHFpdtIxBbAhQcDHrj1ofRrKJ1SXSbeMsCRmKM5xj0z6ir Y2CT96szRshU
+TIUYHKkcggjp2NDeXujWFLkIoYkzzGQ5O3oSxPagDLvLGygMCw6VZSSTSbA HRUA+VmzkKf7
vpUclnAssEC6NpxmkR3YHAVQpUcHZk/eHYVc1S0a7W32wwTiKXe0cxwrDaw9 D3IPTtTGgu1l
tZobe2UxRPEYvNIVQSuMHZ6L6CgCIQaILZZ5bSygQsUPmxouGBIK+mQQenpR 5GiB7lZLSyj+
zMqyF40AGQCD9DnH1Bp8thOsEaRP5gDO8i+a0O5mbdkMuSACT8vvyeKht9Mu raxECyIT+7LB
ZGj3YjCFdwGQMqGyOvTAoAsPpuntb+Za6dYSlgCmUUKwPfIU9vaobC00+5tI J59MsITOA0aB
VbIK7u6jnGeParmmW0lrZCKXG/e7HDl8bnLD5jyevU1Ue3mt7HTbeP5rqDYF IQtGMLsYk8cB
WYjJGSB9KAHJb6FJMsKQ6c0rDKoqoWIxnIH05p8Vjo0zyJFa2EjxnDqsaEqf Q+nQ1WtrCdGm
tEQLapPCyyux3kIkfQYwc7cZyO/HFTaXpr2TpvAPlReUr+c7lhxztPCfdHAz 9eOQCf8AsnTf
+gfaf9+V/wAKP7J03/oH2n/flf8ACrlFAFP+ydN/6B9p/wB+V/wo/snTf+gf af8Aflf8KuUU
AU/7J03/AKB9p/35X/Cj+ydN/wCgfaf9+V/wq5RQBT/snTf+gfaf9+V/wo/s nTf+gfaf9+V/
wq5RQBT/ALJ03/oH2n/flf8ACj+ydN/6B9p/35X/AAq5RQBT/snTf+gfaf8A flf8KP7J03/o
H2n/AH5X/CrlFAFP+ydN/wCgfaf9+V/wo/snTf8AoH2n/flf8KuUUAU/7J03 /oH2n/flf8KP
7J03/oH2n/flf8KuUUAU/wCydN/6B9p/35X/AAo/snTf+gfaf9+V/wAKuUUA U/7J03/oH2n/
AH5X/Cj+ydN/6B9p/wB+V/wq5RQBT/snTf8AoH2n/flf8KP7J03/AKB9p/35 X/CrlFAFP+yd
N/6B9p/35X/Cj+ydN/6B9p/35X/CrlFAFP8AsnTf+gfaf9+V/wAKP7J03/oH 2n/flf8ACrlF
AFP+ydN/6B9p/wB+V/wo/snTf+gfaf8Aflf8KuUUAU/7J03/AKB9p/35X/Cj +ydN/wCgfaf9
+V/wq5RQBT/snTf+gfaf9+V/wo/snTf+gfaf9+V/wq5RQBT/ALJ03/oH2n/f lf8ACj+ydN/6
B9p/35X/AAq5RQBT/snTf+gfaf8Aflf8KP7J03/oH2n/AH5X/CrlFAFP+ydN /wCgfaf9+V/w
o/snTf8AoH2n/flf8KuUUAU/7J03/oH2n/flf8KP7J03/oH2n/flf8KuUUAU /wCydN/6B9p/
35X/AAo/snTf+gfaf9+V/wAKuUUAU/7J03/oH2n/AH5X/Cj+ydN/6B9p/wB+ V/wq5RQBT/sn
Tf8AoH2n/flf8KP7J03/AKB9p/35X/CrlFAFP+ydN/6B9p/35X/CirlFAGxY f8ecf4/zNSS7
t8OOm/nr02n0/Drx+OKjsP8Ajzj/AB/maklGXh4zh/Tp8p9v8Pr2IBJRRRQB Hb7vs8W/72wZ
69ce/P581JUduMW8QxjCDjGMcfQfyH0qSgCNd32h8/d2Ljr1yc+3p059e1SV C28TuURSSg+8
cf3u+PXHfv09VZpwDtjjJ5xmQjPXHb6fmfTkAoxwW8bh7azlTy2KhkKgYDNk cngZJ9O3oKdZ
Wlu0kd1HJKxQbQrEfJxjHA+lctZ3l0b6MpNuldol2mZvm5PB/M59MmupsZo3 vpAibA8SsvAG
QCef/HhUVYKEo8zuzVxcU0jRorLv4IbvWbO3uoo54DbzOY5FDLuDRAHB4yAz DPufWs2Sc6br
U0mnqs1sltFD5CuAN5kmCAMc4w48vA4G/sFqzI6aiuX0u1Wd7O01Dy7xR9uZ /MjG15FuFG/b
0B5b6bjUa232m5soRZWl4sf25UiuWwiKs6quPlboMADHSgDoP7Mg+0ef5l3v 378fa5duc5+7
uxj2xiprq2juoxHI0qgHOYpnjP5qQfwqnqlzLp9taw6fbqzyyCGNFUEIAjNw pZQeExjcP0wa
sGqX1wHz9ktmtovMn845VvnkXG5WIj/1ZJ+/jdjnbyAa1rbR2sZjjaVgTnMs zyH82JP4VNXP
3utXltaTXirAYi9xFHEUO5WiWQ7i2eQfKPAA+9145kbU9RXUmhEEb28EscE0 mFRWZghLAmTK
/fGF2tnGM88AG5RTJEEiFGLAH+6xU/mKgsVDaZbqc4MKjg4P3R3pAWqKq6eo W2KjOBLIOTk/
fbvVqhAFFFFMAooooAKKKKACiiigAooooAKKKKACiiigAooooAjn/wBS3+f8 /wCeR1qn09sf
5/p+nbHy3J/9S3+f8/55HWqfT2x/n+n6dsfKAUb7/j4g+v8ARv8AP+HQWNGj R0l3orYc4yM/
xGq99/x8QfX+jf5/w6C1of3Jv98/+hNQBoeRD/zyj/75FHkQ/wDPKP8A75FS UUAR+RD/AM8o
/wDvkUeRD/zyj/75FSUUAR+RD/zyj/75FUba9sp5LxSkUaWpOXYAAoMgscjj DJIv/Ac9CKvX
HnfZ5fs3l+fsPl+ZnbuxxnHOM1h3Ph6dbIW9reyTAWkloq3O0BI2TAxsUHO5 U654z3oA1DPp
oV2MtptR2RzuXCsoJYH0IAJI7AUNPpqeRvltF+0Y8nLKPNzjG316jp6iqc+j eZrFtcKkAtYP
KxHj7uxZgMDGODIhH0PoKrtot4I76JGgZb9JIpGZyDErSSsGAwdxxL0+Xlev OQAXk1DSjbvP
JJbQJHO9uxlZVw6kgjr3xkd8EGnJdWct7JaokAlhlEciuQG5j3gqOc/p0b05 qy6ZeLF5cTrJ
GJ5pNguXt929t4JZASNpLLt5BznggCqaeG7k6bHZPNEAQN7jJ2n7KYDgY552 nqM5PTHIBsJd
6VJAZ47izeIEr5iupXIG4jPsAT9OakElgWgUPbE3ALQjK/vABnK+vHPFZ7aX c3epwX15HbKY
5EJiVzIMIsuGBKjndKOMcbc57UQ6VcxXEbf6MUM8kkhOSSplaRQRjDfeGDwU YEgsCQQDW8iH
/nlH/wB8ijyIf+eUf/fIqSigCPyIf+eUf/fIo8iH/nlH/wB8ipKKAI/Ih/55 R/8AfIo8iH/n
lH/3yKkooAj8iH/nlH/3yKPIh/55R/8AfIqSigCPyIf+eUf/AHyKPIh/55R/ 98ipKKAI/Ih/
55R/98ijyIf+eUf/AHyKkooAj8iH/nlH/wB8ijyIf+eUf/fIqSigCPyIf+eU f/fIo8iH/nlH
/wB8ipKKAI/Ih/55R/8AfIo8iH/nlH/3yKkooAj8iH/nlH/3yKPIh/55R/8A fIqSigCPyIf+
eUf/AHyKPIh/55R/98ipKKAI/Ih/55R/98ijyIf+eUf/AHyKkooAj8iH/nlH /wB8ijyIf+eU
f/fIqSigCPyIf+eUf/fIo8iH/nlH/wB8ipKKAI/Ih/55R/8AfIo8iH/nlH/3 yKkooAj8iH/n
lH/3yKPIh/55R/8AfIqSigCPyIf+eUf/AHyKPIh/55R/98ipKKAI/Ih/55R/ 98io5oYggxEg
+Zf4R6irFRz/AHB/vr/6EKAKE0qJdPCsUI2qzDMY6ALnnI/vCoIdQhe6jheO 2Xe2M5j/AC++
T+laD2YaaSVZGV3BHQcZAHpnsOh7VDbWFxBdCVrsumCCh3nP5uQPyqlykvmu XPIh/wCeUf8A
3yKPIh/55R/98ipKKkoj8iH/AJ5R/wDfIo8iH/nlH/3yKkooAj8iH/nlH/3y KPIh/wCeUf8A
3yKkooAj8iH/AJ5R/wDfIoqSigCvYf8AHnH+P8zT5v8AWQcA/OepHHyt6/0/ lmmWH/HnH+P8
zUkpw8POMv69flPv/j9O4AJKKKKAIrXm1h4A+ReAQQOPbj8qlqO3ObeI5zlB znOePqf5n61J
QBEv/H1JwPuLzkZ6t+P+frTppBDC8rAlUUscdeKYzlZ3wrP8g+VSOPvep9sd Px9Ir52Njcjy
nA8t+cjHQ+/sPzHvgAYljsuDMss4LNkj5ORknGcZxye/eo9Ptwl07NIS8SeV 5ZTaQvGD1Oc7
eo9+/ArajLcR322HzSWYBcMcA4HbOKfH5c/iSK5hXj7JIrsRg5LRkfXgHkcf pUzhG8XJ+gQm
3zJfM0rq0tryMR3dvFOgO4LKgYA+uD9adFBDDjyoo48IqDaoGFGcD6DJwPes nWS7arZRCK8m
RoJmMdrceUchowCTvXOMnv3q1JdTQ3H2OztvP8iJHk8yYhtpLABSQdzfI33i O3PJxQFiaws7
iHyZ7SCWLeX2PGGXccknB78nn3NSJBDH5flxRr5SbE2qBsXjgeg4HHsKybrX ntoJbk2qtbqZ
kjIl+dniDkgrtwAfLbByT045OHHWpRqQtPsMjbHSOZoxI4V2CnghNpUbhkll OM8dMgGlLaW0
8csc1vFIkpDSK6AhyMYJHfoPyFNaws38jfaQN9nx5OYwfKxjG306Dp6CqOp6 01le/Z4rOW5K
xiWTy0djtJIAXarAn5T94qOnPXEL69NGJnazj8qPz3yJzuMcL7XONv3umFzg 85IxyAajWFm0
0szWkBlmTZI5jG516YJ7jgcH0pzWls90l09vE1wg2rKUBdRzwD1HU/nVW01P 7VqM9kIdslvu
8/5s7Mn93253rluOmMHmpr7eEjdJXTEqAhcYYF1HPek9ALVMWNF27UUbRtXA 6D0H5D8qg1He
LCdo5XjZUZsrjJwDx/8AqouN4urVhK4VnKlBjB+Rjn1ouMsKqqMKABkngdz1 p1FFMQUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAEc/+pb/P+f8API61T6e2P8/0 /Ttj5bk/+pb/
AD/n/PI61T6e2P8AP9P07Y+UAo33/HxB9f6N/n/DoLGjRo6S70VsOcZGf4jV e+/4+IPr/Rv8
/wCHQWtD+5N/vn/0JqANDyIf+eUf/fIo8iH/AJ5R/wDfIqSigCPyIf8AnlH/ AN8ijyIf+eUf
/fIqSigCPyIf+eUf/fIrL069+0xWcl1YQQJeoGgMb+Zkld+1vlGDtBPccHkc Z2Kx9M0+8jg0
6G9ECLp6KEMMhcyMEKZOVGBgnjnkjkY5AJrjUNKgimkMls4gkSObYynyizBf m54wTzn0NWFk
sHuntUe2a4QbmiBUuo45I6jqPzrFOh38l0k0skbvEn+sa5kfznEscgOwjEQP lnIXON3Q4q1/
Zl42swXMjq8cU7yeYbl+VKOqqIsbBjcBkHJxnqTQBNNLMmrxWaWFo0UqNIJT KQwVSgb5dh5+
fgZ5x1FWJZ9NhQvLLaRoN2WZlAGGCn8mIB9zinSWztqtvdArsjgljI75ZoyP /QD+lYMtlcSx
SXVvFIyx3am1jkRo2YPPFJIz5GQAwIHyjCqT82QaANprvSktUunuLNbdztWU uoRjzwD0PQ/l
UeqXdtpgtWktlZJ5xEzAD92NrMXPsNvPoMntVGbRruW5N8wjM7u5aGO7kiVQ yxrxIoyf9UDg
qB83+zzefSw1vplvtiaG0OJEIO1k8p48AHP94cEnjuaAHLdWam9NwkFvFaSi NpJCApyiNkk9
Pv4pzXelIyK9xZqXj81QXUbkwTuHqMAnPTiqKaTfQwXaLc+b5t35oBleJnj2 KoQyDLAjaPmG
S23n7xqGz0K7hicO0QLyQvjzWfGy5eUjcRk/K4GT1Oc+tAGs0+mp5G+W0X7R jycso83OMbfX
qOnqKseRD/zyj/75Fc/L4eneSYny5FuPMRx9pljVVMsjglUx5nEnKkjpwecj pKAI/Ih/55R/
98ijyIf+eUf/AHyKkooAj8iH/nlH/wB8ijyIf+eUf/fIqSigCPyIf+eUf/fI o8iH/nlH/wB8
ipKKAI/Ih/55R/8AfIo8iH/nlH/3yKkooAj8iH/nlH/3yKPIh/55R/8AfIqS igCPyIf+eUf/
AHyKPIh/55R/98ipKKAI/Ih/55R/98ijyIf+eUf/AHyKkooAj8iH/nlH/wB8 ijyIf+eUf/fI
qSigCPyIf+eUf/fIo8iH/nlH/wB8ipKKAI/Ih/55R/8AfIo8iH/nlH/3yKko oAj8iH/nlH/3
yKPIh/55R/8AfIqSigCPyIf+eUf/AHyKPIh/55R/98ipKKAI/Ih/55R/98ij yIf+eUf/AHyK
kooAj8iH/nlH/wB8ijyIf+eUf/fIqSigCPyIf+eUf/fIo8iH/nlH/wB8ipKK AI/Ih/55R/8A
fIqOaGIIMRIPmX+EeoqxUc/3B/vr/wChCgChNKiXTwrFCNqswzGOgC55yP7w qCHUIXuo4Xjt
l3tjOY/y++T+laD2YaaSVZGV3BHQcZAHpnsOh7VDbWFxBdCVrsumCCh3nP5u QPyqlykvmuXP
Ih/55R/98ijyIf8AnlH/AN8ipKKkoj8iH/nlH/3yKPIh/wCeUf8A3yKkooAj 8iH/AJ5R/wDf
Io8iH/nlH/3yKkooAj8iH/nlH/3yKKkooAr2H/HnH+P8zUkpIeHAbl+cA/3T 15/x/rUdh/x5
x/j/ADNSSjLw8Zw/p0+U+3+H17EAkooooAjtyTbxEhgSgyGBB6d8k/zqSo7c Yt4hjGEHGMY4
+g/kPpUlAEak/aHGGxs
Re: Primitive types and Java types in XMI [message #477296 is a reply to message #477294] |
Wed, 30 April 2008 09:43   |
--------------080802030804060305090009
Ed,
I'd really like to "apply the Ecore profile"... But I don't know how !
I attached a screenshot to illustrate my problem.
In the state exposed by the screenshot, how can I replace the "int" type
defined in my model by the one defined in the ecore ressource, so that
the attribute "einttest2" gets the ecore EInt type instead of my fake
int type ?
Of course, I can do this "by hand" in the properties of the "einttest2"
attribute, but if I had a very very large model with lots of attributes
using this int type, it wouldn't be feasible to change each one manually !
Thanks again !
Stephane
Ed Merks wrote :
> Stephane,
> SWT wrote:
>> Hello all !
>> </ownedAttribute>
>> name="int"/>
>> class !
>> java.util.Date...
>> Thanks in advance !
>> Stephane
Content-Type: image/png;
name="primitiveTypes.png"
filename="primitiveTypes.png"
iVBORw0KGgoAAAANSUhEUgAAA28AAAOiCAYAAADnue+WAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
ABh0RVh0U29mdHdhcmUAUGFpbnQuTkVUIHYzLjA4ZXKc4QAA+TRJREFUeF7t /W2wHcd5mIvi
/E2lKvfjnFOpW3V+5f5IVKkiwlIRMAMEvMqVK0pFlkvyLeX6RskxDhAhMFDg oYCQMGnY2BBg
UZZpi7RMUtS2QCsyZFnWByRaNk3FihGZcCRbhiwxtiXblGXLtqwvK1K4Nyll LnqDDfRudvfb
Pd0zq6f7maqptfZ0T/fbz9trr3l2z9rrf/r0714edrBBAAIQgAAEIAABCEAA AhCAQMUE/qcd
O5S8scOAOcAcYA4wB5gDzAHmAHOAOcAcYA7UPQeQN+QVeWcOMAeYA8wB5gBz gDnAHGAOMAcW
MAe88vYrj71/+NEf/VF2GDAHmAPMAeYAcyBjDqj30zF/yeZ9mGsQrsOYA8yB fueA773jBfJm
vlmMebPhnLqXWvUvAfJUd55K5cd8PX/jm88M7PkMzDfSsRflpfJLO8t4Hes5 EztfzNftwJZN
gNfsMl4nLfw+m1K01AuhBUaMIf716Hvv2CZv+g0DsPFgl8RKTYIlxUusefNQ v56/+vVvDmr/
0z//CnsBBpqneuSiMG+O9vYaV/NFEjj9uv3Od74zsJdnwGuW1+yUv3emvM5C 3vqdu/Z7x3V5
Q9zanhRT/kKZ8hchbY+bl/r1/KWvfGP4o8//NftEDBRfvaeurjC3x83tpXML CZx+3T733LMD
+/QMeM32+Rqc8neIea2lZav045Tx03a9rwnzvWNL3hC3epNV4oWEuLWdX3uO 6NfzF//qa8Mf
/NFfss/EQPFWe8zqSonXNW0s93XtmiP6dbu5uTGwz8uA1+xyX0u1/R7U11tT CBsrb8xT/btK
lLcP/dTeIbTX9sIhnhdObp+8kds2fxHoi8A//eJXhs/8wZ9v26Wc2/X5eTu/ GB6KO3/Rr/e1
ddtttw0xu/ReEtOGquNqJyRvG898a2CfnwGv2Xpfs9JrsabyGlbejv3712/7 vXPn699a9Udm
fuM//adB76VzmfN72o6lVFs57WyTt9DKjLrY23z228790xf/3ZbYlYZNe+V+ iZLbciyXMC+1
uP3xn/71cOWpL7xgj3k9u87j2AtZhpgo/mrnL/r1vf7UG6e0+aTL/B2Q2479 u1n9/N+/9d9e
sP//jtw7/OtjPz7877e/adh/x08OB//9Tw2H7vrp4cg9PzMc+9GHh9e9fn24 88fOD3e/6R3D
j/zkzw9n7n+Xsx1X2xx7IW9es/W9Zpfw3qtjrGHlTcnby7//NdevzXPlzZSr 2OcpOVNtqk09
ppwXWzf0uzrmd73uJ/d3fql21BzbWnkLXeC//yf/yfDM5nPDrf/ft1zf1c9q /8OP3DN8BoGb
ZLLFTkqpXkxudT7NR3K7zDcwU94+8amnB3vXr2cp565zeztm/nXMHnuozKyL wNX3Oir5Bhzz
F1Tf72iXvH3zv/3NYO8/df79w2/+7ueGS5/4g+Gjv/XU8K73f3T41d/43eFD //ETw/t+7fLw
Sx/+zeHdH/rPw89f/I3hP1wtO/PAu17QhqvdFo+Z+bDHFyqz6yJw9b1upWud WspXsfL2fT/+
weFfnX3ncPCHf3pQ4qZ3LXAl5O3P/vyLwxf+7M+Hz//pF4bfvfJ7wx//ydPD 5/7oj4c/+MPP
Db//B58dnvqvfzB85qnfHz79mf+aLGFK2n72534h+byUnLt+76eIm+qrpvcO Ud7e86bbhm9t
XJM3talH9bPan778k1sC9+mLhwZVLwVkq3V37NgR5CCVl+YS/Lzbb719K4// 8h/+2+s5JbfL
ftPS8vaHf/KXw+Xf+aMX7J9OyLnr/J6Omb+o1XM9dt9xHxuVCy4G63ldxQhX zJt67hu5S96+
8TdfHexdrbyd/on/MKz95DuH17/554dzP/3u4Y0/84vDmx7+peEn3/a+4f63 Xxze8nOPDQ/9
hw8Pb3vXr16Vt194QRuudls8Zr829Rh9x0MMeM3W85otfV00ZXsxK2//6ofe Peg99rNxKubY
z7zZK2+vPnD1Oj3ji6eVXP3CL753ePd73jf84i+9f/il910c3veBDw0XP/Th 4YOP/crwy7/y
a8OvPP6R4Vd/7T8Ov/aRj46SMHPVzV7dy4ndd7dEzO/4KW+bzLn7I2rl7cIb XzJ841vbV97U
z/Z+4cdf4p0cOcKSc26phKe0I8Urlaf0FVPXJ2/nX/3hYf2Vj23tr/uus9ef q+Nmbv/bf39u
COU2JoZQnbl55MZb+/la3p767BeH//xfPrttT825fb7+WeXMVyYdzzlXart0 uX1xri/6zV+6
6lhMvyofXAy2dTE4hbx9/WtfHuz9x9/63m3v85ev/FHwfV/Vd7WjXnvm7qoz 5THVt9m+/XOJ
vmNfs7F98Zpt6zU7x/t3zMqbErc3v/PJLYFTMf37n/6Pwx0/9fhw5I0fHv7t mQ8M//upX9o6
7hM7aRz2Z952/7+v3UL5kdf/r1u7dL5drm9r1L94rvzeZ4K/g8bc/mh+5k09 f+q3/3Brd0ld
avy2wI0Rt5w+XRI4ubz93Bv+6fD1q7KmdrXqZj7Xt1KqY6qeb3A5F+g555aE HduWFK9UHttP
bD2fvL315R8cnnzbZ4aLd31seONLz19/ro7rHG89fjOc29g4ppgbuX23eL6W t9/7/T8bfv03
f3/bnppz+3z9s5rDvjLpeM65UttTlEv3yqf0qXLCxWA7F4NTyNtXv/JXg70r GfvPVy9ifvPq
/p8/+fxuPv/k564f/82r5aq+qx312jOP2z+7zil5bK7+pNds6ph4zbbzmp3j Pb+GlTffOJW4
/Y/vfC1Z4JRAqVsl7f3Kpz49/O7V/c+/+Bdbu3qujo2VNx23a+VNHXv22Y1R bc+R95Q+Srx3
iLdNrp996fCVbzy7tZufe1PPn374j7aOqTJVL3SBrv/ip+uYfwE0z7OP++r5 zjHlyHWu/ddH
Xzx2vKpeTMwx/ackObeuT97uf9m7t8TtwoGPDEduOXX9uTqu860fQ7l1cbEF NcREylFufnTf
IWmOyWto3rr6iJm3ubl1na/l7ZOf/vzwa7/x1LY9Nef2+fpnc2yhY6rMrus6 1+7HVye2X1VP
9y3F5xujedx3r3zMuXYdlRcuBtu4GCzxBmy+htW8+PJf/8UL9h+7eoukuf2n q597C20/9jO/
4GxHvS7M9vXP9qOqY77W9Dn2e6fdli436+u2XG2a8bj688XhYmQf871mY851 1eE128Zrdor3
XLvNmJU39fpVq26xt0za9aRx/OqP/i/Dr/7o/3p1/1+Gx7eeX308fe1RyZva 1XGpHVOmzN85
n/zdT237FfSh9//coHa95cqbHZcWNyVv73vXI9f/M+WYfmLHPGW9Eu8dorw9 uPbdw5e+vrm1
K1Ezn2uZU8dUvdjVFd/FvesCO3TRrcXBFrnc47Zs5LZnni+Np/SEccmb+oyb ulVSrbgpcVO7
eq52dVyV6zyn5jaFVaiuKUt2vdT8SOIWM3+kcblissdQOrchefv4lT8ZPvwf f+/6Pibn5vnm
czXWmJ/teuoc17FSbem29YWgbleK1zdOfdx3ISid5ytXueFicPkXgyXegG15 +9Jf/flg7z/6
Uz8/PPGff2/4tau7+aieu3ZV39WOeh2Yx/XP+vWiy0L1fOfP0a5rTL5jvtds ShsvyMNVuVZ/
HJvj9zh9LPf3Q8zKm8qvvmXSFLPQZ+HUOTGfefvQ3f/z8J1v/Obz+5PDd/7m 6nO1f+Pqc3X8
b24c+9AP/c9R81lJ0m9/8srwO1d381H9AxMlbUqq1KP6pyZqHyNVoc+8fetb fzO49jH91PDa
KvHeIcrbm3/knw1f/Orm1q5kTT+3H1W9FHmz/4qnL459YpfSttmW2Y90Ae66 2NbxxAqnWd83
xjknj2/l7fUvedh526Q6bub2L67mPSW3EmMpvzGcffI2hrd9ji/f0rhsAXTF Mkfe9crbk7/9
R8PFx393256ac/t8/bMam1nmYqjK9XG7rq9d8xyzTX3cPs8Vh6uuL75QHLpM ugUrpg1XHZUf
BG65F2jqtVziDdiWt7/64p8O9n7Xvee3/ZVbSVxoU/Vd7divA11HHTfr+34O HXe1ndKu73y7
Dde47GPSazamDV8dXrPLfs3O8R6csvJmypp+bn4Wbuxn3t574v82vPf41f3q 4/uO/9+3nr/v
+f3bX/zZQe2qLJaH/Zm3T/zO7279CtLipuVNr8Bd+o3fiG5bx2B/5u2rf/31 4T3vfHj467/6
0+ErX/5z5468Xf2Lki+Jb/rhfz782Zc3t3Ylb+ZzvfKmjv3E1XqpghWqH7qI dq2U2OJlS4Bv
FcTVj08OXP3GyEYo3tgXz9h6Pnk7te/+67dKqhU3fQulOq5zrB9TchuSHDMH khSH8hmTH1++
bY6x8yRV3sbmK/c8LW+X/ssfDu/98O9s21Nzbp+vf1bMzDL7Z/s8fWGmjsfU dfXrOs8XR2p8
vnHG/vMD3/nScZUjLgaXezGY+18rXf9t8i/+7OnB3v/PM28d3n/1KwHe/8Rv bT0qedv62bOr
+q521Osi5rhdT/8ce1z34atvl/viMutJdXTd2Nesi0PsMV6zy33N5r6/xpy/ 6pW3UIy/cOz/
uiVu7776GDMWU6w+/tufHP7LJ35na//TL/zZlrh94fP/dfjyl76wbf/cH3yy +Mrbn//pHwyu
fcnyFvP+4ctR1H+b/LEf+hfD57+0sbX7PvOmylS9sfLmuoAOyZvr4l2SN0kW fG2mnGde4KdK
XcoLKaWuT97e8ZrHB3Uxr3Z1q6R+ro7rfOvHlNzGyFsMp1x5Kz1/cuTNJ4gp eYytq+VN/SON
d3/w49v21Jzb5+uf1XjMMulnVVfXseuaZfbzlPNCdWPic43V/vfiuo7vuI9X 6LjKExeDfV4M
uuTtz//0j69epGzff/Dun9m20PbLH/1kcOVN1Xe1o14HMcftevrnUsd1DFK7 Zqy+2O3x2K9N
Xe477uIRc4zXbJ+v2Zj34ZSVt6k+8+b7b5M//4P/l0HtMeMw69grb+q73j7w nrcPn/uD3x6+
+GeffcH++5/+rWSBC4mYKtPy9vNv/+nFf+Ytlb9dP0reztz58uFP/mrjBbsp cqpc1QsFpP/6
bq++2NJk19MXzZKw6fOk9mKkKiRyofhix5ibuJTzffKm2vi1x9+3lVf1eShX jtWxP/7L+Nz6
2JsiFZtfF0tb6Gyh8s0Bm5drDkh5leatqw9Xmym5G1NXy9uvXfrM8PPvu/yC PSXnrvP1MT02
+2d1PHRMlbnONfsy8ygdd9U1Y5BiCY3R/MuYXS9UFmrTmZOrueJisL+LQZe8 feHpzw72rr7n
LXV3taNeF7HHzdeVPsc8Zrflq2/3p+up42YbUn+uuF3HzNelXR4qi23frMdr tr/XbMx7cg0r
b1N8z5v9HyD1z09duTQ8/blPDb/wHx7akir9c+qqmPQ9b1rgUtuNydnS6kTJ 26kT3zN87i+e
EfcfOf49yTY/BTD7wnyKPpbUZkjelpbbJXFfVaxa3n7l139vWL9w6QV7Ss5d 53PshUxLMPnQ
E1cQuIwvkV3V6y2nX5e8ff6P/2CodVfvrbXGtqq4EDgEzrUqoo+FVtZcn3ez v/8t9jNv3/fj
Hxz+1dl3Dgd/+KcHJW56f/n3X/t+tztf/9bJrs+1sGmpsn+O/R051/e8xcZT c70oebv7dd87
3H1c7a8Yfuh1r7j+/MbPV4+pOlfLVjVY14rLqmKprd+QvC0ht7XxrD0eLW9K BlxSkZLzElJC
G/Gy9/5f+Z0tgeOCsI8LQpe8/cnnnhpq3dX7bK2xrTIuXrN9vF5j3/tjV95c Ylbiv02qOO2V
tynlTfVnipf+OZaXq57re95y2mvt3Ch5a23QvY0nJG+9sehhvFrelAggTvHi VAur9zz2iUHt
CFz7F4QuefujP/z0wL5MBrxm23/NxlxDxH7mTbU112feppa3GC7UKff6QN46 uE0HeSv3glnC
Lx8tb0oAahES4kiXyHd94L+wCtf472eXvH329z81sC+XAatwfb3fuq4Jclbe QkJnli3hWoQY
p3stIG+NXxyoFw/yNt0LqMZfTlre1MU/0pQuTTUx+w/vfXJQu74g5C/7bb2W XfL2h099cmBf
PgNes229VlPe66e85or5ku6UWKm7zHmKvCFvK/ucIr80pvmloeVNXfTXJCLE Ml4kz7/7Y4Pe
uSic5nWzit9HLnn7/U//9sDeFgNes+28ZmN+TwS/x6NAYUwM1Gl7zm2TN/MX DM+v/dMAdhgs
dQ6oi32EabwwLYHdUucmcd/4vWpeZCkuT33qv7A3zIC5zzUFc4A5UGIO7NC3 1i3hYoUY274Y
Jb/klznAHOhlDrhW3viLedt/MSe/5Jc5wBzInQPbVt56ecNknFwcMgeYA8wB 5sCq5wDyxkVc
7kUc5zOHmAP9zQGnvBW4JZcmIAABCEAAAk0SyLlYuu22267fzhyStybBMaii BNRcYoMABPoh
oN97ViZvH/qpvUNo7ycVjBQCEIAABJZEQP/L7tSY1RtuirzlSCLntv3XeD2X +O+DbeeZ1zH5
9X0dxQs+85b6hjSmvhK3zWe/7dw/ffHfbYkdGwQgAAEIQKA2AmO/bwl540Ks 1MU48sZcKjWX
aGd5c2llK2/v/8l/Mjyz+Zxz/8OP3DN8BoGr7XqFeCAAAQhA4CoB5G15Fzut XaAib8zB1uY0
44mf08nyFvPvLWPe3T/9W28fvrXx3PAv/+G/3Xo096cv/+SgBO7TFw8N73nT uHu6d+zYERPG
tjrqnDHnJXd09YS5+hkTW+icmLhLc4zpM2WcUnt2uVQ/pW/qQgACyyeAvMVf ZHBBNg2r0vKm
3ufI1TS5gitcS8+BUfIWeutVDUrb+Vd/eFh/5WNb++u+6+z15+r4N7713PX9 v/3354YLP/4S
qTlnuXTBveoLdCm+UYOe4SQpbql8TIil25Ta880N6bxc6R3DhnMgAIH5CaxS 3vQfx/Rj6YsC
qT0u8uu4EJXkzc6TlDepXJoXlNcxL8hDH3lYiby99eUfHJ5822eGi3d9bHjj S89ff66Of/2q
vF3fv/nc8HNv+Kej3pmlC23kbRRWccVQ4j6m19JtSu0hb2OyxDkQ6IdASN5C F8ElPvOWelFe
+mKOi/w6Lg6RtzryUPr1RXvkNWYOrETe7n/Zu7fE7cKBjwxHbjl1/bk6/pVv PLttXz/70uAV
gf1XSF3ZvAA365jl+rg6FlNH17MfXe2YQYdEUZdJ8Y6J0WYR25eLhTlmH8PU GO1+fPFJObNZ
m/lwnSuxtstTx+vi4GOaGrsUi52nmH77ueRmpBAoQ8Anb+brzfcfwnL/26RP 3vRxs9wVj/2e
acbpq6/qmO3reuZx3Q5yN8/FZ468xeTZlU9pfsdcdFJnnvkB57Y5j5Y3+w1A X/Dq2yZ9j+oz
bupWSbXipsRN7eq52tVxVf6lr29e3x9c+25R3lyiZAuTT2RcsucTFfOi3CeJ 0nHfxbUUh2s8
PikMHfeJidS/K+4Y7iFxdeUkRnR9sYzhIY0hxCu2P9d8sid1Tlum9KbEW+Yy llYg0B8Bl7y5
3hPtC6gpV95MoQpJlSR/9kV7bLvI27wXi5K82cLtu5i3pT91fiAJ8+Yd3vBW c2C0vPnermM+
8/b6lzzsvG1SHf/iVzev739x9fmbf+SfZcub/aYakjNJYsbIRehC3dWeL15J hMyLeElKfELh
k3KfdJr1fVxd44mR3JAwuiQlVoBs2QmNQZKhsblyzYmYeSr9YcHOe4h9f5fc jBgCZQjY8ub6
vWlLj37DLbHyZvbnk6bUi3CffPrasVfsXMLIheZ0F5o58mbnOiR6pty5ziPH 0+UYtrD1zYGV
yNupffdfv1VSrbjpWyjV8T/78ua2/Sd++J9nyVvqBX0N8hYasP7lmXoRHyOs 0gpRSGQkbq4x
STI6h7xJcUnyNjZXIaF3iXfomCTtZS5XaQUCENAEfLdNShdbU6y8lZQ3V/zI W50XkGPlTZJ6
qVya45TXOV/IS1t5WYm8veM1jw9K1NSubpXUz9Xxz39pY9v+Yz/0LxYvbyFJ kQTGLjeFJlVM
pb4kwYsRGakPn2j4xNHXp+t4KR4xfUqsbJkN5TFFxFPqSrngUhwCEBhHoAd5 M1dcXKts9sWg
fdHPxeK0F4sx8ha6fdZ1e+yY223J87R5hi98XXNglLxJ3/UW83b4a4+/b/iT v9rY+oybenTt
f/yXG8OZO18uypu5lO9aAbKX+s06kkyYK13SBXvMRX/MBbVvPHYsOh7p+Jgx SuP29e2TFFd7
9jglNrF8Y3lIYwiNxZ5DdmyhGFxzNDaXUr+uFT1XLDGvUepAAAJuAkuQN30h rl//5sW6+bvX
FjNXfZeo2bKGvM17kTlW3ux54ZJ0+5rJNXeQinnzDW94m3MgWd5KvZmfOvE9 w+f+4hlx/5Hj
3yPKW6mY5mjHJQRz9JvbxyriXkWfJqdV95+bM86HAASmIbBKecu9iJtCsqZo M3ecrZ8fK2+t
c2B8SE2PcyBb3mL+QYnr7fPu133vcPdxtb9i+KHXveL68xs/Xz2m6lwtC21L u8BeWry+VaJp
Lom2t7pqVqvufw7G9AEBCKQTUBcL0h0ovvLcf1iSe6EyhWhN0WbuOFs/H3lD Wlqf44zPP8ez
5S39bY8zIAABCEAAAssloAQsZ1+/cGlQu3oDtm+F0T8rOmMFkfN+tAt2ag4y T/rINa9p8my+
XyBvy71+IHIIQAACEFgBgZy/CMeuvOXIIefmyTX84MccYA7UOAf0e0+2vI29 bdL1fluyrRW8
n9MlBCAAAQh0QEB/5i11qKlfFZDaPvX7IjB2HvZFidFCoB0CxeStHSSMBAIQ gAAEICATmOsf
lsiRUKNnAshbz9ln7D0SKCZvJVfLSrbVY1IZMwQgAAEITE8AeZueMT3IBPQ8 /PVffsMwZv/U
J94jd0INCECgGgLF5K2aEVmBqO+PY4MABCAAAQiUJtCzvOV8b+QU/8F3ijZL z5ep2tPz8Fcv
vmn45FeeG7VPFRvtQgAC5QkUk7ec1bKY/54TO/Tzr/7wsP7Kx67vr/uus9t+ VuVsEIAABCAA
gVwCLcib/UXMMUxyRUmfH2rHLpP6lMpjxrXUOlPKmzk/lsqHuCHQGoFi8pYD RhI/qdzs+5FX
fGh47J4nh8fPfXx4z5GPDuuvemzbz6pc2nLeBHLOleKiHAIQgAAE6iHQiryZ RGPew2LqhLKE
vJWdw3oefuC9b95adfv7+39ma//8X28MX/r6s8Odb/3w8IP3f2D4/nPvHr77 5M8N/+gHH97a
/7d//VPD337lG7bqubZUgS47KlqDAAR8BIrJW4pg2cFI50rlZntvffkHt8Tt ybd9Zrh418eG
N770/LafVbm05bwx5ZwrxUU5BCAAAQjUQ6BFeVN0zfcx18pLyjGXGJry5rv9 MiQOvv7t2GPG
Us9sGh+JnofvetdD2+TtL7+2OXz1m89t27929Wd7V3WQt/H8ORMCcxMoJm85 gUtyJpWbfd//
sndvrbgpcbtw4CPDkVtObftZlUtb7BuTfmMw33y4xUCiSzkEIACBNgi0Lm8+ gZL+SOlbWbOP
j21HEsJQuS6T+l7SDNXz8O3v+Nlt8qYk7ZvPfHtr5e3oT39w+Ddv/KXhe37k ncM/vmN9a/8H
B98y/N3vv2/4W9/7BuRtSQkn1u4JFJO3FMGyqetz7Xvv9S9XXe571O2pf06i PuOmVtvUrsRN
7/qYKpf+iYl0q0Dolo+W3hC6f3UAAAIQgECAQA/yZr8v6z9a2lhi6pWSt1Bf IeF0ndfCBNfz
8C3r79wmb9/a/M6w8ez/2LZvPvudQe+6bPO57yBvLUwExtANgWLylkNMEj+p 3OxbSZr5mTcl
b+bPqlzaXL/8fW8WkuhJfVEOAQhAAALLJNCDvLkyI73vTbnyJq0GSuXLnGnh qPU8/ImHf3FL
3r618e3ruxI1tfJ26M0fGF61dmHYc3XF7e/9wANb+9/5vnuv1dv8NvLW4sRg TM0SKCZvKYJl
05TOlcrN9l7/koeDn3lT5dImvTH5/uLo+4uk1B/lEIAABCCwPAItypv5/hcr Qqn1QnevuN5f
zWNSX1K5bqulu2T0PHzDW9472PtTn/3CIO1f+OKXkbfl/foh4o4JFJO3HIaS nEnlZt+n9t2/
7TNuaqXN/AycKpc2Sd5cv/RT3oyk/imHAAQgAIH6CbQib+adJb4/ToakTv/h 0tWOdDulLvdl
2/d+a/dlxyfFUv/sio9Qz0PfGdJ/mwz1FJob8RFSEwIQKEmgmLylCJY9gJLf 8/aO1zw+KEHT
u/qMm/mzKo/Z7DeUlDcC6c0opn/qQAACEIBA3QRakLe6CRNdDIEp5S2mf+pA AALzEigmb/OG
Hd+b9M9J4luiJgQgAAEIQOAGAeSN2VADAUneaoiRGCAAgXIEislbzspbueHQ EgQgAAEIQGAe
AsjbPJzpJUwAeWOGQKAvAsXkrS9sjBYCEIAABHonMIe86TdpHi8PMIABc4A5 wBy4MQfUwtkO
BUQ9Wb9waWtP2Vh5S6FFXQhAAAIQWDoB5I0LSS4kmQPMAebAquZAs/KGVC79 8oj4IQABCNRJ
AHnjom1VF230y9xjDjAHsuWtzrdWooIABCAAAQhMQwB54+KppgvoX//lNwxj 9k994j3cknr1
zrOackks5CNmDmTLW60rXDlxrd9z0yDt01wS0CoEIAABCNROAHmr7wJLfVVP zEVPi3V+9eKb
hk9+5blRe4s8GFN9r09yUjYn2fJW+5vsmPiUuG1sXvHuqpwNAhCAAAT6JNCC vJnfYZp6YbVq
UbK/AFzFP0VMuh+TzxT9pPK365eWN2mMUnnueDi/7IU+PNvjmS1vOStcU77t 58T1yN07g/Km
ytkgAAEIQKBPAi3IW47wrPLi3df3FDEtRd4+8N43b626/f39P7O1f/6vN4Yv ff3Z4c63fnj4
wfs/MHz/uXcP333y54Z/9IMPb+3/27/+qeFvv/INW/XGXNhPwXpMHJzTnpSQ 07icZstbi2/d
D961c3hm46mtfWPz+V0/v/qoyqVN/XILbVK51D7lEIAABCCwGgItyptrNUtf SNmrdK5VO+mY
fcEv1XddxIWkwSzzrSqm9qnbtNv2cdFCbEqfTwBdx8deuL7rXQ9tk7e//Nrm 8NVvPrdt/9rV
n+1d1Qlx9s2JnFXbsWPkvLiLejj1wSlb3nJWuKZ8282J64E7bx4efejIcN6z q/LcDXnLJcj5
EIAABFZDoFV5c90e6BImaeXFJT3mSl9MmzF1Ym5n9MUSs/IoyZvEyyV9LonN veB++zt+dpu8
KUn75jPf3lp5O/rTHxz+zRt/afieH3nn8I/vWN/a/8HBtwx/9/vvG/7W975B lDdpjLmxc34f
skGey+Y5W95W89Y5ba/3nXhx8LZJVS5tWs7sv1zp88zjUluUQwACEIBAPQR6 k7cY4XCt0vjO
84mZb6XHXOnyXQT6Vt5MAXPFk7KaZwufNGafvEnjTL3Qfcv6O7fJ27c2vzNs PPs/tu2bz35n
0Lsu23zuO8gb/21y1K2zqXOU+pXJW84K15RvxTqu2EczlnvvuCUob6pc2kx5 M+v6jkvtUQ4B
CEAAAnUQ6Ene7FsEXStWsZKWswomrZRJq32ucYSOuUQttHoordKFxp57YfsT D//ilrx9a+Pb
13clamrl7dCbPzC8au3CsOfqitvf+4EHtva/8333Xqu3+W3kDXlD3hY4B1h5 c1wLnDm2K/iZ
N1UubcibRIhyCEAAAssk0KO8xYiLvUIWK3UxQiitvsXKm08CY27T1CtmoXhd q20p7MaI3Bve
8t7B3p/67BcGaf/CF7+MvC3wwn3MHOGcsitfq+aZLW+1r7yNuTQ4dWT3sHbu 9LB21r2rcmlD
3iRClEMAAhBYJoEW5M28dU+SEVNafKtV0i2EoVsO7TZDtzLqdkLx+2Kxx2G3 YV+QSbdZSmMO
iZyLaekLQum/Tfr6ixHhOeIvzYP22hKYnvOZLW/LfOsNR33y8K3B2yZVubQh bxIhyiEAAQgs
k0AL8tbzhU8vYx8rb73wYZzI3FLnQLa8tbjydvzQnqC8qXJpk+RNna//ciW1 RTkEIAABCNRD
AHnjom+pF33EzdxlDix/DmTLWz1vp+Uiuf3g3uBn3lQ5GwQgAAEI9EkAeVv+ xQ8XsOSQOcAc
WOocyJa3Flfejh7YNxze799VORsEIAABCPRJAHnjom+pF33EzdxlDix/DmTL W59v3YwaAhCA
AAR6JTCHvPXKlnHHE9DzMP4MakIAAksmoMU7W95aXHlbcmKJHQIQgAAEpiWA vE3Ll9bjCCBv
cZyoBYFWCCBvrWSScUAAAhCAwKwEkLdZcdOZh4Ceh7/+y28Yxuyf+sR7YAsB CCyIQDF5W9CY
CRUCEIAABCCQTQB5y0ZIAwUI6Hn4qxffNHzyK8+N2guEQRMQgMBMBIrJG7dN zpQxuoEABCAA
gSoItCBv5hdMp0LVX4WTel5ufftLsaeMw/VVPlP2N4bNVPImjVMqHzMWzoEA BGQCxeRN7mr5
Nf7lP/y3yx8EI4AABCAAgSIEWpA3BWLsRfjY84rAz4g7pf8lydsH3vvmrVW3 v7//Z7b2z//1
xvClrz87SF/SreqN2Vad/zExcw4EWiBQTN5qWXlTcUh7bOLOv/rDw/orH7u+ v+67zm77WZWz
QQACEIBAnwRalDd7VcvMrL1K51q1k47ZF/xS/dDMcrVlx6vl1LfCKK086j7M vuzntuD5OIVY
5ryC9Dx817se2iZvf/m1zeGr33xu2/61qz/bu6rj2syx5+QpZ2ycCwEIvJBA MXmrBa4kkVK5
OY5HXvGh4bF7nhweP/fx4T1HPjqsv+qxbT+rcmnL+ctUzrlSXJRDAAIQgEAe gVblzSdANi3p
PcolPlqmzEdXf/pYqI8UeYsZk6svSd6kdl3SJ8WdOiv1PHz7O352m7wpSfvm M9/eWnk7+tMf
HP7NG39p+J4feefwj+9Y39r/wcG3DH/3++8b/tb3vkGUN2mcqTFTHwIQGE+g mLylSNH4cOUz
pTikcrOHt778g1vi9uTbPjNcvOtjwxtfen7bz6pc2qQ3t9D5OedKcVEOAQhA AAJ5BHqTtxjp
cK3c+c7zyVJo9S8kej4xDPUv9SXJlzRe3/lSvykzU8/Dt6y/c5u8fWvzO8PG s/9j27757HcG
veuyzee+g7ylAKcuBFZMoJi8rXgc17uX5EwqN8dx/8vevbXipsTtwoGPDEdu ObXtZ1UubSm3
GvhutUDiJMqUQwACEJifQE/ypumatwhKMldi5S31D5wxK2W+uFx9heQtRkol +Ssxa/U8/ImH
f3FL3r618e3ruxI1tfJ26M0fGF61dmHYc3XF7e/9wANb+9/5vnuv1dv8NvJW IhG0AYGZCBST
txQpmnJsOg77r1r6F6gu9z3q2NQ/J1GfcVOrbWpX4qZ3fUyVS//EZOybm/kX xCl50TYEIAAB
CIwj0KO8me9NY9/fQvIktWlmyveHTakNSSpDfcTIq0vYUrilzkY9D9/wlvcO 9v7UZ78wSPsX
vvhl5C0VOvUhsEICxeRthWPY1rUkkVK52ZiSNPMzb0rezJ9VubS53kR8t1lI bzhSX5RDAAIQ
gMB8BFqQN9cdHy55cd1FooXElpXYNs3zfW2Espkib1L8qW3puHzv52a577kp gjmzVs9DXxvS
f5v0nRcjuaXGkDN+zoVAbwSKyVuKFE0JWYpDKjdje/1LHg5+5k2VS1uqkIX+ qif1RTkEIAAB
CMxHoAV5m4/WPD25JMwnZvNENH0vU8nb9JHTAwQgMIZAMXkb0/kU50hyJpWb MZ3ad/+2z7ip
lTbzM3CqXNokeQu90bT+hiOxoxwCEIBAzQSQt/qyg7zVlxMiggAEyhIoJm8p UlR2CNtbk77j
LSXOd7zm8UEJmt7VZ9zMn1V5zGbfVuC6fUO6pSOmH+pAAAIQgMB8BJC3+VjT k5+AtPIGOwhA
oC0CxeStLSzu0Uj/nKQHBowRAhCAAASuEZhD3vSbNI+Xt3izw4A5wBxgDlyb A2pBaod+sn7h
0qD2lC1lRSulXepCAAIQgAAEaiQwh7zVOG5iqosAK2915YNoIDA1AVbepiZM +xCAAAQg0CQB
5K3JtC5uUMjb4lJGwBDIIlBM3lh5y8oDJ0MAAhCAwMIIIG8LS1ij4ep5+Ou/ /IZhzP6pT7yn
UTIMCwJtEkDeEvKKoCbAoioEIACBxgkgb40neCHD0/PwVy++afjkV54btS9k qIQJAQhcJVBM
3qAJAQhAAAIQ6IlAC/Lm+pJlvqZmWbN4Knmzv4Dc/NLumC/nZh4tax4R7XII FJO3Hlalehjj
cqYukUIAAhBYLQHkbbX86f0aAT0PP/DeN2+tuv39/T+ztX/+rzeGL3392eHO t354+MH7PzB8
/7l3D9998ueGf/SDD2/t/9u//qnhb7/yDVv1XFtIvmLELKYOOYQABNIJFJO3 9K77PoOvHeg7
/4weAhBYPoFW5E1lwrzQtp9L31XqW72LWZ1Z/ixY/Qj0PHzXux7aJm9/+bXN 4avffG7b/rWr
P9u7qpMjb/YKnW7L9/21qydGBBBYNoFi8tbiqlTJL/w+/+oPD+uvfOz6rr7w 2/xZlS9xk/6y
JpUvcczEDAEIQEAR6EHezEybt82ZF+j2c/v3Pu8D075e9Dx8+zt+dpu8KUn7 5jPf3lp5O/rT
Hxz+zRt/afieH3nn8I/vWN/a/8HBtwx/9/vvG/7W977BK28+AfPJvvmHAPI+ bd5pvV8CxeSt
RYSSkErlJpNHXvGh4bF7nhweP/fx4T1HPjqsv+qxbT+rcmnz3X9u/5VLakf/ cnW9wab+spXq
S+UxsVIHAhCAQI0EWpI330W3a1UltEpnvr+w8jLPrNXz8C3r79wmb9/a/M6w 8ez/2LZvPvud
Qe+6bPO573jlzTcC5G2e3NILBFwEislbisgsJRXSmKRyc5xvffkHt8Ttybd9 Zrh418eGN770
/LafVbm0SSKUcotK6DYXKQ6zPCamlPaoCwEIQGApBFqXN98KWoy8LSWHLcSp 5+FPPPyLW/L2
rY1vX9+VqKmVt0Nv/sDwqrULw56rK25/7wce2Nr/zvfde63e5reRtxYmAmPo hkAxeWuRmCRn
UrnJ5P6XvXtrxU2J24UDHxmO3HJq28+qXNpCohT6K5irXfv2F9/tMNJnGex+ 7fqS3EljphwC
EIBArQRakzfF2fwdXkreeB+YdgbrefiGt7x3sPenPvuFQdq/8MUvI2/TpojW IVCUQDF5SxGZ
oiOYsDE9Jt/tirrc96hDU/+cRH3GTa22qV2Jm971MVUu/RMT1+0ruo/S8hbz pq3f6M1HOx7e
tCecoDQNAQislEDr8mbKnE/qQqtwKXeDrDSRC+9cz0PfMKT/Nuk7z3ftY98O 67tesP8YsHDM
hA+BaggUk7dqRlQwEElIpXIzFCVp5mfelLyZP6tyaZti5c0WL9cKXKykueQS eZOySjkEILBU
Ai3I21LZE/cNAlPJG4whAIE6CRSTtxSRqRPFC6OSxiSVmy2+/iUPBz/zpsql zSdCrr+OSdKU
+pmFVKnTY5HikMZMOQQgAIFaCSBvtWamr7gkeeuLBqOFQPsEislbi6gkOZPK TSan9t2/7TNu
aqXN/AycKpe2kLzZ50rSJLXFbZNSNiiHAAR6J4C89T4D6hg/8lZHHogCAnMR KCZvKSIz1+By
+yn5PW/veM3jgxI0vavPuJk/q3JpC91/XlreVHv2fe26D99n71z1JYmUxkw5 BCAAgVoJzCFv
+k2ax8tb36vHDgPmAHOAOXBtDihP2aGfrF+4NKidbToC0j8nma5nWoYABCAA gRIE5pC3EnHS
RtsEWHlrO7+MDgI2AVbeGp8TYz4P1zgShgcBCECgCAHkrQhGGskkgLxlAuR0 CCyMQDF5W9i4
CRcCEIAABCCQRQB5y8LHyYUI6Hn467/8hmHM/qlPvKdQJDQDAQjMQaCYvLX4 mbc5EkAfEIAA
BCCwTALIm5y3nM89S/9YS+69jxp6Hv7qxTcNn/zKc+L+R9/49qB3Xb8PUowS Am0QQN5WlEdk
d0Xg6RYCEIBAIQKtyJvvn1DFYJLkzPc1MzltS33GtN1SnankDc4tzRLG0hKB YvLWEhTGAgEI
QAACEJAItCBvU1+g57TPyps0A6+V63n4gfe+eWvV7e/v/5mt/fN/vTF8/kvb 97/6m83h//yZ
39za/9H3nhz+6m+e3arn2nJyFxc5tSAAgTEEiskbK0lp+OGVxovaEIAABGoj 0Lq8hb7+xbWi
FlvfV08f13kOfS2Nq05t82OuePQ8fNe7Htomb3/5tc3hL4z9q9987rq0KXFT Ave1q8fUcZ+8
mTmxc+77PljVlu+rhuZiQj8QaJlAMXlrGVLtY+NrB2rPEPFBAAItEmhB3nwX 2r4Lc5dg+S78
ddvmo1lXWlkLxeBqs9eVIj0P3/6On90mb0rM1K4k7ZvPfHvr8bYfeNP1lTd9 TIlcKIe2KJs/
u/IZkroWfw8wJgjMTaCYvLGSFE5dyS/8Pv/qDw/rr3zs+q6+8Nv8WZXPtUlv llL5XHHSDwQg
AIHSBFqRN98FuGvlK3a1JWWVxhZI3+fkXG3mfF6v9HxYVXt6Hr5l/Z3b5O1b m9/ZujVSr7Lp
x5fd9cuD2vWtk+oxVt5C8m3mh7ysajbQbw8EislbD7ByxijJrVRu9v3IKz40 PHbPk8Pj5z4+
vOfIR4f1Vz227WdVLm32X0/NN0/p3NAvb/tc5C2FJnUhAIElEWhd3lIu6FNW yaSVmRR5W9J8
mSpWPQ9/4uFf3JK3b218+/r+368+f82P/cctgVOPG89+Z9tn3pS4bTz3neLy NtVYaRcCELj2
OVe1K3fYoZ+sX7g0qD1lS5GPlHZbqSvxkcpNDm99+Qe3xO3Jt31muHjXx4Y3 vvT8tp9VubQh
bxIhyiEAAQiECfQkb7FCpYn5Vt5cf9CTxE9q0y7vbd7qefiGt7x3cO3/9bN/ tiVv//WzX9ja
zX9Yop5/4YtfnlTe+CNubzOS8U5NoJi8TR3o0tuX5EwqN8d//8vevbXipsTt woGPDEduObXt
Z1UubTFvrL4PHPtuh3DV55e2lAnKIQCBpRJoQd5Ct7fF/E43f8eHbrP03VJn ipfdX+i9xnXe
UudRbtx6Hsa0o2+V1J9z07dS+s41/9DrE2/fPHH9kTgmRupAAALyHw5ZeZth lmg5s9+M9C9D
Xe571CGqf06iPuOmVtvUrsRN7/qYKpf+iYkkb2P/Eur7C+kMiOkCAhCAwKwE WpC3WYHR2SQE
ppS3SQKmUQhAIIsAK29Z+OJPllbWpHKzJyVp5mfelLyZP6tyabP/WipJV8wt M6G/ukrxUA4B
CEBgaQSQt6VlrM14U+TN9Z8lff9tsk1ajAoCyydQTN5S5GP52NJHIPGRys0e X/+Sh4OfeVPl
0jaFvLn65LZJKROUQwACSyWAvC01c23FnSJvbY2c0UCgTwLF5K1PfPGjluRM Kjd7OrXv/m2f
cVMrbeZn4FS5tPmkKmaFzWw7tb4UF+UQgAAElkJgDnnTb9I8XvvvauwwYA4w B5gD/LfJWa4T
Sn7P2zte8/igBE3v6jNu5s+qXNokeVPn8w9LJIqUQwACPROYQ9565svY4wiw 8hbHiVoQaIUA
K28NZFL65yQNDJEhQAACEKiOAPJWXUq6DAh56zLtDLpjAsXkLeW2v455Xx86 vJgFEIAABJZN
AHlbdv5aiR55ayWTjAMCcQSKyVtcd9SCAAQgAAEItEEAeWsjj0sfBfK29AwS PwTSCBSTN1aS
0sBTGwIQgAAElk0AeVt2/lqJHnlrJZOMAwJxBJC3OE7Fa5WU3ZJtFR8oDUIA AhBolADy1mhi
FzYs5G1hCSNcCGQSKCZvmXFwOgQgAAEIQGBRBJC3RaWr2WCRt2ZTy8Ag4CRQ TN5Y/UmbYSV5
lWwrbRTUhgAEINAvAeSt39zXNHLkraZsEAsEpidQTN6mD5Ue5iDA1w7MQZk+ IACBFgggby1k
cfljQN6Wn0NGAIEUAsXkjdWfFOzDkMOr5Bd+n3/1h4f1Vz52fVdf+G3+rMpz Nt+Xgee0mXOu
FI9UntM350IAAm0RQN7ayudSR4O8LTVzxA2BcQSKydu47jlrDAFJ/KRys89H XvGh4bF7nhwe
P/fx4T1HPjqsv+qxbT+r8thNiY+5q/NKyZBu14zFdUyKVYpHKpfapxwCEOiH APLWT65rHiny
VnN2iA0C5QkUk7cUYSg/jOW1mMNLOlcqN2m99eUf3BK3J9/2meHiXR8b3vjS 89t+VuUxm096
SskQ8haTBepAAAJzEkDe5qRNXz4CyBtzAwJ9ESgmb31hW+1oJTmTys3o73/Z u7dW3JS4XTjw
keHILae2/azKpS0kaGaZvSqn23Ud963g6fbsR9VWTPtSPKVkU2JGOQQgsHwC yNvyc9jCCJC3
FrLIGCAQT6CYvKUIQ3x47dbM4aXPtW9T1OKhy32Pmqr65yTqM25qtU3tStz0 ro+pcumfmMTK
m5lNl3yZMmdn3idtvnZKHW93BjIyCEAglwDylkuQ80sQQN5KUKQNCCyHQDF5 W86Qlx+pJH5S
uUlASZr5mTclb+bPqlzaYuXN95k4+3zfLZIuucuRtCk/oycxoxwCEFg+AeRt +TlsYQTIWwtZ
ZAwQiCdQTN5ShCE+vHZr5vCSzpXKTaqvf8nDwc+8qXJpi5E3l6CZ7UqfabNv d7RFztd+7HGX
GErjphwCEOibwBzypt+kebw8wAAGzAHmAHPgxhxQ1/s7FBD1ZP3Cpa2drU4C kpxJ5eaoTu27
f9tn3NRKm/kZOFUes0n/sESSN9WHq43Q7ZXmObGSlrpSFzN26kAAAn0SmEPe +iTLqFMIsPKW
Qou6EFg+AVbeVpTDFMGyQyz5PW/veM3jgxI0vavPuJk/q/LYTboNMXTb5Nh/ JCKdpwXP9c9M
fMdix0s9CECgbwLIW9/5r2X0yFstmSAOCMxDoJi8zRMuvUxNQPrnJFP3T/sQ gAAElkIAeVtK
ptqOE3lrO7+MDgI2gWLylrOS1GNa4NVj1hkzBCDQEgHkraVsLncsyNtyc0fk EBhDoJi8jemc
cyAAAQhAAAJLJYC8LTVzbcWNvLWVT0YDAYlAMXljJUlCvb0cXmm8qA0BCECg NgLIW20Z6TMe
5K3PvDPqfgkgbyvKfa3yVmtcK0oT3UIAAhDwEkDemBw1EEDeasgCMUBgPgLF 5G2+kOkJAhCA
AAQgsHoCyNvqc0AEw9b337FBAAL9ECgmb6zYpE2aWnnVGlcaXWpDAAIQmJ4A 8jY9Y3qQCSBv
MiNqQKAlAsXkrSUojKUMAb52oAxHWoEABOokgLzVmZfeokLeess44+2dQDF5 Y8UmbSrVwqvk
F36ff/WHh/VXPnZ9V1/4bf6sytkgAAEItEIAeWslk8seB/K27PwRPQRSCRST t9SOqV8HAUki
pXJzFI+84kPDY/c8OTx+7uPDe458dFh/1WPbflblMduOHTsGc485x6yjzmWD AAQgMDUB5G1q
wrQfQwB5i6FEHQi0Q6CYvKVc5LeDb/xIauElxSGVmwTe+vIPbonbk2/7zHDx ro8Nb3zp+W0/
q3JpKyFeJdqQ4qQcAhCAAPLGHKiBAPJWQxaIAQLzESgmb/OFTE8lCUhyJpWb sdz/sndvrbgp
cbtw4CPDkVtObftZlUubT7zs4+bP9iqda9Uu5piuI8VIOQQgAAFFAHljHtRA AHmrIQvEAIH5
CBSTt5SL/PmGV29PtfDScdi3Kmo50uW+R01Y/XMS9Rk3tdqmdiVuetfHVHnM PzHxiZaZTR2f
S/ZCoqfacJ1ry2C9M4fIIACBWgggb7Vkou84kLe+88/o+yNQTN76Q9fGiCWJ lMpNCkrSzM+8
KXkzf1blqZtLqlyrbi6x08d8YuoTNm67TM0S9SHQJ4E55E2/SfN4eWulkx0G zAHmAHPg2hxQ
1+g79JP1C5cGtadsKRf5Ke22WrcWXlIcUrmZn9e/5OHgZ95UeeomyZstaObK mlnm6hd5S80G
9SEAAZPAHPIGcQhIBFh5kwhRDoG2CLDy1lY+k0cjyZlUbnZ4at/92z7jplba zM/AqfLUTboF
0mzPdyulrw3kLTUb1IcABJA35kBtBJC32jJCPBCYlkAxeUu5yJ92SMtovRZe Jb/n7R2veXxQ
gqZ39Rk382dVLm3S1wS4RMz1j0bsY9Ln6PjMm5QZyiEAAZsAK2/MiRoIIG81 ZIEYIDAfgWLy
Nl/I9LQUAjH/nCRlLHwWLYUWdSEAgakJIG9TE6b9GALIWwwl6kCgHQLF5K2W laSlpAZe6ZlC
3tKZcQYEIDAdAeRtOra0HE8AeYtnRU0ItECgmLy1AIMxQAACEIAABGIJIG+x pKg3JQHkbUq6
tA2B+ggUkzdWktKSC680XtSGAAQgUBsB5K22jPQZD/LWZ94Zdb8EkLcV5b4H eethjCuaPnQL
AQhUQAB5qyAJhLD1fU9sEIBAPwSKyVs/yBgpBCAAAQhAYLh+0Zz6hbHqD1u3 3Xbb1vepql39
bLZh/gxnCEgEkDeJEOUQaItAMXljlSVtYvTAK2eM6/fcNEh7GnFqQwACEChL gJW3sjxpbRwB
5G0cN86CwFIJFJO3pQIg7joJKHHb2Lzi3VU5GwQgAIFVEkDeVkmfvjUB5I25 AIG+CBSTt5xV
lr6QXxtti7xKfuH3I3fvDMqbKs/ZWvjagRbGkJNDzoXAqgkgb6vOAP0rAsgb 8wACfREoJm99
YWO0LgKSkErlZpsP3rVzeGbjqa19Y/P5XT+/+qjKYzclOeauzistPqXbs8c2 9RhsPrFsqQeB
ngkgbz1nv56xI2/15IJIIDAHgWLylnJhPsfAau+jRV72mGyhSRnzA3fePDz6 0JHhvGdX5TGb
T6pKypYWn5h4dJ2U/qceg91+SmwpY6YuBFojgLy1ltFljgd5W2beiBoCYwkU k7exAXBeOwRK
ytt9J14cvG1SlUtbSELMMt+qk+t4qK4Uj10eI31zjmGMWKaOmfoQaIkA8tZS Npc7FuRtubkj
cgiMIVBM3lJWVcYE2to5LfLSY7Jv8dMCost9j2aO773jlqC8qXJpixUfsx19 juvcMe1JMary
kMSN6XPsGHQsMTFTBwIQmOerAlK/hoD6l7d97QI84MEcYA60OgfU9fQONTj1 RH/3DG/OEEgh
UHLl7cyxXcHPvKlyaYsVH9/nyVy3E465hTH282Q5wjj1GCTWlEOgRwKsvPWY 9frGzMpbfTkh
IghMSYCVtynpBtpueeVNDzvnM2+njuwe1s6dHtbOundVLm0x8iZ93su1KuY7 JsXjK89deSsx
Bj7nNjZ7nNczAeSt5+zXM3bkrZ5cEAkE5iBQTN7mCJY+6iYgCalUbo7u5OFb g7dNqvKYTVop
k8RH9RGzIjZGfmI+8+br3zyeO4Yxscewpw4EWieAvLWe4WWMD3lbRp6IEgKl CBSTt5QL81LB
L7mdFnmV/J6344f2BOVNlcduvlsK9fmhWw5NsfHd/hh7W6QZb6owTTkGu+3U 2GLzQD0ItEYA
eWsto8scD/K2zLwRNQTGEigmb2MD4DwIuAjcfnBv8DNvqpwNAhCAwCoJIG+r pE/fmgDyxlyA
QF8EislbiytJU06FHnjljPHogX3D4f3+XZWzQQACEFglAeRtlfTpG3ljDkCg TwLF5K1PfIwa
AhCAAAR6JYC89Zr5usbNyltd+SAaCExNoJi85ayyTD3IGtuHV41ZISYIQAAC 8QSQt3hW1JyO
API2HVtahkCNBJC3FWWlB3nrYYwrmj50CwEIVEAAeasgCYSw9aXkbBCAQD8E islbP8gYKQQg
AAEIQGC4ftGs30hjH9Uftm677bZh/cKlrV39bJ5r/gxnCEgEkDeJEOUQaItA MXljlSVtYvTA
K2eM6/fcNEh7GnFqQwACEChLgJW3sjxpbRwB5G0cN86CwFIJFJO3pQIg7joJ KHHb2Lzi3VU5
GwQgAIFVEkDeVkmfvjUB5I25AIG+CBSTt5xVlr6QXxtti7xKfkn3I3fvDMqb Ks/Z+CLqHHqc
CwEIKALIG/OgBgLIWw1ZIAYIzEegmLzNFzI91UpAElKp3BzXg3ftDH5JtyqP 3ZSombs6r6S8
2W3HxkU9CEBg2QSQt2Xnr5XokbdWMsk4IBBHoJi8pVyYx4XWdq0WeUljksrN jD9w583Dow8d
Gc57dlUes/kkrZS82e2UajdmbNSBAARWSwB5Wy1/er9GAHljJkCgLwLF5K0v bIzWRUCSM6nc
bPO+Ey8O3japyqUtJFJmmW/lzHVcWmVD3qSsUA6BdgjMIW+x/8GSepe3/cdO eMCDOcAcaH0O
qOvqHWqQ6on+98Upb7EpF+Yp7bZat0Veekz2bYpaaHS579HM9b133BKUN1Uu bbHyZrajz3Gd
K4mZVC7FSzkEILAsAnPI27KIEO0qCLDytgrq9AmB1RFg5W117JvrWRJSqdwE cubYruBn3lS5
tMXKm+8zca5bIqe+DVMaE+UQgEA9BJC3enLRcyTIW8/ZZ+w9EigmbykX5j2C tsfcIi9pTFK5
yejUkd3D2rnTw9pZ967KpS1G3qTPrGmxM/uyj7HiJmWCcgi0SQB5azOvSxsV 8ra0jBEvBPII
FJO3vDA4uwUCkpxJ5SaDk4dvDd42qcpjNmmlTJI31UfoFkrELSYL1IFAmwSQ tzbzurRRIW9L
yxjxQiCPQDF5S7kwzwu5jbNb5FXye96OH9oTlDdVHrv5bovU54dum5T+sYnv 832xsVEPAhBY
LgHkbbm5ayly5K2lbDIWCMgEismb3BU1IBBP4PaDe4OfeVPlbBCAAARWSQB5 WyV9+tYEkDfm
AgT6IlBM3lpcSZpyKvTAK2eMRw/sGw7v9++qnA0CEIDAKgkgb6ukT9/IG3MA An0SKCZvfeJj
1BCAAAQg0CsB5K3XzNc1blbe6soH0UBgagLF5C1nlWXqQdbYPrxqzAoxQQAC EIgngLzFs6Lm
dASQt+nY0jIEaiSAvK0oKz3IW8kxlmxrRSmnWwhAoDECyFtjCV3ocJC3hSaO sCEwkkAxeRvZ
P6dBAAIQgAAEFkkAeVtk2poLGnlrLqUMCAJBAsXkjZWRtJnWA6+SYyzZVlqm qA0BCEDATQB5
Y2bUQAB5qyELxACB+QgUk7f5QqYnCEAAAhCAwOoJIG+rzwERDAPyxiyAQF8E iskbKyNpE6cH
XiXHmNPW+g/vHEK7ytz3/n/+TVoCqQ0BCHRPAHnrfgpUAQB5qyINBAGB2QgU k7fZIqYjCCQS
eMvJm4eNzSvO/eMfeWSrNSVvu/9f/zSx5WHYsWNH8By7XKofasx1rjqm99Tg pVik8tT+qA+B
1gggb61ldJnjQd6WmTeihsBYAsXkLWdlZGzwSz6vB14lx5jT1htfd8sLxO27 f/Rdg9pfdvz+
4eU/cGJL3sYKXIpw5QiRJII5bbvGULq9Jb9eiR0CLgJzyJt+k+bx8tbtgeww YA4wB5gD1+aA
ujbeoZ+sX7g0qJ0NAi0QOHX01uGZjae29o3N7ftHf+Xt0StvrlUuLThmmSk9 9jm+NlyrZzHn
mvnxyZZ0PDb2FuYCY4BASQJzyFvJeGmrTQKsvLWZV0YFAR8BVt5WNDdyVpJW FHJytyXHqNuK
fTSDfd1r/8nwg//Hbc5dlalN+sybb9XLlDeXSKWulvnaU22HVsLGlKXGnjwB OAECjRNA3hpP
8EKGh7wtJFGECYFCBIrJW6F4aAYCVRKwV6ds8ZHkTg/KVc+18uVbiXPBGXt7 I/JW5VQjqAUR
QN4WlKyGQ0XeGk4uQ4OAg0AxeSu5ytJDpnrgVesY/x+33Zk8xWJuPSyx8mYH ZkqcK4ax4mau
5MWKZzI0ToBA4wSQt8YTvJDhIW8LSRRhQqAQgWLyVigemoHApASUuJWQt5Ir by7pGyOCPnCl
xHPSxNA4BBZIAHlbYNIaDBl5azCpDAkCAQLF5K3WVZZas98Dr1rHOEbe9EqV fTujdOuheZ6e
i642Yo7Zbflu5bTn/Fh5c8Ve6+uJuCCwCgLI2yqo06dNAHljTkCgLwLF5K0v bIx2yQTGytuS
x0zsEIBAeQLIW3mmtJhOAHlLZ8YZEFgygWLyVusqS63J6YFXjWPUt00icLW+ MogLAsshgLwt
J1ctR4q8tZxdxgaBFxIoJm/AhQAEIAABCPREAHnrKdv1jhV5qzc3RAaBKQgU k7caV1mmAFaq
zR549TDGUvOBdiAAgeURQN6Wl7MWI0beWswqY4KAnwDytqLZ0YPY9DDGFU0f uoUABCoggLxV
kARCGJA3JgEE+iJQTN76wsZoIQABCECgdwLIW+8zoI7xI2915IEoIDAXgWLy xipLWsp64JUz
xvV7bhqkPY04tSEAAQiUJYC8leVJa+MIIG/juHEWBJZKoJi8LRUAcddJQInb xuYV767K2SAA
AQiskgDytkr69K0JIG/MBQj0RaCYvOWssvSF/NpoW+SlxiTtsbl+5O6dQXlT 5Tmb74urc9rk
XAhAoC8CyFtf+a51tMhbrZkhLghMQ6CYvE0THq0uiYAkpFK5OdYH79o5PLPx 1Na+sfn8rp9f
fVTlsZsSNXNX55WUN7vt2LioBwEILJvAHPKm36R5vLz1jznYYcAcYA4wB67N AXVdvUM/Wb9w
aVB7ypZyYZ7Sbqt1W+Rlj8kWpJQxP3DnzcOjDx0Zznt2VR6z+SStlLzZ7ZRq N2Zs1IEABFZL
YA55W+0I6X0JBFh5W0KWiBEC5Qiw8laOZfctlZS3+068OHjbpCqXtpBImWW+ lTPXcWmVDXmT
skI5BNohgLy1k8sljwR5W3L2iB0C6QSKyVvKqkp6mO2d0SIvPSb7NkUtNLrc 92hm+d47bgnK
myqXtlh5M9vR57jOldpD3KSMUA6Btgggb23lc6mjQd6WmjnihsA4AsXkbVz3 nNUSgZIrb2eO
7Qp+5k2VS5skW/p832fiXLdESoImlUsxUw4BCCyHAPK2nFy1HCny1nJ2GRsE XkigmLy1uJI0
5YRpkVdJeTt1ZPewdu70sHbWvatyaYuRN+kza1rs7NW5qT9LJ42NcghAYPUE kLfV54AIhq1/
XMAGAQj0Q6CYvPWDjJH6CEhCKpWb7Z48fGvwtklVHrNJkiXJm+ojdAtlzPkx cVIHAhBYHgHk
bXk5azFi5K3FrDImCPgJFJO3lAtzEsL3vElz4PihPUF5U+Wxm++2SH1+6LbJ sf/YJDY26kEA
AsslgLwtN3ctRY68tZRNxgIBmUAxeZO7ogYE4gncfnBv8DNvqpwNAhCAwCoJ IG+rpE/fmgDy
xlyAQF8EiskbK29pE6cHXjljPHpg33B4v39X5WwQgAAEVkkAeVslffpG3pgD EOiTQDF56xMf
o4YABCAAgV4JIG+9Zr6ucbPyVlc+iAYCUxMoJm85qyxTD7LG9uFVY1aICQIQ gEA8AeQtnhU1
pyOAvE3HlpYhUCMB5G1FWelB3noY44qmD91CAAIVEEDeKkgCIfBVAcwBCHRG oJi8dcaN4UIA
AhCAQOcEkLfOJ0Alw2flrZJEEAYEZiJQTN5YZUnLWA+8csa4fs9Ng7SnEac2 BCAAgbIEkLey
PGltHAHkbRw3zoLAUgkUk7elAiDuOgkocdvYvOLdVTkbBCAAgVUSQN5WSZ++ NQHkjbkAgb4I
FJO3nFWWvpBfG22LvNSYpD0214/cvTMob6qcDQIQgMAqCcwhb/pNmsfLW5/t YocBc4A5wBy4
NgfUNfcO/WT9wqVB7WwQSCEgCalUbvb14F07g1/Srcpjth07dgx6j6kfW8ds Vz2P2WLrxbRF
HQhAYPUE5pC31Y+SCGonwMpb7RkiPgiUJcDKW1me0a2liEx0oyuuaI/JlpWU MT9w583Dow8d
Gc57dlWespUWJ7u9mPZj6qSMiboQgMBqCSBvq+VP79cIIG/MBAj0RaCYvPWF jdG6CJSUt/tO
vDh426QqT9lMcXKtxoVkLKa+iiWmD3sVcKqVwRQ21IUABMYRQN7GceOssgSQ t7I8aQ0CtRMo
Jm8pqyq1Q5kjvhZ56THZtxRqqdHlvkeT+7133BKUN1WesvlWvfTx2JU0X31b 3szYYvtgZS4l
o9SFwOoJIG+rzwERsPLGHIBAbwSKyVtv4BjvCwmUXHk7c2xX8DNvqjxl862K 2cddEub6fJtL
tKQ+XII45rNzKeOmLgQgMB0B5G06trQcT4CVt3hW1IRACwSKyVuLK0lTJrhF XiXl7dSR3cPa
udPD2ln3rspTtpjVL1cd34pcSN5iz2GlLSWD1IVAfQSQt/py0mNEyFuPWWfM PRMoJm89Q2Ts
1whIQiqVmxxPHr41eNukKk/ZYuRNtSfdPhnTzlh5Q+ZSMkpdCKyeAPK2+hwQ AbdNMgcg0BuB
YvKWcmHeG2TXeFvkJX3HW8qYjx/aE5Q3VS5tvn8GErpV0beiZrcl3e7oK9fH dey+GKWxUQ4B
CKyeAPK2+hwQAfLGHIBAbwSKyVtv4BjvtARuP7g3+Jk3Vc4GAQhAYJUEkLdV 0qdvTYDbJpkL
EOiLQDF5S1lV6Quxe7TwCs+Cowf2DYf3+3dVzgYBCEBglQSQt1XSp2/kjTkA gT4JFJO3PvEx
aghAAAIQ6JUA8tZr5usaNytvdeWDaCAwNYFi8sZKUlqq4JXGi9oQgAAEaiOA vNWWkT7jQd76
zDuj7pcA8rai3CNvKwJPtxCAAAQKEUDeCoGkmSwCyFsWPk6GwOIIFJO3xY2c gCEAAQhAAAIZ
BJC3DHicWowA8lYMJQ1BYBEEiskbK0lp+YZXGi9qQwACEKiNAPJWW0b6jAd5 6zPvjLpfAsXk
rV+Eqx/5v/yH/3b1QRABBCAAgc4IzCFv+k2ax8sDDGDAHGAOMAduzAG1ELRD AVFP1i9c2tpT
NlaSwrRKfoH1+Vd/eFh/5WPX99d919ltP6tytnYJuL5IvN3RMjII1EtgDnmr d/REVgsBVt5q
yQRxQGAeAqy8zcN5S4pDm1RunvvIKz40PHbPk8Pj5z4+vOfIR4f1Vz227WdV Lm1KAOzdPEeX
Se2o8lA7dpux7el2x5xv9yGNNSamUnViWYX6Q95KZYN2IJBHAHnL48fZZQgg b2U40goElkKg
mLylyMdS4JSM0+ZjX4Cn8Hvryz+4JW5Pvu0zw8W7Pja88aXnt/2syqVNEoBU eSshWS7pksaR
Ui6NOaWtsXXtGMbENOacsfFyHgQg4CeAvDE7aiCAvNWQBWKAwHwEisnbfCEv s6eS8nb/y969
teKmxO3CgY8MR245te1nVS5tIQEwy2JEwSck+rjr0ZRDWxTN+nY9Na6QAJkr W5IMhuL2tZN6
PCWG2LZ9+Yk53z43RdKlOUU5BHojgLz1lvE6x4u81ZkXooLAVASKyVvKytFU g6m5Xc3Hdwuf
Lvc96rGpf06iPuOmVtvUrsRN7/qYKpf+iUno9r2S8uZqKyQfppxJUqiZ2HJo H0/9Obff0DyM
XXnzjSnEx+xXYhIbR82vKWKDwKoJIG+rzgD9KwLIG/MAAn0RKCZvfWFLH23J lTclaeZn3pS8
mT+rcmkrvfLmWvWJkaCQ3EkrbKbI6OexUhoSv9gVOXuFUGLuitEWLpujK0++ 1TLX2FPHEjMG
6kAAAtcIIG/MhBoIIG81ZIEYIDAfgWLyxspbOGkl5e31L3k4+Jk3VS5tPnlz rQyGRM8WKFtG
XD/nrryZfaasEvpEyCWBUtwuvjG3IIa4x/bpWlWLEWUfN2muUA4BCLgJIG/M jBoIIG81ZIEY
IDAfgWLyNl/Iy+xJklup3Bz1qX33b/uMm1ppMz8Dp8qlLVYiQnKm+4htS5IO u1y6tS+33Bd/
qgiFhNXOQw4rV7wupiFJk+pL84ZyCEDgBgHkjdlQAwHkrYYsEAME5iNQTN5S 5GO+4dXTU8nv
eXvHax4flKDpXX3GzfxZlUuba4XNJ2qrWnnT8aQIh33bYYxYuWTN147reKjP WHkzx2qv4Nnt
x94KacpebtzSfKIcAj0SQN56zHp9Y0be6ssJEUFgSgLF5G3KIGk7TED65yTw 8xMI3UrZIjdJ
xFscM2OCwFQEkLepyNJuCgHkLYUWdSGwfALF5I2Vt+VPBmkErtW6pcvAVPJW E6uUlUFpDlAO
AQjcIIC8MRtqIIC81ZAFYoDAfASKydt8IdMTBCAAAQhAYPUEkLfV54AI+KoA 5gAEeiNQTN5Y
eett6jBeCEAAAn0TQN76zn8to2flrZZMEAcE5iGAvM3DmV4gAAEIQKAxAshb Ywld6HCQt4Um
jrAhMJJAMXkb2f/woZ/aG9zHtst5EIAABCAAgSkJIG9T0qXtWALIWywp6kGg DQLF5G3sbZNK
3jaf/bZz//TFf7cldmwQgAAEIACB2gjMIW/6TZrHywMMYMAcYA4wB27MAeVe OxQQ9WT9wqWt
fY7t/T/5T4ZnNp9z7n/4kXuGzyBwc6SBPiAAAQhAIJHAHPKWGBLVOyTAyluH SWfIXRMYvfJW
6kunP/1bbx++tfHcoL6rTD2a+9OXf3JQAvfpi4eG97zptlGJGvOv7O0vSR7V ceRJUnxSeWQ3
3mpTtx8TXw0xhOKccz6sgpfE3/el4DGxUgcCLRNA3lrO7nLGhrwtJ1dECoES BLLkLRRAzG2U
51/94WH9lY9t7a/7rrPXn6vj3/jWc9f3//bfnxsu/PhLRo239gvT1PhiIUjt 6nZi68X2O6ae
jqGGWOz4e4hJGqNP3lzfZTcm/5wDgaUSQN6Wmrm24kbe2sono4GARGCl8vbW l39wePJtnxku
3vWx4Y0vPX/9uTr+9avydn3/5nPDz73hn0pjcZaPvTAd1dmIk1LjG9FF8BSp /9L9udqrIQbf
OGuMrXRMUnsheZtjftAHBGolgLzVmpm+4kLe+so3o4XASuXt/pe9e0vcLhz4 yHDkllPXn6vj
X/nGs9v29bMvFSXEXAnQlc0LT1+5eVtcTB3Vtr1aZJ/nutUudPuZvYphx596 rhmfa0zmGMy+
7Lhdq2K+WO0Ehfq1mdtMY8/V57l4x8Qj5c0Xh9l2bqwSY7svX758c046HvMa 8b2eQtLrmkup
8yv0op+TO28VEHARQN6YFzUQQN5qyAIxQGA+AtnyZl/I6wtBfduk71F9xk3d KqlW3JS4qV09
V7s6rsq/9PXN6/uDa98typvrIteWnhQp8gmOKQzSRa19YRy6EA/F75M36bgk fa74XSIl1XOJ
Umw+XCKceq4vPiluX35cQuWagBJ/X77HMpbitduN4egbq08qTaYugXK95kKc Yl8jsSxT5uKY
vuf79UxPtRNA3mrPUB/xIW995JlRQkATyJY3H8qYz7y9/iUPO2+bVMe/+NXN 6/tfXH3+5h/5
Z8GsxVxE26IZkrOUi367ndAF4RLlLeai2XXBHMPbJRuxF/r6XFc/Y+Jx5c0n /z6BCUlfzByV
xjS1vEk5i5nbqfJmz69S+RzzGo7pm7cPCJhvoOp56r+uVu+Pt9122/X/7Kx+ Ntswf4Y2BCQC
yJtEiHIItEVgpfJ2at/912+VVCtu+hZKdfzPvry5bf+JH/7nWfKWcuEcIytj V7R6kjdXwkIX
9tIKkC1MLvn2TRKfhEkyFCNvqeO0pSI0l1wS6pKSGPGU+I5lFIpxjEDF/IqN iXWqvmPio04f
BFh56yPPtY8Seas9Q8QHgbIEVipv73jN44MSNbWrWyX1c3X881/a2Lb/2A/9 i8XLW6zwmVKS
esFt14/ts4TchlZlYlakpLG6xLfk+GIEyBbGWG4u0YwdrySYvphiY5PiiOk/ 9AePqcfuer3k
/gEm5Q8DZX8l09qSCCBvS8pWu7Eib+3mlpFBwEUgS96k73qLQf5rj79v+JO/ 2tj6jJt6dO1/
/Jcbw5k7Xy7Km3nLk+uv7r5bovRx3wWb1G7ogj72wjcUmzkWXyz28ZQLclf7 Ln4xcdgXzSZb
Xz8u4ZTGGduPVE/Kj2uFxyVFMePU88Su6+tDqifF7uvPPm634+s3NG7XObHH 7Be2K/c+AZyD
e8zvMer0SQB56zPvtY0aeastI8QDgWkJjJa3UmGdOvE9w+f+4hlx/5Hj3yPK W6mY5mjHtyqS
27dLBFxtxtaT4inVji1ZUr89lk/BOoXjqvtPiZW6EJiDAPI2B2X6kAggbxIh yiHQFoGVy9vd
r/ve4e7jan/F8EOve8X15zd+vnpM1blaFtqWdmFZUt58KxVT8RrTX8rLZmm5 TBlbTt1Vc1l1
/znsOBcCUxBA3qagSpupBJC3VGLUh8CyCaxc3paNj+ghAAEIQKBXAshbr5mv a9zIW135IBoI
TE0AeZuaMO1DAAIQgECTBJC3JtO6uEEhb4tLGQFDIItAlfIW8x1xWaPmZAhA AAIQgEAmAeQt
EyCnFyGAvBXBSCMQWAyBKuVtMfQIFAIQgAAEuiUwh7ylfgE49S8nf2k6zGDG HGAOLHEOqMWu
HSpw9WT9wqWtfVUbK2+rIk+/EIAABCAQS2AOeYuNhXr9EmDlrd/cM/I+CTS/ 8qa+P44NAhCA
AAQgUJoA8laaKO2NIYC8jaHGORBYLoEq5E36su+Ulbjzr/7wsP7Kx67vr/uu s9t+VuVsEIAA
BCAAgVwCyFsuQc4vQQB5K0GRNiCwHALVyFsIWYq8PfKKDw2P3fPk8Pi5jw/v OfLRYf1Vj237
WZWzQQACEIAABHIJIG+5BDm/BAHkrQRF2oDAcgg0J29vffkHt8Ttybd9Zrh4 18eGN770/Laf
VTkbBCAAAQhAIJcA8pZLkPNLEEDeSlCkDQgsh0Bz8nb/y969teKmxO3CgY8M R245te1nVR6z
7dixY9C7Wd913HdMnafK9OZrMyYe6kAAAhCAQF0EkLe68tFrNMhbr5ln3L0S qEreTLkxxUnf
Nul71MlT/5xEfcZNrbapXYmb3vUxVS79ExNTuEwBs4/bcmbXtcXNlsBeJx3j hgAEINACAeSt
hSwufwzI2/JzyAggkEKgKnnzBZ7ymTclaeZn3pS8mT+rcmnzSWSqvNmyZrcr xUE5BCAAAQjU
SwB5qzc3PUWGvPWUbcYKgeH6d1mu9HveJDmTys1Evv4lDwc/86bKpc0laeqc XHmT+qUcAhCA
AASWQwB5W06uWo4UeWs5u4wNAi8k0NzK26l992/7jJtaaTM/A6fKpa3UbZNm P742pVgohwAE
IACBOgkgb3XmpbeokLfeMs54eydQjbxJ3/UWm6h3vObxQQma3tVn3MyfVXnM VuofltgC5/on
KDHxUAcCEIAABOoigLzVlY9eo0Hees084+6VQBXyNiV86Z+TTNk3bUMAAhCA QLsEkLd2c7uk
kSFvS8oWsUIgn0Dz8paPiBYgAAEIQAACLySAvDEraiCAvNWQBWKAwHwEkLf5 WNMTBCAAAQg0
RAB5ayiZCx4K8rbg5BE6BEYQQN5GQOMUCEAAAhCAAPLGHKiBAPJWQxaIAQLz EWhe3lK+ZmA+
7PQEAQhAAAJLJzCHvOk3aR4vX/9uI1jAgjnAHGAOXB5W+j1vS38DJ34IQAAC EOiPwBzy1h9V
RpxKgJW3VGLUh8CyCbDyFsjf+j03DdK+7PQTPQQgAAEIjCWAvI0lx3klCSBv JWnSFgTqJ9C8
vOWkQInbxuYV767K2SAAAQhAoE8CyFufea9t1MhbbRkhHghMS6A5eZO+7Dvl M3CP3L0zKG+q
vKZNfQE42zwEYD0PZ3qBQM0EkLeas9NPbMhbP7lmpBBQBJqUt1BqU+Ttwbt2 Ds9sPLW1b2w+
v+vnVx9VubSpi3x7N8/RZfax0M92n1okUoUitb40Vqk8xMLFqGR8JdtS4zSZ h/IrMdHlpeOL
7Zd6EIDAeALI23h2nFmOAPJWjiUtQWAJBJqXN/uiOEXeHrjz5uHRh44M5z27 Kpc26aK8hLyN
FQApNmlsqf36+ks9HhtXigCntjlWmH39lMpF6jioDwEIjCeAvI1nx5nlCCBv 5VjSEgSWQAB5
C2TpvhMvDt42qcqlLXRRbpbZz02pM1d2VH+2OPhWgXxy5apv1nUJZcw4JQFJ lbTYcbvG6TrX
ZuqSO5eU2W25cuDi4zpPn2sz9o3VHltsfFK+KIcABPIJIG/5DGkhnwDyls+Q FiCwJALNypt9
K5u+6NUrb75HM3n33nFLUN5UubSFbqkLyZtLLGzB8l3Y5x73SZ80VlNMJJmx RS4kSNK4pfGa
suUbmy20vrG6xNmVY9f4fExy4ovtJyZ31IEABNIIIG9pvKg9DQHkbRqutAqB Wgk0K2++i/SU
2ybPHNsV/MybKpe2sStvkry5yn0X8inHQ7JpytmYVTbpHEnCJFFxrUpJsib1 aY/ZJW8xomqL
euxKmxSf748U0rykHAIQyCeAvOUzpIV8AshbPkNagMCSCCBvgWydOrJ7WDt3 elg7695VubT5
hMV10e2Tj7HSIrUntSuNLSQtvrKYNqW4JSFzMZfGmtpnSBS18MUwGNuvj0EM X+pAAAJlCCBv
ZTjSSh4B5C2PH2dDYGkEmpc3OyEpK28nD98avG1SlUtbSN7sc1Mv5O0L+JQV NpdgSIITGquW
UamOxMuMS4ondrwpY43tM1XepNym9isJbAxn6kAAAnkEkLc8fpxdhgDyVoYj rUBgKQSalDfp
u95ik3P80J6gvKlyafPd1iatDtkyZP4ckhb7djzzIt9V5uvHJ52u8cbWDbGQ 4nYJmD4WGpcZ
W2isIRmz4w4JpslHGlMox76x+eZNjDxLc5VyCEAgjQDylsaL2tMQQN6m4Uqr EKiVQHPyVhL0
7Qf3Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5S7lN0kZ99MC+ 4fB+/67K2SAA
AQhAoE8CyFufea9t1MhbbRkhHghMS6B5eZsWH61DAAIQgECvBJC3XjNf17iR t7ryQTQQmJoA
8jY1YdqHAAQgAIEmCcwhb/pNmsfLAwxgwBxgDjAHbswBdXfhDgVEPVm/cGlr b2HLuW2yhfEz
BghAAAIQmIbAHPI2TeS02hIBVt5ayiZjgYBMgJU3mRE1IAABCEAAAi8ggLwx KWoggLzVkAVi
gMB8BJqXt5yVt/V7bhqkfb5U0RMEIAABCNREAHmrKRv9xoK89Zt7Rt4ngebl LSetStw2Nq94
d1XOBgEIQAACfRJA3vrMe22jRt5qywjxQGBaAs3Jm/QF3SkrcY/cvTMob6qc bXkEpC8Vzy1f
HhEihgAExhBA3sZQ45zSBJC30kRpDwJ1E2hS3kLIU+Ttwbt2Br+kW5VLmxIB ezfP0WVSO2PK
JQnRbdr1Ys8bE1PMOT5mLlZj+Enj0+WhOGLGUaqOFG+pfmgHAhBII4C8pfGi 9jQEkLdpuNIq
BGol0Ly82Re+KfL2wJ03D48+dGQ479lVubRJF95j5EPq0ydlvvOkGGP7k+rF 9uOrtwp5c40p
dhwSj9jyufuLjYt6EOidAPLW+wyoY/zIWx15IAoIzEUAeQuQvu/Ei4O3Tapy aQtdeJtl9nNz
1ceUMddxVS7Vd7XhO+aLJSaOGB6SjITkTY/V9ejjYB+PGZ/Zvj2mmPNN0QxJ Z2reJb6UQwAC
8xFA3uZjTU9+AsgbswMCfRFoVt58t7zplTffo5n+e++4JShvqlza7DjM+iF5 c9Wzpca8vS+m
vk9CctuVZMzFKLTi6GNmj9f3symZLgmL5RYbR6g/V45zeUtzjnIIQGAeAsjb PJzpJUwAeWOG
QKAvAs3Km31BrX9OuW3yzLFdwc+8qXJpG7vyFiNjsRJit2Wv0uXKhGuMvhVC n0D6pDZFdseM
wyVoPq4uSQudb4uj2a50nnnuGDmW5iXlEIBAPgHkLZ8hLeQTQN7yGdICBJZE AHkLZOvUkd3D
2rnTw9pZ967Kpc134e1aGUyVsbH1XRJSQhYlFi6JdJ0TYuaS8rEcpH5yy0Py FjNuSSJTeFMX
AhAoTwB5K8+UFtMJIG/pzDgDAksm0Ly82clJWXk7efjW4G2TqlzaJAEoIU2p K06rlLfQ7ZIu
MXPxsZmXkjfpNswx3LhtUnqFUA6B5RJA3pabu5YiR95ayiZjgYBMoEl5k77r TcZyrcbxQ3uC
8qbKpc21wqbO8d1q6CqT5ESf4xIj+5jrdj3zfLt/1+2PPlmMYSHVscdixh8j wq54XW2aIuZi
FBuHxMclb758hbjGSG8MW+pAAALlCCBv5VjS0ngCyNt4dpwJgSUSaE7eSibh 9oN7g595U+Vs
EIAABCDQJwHkrc+81zZq5K22jBAPBKYl0Ly8pdwmaaM+emDfcHi/f1flbBCA AAQg0CcB5K3P
vNc2auSttowQDwSmJdC8vE2Lj9YhAAEIQKBXAnPIm36T5vHyAAMYMAeYA8yB G3NALVDtUEDU
k/ULl7Z2NghAAAIQgAAE3ATmkDfYQ0AiwMqbRIhyCLRFoPmVt5zbJttKNaOB AAQgAIGSBJC3
kjRpaywB5G0sOc6DwDIJNC9vy0wLUUMAAhCAQO0EkLfaM9RHfMhbH3lmlBDQ BJqXt5yVt/V7
bhqknakEAQhAAAJ9EkDe+sx7baNG3mrLCPFAYFoCzctbDj4lbhubV7y7KmeD AAQgAIE+CSBv
fea9tlEjb7VlhHggMC2B5uRN+oLulJW4R+7eGZQ3VT7F5vsy6in6mqrNKcbA F1VPlS3ahQAE
xhBA3sZQ45zSBJC30kRpDwJ1E2hS3kLIU+Ttwbt2Br+kW5VLmxYO89E8xy5X ZVOIjxRnqHyV
Y9AsbCa1Mcrhy7kQgMAyCSBvy8xba1Ejb61llPFAIEygeXmzL/JT5O2BO28e Hn3oyHDes6ty
aQtJhq9sLjGJ7aeGMcTGKuWDcghAAAKlCCBvpUjSTg4B5C2HHudCYHkEkLdA zu478eLgbZOq
XNrGCJp5TsyKnY7BVzdmVU2q4yqPlbqcMZgrb+ZtkxIj34qdlC/KIQABCMQS QN5iSVFvSgLI
25R0aRsC9RFoVt58t/rplTffo5mie++4JShvqlzaXLdFqnNixcdsPyQkuStT oc+TrXIM0m2T
vtspQ+ORckY5BCAAgRgCyFsMJepMTQB5m5ow7UOgLgLNypvGnHPb5Jlju4Kf eVPl0lZy5c1e
hbLFThLCGKFxtbHKMcTIm0suc2VWyivlEIAABJA35kANBJC3GrJADBCYjwDy FmB96sjuYe3c
6WHtrHtX5dKWIz6+VSVTTF11xoiLtPLmGqcki+qc3DHEyFtqbFLOKIcABCAQ QwB5i6FEnakJ
IG9TE6Z9CNRFoHl5s3Gn/MOSk4dvDd42qcqlLUZw7DYkYTHrp6yU+SRHkr1V jkFiEbptUsoN
5RCAAARyCCBvOfQ4txQB5K0USdqBwDIINClv0ne9xabm+KE9QXlT5dJm39Ln WykzV77MOr5b
Au2VMrOeFJMul6TNrOeKw1eujpcagyRvui8Xj1gO1IMABCAwhgDyNoYa55Qm gLyVJkp7EKib
QHPyVhL37Qf3Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5S7lN 0kZ99MC+4fB+
/67K2SAAAQhAoE8Cc8ibfpPm8fIAAxgwB5gDzIEbc0A5zg4FRD1Zv3Bpa2eD AAQgAAEIQMBN
YA55gz0EJAKsvEmEKIdAWwSaX3lrK12MBgIQgAAEaiGAvNWSib7jQN76zj+j 749A8/KWc9tk
f9OBEUMAAhCAQCwB5C2WFPWmJIC8TUmXtiFQH4Hm5a0+5EQEAQhAAAItEEDe Wsji8seAvC0/
h4wAAikEmpe3nJW39XtuGqQ9BTZ1IQABCECgHQLIWzu5XPJIkLclZ4/YIZBO oHl5S0dy4wwl
bhubV7y7KmeDAAQgAIE+CSBvfea9tlEjb7VlhHggMC2B5uRN+oLulJW4R+7e GZQ3VT7FFvvl
2Sl9219inXJuy3Ul1lJ5y2wYGwQgECaAvDFDaiCAvNWQBWKAwHwEmpS3EL4U eXvwrp3BL+lW
5dKmpcl8NM+xy1VZKWHQ7djtlWpfGrtd7mPhEsu5YjQZTZmLWFZzjTs2HupB AAJ+Asgbs6MG
AshbDVkgBgjMR6B5ebMvhlPk7YE7bx4efejIcN6zq3JpC12M+8pKX8CXbs8l ZRKHkJTWIm+u
MUzNbizLGN7UgQAEpiWAvE3Ll9bjCCBvcZyoBYFWCCBvgUzed+LFwdsmVbm0 jRE085yYFTsd
g13XtapkS5Srfd+KXWisMbdlSizscfvGpcdg9ukTQOm4NFYpFy7mrpVOOw7X Kp9rXNL8ohwC
EFgdAeRtdezp+QYB5I3ZAIG+CDQrb75b9PTKm+/RTP+9d9wSlDdVLm2hi3Tf uSmSYwqO3Z5P
TGKOj11xCkmcxMInb+a4XLG7znMJlC2u5s8psdnnuXIQw1galzS3KIcABFZL AHlbLX96v0YA
eWMmQKAvAs3Km09qUm6bPHNsV/Azb6pc2iQRc53vW+2xV9Lsi/9cYZFWobS0 jF1li2HhkzPX
CpckTS4hi2Vkt+37Y4BPOO1cheL3yaA0tyiHAARWSwB5Wy1/ekfemAMQ6JEA 8hbI+qkju4e1
c6eHtbPuXZVLW4yw2G1IqzamWLhkxD5/rLBIY/OJZ+qYQytnMbHHrLz5ZF4S 1thyU8BiZCxm
XGP4cw4EIDAfAeRtPtb05CfAyhuzAwJ9EWhe3ux0pqy8nTx8a/C2SVUubT6R sS/2zXZi5c3X
xlh5k0QlNNaxq3GuMZhtxUhOjLxJTCXhXHUc0jyjHAIQmJ8A8jY/c3p8IQHk jVkBgb4INClv
0ne9xab4+KE9QXlT5dLmu91Onyfd2ucrt2XJvi3PlCKfeOg6rrakcblkUzrH xyK0emjH6JIw
l7z5xhZqLyUXZv5inkuM7TGEpF/iTDkEIDAPAeRtHs70EiaAvDFDINAXgebk rWT6bj+4N/iZ
N1XOBgEIQAACfRKYQ970mzSPl7f+MQc7DJgDzAHmwLU5oBardugn6xcuDWpv YUu5TdIe79ED
+4bD+/27KmeDAAQgAIE+Ccwhb32SZdQpBFh5S6FFXQgsnwArb8vPISOAAAQg AIEVEEDeVgCd
Ll9AAHljUkCgLwLIW1/5ZrQQgAAEIFCIAPJWCCTNZBFA3rLwcTIEFkegeXnL uW1ycdkkYAhA
AAIQmI0A8jYbajoKEEDemB4Q6ItA8/LWVzoZLQQgAAEIzEUAeZuLNP2ECCBv zA8I9EWgeXnL
WXlbv+emQdr7mi6MFgIQgAAENAHkjblQAwHkrYYsEAME5iPQvLzloFTitrF5 xburcjYIQAAC
EOiTAPLWZ95rGzXyVltGiAcC0xJoTt6kL+hOWYl75O6dQXlT5WzzEpjiy6vt L9Ced0T0BgEI
LJUA8rbUzLUVN/LWVj4ZDQQkAk3KW2jQKfL24F07g1/SrcqlTYuB+ajOsY9L 7ehzYuuNaT+m
7ZJ1fGx0H64xlJI33Y7dXqn2S3KiLQhAoE4CyFudeektKuStt4wz3t4JNC9v 9sV4irw9cOfN
w6MPHRnOe3ZVLm0+GRgjDalikVpfGktseWy/oXqx3GJj8tWLjTW3H86HAATa I4C8tZfTJY4I
eVti1ogZAuMJIG8BdvedeHHwtklVLm0pEmLWtVfqVD+xx3RMkiCaq0+utn19 SmM2zwvVTWHj
GlNKzK6VT9f4YnKgz4vhQB0IQKBdAshbu7ld0siQtyVli1ghkE+gWXnz3ZKn V958jybSe++4
JShvqlzafLcvusRFkhlplShW1mwR8p0ntSeNXZK4FDY+IZXG4hMt6bbJEBMp DzFcqAMBCCyf
APK2/By2MALkrYUsMgYIxBNoVt58F/spt02eObYr+Jk3VS5tkpCZ5/tWfXyi YcqRFiFfeyHJ
kUTFt8Jl9x9iMUZWXe3FMHKNJ1VQffKPuEkznnII9EMAeesn1zWPFHmrOTvE BoHyBJC3ANNT
R3YPa+dOD2tn3bsql7Yx8pYqGj5RDQmTLUEu6SshKi6p9MUrHdeyaD6Gxh6S uNSVt5jYpLlA
OQQg0BYB5K2tfC51NMjbUjNH3BAYR6B5ebOxpKy8nTx8a/C2SVUubbHyNkam pNsax/SdIkih
sYekLUaEpNilsbsEzzW2VFEuIbTSnKEcAhBYBgHkbRl5aj1K5K31DDM+CGwn 0KS8Sd/1FjsJ
jh/aE5Q3VS5todvvYm9HdN0qaAqQrx1JgGLbiBExk0Os4PjYhOKKvW3SV88W x5AEurjGjk2a
F5RDAALLJzCHvOk3aR4vDzCAAXOAOcAcuDEHlO/sUEDUk/ULl7b23rfbD+4N fuZNlS9tC91K
ubSxEC8EIACBVRKYQ95WOT76XgYBVt6WkSeihEApAs2tvNlgUm6TtM89emDf cHi/f1flS9uQ
t6VljHghAIFaCSBvtWamr7iQt77yzWgh0Ly8kWIIQAACEIDAFASQtymo0mYq AeQtlRj1IbBs
AsjbsvNH9BCAAAQgsCICyNuKwNPtNgLIGxMCAn0RaF7ecm6b7GsqMFoIQAAC EEghgLyl0KLu
VASQt6nI0i4E6iTQvLzViZ2oIAABCEBg6QSQt6VnsI34kbc28sgoIBBLoHl5 y1l5W7/npkHa
Y0FTDwIQgAAE2iKAvLWVz6WOBnlbauaIGwLjCDQvb+OwXDtLidvG5hXvrsrZ IAABCECgTwLI
W595r23UyFttGSEeCExLoDl5k76gO2Ul7pG7dwblTZWzQQACEIBAnwSQtz7z XtuokbfaMkI8
EJiWQJPyFkKWIm8P3rUz+CXdqlza1Peq2bs6x3dcam9V5bHjiInP9V1zrvOW xihm7NSBAATa
IYC8tZPLJY8EeVty9ogdAukEmpc3WxRS5O2BO28eHn3oyHDes6tyafOJSqzA SO3nlsfGETuO
mPZi6pjjSq2fy4TzIQABCMQQQN5iKFFnagLI29SEaR8CdRFA3gL5uO/Ei4O3 TapyaYuVHt2O
a5VOldnt6J/N+rpequzoNkJjSRmHWdeOz4xRqmcyCcmci4WLV8w4pXxSDgEI QEATQN6YCzUQ
QN5qyAIxQGA+As3Km++WO73y5ns00d97xy1BeVPl0haSMZ/YuEQlJG8uyUkV OEn8YqXSJZp2
fFJsvrFKMhfDKBSflEvKIQABCJgEkDfmQw0EkLcaskAMEJiPQLPy5rvQT7lt 8syxXcHPvKly
aUtZsXKJhbmqJEmdvZJlx+aSRVf8rphTxuFbUfONxRRH1+pYKJ7QmH0rcpI8 SjmlHAIQgIAi
gLwxD2oggLzVkAVigMB8BJC3AOtTR3YPa+dOD2tn3bsql7YU6Zla3mJizY3X HMPYlTBp5c3X
R2x/EgfKIQABCMQQQN5iKFFnagLI29SEaR8CdRFoXt5s3CkrbycP3xq8bVKV S1uuDJVcefPF
GvNZsNhxxK6EmbFIsjam7xiJlHJHOQQgAIEQgTnkTb9J83h5a6WTHQbMAeYA c+DaHFBOs0M/
Wb9waVD7EreS3/N2/NCeoLypcmmzPysm3coXEhnX5858shR7a2BKPV//odsx XedosZJur9Rs
U+TNF0soRimHlEMAAhBwEZhD3iAPAYkAK28SIcoh0BaB5lbeSqbn9oN7g595 U+VsqyEQ+hzc
aiKiVwhAoDcCyFtvGa9zvMhbnXkhKghMRaB5eUu5TdKGfPTAvuHwfv+uytlW QwB5Ww13eoUA
BG4QQN6YDTUQQN5qyAIxQGA+As3L23wo6QkCEIAABHoigLz1lO16x4q81Zsb IoPAFASQtymo
0iYEIAABCDRPAHlrPsWLGCDytog0ESQEihFoXt5ybpssRpmGIAABCECgOQLI W3MpXeSAkLdF
po2gITCaQPPyNpoMJ0IAAhCAAAQCBJA3pkcNBJC3GrJADBCYj0Dz8paz8rZ+ z02DtM+XKnqC
AAQgAIGaCCBvNWWj31iQt35zz8j7JNC8vOWkVYnbxuYV767K2SAAAQhAoE8C yFufea9t1Mhb
bRkhHghMS6A5eSv5Jd2P3L0zKG+qnO0Ggdgv/F4yM2mMUvmSx07sEIDAdgLI GzOiBgLIWw1Z
IAYIzEegSXkL4Uu5jfLBu3YGv6RblUubupi3d3WO77jUXmp56PvQSovGFO2F 2JksSvft46z7
CeU1NUc59ecad06MnAuBVgkgb61mdlnjQt6WlS+ihUAugeblzb64TZG3B+68 eXj0oSPDec+u
yqXNd3E910V3qJ/SMcS2l1tPi9Oq5c2V+9ixSfMmtnzu/mLjoh4EeiCAvPWQ 5frHiLzVnyMi
hEBJAshbgOZ9J14cvG1SlUtbqry5VppUH3Y7rhUgXc+sK6282SJk9q/HZvZl HnOdK/Gwzw/V
l9j5xukbgxmvTwCl4y4WPoksGUdoXrhijs0D9SAAgfEEkLfx7DizHAHkrRxL WoLAEgg0K2++
29r0ypvv0UzavXfcEpQ3VS5tMRfdIdnyyYJPqELCJZVJgugbqyQ0kqCFJC1F Jl39jOUUwz02
NlO+Q8IpSbpLEn3spHlJOQQgkE8AectnSAv5BJC3fIa0AIElEWhW3mxR0T+n 3DZ55tiu4Gfe
VLm0SatH9vkhgZIu3l1iIK282W26ZNPXhi0vUj1J4iQWrpz65CwUm49TzNgl UTXLpfamjEOa
l5RDAAL5BJC3fIa0kE8AectnSAsQWBIB5C2QrVNHdg9r504Pa2fduyqXtqXJ m2s8PqG0ZWrM
KpAWnJh+Y+QtRn5jJVf1F9OeJNWucrvtWCkswVyas5RDAAJxBOaQN/0mzePl AQYwYA4wB5gD
N+aAWpDaoYCoJ+sXLm3tS9yklTWp3BzzycO3Bm+bVOXStmR5k24dzBGJkLS5 JM0nQFqCpFjn
ul2xljikeUk5BCCQT2AOecuPkhZaJ8DKW+sZZnwQ2E6gyZU36bveYifB8UN7 gvKmyqXNvnUu
5bY61+pM7u2AvjZNYbLFSrodUlo1shnFrtCF2NkyZ8tZKidTAl2rba72Ym6L DLEMCaWUA9d4
pblIOQQgUJYA8laWJ62NI4C8jePGWRBYKoHm5K1kIm4/uDf4mTdVzgYBCEAA An0SQN76zHtt
o0beassI8UBgWgLNy1vKbZI26qMH9g2H9/t3Vc4GAQhAAAJ9EkDe+sx7baNG 3mrLCPFAYFoC
zcvbtPhoHQIQgAAEeiWAvPWa+brGjbzVlQ+igcDUBJC3qQnTPgQgAAEINEkA eWsyrYsbFPK2
uJQRMASyCDQvbzm3TWaR5WQIQAACEGiaAPLWdHoXMzjkbTGpIlAIFCHQvLwV oUQjEIAABCAA
AYsA8saUqIEA8lZDFogBAvMRaF7eclbe1u+5aZD2+VJFTxCAAAQgUBMB5K2m bPQbC/LWb+4Z
eZ8Empe3nLQqcdvYvOLdVTkbBCAAAQj0SQB56zPvtY0aeastI8QDgWkJNCdv 0hd0p6zEPXL3
zqC8qXK2+QlIX/KdWz7/iOgRAhBYIgHkbYlZay9m5K29nDIiCIQINClvoQGn yNuDd+0Mfkm3
Kpc2JRL2rs7xHZfaM8slSUlpq2Rdacz2GFLHIdXX5aE4So5XakuKVzqfcghA oE4CyFudeekt
KuStt4wz3t4JNC9v9oVzirw9cOfNw6MPHRnOe3ZVLm2+C/cSF/Ql2pDiHyOL oTHbZVqwSsZh
ypur3Vq5pTCgLgQgsHoCyNvqc0AEw4C8MQsg0BcB5C2Q7/tOvDh426Qql7Yx 8mauGLlWqVwr
S7qe61xbZlwCJY3Dbj9UXxpzKJ6YsZvtx4zXjjXmfFMqXYLp61c6HsuZehCA QP0EkLf6c9RD
hMhbD1lmjBC4QaBZefPdMqdX3nyP5uS4945bgvKmyqXNjsMlWaHVp9AqkiRh tuSZfdtSKI3D
JUDSCps9Lp+0+caYezzEXo3Hx8+WO5tbzHlm+3Ov9KXmkvoQgMA4AsjbOG6c VZYA8laWJ61B
oHYCzcqbT1RSbps8c2xX8DNvqlzapFUo1/ku6XC1kyJvLvlyCYxLLkNjjInL lQuXII2RohAr
ib1P8GPkLSZHIfGW5g3lEIBA/QTmkDf9Js3j5a3bA9lhwBxgDjAHrs0B5TQ7 9JP1C5cGtS9x
s+XMvoBPkbdTR3YPa+dOD2tn3bsqlzZJIHxSZQtPjCTFyo8pbWNXhWJWC0Nj KyVvPvmVxDSm
3K4jyVgKf2neUA4BCNRPYA55q58CEa6aACtvq84A/UNgXgLNr7zZOFPk7eTh W4O3TapyaatV
3kLyEhpTSNps4ZTEVBLUErdNpsidq78pJVOaO5RDAAJ1E0De6s5PL9Ehb71k mnFC4BqBJuVN
+q632OQfP7QnKG+qXNpibs1zSY55nik5tjz5fvbd+mf2lbrqFls/dcx2rC5B dN2mqAXUxcAu
M+tI/Um3TUr9uiQ2RnqluUQ5BCBQFwHkra589BoN8tZr5hl3rwSak7eSibz9 4N7gZ95U+VK3
WBFb6viIGwIQgMDUBJC3qQnTfgwB5C2GEnUg0A6B5uUt5TZJO61HD+wbDu/3 76p8qRvyttTM
ETcEIFALAeStlkz0HQfy1nf+GX1/BJqXt/5SyoghAAEIQGAOAsjbHJTpQyKA vEmEKIdAWwSQ
t7byyWggAAEIQGAmAsjbTKDpJkgAeWOCQKAvAs3LW85tk31NBUYLAQhAAAIp BJC3FFrUnYoA
8jYVWdqFQJ0Empe3OrETFQQgAAEILJ0A8rb0DLYRP/LWRh4ZBQRiCTQvbzkr b+v33DRIeyxo
6kEAAhCAQFsEkLe28rnU0SBvS80ccUNgHIHm5W0clmtnKXHb2Lzi3VU5GwQg AAEI9EkAeesz
77WNGnmrLSPEA4FpCTQnb9IXdKesxD1y986gvKnyVW/Sv/zPLV/1+KbuX+Iz df+0DwEILJcA
8rbc3LUUOfLWUjYZCwRkAk3KW2jYKfL24F07g1/SrcqlTcmBvatz9DHzfNex mPZDdbSchOKQ
+ihZPpUs+canYzfLbea+8Y2Jdcw5JfnSFgQgMB8B5G0+1vTkJ4C8MTsg0BeB 5uXNvphOkbcH
7rx5ePShI8N5z67Kpc13Mb8KeXPFOrdspPYXWz9Uzy4zf45tX8qzKYmxdakH AQgsmwDytuz8
tRI98tZKJhkHBOIIIG8BTvedeHHwtklVLm0heVPnmitj5s/6eUjy7DLX6pLd vh2vLTJSm1I8
psT44kldYYypL3H2jdtesbPjd43HbMseo2+FT5onlEMAAssjgLwtL2ctRoy8 tZhVxgQBP4Fm
5c13G51eefM9mqjuveOWoLypcmkLyUFI3nyrRWOPx8ZhyopLJkPlrvFI9SV+ LlFynSONLyRv
dh9SzCEhLr2Sl8KHuhCAwLwE5pA3/SbN4+UBBjBgDjAHmAM35oBymR0KiHqy fuHS1r7Ezb4t
0r6YTrlt8syxXcHPvKlyaYtZEXLdxjdG0lwCE7vy5pNdV2y2pIX6lUTIJWeS ALnKYzi7JM3H
ecwYbdmV5gblEIDAsgnMIW/LJkT0cxBg5W0OyvQBgXoINLvyZkuD/jlF3k4d 2T2snTs9rJ11
76pc2mKkopS8uWJJkbfQ+baYxLabIm8xLGN4uiTNbtsXf0wufHMLeZMySDkE 2iKAvLWVz6WO
BnlbauaIGwLjCDQvbzaWFHk7efjW4G2TqlzaxsrGmJU3l7TESlZMfzFiI0mR tKrmE0jpvFB5
zOqaS8jGjEWKU5ovlEMAAsshgLwtJ1ctR4q8tZxdxgaBFxJoUt6k73qLnQjH D+0Jypsql7aY
2xFd0qVXcfT5dh2zXVM87PqmgEi3N/raDImNL05JmGIlJ6Wea3whNnbsMTG7 6riYx8YtzR/K
IQCBegkgb/XmpqfIkLeess1YITBc//xvM595K5nU2w/uDX7mTZWztUsAAWs3 t4wMAiUIIG8l
KNJGLgHkLZcg50NgWQSaW3mz8afcJmmfe/TAvuHwfv+uytnaJIC4tZlXRgWB kgSQt5I0aWss
AeRtLDnOg8AyCTQvb8tMC1FDAAIQgEDtBJC32jPUR3zIWx95ZpQQ0ASQN+YC BCAAAQhAYAQB
5G0ENE4pTgB5K46UBiFQNYHm5S3ntsmqM0dwEIAABCCwUgLI20rx0/nzBJA3 pgIE+iLQvLz1
lU5GCwEIQAACcxFA3uYiTT8hAsgb8wMCfRFoXt5yVt7W77lpkPa+pgujhQAE IAABTQB5Yy7U
QAB5qyELxACB+Qg0L285KJW4bWxe8e6qnA0CEIAABPokgLz1mffaRo281ZYR 4oHAtASakzfp
C7pTVuIeuXtnUN5U+RI36d/gS+VLHPMUMUuccsuniJk2IQCBcgSQt3IsaWk8 AeRtPDvOhMAS
CTQpb6FEpMjbg3ftDH5JtyqXNnUBb+/qHH3MPF+62Jf6ii3X/YRii22rRL2p xp3KPjUOqX4v
nEvMAdqAwBIJIG9LzFp7MSNv7eWUEUEgRKB5ebMvsFPk7YE7bx4efejIcN6z q3Jp813g1yJv
rvglKZHGnFqe2l9s/VT2se3q8Un1TXlbIufUPFIfAr0RQN56y3id40Xe6swL UUFgKgLIW4Ds
fSdeHLxtUpVLW0gg1Llmuf3cFjxzJUmfa7dv1zFFw3W+JBWu9sbG4VqBNMch yZAZq0t+7bHE
sndJVgpH3xhS5K1WztL8phwCPROYQ970mzSPlwcYwIA5wBxgDtyYA2pBaocC op6sX7i0tS9x
0ytrvlvmdLnv0RzzvXfcEpQ3VS5tIWEJyZstKpLo2eXmzy7Bs4XDJZGh80wp tJ/HnBeKT2Ia
K3Gx7G3Jyo3f1Z5PzmLzNjY/pTin5IS6EOiFwBzy1gtLxjmeACtv49lxJgSW SICVt0DWzhzb
FfzMmyqXNmn1x3dx7RKP0CqdS8Z8Kz+xK0I+AZ4rDntMIdYuzinsY2XXJ9Wh fElx1MBZmseU
QwACLySAvDEraiCAvNWQBWKAwHwEkLcA61NHdg9r504Pa2fduyqXNunC3SUN MSs/MSsxOraY
9nxS4hpfjLxJ54VkSWJqxxrD2DU+M4ZceQuNV4pPKo+Nc2y+U3hTFwIQuEEA eWM21EAAeash
C8QAgfkINC9vNsqUf1hy8vCtwdsmVbm0xVyY64vzlJWyGHlLaS9G3lztTRlH iK1erZLqxEik
LT2xshvLV5oDMf2tirM0vymHQM8EkLees1/P2JG3enJBJBCYg0CT8iZ911ss 2OOH9gTlTZVL
W8wtcba8mT+bkiKteNnn2UJmxuLqwydntiiNjcMnKa7xj5Ey+5xY9ra8pXL0 1Td52rHoc8y+
a+MszW3KIdA7AeSt9xlQx/iRtzryQBQQmItAc/JWEtztB/cGP/OmytkgAAEI QKBPAshbn3mv
bdTIW20ZIR4ITEugeXlLuU3SRn30wL7h8H7/rsrZIAABCECgTwLIW595r23U yFttGSEeCExL
oHl5mxYfrUMAAhCAQK8EkLdeM1/XuJG3uvJBNBCYmgDyNjVh2ocABCAAgSYJ IG9NpnVxg0Le
FpcyAoZAFoHm5S3ntsksspwMAQhAAAJNE0Demk7vYgaHvC0mVQQKgSIEmpe3 IpRoBAIQgAAE
IGARQN6YEjUQQN5qyAIxQGA+As3LW87K2/o9Nw3SPl+q6AkCEIAABGoigLzV lI1+Y0He+s09
I++TQPPylpNWJW4bm1e8uypngwAEIACBPgkgb33mvbZRI2+1ZYR4IDAtgebk TfqC7pSVuEfu
3hmUN1U+1WZ/ofVU/dAuBCAAAQiMI4C8jePGWWUJIG9ledIaBGon0KS8haCn yNuDd+0Mfkm3
Kpc2JWH2bp5jltnHfW2PEbsx50hjoxwCEIBAzwSQt56zX8/Ykbd6ckEkEJiD QPPyZktLirw9
cOfNw6MPHRnOe3ZVLm0habLLzJ9Ly1bp9qRxUw4BCECgdQJzyJt+k+bx8gAD GDAHmAPMgRtz
QDnNDgVEPVm/cGlrX+Jmy1mOvN134sXB2yZVubT5pEk67lut08d1v6GVO7Ou r54UP+UQgAAE
IOAmMIe8wR4CEgFW3iRClEOgLQLNrrz5blfUcud7NNN77x23BOVNlUtbSMJc 52qpi1mV89Vx
iSErb1KmKIcABCCQRgB5S+NF7WkIIG/TcKVVCNRKoFl5M1emTPgpt02eObYr +Jk3VS5t0gqb
fX6qvLnkEHmTskI5BCAAgXwCyFs+Q1rIJ4C85TOkBQgsiQDyFsjWqSO7h7Vz p4e1s+5dlUvb
1PLm6h95k7JCOQQgAIF8AshbPkNayCeAvOUzpAUILIlA8/JmJyNl5e3k4VuD t02qcmkr9Q9L
XP/MhNsmJfqUQwACEJiOAPI2HVtajieAvMWzoiYEWiDQpLxJ3/UWm7jjh/YE 5U2VS5vvs3f6
vJh/OCJ9/s3+JyaqbVe7rnpS/JRDAAIQgICbAPLGzKiBAPJWQxaIAQLzEWhO 3kqiu/3g3uBn
3lT5Kjb++cgqqNMnBCAAge0EkDdmRA0EkLcaskAMEJiPQPPylnKbpI396IF9 w+H9/l2Vz70h
bnMTpz8IQAACrLwxB+olgLzVmxsig8AUBJqXtymg0SYEIAABCECAlTfmQA0E kLcaskAMEJiP
API2H2t6ggAEIACBhgggbw0lc8FDQd4WnDxCh8AIAs3LW85tkyN4cgoEIAAB CHRCAHnrJNGV
DxN5qzxBhAeBwgSal7fCvGgOAhCAAAQgsEUAeWMi1EAAeashC8QAgfkINC9v OStv6/fcNEj7
fKmiJwhAAAIQqIkA8lZTNvqNBXnrN/eMvE8CzctbTlqVuG1sXvHuqpwNAhCA AAT6JIC89Zn3
2kaNvNWWEeKBwLQEmpM36Qu6U1biHrl7Z1DeVDlbGwSkr2CQytugwCggAIEU AshbCi3qTkUA
eZuKLO1CoE4CTcpbCHWKvD14187gl3SrcmlTF/32bp5jlkltlSi3JWTVUuLj I3ErwcLOg/o5
FE/pPkPtrTovc46VviCwVAJzyJt+k+bx8tZnDNlhwBxgDjAHrs0B5TQ79JP1 C5cGtS9xs+XM
vghOkbcH7rx5ePShI8N5z67KpS10Eb4KkZpLCmL7kepJ5RL/2HLdj6+/ueLQ 8c7dXywn6kEA
AjcIzCFv8IaARICVN4kQ5RBoi0DzK2858nbfiRcHb5tU5dKWKgOmRPhW5VzH XfLhq6eP65Um
UxjMMtdKlDRes9xuy3WuJCmS4I7l5RtbTL5iubpij+Xry30Kf+pCAALTEkDe puVL63EEkLc4
TtSCQCsEmpU33+1veuXN92gm9t47bgnKmyqXNjsOU5RCMuOTltDxmFW+Me3a QiaN2S4PSZyP
j49Tqfglji7JsmXX/Nlsz/U8N+5U5tSHAASmJ4C8Tc+YHmQCyJvMiBoQaIlA s/Lmu/hPuW3y
zLFdwc+8qXJpi1nJcclRrFy4VtzMsdsrOLkS4RpP7CqR79wQw9A5PmGypcol iLEc7Hnk+6NA
jLyViEOab5RDAALzEUDe5mNNT34CyBuzAwJ9EUDeAvk+dWT3sHbu9LB21r2r cmmbQt5cffpk
xCUfqbLoqi+N2z4nlYNPvm0x89ULSa3ZhsQntdxuu3QcKdypCwEITEsAeZuW L63HEUDe4jhR
CwKtEGhe3uxEpay8nTx8a/C2SVUubTG3MroEJHZlyCcHpc6XpDA0fvvWwxjp tOvESt9U45Xk
zcWf2yalVwXlEGiDAPLWRh6XPgrkbekZJH4IpBFoUt6k73qLRXT80J6gvKly afPdZmdKgUty
XLfYhc6Rbme0hcInHXYsY+UtJK0msxg+MdKXyku16buNUbq90SyXxNvF3XeL pY7JzrM0xyiH
AARWQwB5Ww13et1OAHljRkCgLwLNyVvJ9N1+cG/wM2+qfKotVn6m6r/mdn2i WnPMxAYBCLRH
AHlrL6dLHBHytsSsETMExhNoXt5SbpO0MR49sG84vN+/q/KpNuTNTxZ5m2rW 0S4EIJBCAHlL
oUXdqQggb1ORpV0I1EmgeXmrEztRQQACEIDA0gkgb0vPYBvxI29t5JFRQCCW APIWS4p6EIAA
BCAAAYMA8sZ0qIEA8lZDFogBAvMRaF7ecm6bnC8N9AQBCEAAAksjgLwtLWNt xou8tZlXRgUB
H4Hm5Y3UQwACEIAABKYggLxNQZU2Uwkgb6nEqA+BZRNoXt5yVt7W77lpkPZl p5/oIQABCEBg
LAHkbSw5zitJAHkrSZO2IFA/geblLScFStw2Nq94d1XOBgEIQAACfRJA3vrM e22jRt5qywjx
QGBaAs3Jm/QF3SkrcY/cvTMob6p8lRtfJzCOvsRNKh/XK2dBAAKtEZhD3vSb NI+XBxjAgDnA
HGAO3JgDyml2KCDqyfqFS1v7EjdJzqRyc8wP3rUz+CXdqlzalAjYuzrHdUxq yy5fgmRI4zfH
NNd4dD+h2FJzkVN/rnHnxMi5EIDACwnMIW9wh4BEgJU3iRDlEGiLQJMrbyEh SJG3B+68eXj0
oSPDec+uyqXNd2FuHx9zAT/mHCne2PLYvkPjL8EgNl7XnIjNzZg+Us6JZZnS JnUhAIHpCSBv
0zOmB5kA8iYzogYEWiKAvAWyed+JFwdvm1Tl0hYrCGY9c0XIlg5dpo7b5+i6 MefH9BczNkk8
pPGnjMEel8lizNil2DRju5+xcfhWW335kvhTDgEIrJYA8rZa/vR+jQDyxkyA QF8EmpU33y1x
euXN92im/947bgnKmyqXttAFuy1mrrbMW/zs8lCZKTO26Jk/l1j9ckmUS6Zc ouaTNxebkOiN
GaOUGx+bKeKQ5hHlEIBAfQSQt/py0mNEyFuPWWfMPRNoVt5sedE/p9w2eebY ruBn3lS5tIVW
d1JWyFzt+KTJJSUhEfFJjEvAQuP1xRiSUp9ISmPwiaB0XkhcXcIrtTdlHNLc ohwCEFgtAeRt
tfzp/RoB5I2ZAIG+CCBvgXyfOrJ7WDt3elg7695VubTF3JpnthGz2uOSDJ+s +lbnYlbtpLHZ
cidJmm+cdiwxDKRVvLFMU+TOrJt6Xkz9WP7UgwAEVkMAeVsNd3rdTgB5Y0ZA oC8Czcubnc6U
lbeTh28N3japyqVtDnkLiUCqvPni9YmZVD92/OYqYil5Sx17SIp9jGMkcmwc 0tyiHAIQWC0B
5G21/On9GgHkjZkAgb4INClv0ne9xab4+KE9QXlT5dJm33YXs+Llu43Rvs0y 9lZIU0rsNrSU
mPIkjckUGalu7Pjt/sfcrhgai6+9mH5csdmiZzPxcTZ52eInibDEmnIIQGBe AsjbvLzpzU0A
eWNmQKAvAs3JW8n03X5wb/Azb6p8qRuisNTMETcEIFALAeStlkz0HQfy1nf+ GX1/BJqXt5Tb
JO30Hz2wbzi837+r8iVtrtWgJcVPrBCAAARqIoC81ZSNfmNB3vrNPSPvk0Dz 8tZnWhk1BCAA
AQhMTQB5m5ow7ccQQN5iKFEHAu0QQN7aySUjgQAEIACBGQkgbzPCpisvAeSN yQGBvgg0L285
t032NRUYLQQgAAEIpBBA3lJoUXcqAsjbVGRpFwJ1Emhe3urETlQQgAAEILB0 Asjb0jPYRvzI
Wxt5ZBQQiCXQvLzlrLyt33PTIO2xoKkHAQhAAAJtEUDe2srnUkeDvC01c8QN gXEEmpe3cViu
naXEbWPzindX5WwQgAAEINAngTnkTb9J83h568uo2WHAHGAOMAeuzQG1QLVD P1m/cGlQ+xI3
6Qu6U1biHrl7Z1DeVDlbWwSk77+TytuiwWggAIEQgTnkjQxAQCLAyptEiHII tEWguZU3Sc6k
cjO9D961M/gl3apc2szvVtPP1Tn2camdqctXLSWxnKaOU7cfimfqXJjtTz3e OcdCXxBojQDy
1lpGlzke5G2ZeSNqCIwl0Ly82Re/KfL2wJ03D48+dGQ479lVubT5Lr7t46u+ SJ+q/9h2pXpS
uZSH2HJT3lznzBWH7nvu/mI5UQ8CEBi2bltRW+otPOp96Lbbbtu6w0Xt6mez DfNnOENAIoC8
SYQoh0BbBJC3QD7vO/Hi4G2TqlzaxsibuepjX8Sb7fnquVb4zDhjzlP1Y+OI YSBJSGq5T35D
K5qu8djjTJG3GI5mLsxc2sd9cftilphTDgEITE8AeZueMT3IBJA3mRE1INAS gWblzXfbm155
8z2ayb33jluC8qbKpS10UW4LlastUyZCguOSDlv0tKi4+vXJkEseJdHyMXGJ jEtoXO2nxJcy
vlQJ9MndVPzHspbmJeUQgEA+AeQtnyEt5BNA3vIZ0gIElkSgWXmzpUP/nHLb 5Jlju4KfeVPl
0ua7+I5dIQqtBLnacAmbKW0+qXVJjNS+PfbYVaIYOXO17TvmG/PYcbsk1yex 9phL8g/FIc07
yiEAgekJIG/TM6YHmQDyJjOiBgRaIoC8BbJ56sjuYe3c6WHtrHtX5dIWkjfX uaGVILN+TL2Y
lTef5KbGLXHQIjK23ZDwxcpbDm+XvEntleDPylvMzKIOBFZDAHlbDXd63U4A eWNGQKAvAs3L
m53OlJW3k4dvDd42qcqlLVVWYqRMi5BL5mJWfqTzYtuXxm4KjyQhY8t9vCTZ Srn9MYVXaf4S
l9gcUA8CEChPAHkrz5QW0wkgb+nMOAMCSybQpLxJ3/UWm7Djh/YE5U2VS1vs bYq2IIRux7Ol
SNe1pSskEuY5Psly3QaZKhOx9X2cbAmzebvkzRW3ZhMat83RjsnF125Pkjdf HCEJdcUszTvK
IQCB6Qkgb9MzpgeZAPImM6IGBFoi0Jy8lUzO7Qf3Bj/zpsrZVkcgdCvl6qKi ZwhAoBcCyFsv
ma57nMhb3fkhOgiUJtC8vKXcJmnDPXpg33B4v39X5WyrI4C8rY49PUMAAnzP G3OgDgLIWx15
IAoIzEWgeXmbCyT9QAACEIBAXwRYeesr37WOFnmrNTPEBYFpCCBv03ClVQhA AAIQaJwA8tZ4
ghcyPORtIYkiTAgUItC8vOXcNlmIMc1AAAIQgECDBJC3BpO6wCEhbwtMGiFD IINA8/KWwYZT
IQABCEAAAl4CyBuTowYCyFsNWSAGCMxHoHl5y1l5W7/npkHa50sVPUEAAhCA QE0E5pA3/SbN
4+UBBjBgDjAHmAM35oBynB0KiHqyfuHS1t77psRtY/OKd1flbBCAAAQg0CeB OeStT7KMOoUA
K28ptKgLgeUTaG7lTfqC7pSVuEfu3hmUN1U+98YXNs9NPL2/2C8mT2+ZMyAA gZoIIG81ZaPf
WJC3fnPPyPsk0KS8hVKZIm8P3rUz+CXdqlzatGyZj+oc+7jUjj4npt4S6/g4 +ViVFKSSbZl5
Co0pJUel40vpm7oQgICfAPLG7KiBAPJWQxaIAQLzEWhe3uwL3xR5e+DOm4dH HzoynPfsqlza
fBfe9vGYC/SYOlI8c5fHxhzLSccf227MeEu2ZctbTP9SndLxSf1RDgEIxBFA 3uI4UWtaAsjb
tHxpHQK1EUDeAhm578SLg7dNqnJpi5USl8zZt0jaq3daFFz1TIkI1XO1GVNf GrdZHnOrZywn
U97MdvX59qNL9kKroDY3l4yZsfpy4mrHxWRM3n3i7xq7L78p+aMuBCDgJoC8 MTNqIIC81ZAF
YoDAfASalTffLWt65c33aKK/945bgvKmyqXNjsMlEy7Rsi/0Q1Jht+mTOVe9 mH5i+pY4mELo
quvjZJ5nS5NLhiS+LkmUVkFNKQqtgrkE0jUuqb/YPI3Ne0yuqAMBCMgEkDeZ ETWmJ4C8Tc+Y
HiBQE4Fm5c13EZ9y2+SZY7uCn3lT5dIWWlGKWfVyrS6ZY4uVg9h6LlGzBcq3 kha7yhMjUD6u
MStrIdmM6Vta2XJJoytPsbn3reSljjW0iufLmTR/KYcABPwEkDdmRw0EkLca skAMEJiPAPIW
YH3qyO5h7dzpYe2se1fl0ha6gPcJZsw5PskKiYsda6qkSGOVykMCEVrRsmUp Zow5Y4s9V6oX
m0dpHkgrdbGSJ+WHcghAII0A8pbGi9rTEEDepuFKqxColUDz8maDT1l5O3n4 1uBtk6pc2mIv
4O3Vlxxhyb3YH7M6FeIQs+rTs7xJ8pWbT58cSnOXcghAIEwAeWOG1EAAeash C8QAgfkINClv
0ne9xeI9fmhPUN5UubTZtyv6LtRVO77b50IX32b7ufVi+o8RMZd45nByjVHz knj6+Njj8P1s
HvdJrd1HKCYzRy6W9nyx67vOj2Ug5YByCEAgjQDylsaL2tMQQN6m4UqrEKiV QHPyVhL07Qf3
Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5S7lN0kZ99MC+4fB+ /67K2SAAAQhA
oE8CyFufea9t1MhbbRkhHghMS6B5eZsWH61DAAIQgECvBJC3XjNf17iRt7ry QTQQmJoA8jY1
YdqHAAQgAIEmCSBvTaZ1cYNC3haXMgKGQBaB5uUt57bJLLKcDAEIQAACTRNA 3ppO72IGh7wt
JlUECoEiBJqXtyKUaAQCEIAABCBgEZhD3vSbNI+XBxjAgDnAHGAO3JgDaoFq hwKinqxfuLS1
t7DlrLyt33PTIO0tMGIMEIAABCCQTmAOeUuPijN6I8DKW28ZZ7y9E2DlLTAD lLhtbF7x7qqc
DQIQgAAE+iSAvPWZ99pGjbzVlhHigcC0BJqTN+kLulNW4h65e2dQ3lR5T5vr S6p7Gv/cY5V4
S+Vzx0t/EOiNAPLWW8brHC/yVmdeiAoCUxFoUt5CsFLk7cG7dga/pFuVS5u6 wLZ3fY7reMkL
8pJtqZh1e6ExSTzM8tLxpfQdqusbX6lxx8Yp8Z6b39z9xXKiHgRWRQB5WxV5 +jUJIG/MBwj0
RaB5ebMvOFPk7YE7bx4efejIcN6zq3Jp813wph6X+nGVl77YNmViTDz2OaXj k2KK7U+qJ5VL
ccSWS7znisP8Y0Ns7NSDQA8EkLceslz/GJG3+nNEhBAoSQB5C9C878SLg7dN qnJpS5U0c3VH
tW1fwNvtmT+7ztXHzLbsi3GXJNhtuWLxCaPZp9mXfdw31rHxSbnQY5CkJ7Xc lxN7pc6Mz8XX
jC+UN5dM+fJlt+OKNZSX0PyK4U0dCLRMAHlrObvLGRvytpxcESkEShBoVt7s C2d9EapX3nyP
JtR777glKG+qXNpSL+B9F9euC3ZJqEKiZ58bEhaXQLrGJfXnk7KYsdkSYYuQ lAe73CWYLtF0
cZHG6ZLhUK5i6qfItE/GY/mHZDSVM/Uh0DIB5K3l7C5nbMjbcnJFpBAoQaBZ efMJQcptk2eO
7Qp+5k2VS5u0ihN7QR0jOC5BCUmOTxq0aPhWxnxj8gmz1F7q2EL9uAQslKMY OZO4+sQsJEEp
8hvi7WKbIm8l4pBeA5RDoFUCyFurmV3WuJC3ZeWLaCGQSwB5CxA8dWT3sHbu 9LB21r2rcmlb
orxJKy+STEiyI600pQqtlANXubTyNlb4YlYIY/mF5NonjD5Zd8VVKo4x/DkH Ai0QQN5ayOLy
x4C8LT+HjAACKQSalzcbRsrK28nDtwZvm1Tl0tazvEmSlnv7oS15Ui608Eg5 GVueOx5Jmn1S
HHNejLyl5iuGN3Ug0DIB5K3l7C5nbMjbcnJFpBAoQaBJeZO+6y0W3PFDe4Ly psqlzXeLn+t2
NVNGQqsuvnPN4662THkxV558tw7a7UkrQXb7JhspZjvelPikHKRKni9nUjsu iXLlJJVTaA65
uLni9K0I+uaMnTvffIplTz0ItEgAeWsxq8sbE/K2vJwRMQRyCDQnbzkw7HNv P7g3+Jk3Vc4G
AS1jNglpBQ9yEIDAsgkgb8vOXyvRI2+tZJJxQCCOQPPylnKbpI3s6IF9w+H9 /l2Vs0EAeWMO
QKBPAshbn3mvbdTIW20ZIR4ITEugeXmbFh+tQwACEIBArwSQt14zX9e4kbe6 8kE0EJiaAPI2
NWHahwAEIACBJgkgb02mdXGDQt4WlzIChkAWgeblLee2ySyynAwBCEAAAk0T mEPe9Js0j5cH
GMCAOcAcYA7cmAPKcXYoIOrJ+oVLWzsbBCAAAQhAAAJuAnPI
Re: Primitive types and Java types in XMI [message #477298 is a reply to message #477296] |
Wed, 30 April 2008 10:17   |
--------------030505080708050601040706
Stephane,
Someone with UML knowledge will need to help. By the time you get to an
Ecore with this structure, it's major task to turn your EClasses into
EDataTypes. So likely you need to do something to the UML first. There
are introductory guides for how to do these kinds of things. I assume
you've looked carefully at the UML2 documentation and the wiki?
SWT wrote:
> Ed,
> type defined in my model by the one defined in the ecore ressource, so
> that the attribute "einttest2" gets the ecore EInt type instead of my
> fake int type ?
> "einttest2" attribute, but if I had a very very large model with lots
> of attributes using this int type, it wouldn't be feasible to change
> each one manually !
> Thanks again !
> Stephane
> Ed Merks wrote :
>> Stephane,
>> If I look at Ecore.uml it looks like as below, so I imagine you need
>> to apply the Ecore profile and set the Instance Class Name
>> SWT wrote:
>>> Hello all !
>>> I managed to import XMI 2.1 files generated by other uml tools
>>> (Enterprise Architect & Bouml) into eclipse, and it works well (at
>>> least with Bouml) except for primitive types and java types.
>>> For instance, in Bouml, if I define a class attribute with type
>>> "int", the resulting XMI declaration becomes :
>>> <ownedAttribute xmi:type="uml:Property" name="myIntAttribute"
>>> xmi:id="BOUML_0x1f482_1" visibility="private">
>>> <type xmi:type="uml:Class" xmi:idref="BOUML_datatype_0"/>
>>> </ownedAttribute>
>>> Where "BOUML_datatype_0" is defined as :
>>> <packagedElement xmi:type="uml:DataType" xmi:id="BOUML_datatype_0"
>>> name="int"/>
>>> After importing that into eclipse, I get an "int" class definition.
>>> If I use EMF to generate the corresponding model classes, it will
>>> result in creating a "int" class (public class int extends EObject) !
>>> Of course, I'd like to use the primitive java type int instead of
>>> this class !
>>> The same kind of problem appear with other java classes such as
>>> java.util.Date...
>>> So I'd like to know how to work around this problem... Can I do
>>> something with my UML tool such as using "special" stereotypes which
>>> would be recognized when importing into eclipse ?
>>> Or should I use some transformation (xsl) on my XMI files in order
>>> to change types declarations into ECore/XML types declarations ?
>>> Maybe there's a way under Eclipse, to switch attribute types from
>>> "fake classes" to ECore classes ?
>>> Any advice would be really appreciated. I already tried a lot of
>>> different things, but I can't find any working solution... I hope
>>> this is a "well known newbie problem" so that someone will tell me
>>> the right thing to do in no time :)
>>> Thanks in advance !
>>> Stephane
Content-Type: multipart/related;
boundary="------------070102010605050007000306"
--------------070102010605050007000306
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Stephane,<br>
<br>
an Ecore with this structure, it's major task to turn your EClasses
into EDataTypes. So likely you need to do something to the UML first.
There are introductory guides for how to do these kinds of things. I
assume you've looked carefully at the UML2 documentation and the wiki?<br>
<br>
<br>
SWT wrote:
<blockquote cite="mid:fv9t34$jfq$1@build.eclipse.org" type="cite">Ed,
<br>
<br>
<br>
<br>
fake int type ?
<br>
manually !
<br>
<br>
Thanks again !
<br>
Stephane
<br>
<br>
Ed Merks wrote :
<br>
<blockquote type="cite">Stephane,
<br>
<br>
If I look at Ecore.uml it looks like as below, so I imagine you need to
<br>
<br>
<br>
<br>
<br>
SWT wrote:
<br>
<blockquote type="cite">Hello all !
<br>
<br>
<br>
For instance, in Bouml, if I define a class attribute with type "int",
<br>
<br>
<br>
<br>
<br>
</ownedAttribute>
<br>
<br>
<br>
<br>
name="int"/>
<br>
<br>
<br>
<br>
Of course, I'd like to use the primitive java type int instead of this
class !
<br>
java.util.Date...
<br>
<br>
<br>
Or should I use some transformation (xsl) on my XMI files in order to
<br>
Maybe there's a way under Eclipse, to switch attribute types from "fake
<br>
<br>
different things, but I can't find any working solution... I hope this
is a "well known newbie problem" so that someone will tell me the right
<br>
<br>
Thanks in advance !
<br>
Stephane
<br>
</blockquote>
<br>
</blockquote>
<br>
<br>
<hr size="4" width="90%"><br>
<center><img src="cid:part1.00020103.06040206@ca.ibm.com"></center>
</blockquote>
<br>
</body>
</html>
Content-Type: image/png
Content-ID: <part1.00020103.06040206@ca.ibm.com>
iVBORw0KGgoAAAANSUhEUgAAA28AAAOiCAYAAADnue+WAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
ABh0RVh0U29mdHdhcmUAUGFpbnQuTkVUIHYzLjA4ZXKc4QAA+TRJREFUeF7t /W2wHcd5mIvi
/E2lKvfjnFOpW3V+5f5IVKkiwlIRMAMEvMqVK0pFlkvyLeX6RskxDhAhMFDg oYCQMGnY2BBg
UZZpi7RMUtS2QCsyZFnWByRaNk3FihGZcCRbhiwxtiXblGXLtqwvK1K4Nyll LnqDDfRudvfb
Pd0zq6f7maqptfZ0T/fbz9trr3l2z9rrf/r0714edrBBAAIQgAAEIAABCEAA AhCAQMUE/qcd
O5S8scOAOcAcYA4wB5gDzAHmAHOAOcAcYA7UPQeQN+QVeWcOMAeYA8wB5gBz gDnAHGAOMAcW
MAe88vYrj71/+NEf/VF2GDAHmAPMAeYAcyBjDqj30zF/yeZ9mGsQrsOYA8yB fueA773jBfJm
vlmMebPhnLqXWvUvAfJUd55K5cd8PX/jm88M7PkMzDfSsRflpfJLO8t4Hes5 EztfzNftwJZN
gNfsMl4nLfw+m1K01AuhBUaMIf716Hvv2CZv+g0DsPFgl8RKTYIlxUusefNQ v56/+vVvDmr/
0z//CnsBBpqneuSiMG+O9vYaV/NFEjj9uv3Od74zsJdnwGuW1+yUv3emvM5C 3vqdu/Z7x3V5
Q9zanhRT/kKZ8hchbY+bl/r1/KWvfGP4o8//NftEDBRfvaeurjC3x83tpXML CZx+3T733LMD
+/QMeM32+Rqc8neIea2lZav045Tx03a9rwnzvWNL3hC3epNV4oWEuLWdX3uO 6NfzF//qa8Mf
/NFfss/EQPFWe8zqSonXNW0s93XtmiP6dbu5uTGwz8uA1+xyX0u1/R7U11tT CBsrb8xT/btK
lLcP/dTeIbTX9sIhnhdObp+8kds2fxHoi8A//eJXhs/8wZ9v26Wc2/X5eTu/ GB6KO3/Rr/e1
ddtttw0xu/ReEtOGquNqJyRvG898a2CfnwGv2Xpfs9JrsabyGlbejv3712/7 vXPn699a9Udm
fuM//adB76VzmfN72o6lVFs57WyTt9DKjLrY23z228790xf/3ZbYlYZNe+V+ iZLbciyXMC+1
uP3xn/71cOWpL7xgj3k9u87j2AtZhpgo/mrnL/r1vf7UG6e0+aTL/B2Q2479 u1n9/N+/9d9e
sP//jtw7/OtjPz7877e/adh/x08OB//9Tw2H7vrp4cg9PzMc+9GHh9e9fn24 88fOD3e/6R3D
j/zkzw9n7n+Xsx1X2xx7IW9es/W9Zpfw3qtjrGHlTcnby7//NdevzXPlzZSr 2OcpOVNtqk09
ppwXWzf0uzrmd73uJ/d3fql21BzbWnkLXeC//yf/yfDM5nPDrf/ft1zf1c9q /8OP3DN8BoGb
ZLLFTkqpXkxudT7NR3K7zDcwU94+8amnB3vXr2cp565zeztm/nXMHnuozKyL wNX3Oir5Bhzz
F1Tf72iXvH3zv/3NYO8/df79w2/+7ueGS5/4g+Gjv/XU8K73f3T41d/43eFD //ETw/t+7fLw
Sx/+zeHdH/rPw89f/I3hP1wtO/PAu17QhqvdFo+Z+bDHFyqz6yJw9b1upWud WspXsfL2fT/+
weFfnX3ncPCHf3pQ4qZ3LXAl5O3P/vyLwxf+7M+Hz//pF4bfvfJ7wx//ydPD 5/7oj4c/+MPP
Db//B58dnvqvfzB85qnfHz79mf+aLGFK2n72534h+byUnLt+76eIm+qrpvcO Ud7e86bbhm9t
XJM3talH9bPan778k1sC9+mLhwZVLwVkq3V37NgR5CCVl+YS/Lzbb719K4// 8h/+2+s5JbfL
ftPS8vaHf/KXw+Xf+aMX7J9OyLnr/J6Omb+o1XM9dt9xHxuVCy4G63ldxQhX zJt67hu5S96+
8TdfHexdrbyd/on/MKz95DuH17/554dzP/3u4Y0/84vDmx7+peEn3/a+4f63 Xxze8nOPDQ/9
hw8Pb3vXr16Vt194QRuudls8Zr829Rh9x0MMeM3W85otfV00ZXsxK2//6ofe Peg99rNxKubY
z7zZK2+vPnD1Oj3ji6eVXP3CL753ePd73jf84i+9f/il910c3veBDw0XP/Th 4YOP/crwy7/y
a8OvPP6R4Vd/7T8Ov/aRj46SMHPVzV7dy4ndd7dEzO/4KW+bzLn7I2rl7cIb XzJ841vbV97U
z/Z+4cdf4p0cOcKSc26phKe0I8Urlaf0FVPXJ2/nX/3hYf2Vj23tr/uus9ef q+Nmbv/bf39u
COU2JoZQnbl55MZb+/la3p767BeH//xfPrttT825fb7+WeXMVyYdzzlXart0 uX1xri/6zV+6
6lhMvyofXAy2dTE4hbx9/WtfHuz9x9/63m3v85ev/FHwfV/Vd7WjXnvm7qoz 5THVt9m+/XOJ
vmNfs7F98Zpt6zU7x/t3zMqbErc3v/PJLYFTMf37n/6Pwx0/9fhw5I0fHv7t mQ8M//upX9o6
7hM7aRz2Z952/7+v3UL5kdf/r1u7dL5drm9r1L94rvzeZ4K/g8bc/mh+5k09 f+q3/3Brd0ld
avy2wI0Rt5w+XRI4ubz93Bv+6fD1q7KmdrXqZj7Xt1KqY6qeb3A5F+g555aE HduWFK9UHttP
bD2fvL315R8cnnzbZ4aLd31seONLz19/ro7rHG89fjOc29g4ppgbuX23eL6W t9/7/T8bfv03
f3/bnppz+3z9s5rDvjLpeM65UttTlEv3yqf0qXLCxWA7F4NTyNtXv/JXg70r GfvPVy9ifvPq
/p8/+fxuPv/k564f/82r5aq+qx312jOP2z+7zil5bK7+pNds6ph4zbbzmp3j Pb+GlTffOJW4
/Y/vfC1Z4JRAqVsl7f3Kpz49/O7V/c+/+Bdbu3qujo2VNx23a+VNHXv22Y1R bc+R95Q+Srx3
iLdNrp996fCVbzy7tZufe1PPn374j7aOqTJVL3SBrv/ip+uYfwE0z7OP++r5 zjHlyHWu/ddH
Xzx2vKpeTMwx/ackObeuT97uf9m7t8TtwoGPDEduOXX9uTqu860fQ7l1cbEF NcREylFufnTf
IWmOyWto3rr6iJm3ubl1na/l7ZOf/vzwa7/x1LY9Nef2+fpnc2yhY6rMrus6 1+7HVye2X1VP
9y3F5xujedx3r3zMuXYdlRcuBtu4GCzxBmy+htW8+PJf/8UL9h+7eoukuf2n q597C20/9jO/
4GxHvS7M9vXP9qOqY77W9Dn2e6fdli436+u2XG2a8bj688XhYmQf871mY851 1eE128Zrdor3
XLvNmJU39fpVq26xt0za9aRx/OqP/i/Dr/7o/3p1/1+Gx7eeX308fe1RyZva 1XGpHVOmzN85
n/zdT237FfSh9//coHa95cqbHZcWNyVv73vXI9f/M+WYfmLHPGW9Eu8dorw9 uPbdw5e+vrm1
K1Ezn2uZU8dUvdjVFd/FvesCO3TRrcXBFrnc47Zs5LZnni+Np/SEccmb+oyb ulVSrbgpcVO7
eq52dVyV6zyn5jaFVaiuKUt2vdT8SOIWM3+kcblissdQOrchefv4lT8ZPvwf f+/6Pibn5vnm
czXWmJ/teuoc17FSbem29YWgbleK1zdOfdx3ISid5ytXueFicPkXgyXegG15 +9Jf/flg7z/6
Uz8/PPGff2/4tau7+aieu3ZV39WOeh2Yx/XP+vWiy0L1fOfP0a5rTL5jvtds ShsvyMNVuVZ/
HJvj9zh9LPf3Q8zKm8qvvmXSFLPQZ+HUOTGfefvQ3f/z8J1v/Obz+5PDd/7m 6nO1f+Pqc3X8
b24c+9AP/c9R81lJ0m9/8srwO1d381H9AxMlbUqq1KP6pyZqHyNVoc+8fetb fzO49jH91PDa
KvHeIcrbm3/knw1f/Orm1q5kTT+3H1W9FHmz/4qnL459YpfSttmW2Y90Ae66 2NbxxAqnWd83
xjknj2/l7fUvedh526Q6bub2L67mPSW3EmMpvzGcffI2hrd9ji/f0rhsAXTF Mkfe9crbk7/9
R8PFx393256ac/t8/bMam1nmYqjK9XG7rq9d8xyzTX3cPs8Vh6uuL75QHLpM ugUrpg1XHZUf
BG65F2jqtVziDdiWt7/64p8O9n7Xvee3/ZVbSVxoU/Vd7divA11HHTfr+34O HXe1ndKu73y7
Dde47GPSazamDV8dXrPLfs3O8R6csvJmypp+bn4Wbuxn3t574v82vPf41f3q 4/uO/9+3nr/v
+f3bX/zZQe2qLJaH/Zm3T/zO7279CtLipuVNr8Bd+o3fiG5bx2B/5u2rf/31 4T3vfHj467/6
0+ErX/5z5468Xf2Lki+Jb/rhfz782Zc3t3Ylb+ZzvfKmjv3E1XqpghWqH7qI dq2U2OJlS4Bv
FcTVj08OXP3GyEYo3tgXz9h6Pnk7te/+67dKqhU3fQulOq5zrB9TchuSHDMH khSH8hmTH1++
bY6x8yRV3sbmK/c8LW+X/ssfDu/98O9s21Nzbp+vf1bMzDL7Z/s8fWGmjsfU dfXrOs8XR2p8
vnHG/vMD3/nScZUjLgaXezGY+18rXf9t8i/+7OnB3v/PM28d3n/1KwHe/8Rv bT0qedv62bOr
+q521Osi5rhdT/8ce1z34atvl/viMutJdXTd2Nesi0PsMV6zy33N5r6/xpy/ 6pW3UIy/cOz/
uiVu7776GDMWU6w+/tufHP7LJ35na//TL/zZlrh94fP/dfjyl76wbf/cH3yy +Mrbn//pHwyu
fcnyFvP+4ctR1H+b/LEf+hfD57+0sbX7PvOmylS9sfLmuoAOyZvr4l2SN0kW fG2mnGde4KdK
XcoLKaWuT97e8ZrHB3Uxr3Z1q6R+ro7rfOvHlNzGyFsMp1x5Kz1/cuTNJ4gp eYytq+VN/SON
d3/w49v21Jzb5+uf1XjMMulnVVfXseuaZfbzlPNCdWPic43V/vfiuo7vuI9X 6LjKExeDfV4M
uuTtz//0j69epGzff/Dun9m20PbLH/1kcOVN1Xe1o14HMcftevrnUsd1DFK7 Zqy+2O3x2K9N
Xe477uIRc4zXbJ+v2Zj34ZSVt6k+8+b7b5M//4P/l0HtMeMw69grb+q73j7w nrcPn/uD3x6+
+GeffcH++5/+rWSBC4mYKtPy9vNv/+nFf+Ytlb9dP0reztz58uFP/mrjBbsp cqpc1QsFpP/6
bq++2NJk19MXzZKw6fOk9mKkKiRyofhix5ibuJTzffKm2vi1x9+3lVf1eShX jtWxP/7L+Nz6
2JsiFZtfF0tb6Gyh8s0Bm5drDkh5leatqw9Xmym5G1NXy9uvXfrM8PPvu/yC PSXnrvP1MT02
+2d1PHRMlbnONfsy8ygdd9U1Y5BiCY3R/MuYXS9UFmrTmZOrueJisL+LQZe8 feHpzw72rr7n
LXV3taNeF7HHzdeVPsc8Zrflq2/3p+up42YbUn+uuF3HzNelXR4qi23frMdr tr/XbMx7cg0r
b1N8z5v9HyD1z09duTQ8/blPDb/wHx7akir9c+qqmPQ9b1rgUtuNydnS6kTJ 26kT3zN87i+e
EfcfOf49yTY/BTD7wnyKPpbUZkjelpbbJXFfVaxa3n7l139vWL9w6QV7Ss5d 53PshUxLMPnQ
E1cQuIwvkV3V6y2nX5e8ff6P/2CodVfvrbXGtqq4EDgEzrUqoo+FVtZcn3ez v/8t9jNv3/fj
Hxz+1dl3Dgd/+KcHJW56f/n3X/t+tztf/9bJrs+1sGmpsn+O/R051/e8xcZT c70oebv7dd87
3H1c7a8Yfuh1r7j+/MbPV4+pOlfLVjVY14rLqmKprd+QvC0ht7XxrD0eLW9K BlxSkZLzElJC
G/Gy9/5f+Z0tgeOCsI8LQpe8/cnnnhpq3dX7bK2xrTIuXrN9vF5j3/tjV95c Ylbiv02qOO2V
tynlTfVnipf+OZaXq57re95y2mvt3Ch5a23QvY0nJG+9sehhvFrelAggTvHi VAur9zz2iUHt
CFz7F4QuefujP/z0wL5MBrxm23/NxlxDxH7mTbU112feppa3GC7UKff6QN46 uE0HeSv3glnC
Lx8tb0oAahES4kiXyHd94L+wCtf472eXvH329z81sC+XAatwfb3fuq4Jclbe QkJnli3hWoQY
p3stIG+NXxyoFw/yNt0LqMZfTlre1MU/0pQuTTUx+w/vfXJQu74g5C/7bb2W XfL2h099cmBf
PgNes229VlPe66e85or5ku6UWKm7zHmKvCFvK/ucIr80pvmloeVNXfTXJCLE Ml4kz7/7Y4Pe
uSic5nWzit9HLnn7/U//9sDeFgNes+28ZmN+TwS/x6NAYUwM1Gl7zm2TN/MX DM+v/dMAdhgs
dQ6oi32EabwwLYHdUucmcd/4vWpeZCkuT33qv7A3zIC5zzUFc4A5UGIO7NC3 1i3hYoUY274Y
Jb/klznAHOhlDrhW3viLedt/MSe/5Jc5wBzInQPbVt56ecNknFwcMgeYA8wB 5sCq5wDyxkVc
7kUc5zOHmAP9zQGnvBW4JZcmIAABCEAAAk0SyLlYuu22267fzhyStybBMaii BNRcYoMABPoh
oN97ViZvH/qpvUNo7ycVjBQCEIAABJZEQP/L7tSY1RtuirzlSCLntv3XeD2X +O+DbeeZ1zH5
9X0dxQs+85b6hjSmvhK3zWe/7dw/ffHfbYkdGwQgAAEIQKA2AmO/bwl540Ks 1MU48sZcKjWX
aGd5c2llK2/v/8l/Mjyz+Zxz/8OP3DN8BoGr7XqFeCAAAQhA4CoB5G15Fzut XaAib8zB1uY0
44mf08nyFvPvLWPe3T/9W28fvrXx3PAv/+G/3Xo096cv/+SgBO7TFw8N73nT uHu6d+zYERPG
tjrqnDHnJXd09YS5+hkTW+icmLhLc4zpM2WcUnt2uVQ/pW/qQgACyyeAvMVf ZHBBNg2r0vKm
3ufI1TS5gitcS8+BUfIWeutVDUrb+Vd/eFh/5WNb++u+6+z15+r4N7713PX9 v/3354YLP/4S
qTlnuXTBveoLdCm+UYOe4SQpbql8TIil25Ta880N6bxc6R3DhnMgAIH5CaxS 3vQfx/Rj6YsC
qT0u8uu4EJXkzc6TlDepXJoXlNcxL8hDH3lYiby99eUfHJ5822eGi3d9bHjj S89ff66Of/2q
vF3fv/nc8HNv+Kej3pmlC23kbRRWccVQ4j6m19JtSu0hb2OyxDkQ6IdASN5C F8ElPvOWelFe
+mKOi/w6Lg6RtzryUPr1RXvkNWYOrETe7n/Zu7fE7cKBjwxHbjl1/bk6/pVv PLttXz/70uAV
gf1XSF3ZvAA365jl+rg6FlNH17MfXe2YQYdEUZdJ8Y6J0WYR25eLhTlmH8PU GO1+fPFJObNZ
m/lwnSuxtstTx+vi4GOaGrsUi52nmH77ueRmpBAoQ8Anb+brzfcfwnL/26RP 3vRxs9wVj/2e
acbpq6/qmO3reuZx3Q5yN8/FZ468xeTZlU9pfsdcdFJnnvkB57Y5j5Y3+w1A X/Dq2yZ9j+oz
bupWSbXipsRN7eq52tVxVf6lr29e3x9c+25R3lyiZAuTT2RcsucTFfOi3CeJ 0nHfxbUUh2s8
PikMHfeJidS/K+4Y7iFxdeUkRnR9sYzhIY0hxCu2P9d8sid1Tlum9KbEW+Yy llYg0B8Bl7y5
3hPtC6gpV95MoQpJlSR/9kV7bLvI27wXi5K82cLtu5i3pT91fiAJ8+Yd3vBW c2C0vPnermM+
8/b6lzzsvG1SHf/iVzev739x9fmbf+SfZcub/aYakjNJYsbIRehC3dWeL15J hMyLeElKfELh
k3KfdJr1fVxd44mR3JAwuiQlVoBs2QmNQZKhsblyzYmYeSr9YcHOe4h9f5fc jBgCZQjY8ub6
vWlLj37DLbHyZvbnk6bUi3CffPrasVfsXMLIheZ0F5o58mbnOiR6pty5ziPH 0+UYtrD1zYGV
yNupffdfv1VSrbjpWyjV8T/78ua2/Sd++J9nyVvqBX0N8hYasP7lmXoRHyOs 0gpRSGQkbq4x
STI6h7xJcUnyNjZXIaF3iXfomCTtZS5XaQUCENAEfLdNShdbU6y8lZQ3V/zI W50XkGPlTZJ6
qVya45TXOV/IS1t5WYm8veM1jw9K1NSubpXUz9Xxz39pY9v+Yz/0LxYvbyFJ kQTGLjeFJlVM
pb4kwYsRGakPn2j4xNHXp+t4KR4xfUqsbJkN5TFFxFPqSrngUhwCEBhHoAd5 M1dcXKts9sWg
fdHPxeK0F4sx8ha6fdZ1e+yY223J87R5hi98XXNglLxJ3/UW83b4a4+/b/iT v9rY+oybenTt
f/yXG8OZO18uypu5lO9aAbKX+s06kkyYK13SBXvMRX/MBbVvPHYsOh7p+Jgx SuP29e2TFFd7
9jglNrF8Y3lIYwiNxZ5DdmyhGFxzNDaXUr+uFT1XLDGvUepAAAJuAkuQN30h rl//5sW6+bvX
FjNXfZeo2bKGvM17kTlW3ux54ZJ0+5rJNXeQinnzDW94m3MgWd5KvZmfOvE9 w+f+4hlx/5Hj
3yPKW6mY5mjHJQRz9JvbxyriXkWfJqdV95+bM86HAASmIbBKecu9iJtCsqZo M3ecrZ8fK2+t
c2B8SE2PcyBb3mL+QYnr7fPu133vcPdxtb9i+KHXveL68xs/Xz2m6lwtC21L u8BeWry+VaJp
Lom2t7pqVqvufw7G9AEBCKQTUBcL0h0ovvLcf1iSe6EyhWhN0WbuOFs/H3lD Wlqf44zPP8ez
5S39bY8zIAABCEAAAssloAQsZ1+/cGlQu3oDtm+F0T8rOmMFkfN+tAt2ag4y T/rINa9p8my+
XyBvy71+IHIIQAACEFgBgZy/CMeuvOXIIefmyTX84MccYA7UOAf0e0+2vI29 bdL1fluyrRW8
n9MlBCAAAQh0QEB/5i11qKlfFZDaPvX7IjB2HvZFidFCoB0CxeStHSSMBAIQ gAAEICATmOsf
lsiRUKNnAshbz9ln7D0SKCZvJVfLSrbVY1IZMwQgAAEITE8AeZueMT3IBPQ8 /PVffsMwZv/U
J94jd0INCECgGgLF5K2aEVmBqO+PY4MABCAAAQiUJtCzvOV8b+QU/8F3ijZL z5ep2tPz8Fcv
vmn45FeeG7VPFRvtQgAC5QkUk7ec1bKY/54TO/Tzr/7wsP7Kx67vr/uus9t+ VuVsEIAABCAA
gVwCLcib/UXMMUxyRUmfH2rHLpP6lMpjxrXUOlPKmzk/lsqHuCHQGoFi8pYD RhI/qdzs+5FX
fGh47J4nh8fPfXx4z5GPDuuvemzbz6pc2nLeBHLOleKiHAIQgAAE6iHQiryZ RGPew2LqhLKE
vJWdw3oefuC9b95adfv7+39ma//8X28MX/r6s8Odb/3w8IP3f2D4/nPvHr77 5M8N/+gHH97a
/7d//VPD337lG7bqubZUgS47KlqDAAR8BIrJW4pg2cFI50rlZntvffkHt8Tt ybd9Zrh418eG
N770/LafVbm05bwx5ZwrxUU5BCAAAQjUQ6BFeVN0zfcx18pLyjGXGJry5rv9 MiQOvv7t2GPG
Us9sGh+JnofvetdD2+TtL7+2OXz1m89t27929Wd7V3WQt/H8ORMCcxMoJm85 gUtyJpWbfd//
sndvrbgpcbtw4CPDkVtObftZlUtb7BuTfmMw33y4xUCiSzkEIACBNgi0Lm8+ gZL+SOlbWbOP
j21HEsJQuS6T+l7SDNXz8O3v+Nlt8qYk7ZvPfHtr5e3oT39w+Ddv/KXhe37k ncM/vmN9a/8H
B98y/N3vv2/4W9/7BuRtSQkn1u4JFJO3FMGyqetz7Xvv9S9XXe571O2pf06i PuOmVtvUrsRN
7/qYKpf+iYl0q0Dolo+W3hC6f3UAAAIQgECAQA/yZr8v6z9a2lhi6pWSt1Bf IeF0ndfCBNfz
8C3r79wmb9/a/M6w8ez/2LZvPvudQe+6bPO57yBvLUwExtANgWLylkNMEj+p 3OxbSZr5mTcl
b+bPqlzaXL/8fW8WkuhJfVEOAQhAAALLJNCDvLkyI73vTbnyJq0GSuXLnGnh qPU8/ImHf3FL
3r618e3ruxI1tfJ26M0fGF61dmHYc3XF7e/9wANb+9/5vnuv1dv8NvLW4sRg TM0SKCZvKYJl
05TOlcrN9l7/koeDn3lT5dImvTH5/uLo+4uk1B/lEIAABCCwPAItypv5/hcr Qqn1QnevuN5f
zWNSX1K5bqulu2T0PHzDW9472PtTn/3CIO1f+OKXkbfl/foh4o4JFJO3HIaS nEnlZt+n9t2/
7TNuaqXN/AycKpc2Sd5cv/RT3oyk/imHAAQgAIH6CbQib+adJb4/ToakTv/h 0tWOdDulLvdl
2/d+a/dlxyfFUv/sio9Qz0PfGdJ/mwz1FJob8RFSEwIQKEmgmLylCJY9gJLf 8/aO1zw+KEHT
u/qMm/mzKo/Z7DeUlDcC6c0opn/qQAACEIBA3QRakLe6CRNdDIEp5S2mf+pA AALzEigmb/OG
Hd+b9M9J4luiJgQgAAEIQOAGAeSN2VADAUneaoiRGCAAgXIEislbzspbueHQ EgQgAAEIQGAe
AsjbPJzpJUwAeWOGQKAvAsXkrS9sjBYCEIAABHonMIe86TdpHi8PMIABc4A5 wBy4MQfUwtkO
BUQ9Wb9waWtP2Vh5S6FFXQhAAAIQWDoB5I0LSS4kmQPMAebAquZAs/KGVC79 8oj4IQABCNRJ
AHnjom1VF230y9xjDjAHsuWtzrdWooIABCAAAQhMQwB54+KppgvoX//lNwxj 9k994j3cknr1
zrOackks5CNmDmTLW60rXDlxrd9z0yDt01wS0CoEIAABCNROAHmr7wJLfVVP zEVPi3V+9eKb
hk9+5blRe4s8GFN9r09yUjYn2fJW+5vsmPiUuG1sXvHuqpwNAhCAAAT6JNCC vJnfYZp6YbVq
UbK/AFzFP0VMuh+TzxT9pPK365eWN2mMUnnueDi/7IU+PNvjmS1vOStcU77t 58T1yN07g/Km
ytkgAAEIQKBPAi3IW47wrPLi3df3FDEtRd4+8N43b626/f39P7O1f/6vN4Yv ff3Z4c63fnj4
wfs/MHz/uXcP333y54Z/9IMPb+3/27/+qeFvv/INW/XGXNhPwXpMHJzTnpSQ 07icZstbi2/d
D961c3hm46mtfWPz+V0/v/qoyqVN/XILbVK51D7lEIAABCCwGgItyptrNUtf SNmrdK5VO+mY
fcEv1XddxIWkwSzzrSqm9qnbtNv2cdFCbEqfTwBdx8deuL7rXQ9tk7e//Nrm 8NVvPrdt/9rV
n+1d1Qlx9s2JnFXbsWPkvLiLejj1wSlb3nJWuKZ8282J64E7bx4efejIcN6z q/LcDXnLJcj5
EIAABFZDoFV5c90e6BImaeXFJT3mSl9MmzF1Ym5n9MUSs/IoyZvEyyV9LonN veB++zt+dpu8
KUn75jPf3lp5O/rTHxz+zRt/afieH3nn8I/vWN/a/8HBtwx/9/vvG/7W975B lDdpjLmxc34f
skGey+Y5W95W89Y5ba/3nXhx8LZJVS5tWs7sv1zp88zjUluUQwACEIBAPQR6 k7cY4XCt0vjO
84mZb6XHXOnyXQT6Vt5MAXPFk7KaZwufNGafvEnjTL3Qfcv6O7fJ27c2vzNs PPs/tu2bz35n
0Lsu23zuO8gb/21y1K2zqXOU+pXJW84K15RvxTqu2EczlnvvuCUob6pc2kx5 M+v6jkvtUQ4B
CEAAAnUQ6Ene7FsEXStWsZKWswomrZRJq32ucYSOuUQttHoordKFxp57YfsT D//ilrx9a+Pb
13clamrl7dCbPzC8au3CsOfqitvf+4EHtva/8333Xqu3+W3kDXlD3hY4B1h5 c1wLnDm2K/iZ
N1UubcibRIhyCEAAAssk0KO8xYiLvUIWK3UxQiitvsXKm08CY27T1CtmoXhd q20p7MaI3Bve
8t7B3p/67BcGaf/CF7+MvC3wwn3MHOGcsitfq+aZLW+1r7yNuTQ4dWT3sHbu 9LB21r2rcmlD
3iRClEMAAhBYJoEW5M28dU+SEVNafKtV0i2EoVsO7TZDtzLqdkLx+2Kxx2G3 YV+QSbdZSmMO
iZyLaekLQum/Tfr6ixHhOeIvzYP22hKYnvOZLW/LfOsNR33y8K3B2yZVubQh bxIhyiEAAQgs
k0AL8tbzhU8vYx8rb73wYZzI3FLnQLa8tbjydvzQnqC8qXJpk+RNna//ciW1 RTkEIAABCNRD
AHnjom+pF33EzdxlDix/DmTLWz1vp+Uiuf3g3uBn3lQ5GwQgAAEI9EkAeVv+ xQ8XsOSQOcAc
WOocyJa3Flfejh7YNxze799VORsEIAABCPRJAHnjom+pF33EzdxlDix/DmTL W59v3YwaAhCA
AAR6JTCHvPXKlnHHE9DzMP4MakIAAksmoMU7W95aXHlbcmKJHQIQgAAEpiWA vE3Ll9bjCCBv
cZyoBYFWCCBvrWSScUAAAhCAwKwEkLdZcdOZh4Ceh7/+y28Yxuyf+sR7YAsB CCyIQDF5W9CY
CRUCEIAABCCQTQB5y0ZIAwUI6Hn4qxffNHzyK8+N2guEQRMQgMBMBIrJG7dN zpQxuoEABCAA
gSoItCBv5hdMp0LVX4WTel5ufftLsaeMw/VVPlP2N4bNVPImjVMqHzMWzoEA BGQCxeRN7mr5
Nf7lP/y3yx8EI4AABCAAgSIEWpA3BWLsRfjY84rAz4g7pf8lydsH3vvmrVW3 v7//Z7b2z//1
xvClrz87SF/SreqN2Vad/zExcw4EWiBQTN5qWXlTcUh7bOLOv/rDw/orH7u+ v+67zm77WZWz
QQACEIBAnwRalDd7VcvMrL1K51q1k47ZF/xS/dDMcrVlx6vl1LfCKK086j7M vuzntuD5OIVY
5ryC9Dx817se2iZvf/m1zeGr33xu2/61qz/bu6rj2syx5+QpZ2ycCwEIvJBA MXmrBa4kkVK5
OY5HXvGh4bF7nhweP/fx4T1HPjqsv+qxbT+rcmnL+ctUzrlSXJRDAAIQgEAe gVblzSdANi3p
PcolPlqmzEdXf/pYqI8UeYsZk6svSd6kdl3SJ8WdOiv1PHz7O352m7wpSfvm M9/eWnk7+tMf
HP7NG39p+J4feefwj+9Y39r/wcG3DH/3++8b/tb3vkGUN2mcqTFTHwIQGE+g mLylSNH4cOUz
pTikcrOHt778g1vi9uTbPjNcvOtjwxtfen7bz6pc2qQ3t9D5OedKcVEOAQhA AAJ5BHqTtxjp
cK3c+c7zyVJo9S8kej4xDPUv9SXJlzRe3/lSvykzU8/Dt6y/c5u8fWvzO8PG s/9j27757HcG
veuyzee+g7ylAKcuBFZMoJi8rXgc17uX5EwqN8dx/8vevbXipsTtwoGPDEdu ObXtZ1UubSm3
GvhutUDiJMqUQwACEJifQE/ypumatwhKMldi5S31D5wxK2W+uFx9heQtRkol +Ssxa/U8/ImH
f3FL3r618e3ruxI1tfJ26M0fGF61dmHYc3XF7e/9wANb+9/5vnuv1dv8NvJW IhG0AYGZCBST
txQpmnJsOg77r1r6F6gu9z3q2NQ/J1GfcVOrbWpX4qZ3fUyVS//EZOybm/kX xCl50TYEIAAB
CIwj0KO8me9NY9/fQvIktWlmyveHTakNSSpDfcTIq0vYUrilzkY9D9/wlvcO 9v7UZ78wSPsX
vvhl5C0VOvUhsEICxeRthWPY1rUkkVK52ZiSNPMzb0rezJ9VubS53kR8t1lI bzhSX5RDAAIQ
gMB8BFqQN9cdHy55cd1FooXElpXYNs3zfW2Espkib1L8qW3puHzv52a577kp gjmzVs9DXxvS
f5v0nRcjuaXGkDN+zoVAbwSKyVuKFE0JWYpDKjdje/1LHg5+5k2VS1uqkIX+ qif1RTkEIAAB
CMxHoAV5m4/WPD25JMwnZvNENH0vU8nb9JHTAwQgMIZAMXkb0/kU50hyJpWb MZ3ad/+2z7ip
lTbzM3CqXNokeQu90bT+hiOxoxwCEIBAzQSQt/qyg7zVlxMiggAEyhIoJm8p UlR2CNtbk77j
LSXOd7zm8UEJmt7VZ9zMn1V5zGbfVuC6fUO6pSOmH+pAAAIQgMB8BJC3+VjT k5+AtPIGOwhA
oC0CxeStLSzu0Uj/nKQHBowRAhCAAASuEZhD3vSbNI+Xt3izw4A5wBxgDlyb A2pBaod+sn7h
0qD2lC1lRSulXepCAAIQgAAEaiQwh7zVOG5iqosAK2915YNoIDA1AVbepiZM +xCAAAQg0CQB
5K3JtC5uUMjb4lJGwBDIIlBM3lh5y8oDJ0MAAhCAwMIIIG8LS1ij4ep5+Ou/ /IZhzP6pT7yn
UTIMCwJtEkDeEvKKoCbAoioEIACBxgkgb40neCHD0/PwVy++afjkV54btS9k qIQJAQhcJVBM
3qAJAQhAAAIQ6IlAC/Lm+pJlvqZmWbN4Knmzv4Dc/NLumC/nZh4tax4R7XII FJO3Hlalehjj
cqYukUIAAhBYLQHkbbX86f0aAT0PP/DeN2+tuv39/T+ztX/+rzeGL3392eHO t354+MH7PzB8
/7l3D9998ueGf/SDD2/t/9u//qnhb7/yDVv1XFtIvmLELKYOOYQABNIJFJO3 9K77PoOvHeg7
/4weAhBYPoFW5E1lwrzQtp9L31XqW72LWZ1Z/ixY/Qj0PHzXux7aJm9/+bXN 4avffG7b/rWr
P9u7qpMjb/YKnW7L9/21qydGBBBYNoFi8tbiqlTJL/w+/+oPD+uvfOz6rr7w 2/xZlS9xk/6y
JpUvcczEDAEIQEAR6EHezEybt82ZF+j2c/v3Pu8D075e9Dx8+zt+dpu8KUn7 5jPf3lp5O/rT
Hxz+zRt/afieH3nn8I/vWN/a/8HBtwx/9/vvG/7W977BK28+AfPJvvmHAPI+ bd5pvV8CxeSt
RYSSkErlJpNHXvGh4bF7nhweP/fx4T1HPjqsv+qxbT+rcmnz3X9u/5VLakf/ cnW9wab+spXq
S+UxsVIHAhCAQI0EWpI330W3a1UltEpnvr+w8jLPrNXz8C3r79wmb9/a/M6w 8ez/2LZvPvud
Qe+6bPO573jlzTcC5G2e3NILBFwEislbisgsJRXSmKRyc5xvffkHt8Ttybd9 Zrh418eGN770
/LafVbm0SSKUcotK6DYXKQ6zPCamlPaoCwEIQGApBFqXN98KWoy8LSWHLcSp 5+FPPPyLW/L2
rY1vX9+VqKmVt0Nv/sDwqrULw56rK25/7wce2Nr/zvfde63e5reRtxYmAmPo hkAxeWuRmCRn
UrnJ5P6XvXtrxU2J24UDHxmO3HJq28+qXNpCohT6K5irXfv2F9/tMNJnGex+ 7fqS3EljphwC
EIBArQRakzfF2fwdXkreeB+YdgbrefiGt7x3sPenPvuFQdq/8MUvI2/TpojW IVCUQDF5SxGZ
oiOYsDE9Jt/tirrc96hDU/+cRH3GTa22qV2Jm971MVUu/RMT1+0ruo/S8hbz pq3f6M1HOx7e
tCecoDQNAQislEDr8mbKnE/qQqtwKXeDrDSRC+9cz0PfMKT/Nuk7z3ftY98O 67tesP8YsHDM
hA+BaggUk7dqRlQwEElIpXIzFCVp5mfelLyZP6tyaZti5c0WL9cKXKykueQS eZOySjkEILBU
Ai3I21LZE/cNAlPJG4whAIE6CRSTtxSRqRPFC6OSxiSVmy2+/iUPBz/zpsql zSdCrr+OSdKU
+pmFVKnTY5HikMZMOQQgAIFaCSBvtWamr7gkeeuLBqOFQPsEislbi6gkOZPK TSan9t2/7TNu
aqXN/AycKpe2kLzZ50rSJLXFbZNSNiiHAAR6J4C89T4D6hg/8lZHHogCAnMR KCZvKSIz1+By
+yn5PW/veM3jgxI0vavPuJk/q3JpC91/XlreVHv2fe26D99n71z1JYmUxkw5 BCAAgVoJzCFv
+k2ax8tb36vHDgPmAHOAOXBtDihP2aGfrF+4NKidbToC0j8nma5nWoYABCAA gRIE5pC3EnHS
RtsEWHlrO7+MDgI2AVbeGp8TYz4P1zgShgcBCECgCAHkrQhGGskkgLxlAuR0 CCyMQDF5W9i4
CRcCEIAABCCQRQB5y8LHyYUI6Hn467/8hmHM/qlPvKdQJDQDAQjMQaCYvLX4 mbc5EkAfEIAA
BCCwTALIm5y3nM89S/9YS+69jxp6Hv7qxTcNn/zKc+L+R9/49qB3Xb8PUowS Am0QQN5WlEdk
d0Xg6RYCEIBAIQKtyJvvn1DFYJLkzPc1MzltS33GtN1SnankDc4tzRLG0hKB YvLWEhTGAgEI
QAACEJAItCBvU1+g57TPyps0A6+V63n4gfe+eWvV7e/v/5mt/fN/vTF8/kvb 97/6m83h//yZ
39za/9H3nhz+6m+e3arn2nJyFxc5tSAAgTEEiskbK0lp+OGVxovaEIAABGoj 0Lq8hb7+xbWi
FlvfV08f13kOfS2Nq05t82OuePQ8fNe7Htomb3/5tc3hL4z9q9987rq0KXFT Ave1q8fUcZ+8
mTmxc+77PljVlu+rhuZiQj8QaJlAMXlrGVLtY+NrB2rPEPFBAAItEmhB3nwX 2r4Lc5dg+S78
ddvmo1lXWlkLxeBqs9eVIj0P3/6On90mb0rM1K4k7ZvPfHvr8bYfeNP1lTd9 TIlcKIe2KJs/
u/IZkroWfw8wJgjMTaCYvLGSFE5dyS/8Pv/qDw/rr3zs+q6+8Nv8WZXPtUlv llL5XHHSDwQg
AIHSBFqRN98FuGvlK3a1JWWVxhZI3+fkXG3mfF6v9HxYVXt6Hr5l/Z3b5O1b m9/ZujVSr7Lp
x5fd9cuD2vWtk+oxVt5C8m3mh7ysajbQbw8EislbD7ByxijJrVRu9v3IKz40 PHbPk8Pj5z4+
vOfIR4f1Vz227WdVLm32X0/NN0/p3NAvb/tc5C2FJnUhAIElEWhd3lIu6FNW yaSVmRR5W9J8
mSpWPQ9/4uFf3JK3b218+/r+368+f82P/cctgVOPG89+Z9tn3pS4bTz3neLy NtVYaRcCELj2
OVe1K3fYoZ+sX7g0qD1lS5GPlHZbqSvxkcpNDm99+Qe3xO3Jt31muHjXx4Y3 vvT8tp9VubQh
bxIhyiEAAQiECfQkb7FCpYn5Vt5cf9CTxE9q0y7vbd7qefiGt7x3cO3/9bN/ tiVv//WzX9ja
zX9Yop5/4YtfnlTe+CNubzOS8U5NoJi8TR3o0tuX5EwqN8d//8vevbXipsTt woGPDEduObXt
Z1UubTFvrL4PHPtuh3DV55e2lAnKIQCBpRJoQd5Ct7fF/E43f8eHbrP03VJn ipfdX+i9xnXe
UudRbtx6Hsa0o2+V1J9z07dS+s41/9DrE2/fPHH9kTgmRupAAALyHw5ZeZth lmg5s9+M9C9D
Xe571CGqf06iPuOmVtvUrsRN7/qYKpf+iYkkb2P/Eur7C+kMiOkCAhCAwKwE WpC3WYHR2SQE
ppS3SQKmUQhAIIsAK29Z+OJPllbWpHKzJyVp5mfelLyZP6tyabP/WipJV8wt M6G/ukrxUA4B
CEBgaQSQt6VlrM14U+TN9Z8lff9tsk1ajAoCyydQTN5S5GP52NJHIPGRys0e X/+Sh4OfeVPl
0jaFvLn65LZJKROUQwACSyWAvC01c23FnSJvbY2c0UCgTwLF5K1PfPGjluRM Kjd7OrXv/m2f
cVMrbeZn4FS5tPmkKmaFzWw7tb4UF+UQgAAElkJgDnnTb9I8XvvvauwwYA4w B5gD/LfJWa4T
Sn7P2zte8/igBE3v6jNu5s+qXNokeVPn8w9LJIqUQwACPROYQ9565svY4wiw 8hbHiVoQaIUA
K28NZFL65yQNDJEhQAACEKiOAPJWXUq6DAh56zLtDLpjAsXkLeW2v455Xx86 vJgFEIAABJZN
AHlbdv5aiR55ayWTjAMCcQSKyVtcd9SCAAQgAAEItEEAeWsjj0sfBfK29AwS PwTSCBSTN1aS
0sBTGwIQgAAElk0AeVt2/lqJHnlrJZOMAwJxBJC3OE7Fa5WU3ZJtFR8oDUIA AhBolADy1mhi
FzYs5G1hCSNcCGQSKCZvmXFwOgQgAAEIQGBRBJC3RaWr2WCRt2ZTy8Ag4CRQ TN5Y/UmbYSV5
lWwrbRTUhgAEINAvAeSt39zXNHLkraZsEAsEpidQTN6mD5Ue5iDA1w7MQZk+ IACBFgggby1k
cfljQN6Wn0NGAIEUAsXkjdWfFOzDkMOr5Bd+n3/1h4f1Vz52fVdf+G3+rMpz Nt+Xgee0mXOu
FI9UntM350IAAm0RQN7ayudSR4O8LTVzxA2BcQSKydu47jlrDAFJ/KRys89H XvGh4bF7nhwe
P/fx4T1HPjqsv+qxbT+r8thNiY+5q/NKyZBu14zFdUyKVYpHKpfapxwCEOiH APLWT65rHiny
VnN2iA0C5QkUk7cUYSg/jOW1mMNLOlcqN2m99eUf3BK3J9/2meHiXR8b3vjS 89t+VuUxm096
SskQ8haTBepAAAJzEkDe5qRNXz4CyBtzAwJ9ESgmb31hW+1oJTmTys3o73/Z u7dW3JS4XTjw
keHILae2/azKpS0kaGaZvSqn23Ud963g6fbsR9VWTPtSPKVkU2JGOQQgsHwC yNvyc9jCCJC3
FrLIGCAQT6CYvKUIQ3x47dbM4aXPtW9T1OKhy32Pmqr65yTqM25qtU3tStz0 ro+pcumfmMTK
m5lNl3yZMmdn3idtvnZKHW93BjIyCEAglwDylkuQ80sQQN5KUKQNCCyHQDF5 W86Qlx+pJH5S
uUlASZr5mTclb+bPqlzaYuXN95k4+3zfLZIuucuRtCk/oycxoxwCEFg+AeRt +TlsYQTIWwtZ
ZAwQiCdQTN5ShCE+vHZr5vCSzpXKTaqvf8nDwc+8qXJpi5E3l6CZ7UqfabNv d7RFztd+7HGX
GErjphwCEOibwBzypt+kebw8wAAGzAHmAHPgxhxQ1/s7FBD1ZP3Cpa2drU4C kpxJ5eaoTu27
f9tn3NRKm/kZOFUes0n/sESSN9WHq43Q7ZXmObGSlrpSFzN26kAAAn0SmEPe +iTLqFMIsPKW
Qou6EFg+AVbeVpTDFMGyQyz5PW/veM3jgxI0vavPuJk/q/LYTboNMXTb5Nh/ JCKdpwXP9c9M
fMdix0s9CECgbwLIW9/5r2X0yFstmSAOCMxDoJi8zRMuvUxNQPrnJFP3T/sQ gAAElkIAeVtK
ptqOE3lrO7+MDgI2gWLylrOS1GNa4NVj1hkzBCDQEgHkraVsLncsyNtyc0fk EBhDoJi8jemc
cyAAAQhAAAJLJYC8LTVzbcWNvLWVT0YDAYlAMXljJUlCvb0cXmm8qA0BCECg NgLIW20Z6TMe
5K3PvDPqfgkgbyvKfa3yVmtcK0oT3UIAAhDwEkDemBw1EEDeasgCMUBgPgLF 5G2+kOkJAhCA
AAQgsHoCyNvqc0AEw9b337FBAAL9ECgmb6zYpE2aWnnVGlcaXWpDAAIQmJ4A 8jY9Y3qQCSBv
MiNqQKAlAsXkrSUojKUMAb52oAxHWoEABOokgLzVmZfeokLeess44+2dQDF5 Y8UmbSrVwqvk
F36ff/WHh/VXPnZ9V1/4bf6sytkgAAEItEIAeWslk8seB/K27PwRPQRSCRST t9SOqV8HAUki
pXJzFI+84kPDY/c8OTx+7uPDe458dFh/1WPbflblMduOHTsGc485x6yjzmWD AAQgMDUB5G1q
wrQfQwB5i6FEHQi0Q6CYvKVc5LeDb/xIauElxSGVmwTe+vIPbonbk2/7zHDx ro8Nb3zp+W0/
q3JpKyFeJdqQ4qQcAhCAAPLGHKiBAPJWQxaIAQLzESgmb/OFTE8lCUhyJpWb sdz/sndvrbgp
cbtw4CPDkVtObftZlUubT7zs4+bP9iqda9Uu5piuI8VIOQQgAAFFAHljHtRA AHmrIQvEAIH5
CBSTt5SL/PmGV29PtfDScdi3Kmo50uW+R01Y/XMS9Rk3tdqmdiVuetfHVHnM PzHxiZaZTR2f
S/ZCoqfacJ1ry2C9M4fIIACBWgggb7Vkou84kLe+88/o+yNQTN76Q9fGiCWJ lMpNCkrSzM+8
KXkzf1blqZtLqlyrbi6x08d8YuoTNm67TM0S9SHQJ4E55E2/SfN4eWulkx0G zAHmAHPg2hxQ
1+g79JP1C5cGtadsKRf5Ke22WrcWXlIcUrmZn9e/5OHgZ95UeeomyZstaObK mlnm6hd5S80G
9SEAAZPAHPIGcQhIBFh5kwhRDoG2CLDy1lY+k0cjyZlUbnZ4at/92z7jplba zM/AqfLUTboF
0mzPdyulrw3kLTUb1IcABJA35kBtBJC32jJCPBCYlkAxeUu5yJ92SMtovRZe Jb/n7R2veXxQ
gqZ39Rk382dVLm3S1wS4RMz1j0bsY9Ln6PjMm5QZyiEAAZsAK2/MiRoIIG81 ZIEYIDAfgWLy
Nl/I9LQUAjH/nCRlLHwWLYUWdSEAgakJIG9TE6b9GALIWwwl6kCgHQLF5K2W laSlpAZe6ZlC
3tKZcQYEIDAdAeRtOra0HE8AeYtnRU0ItECgmLy1AIMxQAACEIAABGIJIG+x pKg3JQHkbUq6
tA2B+ggUkzdWktKSC680XtSGAAQgUBsB5K22jPQZD/LWZ94Zdb8EkLcV5b4H eethjCuaPnQL
AQhUQAB5qyAJhLD1fU9sEIBAPwSKyVs/yBgpBCAAAQhAYLh+0Zz6hbHqD1u3 3Xbb1vepql39
bLZh/gxnCEgEkDeJEOUQaItAMXljlSVtYvTAK2eM6/fcNEh7GnFqQwACEChL gJW3sjxpbRwB
5G0cN86CwFIJFJO3pQIg7joJKHHb2Lzi3VU5GwQgAIFVEkDeVkmfvjUB5I25 AIG+CBSTt5xV
lr6QXxtti7xKfuH3I3fvDMqbKs/ZWvjagRbGkJNDzoXAqgkgb6vOAP0rAsgb 8wACfREoJm99
YWO0LgKSkErlZpsP3rVzeGbjqa19Y/P5XT+/+qjKYzclOeauzistPqXbs8c2 9RhsPrFsqQeB
ngkgbz1nv56xI2/15IJIIDAHgWLylnJhPsfAau+jRV72mGyhSRnzA3fePDz6 0JHhvGdX5TGb
T6pKypYWn5h4dJ2U/qceg91+SmwpY6YuBFojgLy1ltFljgd5W2beiBoCYwkU k7exAXBeOwRK
ytt9J14cvG1SlUtbSELMMt+qk+t4qK4Uj10eI31zjmGMWKaOmfoQaIkA8tZS Npc7FuRtubkj
cgiMIVBM3lJWVcYE2to5LfLSY7Jv8dMCost9j2aO773jlqC8qXJpixUfsx19 juvcMe1JMary
kMSN6XPsGHQsMTFTBwIQmOerAlK/hoD6l7d97QI84MEcYA60OgfU9fQONTj1 RH/3DG/OEEgh
UHLl7cyxXcHPvKlyaYsVH9/nyVy3E465hTH282Q5wjj1GCTWlEOgRwKsvPWY 9frGzMpbfTkh
IghMSYCVtynpBtpueeVNDzvnM2+njuwe1s6dHtbOundVLm0x8iZ93su1KuY7 JsXjK89deSsx
Bj7nNjZ7nNczAeSt5+zXM3bkrZ5cEAkE5iBQTN7mCJY+6iYgCalUbo7u5OFb g7dNqvKYTVop
k8RH9RGzIjZGfmI+8+br3zyeO4Yxscewpw4EWieAvLWe4WWMD3lbRp6IEgKl CBSTt5QL81LB
L7mdFnmV/J6344f2BOVNlcduvlsK9fmhWw5NsfHd/hh7W6QZb6owTTkGu+3U 2GLzQD0ItEYA
eWsto8scD/K2zLwRNQTGEigmb2MD4DwIuAjcfnBv8DNvqpwNAhCAwCoJIG+r pE/fmgDyxlyA
QF8EislbiytJU06FHnjljPHogX3D4f3+XZWzQQACEFglAeRtlfTpG3ljDkCg TwLF5K1PfIwa
AhCAAAR6JYC89Zr5usbNyltd+SAaCExNoJi85ayyTD3IGtuHV41ZISYIQAAC 8QSQt3hW1JyO
API2HVtahkCNBJC3FWWlB3nrYYwrmj50CwEIVEAAeasgCYSw9aXkbBCAQD8E islbP8gYKQQg
AAEIQGC4ftGs30hjH9Uftm677bZh/cKlrV39bJ5r/gxnCEgEkDeJEOUQaItA MXljlSVtYvTA
K2eM6/fcNEh7GnFqQwACEChLgJW3sjxpbRwB5G0cN86CwFIJFJO3pQIg7joJ KHHb2Lzi3VU5
GwQgAIFVEkDeVkmfvjUB5I25AIG+CBSTt5xVlr6QXxtti7xKfkn3I3fvDMqb Ks/Z+CLqHHqc
CwEIKALIG/OgBgLIWw1ZIAYIzEegmLzNFzI91UpAElKp3BzXg3ftDH5JtyqP 3ZSombs6r6S8
2W3HxkU9CEBg2QSQt2Xnr5XokbdWMsk4IBBHoJi8pVyYx4XWdq0WeUljksrN jD9w583Dow8d
Gc57dlUes/kkrZS82e2UajdmbNSBAARWSwB5Wy1/er9GAHljJkCgLwLF5K0v bIzWRUCSM6nc
bPO+Ey8O3japyqUtJFJmmW/lzHVcWmVD3qSsUA6BdgjMIW+x/8GSepe3/cdO eMCDOcAcaH0O
qOvqHWqQ6on+98Upb7EpF+Yp7bZat0Veekz2bYpaaHS579HM9b133BKUN1Uu bbHyZrajz3Gd
K4mZVC7FSzkEILAsAnPI27KIEO0qCLDytgrq9AmB1RFg5W117JvrWRJSqdwE cubYruBn3lS5
tMXKm+8zca5bIqe+DVMaE+UQgEA9BJC3enLRcyTIW8/ZZ+w9EigmbykX5j2C tsfcIi9pTFK5
yejUkd3D2rnTw9pZ967KpS1G3qTPrGmxM/uyj7HiJmWCcgi0SQB5azOvSxsV 8ra0jBEvBPII
FJO3vDA4uwUCkpxJ5SaDk4dvDd42qcpjNmmlTJI31UfoFkrELSYL1IFAmwSQ tzbzurRRIW9L
yxjxQiCPQDF5S7kwzwu5jbNb5FXye96OH9oTlDdVHrv5bovU54dum5T+sYnv 832xsVEPAhBY
LgHkbbm5ayly5K2lbDIWCMgEismb3BU1IBBP4PaDe4OfeVPlbBCAAARWSQB5 WyV9+tYEkDfm
AgT6IlBM3lpcSZpyKvTAK2eMRw/sGw7v9++qnA0CEIDAKgkgb6ukT9/IG3MA An0SKCZvfeJj
1BCAAAQg0CsB5K3XzNc1blbe6soH0UBgagLF5C1nlWXqQdbYPrxqzAoxQQAC EIgngLzFs6Lm
dASQt+nY0jIEaiSAvK0oKz3IW8kxlmxrRSmnWwhAoDECyFtjCV3ocJC3hSaO sCEwkkAxeRvZ
P6dBAAIQgAAEFkkAeVtk2poLGnlrLqUMCAJBAsXkjZWRtJnWA6+SYyzZVlqm qA0BCEDATQB5
Y2bUQAB5qyELxACB+QgUk7f5QqYnCEAAAhCAwOoJIG+rzwERDAPyxiyAQF8E iskbKyNpE6cH
XiXHmNPW+g/vHEK7ytz3/n/+TVoCqQ0BCHRPAHnrfgpUAQB5qyINBAGB2QgU k7fZIqYjCCQS
eMvJm4eNzSvO/eMfeWSrNSVvu/9f/zSx5WHYsWNH8By7XKofasx1rjqm99Tg pVik8tT+qA+B
1gggb61ldJnjQd6WmTeihsBYAsXkLWdlZGzwSz6vB14lx5jT1htfd8sLxO27 f/Rdg9pfdvz+
4eU/cGJL3sYKXIpw5QiRJII5bbvGULq9Jb9eiR0CLgJzyJt+k+bx8tbtgeww YA4wB5gD1+aA
ujbeoZ+sX7g0qJ0NAi0QOHX01uGZjae29o3N7ftHf+Xt0StvrlUuLThmmSk9 9jm+NlyrZzHn
mvnxyZZ0PDb2FuYCY4BASQJzyFvJeGmrTQKsvLWZV0YFAR8BVt5WNDdyVpJW FHJytyXHqNuK
fTSDfd1r/8nwg//Hbc5dlalN+sybb9XLlDeXSKWulvnaU22HVsLGlKXGnjwB OAECjRNA3hpP
8EKGh7wtJFGECYFCBIrJW6F4aAYCVRKwV6ds8ZHkTg/KVc+18uVbiXPBGXt7 I/JW5VQjqAUR
QN4WlKyGQ0XeGk4uQ4OAg0AxeSu5ytJDpnrgVesY/x+33Zk8xWJuPSyx8mYH ZkqcK4ax4mau
5MWKZzI0ToBA4wSQt8YTvJDhIW8LSRRhQqAQgWLyVigemoHApASUuJWQt5Ir by7pGyOCPnCl
xHPSxNA4BBZIAHlbYNIaDBl5azCpDAkCAQLF5K3WVZZas98Dr1rHOEbe9EqV fTujdOuheZ6e
i642Yo7Zbflu5bTn/Fh5c8Ve6+uJuCCwCgLI2yqo06dNAHljTkCgLwLF5K0v bIx2yQTGytuS
x0zsEIBAeQLIW3mmtJhOAHlLZ8YZEFgygWLyVusqS63J6YFXjWPUt00icLW+ MogLAsshgLwt
J1ctR4q8tZxdxgaBFxIoJm/AhQAEIAABCPREAHnrKdv1jhV5qzc3RAaBKQgU k7caV1mmAFaq
zR549TDGUvOBdiAAgeURQN6Wl7MWI0beWswqY4KAnwDytqLZ0YPY9DDGFU0f uoUABCoggLxV
kARCGJA3JgEE+iJQTN76wsZoIQABCECgdwLIW+8zoI7xI2915IEoIDAXgWLy xipLWsp64JUz
xvV7bhqkPY04tSEAAQiUJYC8leVJa+MIIG/juHEWBJZKoJi8LRUAcddJQInb xuYV767K2SAA
AQiskgDytkr69K0JIG/MBQj0RaCYvOWssvSF/NpoW+SlxiTtsbl+5O6dQXlT 5Tmb74urc9rk
XAhAoC8CyFtf+a51tMhbrZkhLghMQ6CYvE0THq0uiYAkpFK5OdYH79o5PLPx 1Na+sfn8rp9f
fVTlsZsSNXNX55WUN7vt2LioBwEILJvAHPKm36R5vLz1jznYYcAcYA4wB67N AXVdvUM/Wb9w
aVB7ypZyYZ7Sbqt1W+Rlj8kWpJQxP3DnzcOjDx0Zznt2VR6z+SStlLzZ7ZRq N2Zs1IEABFZL
YA55W+0I6X0JBFh5W0KWiBEC5Qiw8laOZfctlZS3+068OHjbpCqXtpBImWW+ lTPXcWmVDXmT
skI5BNohgLy1k8sljwR5W3L2iB0C6QSKyVvKqkp6mO2d0SIvPSb7NkUtNLrc 92hm+d47bgnK
myqXtlh5M9vR57jOldpD3KSMUA6Btgggb23lc6mjQd6WmjnihsA4AsXkbVz3 nNUSgZIrb2eO
7Qp+5k2VS5skW/p832fiXLdESoImlUsxUw4BCCyHAPK2nFy1HCny1nJ2GRsE XkigmLy1uJI0
5YRpkVdJeTt1ZPewdu70sHbWvatyaYuRN+kza1rs7NW5qT9LJ42NcghAYPUE kLfV54AIhq1/
XMAGAQj0Q6CYvPWDjJH6CEhCKpWb7Z48fGvwtklVHrNJkiXJm+ojdAtlzPkx cVIHAhBYHgHk
bXk5azFi5K3FrDImCPgJFJO3lAtzEsL3vElz4PihPUF5U+Wxm++2SH1+6LbJ sf/YJDY26kEA
AsslgLwtN3ctRY68tZRNxgIBmUAxeZO7ogYE4gncfnBv8DNvqpwNAhCAwCoJ IG+rpE/fmgDy
xlyAQF8EiskbK29pE6cHXjljPHpg33B4v39X5WwQgAAEVkkAeVslffpG3pgD EOiTQDF56xMf
o4YABCAAgV4JIG+9Zr6ucbPyVlc+iAYCUxMoJm85qyxTD7LG9uFVY1aICQIQ gEA8AeQtnhU1
pyOAvE3HlpYhUCMB5G1FWelB3noY44qmD91CAAIVEEDeKkgCIfBVAcwBCHRG oJi8dcaN4UIA
AhCAQOcEkLfOJ0Alw2flrZJEEAYEZiJQTN5YZUnLWA+8csa4fs9Ng7SnEac2 BCAAgbIEkLey
PGltHAHkbRw3zoLAUgkUk7elAiDuOgkocdvYvOLdVTkbBCAAgVUSQN5WSZ++ NQHkjbkAgb4I
FJO3nFWWvpBfG22LvNSYpD0214/cvTMob6qcDQIQgMAqCcwhb/pNmsfLW5/t YocBc4A5wBy4
NgfUNfcO/WT9wqVB7WwQSCEgCalUbvb14F07g1/Srcpjth07dgx6j6kfW8ds Vz2P2WLrxbRF
HQhAYPUE5pC31Y+SCGonwMpb7RkiPgiUJcDKW1me0a2liEx0oyuuaI/JlpWU MT9w583Dow8d
Gc57dlWespUWJ7u9mPZj6qSMiboQgMBqCSBvq+VP79cIIG/MBAj0RaCYvPWF jdG6CJSUt/tO
vDh426QqT9lMcXKtxoVkLKa+iiWmD3sVcKqVwRQ21IUABMYRQN7GceOssgSQ t7I8aQ0CtRMo
Jm8pqyq1Q5kjvhZ56THZtxRqqdHlvkeT+7133BKUN1WesvlWvfTx2JU0X31b 3szYYvtgZS4l
o9SFwOoJIG+rzwERsPLGHIBAbwSKyVtv4BjvCwmUXHk7c2xX8DNvqjxl862K 2cddEub6fJtL
tKQ+XII45rNzKeOmLgQgMB0B5G06trQcT4CVt3hW1IRACwSKyVuLK0lTJrhF XiXl7dSR3cPa
udPD2ln3rspTtpjVL1cd34pcSN5iz2GlLSWD1IVAfQSQt/py0mNEyFuPWWfM PRMoJm89Q2Ts
1whIQiqVmxxPHr41eNukKk/ZYuRNtSfdPhnTzlh5Q+ZSMkpdCKyeAPK2+hwQ AbdNMgcg0BuB
YvKWcmHeG2TXeFvkJX3HW8qYjx/aE5Q3VS5tvn8GErpV0beiZrcl3e7oK9fH dey+GKWxUQ4B
CKyeAPK2+hwQAfLGHIBAbwSKyVtv4BjvtARuP7g3+Jk3Vc4GAQhAYJUEkLdV 0qdvTYDbJpkL
EOiLQDF5S1lV6Quxe7TwCs+Cowf2DYf3+3dVzgYBCEBglQSQt1XSp2/kjTkA gT4JFJO3PvEx
aghAAAIQ6JUA8tZr5usaNytvdeWDaCAwNYFi8sZKUlqq4JXGi9oQgAAEaiOA vNWWkT7jQd76
zDuj7pcA8rai3CNvKwJPtxCAAAQKEUDeCoGkmSwCyFsWPk6GwOIIFJO3xY2c gCEAAQhAAAIZ
BJC3DHicWowA8lYMJQ1BYBEEiskbK0lp+YZXGi9qQwACEKiNAPJWW0b6jAd5 6zPvjLpfAsXk
rV+Eqx/5v/yH/3b1QRABBCAAgc4IzCFv+k2ax8sDDGDAHGAOMAduzAG1ELRD AVFP1i9c2tpT
NlaSwrRKfoH1+Vd/eFh/5WPX99d919ltP6tytnYJuL5IvN3RMjII1EtgDnmr d/REVgsBVt5q
yQRxQGAeAqy8zcN5S4pDm1RunvvIKz40PHbPk8Pj5z4+vOfIR4f1Vz227WdV Lm1KAOzdPEeX
Se2o8lA7dpux7el2x5xv9yGNNSamUnViWYX6Q95KZYN2IJBHAHnL48fZZQgg b2U40goElkKg
mLylyMdS4JSM0+ZjX4Cn8Hvryz+4JW5Pvu0zw8W7Pja88aXnt/2syqVNEoBU eSshWS7pksaR
Ui6NOaWtsXXtGMbENOacsfFyHgQg4CeAvDE7aiCAvNWQBWKAwHwEisnbfCEv s6eS8nb/y969
teKmxO3CgY8MR245te1nVS5tIQEwy2JEwSck+rjr0ZRDWxTN+nY9Na6QAJkr W5IMhuL2tZN6
PCWG2LZ9+Yk53z43RdKlOUU5BHojgLz1lvE6x4u81ZkXooLAVASKyVvKytFU g6m5Xc3Hdwuf
Lvc96rGpf06iPuOmVtvUrsRN7/qYKpf+iUno9r2S8uZqKyQfppxJUqiZ2HJo H0/9Obff0DyM
XXnzjSnEx+xXYhIbR82vKWKDwKoJIG+rzgD9KwLIG/MAAn0RKCZvfWFLH23J lTclaeZn3pS8
mT+rcmkrvfLmWvWJkaCQ3EkrbKbI6OexUhoSv9gVOXuFUGLuitEWLpujK0++ 1TLX2FPHEjMG
6kAAAtcIIG/MhBoIIG81ZIEYIDAfgWLyxspbOGkl5e31L3k4+Jk3VS5tPnlz rQyGRM8WKFtG
XD/nrryZfaasEvpEyCWBUtwuvjG3IIa4x/bpWlWLEWUfN2muUA4BCLgJIG/M jBoIIG81ZIEY
IDAfgWLyNl/Iy+xJklup3Bz1qX33b/uMm1ppMz8Dp8qlLVYiQnKm+4htS5IO u1y6tS+33Bd/
qgiFhNXOQw4rV7wupiFJk+pL84ZyCEDgBgHkjdlQAwHkrYYsEAME5iNQTN5S 5GO+4dXTU8nv
eXvHax4flKDpXX3GzfxZlUuba4XNJ2qrWnnT8aQIh33bYYxYuWTN147reKjP WHkzx2qv4Nnt
x94KacpebtzSfKIcAj0SQN56zHp9Y0be6ssJEUFgSgLF5G3KIGk7TED65yTw 8xMI3UrZIjdJ
xFscM2OCwFQEkLepyNJuCgHkLYUWdSGwfALF5I2Vt+VPBmkErtW6pcvAVPJW E6uUlUFpDlAO
AQjcIIC8MRtqIIC81ZAFYoDAfASKydt8IdMTBCAAAQhAYPUEkLfV54AI+KoA 5gAEeiNQTN5Y
eett6jBeCEAAAn0TQN76zn8to2flrZZMEAcE5iGAvM3DmV4gAAEIQKAxAshb Ywld6HCQt4Um
jrAhMJJAMXkb2f/woZ/aG9zHtst5EIAABCAAgSkJIG9T0qXtWALIWywp6kGg DQLF5G3sbZNK
3jaf/bZz//TFf7cldmwQgAAEIACB2gjMIW/6TZrHywMMYMAcYA4wB27MAeVe OxQQ9WT9wqWt
fY7t/T/5T4ZnNp9z7n/4kXuGzyBwc6SBPiAAAQhAIJHAHPKWGBLVOyTAyluH SWfIXRMYvfJW
6kunP/1bbx++tfHcoL6rTD2a+9OXf3JQAvfpi4eG97zptlGJGvOv7O0vSR7V ceRJUnxSeWQ3
3mpTtx8TXw0xhOKccz6sgpfE3/el4DGxUgcCLRNA3lrO7nLGhrwtJ1dECoES BLLkLRRAzG2U
51/94WH9lY9t7a/7rrPXn6vj3/jWc9f3//bfnxsu/PhLRo239gvT1PhiIUjt 6nZi68X2O6ae
jqGGWOz4e4hJGqNP3lzfZTcm/5wDgaUSQN6Wmrm24kbe2sono4GARGCl8vbW l39wePJtnxku
3vWx4Y0vPX/9uTr+9avydn3/5nPDz73hn0pjcZaPvTAd1dmIk1LjG9FF8BSp /9L9udqrIQbf
OGuMrXRMUnsheZtjftAHBGolgLzVmpm+4kLe+so3o4XASuXt/pe9e0vcLhz4 yHDkllPXn6vj
X/nGs9v29bMvFSXEXAnQlc0LT1+5eVtcTB3Vtr1aZJ/nutUudPuZvYphx596 rhmfa0zmGMy+
7Lhdq2K+WO0Ehfq1mdtMY8/V57l4x8Qj5c0Xh9l2bqwSY7svX758c046HvMa 8b2eQtLrmkup
8yv0op+TO28VEHARQN6YFzUQQN5qyAIxQGA+AtnyZl/I6wtBfduk71F9xk3d KqlW3JS4qV09
V7s6rsq/9PXN6/uDa98typvrIteWnhQp8gmOKQzSRa19YRy6EA/F75M36bgk fa74XSIl1XOJ
Umw+XCKceq4vPiluX35cQuWagBJ/X77HMpbitduN4egbq08qTaYugXK95kKc Yl8jsSxT5uKY
vuf79UxPtRNA3mrPUB/xIW995JlRQkATyJY3H8qYz7y9/iUPO2+bVMe/+NXN 6/tfXH3+5h/5
Z8GsxVxE26IZkrOUi367ndAF4RLlLeai2XXBHMPbJRuxF/r6XFc/Y+Jx5c0n /z6BCUlfzByV
xjS1vEk5i5nbqfJmz69S+RzzGo7pm7cPCJhvoOp56r+uVu+Pt9122/X/7Kx+ Ntswf4Y2BCQC
yJtEiHIItEVgpfJ2at/912+VVCtu+hZKdfzPvry5bf+JH/7nWfKWcuEcIytj V7R6kjdXwkIX
9tIKkC1MLvn2TRKfhEkyFCNvqeO0pSI0l1wS6pKSGPGU+I5lFIpxjEDF/IqN iXWqvmPio04f
BFh56yPPtY8Seas9Q8QHgbIEVipv73jN44MSNbWrWyX1c3X881/a2Lb/2A/9 i8XLW6zwmVKS
esFt14/ts4TchlZlYlakpLG6xLfk+GIEyBbGWG4u0YwdrySYvphiY5PiiOk/ 9AePqcfuer3k
/gEm5Q8DZX8l09qSCCBvS8pWu7Eib+3mlpFBwEUgS96k73qLQf5rj79v+JO/ 2tj6jJt6dO1/
/Jcbw5k7Xy7Km3nLk+uv7r5bovRx3wWb1G7ogj72wjcUmzkWXyz28ZQLclf7 Ln4xcdgXzSZb
Xz8u4ZTGGduPVE/Kj2uFxyVFMePU88Su6+tDqifF7uvPPm634+s3NG7XObHH 7Be2K/c+AZyD
e8zvMer0SQB56zPvtY0aeastI8QDgWkJjJa3UmGdOvE9w+f+4hlx/5Hj3yPK W6mY5mjHtyqS
27dLBFxtxtaT4inVji1ZUr89lk/BOoXjqvtPiZW6EJiDAPI2B2X6kAggbxIh yiHQFoGVy9vd
r/ve4e7jan/F8EOve8X15zd+vnpM1blaFtqWdmFZUt58KxVT8RrTX8rLZmm5 TBlbTt1Vc1l1
/znsOBcCUxBA3qagSpupBJC3VGLUh8CyCaxc3paNj+ghAAEIQKBXAshbr5mv a9zIW135IBoI
TE0AeZuaMO1DAAIQgECTBJC3JtO6uEEhb4tLGQFDIItAlfIW8x1xWaPmZAhA AAIQgEAmAeQt
EyCnFyGAvBXBSCMQWAyBKuVtMfQIFAIQgAAEuiUwh7ylfgE49S8nf2k6zGDG HGAOLHEOqMWu
HSpw9WT9wqWtfVUbK2+rIk+/EIAABCAQS2AOeYuNhXr9EmDlrd/cM/I+CTS/ 8qa+P44NAhCA
AAQgUJoA8laaKO2NIYC8jaHGORBYLoEq5E36su+Ulbjzr/7wsP7Kx67vr/uu s9t+VuVsEIAA
BCAAgVwCyFsuQc4vQQB5K0GRNiCwHALVyFsIWYq8PfKKDw2P3fPk8Pi5jw/v OfLRYf1Vj237
WZWzQQACEIAABHIJIG+5BDm/BAHkrQRF2oDAcgg0J29vffkHt8Ttybd9Zrh4 18eGN770/Laf
VTkbBCAAAQhAIJcA8pZLkPNLEEDeSlCkDQgsh0Bz8nb/y969teKmxO3CgY8M R245te1nVR6z
7dixY9C7Wd913HdMnafK9OZrMyYe6kAAAhCAQF0EkLe68tFrNMhbr5ln3L0S qEreTLkxxUnf
Nul71MlT/5xEfcZNrbapXYmb3vUxVS79ExNTuEwBs4/bcmbXtcXNlsBeJx3j hgAEINACAeSt
hSwufwzI2/JzyAggkEKgKnnzBZ7ymTclaeZn3pS8mT+rcmnzSWSqvNmyZrcr xUE5BCAAAQjU
SwB5qzc3PUWGvPWUbcYKgeH6d1mu9HveJDmTys1Evv4lDwc/86bKpc0laeqc XHmT+qUcAhCA
AASWQwB5W06uWo4UeWs5u4wNAi8k0NzK26l992/7jJtaaTM/A6fKpa3UbZNm P742pVgohwAE
IACBOgkgb3XmpbeokLfeMs54eydQjbxJ3/UWm6h3vObxQQma3tVn3MyfVXnM VuofltgC5/on
KDHxUAcCEIAABOoigLzVlY9eo0Hees084+6VQBXyNiV86Z+TTNk3bUMAAhCA QLsEkLd2c7uk
kSFvS8oWsUIgn0Dz8paPiBYgAAEIQAACLySAvDEraiCAvNWQBWKAwHwEkLf5 WNMTBCAAAQg0
RAB5ayiZCx4K8rbg5BE6BEYQQN5GQOMUCEAAAhCAAPLGHKiBAPJWQxaIAQLz EWhe3lK+ZmA+
7PQEAQhAAAJLJzCHvOk3aR4vX/9uI1jAgjnAHGAOXB5W+j1vS38DJ34IQAAC EOiPwBzy1h9V
RpxKgJW3VGLUh8CyCbDyFsjf+j03DdK+7PQTPQQgAAEIjCWAvI0lx3klCSBv JWnSFgTqJ9C8
vOWkQInbxuYV767K2SAAAQhAoE8CyFufea9t1MhbbRkhHghMS6A5eZO+7Dvl M3CP3L0zKG+q
vKZNfQE42zwEYD0PZ3qBQM0EkLeas9NPbMhbP7lmpBBQBJqUt1BqU+Ttwbt2 Ds9sPLW1b2w+
v+vnVx9VubSpi3x7N8/RZfax0M92n1okUoUitb40Vqk8xMLFqGR8JdtS4zSZ h/IrMdHlpeOL
7Zd6EIDAeALI23h2nFmOAPJWjiUtQWAJBJqXN/uiOEXeHrjz5uHRh44M5z27 Kpc26aK8hLyN
FQApNmlsqf36+ks9HhtXigCntjlWmH39lMpF6jioDwEIjCeAvI1nx5nlCCBv 5VjSEgSWQAB5
C2TpvhMvDt42qcqlLXRRbpbZz02pM1d2VH+2OPhWgXxy5apv1nUJZcw4JQFJ lbTYcbvG6TrX
ZuqSO5eU2W25cuDi4zpPn2sz9o3VHltsfFK+KIcABPIJIG/5DGkhnwDyls+Q FiCwJALNypt9
K5u+6NUrb75HM3n33nFLUN5UubSFbqkLyZtLLGzB8l3Y5x73SZ80VlNMJJmx RS4kSNK4pfGa
suUbmy20vrG6xNmVY9f4fExy4ovtJyZ31IEABNIIIG9pvKg9DQHkbRqutAqB Wgk0K2++i/SU
2ybPHNsV/MybKpe2sStvkry5yn0X8inHQ7JpytmYVTbpHEnCJFFxrUpJsib1 aY/ZJW8xomqL
euxKmxSf748U0rykHAIQyCeAvOUzpIV8AshbPkNagMCSCCBvgWydOrJ7WDt3 elg7695VubT5
hMV10e2Tj7HSIrUntSuNLSQtvrKYNqW4JSFzMZfGmtpnSBS18MUwGNuvj0EM X+pAAAJlCCBv
ZTjSSh4B5C2PH2dDYGkEmpc3OyEpK28nD98avG1SlUtbSN7sc1Mv5O0L+JQV NpdgSIITGquW
UamOxMuMS4ondrwpY43tM1XepNym9isJbAxn6kAAAnkEkLc8fpxdhgDyVoYj rUBgKQSalDfp
u95ik3P80J6gvKlyafPd1iatDtkyZP4ckhb7djzzIt9V5uvHJ52u8cbWDbGQ 4nYJmD4WGpcZ
W2isIRmz4w4JpslHGlMox76x+eZNjDxLc5VyCEAgjQDylsaL2tMQQN6m4Uqr EKiVQHPyVhL0
7Qf3Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5S7lN0kZ99MC+ 4fB+/67K2SAA
AQhAoE8CyFufea9t1MhbbRkhHghMS6B5eZsWH61DAAIQgECvBJC3XjNf17iR t7ryQTQQmJoA
8jY1YdqHAAQgAIEmCcwhb/pNmsfLAwxgwBxgDjAHbswBdXfhDgVEPVm/cGlr b2HLuW2yhfEz
BghAAAIQmIbAHPI2TeS02hIBVt5ayiZjgYBMgJU3mRE1IAABCEAAAi8ggLwx KWoggLzVkAVi
gMB8BJqXt5yVt/V7bhqkfb5U0RMEIAABCNREAHmrKRv9xoK89Zt7Rt4ngebl LSetStw2Nq94
d1XOBgEIQAACfRJA3vrMe22jRt5qywjxQGBaAs3Jm/QF3SkrcY/cvTMob6qc bXkEpC8Vzy1f
HhEihgAExhBA3sZQ45zSBJC30kRpDwJ1E2hS3kLIU+Ttwbt2Br+kW5VLmxIB ezfP0WVSO2PK
JQnRbdr1Ys8bE1PMOT5mLlZj+Enj0+WhOGLGUaqOFG+pfmgHAhBII4C8pfGi 9jQEkLdpuNIq
BGol0Ly82Re+KfL2wJ03D48+dGQ479lVubRJF95j5EPq0ydlvvOkGGP7k+rF 9uOrtwp5c40p
dhwSj9jyufuLjYt6EOidAPLW+wyoY/zIWx15IAoIzEUAeQuQvu/Ei4O3Tapy aQtdeJtl9nNz
1ceUMddxVS7Vd7XhO+aLJSaOGB6SjITkTY/V9ejjYB+PGZ/Zvj2mmPNN0QxJ Z2reJb6UQwAC
8xFA3uZjTU9+AsgbswMCfRFoVt58t7zplTffo5n+e++4JShvqlza7DjM+iF5 c9Wzpca8vS+m
vk9CctuVZMzFKLTi6GNmj9f3symZLgmL5RYbR6g/V45zeUtzjnIIQGAeAsjb PJzpJUwAeWOG
QKAvAs3Km31BrX9OuW3yzLFdwc+8qXJpG7vyFiNjsRJit2Wv0uXKhGuMvhVC n0D6pDZFdseM
wyVoPq4uSQudb4uj2a50nnnuGDmW5iXlEIBAPgHkLZ8hLeQTQN7yGdICBJZE AHkLZOvUkd3D
2rnTw9pZ967Kpc134e1aGUyVsbH1XRJSQhYlFi6JdJ0TYuaS8rEcpH5yy0Py FjNuSSJTeFMX
AhAoTwB5K8+UFtMJIG/pzDgDAksm0Ly82clJWXk7efjW4G2TqlzaJAEoIU2p K06rlLfQ7ZIu
MXPxsZmXkjfpNswx3LhtUnqFUA6B5RJA3pabu5YiR95ayiZjgYBMoEl5k77r TcZyrcbxQ3uC
8qbKpc21wqbO8d1q6CqT5ESf4xIj+5jrdj3zfLt/1+2PPlmMYSHVscdixh8j wq54XW2aIuZi
FBuHxMclb758hbjGSG8MW+pAAALlCCBv5VjS0ngCyNt4dpwJgSUSaE7eSibh 9oN7g595U+Vs
EIAABCDQJwHkrc+81zZq5K22jBAPBKYl0Ly8pdwmaaM+emDfcHi/f1flbBCA AAQg0CcB5K3P
vNc2auSttowQDwSmJdC8vE2Lj9YhAAEIQKBXAnPIm36T5vHyAAMYMAeYA8yB G3NALVDtUEDU
k/ULl7Z2NghAAAIQgAAE3ATmkDfYQ0AiwMqbRIhyCLRFoPmVt5zbJttKNaOB AAQgAIGSBJC3
kjRpaywB5G0sOc6DwDIJNC9vy0wLUUMAAhCAQO0EkLfaM9RHfMhbH3lmlBDQ BJqXt5yVt/V7
bhqknakEAQhAAAJ9EkDe+sx7baNG3mrLCPFAYFoCzctbDj4lbhubV7y7KmeD AAQgAIE+CSBv
fea9tlEjb7VlhHggMC2B5uRN+oLulJW4R+7eGZQ3VT7F5vsy6in6mqrNKcbA F1VPlS3ahQAE
xhBA3sZQ45zSBJC30kRpDwJ1E2hS3kLIU+Ttwbt2Br+kW5VLmxYO89E8xy5X ZVOIjxRnqHyV
Y9AsbCa1Mcrhy7kQgMAyCSBvy8xba1Ejb61llPFAIEygeXmzL/JT5O2BO28e Hn3oyHDes6ty
aQtJhq9sLjGJ7aeGMcTGKuWDcghAAAKlCCBvpUjSTg4B5C2HHudCYHkEkLdA zu478eLgbZOq
XNrGCJp5TsyKnY7BVzdmVU2q4yqPlbqcMZgrb+ZtkxIj34qdlC/KIQABCMQS QN5iSVFvSgLI
25R0aRsC9RFoVt58t/rplTffo5mie++4JShvqlzaXLdFqnNixcdsPyQkuStT oc+TrXIM0m2T
vtspQ+ORckY5BCAAgRgCyFsMJepMTQB5m5ow7UOgLgLNypvGnHPb5Jlju4Kf eVPl0lZy5c1e
hbLFThLCGKFxtbHKMcTIm0suc2VWyivlEIAABJA35kANBJC3GrJADBCYjwDy FmB96sjuYe3c
6WHtrHtX5dKWIz6+VSVTTF11xoiLtPLmGqcki+qc3DHEyFtqbFLOKIcABCAQ QwB5i6FEnakJ
IG9TE6Z9CNRFoHl5s3Gn/MOSk4dvDd42qcqlLUZw7DYkYTHrp6yU+SRHkr1V jkFiEbptUsoN
5RCAAARyCCBvOfQ4txQB5K0USdqBwDIINClv0ne9xabm+KE9QXlT5dJm39Ln WykzV77MOr5b
Au2VMrOeFJMul6TNrOeKw1eujpcagyRvui8Xj1gO1IMABCAwhgDyNoYa55Qm gLyVJkp7EKib
QHPyVhL37Qf3Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5S7lN 0kZ99MC+4fB+
/67K2SAAAQhAoE8Cc8ibfpPm8fIAAxgwB5gDzIEbc0A5zg4FRD1Zv3Bpa2eD AAQgAAEIQMBN
YA55gz0EJAKsvEmEKIdAWwSaX3lrK12MBgIQgAAEaiGAvNWSib7jQN76zj+j 749A8/KWc9tk
f9OBEUMAAhCAQCwB5C2WFPWmJIC8TUmXtiFQH4Hm5a0+5EQEAQhAAAItEEDe Wsji8seAvC0/
h4wAAikEmpe3nJW39XtuGqQ9BTZ1IQABCECgHQLIWzu5XPJIkLclZ4/YIZBO oHl5S0dy4wwl
bhubV7y7KmeDAAQgAIE+CSBvfea9tlEjb7VlhHggMC2B5uRN+oLulJW4R+7e GZQ3VT7FFvvl
2Sl9219inXJuy3Ul1lJ5y2wYGwQgECaAvDFDaiCAvNWQBWKAwHwEmpS3EL4U eXvwrp3BL+lW
5dKmpcl8NM+xy1VZKWHQ7djtlWpfGrtd7mPhEsu5YjQZTZmLWFZzjTs2HupB AAJ+Asgbs6MG
AshbDVkgBgjMR6B5ebMvhlPk7YE7bx4efejIcN6zq3JpC12M+8pKX8CXbs8l ZRKHkJTWIm+u
MUzNbizLGN7UgQAEpiWAvE3Ll9bjCCBvcZyoBYFWCCBvgUzed+LFwdsmVbm0 jRE085yYFTsd
g13XtapkS5Srfd+KXWisMbdlSizscfvGpcdg9ukTQOm4NFYpFy7mrpVOOw7X Kp9rXNL8ohwC
EFgdAeRtdezp+QYB5I3ZAIG+CDQrb75b9PTKm+/RTP+9d9wSlDdVLm2hi3Tf uSmSYwqO3Z5P
TGKOj11xCkmcxMInb+a4XLG7znMJlC2u5s8psdnnuXIQw1galzS3KIcABFZL AHlbLX96v0YA
eWMmQKAvAs3Km09qUm6bPHNsV/Azb6pc2iQRc53vW+2xV9Lsi/9cYZFWobS0 jF1li2HhkzPX
CpckTS4hi2Vkt+37Y4BPOO1cheL3yaA0tyiHAARWSwB5Wy1/ekfemAMQ6JEA 8hbI+qkju4e1
c6eHtbPuXZVLW4yw2G1IqzamWLhkxD5/rLBIY/OJZ+qYQytnMbHHrLz5ZF4S 1thyU8BiZCxm
XGP4cw4EIDAfAeRtPtb05CfAyhuzAwJ9EWhe3ux0pqy8nTx8a/C2SVUubT6R sS/2zXZi5c3X
xlh5k0QlNNaxq3GuMZhtxUhOjLxJTCXhXHUc0jyjHAIQmJ8A8jY/c3p8IQHk jVkBgb4INClv
0ne9xab4+KE9QXlT5dLmu91Onyfd2ucrt2XJvi3PlCKfeOg6rrakcblkUzrH xyK0emjH6JIw
l7z5xhZqLyUXZv5inkuM7TGEpF/iTDkEIDAPAeRtHs70EiaAvDFDINAXgebk rWT6bj+4N/iZ
N1XOBgEIQAACfRKYQ970mzSPl7f+MQc7DJgDzAHmwLU5oBardugn6xcuDWpv YUu5TdIe79ED
+4bD+/27KmeDAAQgAIE+Ccwhb32SZdQpBFh5S6FFXQgsnwArb8vPISOAAAQg AIEVEEDeVgCd
Ll9AAHljUkCgLwLIW1/5ZrQQgAAEIFCIAPJWCCTNZBFA3rLwcTIEFkegeXnL uW1ycdkkYAhA
AAIQmI0A8jYbajoKEEDemB4Q6ItA8/LWVzoZLQQgAAEIzEUAeZuLNP2ECCBv zA8I9EWgeXnL
WXlbv+emQdr7mi6MFgIQgAAENAHkjblQAwHkrYYsEAME5iPQvLzloFTitrF5 xburcjYIQAAC
EOiTAPLWZ95rGzXyVltGiAcC0xJoTt6kL+hOWYl75O6dQXlT5WzzEpjiy6vt L9Ced0T0BgEI
LJUA8rbUzLUVN/LWVj4ZDQQkAk3KW2jQKfL24F07g1/SrcqlTYuB+ajOsY9L 7ehzYuuNaT+m
7ZJ1fGx0H64xlJI33Y7dXqn2S3KiLQhAoE4CyFudeektKuStt4wz3t4JNC9v 9sV4irw9cOfN
w6MPHRnOe3ZVLm0+GRgjDalikVpfGktseWy/oXqx3GJj8tWLjTW3H86HAATa I4C8tZfTJY4I
eVti1ogZAuMJIG8BdvedeHHwtklVLm0pEmLWtVfqVD+xx3RMkiCaq0+utn19 SmM2zwvVTWHj
GlNKzK6VT9f4YnKgz4vhQB0IQKBdAshbu7ld0siQtyVli1ghkE+gWXnz3ZKn V958jybSe++4
JShvqlzafLcvusRFkhlplShW1mwR8p0ntSeNXZK4FDY+IZXG4hMt6bbJEBMp DzFcqAMBCCyf
APK2/By2MALkrYUsMgYIxBNoVt58F/spt02eObYr+Jk3VS5tkpCZ5/tWfXyi YcqRFiFfeyHJ
kUTFt8Jl9x9iMUZWXe3FMHKNJ1VQffKPuEkznnII9EMAeesn1zWPFHmrOTvE BoHyBJC3ANNT
R3YPa+dOD2tn3bsql7Yx8pYqGj5RDQmTLUEu6SshKi6p9MUrHdeyaD6Gxh6S uNSVt5jYpLlA
OQQg0BYB5K2tfC51NMjbUjNH3BAYR6B5ebOxpKy8nTx8a/C2SVUubbHyNkam pNsax/SdIkih
sYekLUaEpNilsbsEzzW2VFEuIbTSnKEcAhBYBgHkbRl5aj1K5K31DDM+CGwn 0KS8Sd/1FjsJ
jh/aE5Q3VS5todvvYm9HdN0qaAqQrx1JgGLbiBExk0Os4PjYhOKKvW3SV88W x5AEurjGjk2a
F5RDAALLJzCHvOk3aR4vDzCAAXOAOcAcuDEHlO/sUEDUk/ULl7b23rfbD+4N fuZNlS9tC91K
ubSxEC8EIACBVRKYQ95WOT76XgYBVt6WkSeihEApAs2tvNlgUm6TtM89emDf cHi/f1flS9uQ
t6VljHghAIFaCSBvtWamr7iQt77yzWgh0Ly8kWIIQAACEIDAFASQtymo0mYq AeQtlRj1IbBs
AsjbsvNH9BCAAAQgsCICyNuKwNPtNgLIGxMCAn0RaF7ecm6b7GsqMFoIQAAC EEghgLyl0KLu
VASQt6nI0i4E6iTQvLzViZ2oIAABCEBg6QSQt6VnsI34kbc28sgoIBBLoHl5 y1l5W7/npkHa
Y0FTDwIQgAAE2iKAvLWVz6WOBnlbauaIGwLjCDQvb+OwXDtLidvG5hXvrsrZ IAABCECgTwLI
W595r23UyFttGSEeCExLoDl5k76gO2Ul7pG7dwblTZWzQQACEIBAnwSQtz7z XtuokbfaMkI8
EJiWQJPyFkKWIm8P3rUz+CXdqlza1Peq2bs6x3dcam9V5bHjiInP9V1zrvOW xihm7NSBAATa
IYC8tZPLJY8EeVty9ogdAukEmpc3WxRS5O2BO28eHn3oyHDes6tyafOJSqzA SO3nlsfGETuO
mPZi6pjjSq2fy4TzIQABCMQQQN5iKFFnagLI29SEaR8CdRFA3gL5uO/Ei4O3 TapyaYuVHt2O
a5VOldnt6J/N+rpequzoNkJjSRmHWdeOz4xRqmcyCcmci4WLV8w4pXxSDgEI QEATQN6YCzUQ
QN5qyAIxQGA+As3Km++WO73y5ns00d97xy1BeVPl0haSMZ/YuEQlJG8uyUkV OEn8YqXSJZp2
fFJsvrFKMhfDKBSflEvKIQABCJgEkDfmQw0EkLcaskAMEJiPQLPy5rvQT7lt 8syxXcHPvKly
aUtZsXKJhbmqJEmdvZJlx+aSRVf8rphTxuFbUfONxRRH1+pYKJ7QmH0rcpI8 SjmlHAIQgIAi
gLwxD2oggLzVkAVigMB8BJC3AOtTR3YPa+dOD2tn3bsql7YU6Zla3mJizY3X HMPYlTBp5c3X
R2x/EgfKIQABCMQQQN5iKFFnagLI29SEaR8CdRFoXt5s3CkrbycP3xq8bVKV S1uuDJVcefPF
GvNZsNhxxK6EmbFIsjam7xiJlHJHOQQgAIEQgTnkTb9J83h5a6WTHQbMAeYA c+DaHFBOs0M/
Wb9waVD7EreS3/N2/NCeoLypcmmzPysm3coXEhnX5858shR7a2BKPV//odsx XedosZJur9Rs
U+TNF0soRimHlEMAAhBwEZhD3iAPAYkAK28SIcoh0BaB5lbeSqbn9oN7g595 U+VsqyEQ+hzc
aiKiVwhAoDcCyFtvGa9zvMhbnXkhKghMRaB5eUu5TdKGfPTAvuHwfv+uytlW QwB5Ww13eoUA
BG4QQN6YDTUQQN5qyAIxQGA+As3L23wo6QkCEIAABHoigLz1lO16x4q81Zsb IoPAFASQtymo
0iYEIAABCDRPAHlrPsWLGCDytog0ESQEihFoXt5ybpssRpmGIAABCECgOQLI W3MpXeSAkLdF
po2gITCaQPPyNpoMJ0IAAhCAAAQCBJA3pkcNBJC3GrJADBCYj0Dz8paz8rZ+ z02DtM+XKnqC
AAQgAIGaCCBvNWWj31iQt35zz8j7JNC8vOWkVYnbxuYV767K2SAAAQhAoE8C yFufea9t1Mhb
bRkhHghMS6A5eSv5Jd2P3L0zKG+qnO0Ggdgv/F4yM2mMUvmSx07sEIDAdgLI GzOiBgLIWw1Z
IAYIzEegSXkL4Uu5jfLBu3YGv6RblUubupi3d3WO77jUXmp56PvQSovGFO2F 2JksSvft46z7
CeU1NUc59ecad06MnAuBVgkgb61mdlnjQt6WlS+ihUAugeblzb64TZG3B+68 eXj0oSPDec+u
yqXNd3E910V3qJ/SMcS2l1tPi9Oq5c2V+9ixSfMmtnzu/mLjoh4EeiCAvPWQ 5frHiLzVnyMi
hEBJAshbgOZ9J14cvG1SlUtbqry5VppUH3Y7rhUgXc+sK6282SJk9q/HZvZl HnOdK/Gwzw/V
l9j5xukbgxmvTwCl4y4WPoksGUdoXrhijs0D9SAAgfEEkLfx7DizHAHkrRxL WoLAEgg0K2++
29r0ypvv0UzavXfcEpQ3VS5tMRfdIdnyyYJPqELCJZVJgugbqyQ0kqCFJC1F Jl39jOUUwz02
NlO+Q8IpSbpLEn3spHlJOQQgkE8AectnSAv5BJC3fIa0AIElEWhW3mxR0T+n 3DZ55tiu4Gfe
VLm0SatH9vkhgZIu3l1iIK282W26ZNPXhi0vUj1J4iQWrpz65CwUm49TzNgl UTXLpfamjEOa
l5RDAAL5BJC3fIa0kE8AectnSAsQWBIB5C2QrVNHdg9r504Pa2fduyqXtqXJ m2s8PqG0ZWrM
KpAWnJh+Y+QtRn5jJVf1F9OeJNWucrvtWCkswVyas5RDAAJxBOaQN/0mzePl AQYwYA4wB5gD
N+aAWpDaoYCoJ+sXLm3tS9yklTWp3BzzycO3Bm+bVOXStmR5k24dzBGJkLS5 JM0nQFqCpFjn
ul2xljikeUk5BCCQT2AOecuPkhZaJ8DKW+sZZnwQ2E6gyZU36bveYifB8UN7 gvKmyqXNvnUu
5bY61+pM7u2AvjZNYbLFSrodUlo1shnFrtCF2NkyZ8tZKidTAl2rba72Ym6L DLEMCaWUA9d4
pblIOQQgUJYA8laWJ62NI4C8jePGWRBYKoHm5K1kIm4/uDf4mTdVzgYBCEAA An0SQN76zHtt
o0beassI8UBgWgLNy1vKbZI26qMH9g2H9/t3Vc4GAQhAAAJ9EkDe+sx7baNG 3mrLCPFAYFoC
zcvbtPhoHQIQgAAEeiWAvPWa+brGjbzVlQ+igcDUBJC3qQnTPgQgAAEINEkA eWsyrYsbFPK2
uJQRMASyCDQvbzm3TWaR5WQIQAACEGiaAPLWdHoXMzjkbTGpIlAIFCHQvLwV oUQjEIAABCAA
AYsA8saUqIEA8lZDFogBAvMRaF7eclbe1u+5aZD2+VJFTxCAAAQgUBMB5K2m bPQbC/LWb+4Z
eZ8Empe3nLQqcdvYvOLdVTkbBCAAAQj0SQB56zPvtY0aeastI8QDgWkJNCdv 0hd0p6zEPXL3
zqC8qXK2+QlIX/KdWz7/iOgRAhBYIgHkbYlZay9m5K29nDIiCIQINClvoQGn yNuDd+0Mfkm3
Kpc2JRL2rs7xHZfaM8slSUlpq2Rdacz2GFLHIdXX5aE4So5XakuKVzqfcghA oE4CyFudeekt
KuStt4wz3t4JNC9v9oVzirw9cOfNw6MPHRnOe3ZVLm2+C/cSF/Ql2pDiHyOL oTHbZVqwSsZh
ypur3Vq5pTCgLgQgsHoCyNvqc0AEw4C8MQsg0BcB5C2Q7/tOvDh426Qql7Yx 8mauGLlWqVwr
S7qe61xbZlwCJY3Dbj9UXxpzKJ6YsZvtx4zXjjXmfFMqXYLp61c6HsuZehCA QP0EkLf6c9RD
hMhbD1lmjBC4QaBZefPdMqdX3nyP5uS4945bgvKmyqXNjsMlWaHVp9AqkiRh tuSZfdtSKI3D
JUDSCps9Lp+0+caYezzEXo3Hx8+WO5tbzHlm+3Ov9KXmkvoQgMA4AsjbOG6c VZYA8laWJ61B
oHYCzcqbT1RSbps8c2xX8DNvqlzapFUo1/ku6XC1kyJvLvlyCYxLLkNjjInL lQuXII2RohAr
ib1P8GPkLSZHIfGW5g3lEIBA/QTmkDf9Js3j5a3bA9lhwBxgDjAHrs0B5TQ7 9JP1C5cGtS9x
s+XMvoBPkbdTR3YPa+dOD2tn3bsqlzZJIHxSZQtPjCTFyo8pbWNXhWJWC0Nj KyVvPvmVxDSm
3K4jyVgKf2neUA4BCNRPYA55q58CEa6aACtvq84A/UNgXgLNr7zZOFPk7eTh W4O3TapyaatV
3kLyEhpTSNps4ZTEVBLUErdNpsidq78pJVOaO5RDAAJ1E0De6s5PL9Ehb71k mnFC4BqBJuVN
+q632OQfP7QnKG+qXNpibs1zSY55nik5tjz5fvbd+mf2lbrqFls/dcx2rC5B dN2mqAXUxcAu
M+tI/Um3TUr9uiQ2RnqluUQ5BCBQFwHkra589BoN8tZr5hl3rwSak7eSibz9 4N7gZ95U+VK3
WBFb6viIGwIQgMDUBJC3qQnTfgwB5C2GEnUg0A6B5uUt5TZJO61HD+wbDu/3 76p8qRvyttTM
ETcEIFALAeStlkz0HQfy1nf+GX1/BJqXt/5SyoghAAEIQGAOAsjbHJTpQyKA vEmEKIdAWwSQ
t7byyWggAAEIQGAmAsjbTKDpJkgAeWOCQKAvAs3LW85tk31NBUYLAQhAAAIp BJC3FFrUnYoA
8jYVWdqFQJ0Empe3OrETFQQgAAEILJ0A8rb0DLYRP/LWRh4ZBQRiCTQvbzkr b+v33DRIeyxo
6kEAAhCAQFsEkLe28rnU0SBvS80ccUNgHIHm5W0clmtnKXHb2Lzi3VU5GwQg AAEI9EkAeesz
77WNGnmrLSPEA4FpCTQnb9IXdKesxD1y986gvKnyVW/Sv/zPLV/1+KbuX+Iz df+0DwEILJcA
8rbc3LUUOfLWUjYZCwRkAk3KW2jYKfL24F07g1/SrcqlTcmBvatz9DHzfNex mPZDdbSchOKQ
+ihZPpUs+canYzfLbea+8Y2Jdcw5JfnSFgQgMB8B5G0+1vTkJ4C8MTsg0BeB 5uXNvphOkbcH
7rx5ePShI8N5z67Kpc13Mb8KeXPFOrdspPYXWz9Uzy4zf45tX8qzKYmxdakH AQgsmwDytuz8
tRI98tZKJhkHBOIIIG8BTvedeHHwtklVLm0heVPnmitj5s/6eUjy7DLX6pLd vh2vLTJSm1I8
psT44kldYYypL3H2jdtesbPjd43HbMseo2+FT5onlEMAAssjgLwtL2ctRoy8 tZhVxgQBP4Fm
5c13G51eefM9mqjuveOWoLypcmkLyUFI3nyrRWOPx8ZhyopLJkPlrvFI9SV+ LlFynSONLyRv
dh9SzCEhLr2Sl8KHuhCAwLwE5pA3/SbN4+UBBjBgDjAHmAM35oBymR0KiHqy fuHS1r7Ezb4t
0r6YTrlt8syxXcHPvKlyaYtZEXLdxjdG0lwCE7vy5pNdV2y2pIX6lUTIJWeS ALnKYzi7JM3H
ecwYbdmV5gblEIDAsgnMIW/LJkT0cxBg5W0OyvQBgXoINLvyZkuD/jlF3k4d 2T2snTs9rJ11
76pc2mKkopS8uWJJkbfQ+baYxLabIm8xLGN4uiTNbtsXf0wufHMLeZMySDkE 2iKAvLWVz6WO
BnlbauaIGwLjCDQvbzaWFHk7efjW4G2TqlzaxsrGmJU3l7TESlZMfzFiI0mR tKrmE0jpvFB5
zOqaS8jGjEWKU5ovlEMAAsshgLwtJ1ctR4q8tZxdxgaBFxJoUt6k73qLnQjH D+0Jypsql7aY
2xFd0qVXcfT5dh2zXVM87PqmgEi3N/raDImNL05JmGIlJ6Wea3whNnbsMTG7 6riYx8YtzR/K
IQCBegkgb/XmpqfIkLeess1YITBc//xvM595K5nU2w/uDX7mTZWztUsAAWs3 t4wMAiUIIG8l
KNJGLgHkLZcg50NgWQSaW3mz8afcJmmfe/TAvuHwfv+uytnaJIC4tZlXRgWB kgSQt5I0aWss
AeRtLDnOg8AyCTQvb8tMC1FDAAIQgEDtBJC32jPUR3zIWx95ZpQQ0ASQN+YC BCAAAQhAYAQB
5G0ENE4pTgB5K46UBiFQNYHm5S3ntsmqM0dwEIAABCCwUgLI20rx0/nzBJA3 pgIE+iLQvLz1
lU5GCwEIQAACcxFA3uYiTT8hAsgb8wMCfRFoXt5yVt7W77lpkPa+pgujhQAE IAABTQB5Yy7U
QAB5qyELxACB+Qg0L285KJW4bWxe8e6qnA0CEIAABPokgLz1mffaRo281ZYR 4oHAtASakzfp
C7pTVuIeuXtnUN5U+RI36d/gS+VLHPMUMUuccsuniJk2IQCBcgSQt3IsaWk8 AeRtPDvOhMAS
CTQpb6FEpMjbg3ftDH5JtyqXNnUBb+/qHH3MPF+62Jf6ii3X/YRii22rRL2p xp3KPjUOqX4v
nEvMAdqAwBIJIG9LzFp7MSNv7eWUEUEgRKB5ebMvsFPk7YE7bx4efejIcN6z q3Jp813g1yJv
rvglKZHGnFqe2l9s/VT2se3q8Un1TXlbIufUPFIfAr0RQN56y3id40Xe6swL UUFgKgLIW4Ds
fSdeHLxtUpVLW0gg1Llmuf3cFjxzJUmfa7dv1zFFw3W+JBWu9sbG4VqBNMch yZAZq0t+7bHE
sndJVgpH3xhS5K1WztL8phwCPROYQ970mzSPlwcYwIA5wBxgDtyYA2pBaocC op6sX7i0tS9x
0ytrvlvmdLnv0RzzvXfcEpQ3VS5tIWEJyZstKpLo2eXmzy7Bs4XDJZGh80wp tJ/HnBeKT2Ia
K3Gx7G3Jyo3f1Z5PzmLzNjY/pTin5IS6EOiFwBzy1gtLxjmeACtv49lxJgSW SICVt0DWzhzb
FfzMmyqXNmn1x3dx7RKP0CqdS8Z8Kz+xK0I+AZ4rDntMIdYuzinsY2XXJ9Wh fElx1MBZmseU
QwACLySAvDEraiCAvNWQBWKAwHwEkLcA61NHdg9r504Pa2fduyqXNunC3SUN MSs/MSsxOraY
9nxS4hpfjLxJ54VkSWJqxxrD2DU+M4ZceQuNV4pPKo+Nc2y+U3hTFwIQuEEA eWM21EAAeash
C8QAgfkINC9vNsqUf1hy8vCtwdsmVbm0xVyY64vzlJWyGHlLaS9G3lztTRlH iK1erZLqxEik
LT2xshvLV5oDMf2tirM0vymHQM8EkLees1/P2JG3enJBJBCYg0CT8iZ911ss 2OOH9gTlTZVL
W8wtcba8mT+bkiKteNnn2UJmxuLqwydntiiNjcMnKa7xj5Ey+5xY9ra8pXL0 1Td52rHoc8y+
a+MszW3KIdA7AeSt9xlQx/iRtzryQBQQmItAc/JWEtztB/cGP/OmytkgAAEI QKBPAshbn3mv
bdTIW20ZIR4ITEugeXlLuU3SRn30wL7h8H7/rsrZIAABCECgTwLIW595r23U yFttGSEeCExL
oHl5mxYfrUMAAhCAQK8EkLdeM1/XuJG3uvJBNBCYmgDyNjVh2ocABCAAgSYJ IG9NpnVxg0Le
FpcyAoZAFoHm5S3ntsksspwMAQhAAAJNE0Demk7vYgaHvC0mVQQKgSIEmpe3 IpRoBAIQgAAE
IGARQN6YEjUQQN5qyAIxQGA+As3LW87K2/o9Nw3SPl+q6AkCEIAABGoigLzV lI1+Y0He+s09
I++TQPPylpNWJW4bm1e8uypngwAEIACBPgkgb33mvbZRI2+1ZYR4IDAtgebk TfqC7pSVuEfu
3hmUN1U+1WZ/ofVU/dAuBCAAAQiMI4C8jePGWWUJIG9ledIaBGon0KS8haCn yNuDd+0Mfkm3
Kpc2JWH2bp5jltnHfW2PEbsx50hjoxwCEIBAzwSQt56zX8/Ykbd6ckEkEJiD QPPyZktLirw9
cOfNw6MPHRnOe3ZVLm0habLLzJ9Ly1bp9qRxUw4BCECgdQJzyJt+k+bx8gAD GDAHmAPMgRtz
QDnNDgVEPVm/cGlrX+Jmy1mOvN134sXB2yZVubT5pEk67lut08d1v6GVO7Ou r54UP+UQgAAE
IOAmMIe8wR4CEgFW3iRClEOgLQLNrrz5blfUcud7NNN77x23BOVNlUtbSMJc 52qpi1mV89Vx
iSErb1KmKIcABCCQRgB5S+NF7WkIIG/TcKVVCNRKoFl5M1emTPgpt02eObYr +Jk3VS5t0gqb
fX6qvLnkEHmTskI5BCAAgXwCyFs+Q1rIJ4C85TOkBQgsiQDyFsjWqSO7h7Vz p4e1s+5dlUvb
1PLm6h95k7JCOQQgAIF8AshbPkNayCeAvOUzpAUILIlA8/JmJyNl5e3k4VuD t02qcmkr9Q9L
XP/MhNsmJfqUQwACEJiOAPI2HVtajieAvMWzoiYEWiDQpLxJ3/UWm7jjh/YE 5U2VS5vvs3f6
vJh/OCJ9/s3+JyaqbVe7rnpS/JRDAAIQgICbAPLGzKiBAPJWQxaIAQLzEWhO 3kqiu/3g3uBn
3lT5Kjb++cgqqNMnBCAAge0EkDdmRA0EkLcaskAMEJiPQPPylnKbpI396IF9 w+H9/l2Vz70h
bnMTpz8IQAACrLwxB+olgLzVmxsig8AUBJqXtymg0SYEIAABCECAlTfmQA0E kLcaskAMEJiP
API2H2t6ggAEIACBhgggbw0lc8FDQd4WnDxCh8AIAs3LW85tkyN4cgoEIAAB CHRCAHnrJNGV
DxN5qzxBhAeBwgSal7fCvGgOAhCAAAQgsEUAeWMi1EAAeashC8QAgfkINC9v OStv6/fcNEj7
fKmiJwhAAAIQqIkA8lZTNvqNBXnrN/eMvE8CzctbTlqVuG1sXvHuqpwNAhCA AAT6JIC89Zn3
2kaNvNWWEeKBwLQEmpM36Qu6U1biHrl7Z1DeVDlbGwSkr2CQytugwCggAIEU AshbCi3qTkUA
eZuKLO1CoE4CTcpbCHWKvD14187gl3SrcmlTF/32bp5jlkltlSi3JWTVUuLj I3ErwcLOg/o5
FE/pPkPtrTovc46VviCwVAJzyJt+k+bx8tZnDNlhwBxgDjAHrs0B5TQ79JP1 C5cGtS9xs+XM
vghOkbcH7rx5ePShI8N5z67KpS10Eb4KkZpLCmL7kepJ5RL/2HLdj6+/ueLQ 8c7dXywn6kEA
AjcIzCFv8IaARICVN4kQ5RBoi0DzK2858nbfiRcHb5tU5dKWKgOmRPhW5VzH XfLhq6eP65Um
UxjMMtdKlDRes9xuy3WuJCmS4I7l5RtbTL5iubpij+Xry30Kf+pCAALTEkDe puVL63EEkLc4
TtSCQCsEmpU33+1veuXN92gm9t47bgnKmyqXNjsOU5RCMuOTltDxmFW+Me3a QiaN2S4PSZyP
j49Tqfglji7JsmXX/Nlsz/U8N+5U5tSHAASmJ4C8Tc+YHmQCyJvMiBoQaIlA s/Lmu/hPuW3y
zLFdwc+8qXJpi1nJcclRrFy4VtzMsdsrOLkS4RpP7CqR79wQw9A5PmGypcol iLEc7Hnk+6NA
jLyViEOab5RDAALzEUDe5mNNT34CyBuzAwJ9EUDeAvk+dWT3sHbu9LB21r2r cmmbQt5cffpk
xCUfqbLoqi+N2z4nlYNPvm0x89ULSa3ZhsQntdxuu3QcKdypCwEITEsAeZuW L63HEUDe4jhR
CwKtEGhe3uxEpay8nTx8a/C2SVUubTG3MroEJHZlyCcHpc6XpDA0fvvWwxjp tOvESt9U45Xk
zcWf2yalVwXlEGiDAPLWRh6XPgrkbekZJH4IpBFoUt6k73qLRXT80J6gvKly afPdZmdKgUty
XLfYhc6Rbme0hcInHXYsY+UtJK0msxg+MdKXyku16buNUbq90SyXxNvF3XeL pY7JzrM0xyiH
AARWQwB5Ww13et1OAHljRkCgLwLNyVvJ9N1+cG/wM2+qfKotVn6m6r/mdn2i WnPMxAYBCLRH
AHlrL6dLHBHytsSsETMExhNoXt5SbpO0MR49sG84vN+/q/KpNuTNTxZ5m2r
Re: Primitive types and Java types in XMI [message #477306 is a reply to message #477298] |
Wed, 30 April 2008 23:24   |
------=_NextPart_000_0049_01C8AB19.5F91C560
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_004A_01C8AB19.5F91C560"
------=_NextPart_001_004A_01C8AB19.5F91C560
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
If one has a .uml model, you can use the uml editor to apply the Ecore =
profile in the following way.
1. Open up your .uml model.
2. Select the root package.
3. From the tool bar select "UML Editor > Package > Apply Profile ..."
4. Select "Ecore" the "Add".
To apply a stereotype, select the element you wish to apply the =
Stereotype to, then..
1. Select "UML Editor > Element > Apply Stereotype ..."
2. Applicable choices will be presented.
To add values to the stereotype...
1. Open up the "Properties" view.
2. Add stereotype properties.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fv9uu2$joo$1@build.eclipse.org...
Stephane,
Someone with UML knowledge will need to help. By the time you get to =
an Ecore with this structure, it's major task to turn your EClasses into =
EDataTypes. So likely you need to do something to the UML first. There =
are introductory guides for how to do these kinds of things. I assume =
SWT wrote:=20
Ed,=20
I'd really like to "apply the Ecore profile"... But I don't know how =
!=20
I attached a screenshot to illustrate my problem.=20
In the state exposed by the screenshot, how can I replace the "int" =
type defined in my model by the one defined in the ecore ressource, so =
that the attribute "einttest2" gets the ecore EInt type instead of my =
fake int type ?=20
Of course, I can do this "by hand" in the properties of the =
"einttest2" attribute, but if I had a very very large model with lots of =
attributes using this int type, it wouldn't be feasible to change each =
one manually !=20
Thanks again !=20
Stephane=20
Ed Merks wrote :=20
Stephane,=20
If I look at Ecore.uml it looks like as below, so I imagine you =
need to apply the Ecore profile and set the Instance Class Name=20
SWT wrote:=20
Hello all !=20
I managed to import XMI 2.1 files generated by other uml tools =
(Enterprise Architect & Bouml) into eclipse, and it works well (at least =
with Bouml) except for primitive types and java types.=20
For instance, in Bouml, if I define a class attribute with type =
"int", the resulting XMI declaration becomes :=20
<ownedAttribute xmi:type=3D"uml:Property" =
name=3D"myIntAttribute" xmi:id=3D"BOUML_0x1f482_1" =
visibility=3D"private">=20
<type xmi:type=3D"uml:Class" =
xmi:idref=3D"BOUML_datatype_0"/>=20
[...]=20
</ownedAttribute>=20
Where "BOUML_datatype_0" is defined as :=20
<packagedElement xmi:type=3D"uml:DataType" =
xmi:id=3D"BOUML_datatype_0" name=3D"int"/>=20
After importing that into eclipse, I get an "int" class =
definition.=20
If I use EMF to generate the corresponding model classes, it =
will result in creating a "int" class (public class int extends EObject) =
!=20
Of course, I'd like to use the primitive java type int instead =
of this class !=20
The same kind of problem appear with other java classes such as =
java.util.Date...=20
So I'd like to know how to work around this problem... Can I do =
something with my UML tool such as using "special" stereotypes which =
would be recognized when importing into eclipse ?=20
Or should I use some transformation (xsl) on my XMI files in =
order to change types declarations into ECore/XML types declarations ?=20
Maybe there's a way under Eclipse, to switch attribute types =
from "fake classes" to ECore classes ?=20
Any advice would be really appreciated. I already tried a lot of =
different things, but I can't find any working solution... I hope this =
is a "well known newbie problem" so that someone will tell me the right =
thing to do in no time :)=20
Thanks in advance !=20
Stephane=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3157" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>If one has a .uml model, you =
can use the=20
uml editor to apply the Ecore profile in the following way.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>1. Open up your .uml =
model.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2. Select the root =
package.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>3. From the tool bar select "UML Editor =
>=20
Package > Apply Profile ..."</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>4. Select "Ecore" the =
"Add".</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>To apply a stereotype, select the =
element you wish=20
to apply the Stereotype to, then..</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>1. Select "UML Editor > Element > =
Apply Stereotype ..."</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2. Applicable choices will be=20
presented.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>To add values to the =
stereotype...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>1. Open up the "Properties"=20
view.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2. Add stereotype =
properties.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Cheers,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- James.</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fv9uu2$joo$1@build.eclipse.org">news:fv9uu2$joo$1@build.ecli=
pse.org</A>...</DIV>Stephane,<BR><BR>Someone=20
with UML knowledge will need to help. By the time you get to an =
Ecore=20
with this structure, it's major task to turn your EClasses into=20
EDataTypes. So likely you need to do something to the UML =
first. =20
There are introductory guides for how to do these kinds of =
things. I=20
assume you've looked carefully at the UML2 documentation and the=20
wiki?<BR><BR><BR>SWT wrote:=20
<BLOCKQUOTE cite=3Dmid:fv9t34$jfq$1@build.eclipse.org =
type=3D"cite">Ed,=20
<BR><BR>I'd really like to "apply the Ecore profile"... But I don't =
know how=20
! <BR>I attached a screenshot to illustrate my problem. <BR>In the =
state=20
exposed by the screenshot, how can I replace the "int" type defined =
in my=20
model by the one defined in the ecore ressource, so that the =
attribute=20
"einttest2" gets the ecore EInt type instead of my fake int type ? =
<BR>Of=20
course, I can do this "by hand" in the properties of the "einttest2" =
attributes=20
using this int type, it wouldn't be feasible to change each one =
manually !=20
<BR><BR>Thanks again ! <BR>Stephane <BR><BR>Ed Merks wrote : <BR>
<BLOCKQUOTE type=3D"cite">Stephane, <BR><BR>If I look at Ecore.uml =
it looks=20
like as below, so I imagine you need to apply the Ecore profile =
and set=20
the Instance Class Name <BR><BR><BR><BR><BR>SWT wrote: <BR>
<BLOCKQUOTE type=3D"cite">Hello all ! <BR><BR>I managed to import =
XMI 2.1=20
files generated by other uml tools (Enterprise Architect & =
Bouml)=20
into eclipse, and it works well (at least with Bouml) except for =
primitive types and java types. <BR>For instance, in Bouml, if I =
define=20
a class attribute with type "int", the resulting XMI declaration =
becomes=20
: <BR><BR><ownedAttribute xmi:type=3D"uml:Property"=20
<BR> <type xmi:type=3D"uml:Class"=20
xmi:idref=3D"BOUML_datatype_0"/> <BR> [...] =
<BR></ownedAttribute> <BR><BR>Where "BOUML_datatype_0" is =
defined=20
as : <BR><BR><packagedElement xmi:type=3D"uml:DataType"=20
xmi:id=3D"BOUML_datatype_0" name=3D"int"/> <BR><BR>After =
importing that=20
into eclipse, I get an "int" class definition. <BR>If I use EMF =
to=20
generate the corresponding model classes, it will result in =
creating a=20
"int" class (public class int extends EObject) ! <BR>Of course, =
I'd like=20
to use the primitive java type int instead of this class ! =
<BR>The same=20
<BR><BR>So I'd like to know how to work around this problem... =
Can I do=20
something with my UML tool such as using "special" stereotypes =
which=20
would be recognized when importing into eclipse ? <BR>Or should =
I use=20
some transformation (xsl) on my XMI files in order to change =
types=20
declarations into ECore/XML types declarations ? <BR>Maybe =
there's a way=20
under Eclipse, to switch attribute types from "fake classes" to =
ECore=20
classes ? <BR><BR>Any advice would be really appreciated. I =
already=20
tried a lot of different things, but I can't find any working=20
solution... I hope this is a "well known newbie problem" so that =
someone=20
will tell me the right thing to do in no time :) <BR><BR>Thanks =
in=20
advance ! <BR>Stephane =
<BR></BLOCKQUOTE><BR></BLOCKQUOTE><BR><BR>
<HR width=3D"90%" SIZE=3D4>
<BR>
<CENTER><IMG=20
src=3D"cid:004101c8ab3a$e6975770$682b1a09@rationalnt.ibm.com"></CENTER></=
BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_001_004A_01C8AB19.5F91C560--
Content-ID: <004101c8ab3a$e6975770$682b1a09@rationalnt.ibm.com>
iVBORw0KGgoAAAANSUhEUgAAA28AAAOiCAYAAADnue+WAAAAAXNSR0IArs4c 6QAAAARnQU1BAACx
jwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdw nLpRPAAAABh0RVh0
U29mdHdhcmUAUGFpbnQuTkVUIHYzLjA4ZXKc4QAA+TRJREFUeF7t/W2wHcd5 mIvi/E2lKvfjnFOp
W3V+5f5IVKkiwlIRMAMEvMqVK0pFlkvyLeX6RskxDhAhMFDgoYCQMGnY2BBg UZZpi7RMUtS2QCsy
ZFnWByRaNk3FihGZcCRbhiwxtiXblGXLtqwvK1K4NyllLnqDDfRudvfbPd0z q6f7maqptfZ0T/fb
z9trr3l2z9rrf/r0714edrBBAAIQgAAEIAABCEAAAhCAQMUE/qcdO5S8scOA OcAcYA4wB5gDzAHm
AHOAOcAcYA7UPQeQN+QVeWcOMAeYA8wB5gBzgDnAHGAOMAcWMAe88vYrj71/ +NEf/VF2GDAHmAPM
AeYAcyBjDqj30zF/yeZ9mGsQrsOYA8yBfueA773jBfJmvlmMebPhnLqXWvUv AfJUd55K5cd8PX/j
m88M7PkMzDfSsRflpfJLO8t4Hes5EztfzNftwJZNgNfsMl4nLfw+m1K01Auh BUaMIf716Hvv2CZv
+g0DsPFgl8RKTYIlxUusefNQv56/+vVvDmr/0z//CnsBBpqneuSiMG+O9vYa V/NFEjj9uv3Od74z
sJdnwGuW1+yUv3emvM5C3vqdu/Z7x3V5Q9zanhRT/kKZ8hchbY+bl/r1/KWv fGP4o8//NftEDBRf
vaeurjC3x83tpXMLCZx+3T733LMD+/QMeM32+Rqc8neIea2lZav045Tx03a9 rwnzvWNL3hC3epNV
4oWEuLWdX3uO6NfzF//qa8Mf/NFfss/EQPFWe8zqSonXNW0s93XtmiP6dbu5 uTGwz8uA1+xyX0u1
/R7U11tTCBsrb8xT/btKlLcP/dTeIbTX9sIhnhdObp+8kds2fxHoi8A//eJX hs/8wZ9v26Wc2/X5
eTu/GB6KO3/Rr/e1ddtttw0xu/ReEtOGquNqJyRvG898a2CfnwGv2Xpfs9Jr sabyGlbejv3712/7
vXPn699a9UdmfuM//adB76VzmfN72o6lVFs57WyTt9DKjLrY23z228790xf/ 3ZbYlYZNe+V+iZLb
ciyXMC+1uP3xn/71cOWpL7xgj3k9u87j2AtZhpgo/mrnL/r1vf7UG6e0+aTL /B2Q2479u1n9/N+/
9d9esP//jtw7/OtjPz7877e/adh/x08OB//9Tw2H7vrp4cg9PzMc+9GHh9e9 fn2488fOD3e/6R3D
j/zkzw9n7n+Xsx1X2xx7IW9es/W9Zpfw3qtjrGHlTcnby7//NdevzXPlzZSr 2OcpOVNtqk09ppwX
Wzf0uzrmd73uJ/d3fql21BzbWnkLXeC//yf/yfDM5nPDrf/ft1zf1c9q/8OP 3DN8BoGbZLLFTkqp
XkxudT7NR3K7zDcwU94+8amnB3vXr2cp565zeztm/nXMHnuozKyLwNX3Oir5 BhzzF1Tf72iXvH3z
v/3NYO8/df79w2/+7ueGS5/4g+Gjv/XU8K73f3T41d/43eFD//ETw/t+7fLw Sx/+zeHdH/rPw89f
/I3hP1wtO/PAu17QhqvdFo+Z+bDHFyqz6yJw9b1upWudWspXsfL2fT/+weFf nX3ncPCHf3pQ4qZ3
LXAl5O3P/vyLwxf+7M+Hz//pF4bfvfJ7wx//ydPD5/7oj4c/+MPPDb//B58d nvqvfzB85qnfHz79
mf+aLGFK2n72534h+byUnLt+76eIm+qrpvcOUd7e86bbhm9tXJM3talH9bPa n778k1sC9+mLhwZV
LwVkq3V37NgR5CCVl+YS/Lzbb719K4//8h/+2+s5JbfLftPS8vaHf/KXw+Xf +aMX7J9OyLnr/J6O
mb+o1XM9dt9xHxuVCy4G63ldxQhXzJt67hu5S96+8TdfHexdrbyd/on/MKz9 5DuH17/554dzP/3u
4Y0/84vDmx7+peEn3/a+4f63Xxze8nOPDQ/9hw8Pb3vXr16Vt194QRuudls8 Zr829Rh9x0MMeM3W
85otfV00ZXsxK2//6ofePeg99rNxKubYz7zZK2+vPnD1Oj3ji6eVXP3CL753 ePd73jf84i+9f/il
910c3veBDw0XP/Th4YOP/crwy7/ya8OvPP6R4Vd/7T8Ov/aRj46SMHPVzV7d y4ndd7dEzO/4KW+b
zLn7I2rl7cIbXzJ841vbV97Uz/Z+4cdf4p0cOcKSc26phKe0I8Urlaf0FVPX J2/nX/3hYf2Vj23t
r/uus9efq+Nmbv/bf39uCOU2JoZQnbl55MZb+/la3p767BeH//xfPrttT825 fb7+WeXMVyYdzzlX
art0uX1xri/6zV+66lhMvyofXAy2dTE4hbx9/WtfHuz9x9/63m3v85ev/FHw fV/Vd7WjXnvm7qoz
5THVt9m+/XOJvmNfs7F98Zpt6zU7x/t3zMqbErc3v/PJLYFTMf37n/6Pwx0/ 9fhw5I0fHv7tmQ8M
//upX9o67hM7aRz2Z952/7+v3UL5kdf/r1u7dL5drm9r1L94rvzeZ4K/g8bc /mh+5k09f+q3/3Br
d0ldavy2wI0Rt5w+XRI4ubz93Bv+6fD1q7KmdrXqZj7Xt1KqY6qeb3A5F+g5 55aEHduWFK9UHttP
bD2fvL315R8cnnzbZ4aLd31seONLz19/ro7rHG89fjOc29g4ppgbuX23eL6W t9/7/T8bfv03f3/b
nppz+3z9s5rDvjLpeM65UttTlEv3yqf0qXLCxWA7F4NTyNtXv/JXg70rGfvP Vy9ifvPq/p8/+fxu
Pv/k564f/82r5aq+qx312jOP2z+7zil5bK7+pNds6ph4zbbzmp3jPb+GlTff OJW4/Y/vfC1Z4JRA
qVsl7f3Kpz49/O7V/c+/+Bdbu3qujo2VNx23a+VNHXv22Y1Rbc+R95Q+Srx3 iLdNrp996fCVbzy7
tZufe1PPn374j7aOqTJVL3SBrv/ip+uYfwE0z7OP++r5zjHlyHWu/ddHXzx2 vKpeTMwx/ackObeu
T97uf9m7t8TtwoGPDEduOXX9uTqu860fQ7l1cbEFNcREylFufnTfIWmOyWto 3rr6iJm3ubl1na/l
7ZOf/vzwa7/x1LY9Nef2+fpnc2yhY6rMrus61+7HVye2X1VP9y3F5xujedx3 r3zMuXYdlRcuBtu4
GCzxBmy+htW8+PJf/8UL9h+7eoukuf2nq597C20/9jO/4GxHvS7M9vXP9qOq Y77W9Dn2e6fdli43
6+u2XG2a8bj688XhYmQf871mY8511eE128Zrdor3XLvNmJU39fpVq26xt0za 9aRx/OqP/i/Dr/7o
/3p1/1+Gx7eeX308fe1RyZva1XGpHVOmzN85n/zdT237FfSh9//coHa95cqb HZcWNyVv73vXI9f/
M+WYfmLHPGW9Eu8dorw9uPbdw5e+vrm1K1Ezn2uZU8dUvdjVFd/FvesCO3TR rcXBFrnc47Zs5LZn
ni+Np/SEccmb+oybulVSrbgpcVO7eq52dVyV6zyn5jaFVaiuKUt2vdT8SOIW M3+kcblissdQOrch
efv4lT8ZPvwff+/6Pibn5vnmczXWmJ/teuoc17FSbem29YWgbleK1zdOfdx3 ISid5ytXueFicPkX
gyXegG15+9Jf/flg7z/6Uz8/PPGff2/4tau7+aieu3ZV39WOeh2Yx/XP+vWi y0L1fOfP0a5rTL5j
vtdsShsvyMNVuVZ/HJvj9zh9LPf3Q8zKm8qvvmXSFLPQZ+HUOTGfefvQ3f/z 8J1v/Obz+5PDd/7m
6nO1f+Pqc3X8b24c+9AP/c9R81lJ0m9/8srwO1d381H9AxMlbUqq1KP6pyZq HyNVoc+8fetbfzO4
9jH91PDaKvHeIcrbm3/knw1f/Orm1q5kTT+3H1W9FHmz/4qnL459YpfSttmW 2Y90Ae662NbxxAqn
Wd83xjknj2/l7fUvedh526Q6bub2L67mPSW3EmMpvzGcffI2hrd9ji/f0rhs AXTFMkfe9crbk7/9
R8PFx393256ac/t8/bMam1nmYqjK9XG7rq9d8xyzTX3cPs8Vh6uuL75QHLpM ugUrpg1XHZUfBG65
F2jqtVziDdiWt7/64p8O9n7Xvee3/ZVbSVxoU/Vd7divA11HHTfr+34OHXe1 ndKu73y7Dde47GPS
azamDV8dXrPLfs3O8R6csvJmypp+bn4Wbuxn3t574v82vPf41f3q4/uO/9+3 nr/v+f3bX/zZQe2q
LJaH/Zm3T/zO7279CtLipuVNr8Bd+o3fiG5bx2B/5u2rf/314T3vfHj467/6 0+ErX/5z5468Xf2L
ki+Jb/rhfz782Zc3t3Ylb+ZzvfKmjv3E1XqpghWqH7qIdq2U2OJlS4BvFcTV j08OXP3GyEYo3tgX
z9h6Pnk7te/+67dKqhU3fQulOq5zrB9TchuSHDMHkhSH8hmTH1++bY6x8yRV 3sbmK/c8LW+X/ssf
Du/98O9s21Nzbp+vf1bMzDL7Z/s8fWGmjsfUdfXrOs8XR2p8vnHG/vMD3/nS cZUjLgaXezGY+18r
Xf9t8i/+7OnB3v/PM28d3n/1KwHe/8RvbT0qedv62bOr+q521Osi5rhdT/8c e1z34atvl/viMutJ
dXTd2Nesi0PsMV6zy33N5r6/xpy/6pW3UIy/cOz/uiVu7776GDMWU6w+/tuf HP7LJ35na//TL/zZ
lrh94fP/dfjyl76wbf/cH3yy+Mrbn//pHwyufcnyFvP+4ctR1H+b/LEf+hfD 57+0sbX7PvOmylS9
sfLmuoAOyZvr4l2SN0kWfG2mnGde4KdKXcoLKaWuT97e8ZrHB3Uxr3Z1q6R+ ro7rfOvHlNzGyFsM
p1x5Kz1/cuTNJ4gpeYytq+VN/SONd3/w49v21Jzb5+uf1XjMMulnVVfXseua ZfbzlPNCdWPic43V
/vfiuo7vuI9X6LjKExeDfV4MuuTtz//0j69epGzff/Dun9m20PbLH/1kcOVN 1Xe1o14HMcftevrn
Usd1DFK7Zqy+2O3x2K9NXe477uIRc4zXbJ+v2Zj34ZSVt6k+8+b7b5M//4P/ l0HtMeMw69grb+q7
3j7wnrcPn/uD3x6++GeffcH++5/+rWSBC4mYKtPy9vNv/+nFf+Ytlb9dP0re ztz58uFP/mrjBbsp
cqpc1QsFpP/6bq++2NJk19MXzZKw6fOk9mKkKiRyofhix5ibuJTzffKm2vi1 x9+3lVf1eShXjtWx
P/7L+Nz62JsiFZtfF0tb6Gyh8s0Bm5drDkh5leatqw9Xmym5G1NXy9uvXfrM 8PPvu/yCPSXnrvP1
MT02+2d1PHRMlbnONfsy8ygdd9U1Y5BiCY3R/MuYXS9UFmrTmZOrueJisL+L QZe8feHpzw72rr7n
LXV3taNeF7HHzdeVPsc8Zrflq2/3p+up42YbUn+uuF3HzNelXR4qi23frMdr tr/XbMx7cg0rb1N8
z5v9HyD1z09duTQ8/blPDb/wHx7akir9c+qqmPQ9b1rgUtuNydnS6kTJ26kT 3zN87i+eEfcfOf49
yTY/BTD7wnyKPpbUZkjelpbbJXFfVaxa3n7l139vWL9w6QV7Ss5d53PshUxL MPnQE1cQuIwvkV3V
6y2nX5e8ff6P/2CodVfvrbXGtqq4EDgEzrUqoo+FVtZcn3ezv/8t9jNv3/fj Hxz+1dl3Dgd/+KcH
JW56f/n3X/t+tztf/9bJrs+1sGmpsn+O/R051/e8xcZTc70oebv7dd873H1c 7a8Yfuh1r7j+/MbP
V4+pOlfLVjVY14rLqmKprd+QvC0ht7XxrD0eLW9KBlxSkZLzElJCG/Gy9/5f +Z0tgeOCsI8LQpe8
/cnnnhpq3dX7bK2xrTIuXrN9vF5j3/tjV95cYlbiv02qOO2VtynlTfVnipf+ OZaXq57re95y2mvt
3Ch5a23QvY0nJG+9sehhvFrelAggTvHiVAur9zz2iUHtCFz7F4QuefujP/z0 wL5MBrxm23/NxlxD
xH7mTbU112feppa3GC7UKff6QN46uE0HeSv3glnCLx8tb0oAahES4kiXyHd9 4L+wCtf472eXvH32
9z81sC+XAatwfb3fuq4JclbeQkJnli3hWoQYp3stIG+NXxyoFw/yNt0LqMZf Tlre1MU/0pQuTTUx
+w/vfXJQu74g5C/7bb2WXfL2h099cmBfPgNes229VlPe66e85or5ku6UWKm7 zHmKvCFvK/ucIr80
pvmloeVNXfTXJCLEMl4kz7/7Y4PeuSic5nWzit9HLnn7/U//9sDeFgNes+28 ZmN+TwS/x6NAYUwM
1Gl7zm2TN/MXDM+v/dMAdhgsdQ6oi32EabwwLYHdUucmcd/4vWpeZCkuT33q v7A3zIC5zzUFc4A5
UGIO7NC31i3hYoUY274YJb/klznAHOhlDrhW3viLedt/MSe/5Jc5wBzInQPb Vt56ecNknFwcMgeY
A8wB5sCq5wDyxkVc7kUc5zOHmAP9zQGnvBW4JZcmIAABCEAAAk0SyLlYuu22 267fzhyStybBMaii
BNRcYoMABPohoN97ViZvH/qpvUNo7ycVjBQCEIAABJZEQP/L7tSY1Rtuirzl SCLntv3XeD2X+O+D
beeZ1zH59X0dxQs+85b6hjSmvhK3zWe/7dw/ffHfbYkdGwQgAAEIQKA2AmO/ bwl540Ks1MU48sZc
KjWXaGd5c2llK2/v/8l/Mjyz+Zxz/8OP3DN8BoGr7XqFeCAAAQhA4CoB5G15 FzutXaAib8zB1uY0
44mf08nyFvPvLWPe3T/9W28fvrXx3PAv/+G/3Xo096cv/+SgBO7TFw8N73nT uHu6d+zYERPGtjrq
nDHnJXd09YS5+hkTW+icmLhLc4zpM2WcUnt2uVQ/pW/qQgACyyeAvMVfZHBB Ng2r0vKm3ufI1TS5
gitcS8+BUfIWeutVDUrb+Vd/eFh/5WNb++u+6+z15+r4N7713PX9v/3354YL P/4SqTlnuXTBveoL
dCm+UYOe4SQpbql8TIil25Ta880N6bxc6R3DhnMgAIH5CaxS3vQfx/Rj6YsC qT0u8uu4EJXkzc6T
lDepXJoXlNcxL8hDH3lYiby99eUfHJ5822eGi3d9bHjjS89ff66Of/2qvF3f v/nc8HNv+Kej3pml
C23kbRRWccVQ4j6m19JtSu0hb2OyxDkQ6IdASN5CF8ElPvOWelFe+mKOi/w6 Lg6RtzryUPr1RXvk
NWYOrETe7n/Zu7fE7cKBjwxHbjl1/bk6/pVvPLttXz/70uAVgf1XSF3ZvAA3 65jl+rg6FlNH17Mf
Xe2YQYdEUZdJ8Y6J0WYR25eLhTlmH8PUGO1+fPFJObNZm/lwnSuxtstTx+vi 4GOaGrsUi52nmH77
ueRmpBAoQ8Anb+brzfcfwnL/26RP3vRxs9wVj/2eacbpq6/qmO3reuZx3Q5y N8/FZ468xeTZlU9p
fsdcdFJnnvkB57Y5j5Y3+w1AX/Dq2yZ9j+ozbupWSbXipsRN7eq52tVxVf6l r29e3x9c+25R3lyi
ZAuTT2RcsucTFfOi3CeJ0nHfxbUUh2s8PikMHfeJidS/K+4Y7iFxdeUkRnR9 sYzhIY0hxCu2P9d8
sid1Tlum9KbEW+YyllYg0B8Bl7y53hPtC6gpV95MoQpJlSR/9kV7bLvI27wX i5K82cLtu5i3pT91
fiAJ8+Yd3vBWc2C0vPnermM+8/b6lzzsvG1SHf/iVzev739x9fmbf+SfZcub /aYakjNJYsbIRehC
3dWeL15JhMyLeElKfELhk3KfdJr1fVxd44mR3JAwuiQlVoBs2QmNQZKhsbly zYmYeSr9YcHOe4h9
f5fcjBgCZQjY8ub6vWlLj37DLbHyZvbnk6bUi3CffPrasVfsXMLIheZ0F5o5 8mbnOiR6pty5ziPH
0+UYtrD1zYGVyNupffdfv1VSrbjpWyjV8T/78ua2/Sd++J9nyVvqBX0N8hYa sP7lmXoRHyOs0gpR
SGQkbq4xSTI6h7xJcUnyNjZXIaF3iXfomCTtZS5XaQUCENAEfLdNShdbU6y8 lZQ3V/zIW50XkGPl
TZJ6qVya45TXOV/IS1t5WYm8veM1jw9K1NSubpXUz9Xxz39pY9v+Yz/0LxYv byFJkQTGLjeFJlVM
pb4kwYsRGakPn2j4xNHXp+t4KR4xfUqsbJkN5TFFxFPqSrngUhwCEBhHoAd5 M1dcXKts9sWgfdHP
xeK0F4sx8ha6fdZ1e+yY223J87R5hi98XXNglLxJ3/UW83b4a4+/b/iTv9rY +oybenTtf/yXG8OZ
O18uypu5lO9aAbKX+s06kkyYK13SBXvMRX/MBbVvPHYsOh7p+JgxSuP29e2T FFd79jglNrF8Y3lI
YwiNxZ5DdmyhGFxzNDaXUr+uFT1XLDGvUepAAAJuAkuQN30hrl//5sW6+bvX FjNXfZeo2bKGvM17
kTlW3ux54ZJ0+5rJNXeQinnzDW94m3MgWd5KvZmfOvE9w+f+4hlx/5Hj3yPK W6mY5mjHJQRz9Jvb
xyriXkWfJqdV95+bM86HAASmIbBKecu9iJtCsqZoM3ecrZ8fK2+tc2B8SE2P cyBb3mL+QYnr7fPu
133vcPdxtb9i+KHXveL68xs/Xz2m6lwtC21Lu8BeWry+VaJpLom2t7pqVqvu fw7G9AEBCKQTUBcL
0h0ovvLcf1iSe6EyhWhN0WbuOFs/H3lDWlqf44zPP8ez5S39bY8zIAABCEAA AssloAQsZ1+/cGlQ
u3oDtm+F0T8rOmMFkfN+tAt2ag4yT/rINa9p8my+XyBvy71+IHIIQAACEFgB gZy/CMeuvOXIIefm
yTX84MccYA7UOAf0e0+2vI29bdL1fluyrRW8n9MlBCAAAQh0QEB/5i11qKlf FZDaPvX7IjB2HvZF
idFCoB0CxeStHSSMBAIQgAAEICATmOsflsiRUKNnAshbz9ln7D0SKCZvJVfL SrbVY1IZMwQgAAEI
TE8AeZueMT3IBPQ8/PVffsMwZv/UJ94jd0INCECgGgLF5K2aEVmBqO+PY4MA BCAAAQiUJtCzvOV8
b+QU/8F3ijZLz5ep2tPz8Fcvvmn45FeeG7VPFRvtQgAC5QkUk7ec1bKY/54T O/Tzr/7wsP7Kx67v
r/uus9t+VuVsEIAABCAAgVwCLcib/UXMMUxyRUmfH2rHLpP6lMpjxrXUOlPK mzk/lsqHuCHQGoFi
8pYDRhI/qdzs+5FXfGh47J4nh8fPfXx4z5GPDuuvemzbz6pc2nLeBHLOleKi HAIQgAAE6iHQiryZ
RGPew2LqhLKEvJWdw3oefuC9b95adfv7+39ma//8X28MX/r6s8Odb/3w8IP3 f2D4/nPvHr775M8N
/+gHH97a/7d//VPD337lG7bqubZUgS47KlqDAAR8BIrJW4pg2cFI50rlZntv ffkHt8Ttybd9Zrh4
18eGN770/LafVbm05bwx5ZwrxUU5BCAAAQjUQ6BFeVN0zfcx18pLyjGXGJry 5rv9MiQOvv7t2GPG
Us9sGh+JnofvetdD2+TtL7+2OXz1m89t27929Wd7V3WQt/H8ORMCcxMoJm85 gUtyJpWbfd//sndv
rbgpcbtw4CPDkVtObftZlUtb7BuTfmMw33y4xUCiSzkEIACBNgi0Lm8+gZL+ SOlbWbOPj21HEsJQ
uS6T+l7SDNXz8O3v+Nlt8qYk7ZvPfHtr5e3oT39w+Ddv/KXhe37kncM/vmN9 a/8HB98y/N3vv2/4
W9/7BuRtSQkn1u4JFJO3FMGyqetz7Xvv9S9XXe571O2pf06iPuOmVtvUrsRN 7/qYKpf+iYl0q0Do
lo+W3hC6f3UAAAIQgECAQA/yZr8v6z9a2lhi6pWSt1BfIeF0ndfCBNfz8C3r 79wmb9/a/M6w8ez/
2LZvPvudQe+6bPO57yBvLUwExtANgWLylkNMEj+p3OxbSZr5mTclb+bPqlza XL/8fW8WkuhJfVEO
AQhAAALLJNCDvLkyI73vTbnyJq0GSuXLnGnhqPU8/ImHf3FL3r618e3ruxI1 tfJ26M0fGF61dmHY
c3XF7e/9wANb+9/5vnuv1dv8NvLW4sRgTM0SKCZvKYJl05TOlcrN9l7/koeD n3lT5dImvTH5/uLo
+4uk1B/lEIAABCCwPAItypv5/hcrQqn1QnevuN5fzWNSX1K5bqulu2T0PHzD W9472PtTn/3CIO1f
+OKXkbfl/foh4o4JFJO3HIaSnEnlZt+n9t2/7TNuaqXN/AycKpc2Sd5cv/RT 3oyk/imHAAQgAIH6
CbQib+adJb4/ToakTv/h0tWOdDulLvdl2/d+a/dlxyfFUv/sio9Qz0PfGdJ/ mwz1FJob8RFSEwIQ
KEmgmLylCJY9gJLf8/aO1zw+KEHTu/qMm/mzKo/Z7DeUlDcC6c0opn/qQAAC EIBA3QRakLe6CRNd
DIEp5S2mf+pAAALzEigmb/OGHd+b9M9J4luiJgQgAAEIQOAGAeSN2VADAUne aoiRGCAAgXIEislb
zspbueHQEgQgAAEIQGAeAsjbPJzpJUwAeWOGQKAvAsXkrS9sjBYCEIAABHon MIe86TdpHi8PMIAB
c4A5wBy4MQfUwtkOBUQ9Wb9waWtP2Vh5S6FFXQhAAAIQWDoB5I0LSS4kmQPM AebAquZAs/KGVC79
8oj4IQABCNRJAHnjom1VF230y9xjDjAHsuWtzrdWooIABCAAAQhMQwB54+Kp pgvoX//lNwxj9k99
4j3cknr1zrOackks5CNmDmTLW60rXDlxrd9z0yDt01wS0CoEIAABCNROAHmr 7wJLfVVPzEVPi3V+
9eKbhk9+5blRe4s8GFN9r09yUjYn2fJW+5vsmPiUuG1sXvHuqpwNAhCAAAT6 JNCCvJnfYZp6YbVq
UbK/AFzFP0VMuh+TzxT9pPK365eWN2mMUnnueDi/7IU+PNvjmS1vOStcU77t 58T1yN07g/Kmytkg
AAEIQKBPAi3IW47wrPLi3df3FDEtRd4+8N43b626/f39P7O1f/6vN4Yvff3Z 4c63fnj4wfs/MHz/
uXcP333y54Z/9IMPb+3/27/+qeFvv/INW/XGXNhPwXpMHJzTnpSQ07icZstb i2/dD961c3hm46mt
fWPz+V0/v/qoyqVN/XILbVK51D7lEIAABCCwGgItyptrNUtfSNmrdK5VO+mY fcEv1XddxIWkwSzz
rSqm9qnbtNv2cdFCbEqfTwBdx8deuL7rXQ9tk7e//Nrm8NVvPrdt/9rVn+1d 1Qlx9s2JnFXbsWPk
vLiLejj1wSlb3nJWuKZ8282J64E7bx4efejIcN6zq/LcDXnLJcj5EIAABFZD oFV5c90e6BImaeXF
JT3mSl9MmzF1Ym5n9MUSs/IoyZvEyyV9LonNveB++zt+dpu8KUn75jPf3lp5 O/rTHxz+zRt/afie
H3nn8I/vWN/a/8HBtwx/9/vvG/7W975BlDdpjLmxc34fskGey+Y5W95W89Y5 ba/3nXhx8LZJVS5t
Ws7sv1zp88zjUluUQwACEIBAPQR6k7cY4XCt0vjO84mZb6XHXOnyXQT6Vt5M AXPFk7KaZwufNGaf
vEnjTL3Qfcv6O7fJ27c2vzNsPPs/tu2bz35n0Lsu23zuO8gb/21y1K2zqXOU +pXJW84K15RvxTqu
2EczlnvvuCUob6pc2kx5M+v6jkvtUQ4BCEAAAnUQ6Ene7FsEXStWsZKWswom rZRJq32ucYSOuUQt
tHoordKFxp57YfsTD//ilrx9a+Pb13clamrl7dCbPzC8au3CsOfqitvf+4EH tva/8333Xqu3+W3k
DXlD3hY4B1h5c1wLnDm2K/iZN1UubcibRIhyCEAAAssk0KO8xYiLvUIWK3Ux QiitvsXKm08CY27T
1CtmoXhdq20p7MaI3Bve8t7B3p/67BcGaf/CF7+MvC3wwn3MHOGcsitfq+aZ LW+1r7yNuTQ4dWT3
sHbu9LB21r2rcmlD3iRClEMAAhBYJoEW5M28dU+SEVNafKtV0i2EoVsO7TZD tzLqdkLx+2Kxx2G3
YV+QSbdZSmMOiZyLaekLQum/Tfr6ixHhOeIvzYP22hKYnvOZLW/LfOsNR33y 8K3B2yZVubQhbxIh
yiEAAQgsk0AL8tbzhU8vYx8rb73wYZzI3FLnQLa8tbjydvzQnqC8qXJpk+RN na//ciW1RTkEIAAB
CNRDAHnjom+pF33EzdxlDix/DmTLWz1vp+Uiuf3g3uBn3lQ5GwQgAAEI9EkA eVv+xQ8XsOSQOcAc
WOocyJa3Flfejh7YNxze799VORsEIAABCPRJAHnjom+pF33EzdxlDix/DmTL W59v3YwaAhCAAAR6
JTCHvPXKlnHHE9DzMP4MakIAAksmoMU7W95aXHlbcmKJHQIQgAAEpiWAvE3L l9bjCCBvcZyoBYFW
CCBvrWSScUAAAhCAwKwEkLdZcdOZh4Ceh7/+y28Yxuyf+sR7YAsBCCyIQDF5 W9CYCRUCEIAABCCQ
TQB5y0ZIAwUI6Hn4qxffNHzyK8+N2guEQRMQgMBMBIrJG7dNzpQxuoEABCAA gSoItCBv5hdMp0LV
X4WTel5ufftLsaeMw/VVPlP2N4bNVPImjVMqHzMWzoEABGQCxeRN7mr5Nf7l P/y3yx8EI4AABCAA
gSIEWpA3BWLsRfjY84rAz4g7pf8lydsH3vvmrVW3v7//Z7b2z//1xvClrz87 SF/SreqN2Vad/zEx
cw4EWiBQTN5qWXlTcUh7bOLOv/rDw/orH7u+v+67zm77WZWzQQACEIBAnwRa lDd7VcvMrL1K51q1
k47ZF/xS/dDMcrVlx6vl1LfCKK086j7MvuzntuD5OIVY5ryC9Dx817se2iZv f/m1zeGr33xu2/61
qz/bu6rj2syx5+QpZ2ycCwEIvJBAMXmrBa4kkVK5OY5HXvGh4bF7nhweP/fx 4T1HPjqsv+qxbT+r
cmnL+ctUzrlSXJRDAAIQgEAegVblzSdANi3pPcolPlqmzEdXf/pYqI8UeYsZ k6svSd6kdl3SJ8Wd
Oiv1PHz7O352m7wpSfvmM9/eWnk7+tMfHP7NG39p+J4feefwj+9Y39r/wcG3 DH/3++8b/tb3vkGU
N2mcqTFTHwIQGE+gmLylSNH4cOUzpTikcrOHt778g1vi9uTbPjNcvOtjwxtf en7bz6pc2qQ3t9D5
OedKcVEOAQhAAAJ5BHqTtxjpcK3c+c7zyVJo9S8kej4xDPUv9SXJlzRe3/lS vykzU8/Dt6y/c5u8
fWvzO8PGs/9j27757HcGveuyzee+g7ylAKcuBFZMoJi8rXgc17uX5EwqN8dx /8vevbXipsTtwoGP
DEduObXtZ1UubSm3GvhutUDiJMqUQwACEJifQE/ypumatwhKMldi5S31D5wx K2W+uFx9heQtRkol
+Ssxa/U8/ImHf3FL3r618e3ruxI1tfJ26M0fGF61dmHYc3XF7e/9wANb+9/5 vnuv1dv8NvJWIhG0
AYGZCBSTtxQpmnJsOg77r1r6F6gu9z3q2NQ/J1GfcVOrbWpX4qZ3fUyVS//E ZOybm/kXxCl50TYE
IAABCIwj0KO8me9NY9/fQvIktWlmyveHTakNSSpDfcTIq0vYUrilzkY9D9/w lvcO9v7UZ78wSPsX
vvhl5C0VOvUhsEICxeRthWPY1rUkkVK52ZiSNPMzb0rezJ9VubS53kR8t1lI bzhSX5RDAAIQgMB8
BFqQN9cdHy55cd1FooXElpXYNs3zfW2Espkib1L8qW3puHzv52a577kpgjmz Vs9DXxvSf5v0nRcj
uaXGkDN+zoVAbwSKyVuKFE0JWYpDKjdje/1LHg5+5k2VS1uqkIX+qif1RTkE IAABCMxHoAV5m4/W
PD25JMwnZvNENH0vU8nb9JHTAwQgMIZAMXkb0/kU50hyJpWbMZ3ad/+2z7ip lTbzM3CqXNokeQu9
0bT+hiOxoxwCEIBAzQSQt/qyg7zVlxMiggAEyhIoJm8pUlR2CNtbk77jLSXO d7zm8UEJmt7VZ9zM
n1V5zGbfVuC6fUO6pSOmH+pAAAIQgMB8BJC3+VjTk5+AtPIGOwhAoC0CxeSt LSzu0Uj/nKQHBowR
AhCAAASuEZhD3vSbNI+Xt3izw4A5wBxgDlybA2pBaod+sn7h0qD2lC1lRSul XepCAAIQgAAEaiQw
h7zVOG5iqosAK2915YNoIDA1AVbepiZM+xCAAAQg0CQB5K3JtC5uUMjb4lJG wBDIIlBM3lh5y8oD
J0MAAhCAwMIIIG8LS1ij4ep5+Ou//IZhzP6pT7ynUTIMCwJtEkDeEvKKoCbA oioEIACBxgkgb40n
eCHD0/PwVy++afjkV54btS9kqIQJAQhcJVBM3qAJAQhAAAIQ6IlAC/Lm+pJl vqZmWbN4Knmzv4Dc
/NLumC/nZh4tax4R7XIIFJO3HlalehjjcqYukUIAAhBYLQHkbbX86f0aAT0P P/DeN2+tuv39/T+z
tX/+rzeGL3392eHOt354+MH7PzB8/7l3D9998ueGf/SDD2/t/9u//qnhb7/y DVv1XFtIvmLELKYO
OYQABNIJFJO39K77PoOvHeg7/4weAhBYPoFW5E1lwrzQtp9L31XqW72LWZ1Z /ixY/Qj0PHzXux7a
Jm9/+bXN4avffG7b/rWrP9u7qpMjb/YKnW7L9/21qydGBBBYNoFi8tbiqlTJ L/w+/+oPD+uvfOz6
rr7w2/xZlS9xk/6yJpUvcczEDAEIQEAR6EHezEybt82ZF+j2c/v3Pu8D075e 9Dx8+zt+dpu8KUn7
5jPf3lp5O/rTHxz+zRt/afieH3nn8I/vWN/a/8HBtwx/9/vvG/7W977BK28+ AfPJvvmHAPI+bd5p
vV8CxeStRYSSkErlJpNHXvGh4bF7nhweP/fx4T1HPjqsv+qxbT+rcmnz3X9u /5VLakf/cnW9wab+
spXqS+UxsVIHAhCAQI0EWpI330W3a1UltEpnvr+w8jLPrNXz8C3r79wmb9/a /M6w8ez/2LZvPvud
Qe+6bPO573jlzTcC5G2e3NILBFwEislbisgsJRXSmKRyc5xvffkHt8Ttybd9 Zrh418eGN770/Laf
Vbm0SSKUcotK6DYXKQ6zPCamlPaoCwEIQGApBFqXN98KWoy8LSWHLcSp5+FP PPyLW/L2rY1vX9+V
qKmVt0Nv/sDwqrULw56rK25/7wce2Nr/zvfde63e5reRtxYmAmPohkAxeWuR mCRnUrnJ5P6XvXtr
xU2J24UDHxmO3HJq28+qXNpCohT6K5irXfv2F9/tMNJnGex+7fqS3EljphwC EIBArQRakzfF2fwd
XkreeB+YdgbrefiGt7x3sPenPvuFQdq/8MUvI2/TpojWIVCUQDF5SxGZoiOY sDE9Jt/tirrc96hD
U/+cRH3GTa22qV2Jm971MVUu/RMT1+0ruo/S8hbzpq3f6M1HOx7etCecoDQN AQislEDr8mbKnE/q
QqtwKXeDrDSRC+9cz0PfMKT/Nuk7z3ftY98O67tesP8YsHDMhA+BaggUk7dq RlQwEElIpXIzFCVp
5mfelLyZP6tyaZti5c0WL9cKXKykueQSeZOySjkEILBUAi3I21LZE/cNAlPJ G4whAIE6CRSTtxSR
qRPFC6OSxiSVmy2+/iUPBz/zpsqlzSdCrr+OSdKU+pmFVKnTY5HikMZMOQQg AIFaCSBvtWamr7gk
eeuLBqOFQPsEislbi6gkOZPKTSan9t2/7TNuaqXN/AycKpe2kLzZ50rSJLXF bZNSNiiHAAR6J4C8
9T4D6hg/8lZHHogCAnMRKCZvKSIz1+By+yn5PW/veM3jgxI0vavPuJk/q3Jp C91/XlreVHv2fe26
D99n71z1JYmUxkw5BCAAgVoJzCFv+k2ax8tb36vHDgPmAHOAOXBtDihP2aGf rF+4NKidbToC0j8n
ma5nWoYABCAAgRIE5pC3EnHSRtsEWHlrO7+MDgI2AVbeGp8TYz4P1zgShgcB CECgCAHkrQhGGskk
gLxlAuR0CCyMQDF5W9i4CRcCEIAABCCQRQB5y8LHyYUI6Hn467/8hmHM/qlP vKdQJDQDAQjMQaCY
vLX4mbc5EkAfEIAABCCwTALIm5y3nM89S/9YS+69jxp6Hv7qxTcNn/zKc+L+ R9/49qB3Xb8PUowS
Am0QQN5WlEdkd0Xg6RYCEIBAIQKtyJvvn1DFYJLkzPc1MzltS33GtN1Snank Dc4tzRLG0hKBYvLW
EhTGAgEIQAACEJAItCBvU1+g57TPyps0A6+V63n4gfe+eWvV7e/v/5mt/fN/ vTF8/kvb97/6m83h
//yZ39za/9H3nhz+6m+e3arn2nJyFxc5tSAAgTEEiskbK0lp+OGVxovaEIAA BGoj0Lq8hb7+xbWi
FlvfV08f13kOfS2Nq05t82OuePQ8fNe7Htomb3/5tc3hL4z9q9987rq0KXFT Ave1q8fUcZ+8mTmx
c+77PljVlu+rhuZiQj8QaJlAMXlrGVLtY+NrB2rPEPFBAAItEmhB3nwX2r4L c5dg+S78ddvmo1lX
WlkLxeBqs9eVIj0P3/6On90mb0rM1K4k7ZvPfHvr8bYfeNP1lTd9TIlcKIe2 KJs/u/IZkroWfw8w
JgjMTaCYvLGSFE5dyS/8Pv/qDw/rr3zs+q6+8Nv8WZXPtUlvllL5XHHSDwQg AIHSBFqRN98FuGvl
K3a1JWWVxhZI3+fkXG3mfF6v9HxYVXt6Hr5l/Z3b5O1bm9/ZujVSr7Lpx5fd 9cuD2vWtk+oxVt5C
8m3mh7ysajbQbw8EislbD7ByxijJrVRu9v3IKz40PHbPk8Pj5z4+vOfIR4f1 Vz227WdVLm32X0/N
N0/p3NAvb/tc5C2FJnUhAIElEWhd3lIu6FNWyaSVmRR5W9J8mSpWPQ9/4uFf 3JK3b218+/r+368+
f82P/cctgVOPG89+Z9tn3pS4bTz3neLyNtVYaRcCELj2OVe1K3fYoZ+sX7g0 qD1lS5GPlHZbqSvx
kcpNDm99+Qe3xO3Jt31muHjXx4Y3vvT8tp9VubQhbxIhyiEAAQiECfQkb7FC pYn5Vt5cf9CTxE9q
0y7vbd7qefiGt7x3cO3/9bN/tiVv//WzX9jazX9Yop5/4YtfnlTe+CNubzOS 8U5NoJi8TR3o0tuX
5EwqN8d//8vevbXipsTtwoGPDEduObXtZ1UubTFvrL4PHPtuh3DV55e2lAnK IQCBpRJoQd5Ct7fF
/E43f8eHbrP03VJnipfdX+i9xnXeUudRbtx6Hsa0o2+V1J9z07dS+s41/9Dr E2/fPHH9kTgmRupA
AALyHw5ZeZthlmg5s9+M9C9DXe571CGqf06iPuOmVtvUrsRN7/qYKpf+iYkk b2P/Eur7C+kMiOkC
AhCAwKwEWpC3WYHR2SQEppS3SQKmUQhAIIsAK29Z+OJPllbWpHKzJyVp5mfe lLyZP6tyabP/WipJ
V8wtM6G/ukrxUA4BCEBgaQSQt6VlrM14U+TN9Z8lff9tsk1ajAoCyydQTN5S 5GP52NJHIPGRys0e
X/+Sh4OfeVPl0jaFvLn65LZJKROUQwACSyWAvC01c23FnSJvbY2c0UCgTwLF 5K1PfPGjluRMKjd7
OrXv/m2fcVMrbeZn4FS5tPmkKmaFzWw7tb4UF+UQgAAElkJgDnnTb9I8Xvvv auwwYA4wB5gD/LfJ
Wa4TSn7P2zte8/igBE3v6jNu5s+qXNokeVPn8w9LJIqUQwACPROYQ9565svY 4wiw8hbHiVoQaIUA
K28NZFL65yQNDJEhQAACEKiOAPJWXUq6DAh56zLtDLpjAsXkLeW2v455Xx86 vJgFEIAABJZNAHlb
dv5aiR55ayWTjAMCcQSKyVtcd9SCAAQgAAEItEEAeWsjj0sfBfK29AwSPwTS CBSTN1aS0sBTGwIQ
gAAElk0AeVt2/lqJHnlrJZOMAwJxBJC3OE7Fa5WU3ZJtFR8oDUIAAhBolADy 1mhiFzYs5G1hCSNc
CGQSKCZvmXFwOgQgAAEIQGBRBJC3RaWr2WCRt2ZTy8Ag4CRQTN5Y/UmbYSV5 lWwrbRTUhgAEINAv
AeSt39zXNHLkraZsEAsEpidQTN6mD5Ue5iDA1w7MQZk+IACBFgggby1kcflj QN6Wn0NGAIEUAsXk
jdWfFOzDkMOr5Bd+n3/1h4f1Vz52fVdf+G3+rMpzNt+Xgee0mXOuFI9UntM3 50IAAm0RQN7ayudS
R4O8LTVzxA2BcQSKydu47jlrDAFJ/KRys89HXvGh4bF7nhweP/fx4T1HPjqs v+qxbT+r8thNiY+5
q/NKyZBu14zFdUyKVYpHKpfapxwCEOiHAPLWT65rHinyVnN2iA0C5QkUk7cU YSg/jOW1mMNLOlcq
N2m99eUf3BK3J9/2meHiXR8b3vjS89t+VuUxm096SskQ8haTBepAAAJzEkDe 5qRNXz4CyBtzAwJ9
ESgmb31hW+1oJTmTys3o73/Zu7dW3JS4XTjwkeHILae2/azKpS0kaGaZvSqn 23Ud963g6fbsR9VW
TPtSPKVkU2JGOQQgsHwCyNvyc9jCCJC3FrLIGCAQT6CYvKUIQ3x47dbM4aXP tW9T1OKhy32Pmqr6
5yTqM25qtU3tStz0ro+pcumfmMTKm5lNl3yZMmdn3idtvnZKHW93BjIyCEAg lwDylkuQ80sQQN5K
UKQNCCyHQDF5W86Qlx+pJH5SuUlASZr5mTclb+bPqlzaYuXN95k4+3zfLZIu ucuRtCk/oycxoxwC
EFg+AeRt+TlsYQTIWwtZZAwQiCdQTN5ShCE+vHZr5vCSzpXKTaqvf8nDwc+8 qXJpi5E3l6CZ7Uqf
abNvd7RFztd+7HGXGErjphwCEOibwBzypt+kebw8wAAGzAHmAHPgxhxQ1/s7 FBD1ZP3Cpa2drU4C
kpxJ5eaoTu27f9tn3NRKm/kZOFUes0n/sESSN9WHq43Q7ZXmObGSlrpSFzN2 6kAAAn0SmEPe+iTL
qFMIsPKWQou6EFg+AVbeVpTDFMGyQyz5PW/veM3jgxI0vavPuJk/q/LYTboN MXTb5Nh/JCKdpwXP
9c9MfMdix0s9CECgbwLIW9/5r2X0yFstmSAOCMxDoJi8zRMuvUxNQPrnJFP3 T/sQgAAElkIAeVtK
ptqOE3lrO7+MDgI2gWLylrOS1GNa4NVj1hkzBCDQEgHkraVsLncsyNtyc0fk EBhDoJi8jemccyAA
AQhAAAJLJYC8LTVzbcWNvLWVT0YDAYlAMXljJUlCvb0cXmm8qA0BCECgNgLI W20Z6TMe5K3PvDPq
fgkgbyvKfa3yVmtcK0oT3UIAAhDwEkDemBw1EEDeasgCMUBgPgLF5G2+kOkJ AhCAAAQgsHoCyNvq
c0AEw9b337FBAAL9ECgmb6zYpE2aWnnVGlcaXWpDAAIQmJ4A8jY9Y3qQCSBv MiNqQKAlAsXkrSUo
jKUMAb52oAxHWoEABOokgLzVmZfeokLeess44+2dQDF5Y8UmbSrVwqvkF36f f/WHh/VXPnZ9V1/4
bf6sytkgAAEItEIAeWslk8seB/K27PwRPQRSCRSTt9SOqV8HAUkipXJzFI+8 4kPDY/c8OTx+7uPD
e458dFh/1WPbflblMduOHTsGc485x6yjzmWDAAQgMDUB5G1qwrQfQwB5i6FE HQi0Q6CYvKVc5LeD
b/xIauElxSGVmwTe+vIPbonbk2/7zHDxro8Nb3zp+W0/q3JpKyFeJdqQ4qQc AhCAAPLGHKiBAPJW
QxaIAQLzESgmb/OFTE8lCUhyJpWbsdz/sndvrbgpcbtw4CPDkVtObftZlUub T7zs4+bP9iqda9Uu
5piuI8VIOQQgAAFFAHljHtRAAHmrIQvEAIH5CBSTt5SL/PmGV29PtfDScdi3 Kmo50uW+R01Y/XMS
9Rk3tdqmdiVuetfHVHnMPzHxiZaZTR2fS/ZCoqfacJ1ry2C9M4fIIACBWggg b7Vkou84kLe+88/o
+yNQTN76Q9fGiCWJlMpNCkrSzM+8KXkzf1blqZtLqlyrbi6x08d8YuoTNm67 TM0S9SHQJ4E55E2/
SfN4eWulkx0GzAHmAHPg2hxQ1+g79JP1C5cGtadsKRf5Ke22WrcWXlIcUrmZ n9e/5OHgZ95Ueeom
yZstaObKmlnm6hd5S80G9SEAAZPAHPIGcQhIBFh5kwhRDoG2CLDy1lY+k0cj yZlUbnZ4at/92z7j
plbazM/AqfLUTboF0mzPdyulrw3kLTUb1IcABJA35kBtBJC32jJCPBCYlkAx eUu5yJ92SMtovRZe
Jb/n7R2veXxQgqZ39Rk382dVLm3S1wS4RMz1j0bsY9Ln6PjMm5QZyiEAAZsA K2/MiRoIIG81ZIEY
IDAfgWLyNl/I9LQUAjH/nCRlLHwWLYUWdSEAgakJIG9TE6b9GALIWwwl6kCg HQLF5K2WlaSlpAZe
6ZlC3tKZcQYEIDAdAeRtOra0HE8AeYtnRU0ItECgmLy1AIMxQAACEIAABGIJ IG+xpKg3JQHkbUq6
tA2B+ggUkzdWktKSC680XtSGAAQgUBsB5K22jPQZD/LWZ94Zdb8EkLcV5b4H eethjCuaPnQLAQhU
QAB5qyAJhLD1fU9sEIBAPwSKyVs/yBgpBCAAAQhAYLh+0Zz6hbHqD1u33Xbb 1vepql39bLZh/gxn
CEgEkDeJEOUQaItAMXljlSVtYvTAK2eM6/fcNEh7GnFqQwACEChLgJW3sjxp bRwB5G0cN86CwFIJ
FJO3pQIg7joJKHHb2Lzi3VU5GwQgAIFVEkDeVkmfvjUB5I25AIG+CBSTt5xV lr6QXxtti7xKfuH3
I3fvDMqbKs/ZWvjagRbGkJNDzoXAqgkgb6vOAP0rAsgb8wACfREoJm99YWO0 LgKSkErlZpsP3rVz
eGbjqa19Y/P5XT+/+qjKYzclOeauzistPqXbs8c29RhsPrFsqQeBngkgbz1n v56xI2/15IJIIDAH
gWLylnJhPsfAau+jRV72mGyhSRnzA3fePDz60JHhvGdX5TGbT6pKypYWn5h4 dJ2U/qceg91+Smwp
Y6YuBFojgLy1ltFljgd5W2beiBoCYwkUk7exAXBeOwRKytt9J14cvG1SlUtb SELMMt+qk+t4qK4U
j10eI31zjmGMWKaOmfoQaIkA8tZSNpc7FuRtubkjcgiMIVBM3lJWVcYE2to5 LfLSY7Jv8dMCost9
j2aO773jlqC8qXJpixUfsx19juvcMe1JMarykMSN6XPsGHQsMTFTBwIQmOer AlK/hoD6l7d97QI8
4MEcYA60OgfU9fQONTj1RH/3DG/OEEghUHLl7cyxXcHPvKlyaYsVH9/nyVy3 E465hTH282Q5wjj1
GCTWlEOgRwKsvPWY9frGzMpbfTkhIghMSYCVtynpBtpueeVNDzvnM2+njuwe 1s6dHtbOundVLm0x
8iZ93su1KuY7JsXjK89deSsxBj7nNjZ7nNczAeSt5+zXM3bkrZ5cEAkE5iBQ TN7mCJY+6iYgCalU
bo7u5OFbg7dNqvKYTVopk8RH9RGzIjZGfmI+8+br3zyeO4Yxscewpw4EWieA vLWe4WWMD3lbRp6I
EgKlCBSTt5QL81LBL7mdFnmV/J6344f2BOVNlcduvlsK9fmhWw5NsfHd/hh7 W6QZb6owTTkGu+3U
2GLzQD0ItEYAeWsto8scD/K2zLwRNQTGEigmb2MD4DwIuAjcfnBv8DNvqpwN AhCAwCoJIG+rpE/f
mgDyxlyAQF8EislbiytJU06FHnjljPHogX3D4f3+XZWzQQACEFglAeRtlfTp G3ljDkCgTwLF5K1P
fIwaAhCAAAR6JYC89Zr5usbNyltd+SAaCExNoJi85ayyTD3IGtuHV41ZISYI QAAC8QSQt3hW1JyO
API2HVtahkCNBJC3FWWlB3nrYYwrmj50CwEIVEAAeasgCYSw9aXkbBCAQD8E islbP8gYKQQgAAEI
QGC4ftGs30hjH9Uftm677bZh/cKlrV39bJ5r/gxnCEgEkDeJEOUQaItAMXlj lSVtYvTAK2eM6/fc
NEh7GnFqQwACEChLgJW3sjxpbRwB5G0cN86CwFIJFJO3pQIg7joJKHHb2Lzi 3VU5GwQgAIFVEkDe
VkmfvjUB5I25AIG+CBSTt5xVlr6QXxtti7xKfkn3I3fvDMqbKs/Z+CLqHHqc CwEIKALIG/OgBgLI
Ww1ZIAYIzEegmLzNFzI91UpAElKp3BzXg3ftDH5JtyqP3ZSombs6r6S82W3H xkU9CEBg2QSQt2Xn
r5XokbdWMsk4IBBHoJi8pVyYx4XWdq0WeUljksrNjD9w583Dow8dGc57dlUe s/kkrZS82e2Uajdm
bNSBAARWSwB5Wy1/er9GAHljJkCgLwLF5K0vbIzWRUCSM6ncbPO+Ey8O3jap yqUtJFJmmW/lzHVc
WmVD3qSsUA6BdgjMIW+x/8GSepe3/cdOeMCDOcAcaH0OqOvqHWqQ6on+98Up b7EpF+Yp7bZat0Ve
ekz2bYpaaHS579HM9b133BKUN1UubbHyZrajz3GdK4mZVC7FSzkEILAsAnPI 27KIEO0qCLDytgrq
9AmB1RFg5W117JvrWRJSqdwEcubYruBn3lS5tMXKm+8zca5bIqe+DVMaE+UQ gEA9BJC3enLRcyTI
W8/ZZ+w9EigmbykX5j2CtsfcIi9pTFK5yejUkd3D2rnTw9pZ967KpS1G3qTP rGmxM/uyj7HiJmWC
cgi0SQB5azOvSxsV8ra0jBEvBPIIFJO3vDA4uwUCkpxJ5SaDk4dvDd42qcpj NmmlTJI31UfoFkrE
LSYL1IFAmwSQtzbzurRRIW9LyxjxQiCPQDF5S7kwzwu5jbNb5FXye96OH9oT lDdVHrv5bovU54du
m5T+sYnv832xsVEPAhBYLgHkbbm5ayly5K2lbDIWCMgEismb3BU1IBBP4PaD e4OfeVPlbBCAAARW
SQB5WyV9+tYEkDfmAgT6IlBM3lpcSZpyKvTAK2eMRw/sGw7v9++qnA0CEIDA Kgkgb6ukT9/IG3MA
An0SKCZvfeJj1BCAAAQg0CsB5K3XzNc1blbe6soH0UBgagLF5C1nlWXqQdbY PrxqzAoxQQACEIgn
gLzFs6LmdASQt+nY0jIEaiSAvK0oKz3IW8kxlmxrRSmnWwhAoDECyFtjCV3o cJC3hSaOsCEwkkAx
eRvZP6dBAAIQgAAEFkkAeVtk2poLGnlrLqUMCAJBAsXkjZWRtJnWA6+SYyzZ VlqmqA0BCEDATQB5
Y2bUQAB5qyELxACB+QgUk7f5QqYnCEAAAhCAwOoJIG+rzwERDAPyxiyAQF8E iskbKyNpE6cHXiXH
mNPW+g/vHEK7ytz3/n/+TVoCqQ0BCHRPAHnrfgpUAQB5qyINBAGB2QgUk7fZ IqYjCCQSeMvJm4eN
zSvO/eMfeWSrNSVvu/9f/zSx5WHYsWNH8By7XKofasx1rjqm99TgpVik8tT+ qA+B1gggb61ldJnj
Qd6WmTeihsBYAsXkLWdlZGzwSz6vB14lx5jT1htfd8sLxO27f/Rdg9pfdvz+ 4eU/cGJL3sYKXIpw
5QiRJII5bbvGULq9Jb9eiR0CLgJzyJt+k+bx8tbtgewwYA4wB5gD1+aAujbe oZ+sX7g0qJ0NAi0Q
OHX01uGZjae29o3N7ftHf+Xt0StvrlUuLThmmSk99jm+NlyrZzHnmvnxyZZ0 PDb2FuYCY4BASQJz
yFvJeGmrTQKsvLWZV0YFAR8BVt5WNDdyVpJWFHJytyXHqNuKfTSDfd1r/8nw g//Hbc5dlalN+syb
b9XLlDeXSKWulvnaU22HVsLGlKXGnjwBOAECjRNA3hpP8EKGh7wtJFGECYFC BIrJW6F4aAYCVRKw
V6ds8ZHkTg/KVc+18uVbiXPBGXt7I/JW5VQjqAURQN4WlKyGQ0XeGk4uQ4OA g0AxeSu5ytJDpnrg
VesY/x+33Zk8xWJuPSyx8mYHZkqcK4ax4mau5MWKZzI0ToBA4wSQt8YTvJDh IW8LSRRhQqAQgWLy
VigemoHApASUuJWQt5Irby7pGyOCPnClxHPSxNA4BBZIAHlbYNIaDBl5azCp DAkCAQLF5K3WVZZa
s98Dr1rHOEbe9EqVfTujdOuheZ6ei642Yo7Zbflu5bTn/Fh5c8Ve6+uJuCCw CgLI2yqo06dNAHlj
TkCgLwLF5K0vbIx2yQTGytuSx0zsEIBAeQLIW3mmtJhOAHlLZ8YZEFgygWLy VusqS63J6YFXjWPU
t00icLW+MogLAsshgLwtJ1ctR4q8tZxdxgaBFxIoJm/AhQAEIAABCPREAHnr Kdv1jhV5qzc3RAaB
KQgUk7caV1mmAFaqzR549TDGUvOBdiAAgeURQN6Wl7MWI0beWswqY4KAnwDy tqLZ0YPY9DDGFU0f
uoUABCoggLxVkARCGJA3JgEE+iJQTN76wsZoIQABCECgdwLIW+8zoI7xI291 5IEoIDAXgWLyxipL
Wsp64JUzxvV7bhqkPY04tSEAAQiUJYC8leVJa+MIIG/juHEWBJZKoJi8LRUA cddJQInbxuYV767K
2SAAAQiskgDytkr69K0JIG/MBQj0RaCYvOWssvSF/NpoW+SlxiTtsbl+5O6d QXlT5Tmb74urc9rk
XAhAoC8CyFtf+a51tMhbrZkhLghMQ6CYvE0THq0uiYAkpFK5OdYH79o5PLPx 1Na+sfn8rp9ffVTl
sZsSNXNX55WUN7vt2LioBwEILJvAHPKm36R5vLz1jznYYcAcYA4wB67NAXVd vUM/Wb9waVB7ypZy
YZ7Sbqt1W+Rlj8kWpJQxP3DnzcOjDx0Zznt2VR6z+SStlLzZ7ZRqN2Zs1IEA BFZLYA55W+0I6X0J
BFh5W0KWiBEC5Qiw8laOZfctlZS3+068OHjbpCqXtpBImWW+lTPXcWmVDXmT skI5BNohgLy1k8sl
jwR5W3L2iB0C6QSKyVvKqkp6mO2d0SIvPSb7NkUtNLrc92hm+d47bgnKmyqX tlh5M9vR57jOldpD
3KSMUA6Btgggb23lc6mjQd6WmjnihsA4AsXkbVz3nNUSgZIrb2eO7Qp+5k2V S5skW/p832fiXLdE
SoImlUsxUw4BCCyHAPK2nFy1HCny1nJ2GRsEXkigmLy1uJI05YRpkVdJeTt1 ZPewdu70sHbWvaty
aYuRN+kza1rs7NW5qT9LJ42NcghAYPUEkLfV54AIhq1/XMAGAQj0Q6CYvPWD jJH6CEhCKpWb7Z48
fGvwtklVHrNJkiXJm+ojdAtlzPkxcVIHAhBYHgHkbXk5azFi5K3FrDImCPgJ FJO3lAtzEsL3vElz
4PihPUF5U+Wxm++2SH1+6LbJsf/YJDY26kEAAsslgLwtN3ctRY68tZRNxgIB mUAxeZO7ogYE4gnc
fnBv8DNvqpwNAhCAwCoJIG+rpE/fmgDyxlyAQF8EiskbK29pE6cHXjljPHpg 33B4v39X5WwQgAAE
VkkAeVslffpG3pgDEOiTQDF56xMfo4YABCAAgV4JIG+9Zr6ucbPyVlc+iAYC UxMoJm85qyxTD7LG
9uFVY1aICQIQgEA8AeQtnhU1pyOAvE3HlpYhUCMB5G1FWelB3noY44qmD91C AAIVEEDeKkgCIfBV
AcwBCHRGoJi8dcaN4UIAAhCAQOcEkLfOJ0Alw2flrZJEEAYEZiJQTN5YZUnL WA+8csa4fs9Ng7Sn
Eac2BCAAgbIEkLeyPGltHAHkbRw3zoLAUgkUk7elAiDuOgkocdvYvOLdVTkb BCAAgVUSQN5WSZ++
NQHkjbkAgb4IFJO3nFWWvpBfG22LvNSYpD0214/cvTMob6qcDQIQgMAqCcwh b/pNmsfLW5/tYocB
c4A5wBy4NgfUNfcO/WT9wqVB7WwQSCEgCalUbvb14F07g1/Srcpjth07dgx6 j6kfW8dsVz2P2WLr
xbRFHQhAYPUE5pC31Y+SCGonwMpb7RkiPgiUJcDKW1me0a2liEx0oyuuaI/J lpWUMT9w583Dow8d
Gc57dlWespUWJ7u9mPZj6qSMiboQgMBqCSBvq+VP79cIIG/MBAj0RaCYvPWF jdG6CJSUt/tOvDh4
26QqT9lMcXKtxoVkLKa+iiWmD3sVcKqVwRQ21IUABMYRQN7GceOssgSQt7I8 aQ0CtRMoJm8pqyq1
Q5kjvhZ56THZtxRqqdHlvkeT+7133BKUN1WesvlWvfTx2JU0X31b3szYYvtg ZS4lo9SFwOoJIG+r
zwERsPLGHIBAbwSKyVtv4BjvCwmUXHk7c2xX8DNvqjxl862K2cddEub6fJtL tKQ+XII45rNzKeOm
LgQgMB0B5G06trQcT4CVt3hW1IRACwSKyVuLK0lTJrhFXiXl7dSR3cPaudPD 2ln3rspTtpjVL1cd
34pcSN5iz2GlLSWD1IVAfQSQt/py0mNEyFuPWWfMPRMoJm89Q2Ts1whIQiqV mxxPHr41eNukKk/Z
YuRNtSfdPhnTzlh5Q+ZSMkpdCKyeAPK2+hwQAbdNMgcg0BuBYvKWcmHeG2TX eFvkJX3HW8qYjx/a
E5Q3VS5tvn8GErpV0beiZrcl3e7oK9fHdey+GKWxUQ4BCKyeAPK2+hwQAfLG HIBAbwSKyVtv4Bjv
tARuP7g3+Jk3Vc4GAQhAYJUEkLdV0qdvTYDbJpkLEOiLQDF5S1lV6Quxe7Tw Cs+Cowf2DYf3+3dV
zgYBCEBglQSQt1XSp2/kjTkAgT4JFJO3PvExaghAAAIQ6JUA8tZr5usaNytv deWDaCAwNYFi8sZK
Ulqq4JXGi9oQgAAEaiOAvNWWkT7jQd76zDuj7pcA8rai3CNvKwJPtxCAAAQK EUDeCoGkmSwCyFsW
Pk6GwOIIFJO3xY2cgCEAAQhAAAIZBJC3DHicWowA8lYMJQ1BYBEEiskbK0lp +YZXGi9qQwACEKiN
APJWW0b6jAd56zPvjLpfAsXkrV+Eqx/5v/yH/3b1QRABBCAAgc4IzCFv+k2a x8sDDGDAHGAOMAdu
zAG1ELRDAVFP1i9c2tpTNlaSwrRKfoH1+Vd/eFh/5WPX99d919ltP6tytnYJ uL5IvN3RMjII1Etg
Dnmrd/REVgsBVt5qyQRxQGAeAqy8zcN5S4pDm1RunvvIKz40PHbPk8Pj5z4+ vOfIR4f1Vz227WdV
Lm1KAOzdPEeXSe2o8lA7dpux7el2x5xv9yGNNSamUnViWYX6Q95KZYN2IJBH AHnL48fZZQggb2U4
0goElkKgmLylyMdS4JSM0+ZjX4Cn8Hvryz+4JW5Pvu0zw8W7Pja88aXnt/2s yqVNEoBUeSshWS7p
ksaRUi6NOaWtsXXtGMbENOacsfFyHgQg4CeAvDE7aiCAvNWQBWKAwHwEisnb fCEvs6eS8nb/y969
teKmxO3CgY8MR245te1nVS5tIQEwy2JEwSck+rjr0ZRDWxTN+nY9Na6QAJkr W5IMhuL2tZN6PCWG
2LZ9+Yk53z43RdKlOUU5BHojgLz1lvE6x4u81ZkXooLAVASKyVvKytFUg6m5 Xc3HdwufLvc96rGp
f06iPuOmVtvUrsRN7/qYKpf+iUno9r2S8uZqKyQfppxJUqiZ2HJoH0/9Obff 0DyMXXnzjSnEx+xX
YhIbR82vKWKDwKoJIG+rzgD9KwLIG/MAAn0RKCZvfWFLH23JlTclaeZn3pS8 mT+rcmkrvfLmWvWJ
kaCQ3EkrbKbI6OexUhoSv9gVOXuFUGLuitEWLpujK0++1TLX2FPHEjMG6kAA AtcIIG/MhBoIIG81
ZIEYIDAfgWLyxspbOGkl5e31L3k4+Jk3VS5tPnlzrQyGRM8WKFtGXD/nrryZ faasEvpEyCWBUtwu
vjG3IIa4x/bpWlWLEWUfN2muUA4BCLgJIG/MjBoIIG81ZIEYIDAfgWLyNl/I y+xJklup3Bz1qX33
b/uMm1ppMz8Dp8qlLVYiQnKm+4htS5IOu1y6tS+33Bd/qgiFhNXOQw4rV7wu piFJk+pL84ZyCEDg
BgHkjdlQAwHkrYYsEAME5iNQTN5S5GO+4dXTU8nveXvHax4flKDpXX3GzfxZ lUuba4XNJ2qrWnnT
8aQIh33bYYxYuWTN147reKjPWHkzx2qv4Nntx94KacpebtzSfKIcAj0SQN56 zHp9Y0be6ssJEUFg
SgLF5G3KIGk7TED65yTw8xMI3UrZIjdJxFscM2OCwFQEkLepyNJuCgHkLYUW dSGwfALF5I2Vt+VP
BmkErtW6pcvAVPJWE6uUlUFpDlAOAQjcIIC8MRtqIIC81ZAFYoDAfASKydt8 IdMTBCAAAQhAYPUE
kLfV54AI+KoA5gAEeiNQTN5Yeett6jBeCEAAAn0TQN76zn8to2flrZZMEAcE 5iGAvM3DmV4gAAEI
QKAxAshbYwld6HCQt4UmjrAhMJJAMXkb2f/woZ/aG9zHtst5EIAABCAAgSkJ IG9T0qXtWALIWywp
6kGgDQLF5G3sbZNK3jaf/bZz//TFf7cldmwQgAAEIACB2gjMIW/6TZrHywMM YMAcYA4wB27MAeVe
OxQQ9WT9wqWtfY7t/T/5T4ZnNp9z7n/4kXuGzyBwc6SBPiAAAQhAIJHAHPKW GBLVOyTAyluHSWfI
XRMYvfJW6kunP/1bbx++tfHcoL6rTD2a+9OXf3JQAvfpi4eG97zptlGJGvOv 7O0vSR7VceRJUnxS
eWQ33mpTtx8TXw0xhOKccz6sgpfE3/el4DGxUgcCLRNA3lrO7nLGhrwtJ1dE CoESBLLkLRRAzG2U
51/94WH9lY9t7a/7rrPXn6vj3/jWc9f3//bfnxsu/PhLRo239gvT1PhiIUjt 6nZi68X2O6aejqGG
WOz4e4hJGqNP3lzfZTcm/5wDgaUSQN6Wmrm24kbe2sono4GARGCl8vbWl39w ePJtnxku3vWx4Y0v
PX/9uTr+9avydn3/5nPDz73hn0pjcZaPvTAd1dmIk1LjG9FF8BSp/9L9udqr IQbfOGuMrXRMUnsh
eZtjftAHBGolgLzVmpm+4kLe+so3o4XASuXt/pe9e0vcLhz4yHDkllPXn6vj X/nGs9v29bMvFSXE
XAnQlc0LT1+5eVtcTB3Vtr1aZJ/nutUudPuZvYphx596rhmfa0zmGMy+7Lhd q2K+WO0Ehfq1mdtM
Y8/V57l4x8Qj5c0Xh9l2bqwSY7svX758c046HvMa8b2eQtLrmkup8yv0op+T O28VEHARQN6YFzUQ
QN5qyAIxQGA+AtnyZl/I6wtBfduk71F9xk3dKqlW3JS4qV09V7s6rsq/9PXN 6/uDa98typvrIteW
nhQp8gmOKQzSRa19YRy6EA/F75M36bgkfa74XSIl1XOJUmw+XCKceq4vPilu X35cQuWagBJ/X77H
MpbitduN4egbq08qTaYugXK95kKcYl8jsSxT5uKYvuf79UxPtRNA3mrPUB/x IW995JlRQkATyJY3
H8qYz7y9/iUPO2+bVMe/+NXN6/tfXH3+5h/5Z8GsxVxE26IZkrOUi367ndAF 4RLlLeai2XXBHMPb
JRuxF/r6XFc/Y+Jx5c0n/z6BCUlfzByVxjS1vEk5i5nbqfJmz69S+RzzGo7p m7cPCJhvoOp56r+u
Vu+Pt9122/X/7Kx+Ntswf4Y2BCQCyJtEiHIItEVgpfJ2at/912+VVCtu+hZK dfzPvry5bf+JH/7n
WfKWcuEcIytjV7R6kjdXwkIX9tIKkC1MLvn2TRKfhEkyFCNvqeO0pSI0l1wS 6pKSGPGU+I5lFIpx
jEDF/IqNiXWqvmPio04fBFh56yPPtY8Seas9Q8QHgbIEVipv73jN44MSNbWr WyX1c3X881/a2Lb/
2A/9i8XLW6zwmVKSesFt14/ts4TchlZlYlakpLG6xLfk+GIEyBbGWG4u0Ywd rySYvphiY5PiiOk/
9AePqcfuer3k/gEm5Q8DZX8l09qSCCBvS8pWu7Eib+3mlpFBwEUgS96k73qL Qf5rj79v+JO/2tj6
jJt6dO1//Jcbw5k7Xy7Km3nLk+uv7r5bovRx3wWb1G7ogj72wjcUmzkWXyz2 8ZQLclf7Ln4xcdgX
zSZbXz8u4ZTGGduPVE/Kj2uFxyVFMePU88Su6+tDqifF7uvPPm634+s3NG7X ObHH7Be2K/c+AZyD
e8zvMer0SQB56zPvtY0aeastI8QDgWkJjJa3UmGdOvE9w+f+4hlx/5Hj3yPK W6mY5mjHtyqS27dL
BFxtxtaT4inVji1ZUr89lk/BOoXjqvtPiZW6EJiDAPI2B2X6kAggbxIhyiHQ FoGVy9vdr/ve4e7j
an/F8EOve8X15zd+vnpM1blaFtqWdmFZUt58KxVT8RrTX8rLZmm5TBlbTt1V c1l1/znsOBcCUxBA
3qagSpupBJC3VGLUh8CyCaxc3paNj+ghAAEIQKBXAshbr5mva9zIW135IBoI TE0AeZuaMO1DAAIQ
gECTBJC3JtO6uEEhb4tLGQFDIItAlfIW8x1xWaPmZAhAAAIQgEAmAeQtEyCn FyGAvBXBSCMQWAyB
KuVtMfQIFAIQgAAEuiUwh7ylfgE49S8nf2k6zGDGHGAOLHEOqMWuHSpw9WT9 wqWtfVUbK2+rIk+/
EIAABCAQS2AOeYuNhXr9EmDlrd/cM/I+CTS/8qa+P44NAhCAAAQgUJoA8laa KO2NIYC8jaHGORBY
LoEq5E36su+Ulbjzr/7wsP7Kx67vr/uus9t+VuVsEIAABCAAgVwCyFsuQc4v QQB5K0GRNiCwHALV
yFsIWYq8PfKKDw2P3fPk8Pi5jw/vOfLRYf1Vj237WZWzQQACEIAABHIJIG+5 BDm/BAHkrQRF2oDA
cgg0J29vffkHt8Ttybd9Zrh418eGN770/LafVTkbBCAAAQhAIJcA8pZLkPNL EEDeSlCkDQgsh0Bz
8nb/y969teKmxO3CgY8MR245te1nVR6z7dixY9C7Wd913HdMnafK9OZrMyYe 6kAAAhCAQF0EkLe6
8tFrNMhbr5ln3L0SqEreTLkxxUnfNul71MlT/5xEfcZNrbapXYmb3vUxVS79 ExNTuEwBs4/bcmbX
tcXNlsBeJx3jhgAEINACAeSthSwufwzI2/JzyAggkEKgKnnzBZ7ymTclaeZn 3pS8mT+rcmnzSWSq
vNmyZrcrxUE5BCAAAQjUSwB5qzc3PUWGvPWUbcYKgeH6d1mu9HveJDmTys1E vv4lDwc/86bKpc0l
aeqcXHmT+qUcAhCAAASWQwB5W06uWo4UeWs5u4wNAi8k0NzK26l992/7jJta aTM/A6fKpa3UbZNm
P742pVgohwAEIACBOgkgb3XmpbeokLfeMs54eydQjbxJ3/UWm6h3vObxQQma 3tVn3MyfVXnMVuof
ltgC5/onKDHxUAcCEIAABOoigLzVlY9eo0Hees084+6VQBXyNiV86Z+TTNk3 bUMAAhCAQLsEkLd2
c7ukkSFvS8oWsUIgn0Dz8paPiBYgAAEIQAACLySAvDEraiCAvNWQBWKAwHwE kLf5WNMTBCAAAQg0
RAB5ayiZCx4K8rbg5BE6BEYQQN5GQOMUCEAAAhCAAPLGHKiBAPJWQxaIAQLz EWhe3lK+ZmA+7PQE
AQhAAAJLJzCHvOk3aR4vX/9uI1jAgjnAHGAOXB5W+j1vS38DJ34IQAACEOiP wBzy1h9VRpxKgJW3
VGLUh8CyCbDyFsjf+j03DdK+7PQTPQQgAAEIjCWAvI0lx3klCSBvJWnSFgTq J9C8vOWkQInbxuYV
767K2SAAAQhAoE8CyFufea9t1MhbbRkhHghMS6A5eZO+7DvlM3CP3L0zKG+q vKZNfQE42zwEYD0P
Z3qBQM0EkLeas9NPbMhbP7lmpBBQBJqUt1BqU+Ttwbt2Ds9sPLW1b2w+v+vn Vx9VubSpi3x7N8/R
Zfax0M92n1okUoUitb40Vqk8xMLFqGR8JdtS4zSZh/IrMdHlpeOL7Zd6EIDA eALI23h2nFmOAPJW
jiUtQWAJBJqXN/uiOEXeHrjz5uHRh44M5z27Kpc26aK8hLyNFQApNmlsqf36 +ks9HhtXigCntjlW
mH39lMpF6jioDwEIjCeAvI1nx5nlCCBv5VjSEgSWQAB5C2TpvhMvDt42qcql LXRRbpbZz02pM1d2
VH+2OPhWgXxy5apv1nUJZcw4JQFJlbTYcbvG6TrXZuqSO5eU2W25cuDi4zpP n2sz9o3VHltsfFK+
KIcABPIJIG/5DGkhnwDyls+QFiCwJALNypt9K5u+6NUrb75HM3n33nFLUN5U ubSFbqkLyZtLLGzB
8l3Y5x73SZ80VlNMJJmxRS4kSNK4pfGasuUbmy20vrG6xNmVY9f4fExy4ovt JyZ31IEABNIIIG9p
vKg9DQHkbRqutAqBWgk0K2++i/SU2ybPHNsV/MybKpe2sStvkry5yn0X8inH Q7JpytmYVTbpHEnC
JFFxrUpJsib1aY/ZJW8xomqLeuxKmxSf748U0rykHAIQyCeAvOUzpIV8Ashb PkNagMCSCCBvgWyd
OrJ7WDt3elg7695VubT5hMV10e2Tj7HSIrUntSuNLSQtvrKYNqW4JSFzMZfG mtpnSBS18MUwGNuv
j0EMX+pAAAJlCCBvZTjSSh4B5C2PH2dDYGkEmpc3OyEpK28nD98avG1SlUtb SN7sc1Mv5O0L+JQV
NpdgSIITGquWUamOxMuMS4ondrwpY43tM1XepNym9isJbAxn6kAAAnkEkLc8 fpxdhgDyVoYjrUBg
KQSalDfpu95ik3P80J6gvKlyafPd1iatDtkyZP4ckhb7djzzIt9V5uvHJ52u 8cbWDbGQ4nYJmD4W
GpcZW2isIRmz4w4JpslHGlMox76x+eZNjDxLc5VyCEAgjQDylsaL2tMQQN6m 4UqrEKiVQHPyVhL0
7Qf3Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5S7lN0kZ99MC+ 4fB+/67K2SAAAQhA
oE8CyFufea9t1MhbbRkhHghMS6B5eZsWH61DAAIQgECvBJC3XjNf17iRt7ry QTQQmJoA8jY1YdqH
AAQgAIEmCcwhb/pNmsfLAwxgwBxgDjAHbswBdXfhDgVEPVm/cGlrb2HLuW2y hfEzBghAAAIQmIbA
HPI2TeS02hIBVt5ayiZjgYBMgJU3mRE1IAABCEAAAi8ggLwxKWoggLzVkAVi gMB8BJqXt5yVt/V7
bhqkfb5U0RMEIAABCNREAHmrKRv9xoK89Zt7Rt4ngeblLSetStw2Nq94d1XO BgEIQAACfRJA3vrM
e22jRt5qywjxQGBaAs3Jm/QF3SkrcY/cvTMob6qcbXkEpC8Vzy1fHhEihgAE xhBA3sZQ45zSBJC3
0kRpDwJ1E2hS3kLIU+Ttwbt2Br+kW5VLmxIBezfP0WVSO2PKJQnRbdr1Ys8b E1PMOT5mLlZj+Enj
0+WhOGLGUaqOFG+pfmgHAhBII4C8pfGi9jQEkLdpuNIqBGol0Ly82Re+KfL2 wJ03D48+dGQ479lV
ubRJF95j5EPq0ydlvvOkGGP7k+rF9uOrtwp5c40pdhwSj9jyufuLjYt6EOid APLW+wyoY/zIWx15
IAoIzEUAeQuQvu/Ei4O3TapyaQtdeJtl9nNz1ceUMddxVS7Vd7XhO+aLJSaO GB6SjITkTY/V9ejj
YB+PGZ/Zvj2mmPNN0QxJZ2reJb6UQwAC8xFA3uZjTU9+AsgbswMCfRFoVt58 t7zplTffo5n+e++4
JShvqlza7DjM+iF5c9Wzpca8vS+mvk9CctuVZMzFKLTi6GNmj9f3symZLgmL 5RYbR6g/V45zeUtz
jnIIQGAeAsjbPJzpJUwAeWOGQKAvAs3Km31BrX9OuW3yzLFdwc+8qXJpG7vy FiNjsRJit2Wv0uXK
hGuMvhVCn0D6pDZFdseMwyVoPq4uSQudb4uj2a50nnnuGDmW5iXlEIBAPgHk LZ8hLeQTQN7yGdIC
BJZEAHkLZOvUkd3D2rnTw9pZ967Kpc134e1aGUyVsbH1XRJSQhYlFi6JdJ0T YuaS8rEcpH5yy0Py
FjNuSSJTeFMXAhAoTwB5K8+UFtMJIG/pzDgDAksm0Ly82clJWXk7efjW4G2T qlzaJAEoIU2pK06r
lLfQ7ZIuMXPxsZmXkjfpNswx3LhtUnqFUA6B5RJA3pabu5YiR95ayiZjgYBM oEl5k77rTcZyrcbx
Q3uC8qbKpc21wqbO8d1q6CqT5ESf4xIj+5jrdj3zfLt/1+2PPlmMYSHVscdi xh8jwq54XW2aIuZi
FBuHxMclb758hbjGSG8MW+pAAALlCCBv5VjS0ngCyNt4dpwJgSUSaE7eSibh 9oN7g595U+VsEIAA
BCDQJwHkrc+81zZq5K22jBAPBKYl0Ly8pdwmaaM+emDfcHi/f1flbBCAAAQg 0CcB5K3PvNc2auSt
towQDwSmJdC8vE2Lj9YhAAEIQKBXAnPIm36T5vHyAAMYMAeYA8yBG3NALVDt UEDUk/ULl7Z2NghA
AAIQgAAE3ATmkDfYQ0AiwMqbRIhyCLRFoPmVt5zbJttKNaOBAAQgAIGSBJC3 kjRpaywB5G0sOc6D
wDIJNC9vy0wLUUMAAhCAQO0EkLfaM9RHfMhbH3lmlBDQBJqXt5yVt/V7bhqk nakEAQhAAAJ9EkDe
+sx7baNG3mrLCPFAYFoCzctbDj4lbhubV7y7KmeDAAQgAIE+CSBvfea9tlEj b7VlhHggMC2B5uRN
+oLulJW4R+7eGZQ3VT7F5vsy6in6mqrNKcbAF1VPlS3ahQAExhBA3sZQ45zS BJC30kRpDwJ1E2hS
3kLIU+Ttwbt2Br+kW5VLmxYO89E8xy5XZVOIjxRnqHyVY9AsbCa1Mcrhy7kQ gMAyCSBvy8xba1Ej
b61llPFAIEygeXmzL/JT5O2BO28eHn3oyHDes6tyaQtJhq9sLjGJ7aeGMcTG KuWDcghAAAKlCCBv
pUjSTg4B5C2HHudCYHkEkLdAzu478eLgbZOqXNrGCJp5TsyKnY7BVzdmVU2q 4yqPlbqcMZgrb+Zt
kxIj34qdlC/KIQABCMQSQN5iSVFvSgLI25R0aRsC9RFoVt58t/rplTffo5mi e++4JShvqlzaXLdF
qnNixcdsPyQkuStToc+TrXIM0m2TvtspQ+ORckY5BCAAgRgCyFsMJepMTQB5 m5ow7UOgLgLNypvG
nHPb5Jlju4KfeVPl0lZy5c1ehbLFThLCGKFxtbHKMcTIm0suc2VWyivlEIAA BJA35kANBJC3GrJA
DBCYjwDyFmB96sjuYe3c6WHtrHtX5dKWIz6+VSVTTF11xoiLtPLmGqcki+qc 3DHEyFtqbFLOKIcA
BCAQQwB5i6FEnakJIG9TE6Z9CNRFoHl5s3Gn/MOSk4dvDd42qcqlLUZw7DYk YTHrp6yU+SRHkr1V
jkFiEbptUsoN5RCAAARyCCBvOfQ4txQB5K0USdqBwDIINClv0ne9xabm+KE9 QXlT5dJm39LnWykz
V77MOr5bAu2VMrOeFJMul6TNrOeKw1eujpcagyRvui8Xj1gO1IMABCAwhgDy NoYa55QmgLyVJkp7
EKibQHPyVhL37Qf3Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5 S7lN0kZ99MC+4fB+
/67K2SAAAQhAoE8Cc8ibfpPm8fIAAxgwB5gDzIEbc0A5zg4FRD1Zv3Bpa2eD AAQgAAEIQMBNYA55
gz0EJAKsvEmEKIdAWwSaX3lrK12MBgIQgAAEaiGAvNWSib7jQN76zj+j749A 8/KWc9tkf9OBEUMA
AhCAQCwB5C2WFPWmJIC8TUmXtiFQH4Hm5a0+5EQEAQhAAAItEEDeWsji8seA vC0/h4wAAikEmpe3
nJW39XtuGqQ9BTZ1IQABCECgHQLIWzu5XPJIkLclZ4/YIZBOoHl5S0dy4wwl bhubV7y7KmeDAAQg
AIE+CSBvfea9tlEjb7VlhHggMC2B5uRN+oLulJW4R+7eGZQ3VT7FFvvl2Sl9 219inXJuy3Ul1lJ5
y2wYGwQgECaAvDFDaiCAvNWQBWKAwHwEmpS3EL4UeXvwrp3BL+lW5dKmpcl8 NM+xy1VZKWHQ7djt
lWpfGrtd7mPhEsu5YjQZTZmLWFZzjTs2HupBAAJ+Asgbs6MGAshbDVkgBgjM R6B5ebMvhlPk7YE7
bx4efejIcN6zq3JpC12M+8pKX8CXbs8lZRKHkJTWIm+uMUzNbizLGN7UgQAE piWAvE3Ll9bjCCBv
cZyoBYFWCCBvgUzed+LFwdsmVbm0jRE085yYFTsdg13XtapkS5Srfd+KXWis MbdlSizscfvGpcdg
9ukTQOm4NFYpFy7mrpVOOw7XKp9rXNL8ohwCEFgdAeRtdezp+QYB5I3ZAIG+ CDQrb75b9PTKm+/R
TP+9d9wSlDdVLm2hi3TfuSmSYwqO3Z5PTGKOj11xCkmcxMInb+a4XLG7znMJ lC2u5s8psdnnuXIQ
w1galzS3KIcABFZLAHlbLX96v0YAeWMmQKAvAs3Km09qUm6bPHNsV/Azb6pc 2iQRc53vW+2xV9Ls
i/9cYZFWobS0jF1li2HhkzPXCpckTS4hi2Vkt+37Y4BPOO1cheL3yaA0tyiH AARWSwB5Wy1/ekfe
mAMQ6JEA8hbI+qkju4e1c6eHtbPuXZVLW4yw2G1IqzamWLhkxD5/rLBIY/OJ Z+qYQytnMbHHrLz5
ZF4S1thyU8BiZCxmXGP4cw4EIDAfAeRtPtb05CfAyhuzAwJ9EWhe3ux0pqy8 nTx8a/C2SVUubT6R
sS/2zXZi5c3Xxlh5k0QlNNaxq3GuMZhtxUhOjLxJTCXhXHUc0jyjHAIQmJ8A 8jY/c3p8IQHkjVkB
gb4INClv0ne9xab4+KE9QXlT5dLmu91Onyfd2ucrt2XJvi3PlCKfeOg6rrak cblkUzrHxyK0emjH
6JIwl7z5xhZqLyUXZv5inkuM7TGEpF/iTDkEIDAPAeRtHs70EiaAvDFDINAX gebkrWT6bj+4N/iZ
N1XOBgEIQAACfRKYQ970mzSPl7f+MQc7DJgDzAHmwLU5oBardugn6xcuDWpv YUu5TdIe79ED+4bD
+/27KmeDAAQgAIE+Ccwhb32SZdQpBFh5S6FFXQgsnwArb8vPISOAAAQgAIEV EEDeVgCdLl9AAHlj
UkCgLwLIW1/5ZrQQgAAEIFCIAPJWCCTNZBFA3rLwcTIEFkegeXnLuW1ycdkk YAhAAAIQmI0A8jYb
ajoKEEDemB4Q6ItA8/LWVzoZLQQgAAEIzEUAeZuLNP2ECCBvzA8I9EWgeXnL WXlbv+emQdr7mi6M
FgIQgAAENAHkjblQAwHkrYYsEAME5iPQvLzloFTitrF5xburcjYIQAACEOiT APLWZ95rGzXyVltG
iAcC0xJoTt6kL+hOWYl75O6dQXlT5WzzEpjiy6vtL9Ced0T0BgEILJUA8rbU zLUVN/LWVj4ZDQQk
Ak3KW2jQKfL24F07g1/SrcqlTYuB+ajOsY9L7ehzYuuNaT+m7ZJ1fGx0H64x lJI33Y7dXqn2S3Ki
LQhAoE4CyFudeektKuStt4wz3t4JNC9v9sV4irw9cOfNw6MPHRnOe3ZVLm0+ GRgjDalikVpfGkts
eWy/oXqx3GJj8tWLjTW3H86HAATaI4C8tZfTJY4IeVti1ogZAuMJIG8Bdved eHHwtklVLm0pEmLW
tVfqVD+xx3RMkiCaq0+utn19SmM2zwvVTWHjGlNKzK6VT9f4YnKgz4vhQB0I QKBdAshbu7ld0siQ
tyVli1ghkE+gWXnz3ZKnV958jybSe++4JShvqlzafLcvusRFkhlplShW1mwR 8p0ntSeNXZK4FDY+
IZXG4hMt6bbJEBMpDzFcqAMBCCyfAPK2/By2MALkrYUsMgYIxBNoVt58F/sp t02eObYr+Jk3VS5t
kpCZ5/tWfXyiYcqRFiFfeyHJkUTFt8Jl9x9iMUZWXe3FMHKNJ1VQffKPuEkz nnII9EMAeesn1zWP
FHmrOTvEBoHyBJC3ANNTR3YPa+dOD2tn3bsql7Yx8pYqGj5RDQmTLUEu6Ssh Ki6p9MUrHdeyaD6G
xh6SuNSVt5jYpLlAOQQg0BYB5K2tfC51NMjbUjNH3BAYR6B5ebOxpKy8nTx8 a/C2SVUubbHyNkam
pNsax/SdIkihsYekLUaEpNilsbsEzzW2VFEuIbTSnKEcAhBYBgHkbRl5aj1K 5K31DDM+CGwn0KS8
Sd/1FjsJjh/aE5Q3VS5todvvYm9HdN0qaAqQrx1JgGLbiBExk0Os4PjYhOKK vW3SV88Wx5AEurjG
jk2aF5RDAALLJzCHvOk3aR4vDzCAAXOAOcAcuDEHlO/sUEDUk/ULl7b23rfb D+4NfuZNlS9tC91K
ubSxEC8EIACBVRKYQ95WOT76XgYBVt6WkSeihEApAs2tvNlgUm6TtM89emDf cHi/f1flS9uQt6Vl
jHghAIFaCSBvtWamr7iQt77yzWgh0Ly8kWIIQAACEIDAFASQtymo0mYqAeQt lRj1IbBsAsjbsvNH
9BCAAAQgsCICyNuKwNPtNgLIGxMCAn0RaF7ecm6b7GsqMFoIQAACEEghgLyl 0KLuVASQt6nI0i4E
6iTQvLzViZ2oIAABCEBg6QSQt6VnsI34kbc28sgoIBBLoHl5y1l5W7/npkHa Y0FTDwIQgAAE2iKA
vLWVz6WOBnlbauaIGwLjCDQvb+OwXDtLidvG5hXvrsrZIAABCECgTwLIW595 r23UyFttGSEeCExL
oDl5k76gO2Ul7pG7dwblTZWzQQACEIBAnwSQtz7zXtuokbfaMkI8EJiWQJPy FkKWIm8P3rUz+CXd
qlza1Peq2bs6x3dcam9V5bHjiInP9V1zrvOWxihm7NSBAATaIYC8tZPLJY8E eVty9ogdAukEmpc3
WxRS5O2BO28eHn3oyHDes6tyafOJSqzASO3nlsfGETuOmPZi6pjjSq2fy4Tz IQABCMQQQN5iKFFn
agLI29SEaR8CdRFA3gL5uO/Ei4O3TapyaYuVHt2Oa5VOldnt6J/N+rpequzo NkJjSRmHWdeOz4xR
qmcyCcmci4WLV8w4pXxSDgEIQEATQN6YCzUQQN5qyAIxQGA+As3Km++WO73y 5ns00d97xy1BeVPl
0haSMZ/YuEQlJG8uyUkVOEn8YqXSJZp2fFJsvrFKMhfDKBSflEvKIQABCJgE kDfmQw0EkLcaskAM
EJiPQLPy5rvQT7lt8syxXcHPvKlyaUtZsXKJhbmqJEmdvZJlx+aSRVf8rphT xuFbUfONxRRH1+pY
KJ7QmH0rcpI8SjmlHAIQgIAigLwxD2oggLzVkAVigMB8BJC3AOtTR3YPa+dO D2tn3bsql7YU6Zla
3mJizY3XHMPYlTBp5c3XR2x/EgfKIQABCMQQQN5iKFFnagLI29SEaR8CdRFo Xt5s3CkrbycP3xq8
bVKVS1uuDJVcefPFGvNZsNhxxK6EmbFIsjam7xiJlHJHOQQgAIEQgTnkTb9J 83h5a6WTHQbMAeYA
c+DaHFBOs0M/Wb9waVD7EreS3/N2/NCeoLypcmmzPysm3coXEhnX5858shR7 a2BKPV//odsxXedo
sZJur9RsU+TNF0soRimHlEMAAhBwEZhD3iAPAYkAK28SIcoh0BaB5lbeSqbn 9oN7g595U+VsqyEQ
+hzcaiKiVwhAoDcCyFtvGa9zvMhbnXkhKghMRaB5eUu5TdKGfPTAvuHwfv+u ytlWQwB5Ww13eoUA
BG4QQN6YDTUQQN5qyAIxQGA+As3L23wo6QkCEIAABHoigLz1lO16x4q81Zsb IoPAFASQtymo0iYE
IAABCDRPAHlrPsWLGCDytog0ESQEihFoXt5ybpssRpmGIAABCECgOQLIW3Mp XeSAkLdFpo2gITCa
QPPyNpoMJ0IAAhCAAAQCBJA3pkcNBJC3GrJADBCYj0Dz8paz8rZ+z02DtM+X KnqCAAQgAIGaCCBv
NWWj31iQt35zz8j7JNC8vOWkVYnbxuYV767K2SAAAQhAoE8CyFufea9t1Mhb bRkhHghMS6A5eSv5
Jd2P3L0zKG+qnO0Ggdgv/F4yM2mMUvmSx07sEIDAdgLIGzOiBgLIWw1ZIAYI zEegSXkL4Uu5jfLB
u3YGv6RblUubupi3d3WO77jUXmp56PvQSovGFO2F2JksSvft46z7CeU1NUc5 9ecad06MnAuBVgkg
b61mdlnjQt6WlS+ihUAugeblzb64TZG3B+68eXj0oSPDec+uyqXNd3E910V3 qJ/SMcS2l1tPi9Oq
5c2V+9ixSfMmtnzu/mLjoh4EeiCAvPWQ5frHiLzVnyMihEBJAshbgOZ9J14c vG1SlUtbqry5VppU
H3Y7rhUgXc+sK6282SJk9q/HZvZlHnOdK/Gwzw/Vl9j5xukbgxmvTwCl4y4W PoksGUdoXrhijs0D
9SAAgfEEkLfx7DizHAHkrRxLWoLAEgg0K2++29r0ypvv0UzavXfcEpQ3VS5t MRfdIdnyyYJPqELC
JZVJgugbqyQ0kqCFJC1FJl39jOUUwz02NlO+Q8IpSbpLEn3spHlJOQQgkE8A ectnSAv5BJC3fIa0
AIElEWhW3mxR0T+n3DZ55tiu4GfeVLm0SatH9vkhgZIu3l1iIK282W26ZNPX hi0vUj1J4iQWrpz6
5CwUm49TzNglUTXLpfamjEOal5RDAAL5BJC3fIa0kE8AectnSAsQWBIB5C2Q rVNHdg9r504Pa2fd
uyqXtqXJm2s8PqG0ZWrMKpAWnJh+Y+QtRn5jJVf1F9OeJNWucrvtWCkswVya s5RDAAJxBOaQN/0m
zePlAQYwYA4wB5gDN+aAWpDaoYCoJ+sXLm3tS9yklTWp3BzzycO3Bm+bVOXS tmR5k24dzBGJkLS5
JM0nQFqCpFjnul2xljikeUk5BCCQT2AOecuPkhZaJ8DKW+sZZnwQ2E6gyZU3 6bveYifB8UN7gvKm
yqXNvnUu5bY61+pM7u2AvjZNYbLFSrodUlo1shnFrtCF2NkyZ8tZKidTAl2r ba72Ym6LDLEMCaWU
A9d4pblIOQQgUJYA8laWJ62NI4C8jePGWRBYKoHm5K1kIm4/uDf4mTdVzgYB CEAAAn0SQN76zHtt
o0beassI8UBgWgLNy1vKbZI26qMH9g2H9/t3Vc4GAQhAAAJ9EkDe+sx7baNG 3mrLCPFAYFoCzcvb
tPhoHQIQgAAEeiWAvPWa+brGjbzVlQ+igcDUBJC3qQnTPgQgAAEINEkAeWsy rYsbFPK2uJQRMASy
CDQvbzm3TWaR5WQIQAACEGiaAPLWdHoXMzjkbTGpIlAIFCHQvLwVoUQjEIAA BCAAAYsA8saUqIEA
8lZDFogBAvMRaF7eclbe1u+5aZD2+VJFTxCAAAQgUBMB5K2mbPQbC/LWb+4Z eZ8Empe3nLQqcdvY
vOLdVTkbBCAAAQj0SQB56zPvtY0aeastI8QDgWkJNCdv0hd0p6zEPXL3zqC8 qXK2+QlIX/KdWz7/
iOgRAhBYIgHkbYlZay9m5K29nDIiCIQINClvoQGnyNuDd+0Mfkm3Kpc2JRL2 rs7xHZfaM8slSUlp
q2Rdacz2GFLHIdXX5aE4So5XakuKVzqfcghAoE4CyFudeektKuStt4wz3t4J NC9v9oVzirw9cOfN
w6MPHRnOe3ZVLm2+C/cSF/Ql2pDiHyOLoTHbZVqwSsZhypur3Vq5pTCgLgQg sHoCyNvqc0AEw4C8
MQsg0BcB5C2Q7/tOvDh426Qql7Yx8mauGLlWqVwrS7qe61xbZlwCJY3Dbj9U XxpzKJ6YsZvtx4zX
jjXmfFMqXYLp61c6HsuZehCAQP0EkLf6c9RDhMhbD1lmjBC4QaBZefPdMqdX 3nyP5uS4945bgvKm
yqXNjsMlWaHVp9AqkiRhtuSZfdtSKI3DJUDSCps9Lp+0+caYezzEXo3Hx8+W O5tbzHlm+3Ov9KXm
kvoQgMA4AsjbOG6cVZYA8laWJ61BoHYCzcqbT1RSbps8c2xX8DNvqlzapFUo 1/ku6XC1kyJvLvly
CYxLLkNjjInLlQuXII2RohArib1P8GPkLSZHIfGW5g3lEIBA/QTmkDf9Js3j 5a3bA9lhwBxgDjAH
rs0B5TQ79JP1C5cGtS9xs+XMvoBPkbdTR3YPa+dOD2tn3bsqlzZJIHxSZQtP jCTFyo8pbWNXhWJW
C0NjKyVvPvmVxDSm3K4jyVgKf2neUA4BCNRPYA55q58CEa6aACtvq84A/UNg XgLNr7zZOFPk7eTh
W4O3TapyaatV3kLyEhpTSNps4ZTEVBLUErdNpsidq78pJVOaO5RDAAJ1E0De 6s5PL9Ehb71kmnFC
4BqBJuVN+q632OQfP7QnKG+qXNpibs1zSY55nik5tjz5fvbd+mf2lbrqFls/ dcx2rC5BdN2mqAXU
xcAuM+tI/Um3TUr9uiQ2RnqluUQ5BCBQFwHkra589BoN8tZr5hl3rwSak7eS ibz94N7gZ95U+VK3
WBFb6viIGwIQgMDUBJC3qQnTfgwB5C2GEnUg0A6B5uUt5TZJO61HD+wbDu/3 76p8qRvyttTMETcE
IFALAeStlkz0HQfy1nf+GX1/BJqXt/5SyoghAAEIQGAOAsjbHJTpQyKAvEmE KIdAWwSQt7byyWgg
AAEIQGAmAsjbTKDpJkgAeWOCQKAvAs3LW85tk31NBUYLAQhAAAIpBJC3FFrU nYoA8jYVWdqFQJ0E
mpe3OrETFQQgAAEILJ0A8rb0DLYRP/LWRh4ZBQRiCTQvbzkrb+v33DRIeyxo 6kEAAhCAQFsEkLe2
8rnU0SBvS80ccUNgHIHm5W0clmtnKXHb2Lzi3VU5GwQgAAEI9EkAeesz77WN GnmrLSPEA4FpCTQn
b9IXdKesxD1y986gvKnyVW/Sv/zPLV/1+KbuX+Izdf+0DwEILJcA8rbc3LUU OfLWUjYZCwRkAk3K
W2jYKfL24F07g1/SrcqlTcmBvatz9DHzfNexmPZDdbSchOKQ+ihZPpUs+can YzfLbea+8Y2Jdcw5
JfnSFgQgMB8B5G0+1vTkJ4C8MTsg0BeB5uXNvphOkbcH7rx5ePShI8N5z67K pc13Mb8KeXPFOrds
pPYXWz9Uzy4zf45tX8qzKYmxdakHAQgsmwDytuz8tRI98tZKJhkHBOIIIG8B TvedeHHwtklVLm0h
eVPnmitj5s/6eUjy7DLX6pLdvh2vLTJSm1I8psT44kldYYypL3H2jdtesbPj d43HbMseo2+FT5on
lEMAAssjgLwtL2ctRoy8tZhVxgQBP4Fm5c13G51eefM9mqjuveOWoLypcmkL yUFI3nyrRWOPx8Zh
yopLJkPlrvFI9SV+LlFynSONLyRvdh9SzCEhLr2Sl8KHuhCAwLwE5pA3/SbN 4+UBBjBgDjAHmAM3
5oBymR0KiHqyfuHS1r7Ezb4t0r6YTrlt8syxXcHPvKlyaYtZEXLdxjdG0lwC E7vy5pNdV2y2pIX6
lUTIJWeSALnKYzi7JM3HecwYbdmV5gblEIDAsgnMIW/LJkT0cxBg5W0OyvQB gXoINLvyZkuD/jlF
3k4d2T2snTs9rJ1176pc2mKkopS8uWJJkbfQ+baYxLabIm8xLGN4uiTNbtsX f0wufHMLeZMySDkE
2iKAvLWVz6WOBnlbauaIGwLjCDQvbzaWFHk7efjW4G2TqlzaxsrGmJU3l7TE SlZMfzFiI0mRtKrm
E0jpvFB5zOqaS8jGjEWKU5ovlEMAAsshgLwtJ1ctR4q8tZxdxgaBFxJoUt6k 73qLnQjHD+0Jypsq
l7aY2xFd0qVXcfT5dh2zXVM87PqmgEi3N/raDImNL05JmGIlJ6Wea3whNnbs MTG76riYx8YtzR/K
IQCBegkgb/XmpqfIkLeess1YITBc//xvM595K5nU2w/uDX7mTZWztUsAAWs3 t4wMAiUIIG8lKNJG
LgHkLZcg50NgWQSaW3mz8afcJmmfe/TAvuHwfv+uytnaJIC4tZlXRgWBkgSQ t5I0aWssAeRtLDnO
g8AyCTQvb8tMC1FDAAIQgEDtBJC32jPUR3zIWx95ZpQQ0ASQN+YCBCAAAQhA YAQB5G0ENE4pTgB5
K46UBiFQNYHm5S3ntsmqM0dwEIAABCCwUgLI20rx0/nzBJA3pgIE+iLQvLz1 lU5GCwEIQAACcxFA
3uYiTT8hAsgb8wMCfRFoXt5yVt7W77lpkPa+pgujhQAEIAABTQB5Yy7UQAB5 qyELxACB+Qg0L285
KJW4bWxe8e6qnA0CEIAABPokgLz1mffaRo281ZYR4oHAtASakzfpC7pTVuIe uXtnUN5U+RI36d/g
S+VLHPMUMUuccsuniJk2IQCBcgSQt3IsaWk8AeRtPDvOhMASCTQpb6FEpMjb g3ftDH5JtyqXNnUB
b+/qHH3MPF+62Jf6ii3X/YRii22rRL2pxp3KPjUOqX4vnEvMAdqAwBIJIG9L zFp7MSNv7eWUEUEg
RKB5ebMvsFPk7YE7bx4efejIcN6zq3Jp813g1yJvrvglK
Re: Primitive types and Java types in XMI [message #477362 is a reply to message #477359] |
Wed, 07 May 2008 08:05   |
Originally posted by: swt.magellium.fr
For the moment, I solved the problem thanks to Bruno : I modified
Bouml's XMI export code.
Whenever the exporter founds an attribute's type name which starts with
the string "ECore", it creates the following XMI tag :
<type xmi:type="uml:PrimitiveType"
href="pathmap://UML_METAMODELS/Ecore.metamodel.uml#XXXX"/>
Where XXXX is the second part of the type name.
For instance, if I want to use EDate, I just have to use "ECoreEDate" as
type name under my Bouml model :)
PS : For people who use Enterprise Architect (v7.1b829 or later) and
wish to use their models under Eclipse, I strongly suggest to do the
following :
1) Export the EA model (I didn't try with packages but it should work)
using XMI 2.1 (you should disable "full EA roundtrip", check "Exclude EA
tagged value", and uncheck "Export diagrams", I know it works this way).
2) Create a new project under Bouml, import the XMI you just created
using EA (tools->import xmi 2.1).
3) Clean the model (remove EA empty packages, etc.)
4) Generate a new XMI 2.1 using Bouml (check "use PrimitiveType rather
than DataType" and "Generate for Eclipse".
5) You can use the XMI under eclipse !
This way you'll avoid many problem that you may encounter when trying to
directly import the XMIs generated by EA into eclipse...
@Bruno : I can send you the new XMI Generator "plug out" with my changes
if you want (I just added 2 lines of code...) and an explanation on how
to properly declare the types under EA before sending XMIs to Bouml...
(But that will be next week, sorry)
Stephane
Bruno Pagès wrote :
> Thanks, but Bouml doesn't know Ecore. I take into account Eclipse in XMI
> import/export (Eclipse isn't compatible with standard XMI) but there are
> limits ;-)
> Furthermore Stephane wants to XMI export the non primitive type Date
> into a Ecore primitive type, this can't be done in a 'natural' way.
> I will have to do 'something' in Bouml to allow to ask for special
> class/datatype XMI export, and Stephane will have to configure Bouml to
> use this new feature
> Best regards
Re: Primitive types and Java types in XMI [message #477363 is a reply to message #477362] |
Wed, 07 May 2008 09:57   |
Stephane,
That was my point - you could/should be using
" pathmap://UML_LIBRARIES/EcorePrimitiveTypes.library.uml#XXXX" instead of
referencing the Ecore metamodel. Another alternative to chaning the could
would be to adding mappings to the URI converter (before loading the
resource) which will map the URIs produced by Bouml to the URIs expected by
UML2...
Kenn
"SWT" <swt@magellium.fr> wrote in message
news:48219B27.1050306@magellium.fr...
> For the moment, I solved the problem thanks to Bruno : I modified Bouml's
> XMI export code.
> PS : For people who use Enterprise Architect (v7.1b829 or later) and wish
> to use their models under Eclipse, I strongly suggest to do the following
> 2) Create a new project under Bouml, import the XMI you just created using
> if you want (I just added 2 lines of code...) and an explanation on how to
> Stephane
> Bruno Pag
Re: Primitive types and Java types in XMI [message #477371 is a reply to message #477362] |
Sat, 10 May 2008 03:43  |
Originally posted by: bouml.free.fr
> @Bruno : I can send you the new XMI Generator "plug out" with my changes if
I can easily imagine the modifications made in my XMI generator, and sorry
but I am not interested by how to properly declare the types under EA !
Your management of EA and Bouml is very strange and a little bit "usine à
gaz", for me you have two better solutions :
- you give money to use EA, ask them to perform some changes, or
- stop to use EA and use Bouml for free
Bruno
Re: Primitive types and Java types in XMI [message #626454 is a reply to message #477293] |
Wed, 30 April 2008 07:58  |
--------------040303020009020802070604
Stephane,
If I look at Ecore.uml it looks like as below, so I imagine you need to
SWT wrote:
> Hello all !
> least with Bouml) except for primitive types and java types.
> For instance, in Bouml, if I define a class attribute with type "int",
> <ownedAttribute xmi:type="uml:Property" name="myIntAttribute"
> xmi:id="BOUML_0x1f482_1" visibility="private">
> <type xmi:type="uml:Class" xmi:idref="BOUML_datatype_0"/>
> </ownedAttribute>
> <packagedElement xmi:type="uml:DataType" xmi:id="BOUML_datatype_0"
> name="int"/>
> After importing that into eclipse, I get an "int" class definition.
> If I use EMF to generate the corresponding model classes, it will
> result in creating a "int" class (public class int extends EObject) !
> Of course, I'd like to use the primitive java type int instead of this
> class !
> java.util.Date...
> Or should I use some transformation (xsl) on my XMI files in order to
> Maybe there's a way under Eclipse, to switch attribute types from
> Thanks in advance !
> Stephane
Content-Type: multipart/related;
boundary="------------010504060308020405060403"
--------------010504060308020405060403
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Stephane,<br>
<br>
apply the Ecore profile and set the Instance Class Name<br>
<br>
<blockquote><img src="cid:part1.01070906.02080900@ca.ibm.com" alt=""><br>
</blockquote>
<br>
<br>
SWT wrote:
<blockquote cite="mid:fv9dne$18j$1@build.eclipse.org" type="cite">Hello
all !
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</ownedAttribute>
<br>
<br>
<br>
<br>
name="int"/>
<br>
<br>
<br>
<br>
class !
<br>
java.util.Date...
<br>
<br>
<br>
<br>
Maybe there's a way under Eclipse, to switch attribute types from "fake
<br>
<br>
<br>
<br>
Thanks in advance !
<br>
Stephane
<br>
</blockquote>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="moz-screenshot-8.jpg"
Content-ID: <part1.01070906.02080900@ca.ibm.com>
Content-Disposition: inline;
filename="moz-screenshot-8.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDABALDA4MChAODQ4SERATGCgaGBYW GDEjJR0oOjM9
PDkzODdASFxOQERXRTc4UG1RV19iZ2hnPk1xeXBkeFxlZ2P/2wBDARESEhgV GC8aGi9jQjhC
Y2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2NjY2Nj Y2NjY2P/wAAR
CAHdAxMDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDr8iw06Qx4LohYkj7zAdTV e61sQSBUgdxj
JLK644Y/3f8AZ/zg0t7JmyuB/wBM2/lWdqLXDzqTbRsQvULv7N3KHvj8/fIi o2o3RcEm9Tov
MqnaazaXjRiFpcSjMbSQPGr8Z+UsADxzgdgT2pfMrF0y1ng0mzmke4uJre3V oraTYgV/LxjI
UEcEr8xPXnmrIOl8ymC6ja4eAN+8RVdlx0DEgH/x0/lXI28l2rvG8t5JYhka RlinR8ESZC7i
ZD8wiztOPb72bMf2hL83Crdm1WGLcGB81gHlI56nGVJX7xBGcnKsAdR5lHmV yV5PqX9oSNaG
ZJn8xBH5cjIAI22NuY+XywQ8AEZwT1zFNLI1zNFYzXyW4EJl84Tuyg+bkgEh +SE+6e3pmgDr
bq9itIDNOzBAQvyqWJJIAAABJ5Iotr1LqMvGJVAOP3kTRn8mAP41z9x9oPh6 NXkneRZo23rE
fMCiZSCFO48KM85PHPOakmuLmSyg+wSzyXKzEK91E0an5WJ8wBV+XB4wPvbf egDofMpkF1Hc
28c8Lbo5VDo2MZBGQa5OzmkadhE+otcJNAEExkIEflxFw/8ABuwXJzzk8c4o 077XFb2kbLdp
coLdYlw4jEQVPMDD7mf9Z975umP4aAOv8yjzK40rqItrIfaLuNvssZX5JZWM xyX3YYAc7eJP
l+gBrb0syLBKZjKXa4mP7xiePMYLjPQbQMAcUAW59VSC7eF4pdkcaySzDGyN WLAFuc/wnJAw
OpwOaj+221/dJA9q7o8byQzsF2uoKglTncPvDBwM9QSMGqs90y6tFthlZ4Y9 0RRSFlZsgqz4
wqjAYg8k7SBlcEgumbVpd0MqvNHulLqSsTLgBVfGGU5LADkHcSMtgAEtzbtb ZdWLw55B6oPr
3H+eetR1e8yqM0YgJdB+67j+5/8AW/l9OgAVUSaf7WyOuEGSc9AvY5/z3q3V K78oySCSQodi
7cNjJye3ftSZMu5cVlZQykEHoQaaJUMzQhv3iKGIx0BJA/8AQTUNiFETYcsx b5s9jgf0xUEl
tNLq0zpPPbp5EY3RqpDHdJx8ynpkdPWhaoad1cuQTx3CK8RLI6K6ttIBB6df 5VJXOCO+W0tY
1M8US21uJMI524WTIAUhs52Zwc9M8VYhW8RJmc3EuLdFQsHXgu+W2hskhdp6 7+AMgmmM26Y8
qRvGrthpG2oMdTgn+QNYNuNQYyCN7hjHHP5DMrxgttj25Dkk8l8bie/pxYaA Ty2y25v1hE+W
aTeCP3cgOC/zDOQM9ORjBzQBskAggjIPUGmRE/MpOdjYyfz/AK1jx/bPtCwF pcyN8m5iNqRT
HJOeTuRkGeSe/rWvF9+b/f8A/ZRQBIAT098DBJ4x6A+oobKY3K2PXYwA/MVL a+Y02yB0SXax
BdCwH3e2R6HvU11HeraubmaCRMrgRxFDncO5Y1dlYi7uU4gDfRAjPyt/T/P+ NWW5UvFGrIjA
Mduc8gHGPT156Y55qvD/AMf0X+439P8AP9D0p98I0wWYBZGBdTt2vjB/iOM9 B3yPXAJwqNqN
0axSb1J1aEsq7CpPA3Rlcn05HX8+h6/xMuAAigDA3HH5L/n/AB61BD5fmvPb LbrHGuGUFMkc
55BOOg68dffM85DRqwzhmJ5GD0X/AD/jRTnzBKNjHEt2iutxfW0c4J8uFbRm Mw7bP3gz79Nv
fjDG7bCcW6fajGZsfP5YIXPtnmpKK0JKNxcTJetH53kRCNWVvsUs+5iWyMoR jGF6+tFvcTPe
rH53nxGNmZvsUsG1gVwMuTnOW6elXqKAKl9Lco1tHaJvlml2Y2BjjYzcAso/ h7moZ21e1VJJ
4CsRljRi0CKAGcL1E7Hv6GrU4nW4tLi3SOR7eUuUkcoCCjL1AP8Ae9Kdf3eo X9utu9nbRIZY
3Z1uWYgK6twNgz09aABhtmRhxvO1h68ZB/SprZggaViNzEjJ7KDjH6Z//VUU v34f9/8A9lNV
bhma1kiVtrNvA/76NVFXZnVlyxuakE/2hCIryBpgMmMLk5xnA+bnr1FKtwTk MpVl4ZT2NZOl
2l4dQSdhOsQkLlmZCCCg/PPTI/nVu7m231wM/wAQ/wDQRQ4crVmZqbcW2rEh 1aAXLW485pFY
K22F2UEgHlgMDgjvVnz/AHrmobgxarcl5LlRJMCqLCTG37tRkttOOR6jpTGm uP8ASDG1z9t/
e7eT5ePm2fe+Tps6c56/xU7C5jqPP96PP965aOSRryEQNd/ZBKpPmNIDkLJn O75tufL9v1o0
qa5jl3XM0zkoBKpifAckdCWI9fuAL3OBiiwcx1Pn+9MmvEghkmlbbHGpZjjO ABk1yt7c3n2Z
oYhc+ask7F1zjBWQoM9+q4xnBAHBxTb4XAguo4jcOpLxKpdnyhhJ75z8/fr2 zjigLnX+f71T
g1cSxQv5E8clwge3iYLumBGQVwSPrkjaOTgc1D5/vUVhqappzRbLpUuQz3Dp mNrZmHIjUjLE
dSR1JJGSdoGhwknuW4pIryIyiJreXe6tkAMGVipzg4PIPc0oYhtj43diOjD/ AD2qjZ3Ia2UB
QiqSigIUBUEgEKeVBABx2zUzShhgn369DRygqtnZlqiooZg/ysRu/nUtQbp3 1QUUUUDCiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKAJPMo8ytSw/wCPOP8AH+ZqMSXE 5DpBFtjkYDdL
gnBK/wB04/CgDP8AMo8yte2lM0O9lCsGZSAcjIJHX8KqxXM1xHvI8kgldisD yDg5OPUdqmUl
FXY0rlLzKPMq1cyyyrHA0LFjJE4ZAWU4kBbnHGAM8+vetCSRIo2kkdURAWZm OAoHUk1XS4ut
jDcrIjJIoZGBDKwyCPQ0y3igtUKW0McKE5KxoFBPrxWzHf2c3k+VdwP5+7yt sgPmbfvbfXHf
FFpf2d7v+x3cFxsxu8qQPtz0zj6GgDL8yjzK1Fv7N/P2XcDfZ8+diQHysZzu 9Oh6+hqu+qwt
PbJbvBLFcIzLN5w2fK6JgEA5Pz8e4x3yACipVSxVQC5yxA6nAGT+AA/CneZW lDqVhcRyyQXt
tKkI3SMkqsEHPJIPHQ/lTmv7NPI33cC/aMeTmQDzc4xt9eo6eooAy/Mo8yto yIJFjLqHYFgu
eSBjJx7ZH5iqp1bTRuzqFoNiB2zMvCnGCeeh3Dn3HrQBn+ZR5lXDfXUs9zDa WkcjQS+WWkm2
LjYjdlJz8+MYxweRwDYtb2G5tLW4Vti3SK0auQGOV3Y+uMnj0NAGX5lHmVpP qVhHJ5b3tsr4
ZtplUHC53HGe21s+mD6UQXqXF7JBHtZFgjmWVWyHDlwMf98Zz70AYxi2nMLB B/d25X8qjZS2
4SQbtwAO1gR+uK6G5laGHeqhmLKoBOBkkDr+NNe6iW5jgDo0jtgqGGVG0nOP w/WldBYwIv3S
bY7dwOvUf40/zG/54yfmv+Nb8c8MoBjljcE7QVYHJxnH5U7zE2F967Vzls8D HWgLWOe8xv8A
njJ+a/40eY3/ADxk/Nf8a3jc24iEpnjEbHAcuME/Wmfa0WWVZGjjWM4LM+M8 Kc/+PY/L1oug
MTzG/wCeMn5r/jR5jf8APGT81/xrfE8JRHEsZVztVtwwx9B60omiMpiEiGRR koGGQPpTuBzi
hUkeRLUrJJjewCgtjpk55pUZ1ZyYX+ZsjlfQD19q6IzRCURGRBIwyELDJH0p jXdsqK7XEQV8
7WLjBx1xSuBgs2771uxx67f8aQYByLUg/wDAf8a6CGVpHmVlCmN9vBzkYBB/ WpqdwOcjfEwk
aOUFVIAAU5z/AMCHpVk3n/TOX/vhf/i/f/OTnaooAwHkR5/NZJzwBtKrtOCS D97tmia43qAs
MpO4k5Cjrj/aPpW/RSSS2Hc5vzG/54yfmv8AjR5jf88ZPzX/ABrpKKYjm/Mb /njJ+a/40eY3
/PGT81/xrpKKAOb8xv8AnjJ+a/40eY3/ADxk/Nf8a37gAxgEZBZcg/7wrmpd dtIdSj095Yhc
OMgeWuAewJxwT2H+IyASM7NLEDGy/MeTj+6fQ1Uc5dvZm/mabYsWvL0k8/bT /wCilra0D793
/v8A9Wqk7GdSPMkjD8qP+4v5U5VCjCgAewrr7gZt5RjOUPGM54+h/kfpUlHM uxn7FvqcbRXZ
UU+cX1fzONorsqpiS4nIdIItscjAbpcE4JX+6cfhRzh9X8zmaK622lM0O9lC sGZSAcjIJHX8
KxrzUZ4RIVllLhzhAFAx5uwY+Uk9ewP6imncToW6mXRWy1xeSSyRpOEZyJI9 67cKWULkHlcY
IKkZbJwR/DieMv8AkLRf9cB/6E1UtXYzqw9nHmuOorD+zS/aPI2fvO65Hy8Z OfTHfPTBz0pB
BM0DTLE5iU4Zwp2g+5/EVVjm9o+xuVMlzKvBw49+D+f/ANasa7so4XnSCZpW t2IlDJt4ztyO
TkZx6Hke+I4rC6leNBC6mRGePcpG8Bd3HHPH8xScUzSNacHZI6H7Yv8Azzf9 P8aPti/885P0
/wAa5oW8gjSaWOVbdmx5gTIPrjsTweM9qlu7WOGRY7eSWZigkOY9uAVDdiex 59MVPs0X9bna
9joPti/885P0/wAaPti/885P0/xrmxZ3TRtIttMUUZZghwBjPJ+hBpBbTmNJ PKZY5G2rIwwp
P+8ePWn7Ndw+tz/lOl+2L/zzk/T/ABo+2L/zzk/T/GuZEEpeRNhDxgllPBGO vHt/Q+lR0ezQ
vrkux1X2xf8AnnJ+n+NH2xf+ecn6f41gx2aLHM93I8XlOiFUQOcsCefmGMba bLYyRuTtleHb
uWRY89U3gH0OMZ54560uRdyvrU+x0H2xf+ecn6f40fbF/wCecn6f41zclndR BjLbTIEALFkI
wCcDP41NLp80eCI5mDg+WBGc5D7MMOxz9eoHej2a7i+tT/lN77Yv/POT9P8A Gj7Yv/POT9P8
a5mOCaUqIoncuSFCqTkgZOPwoVFWfZcF4wpIbCZYH6EjvT9mhfW59jpvti/8 85P0/wAaPti/
885P0/xrnr21W3upoYWeUQkh2KbcEHHqeM4596Y9ndJE0r20yxqcFyhABzjr 9eKXs13G8XNd
DpPti/8APOT9P8aPti/885P0/wAa5sWdzmMGB180Zj3LjfxnjPX8PUUlrD9p u4YN23zXVN2M
4ycZp+zQfW59jpfti/8APOT9P8aPti/885P0/wAa59be3mk2W88rYR3JeIL9 1S2OGPXFNhsr
iWSJfLZRK6xq7KQuWwRz9CD9KXs0H1qfY6L7Yv8Azzk/T/Gj7Yv/ADzk/T/G svw2rJ4ht0dS
rKXBBGCDtNd7UySizoo1JVI32OW+2L/zzk/T/Gj7Yv8Azzk/T/GupoqdDa0u /wDX3nLfbF/5
5yfp/jR9sX/nnJ+n+NdTRRoFpd/6+85b7Yv/ADzk/T/Gj7Yv/POT9P8AGupo o0C0u/8AX3nL
fbF/55yfp/jR9sX/AJ5yfp/jXU0UaBaXf+vvOW+2L/zzk/T/ABo+2L/zzk/T /Gupoo0C0u/9
fect9sX/AJ5yfp/jR9sX/nnJ+n+NdTRRoFpd/wCvvOW+2L/zzk/T/Gj7Yv8A zzk/T/Gupoo0
C0u/9fect9sX/nnJ+n+NH2xf+ecn6f411NFGgWl3/r7zlvti/wDPOT9P8aPt i/8APOT9P8a6
mijQLS7/ANfect9sX/nnJ+n+NH2xf+ecn6f411NFGgWl3/r7zlvti/8APOT9 P8aPti/885P0
/wAa6mijQLS7/wBfect9sX/nnJ+n+NFdTRRoFpd/6+8r2H/HnH+P8zVGbTIp ZM3Om2N0xdts
ko3EAszY+4cdT3/nV6w/484/x/maklOHh5xl/Xr8p9/8fp3CKIre1AhInjjZ 2ZieNwwSxxkj
0Yj8TWQ9wZ7mYMqzCRFxCdvJyeOe4wvXgY9zXQVDNceVIkaxSSM4LAJjgDHq R6iolFtpp7FJ
pJpowJ7O2NxFE9vGkrOitGAAdpC56fVuR+fFbepWz3Vp5cZUOskcq7uASjhw Ce2duM84z0PS
ks7oSrCmx8PFvSTcrK4GOQQx9RUs8/lFUVdztkgE4GB1JP4j86SXI5Sb3Y2+ ZJJGLcaPcTG9
uLl44vtNvOkixBpTGXSJRt4BfiInoDk4GetTaTLeXWpXN5LaLDG8cUXLOPum QkgOik8svbHP
UkEUl9rxtZvJC24dSm4yTEY3N0xtz0Gc9s5we+hpt6t/aCZQgO5lZVfcAQcd eO2D+NUpJ7Cc
WldmNbeHp4YI0/d77ZI1idrmWTzNjo/3W4iB8sZChsZ/2cGxc6VeXd1BcyLa QurhnWMk9JYG
+9gbjtiPOB1Uds1uUVRJzenabfXGl2JuYIImt7JYUjZ3yxPln5uAY2HljBG4 gnP8PLp9BuJj
mTypDNAIpgJ5IVHzOSxVMCXPmHOduSCeN2B0VFAGfc29493BdQCBZY0lh2ux KhWZSH4HJGwf
Lx1PzcZNHS9EubOOzWR4iYJ0kbaTyBaiE44/vDP0/Kt6igDm7XR9StLNLULa Twts86NpmQPt
hiQAnYcrlGJGBkbc8ZB1LqC8nFtMI4BPbS+YsZlO18xlSC23IwXPY52jpnjQ ooA5+30S8QSm
WWBnklikJXIB23TzHjnHyuMDJ5796uaVps1leXc0rRlZs7QpOR++mfnj0kX8 Qa1KKAK19n7O
CFZsSRsQoJOA4J4FV5rKaVfIzGIt8jb8nd8wb+HHbd69q0aKTVx3KC2cgSR8 Kk3ylCZWk5Gc
ZY9uSCAOhPrUktqWtPs6HhdrBixBYhsnJHTOOvuat0UcqC5QjtZoXE0aRl/m BRpWPXbzuIJP
3R2HX25hmspo28xFjbDrhVBUdYu3OB8h9cCtWilyoLlBrWZyzkRB5HywJJCj AGM4+YYXkEDO
eoxmiOzkjnLgK213kUtK3JOeNvQdevP054v0UcqC5Te2laVwNnlySpKWJOQV 28Yxz93rnv7V
Unimgt/IRPMkktlhOA2AQCMg7SO/fHSteihxC5Wtc+bdNtYAy8ZBGcKo/mDV miiqQgooooAK
KKKACiiigAooooAragZxZu1ssbTDBUSMVXgjqQD/AJ9Otc8Ydb/546f/AN/3 /wDiPb/ODjpp
/wDUt/n/AD/nkdap9PbH+f6fp2x8oBgWtnc2kjm78oST3BkxExIA2bepA/um tbQPv3f+/wD1
aor7/j4g+v8ARv8AP+HQS6B9+7/3/wCrU0TLdf10NW4GbeUYzlDxjOePof5H 6VJUV0AbWYNj
aUbOemMfUfzFS0igooooAKyZtMilkzc6bY3TF22ySjcQCzNj7hx1Pf8AnWtU cpw8POMv69fl
Pv8A4/TuACK3tQISJ442dmYnjcMEscZI9GI/E1RNvcAurJclfNZ12iEry+4E bufQ/WteoZrj
ypEjWKSRnBYBMcAY9SPUU07CauUGiu5HQEXWPMQnzPJxgMDzt5rE8VzNb65b yoAWWEEZ/wB5
vy+o5Haunt523JBJDIj7MgsQQcYB6MT3HWq2rNZxGJri2tppXyq+aBkKAST0 JwPp3qlLUyqU
nONkzh0mhR5YwH+zygA9N69/xwe3AOOxxixHqCLYpFkq6RtGAIkO4MW53nkf e6Aduozx1sKa
PLBHIbexQugbaypkZGasR2GmSrujtLR16ZWNSKrnRzrCzWzOIvLu3aW7ktjK xumO7zEC7BuD
YGCcnIHPH054sf2larC0aKyq7fdWFV8tSjr94HLkb++M47Zro7VbK6nZY9Dx Esjx+e0cOzKE
qeN27qpHSrUtnpcTwpJZ2waZ9iDyRydpbHT0U/lRzof1ad73OM+2W40+WFFK u8aptEK8EMpJ
L53HOCcY4zjtRBMk2opJkJEIVjlLsAQvlhGI9TjJAGT7V2/9mWH/AD423/fp f8KP7MsP+fG2
/wC/S/4Uc6F9Wnpqcct7bmK1uJCyvBOWSJQGyFWMLuORjO3rj147VFLfxS2w jLMhZEicLCnA
Xbzv+833c44+vHPYWdrpt5ZQXUdhAEnjWRQ0K5AIyM/nVfUW0fTXjW5soFDj dv8AKQKo3omS
T05kB+gNHOhvDz7nH/akNyszKwESgRKG546bm4P4j0wMDGIorh4rkTqF3ht2 MYH4Y6fhjHbF
d20OlDUUsfsdsZ3iabAiThQQOe/Jbj6H0qSWz0uJ4Uks7YNM+xB5I5O0tjp6 Kfyo9oiPqk+5
xEd79mgnSzkniMjowIbBAAbIJHXlh9cZ46UsN8qxKJd7vmcs3XJeMKP1HNdl fW+nWVsZm02G
X50QJHEm5izBQBnA6kdTRaW+nXO9TpsMMyY3wyRJuUHoeMgg4PIJHBHUEA50 V9Vn3OSl1GF5
pHCvhpLlxwOkiBV7+vWnXOqRyvPJF5qOysqHpj995gOc8HqPwHrx17WelrcJ bmztvNdGdV8k
chSAT0/2h+dSf2ZYf8+Nt/36X/CjnQ/q8+5xS6lGJnAjEcLx7cLErBWLBmOw 8HkYHsF9KpXk
32i5aQEkYCglQvAAHQcDp07e/WvQv7MsP+fG2/79L/hR/Zlh/wA+Nt/36X/C jnRLws2rNnEp
PFPeX878W028sC4V+W3KAOecgA8HGfxqS4vYXWK6dybh4ZVMaKNoLtJ1Ocj7 2cY9PWuy/syw
/wCfG2/79L/hR/Zlh/z423/fpf8ACjnRX1afc4q81CG7Lbi4SSTzXRIkTBwc DcOW643HpycH
NVobz/iaRXkw4WVXYKOwI9ep9ycnua77+zLD/nxtv+/S/wCFH9mWH/Pjbf8A fpf8KOdCeGm3
e5wzXcYuPNa5ubkmKSMmVcEZUgY+Y8ZNSRaosV0JiruEhhjRSe6FCR7AlW/O u1/syw/58bb/
AL9L/hR/Zlh/z423/fpf8KOdB9Wmtmcb4b2jxDbhCSuXwSMEjae1d7VeKxs4 ZBJFawRuOjLG
AR+NWKiUrs6KFJ042YUUUVJsFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQBXsP8Ajzj/AB/maklOHh5xl/Xr8p9/8fp3Edh/x5x/j/M1JKCX hwW4fnBP909e
P8P6UASVSv4DLImY5nj2MreTL5bAkqRyGB/h7GrtRTXEcLKr7yzAkBUZjgYz 0HuKAMzRrD7L
BaQqs5jig2mSSXdvPyY2/McD5eg4p+pv5IRIs7gyZZizEAsF479AT6ZAJ71d t7lZNkR8zzdm
TvRlzjGeSBnrSXbWSlfthtwTnb5u3n1xmonFyVkOMlF3ZlTQxXG59squXALb mABAZvl7cMPw
9qvaIgTTwQWO53OCc4+Yj+mfqTRPd2X2bbGsNzGrAFEwwXOccdulXYggiXyg ojx8oUYGKxhT
5aju+hpKfNDQwLrSpZ7i6BsVaOWeJnZ3B8xRKjEf7QCqeGGV5VSyni1Y2bQ6 izy2GZ/Nkdr3
eo3oxYqvB3NgFRtYADbkH5VzeudRtbUyCZ2BiCFlVGY/OxVcAA5yQRgVH/a9 mLeSZmlURlQy
NBIr/Mdq4QjccngEDkg+hrpMi9RUNrcx3UZkjWVQDjEsLxn8mAP41Ha6ja3c hjgdicblLIyh
1/vISAGHI5XI5HqKALVFFNSRJFLRurgErlTnkHBH4EEUAOooqOWeOJ4UkbDT PsQY6naWx+Sn
8qAJKKhkuoo7iOByweQ7U+Q4Y4Y4zjHRGP5eozNQAUUUyR1ijaRzhUBYn0Ao AfRURnjG3c23
chf5gRgDGSc9Oo60z7ZDtJy4IONpjYMfouMnoe3Y+lK6AsUVXa8hUIcu28Eg LGzHjg5AHGM9
6kaWNIvNdgiYBy/y4+uelF0BJRUXnx/Z/tG791s37sHpjOaYLuLAJEigsF+a JhyenUUXQFii
iimAUUUUAFFFFABRRRQAUUUUAFFFFAEc/wDqW/z/AJ/zyOtU+ntj/P8AT9O2 PluT/wCpb/P+
f88jrVPp7Y/z/T9O2PlAKN9/x8QfX+jf5/w6CXQPv3f+/wD1aor7/j4g+v8A Rv8AP+HQS6B9
+7/3/wCrU0TLdf10NW4OLeU5xhDznGOPqP5j61JUdwCbeUAsCUOCpIPTtgH+ VSUigooooAKj
lOHh5xl/Xr8p9/8AH6dxJUcoJeHBbh+cE/3T14/w/pQBJVK/gMsiZjmePYyt 5MvlsCSpHIYH
+Hsau0UAZ1pa+XOm2K6SNVYkz3BkOSUwASxOPl6dPzqtrNhJJLbTRLLIsayI yqdzfMFXPJ9A
e/Ug4PNbVFAHNRi8itooR5v7sKpAhlHRQPvY6Z7YrW0nzPIkMquCXHLqQT8i gnnnqDVwE+cw
527Rj0zk+307/l3V3WNGdzhVGSfQU27jbuY+kW8trdzCSyvFMk8zeabgNDta RmUhN/HGOi5y
frVOz0e6SW0e5tldYZIZFUlT5SBZFWIc4byy4beeTnuQBW79th/6a/8Afl/8 Kcl3C7qgLhm6
bo2XPfuKQjmLbQLpYdjx3Pmkwi4kMkSCUiWNmdSgDtwrEM5DDPGSxxck0por uTdpq3WnLI/l
WiCPauUiwwRiFGGWX3y545JreaeNbhLct+9dGdVx1CkAn/x4fnUlAHJ6fod5 FPZPcRz+bEkG
10aHbEqogZCxBkHKvwvynd1GWNN/sSaRrWN9KUOkaJdzt5ZF0wmhZmPO5shH PzAHn1OK66qd
5qdtZTRxT+fvk+55dvJIGPJwCqkZwCcdcDNAGSdFvUkdknZrh7O4gW5aQ7l/ 1YiyfvdFLHH8
RYjrUdlorxSwSC0lWGK5SQwzeQvIV13qkYCDBdTnO47f9lc9NRQByJ0zUVuj OtlKXJSS4VPI
RJZFnifKYIY8CTBk5wfUmtaa3u7hL26Fv5b3EUcP2eTYzbFZix6lNxDsACSO Bk8kDYooA5fT
tKvbefzo7bb5Xnrarc+WPKLpHhiI/lVdyODt5+bpyTVzw9YzWVxdjyJ4LZ0j 2JKIV+cF9xCx
fL02cnk49hWxFPHK8yRtloX2OMdDtDY/Jh+dEU8M2PKljkyiuNrA5U5wfocH B9qAJKKKrvfW
8cV1I8mEtM+cdp+TChz9flIPFAFiiiigAooooAKKr3d7BabBKZCz52pHG0jE DqdqgnAyOenI
9RU0ciSxrJG6ujgMrKchgehBoAdRRUdxPHbW8txM22KJC7tjOABknigCSiqZ 1SyEzxtNs2bs
u6lY8rksA5G0kYOQDkbT6GmjV7Mxs5aVSCB5bQSCQ5zjCEbj0bkD+FvQ4AL1 FU01WxeaCFbm
MzXGfLi/jOM5yvUY2sDnGCMdeKkmvreC8trSWTbPc7vKXaTu2jLc9Bx60AWK KrvfW6Xi2jSY
nfGF2nnIcjnp0jf8vcUS31vDK0ckm118vI2njzGKJ+bAj+dAFiiq93ewWmwS mQs+dqRxtIxA
6naoJwMjnpyPUVNHIksayRuro4DKynIYHoQaAHUVHBPHcIXibcodkJxjlWKk fmDUlABRRVe6
vre03faJNm2J5j8pPyJjcePTcPzoAsUU1XDM4AbKHBypHYHjPXr1H07ULIjs 6o6sUO1gDnac
A4PpwQfxoAdRRRQAUUUUAFFFFABRRRQAUUUUAV7D/jzj/H+ZqSUZeHjOH9On yn2/w+vYx2H/
AB5x/j/M0+b/AFkHIHznqBz8rev9P5ZoAlqjfhjPHtknhzG6+bDHvZTlD0Ks OcHqKvVHLPDB
jzpY489N7AZoAydEtZbaCyt3mnkaC32M7RbQuNnyqSoyPlPXn3qv4ojjaG2i laNmLFg8wHAA
AI4A6kg/hW1aXEEsaJHLEWCDKIRx+AJxVik720dgtF/Ero4SyQRzLHDLCBKw UpGxXcei557E
5rrNGn8+wX/pmSn4dR+hA/CrNzcx2sYeUnBOBipQcjIrGMP3l3K7L91Q5Yxs jnLmO6v/AD5x
bz27v9ijYBctG6TlnxkYYKGB3YKn3waNRtLiL7WC93Of9DYXIiDSYE5JACrt O0Dd90n5ucjA
G0mpWEl0bWO9tnuASvlLKpfI6jGc8YNWI5EljWSN1dHAZWU5DA9CDW5BX06U S2oxJcylSQXu
YTE7d+hVfXqBWTBFdNbz2Fg93FF9keNBcx+X9mkwBGqOFG4D5ssC/wB0HPPP QVDJHbX1u0ci
RXEJJVlYB1JU8gjpwR+YoAwWmurqCO+T7cIbqUTQRRn5lUogXO0kKchmAbMf JD4JBEM9teQp
5Ye5ghNzcvKUjmkyzSBo8CNg2ChJ4O3OcjdXRXd/Z2Wz7ZdwW+/O3zZAm7HX GfqKsUAc3Ba3
0tyv2qS+JkuEilIkeMeWLYMSAjbV/ejqp65GSCQbDzXAsNCuryKdpUdXuNkD MykwOCSqjI+Y
gdOM1uUUAczqbtd6nbzvHqH2EGJv3cUyMp23AJAUBhyUB9iM8GnQC/C3cjpd uot1SEM0nCNN
L82AQS4j8sn+PjGQTXSU2ORJY1kjdXRwGVlOQwPQg0AcraQandGaBZ7sKsVy tvK6zQqGKRbS
d5LHBaTG4nocdBjUt5pLvR769bzFhu0M0CSHLJGYlAyASBkgnAPf1yK1J4Ib mFobiKOaJvvJ
IoZT35BpXaNm8lyhZ1J2EjLKMA8dxyPzFJgVTI5uvNMMn7mOQEAZzypXHrkL 26dDUfyygzuJ
xKCMskTDZwcYBHzdSOh6544xfVVRQqgKoGAAMACnUrDuZjmUyW8kjTphJBvj i3Ejcu3I2nGQ
M9B+HSr6lmYOCPLK/dKENn/PbFSUU0rBcpQx7tKjt5Eky1vtKgYP3QCOeAee 9QtnY2zzfJ8y
Hb5u7O7zBn73PTb7frWnTHjSTbvRW2ncMjOD60rBcfRRRVCCiiigAooooAKK KKACiiigAooo
oAjn/wBS3+f8/wCeR1qn09sf5/p+nbHy3J/9S3+f8/55HWqfT2x/n+n6dsfK AUb7/j4g+v8A
Rv8AP+HQS6B9+7/3/wCrVFff8fEH1/o3+f8ADoJdA+/d/wC//VqaJluv66Gr cDNvKMZyh4xn
PH0P8j9KkqK65tZuQPkbkgEDj34/OpaRQUUUUAFRyjLw8Zw/p0+U+3+H17GS qk93bCaMG5hB
RzuBZcjgjuePw/xoAt0U2ORJUDxurqejKcg1Sl1SOFXd4pBGjFTIWRV4OO7D vTSuJuxforPk
1aGMSkxyHynKHA64Kg/j83A6nsDkZ0KVhkbRZcurshIAyoHv6j3/AE+uYbuC SS0nRJGZmRgq
nGCSDgdPcfkPfNqigDnxaXoneRYbhNxP3PKzyc9SxqXT7O6iuojJC6orZLHa P4WHZjk5IrTt
L+zvd/2O7guNmN3lSB9uemcfQ1Yp8zK5mYusxxnVbKS4S8MKwTKWtRLkMWjw CY+eQD144qi8
mqi4sGn8+O6T7OkipFK6yAlfMYlT5S9XHKk/LkHlcdNJIkUbSSOqIgLMzHAU DqSahtL+zvd/
2O7guNmN3lSB9uemcfQ0iTn5RftaOqSXyJ9oHnvIkjNt2tnCoQ+d2wHyzs4B XgsBehiuTDox
lMszR3LszvGVITy5QpIJJHBUfMc8jPJNbVFAHM63JeodUSGaVPJje83rIQFj Nu0aoOc58xS2
MY4znPFNuRdMriwkvo9P3x72mSd5AcSbsAkSkZ8n7px17bq6JbS2WOaNbeIJ OWaVQgxIT1LD
vnvmpqAM+wS8/seNRP8A6RztknhP3dxxlN277uOrbu55yKdZxut7cPEjRWpJ +RxjdJn5mUfw
g9/7x5AHV5ru/s7LZ9su4Lffnb5sgTdjrjP1FSCeEwpMJY/KfbsfcNrbsBcH vnIx65oAxXtr
mO+vrqI3Ic38ARFzsKFYVdsD73G4ZOQNuRg5NZa2smn6fC0ovIsW1nbsUeTO VnxKo2nP8QC4
6gnZxmuyqFpLaeOEs8UiSlWiyQQ5HzAr69MjHpmgDNsZTBFczGO+kij3tbI4 kLtGFQsCG5Lb
92N3PpxR9imMNvZTLua5cz3siglWxglAe4JKqA3WNWHatio554baFpriWOGJ fvPIwVR25JoA
5+5i1gpdLFJJw8sCHL5PmsSrj2TdEM/wgS9cCi5i1gpdLFJJw8sCHL5PmsSr j2TdEM/wgS9c
Ct61u7a8jMlpcRToDtLROGAPpkfWpqAObuYtYKXSxSScPLAhy+T5rEq49k3R DP8ACBL1wKva
mt3cT24tHlSKUSW0hG5SmSpL9OMKjhW/vMvUGtamySJFG0kjqiICzMxwFA6k mgDFhnvI7Sd7
83cTzy8PawmTyiqopAUqxCsyuwOCMHJIJFDLLHo+nwPDPDHDsju47cSbkAiP ClcsQHKDKk98
nG6tKDUrC5Vmt722lClVYxyq2CxwoOD3PA9atUAczGmokXEjG82LHEEG58+S biTdx1L+SF5+
+OO5p1jm9kuLGL7W1mbvLm58wkRrHETGd/PzM3Q8Fd/tXQTwQ3MLQ3EUc0Tf eSRQynvyDRBB
DbQrDbxRwxL91I1CqO/AFAGDqjNqyXlt5FyJUjmjtozbuqs+xl3mQjbyCQoz jByeSApOzTaz
HqaQXP2WIxBibdw/CTg4QjceZU5A7+xx0VVYdSsLiOWSC9tpUhG6RklVgg55 JB46H8qAM22g
mC6axikA/tC4mOVIKo4nKkjt95evQnB5p08Ut1JNI9szPPJ9mg3qwEKLkmQ4 5GWUkFSM4i5U
8jYaREZFd1UudqgnG44JwPXgE/hTqAObvtOmnkt7IrJ5iXf2gXgQsCxjl2O3 bcrKoI+7jaBg
EKIXtLmGW7u57eUyzmynmCIXwVnYlRtzu2IFBx1xnvXVUUAY95cQXHk3UZ1K 3ZN8YmitGLAH
aSpRkJwcA7tuPlxkdDDM128kLX6XkcjW0ZjSy3YWf5t4OCV/uY8w7fw3VvUU AcybbUbe1aWx
Nz9qlubtQjfcVT5zJ8p+UZcIdx55xnBxTbW2upZIImuL6S1a4G8hJ4CMRy55 dzJjPl+i5xjJ
JrqKKAOXQ6iLELKLvE9vbyTSMJWaKRt5kIVCH6qg2KQF3ZxjOc++sb6+slkl 02O7kWyu4xLN
G6ycSAR4VlLbtuCoJyctznJPcUUAc7BaXc2rtBN9pt7NQ/7uCRkjGI7faqsA MAHfjGOjf7Qq
x4cjuQtxPfJKtzcCGV94IB/coDx0B3K4I4PAzxitqigAooooAKKKKACiiigA ooooAKKKKAK9
h/x5x/j/ADNSSnDw84y/r1+U+/8Aj9O4jsP+POP8f5mpJd2+HHTfz16bT6fh 14/HFAElUL+R
o7mIpcQwOYnCvMu5c7k7ZGeM96v0UAYmitcmKxjubqGe5S2Icp8xX/V5DHcc twfm7+lQeKIP
OitlcB5gxKlWKALgbu574P8Annfh5hj4I+UcEkkce/P51HdQ2siBruOF1ToZ VBC5+tJtpaOw
WjLSWxx1jHPbOY0BVJiAw8wOWIztHI45I/Wur0mcT2CeqfJ+XT9MU6GysDtl htrY4OVdI16j
0IqxFFHCu2KNI1JzhVAGayUJc/O3cv3Iw5ImJp1nc3UDrJcRC0W/mk8tYT5m UuGYfPux95R/
D0496o6Vqklvo1pbtNtmL2SQptyfJZYQxxj7uS43HvxnOBXWUVsQc3p2pXc9 3AsV5HdXMlo8
s9nI6IsEgaP5TtUsuNzjDZPHPrUZ1LUWXVJhd7UsYpJlTy1+crNOApOPu7Y1 BxzwMEc53rXT
7e1kMkfms5G3dNM8pA7gFicZwM464HoKtUAZOoXdtZ67ZSXdxFAhtp1DSuFB O6LjJ+lZs9ze
2NlaRJNHZQO87iSeQQhV8z90mWRgPkbhMAgL22kV1FFAHM2+qXTXbLLfqbsT wILFVUBkZIi7
BSvmcbnbk8beehFV7bVdWlh3G8thLIYQ8YPmm3dpY1KsoRdnDMCrMW44PBNd VFBHE8zxrhpn
3uc9TtC5/JR+VSUAc7JfzRXclpdam1tbwyOv2xxGrM2yJlUkrs58x+AAcIPQ 5o6Pf3wGmwLc
QRxrFbIkDvhpUMaFmCbCzdWG4MANvIwpz2FFAHLxalqMdhYSzXfmNeWizSP5 aqIBviVmXjss
jMS2Rlc4AyKdd6pdRIgsb9byMxyHz2VQMCSEFi4XadodzuA2jHIJU101FAHM rqd2tlE8moxE
GcqksQEvmjC4G7Yqv8xOVQBiAQp3KQemoooAKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigCOf/Ut/n/P+eR1qn09sf5/p+nbHy3J/wDUt/n/AD/nkdap9PbH+f6f p2x8oBRvv+Pi
D6/0b/P+HQS6B9+7/wB/+rVFff8AHxB9f6N/n/DoJdA+/d/7/wDVqaJluv66 GrcHFvKc4wh5
zjHH1H8x9akqO43fZ5dn3thx1649ufy5qSkUFFFFABXP3Mt159sLXULSBEuZ TKkgyR/rOW+d
cjJXjHXBzxXQUx/vx8E/N2J44Pp/X+eKAK1kXe3ZopI9pkkKnbuz87c9fp+v rxmS2v2nefJu
DiVgWQrggTb+DuBB4xkY/HArfrOkbTWkcvbK77iGb7MWyc887eaqLJkQsDFM kiQXEeTHFmRk
YY3jkncSTzgE5x2xk1o3bTpayNaorzAfKrd/1GfpkZ6ZHUUvN0qBmcRQI0TH kRDI2kBmHHQE
8ntg+hrTokxpGTLKBp8BS5lNmxP2i5LHzF5Oc9NnOQxGNnQBeqVbi/vh4gMC 3EEcayxokDvh
pUIUswTYWbqw3BgBt5GFOegoqRnN6LPDd2egLZyxyy20Si48tgTGnkkFWI6Z fZ8p6lc4+U4o
3Gp3F5K8BulETlLgqJEaW0CTxZ3KEGzaGJIbdjb14OeyooA59dVnPiOO3E8f lSyvEbZ5V8xA
qMd2wIGAJQEEsQQw45GJIZ5LbQp7iNtoivZnkbGcRi5YyH/vjd7+nNblQ3Vr FdxiOcMyA5Kh
yA3swB+YeoOQfSgDm59UvIprnzb9oJ1gM1passam4Jkl2KVK7jlVjGBhufWp odQupdUniu7u
CO3DzJLD5214ol3YfAQMmQFO8vj5uMZXHQLBGtw9wF/euiozZ6hSSB/48fzq SgDJaaf+zUeW
SVJ/MxbELiSbg7d0fA5Gcg4wPm+Qj5b073S2LPDFGbrZnZuyue+CcZ74ztz6 rnIsUUAYJEsu
o6cdPu1J+zXBaW5jaQn54twIyu057cYwRgdBGzXWnXMkEd0xVTbOyhFCs89y 3mHkEjjIAzwD
3PNdFRQBy9jqF/5FrLLeSTForOVg6IAxnfYwOFHC4yMYOTySOKh0u5vpkQre NFcahJEWJjU4
zZZEgXHd0+nyY9a66igDm7rVNRe0Fyhjs4nlWBvMkULCVVjIxkKsB+8xHypB 28feBGxpMs0+
mxSXDxySHPzx5KsASAQcDORg5AAPUcEVcooAwbO6ez8O6FPlhAI4Vn2puJUx EKAACTlyg45/
DNVbPUb1ZxFdahm/jlt4msf3fzBki8xsAbjjc7ZBwNvoDXRTWsVxJE8oZjEd yrvIXPGCVzg4
IBGQcHkU6KCOJ5njXDTPvc56naFz+Sj8qAOb03Ubq5SQ6hfRopiDyJBJult5 dy7U2iMbTkkb
GLliMc4bOlqrTv4Uv2ukVJjZy7lXt8h9zj6ZOOmT1OtRQBgz3qXemgDULO9d Ly2ybUYCgzJj
I3N6HvVPUZ9Qm0q5zM0/2qS8tEgWIcKqzbcY5LZQD0wemea6qigDm/7RvTrE cUV9A0IeJY1e
QbriMqpaQIsZLdW+ZWVRt5GAc1TrF5sjMOoLLcSW2+5t2MYFo/mRBs4Xcm0O /wB/djbkg4Nd
dVW10+3tZDJH5rORt3TTPKQO4BYnGcDOOuB6CgDm5rnUL2wntjdLcq9ndlfs +JPPwsYUbtih
sF2+4B0AOSDVjW7u2vo7qSzuIrlItLu1kaFw4Qt5eASOmdrY+h9K6aigDl59 Wu4WI068/tKM
ZKSbUfzH8mZvLygAOCkZwOfm64Iot9Tu/KxNqcBtTKqveRSpJ5IKuTl/LWMc qgwQT83+0tdJ
LBHK8LyLloX3oc9DtK5/Jj+dSUAYumMZNaklN00yPZxiN9gUTBZJPm6c4BXl cKd4OMFcbVFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAFew/wCPOP8A H+ZqSUZeHjOH
9Onyn2/w+vYx2H/HnH+P8zT5v9ZBwD856kcfK3r/AE/lmgCWqF/G0lzEEt4Z 3ETlUmbaudyd
8HHGe1X6jlghnx50UcmOm9QcUAZGirciKxkubWGC5e2JcJ8pb/V5LDaMNyfl 7etWrycx3EBm
AXCOwCsTz8o9BzyR+PvirNpBbxxpJDFGpZB8wVQSPqvH5cUtxaQXWzzkyUOV YMVI9eRzUTi5
RsiotJ6mVO05jkeKPa79MXDA5weSBxkAevatOwuXu7fzWiEfzEABt2cfgO+R +FRvpyCPEDsj
Zzl2aQdCOhPuams7f7LbLDu3YyScYySSf61lTjUjPXYuUouOm5yV5PeromrW aN8sz3kySYHy
RrJJ5i478hRnr++4+5Wta2ST+INQmk0+zlCXK/6RIcyoRDGRtG098fxDqfx2 jBCYXhMUflPu
3ptG1t2S2R3zk59c1C+m2El0LqSytnuAQ3mtEpfI6HOM8YFdBkZ8VpYW/iO+ umt7aIx20Upl
KKu0lptzZ7ZA5PtVfSL+Vbpmkhud95G0zxSQNFtlHSNS4AY7MLwQP3Rb+Imt 54IZPM8yKNvN
TY+5Qd688H1HJ49zTmjR2RnRWKHcpIztOCMj04JH40AcvdpPc3h8gtBcHVFd A7Yw4swwViue
MjDY6jNRyOmpXDFLWK4DauVaC5OF3LaYYNww4IPQEZHHrXVeRDv3+VHv3792 0Z3bdufrt4z6
cUeRDv3+VHv37920Z3bdufrt4z6cUANtIEt7WOKOCK3Cj/VQj5FJ5OOB3z2F TUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBHP8A6lv8 /wCf88jrVPp7
Y/z/AE/Ttj5bk/8AqW/z/n/PI61T6e2P8/0/Ttj5QCjff8fEH1/o3+f8Ogl0 D793/v8A9WqK
+/4+IPr/AEb/AD/h0Eugffu/9/8Aq1NEy3X9dDVuBm3lGM5Q8Yznj6H+R+lS VFdcWs3APyNw
SADx78fnUtIoKKKKACufuYrrz7Y2un2k6PcyiV5Dgn/WcN8jYGQvOeuBjmug qrLaWhlQtbxF
nc5OxfmOCec9fw5/DNADbIOluyxRx7RJIFG7bj5246fT9fTnJurcXSSRl5Np lYMvkuwGJ9xI
4KngEcg9unOegjjSJAkaKijoqjAFUZBpyyOGugjbiWUXTLgk88buOauLJkVS IlmDfvJBI0as
JbdhvbePnJwADgDpjpznAxqXcz29rJLHC0zoMhF7/lk/kCfQE8VW8qxQlmmY +XIAd87EBsjA
IJ9Sv5ir9KTQ1fqZstxKlraot0r/AGk4N4FGxd3I2jkc5wucjpkscBq82qXw 1aSKK2U2kM8c
EjsVGSwU53FwRjePlCHOMZ541jBCYXhMUflPu3ptG1t2S2R3zk59c01rS2e6 S6e3ia4QbVlK
Auo54B6jqfzqRmDosENpZ6A1nFHFLcxKbjy1AMieSSWYDrh9nzHoWxn5jmO6 1e+n2Rx/u4rl
4pbW48vaCnnxDkCQlgRIM52ccY546C0sLOy3/Y7SC3343eVGE3Y6Zx9TTV02 wWSaRbK2Dzhl
lYRLmQHqGOOc980AZ7ajLPqa2z26zadcyPbBmjAG5VbcCS5LcowwUA9z3h05 YdL0ie4tLaCI
/bXWVljCgRi5ZSTjHCoSeeAB6VsfYLP7Z9s+yQfav+e3ljf0x97r04pt1YRX Nq1tuaKGQnzU
iCjzA2dynjvk5IwfegDHOs37JeXCfZhBaQNcbTGxMyeZKF2tuwMpGpBwR82e nFTQalf3V80R
h8m0kllt0lGwMpTcNwJcljlD8uwYz1IHOhJpdnNqP26aCOWcIioZEDeXtLEF cjIOW/QVI1hZ
tNLM1pAZZk2SOYxudemCe44HB9KAKf26Z9L+1+ZGjRvwwU+XcjoNo5YBs8Yy c4xvGN1ye4ki
sWuFtpGkCbvJ/iB9DjPTvjJ44BOAZmjR2RnRWKHcpIztOCMj04JH406gDnb6 3N5f6YGhs9UL
W08mZyFjOWiO5cK3rge3c9wSXNgfsUi2zxRG3fyyhbYZbkgKpyOEAAXgdAeM YreSCFGDJFGr
DdghQCNxy35nk+poeCF2LPFGzHbklQSdpyv5HkehoAwbPWb94raWf7MweO2l dUjZcidtgAJY
42kEk87s4wvWqumXt5NBE8SWm6aWNbeN0OyBjZb/AJeflXOBgDgFuueOmFpb KoVbeIBQigBB
wEOVH4HkelCWlsjRslvEpjAVCEA2gAgAemAzD8T60AY82tXcqI9jaMRNIkMa yIN4fYzvkFlB
wAFxuBDB+uMHQtManpgGoW0TFiyyRNtdSVYjkAsOozjJweMnFWJLS2lt2t5L eJ4XJZo2QFWJ
O4kjp15+tSRxpFGscaKiIAqqowFA6ACgDB0qWHSvD+jOkcFvbzJGbmQgKq5i J3k8DJYKMnrn
HpRZ6tqTxC4uVgRElt4ZIPKZXDSLFk7i3GGk6bf4cZ71rTWEUq28YZo4ICpE EYUI20grnjI2
kAgAj3yOKbFpdnHfzX3kRtdSvu81kBZPkC4U4yBgfqaAMuw1W/vYfMuFjsoZ rf7TFK+wBANp
wRvJdcNy2EwPQkYtarM9x4Uv5ZIWhd7OUlG7fIfXB/MA+oB4q8lhZxtIyWkC tK4eQrGAXYHI
J9SDzn1qaSNJY2jkRXRwVZWGQwPUEUAZ+nwwaeFV7GzsZbmTYq2vIfClhk7F 7Buo/HmsmLVb
iw8Pae1pF532fT457hNgOE2cfMXXGdr9A3Tp0zuJpOmxwyQpp9osUuPMRYVC vjkZGOcVJd2F
ne7PtlpBcbM7fNjD7c9cZ+goAotqssNxJFcIqC2MktxJsbaIAMqV75OVHTBK SY6Cs83V1fX9
tp2q2qgeerOjxqFkRopiAVDuDhoweT1xwMZPSCNBI0gRQ7AKWxyQM4GfbJ/M 1VTSdNjhkhTT
7RYpceYiwqFfHIyMc4oAy7k2umanELIRx7bedFijG5VkZ4AqhcgDJZTjKj5s kjJNCazfeUyz
RwQzQSlZvNGPlCo2dqs21fnAL5bbwSME7dhLCzSEQpaQLEEZAgjAUK3LDHoe 4702PTbCKNY4
7K2REkEqqsSgK46MBjr79aAIbS9mm1GeGRoPLG7ywhOSFO0kHo3OQRwUIwQQ Q1aFRpBDHNJM
kUayy48x1UBnxwMnvipKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
igCvYf8AHnH+P8zUkpw8POMv69flPv8A4/TuI7D/AI84/wAf5mpJSQ8OA3L8 4B/unrz/AI/1
oAkqjflhPHtjnmxG7eVDJsZjlB1LKOMnqavVFNbxzMrPvDKCAVdlODjPQ+wo ApWrv9qjJt7u
DcjgxzShycFPm4dh3PfPWnXkoMsSTKUjKM7K+MHG3r1HGT+I+hqxb28abJcy M+zGXZz1xnhi
cdBTbyxjuzGzs6PGTtZCO/bBBHYH8KiabjZFRaT1M6S4lhgdrZLhAfuKBHtz jjjqBxnGPWtO
zulu4TIiOgzj5wOfyP8AnBqs9i6qVileVwQ2JcAdGHBC+9T2kf2GwCzMPkDO xHIHJNY0lUUr
S2LnyuN1uZr69NGJnazj8qPz3yJzuMcL7XONv3umFzg85IxzJNrv2dXuJrb/ AEMPNGro+ZC0
YctlcAAfu3wdx7cDJxafTbF0dGgJV0lRhluRK25x+J/Ltimx2GnzSyyiLzMs yvG7MUVjw37s
naCQTk45DHruOekyM2bVryy1KcXNspkkjgSGGGV5UyTMSxwm4cIeinoO3Iua Xey3uozu8csI
+zQnyZAw2tvmBIBAPO0ckAkYyB0qZdFshvO2dnfbmRrmRnG3ONrFsr95uhH3 j61YtrG3tGLQ
R7WZAjHcSSAWPOepy7EnqSec0AWKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKAI5/9S3+f8/55HWqfT2x/n+n6dsfLcn/1Lf5/ z/nkdap9PbH+
f6fp2x8oBRvv+PiD6/0b/P8Ah0Eugffu/wDf/q1RX3/HxB9f6N/n/DoJdA+/ d/7/APVqaJlu
v66GrcHFvKc4wh5zjHH1H8x9akqO4JFvKQGJCHAUEnp2wR/OpKRQUUUUAFRT sVMZAJO4/KDg
t8p46j+v9RLUcpIeHAbl+cA/3T15/wAf60ABkYZ/cyHGehXnr7+w/Me+MC7Z nSSOO8iizKwI
MoRlPn5JPIONuehHfrkY6Oqn2IqW8u6mRWYttAQgEnJ6r6mqi7EtGYUtTPhp radZdqsqSAEs
zjdtGSQp6kZOfbnOxd3KWdrJcSBikYyQv/1+B9TgDqSBzUJtMkeZdzOqup2n YBkEEdF9cVco
kxq5RlubmKOCFhF9suCQp58tOp6nBbA7DBbBOFGSteXWmXVms47OWVI5Fikk VHOGYA54UrgB
gTlgevHTN77Db/Y/snl4gHRQx+XnI2nquD0xjGBjGBTX061kuhcMjb8hiA7B GYdGKZ2kjAwS
MjA9BUjMnSS9vZ6JMJ55GvkVZxNM0gJMLPuG4nacr2wME5HTDbrxBMzNDbRK HaSMwSZfZKnn
RofmZAOQ45XcMEnPTOtY6XaWGPs6SDamxfMleTYvou4naOBwMdB6CoxolgrF hFJ9wooMzlYx
kHCDOEwVUjbjGBjGKAIX1VZdT/s9omMMxaJZ4mkHzBSWG7aFGNrD5XJBHQc4 h06QWGnSXBae
dnvWt/3tw74H2gxrjcTjAI6dcc1oDS7QXi3QSQSI5dQJX2BiCCQmduTuPOO5 PU02704TafLZ
QOsMU5fzsqWJVyS+3ngksSDyB6UAUW16bN26WcZgs0eSZjOQ21ZJEO1duCcR E4JHUDPepIdZ
lur6S1gtZFTfJEk5jkZVdMglvlC7cqRw5PTgZOJn0W1kvTM4YReRHCsCMyJt UscFQQGBDYwR
jA96mOl2nnPLskDNuOBK4VS2csozhWOT8wweTzyaAIzfyNYvcqkam3dhOjP8 pC53bXOBx1ye
OCDtOdtie8jgsWu2WTywm/G3a2PcHG33zgDvgA05rWBo4Y/KURwlTGg4UY+7 wOOOoHYgHqBU
1AGDqRuXv7CKeK5mLQTu8VjcGLBDR45LruwCRnvnOB0BHfXNsBaXULMIzC24 3BDqJLgrGpwD
naoG47jkjHOSa1obG3gaJoo9phRkj+Y4VWIJAHp8owOwGBgUS2NvNK0kke52 8vJ3Hny2Lp+T
En+dAGXaa9NMkEk1nHGkqQSNsnLFVmbbHj5Rk7s5HGByCelVbDV7maFHS2aU NIi20f2khgTa
eZtYkfNzxlieWzxtFbSaXZIiIsOFRIkUbjwIm3IOvY/n3zRBpdlbmEww7PJ2 7AGOAVQoDjPJ
2kjJ5Ix6DABRn8QxhA9pA1wjmNInAf5nZDIQQFLDCBTkKfvY4wSL0DjU9NVp op7fzOGTc8Tg
g9j8rAHGR0JB5AzinPp1q9v5JRlTzGlBR2VldiSSGByMlm6HoSOnFTQQR20K xQrtRffJJPJJ
J5JJySTySc0AZOjTm20nR9xlme+Cb3lmZyGMJcn5s/3OgwOabZa9NdRJcGzj S1LwxswnJcNK
sZGF24IBkAzkdCcdquXOlRz2dvYDy1sYtgaFk3lghBVck9PlGcg5Hp1oTSIB f3F3K0kjSyrK
ELsEUhFUZTO0nK5yRkcegoAq6frVxqan7PZtEHjEsLypIEZcj5WJUAEg8bS4 6nnAzNqN75/h
i8vLZpIybSR0bOGUhTyCP0IJB6gkYNTLo9iquohYow27GkZlVcg7FBOFU4GV GAQACMVauII7
m3lt5l3RSoUdc4yCMEcUAU9NSOBSWju7Z5X2LHd3XmsxAJ+X52HTPTnj2rNj 1xrDQtNmkRrk
/Y0muDl2dV2g7uFYc4blioJB5641BpNr5bITcsCQwZ7qVmUjPKsWyvBIOCMg 4NF1o9jdRiOS
FlQR+VthkaIFOykKRkDJwDwMn1NAEY1dBceRIixukkom3PgRRoM7ycYOQ0Rx 23/7JrPGqyal
c29jLFLalpwJQjSR7kMcrDDMqMPmj5wMdsnJFbjWsDySyPErmaMRSBuQyDdg EdP4m/Oqq6LZ
Deds7O+3MjXMjONucbWLZX7zdCPvH1oAzWmu4LtLa0ZpRFqPlIk07DKG1LkM +GJ+Yk857egw
5/EIjlbbaSNcHbFtDuy7w0wYYVScDym+YLk5XIGONJtIs2gSIrLhJPNDieQS b8Fclwdx+U45
PTjtUY0W18+RsMEaONVCsyurKZCW3g7snzDk5yeck5NAEcGrXNyQsGntvSMS TRyuY2ALMo2B
l5zsYjds4K9MnFjSLie5tpnuNpK3MyIQeqLIyjIwMYxjv0znmhtHsWVFMLAK NpAkYeYMkkPg
/Pkkk7s53N6nNqGCODf5S7Q7lyAeMnqQO2evHck9SaAJKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKAK9h/wAecf4/zNSSjLw8Zw/p0+U+3+H17GOw /wCPOP8AH+Zp
8xAkgzjJc4z67W9v8P6EAlooooAjtxi3iGMYQcYxjj6D+Q+lSVFakG1hK42l FxjpjH0H8hUt
AELMI53Yq3KDlUJ6bj2H9fwGeYr6VTY3K4fPluPuHHQ98ex/T1FTKR9qkHG7 YufXGW9vr3/L
u28RpLKdEXc7RsFHqcUAZ2oX81te+Wkj/MQEQKCDwOOme9OQh/EqSQSM0b2j iUBiVDBk25HY
4Lfr71OhLXPmNp1yGYjLM6FV98bz+gqKwtZ47xXkiKKkPl5JByfl6YPtUVJt OKivUIQ+Jt+h
JrEt1BHbyW00cafaIkkDR7mYNIi4BzgcE9j+HWqtxeXS3VxMs7KlveQ2whCr sdX8rJJxuz+8
OMEDgcdc6l1bJdRLHIWAWRJPl9UYMP1UVXl0uKS6aYyyhHkWWSEbdjuuNrE4 3DG1eAQPl6cn
NgZukS6hPDFHeXV9BeTW4fbcRQ7eNu9lCjII3AAP/eGQcEVCNUnNwtq93eLF mQrNHa7p22iI
gOmw7eZG6oOAh75bWGlKGLteXbuEKQszjdCCQcAgZblV+/uzjnOTlo0dVbzU vLlLoli1yNm9
8hQQQV29EToo+77nIA671W30/ToLm4mjlEu1VaNlRZCRnILNtAwCeW9sk4zX TxHbShWggnmQ
opLpsKhmdkVc7uSXUrkZXoc45q02lxfZoYIpZYRblTbsm0mHCbMDIOeCfvZ+ 8fbDf7IhJLPN
O7t5O5mYEkxyGQHp3ZjkDjHAAoAamt2zPHHslEkhCqhAyzbyjgc87CpLYyAO eRV+QOUIjZVb
sWXI/LIqguiWyzCXfKXWTzEYkZjJkaRtvHG7dtb1UAVpUAV7V5JbCFyw8x4l O4jjJHXFJbF/
MlUyNLGuAHYDO7nI4A6cfjn8HLbhbdYFkkVVj8sEEZ6YznHWlghMK7fNd1AA AYKAo9sAVOoy
aiiiqEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBHP/AKlv8/5/ zyOtU+ntj/P9
P07Y+W5P/qW/z/n/ADyOtU+ntj/P9P07Y+UAo33/AB8QfX+jf5/w6CXQPv3f +/8A1aor7/j4
g+v9G/z/AIdBLoH37v8A3/6tTRMt1/XQ1bgZt5RjOUPGM54+h/kfpUlRXRAt Zi2NoRs56Yx9
D/I1LSKCiiigArCu9REFxbrNJds0s8ijyrfeEA8zBBCHJ+XGM5wSelbtUnsw JI8XDj96zqCE
+ViGJ25UnPJ/AmgB9tOfJPmtI7K7jdsJyAzAdBjov8vUVj3dtNKkjQWyMzys BJsBOfOwckg4
AXPOD39Od6CIQRbAzNyWLNjJJJJ6fWqLaVl3bFq252bMlvubkk9d3vVxdiZK 5Wlsj5ji4V1j
lKsxRs7XZ1BAP8XQckArxjtt15547aFpZm2ovtkkngAAckk4AA5JOKorpWHR sWq7XVsx2+1u
CD13e1aEkaSxtHIiujgqysMhgeoIpSsCv1Kr3kiQxhrf/S5s+Xb78nHqxHAA BG48gE4G4kZr
z6/YwaoNPd/3u9Yyd6DDNjaNpO45yvIUjnrwcWmsUe1SBpZSYzujlLZkjPOC D3wDjnORw2cn
LTp6/bGnS4njWRxJJEjALIwAAJON3RV4BAOORycyUZ+lXN2lrpM1xdSXX9oI oYSKi+WxiMmV
2gcfKRg56jkYOS68RxLJNb20e+6hlRPL3xsXBlVGxtf5T8wxu28n2OLlhpKW Swqbme5W3QJA
JtuIgBjjaoyccZOTjOOpzCNAhBQG6uWSGPy7dCUxAAyMu35cnBjTG4npznmg CSTVrdtTbSvM
aK4YEI6vGxzt3cLksMDJyy449xmHTrmW3sZLi8up7nddtbqGVBt/fmJT8oHs Tn049KsLpKJe
RzrcziOKV5kg+XYHYMGOdu7nex69/Tim3enOdMls7TbmaR2MkjYMRdi+9cDk qxyBx0HI60AR
tr8IeYC1uWjtwzTSgJtjVXdCSC2TzGx4BOPfihPEFpNqD2FuVa4BdEDSKAzq DlSAS69DyVxx
xnIy19CV7uYCaSKzlt0heFCCZfmkLbywJ539QQSSSTnmrSaaI5HaK7uY0Yu6 xKV2o7ZJYfLk
8sThiRk9OBgAd9v3W/nRwSN5b7Z4v+WkXHPyjOSMg4HUHK7uAZnuoI7UXJlU wkAq6/Nuz0xj
rnIwB1yMVG2nwNapagMIActGDnzOuQxPJyTk8898gkGxJGksbRyIro4KsrDI YHqCKAMXUb24
W7so5JbuyWWKZ2S2iE75DIFB+RscMc44zxk8Euh1WRY1gukuVlUxnzQiDKPM Uj3A8gsBlhtG
OehwK0IrFI54ZjLLI8MbxKXbPysVPJ6nGwAE8+uTzTbjTYbid5naQM/k5AIx +6cuvb1PPt6U
AVbbX4bhYWNrcxJKI23OE+VZDiMnDH7xyBjJGOcDmqtprxki8xo7uSNXUQlE QvODbebtYA/e
6/dAGSoHGavR6JbRxRxq8uI47eMZI6QsWXt3J5/pRaaJbWn2fynlxAUZQSDu ZYjFk8d1I6cf
KOnOQBt5r9jaKzl/MT5Arq6BHLAsFDkhQdq7uSOCuM5FWILhNV01ZrS4kiWT pJHtLKQcEDIZ
TyCM8j0PQ1GNHt0t1igeSFklM0ciBdyEgjjIIwFOwAg4UAdhVyCLyIVj8ySQ jq8hyzE8kn/A
YA6AAcUAZukXki6Xpkl3PLcTX4UhmVBtYxlyPlA4+U+p5otdfhugjpa3KwMY lM7BNqtIqsoI
Dbv41HAxk+nNOuNLY2Nlp8B2wW+wGYyFZUCYHy7QOWXKkgrgMevSmw6KFu7h mmZbVp45Y7WM
KE+REC5+XIwyA4BxgD3FADbPxFbai0kdgvnSqnmInmpmRAQCRgnaeRgPtyTj jkixqN9jQLy9
s5PmS3kdG28qyqeoPQgjkEcEYNEOlLDD5KXl35IQRxoHCiJOPlBAB6ADcSWA 6EEk1YuLKGfT
pbHb5cEkRhxGANqkY47DigDN+0SxWHnxXt5MWuYIv9KtxGVBlUNgbFPIbGef atC7vRbSRxJB
LcTSBmWOLaDtXAJyxA4LL3zz9ahk0x5rZ4Z9Ru5dzo6uwiDRlGDAjCAdQOoP ShtMdtjnUbv7
Qm4LPiLcFbGVxs24yoPTPHWgCOHXrWd/3Uc7Q740M+zCAyKpTqcnO8DgZHfA wTJZ6sl5cRRL
bTok0TTQyvt2yICvIwxI++p5Aoi0a1ht2t4vMSIyxShQ2dpjCBQM9v3a9eev NVdJ0u7tr2OW
4dUhggaCCBZRIEUlTgHYp4CAc7ifUY5ANqiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKAK9h/wAecf4/zNSSnDw84y/r1+U+/wDj9O4j sP8Ajzj/AB/m
aklOHh5xl/Xr8p9/8fp3ABJRRRQBHbnNvEc5yg5znPH1P8z9akqO3ObeI5zl BznOePqf5n61
JQBC0qRzvvkVRsH3mx/ePr6A9u3U44VriBQS00YC5zlhxjOf/QT+R9KVT/pD jP8AAvGfc+/9
PxPaSgDlINas3uistvalHYEszAsNzEkkkdsj6e9b9iGikkty+9EVWXI5GSeP pxWTbaK0N8rM
l0Y0ddvzx7cKx2k85xjHGM9etW9MikW+3GJ0Ahw5ZCoL/L69e/NRVlGMoqC3 FRjUcZc7LOqX
VzaJA8EUTo88ccjO5BUNIq8ADn7x7jHv0qvPqNyl1MyeV9nguYrZoypLuX2f MGzgY8wcYOdv
UZ4vX1r9rgWPfs2yxyZxn7jq+Px24/Gqs2lvJdSMLhVt5p47iSMx5cum3GGz gD92uRgnrzyM
WMp6Pqd9qNqknn23nSwLIsT2ksW3OMsCzHzAuf4euRyM5qM68+6OF77T4Qxk 23rj9zMFEf3R
vHeQj7x5jPrxoDT7sz+fJfq0sUbRwOIAOCVJ3jOGzsUHbt6tjGRiNdKuY7g3 kd3EL1y29mgJ
jIYIOF3ZHESfxH+L1GADQNwIxbrcbUlnOwKpLDftLEA4HZTyQOlVW1uwWVo/ NkLLnO2FyAQz
JjIGMlkYAdSRxnIpv9lvHaWkFvcKpsiv2dnj3YAjKfOARu4LHjb29Oa8GgGE SbrxpC8kblmj
AJ2XDzc445344A6Zx2oAuWmoC7v5ooirQpBHIpwQ25mkVgQemNgGMZBzmppp ZY7mBAqeXIxU
sSc52sen4dc1X07TPsN1cTedv87PG3GP3ssnr/01x+Hvxbli8x4Wzjy33Yx1 +Uj+tJgJOZQu
Y3jjUAlnkBIA+mR+ee1OhdpIY3ZCjMoJU9VOOlRTwzSlCssY2kna0ZIPPHcd P58+lTruCjcQ
WxyQMAmjqMdRRRTEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBH P/qW/wA/5/zy
OtU+ntj/AD/T9O2PluT/AOpb/P8An/PI61T6e2P8/wBP07Y+UAo33/HxB9f6 N/n/AA6CXQPv
3f8Av/1aor7/AI+IPr/Rv8/4dBLoH37v/f8A6tTRMt1/XQ1bg4t5TnGEPOcY 4+o/mPrUlR3B
xbynOMIec4xx9R/MfWpKRQUUUUAFYt3rEVtPClzf2lu0krqqvwVA3jc3zjg7 SM46kVtVQeyl
8yIh42EczyxkxnKFg3J+YZ4Yjp3oAmt7oGEmeSNXVmB52jALDOCfRSfwNY97 NcIsjRiZnMhC
nzHwczBMABgOAe5Hb3xuW0Rhh2MwZizMSBgZJJ6fjVD7DcK0mFDBnZgRdyJ1 YnoBgdauLsTI
gdLhpZEeaaESlZATzsLMoAOOMjGBg4/vD+9sySJFG0kjqiICzMxwFA6kms37 DcM0eVChXViT
dyP0YHoRg9K0J4I7mFopl3I3vggjkEEcgg4II5BGaUgRC18iWqTtFKDIdscR XEkh5wAO2QM8
4wOWxg4H1G1juhbs7b8hSQjFFY9FL42gnIwCcnI9RTXs5HhjLXH+lw58u42Y OPRgOCCANw4B
IyNpAxVl0OJ9Wa9xbEvIsrM9sryhlAACuT8o+UdieTgjIxJQ3TNQvJINOmvT A66gilBDGUMb
FC+DljkYB545A4OeJrzWre1R/klZ45EQo0TqWBkVCyZX58bh93PUeopunaVN bRWcd1cxzpZI
FgEcRjwQuzc3zHJ2kjsOTweMU4/DOyfzRPAGRMI622JHYOjq0rbvnOYxnpnJ 6ZoA1pLyM3DW
iO0dwQQjSQvsLYzweA3HOAc4B9Dirp19cG1kuNRmgK/aGt08qFl5EpjGcs2c nHpjNRroe3WI
77zID5cry7jB++bcrDaZN3KjdwMcBVHbNOu7GWLSJbW3VpppJ3ljcYURO0hk VmyeQrYzjJOO
h6UATNrdgsrRmWQlc72ELlUAZlJZgMKMo3JIHBPSpDqduZnhj8ySVdwUBCFk YZyiucKW4PGe
MHOMHGa+iTm5uoIplSzuLZYpndNzyEvKXIIICn58/dIy3A4xU0OhLb30l1Ab RXLySI5tQZd7
5J3PnJUFjwNpwAM9cgF5tQgW1S6BYwE4aQDHl9clgeRgjB4474AJFiSRIo2k kdURAWZmOAoH
Uk1V+wbbfyY55F8x908v/LSXjn5hjBOAMjoBhdvBEz2sElqLYxKIQAFRfl24 6Yx0xgYI6YGK
AMvUNXeGezUXNtp8c8cr775Ou0oFGN64yGJwefUA5qS21mOWFFkkVJ8rlhE7 I6GXy1YEcDfj
K8nAOeQM1ajs5Bd29xNcea8MUkWdmC4ZkIJxxkBBnAwSc4HSo7rTPtN1JN52 3f8AZ+NuceVK
ZPXvnHt70AFvrdhc+V5UsmJcbS8LoMH7pJIGA3QE8MeBkiqsHiC3eJpJZlWO Irul8l9symDz
cr/d4ycHJAHqwp0OheVBFH9pz5cVpHnZ18hy+ev8Wce3vRYaF9i+yBbnesDp IcpgsywGE9+A
RtOOcEHk54AL1xqNrbSNHK7eYoU7ERnY7t2MAAk/cY4HQAnpTvNa7s/MsZo1 ZvuvJGWAIOCC
uQcjBGMgg9emKzW8OwfYEtl8pjHP5qCaLzIzhSiqyk87UwOo5UE986VharZW cduvlgLk4jjE
agkknCjoOfc+pJ5oAq6VfSzadYz30sXm3oVo1ijZQMpv28k9AG54p0Gt2Fw6 rFLIQ2zDmFwm
WUMoLkbQSGXgnPIHWq82nzxadpljbGQy23lhbtdoEYUBWOCTyyFwBhhk8461 HbaNNHPPAGjh
08XEMkcYQs7CNItuH3cDcgGCCeDzyDQBeXVrWRXMPmylRuAWJhvTIBZMgbwM g5XPUYzkZdqF
75GjXN9bNHJ5du80ZzlWwpI6dRVHT9AGnKRayW0JEYiSWK0VZNuRku2TubA6 8DJJKngC9c6f
HLpFxp8J8pJYnj3feILA5Y5OSckkknJPegCmmozCyNwl9Y3ym4hhDW8ZCruk VWz87ZOGyOmP
etC7vYLTYJTIWfO1I42kYgdTtUE4GRz05HqKqz2V/dWjxT3ltvEkckbJbMAp Rw3ILnOcDuKG
sr9pIrg3lt9qjDoG+zNs2NtJG3fnOUHO7GM8d6AJE1jT5LjyY7lXfKglQSo3 AFcsBgbgwwSe
TwMniq9zrtvs2WjM00hQRs8LhGDSIm8EgBwC6ng8jvzmi30NLaya1jnbZ58E qllyQIhEAD65
8rrx16cVn2mlX1w8Ecytb29lAI7fzUXfkPGybtsjBv8AVDP3OvHXgAuXGp3d h58dyYpniNu2
+KFhlJJShATLEkBSRg85HHHNr+17QsreftXY5aN4XEmQUGMHkH51wuMtvXHv DNpVzOk0kt3F
9qkMO11gIQCKTeuV3EnJJz8w4x6c1bnQZLq73XDxy+cjvK/l4j8wNBsGwkkq RDyM888jIwAa
R1ezEauGlYkkeWsEhkGMZygG4dV5I/iX1GXWOoR3091HEMrA6gSLysgZFcEH GP4ugJ7HuKpw
aLJaeXLaS2kFwu8EJabYsNszhFYHP7teSx7+wF6zszay3D+c0onKuxcDdvCh ScjA5Crxgc59
QAAWqKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAK9h /wAecf4/zNSS
jLw8Zw/p0+U+3+H17GOw/wCPOP8AH+ZqSUZeHjOH9Onyn2/w+vYgElFFFAEd uMW8QxjCDjGM
cfQfyH0qSo7cYt4hjGEHGMY4+g/kPpUlAEaj/SHOP4F5x7n2/r+A7x3/APyD 7n/rk38jTmiS
Sd98asNg+8uf7w9PQnv36DPMV/FEthcvsQEROd2Bxwef1P5mgCG6v1tp2jaF CARzu5PA7Y9/
WmxySW+vC0XZ9mngecKAcqwZAcfXcSf/ANeYpBpt5fLI97bSEsNiK4yTxx15 6dMd6bpjCTUl
bIdltyGOclCSuR7cjp7e1RUqRi4xS3CEJPmb2Re1G+axEBFtJMssqRs6soWP c6rk5Of4uwPT
nHWoZtUeO6kUW6tbwzx28khkw4d9uMLjBH7xcnIPXjgZsajbPdWyRxlQVnhk +b0SRWP6Kapz
6dcvdTKnlfZ57mK5aQsQ6FNnyhcYOfLHORjd0OObAj0rWp9UtTPBBZyExq3l w3m90ZsYDjYN
vfPU8HANSSapdpbXMv2W2Bsywud9wwVcIr5UiMlvlbngcjv1ojs79Z45glnE bWBoYUjLbJAS
h5GB5fEeABuxu745bb6VMkUUbLBDAbsTvbRE7I1VflVDgf8ALRVc8DqevcA0 BdLDYpc33l2n
yKZBJINsZOOC3TqcZpralYIyK97bKXj81QZVG5ME7hzyMAnPTiq+rWM18kW0 KDbz+Yiid4vM
Gwry6jKcsemc49+KcWhzRhtpiUMbdivmO2Clw8r/ADNknhup6nPC0AbAu7Zl DLcREMEYEOOQ
5wp/E8D1p8jFELKjOR/CuMn8yKxE0S5W6ScvFiOdpAgJ2yBp3c+YMc7VYFPR 8mt6gCGGYy2k
c4Q5dA+wHnkZxSQzO0jxSoqOoDfK24YOcc4HoabDHNDZRxJ5ZdItuSTjcAAP wpbVJUVhKiAk
5LByxY9yeB7f/WxU6jLFFFFUIKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigCOf8A
1Lf5/wA/55HWqfT2x/n+n6dsfLcn/wBS3+f8/wCeR1qn09sf5/p+nbHygFG+ /wCPiD6/0b/P
+HQU5LeJSWaV13HOOOp9OKuX3/HxB9f6N/n/AA6Cug3NvJILSBAfQbsUXsJp Pcg8mL+/P/37
P+FHkxf35/8Av2f8KtLNA19Jagy5XcAxI5Kg+3tVi5iWGXYrZGM89qFK6uEq Si7SRm+TF/fn
/wC/Z/wo8mL+/P8A9+z/AIU+TUbaOZ4naQGMgOwiconAPLYwOCD14q1Tuxck exS8mL+/P/37
P+FHkxf35/8Av2f8KtJKkjyKjZaNtrjHQ4B/kRRDKk8Mc0Tbo5FDKcYyCMii 7Dkj2Kvkxf35
/wDv2f8ACjyYv78//fs/4Vdoouw5I9iiY4QQDJMCeg2df0pfJi/vz/8Afs/4 VZg+aMSH7zjP
4dhTkZ5UaSKGR4lzmQDjjrjufwBoV2JxguhU8mL+/P8A9+z/AIUeTF/fn/79 n/CrgIZQykEH
kEU0SoZmhDfvEUMRjoCSB/6CaLsfJHsVfJi/vz/9+z/hR5MX9+f/AL9n/Crt FF2HJHsUvJi/
vz/9+z/hR5MX9+f/AL9n/CrRlQTLCW/eOpYDHUAgH/0IU+i7Dkj2KXkxf35/ +/Z/wpBHC2ds
kxwcHCdD+VW5SflUHG9sZH5/0qW3ijcYeSRSZREiRhf7oPcdhk/hScmHJHsU PJi/vz/9+z/h
R5MX9+f/AL9n/Cr8sT283lvkq2SjHGSB64+oqG4njtoTLKSEBA+VSxySAAAO TyRQpNg4RXQr
eTF/fn/79n/CjyYv78//AH7P+FWYJ47hC0ZPBwQylWU+hB5HY8+oqSndhyR7 FLyYv78//fs/
4UeTF/fn/wC/Z/wq0kqSPIqNlo22uMdDgH+RFPouw5I9il5MX9+f/v2f8KPJ i/vz/wDfs/4V
aaVFYqWyw25VRkjJwDgduvPsfSn0XYckexS8mL+/P/37P+FJ5cO7b5k27Gcb OcflVyRtkbPj
O0E4qvcPLAkKw7GllkCZfOCT3pq7dhOMV0GeTF/fn/79n/CjyYv78/8A37P+ FSxR38zlIrjT
ZHAyVWQk4pbKZri1SVwAzZyB04OKbTSvcSUX0IfJi/vz/wDfs/4UeTF/fn/7 9n/CpIb+3mkC
Iz5b7rGNlV+/ysRhuOeD05qzU3ZXJHsUvJi/vz/9+z/hR5MX9+f/AL9n/Crt MllSFA0jYUsq
g47kgD9SKLsOSPYq+TF/fn/79n/CkMcK43STDJwMp1P5VeqJWXDzOQACRknh QOv8s/8A6qLs
OSPYr+TF/fn/AO/Z/wAKPJi/vz/9+z/hTYry5miSdYofIaJnLCQsQew6D3/z 1uyI0NwsZYsG
TdyR7egHrUTqck1B7scacZK6RU8mL+/P/wB+z/hR5MX9+f8A79n/AAqZ72BL jyWc78gE7CVB
PQFsYBORwTnkeoqeruxckexS8mL+/P8A9+z/AIUeTF/fn/79n/CrtMSVJHkV Gy0bbXGOhwD/
ACIouw5I9ir5MX9+f/v2f8KPJi/vz/8Afs/4VdpHYIjOckKMnaCT+AHJouw5 I9in5MX9+f8A
79n/AAo8mL+/P/37P+FXabI2yNnxnaCcUXYckexT8uHdt8ybdjONnOPypfJi /vz/APfs/wCF
WlAjT5mGf4mPGTSptkiZvNIcE4RWXkCsqlb2au7lRpRl0RU8mL+/P/37P+FH kxf35/8Av2f8
KtxMXiRyMFlBxUaXULx27q+VuMeUcH5sqW/DgHrWildXJcIroQeTF/fn/wC/ Z/wo8mL+/P8A
9+z/AIVa81BD5zNsj27iXG3AxnnPT8afTuw5I9il5MX9+f8A79n/AAoMUKgk yTgDuU/+tV2p
LFFkvGL8iEAgH1PQ/hj9aLsOSPYorab1DKLplIyCIjgj/vml+xH+5d/9+T/8 TWm2pXO9glmW
UOVDZbnBI/u+1SRX87TIktq0auSNxJ9Ce4HpT1Fyx7GR9iP9y7/78n/4miui 8yildj5I9hLD
/jzj/H+Zp8wBkgzjIc4z67W9/wDH+oZYf8ecf4/zNSSnDw84y/r1+U+/+P07 hFElFFFAEVqA
LWELjaEXGOmMfU/zNS1HbnNvEc5yg5znPH1P8z9akoAiUD7VIeN2xc+uMt7/ AF7fn2lqFlEk
7qWbhBwrkddw7H+n4nHCtAjAgmTnPSRh1z7+5/T0FAGZFqcU1wY/tk6ksNpE Y2kMTtAJX0A6
+tX7OaV90U64lQAkjGGBzg/Xg1ydrpmNQWOSaBdsiKSLhgxKsQQB1ycfhkYr f0+aRr/5m3eb
AHPHTGMAf99GoqyhCUUm9SaPtJxbkti5e38ViYRKsrGaRY12RlgCzBRk9F5Y dT9M1HLqkUd0
0JilKJIsUkw27EdsbVIzuOdy8gEfN14OHapBJcWqJEu5hcQORnHCyqxP5A1R uLO6a6uIVgZk
uLyG5EwZdiKnlZBGd2f3ZxgEcjnriyixa6s11arcrpt4sTxiSMnyz5m7G0AK 5IznqcAdyKH1
fbBJILG5JhJE67ol8nADfMS4H3WByCffFU7GyksZ1kstIW0SGAxyRLIg+0Nl MEEHLYCvgvtP
zDpkkOhsLhoPJaCSO2uLsNIksgeRYgg4dsndudADkt8jY47AGxby+fbxTeXJ H5iBtkgwy5Gc
EdjUlZ+opO8ltNFbySfZLjeUDKGkBjZcrkgdX7kdD7ZxYtEupJJprqyi81pE wdyvhDdStIAT
zgxuM8DIOMdRQB0i3KNey2oDb440kJ7YYsB/6Af0oe4SOeOEh90hwCFOOhPX p2rN0WxuLS8u
mmj2RFAkXzAgKJpioAHQBGTA7DjtWjOjPLbsoyEkLN7Daw/mRSYDpZTHgLFJ IT2TH8yQKdG6
yxrIhyrgMD6g1BcvMQqpDIUYneUZQ2B0xkjGfXr9D0njAEagJsAAwvHy+3FH UY+iiimIKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigCOf/Ut/n/P+eR1qn09sf5/ p+nbHy3J/wDU
t/n/AD/nkdap9PbH+f6fp2x8oBRvv+PiD6/0b/P+HQVk/wBWg9ZwP/IlWb7/ AI+IPr/Rv8/4
dBVU7o2RoDIu9v7uD8x9TQBf3W/2uZVTDkMud5LZAPXnpwf09eI51ZbiRXzn cSM+nb9KpeTD
/wA+I/75T/GpI8RAiO1KA9doUf1pRTSs3cbd3oUlsXuLnUBLNOkEsoBiAULI vloDyRnnkcEd
PWodsi7TdfbPIaWct5ZkLbvMxH935gu0Hp8vTvitXzG/54yfmv8AjR5jf88Z PzX/ABpiMS1S
5WdjKtyL5pYSxAfyyNkYkJx8nZ/y47VHYRXyNZq7zx7EhCRiJyNgRdwJ3BBz v+8N3p/DW/5j
f88ZPzX/ABo8xv8AnjJ+a/40AYtrFeRxW7E3ZdY7Zjvd2+ZmxLkE8/KBwfu9 Rir+l+Z++En2
j73WbPJ78Hv2O35OAVxkgW/Mb/njJ+a/40eY3/PGT81/xoASEZtYxnGUHP4V HHG6/Z/9Xvh2
Ebg3G2PbgYGMbst1Gc44p8TOkSIYXyqgHBX/ABp3mN/zxk/Nf8aqMrEyjcdE gjiSNc4VQBn2
rL33Ehu7gW0iM0EUTKd2VYF9+MYLbQ2cr1xwc1peY3/PGT81/wAaPMb/AJ4y fmv+NSUY9qb9
IHkiaSUxymKNZY5FDKyrhirEscP3JOF3Y7CluRdQ3tukT3H7poowSsknmpkB mZgdgOC2cjPG
e4xr+Y3/ADxk/Nf8aPMb/njJ+a/40AYAScyQuFvPtAgIumYSYBLx7wmeOgfG z047VYG/ePN+
2/YNzeXt83zM4TGcfPjPm9eOn+zWv5jf88ZPzX/GjzG/54yfmv8AjQAwbtlt v37sjO/G7O09
ccZ+nFPWSJRKWlRXjkJKZG50MYBAHfscdCVFNdnZkIhf5WyeV9CPX3p3mN/z xk/Nf8aNegAu
1bYsk8DJAMKkTKc5JJ6KME8YHfHvmq+q5+xghXbbNExCKWOBIpPA5PANS9Zf MNvJuxjOR7+/
ufzp/mN/zxk/Nf8AGogpK/M7lNroZtyLiZbq6tRJGJEijUsjB9quxc7eG6Mc dGODjsTDEsyp
GLmS8ktMvgxxyo+fl28AmTH+s+9/LbWx5jf88ZPzX/GjzG/54yfmv+NWSYsq 3A85WW4jV5g5
l2OzZEUYwRERnPzcg7QVx6UQm9awle4FwJJWiDsRJ+7HlKSQikH7+QduOpzw MVteY3/PGT81
/wAaPMb/AJ4yfmv+NAGFbJeEiZxcGRvKjVtrrlFuGzkHkfIV+9zgnk/NTgt6 0USxteJKRGLp
ju4k8yPJXdxjHmfd+XHXjFbfmN/zxk/Nf8aPMb/njJ+a/wCNAFWFZI4b6JvM MaMREZCWJXYp
PJ5PzFv5dqkviyLBMFDCGUOQWC8DPc1JKzvE6CF8spAyV/xp3mN/zxk/Nf8A GmnZ3E1dFJde
gM4Agn3Kc83h28fjg1Y09Gjso1YYPJ6g8EkjpUvmN/zxk/Nf8aPMb/njJ+a/ 41UpXVkhKNjN
tpp49HSzghnF7FbbBmIhVcJj7zfKeQBwT+WTUQjlluokt3vUszIu4uZA2dkm 4Zf5gP8AV+2e
mDWv5jf88ZPzX/GjzG/54yfmv+NQUZcX2kT24f7WdsjovXG0OwBJ6H5QM7+o OVO7OYFS5dIB
tuWfMRuhIHI8wSxnK54x/rPucY/CtvzG/wCeMn5r/jR5jf8APGT81/xoAy9G W8E2bmWVmMf7
5WidVEmR0LMQf4vuAL/47V2bzjZsts4SVpdqsegy+PQ/yqfzG/54yfmv+NRg ExFJLdnUsSQd
pHXPrQgI/sN9aiFLp0MLkxlVcEY2ngAIuOnrVkI3mb5JXkYDALY4H4AegqFI oo2DJZBWHQhU
B/nUvmN/zxk/Nf8AGiSUpczQRulYozb4r8/ZhcCSSRC6eXmKQcBm3Y4IUdMj lRwc81ZReyPJ
HHLOvkT7HdGznfLG4wOfuoSDkYGccjNbHmN/zxk/Nf8AGmQhYIxHDamONeio FAH4A0AZrrJH
cPFP9sNkjsFMZkZydsZHK/MRkye3bsKI4LlJJ7gG5En2mEBW7qViVyQvB4yC eQMcYrV8xv8A
njJ+a/40eY3/ADxk/Nf8aAMQLdpYwhvtnn/ZEMGDIf35yW3/AI7Pv8de2aW6 jvUspZYnu2me
S4TGWO1MSFMDtyEwevIAOMCtrzG/54yfmv8AjR5jf88ZPzX/ABoAx5xM8l21 sbyJwdu1xKyl
d43sM8dM7QhBx05OFt2Kyrps4lkkkHzbDJGyHGPRiW65+9/LFXfMb/njJ+a/ 402VneJ0EL5Z
SBkr/jQBKW2vGf8Apon/AKEKbIZ0TDhwWfC72J/hb1dv6U1mLqVe3ZlPY7SP 50xURGDJabWH
cBQf50NJxafUNU7k0aeXGqZztAGfWsays7iKDR2eW4cJjdE6KBH+5YdlBGDx ye9a/mN/zxk/
Nf8AGjzG/wCeMn5r/jQlbQDC8q8nsfJZbtppLHaQ5IG4x45z8vLHvhwR3U8W T5v2keX9r3+Z
F5GfM2+Thd27PGf9Z975untWp5jf88ZPzX/GjzG/54yfmv8AjQBj2y3arZQF 5/Mmghdt8hyh
Rw0u7JzzvAwM+hwBW9ZNtup/91P61WUKkjyJalZJMb2AUFsdMnPNPgLCaR2Q qGCgZx2z6UAW
I7lEG11fIkfP7pjxk4/gP8zTmuFkmhEatw5JPllcDae5QfzpvmUeZTuKxa8y iqvmUUhmpYf8
ecf4/wAzUkoJeHBbh+cE/wB09eP8P6VHYf8AHnH+P8zUkoy8PGcP6dPlPt/h 9exAJKKKKAI7
cEW8QJYkIMliSenfIH8qkqO3GLeIYxhBxjGOPoP5D6VJQBGoP2hzlsbF4ycd T7f19Pxc7BEZ
zkhRk7QSfwA5NRshad8MyfIPmUDn73qPfPX8PVWV0BcPI+MnYNvPXj9R37D3 yAc7a+ILqSdm
lCiIKhKiIjqexJ68jrxx9a0dJ1C0u53WC18mQhmJAX5gGxyR3rCtYYJ2O60e NJLtYvmIKx4B
+UZO7dz6Y/UVo6LYwW+pIyqCfJLoSo+XJHt15xmqqzpRlyNamsXGcOaJtXd7 BabBKZCz52pH
G0jEDqdqgnAyOenI9RRbX1vdsVgk3MqB2G0ggEsOc9DlGBHUEc4qrfubbVbW 7eOVoVgliYxR
NIQzNGR8qgnojc4xx7is+4t7u61eTULKOW3lNtFCjyRj7jPKGODxx+7kwefl CnG41Jka0mqW
iIH3yPud0CxxO7Eo21vlUE4BGM4xyPUU2TV7ONYTulczBiixQSO3ykBshQSM EgEHGDxWTp1u
NJ+yMbadLWD7ZCoSJ5GUNOCnABbBVSc9OnPIy62sbqS6tGWS5tAReSeYiLnD zqyg71OMg5wQ
Dx7GgDoI3EkayKGAYAgMpU8+oPI+hqva6ja3chjgdicblLIyh1/vISAGHI5X I5HqKtVk6Zcr
f3v2mWK5imEZWOOS3kjESEjILMoBYkLnBIGMDoWYA0mnjW4S3LfvXRnVcdQp AJ/8eH51HFfW
80qxxybnbzMDaefLYI/5MQP5VVv3NtqtrdvHK0KwSxMYomkIZmjI+VQT0Ruc Y49xWSbG6aaz
uYoJPOg+2XMIYbclplZVOeFLoWHPIyTjIoA6D7db+f5PmfvPN8nG0/f2eZj/ AL55/wDr1Yrl
4LR9LmVpI55VTU/NkljgZi5a1wzhVBOC5PTgE47Vqajcy3WlSmw8+OQ7CS0E isE34fAOGJ2h
uBhumOSDQBqUVzMCzrHELyXUJbHMmDFFPG+75NvAZpcf637xxn221Mftn2wb vt32rzYfJ3Z2
eThPM37P3W7/AFvXnpj+GgDoKqpqNrJdG3V235KglGCMw6qHxtJGDkA5GD6G ubMOqC1sB9ov
Im+xxlP3csrmc5L7sOAOdnEmV7cANWheXM15LcLDFcx3NuJRZobdwplCsocu V2c5IUZxg5OS
QFAN6iuXt0uki+ee+lsTKvm7YZ43A2vnbuZpT83lZ24H/j9SXf2nY3lf2ln7 P/oGd+fN3P8A
6zbxjHlf63t1530AdJRXL3UV/wCWhaa7ihe4uWkOyeVs+ZiIARsGC7AcY+X2 yQa6KzEosoBc
MzTCNfMLKAS2OcgEgc+hIoAWGeKcMYZFkCnaSpyM4z1/GiOeKWR445FZo8bg DnHX/A1HDlJb
pmVgGlGODz8qj+dKisL+ZsHaYkAOOCcv/iKVxliiiimIKKKKACiiigAooooA jn/1Lf5/z/nk
dap9PbH+f6fp2x8tyf8A1Lf5/wA/55HWqfT2x/n+n6dsfKAUb7/j4g+v9G/z /h0CWjslpIUY
qfN6g47tS33/AB8QfX+jf5/w6COF1SykLsFHndScd2oAhm1G/wDtr29sqybI 1dmkuGT7xYYG
FP8AdpYdZilthcfbQibEdg8oBQMMru54zmqstrZXGoSXFytrMhiREEgVipBY nr/vD8qZJERO
88c1uzi5EyI0mAR5QjwTg47noeg9eADQOqxK8aG/QPKAY1Mwy4PQjnnNOOpI skkZvVEka73U
y8qvqRngcisAW8vmXluGt9lzBiSQyEBC7ykhePmxv9u3TPDp9NEi3CCaEh/O ZHa5c/M4bjZ9
1cbzzz06c8AG1BqyXEskcd2SyMqj9597K7gRzyCM/kfSp0upJEV0nZkYZVlf II9RWJd/u7ot
BLG0slws0RwSq/II33dsBckcjJ47c6Nsbe2tordJlKRIEUswzgDHNAFzz5v+ esn/AH0aPPm/
56yf99Gq/nw/89Y/++hR58P/AD1j/wC+hQBY8+b/AJ6yf99Gjz5v+esn/fRq v58P/PWP/voU
efD/AM9Y/wDvoUAWPPm/56yf99Gjz5v+esn/AH0ar+fD/wA9Y/8AvoUefD/z 1j/76FAFjz5v
+esn/fRo8+b/AJ6yf99Gq/nw/wDPWP8A76FHnw/89Y/++hQBY8+b/nrJ/wB9 Gjz5v+esn/fR
qv58P/PWP/voUefD/wA9Y/8AvoUAWPPm/wCesn/fRo8+b/nrJ/30ar+fD/z1 j/76FHnw/wDP
WP8A76FAFjz5v+esn/fRo8+b/nrJ/wB9Gq/nw/8APWP/AL6FHnw/89Y/++hQ BY8+b/nrJ/30
aPPm/wCesn/fRqv58P8Az1j/AO+hR58P/PWP/voUAWPPm/56yf8AfRo8+b/n rJ/30ar+fD/z
1j/76FHnw/8APWP/AL6FAFjz5v8AnrJ/30aPPm/56yf99Gq/nw/89Y/++hR5 8P8Az1j/AO+h
QBY8+b/nrJ/30aPPm/56yf8AfRqv58P/AD1j/wC+hR58P/PWP/voUAWPPm/5 6yf99Gjz5v8A
nrJ/30ar+fD/AM9Y/wDvoUefD/z1j/76FAFjz5v+esn/AH0aPPm/56yf99Gq /nw/89Y/++hR
58P/AD1j/wC+hQBY8+b/AJ6yf99Gjz5v+esn/fRqv58P/PWP/voUefD/AM9Y /wDvoUAWPPm/
56yf99Gjz5v+esn/AH0ar+fD/wA9Y/8AvoUefD/z1j/76FAFjz5v+esn/fRo 8+b/AJ6yf99G
q/nw/wDPWP8A76FHnw/89Y/++hQBY8+b/nrJ/wB9Gjz5v+esn/fRqv58P/PW P/voUefD/wA9
Y/8AvoUAWPPm/wCesn/fRo8+b/nrJ/30ar+fD/z1j/76FHnw/wDPWP8A76FA Fjz5v+esn/fR
o8+b/nrJ/wB9Gq/nw/8APWP/AL6FHnw/89Y/++hQBY8+b/nrJ/30aPPm/wCe sn/fRqv58P8A
z1j/AO+hR58P/PWP/voUAWPPm/56yf8AfRqlqU0rCzUyuVN7b5BY4P7xal8+ H/nrH/30KqX8
sbtZBHVj9tg4Bz/y0WgC7c381v5RLyFHkCM28/LngH3y20fjntTDqhSS48yc xwwbQ0ryYAY8
459ivP8Ate1MuTb3Nu8LzKAwxuVhlT2I9CDyD6iqbRMLFVW4iM7P5k4ExQSE 9QHHzAA4x3wo
HSgC/HqhkuzCJyVMaOjiT7+7fwPXhCae2pIjIr3qq0jFEBlxuYHBA55OeKwr axkt5EnE1sZI
23qhnJB+abguRnpKOcHJB+tNOmsd/mT28pmDLJi4eNQDI7Z2qfm4f7pI6dec 0AdL583/AD1k
/wC+jR583/PWT/vo1X8+H/nrH/30KPPh/wCesf8A30KALHnzf89ZP++jR583 /PWT/vo1X8+H
/nrH/wB9Cjz4f+esf/fQoAsefN/z1k/76NFV/Ph/56x/99CigDcsP+POP8f5 mnzf6yDkD5z1
A5+VvX+n8s0yw/484/x/maklOHh5xl/Xr8p9/wDH6dwASUUUUARWvFrDyD8i 8gAA8e3H5VLU
duc28RznKDnOc8fU/wAz9akoAiX/AI+pOR9xeMDPVvx/z9ae7rGjO7BUUZZm OAB6mo23mdwj
qCEH3hn+92z647duvorF0BeSSMRrksSuMDnvn6fkfXgAwrXXkuLzi0i2FkJY NkqxypYnH93A
+g61tQ2cEEhkjQhiMZLE4HoMnisPS49PF8Ftp3mDALslA4xvH+Bwecc/S7aX R/tFI1QJHMu4
KOgGM59j0qK06amlbrY0+JXhsaN1d21nGJLu4igQnaGlcKCfTJ+lOinhmx5U scmUVxtYHKnO
D9Dg4PtWffzw2ms2dxdSxwQC3mQySMFXcWiIGTxkhWOPY+lZsjy/21NeaOFc G2iQJtby38yS
bEmB1+faxb+6XIzkVZmb01/Z28PnT3cEUW8pveQKu4ZBGT34PHsabNqVhbxx ST3ttEkw3Rs8
qqHHHIJPPUfnWDpbQ6Y9m11c7YIvt0JuLiQDc32hcbmPBYhWPvg06zW5e9s2 tJYoy4vpFeWI
yKyNcIQQAy9QQQc4x9aANiPTdKlkW8jsrN3ciVZ1iUlieQwbH45pz/2bqvmW 8n2S88h/njbb
J5bcjkc4PUfnVysXSbuw1G9jntLi22wQNHBbxOu4RkrlmUfd+6oA7DrycKAa VtBZ2WLe1igt
9+XEcahN2MAnA+qjP0qRJ4XYKksbMd2AGBJ2nDfkeD6Gs+/nhtNZs7i6ljgg FvMhkkYKu4tE
QMnjJCscex9Kx185bmyu7fzGMX264VEyfPjM6nAA+9lGyvYnaelAHUefDv2e bHv37Nu4Z3bd
2Prt5x6c1JXJwN/Z90r6jcxqw1XdNI8mEVms8kAnooJwM9sCtjUdTU6VLPpt xBK42fOsgKoj
PtLk8gAAMckEDacg4IoA1KK5mDUrho4lvNVigtmMmL2J0YMRs2rvZAhzuk+6 v8GM5VqmOpXH
2wK13ifzYUjtPLCefGwTfJsYbxjdJ0OBs56NkA6CoVu7Z7p7VLiJrhBuaIOC 6jjkjqOo/OuX
OqaoLWwb7bEryWcc6tOyp58jZJQKIyXx8o2ptb5hySQRcur+wnllSG/trP7C ZpF27Wk80K4d
/L6kLuc9MseegywB0VNMiCRYy6h2BYLnkgYyce2R+Yrl59V1LE0ryNaywQXE 72gCOEaNYiqM
2PmBDFiVwfnxnirlnLK3iQQTStMbaOeNZHADMCLZ+cADq5HAHAH1oA3GZVGW IAyBye56UMyo
pZiFUDJJOABVa/jRo43ZFLJLHtYjkZdc4pNSWKXT7kMEcxox5AO1tvH0PNJs ZcooopiCiiig
AooooAKKKKACiiigCOf/AFLf5/z/AJ5HWqfT2x/n+n6dsfLcn/1Lf5/z/nkd ap9PbH+f6fp2
x8oBRvv+PiD6/wBG/wA/4dBTNpbXSD7TbxTbXfb5iBsfMemauX3/AB8QfX+j f5/w6CGD7h/3
2/8AQjQBXXSLB5BHFpdtIxBbAhQcDHrj1ofRrKJ1SXSbeMsCRmKM5xj0z6ir Y2CT96szRshU
+TIUYHKkcggjp2NDeXujWFLkIoYkzzGQ5O3oSxPagDLvLGygMCw6VZSSTSbA HRUA+VmzkKf7
vpUclnAssEC6NpxmkR3YHAVQpUcHZk/eHYVc1S0a7W32wwTiKXe0cxwrDaw9 D3IPTtTGgu1l
tZobe2UxRPEYvNIVQSuMHZ6L6CgCIQaILZZ5bSygQsUPmxouGBIK+mQQenpR 5GiB7lZLSyj+
zMqyF40AGQCD9DnH1Bp8thOsEaRP5gDO8i+a0O5mbdkMuSACT8vvyeKht9Mu raxECyIT+7LB
ZGj3YjCFdwGQMqGyOvTAoAsPpuntb+Za6dYSlgCmUUKwPfIU9vaobC00+5tI J59MsITOA0aB
VbIK7u6jnGeParmmW0lrZCKXG/e7HDl8bnLD5jyevU1Ue3mt7HTbeP5rqDYF IQtGMLsYk8cB
WYjJGSB9KAHJb6FJMsKQ6c0rDKoqoWIxnIH05p8Vjo0zyJFa2EjxnDqsaEqf Q+nQ1WtrCdGm
tEQLapPCyyux3kIkfQYwc7cZyO/HFTaXpr2TpvAPlReUr+c7lhxztPCfdHAz 9eOQCf8AsnTf
+gfaf9+V/wAKP7J03/oH2n/flf8ACrlFAFP+ydN/6B9p/wB+V/wo/snTf+gf af8Aflf8KuUU
AU/7J03/AKB9p/35X/Cj+ydN/wCgfaf9+V/wq5RQBT/snTf+gfaf9+V/wo/s nTf+gfaf9+V/
wq5RQBT/ALJ03/oH2n/flf8ACj+ydN/6B9p/35X/AAq5RQBT/snTf+gfaf8A flf8KP7J03/o
H2n/AH5X/CrlFAFP+ydN/wCgfaf9+V/wo/snTf8AoH2n/flf8KuUUAU/7J03 /oH2n/flf8KP
7J03/oH2n/flf8KuUUAU/wCydN/6B9p/35X/AAo/snTf+gfaf9+V/wAKuUUA U/7J03/oH2n/
AH5X/Cj+ydN/6B9p/wB+V/wq5RQBT/snTf8AoH2n/flf8KP7J03/AKB9p/35 X/CrlFAFP+yd
N/6B9p/35X/Cj+ydN/6B9p/35X/CrlFAFP8AsnTf+gfaf9+V/wAKP7J03/oH 2n/flf8ACrlF
AFP+ydN/6B9p/wB+V/wo/snTf+gfaf8Aflf8KuUUAU/7J03/AKB9p/35X/Cj +ydN/wCgfaf9
+V/wq5RQBT/snTf+gfaf9+V/wo/snTf+gfaf9+V/wq5RQBT/ALJ03/oH2n/f lf8ACj+ydN/6
B9p/35X/AAq5RQBT/snTf+gfaf8Aflf8KP7J03/oH2n/AH5X/CrlFAFP+ydN /wCgfaf9+V/w
o/snTf8AoH2n/flf8KuUUAU/7J03/oH2n/flf8KP7J03/oH2n/flf8KuUUAU /wCydN/6B9p/
35X/AAo/snTf+gfaf9+V/wAKuUUAU/7J03/oH2n/AH5X/Cj+ydN/6B9p/wB+ V/wq5RQBT/sn
Tf8AoH2n/flf8KP7J03/AKB9p/35X/CrlFAFP+ydN/6B9p/35X/CirlFAGxY f8ecf4/zNSS7
t8OOm/nr02n0/Drx+OKjsP8Ajzj/AB/maklGXh4zh/Tp8p9v8Pr2IBJRRRQB Hb7vs8W/72wZ
69ce/P581JUduMW8QxjCDjGMcfQfyH0qSgCNd32h8/d2Ljr1yc+3p059e1SV C28TuURSSg+8
cf3u+PXHfv09VZpwDtjjJ5xmQjPXHb6fmfTkAoxwW8bh7azlTy2KhkKgYDNk cngZJ9O3oKdZ
Wlu0kd1HJKxQbQrEfJxjHA+lctZ3l0b6MpNuldol2mZvm5PB/M59MmupsZo3 vpAibA8SsvAG
QCef/HhUVYKEo8zuzVxcU0jRorLv4IbvWbO3uoo54DbzOY5FDLuDRAHB4yAz DPufWs2Sc6br
U0mnqs1sltFD5CuAN5kmCAMc4w48vA4G/sFqzI6aiuX0u1Wd7O01Dy7xR9uZ /MjG15FuFG/b
0B5b6bjUa232m5soRZWl4sf25UiuWwiKs6quPlboMADHSgDoP7Mg+0ef5l3v 378fa5duc5+7
uxj2xiprq2juoxHI0qgHOYpnjP5qQfwqnqlzLp9taw6fbqzyyCGNFUEIAjNw pZQeExjcP0wa
sGqX1wHz9ktmtovMn845VvnkXG5WIj/1ZJ+/jdjnbyAa1rbR2sZjjaVgTnMs zyH82JP4VNXP
3utXltaTXirAYi9xFHEUO5WiWQ7i2eQfKPAA+9145kbU9RXUmhEEb28EscE0 mFRWZghLAmTK
/fGF2tnGM88AG5RTJEEiFGLAH+6xU/mKgsVDaZbqc4MKjg4P3R3pAWqKq6eo W2KjOBLIOTk/
fbvVqhAFFFFMAooooAKKKKACiiigAooooAKKKKACiiigAooooAjn/wBS3+f8 /wCeR1qn09sf
5/p+nbHy3J/9S3+f8/55HWqfT2x/n+n6dsfKAUb7/j4g+v8ARv8AP+HQWNGj R0l3orYc4yM/
xGq99/x8QfX+jf5/w6C1of3Jv98/+hNQBoeRD/zyj/75FHkQ/wDPKP8A75FS UUAR+RD/AM8o
/wDvkUeRD/zyj/75FSUUAR+RD/zyj/75FUba9sp5LxSkUaWpOXYAAoMgscjj DJIv/Ac9CKvX
HnfZ5fs3l+fsPl+ZnbuxxnHOM1h3Ph6dbIW9reyTAWkloq3O0BI2TAxsUHO5 U654z3oA1DPp
oV2MtptR2RzuXCsoJYH0IAJI7AUNPpqeRvltF+0Y8nLKPNzjG316jp6iqc+j eZrFtcKkAtYP
KxHj7uxZgMDGODIhH0PoKrtot4I76JGgZb9JIpGZyDErSSsGAwdxxL0+Xlev OQAXk1DSjbvP
JJbQJHO9uxlZVw6kgjr3xkd8EGnJdWct7JaokAlhlEciuQG5j3gqOc/p0b05 qy6ZeLF5cTrJ
GJ5pNguXt929t4JZASNpLLt5BznggCqaeG7k6bHZPNEAQN7jJ2n7KYDgY552 nqM5PTHIBsJd
6VJAZ47izeIEr5iupXIG4jPsAT9OakElgWgUPbE3ALQjK/vABnK+vHPFZ7aX c3epwX15HbKY
5EJiVzIMIsuGBKjndKOMcbc57UQ6VcxXEbf6MUM8kkhOSSplaRQRjDfeGDwU YEgsCQQDW8iH
/nlH/wB8ijyIf+eUf/fIqSigCPyIf+eUf/fIo8iH/nlH/wB8ipKKAI/Ih/55 R/8AfIo8iH/n
lH/3yKkooAj8iH/nlH/3yKPIh/55R/8AfIqSigCPyIf+eUf/AHyKPIh/55R/ 98ipKKAI/Ih/
55R/98ijyIf+eUf/AHyKkooAj8iH/nlH/wB8ijyIf+eUf/fIqSigCPyIf+eU f/fIo8iH/nlH
/wB8ipKKAI/Ih/55R/8AfIo8iH/nlH/3yKkooAj8iH/nlH/3yKPIh/55R/8A fIqSigCPyIf+
eUf/AHyKPIh/55R/98ipKKAI/Ih/55R/98ijyIf+eUf/AHyKkooAj8iH/nlH /wB8ijyIf+eU
f/fIqSigCPyIf+eUf/fIo8iH/nlH/wB8ipKKAI/Ih/55R/8AfIo8iH/nlH/3 yKkooAj8iH/n
lH/3yKPIh/55R/8AfIqSigCPyIf+eUf/AHyKPIh/55R/98ipKKAI/Ih/55R/ 98io5oYggxEg
+Zf4R6irFRz/AHB/vr/6EKAKE0qJdPCsUI2qzDMY6ALnnI/vCoIdQhe6jheO 2Xe2M5j/AC++
T+laD2YaaSVZGV3BHQcZAHpnsOh7VDbWFxBdCVrsumCCh3nP5uQPyqlykvmu XPIh/wCeUf8A
3yKPIh/55R/98ipKKkoj8iH/AJ5R/wDfIo8iH/nlH/3yKkooAj8iH/nlH/3y KPIh/wCeUf8A
3yKkooAj8iH/AJ5R/wDfIoqSigCvYf8AHnH+P8zT5v8AWQcA/OepHHyt6/0/ lmmWH/HnH+P8
zUkpw8POMv69flPv/j9O4AJKKKKAIrXm1h4A+ReAQQOPbj8qlqO3ObeI5zlB znOePqf5n61J
QBEv/H1JwPuLzkZ6t+P+frTppBDC8rAlUUscdeKYzlZ3wrP8g+VSOPvep9sd Px9Ir52Njcjy
nA8t+cjHQ+/sPzHvgAYljsuDMss4LNkj5ORknGcZxye/eo9Ptwl07NIS8SeV 5ZTaQvGD1Oc7
eo9+/ArajLcR322HzSWYBcMcA4HbOKfH5c/iSK5hXj7JIrsRg5LRkfXgHkcf pUzhG8XJ+gQm
3zJfM0rq0tryMR3dvFOgO4LKgYA+uD9adFBDDjyoo48IqDaoGFGcD6DJwPes nWS7arZRCK8m
RoJmMdrceUchowCTvXOMnv3q1JdTQ3H2OztvP8iJHk8yYhtpLABSQdzfI33i O3PJxQFiaws7
iHyZ7SCWLeX2PGGXccknB78nn3NSJBDH5flxRr5SbE2qBsXjgeg4HHsKybrX ntoJbk2qtbqZ
kjIl+dniDkgrtwAfLbByT045OHHWpRqQtPsMjbHSOZoxI4V2CnghNpUbhkll OM8dMgGlLaW0
8csc1vFIkpDSK6AhyMYJHfoPyFNaws38jfaQN9nx5OYwfKxjG306Dp6CqOp6 01le/Z4rOW5K
xiWTy0djtJIAXarAn5T94qOnPXEL69NGJnazj8qPz3yJzuMcL7XONv3umFzg 85IxyAajWFm0
0szWkBlmTZI5jG516YJ7jgcH0pzWls90l09vE1wg2rKUBdRzwD1HU/nVW01P 7VqM9kIdslvu
8/5s7Mn93253rluOmMHmpr7eEjdJXTEqAhcYYF1HPek9ALVMWNF27UUbRtXA 6D0H5D8qg1He
LCdo5XjZUZsrjJwDx/8AqouN4urVhK4VnKlBjB+Rjn1ouMsKqqMKABkngdz1 p1FFMQUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAEc/+pb/P+f8API61T6e2P8/0 /Ttj5bk/+pb/
AD/n/PI61T6e2P8AP9P07Y+UAo33/HxB9f6N/n/DoLGjRo6S70VsOcZGf4jV e+/4+IPr/Rv8
/wCHQWtD+5N/vn/0JqANDyIf+eUf/fIo8iH/AJ5R/wDfIqSigCPyIf8AnlH/ AN8ijyIf+eUf
/fIqSigCPyIf+eUf/fIrL069+0xWcl1YQQJeoGgMb+Zkld+1vlGDtBPccHkc Z2Kx9M0+8jg0
6G9ECLp6KEMMhcyMEKZOVGBgnjnkjkY5AJrjUNKgimkMls4gkSObYynyizBf m54wTzn0NWFk
sHuntUe2a4QbmiBUuo45I6jqPzrFOh38l0k0skbvEn+sa5kfznEscgOwjEQP lnIXON3Q4q1/
Zl42swXMjq8cU7yeYbl+VKOqqIsbBjcBkHJxnqTQBNNLMmrxWaWFo0UqNIJT KQwVSgb5dh5+
fgZ5x1FWJZ9NhQvLLaRoN2WZlAGGCn8mIB9zinSWztqtvdArsjgljI75ZoyP /QD+lYMtlcSx
SXVvFIyx3am1jkRo2YPPFJIz5GQAwIHyjCqT82QaANprvSktUunuLNbdztWU uoRjzwD0PQ/l
UeqXdtpgtWktlZJ5xEzAD92NrMXPsNvPoMntVGbRruW5N8wjM7u5aGO7kiVQ yxrxIoyf9UDg
qB83+zzefSw1vplvtiaG0OJEIO1k8p48AHP94cEnjuaAHLdWam9NwkFvFaSi NpJCApyiNkk9
Pv4pzXelIyK9xZqXj81QXUbkwTuHqMAnPTiqKaTfQwXaLc+b5t35oBleJnj2 KoQyDLAjaPmG
S23n7xqGz0K7hicO0QLyQvjzWfGy5eUjcRk/K4GT1Oc+tAGs0+mp5G+W0X7R jycso83OMbfX
qOnqKseRD/zyj/75Fc/L4eneSYny5FuPMRx9pljVVMsjglUx5nEnKkjpwecj pKAI/Ih/55R/
98ijyIf+eUf/AHyKkooAj8iH/nlH/wB8ijyIf+eUf/fIqSigCPyIf+eUf/fI o8iH/nlH/wB8
ipKKAI/Ih/55R/8AfIo8iH/nlH/3yKkooAj8iH/nlH/3yKPIh/55R/8AfIqS igCPyIf+eUf/
AHyKPIh/55R/98ipKKAI/Ih/55R/98ijyIf+eUf/AHyKkooAj8iH/nlH/wB8 ijyIf+eUf/fI
qSigCPyIf+eUf/fIo8iH/nlH/wB8ipKKAI/Ih/55R/8AfIo8iH/nlH/3yKko oAj8iH/nlH/3
yKPIh/55R/8AfIqSigCPyIf+eUf/AHyKPIh/55R/98ipKKAI/Ih/55R/98ij yIf+eUf/AHyK
kooAj8iH/nlH/wB8ijyIf+eUf/fIqSigCPyIf+eUf/fIo8iH/nlH/wB8ipKK AI/Ih/55R/8A
fIqOaGIIMRIPmX+EeoqxUc/3B/vr/wChCgChNKiXTwrFCNqswzGOgC55yP7w qCHUIXuo4Xjt
l3tjOY/y++T+laD2YaaSVZGV3BHQcZAHpnsOh7VDbWFxBdCVrsumCCh3nP5u QPyqlykvmuXP
Ih/55R/98ijyIf8AnlH/AN8ipKKkoj8iH/nlH/3yKPIh/wCeUf8A3yKkooAj 8iH/AJ5R/wDf
Io8iH/nlH/3yKkooAj8iH/nlH/3yKKkooAr2H/HnH+P8zUkpIeHAbl+cA/3T 15/x/rUdh/x5
x/j/ADNSSjLw8Zw/p0+U+3+H17EAkooooAjtyTbxEhgSgyGBB6d8k/zqSo7c Yt4hjGEHGMY4
+g/kPpUlAEak/aHGGxs
Re: Primitive types and Java types in XMI [message #626456 is a reply to message #477294] |
Wed, 30 April 2008 09:43  |
--------------080802030804060305090009
Ed,
I'd really like to "apply the Ecore profile"... But I don't know how !
I attached a screenshot to illustrate my problem.
In the state exposed by the screenshot, how can I replace the "int" type
defined in my model by the one defined in the ecore ressource, so that
the attribute "einttest2" gets the ecore EInt type instead of my fake
int type ?
Of course, I can do this "by hand" in the properties of the "einttest2"
attribute, but if I had a very very large model with lots of attributes
using this int type, it wouldn't be feasible to change each one manually !
Thanks again !
Stephane
Ed Merks wrote :
> Stephane,
> SWT wrote:
>> Hello all !
>> I managed to import XMI 2.1 files generated by other uml tools
>> (Enterprise Architect & Bouml) into eclipse, and it works well (at
>> the resulting XMI declaration becomes :
>> </ownedAttribute>
>> Where "BOUML_datatype_0" is defined as :
>> name="int"/>
>> class !
>> The same kind of problem appear with other java classes such as
>> java.util.Date...
>> So I'd like to know how to work around this problem... Can I do
>> something with my UML tool such as using "special" stereotypes which
>> would be recognized when importing into eclipse ?
>> change types declarations into ECore/XML types declarations ?
>> "fake classes" to ECore classes ?
>> Any advice would be really appreciated. I already tried a lot of
>> different things, but I can't find any working solution... I hope this
>> is a "well known newbie problem" so that someone will tell me the
>> right thing to do in no time :)
>> Thanks in advance !
>> Stephane
Content-Type: image/png;
name="primitiveTypes.png"
filename="primitiveTypes.png"
iVBORw0KGgoAAAANSUhEUgAAA28AAAOiCAYAAADnue+WAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
ABh0RVh0U29mdHdhcmUAUGFpbnQuTkVUIHYzLjA4ZXKc4QAA+TRJREFUeF7t /W2wHcd5mIvi
/E2lKvfjnFOpW3V+5f5IVKkiwlIRMAMEvMqVK0pFlkvyLeX6RskxDhAhMFDg oYCQMGnY2BBg
UZZpi7RMUtS2QCsyZFnWByRaNk3FihGZcCRbhiwxtiXblGXLtqwvK1K4Nyll LnqDDfRudvfb
Pd0zq6f7maqptfZ0T/fbz9trr3l2z9rrf/r0714edrBBAAIQgAAEIAABCEAA AhCAQMUE/qcd
O5S8scOAOcAcYA4wB5gDzAHmAHOAOcAcYA7UPQeQN+QVeWcOMAeYA8wB5gBz gDnAHGAOMAcW
MAe88vYrj71/+NEf/VF2GDAHmAPMAeYAcyBjDqj30zF/yeZ9mGsQrsOYA8yB fueA773jBfJm
vlmMebPhnLqXWvUvAfJUd55K5cd8PX/jm88M7PkMzDfSsRflpfJLO8t4Hes5 EztfzNftwJZN
gNfsMl4nLfw+m1K01AuhBUaMIf716Hvv2CZv+g0DsPFgl8RKTYIlxUusefNQ v56/+vVvDmr/
0z//CnsBBpqneuSiMG+O9vYaV/NFEjj9uv3Od74zsJdnwGuW1+yUv3emvM5C 3vqdu/Z7x3V5
Q9zanhRT/kKZ8hchbY+bl/r1/KWvfGP4o8//NftEDBRfvaeurjC3x83tpXML CZx+3T733LMD
+/QMeM32+Rqc8neIea2lZav045Tx03a9rwnzvWNL3hC3epNV4oWEuLWdX3uO 6NfzF//qa8Mf
/NFfss/EQPFWe8zqSonXNW0s93XtmiP6dbu5uTGwz8uA1+xyX0u1/R7U11tT CBsrb8xT/btK
lLcP/dTeIbTX9sIhnhdObp+8kds2fxHoi8A//eJXhs/8wZ9v26Wc2/X5eTu/ GB6KO3/Rr/e1
ddtttw0xu/ReEtOGquNqJyRvG898a2CfnwGv2Xpfs9JrsabyGlbejv3712/7 vXPn699a9Udm
fuM//adB76VzmfN72o6lVFs57WyTt9DKjLrY23z228790xf/3ZbYlYZNe+V+ iZLbciyXMC+1
uP3xn/71cOWpL7xgj3k9u87j2AtZhpgo/mrnL/r1vf7UG6e0+aTL/B2Q2479 u1n9/N+/9d9e
sP//jtw7/OtjPz7877e/adh/x08OB//9Tw2H7vrp4cg9PzMc+9GHh9e9fn24 88fOD3e/6R3D
j/zkzw9n7n+Xsx1X2xx7IW9es/W9Zpfw3qtjrGHlTcnby7//NdevzXPlzZSr 2OcpOVNtqk09
ppwXWzf0uzrmd73uJ/d3fql21BzbWnkLXeC//yf/yfDM5nPDrf/ft1zf1c9q /8OP3DN8BoGb
ZLLFTkqpXkxudT7NR3K7zDcwU94+8amnB3vXr2cp565zeztm/nXMHnuozKyL wNX3Oir5Bhzz
F1Tf72iXvH3zv/3NYO8/df79w2/+7ueGS5/4g+Gjv/XU8K73f3T41d/43eFD //ETw/t+7fLw
Sx/+zeHdH/rPw89f/I3hP1wtO/PAu17QhqvdFo+Z+bDHFyqz6yJw9b1upWud WspXsfL2fT/+
weFfnX3ncPCHf3pQ4qZ3LXAl5O3P/vyLwxf+7M+Hz//pF4bfvfJ7wx//ydPD 5/7oj4c/+MPP
Db//B58dnvqvfzB85qnfHz79mf+aLGFK2n72534h+byUnLt+76eIm+qrpvcO Ud7e86bbhm9t
XJM3talH9bPan778k1sC9+mLhwZVLwVkq3V37NgR5CCVl+YS/Lzbb719K4// 8h/+2+s5JbfL
ftPS8vaHf/KXw+Xf+aMX7J9OyLnr/J6Omb+o1XM9dt9xHxuVCy4G63ldxQhX zJt67hu5S96+
8TdfHexdrbyd/on/MKz95DuH17/554dzP/3u4Y0/84vDmx7+peEn3/a+4f63 Xxze8nOPDQ/9
hw8Pb3vXr16Vt194QRuudls8Zr829Rh9x0MMeM3W85otfV00ZXsxK2//6ofe Peg99rNxKubY
z7zZK2+vPnD1Oj3ji6eVXP3CL753ePd73jf84i+9f/il910c3veBDw0XP/Th 4YOP/crwy7/y
a8OvPP6R4Vd/7T8Ov/aRj46SMHPVzV7dy4ndd7dEzO/4KW+bzLn7I2rl7cIb XzJ841vbV97U
z/Z+4cdf4p0cOcKSc26phKe0I8Urlaf0FVPXJ2/nX/3hYf2Vj23tr/uus9ef q+Nmbv/bf39u
COU2JoZQnbl55MZb+/la3p767BeH//xfPrttT825fb7+WeXMVyYdzzlXart0 uX1xri/6zV+6
6lhMvyofXAy2dTE4hbx9/WtfHuz9x9/63m3v85ev/FHwfV/Vd7WjXnvm7qoz 5THVt9m+/XOJ
vmNfs7F98Zpt6zU7x/t3zMqbErc3v/PJLYFTMf37n/6Pwx0/9fhw5I0fHv7t mQ8M//upX9o6
7hM7aRz2Z952/7+v3UL5kdf/r1u7dL5drm9r1L94rvzeZ4K/g8bc/mh+5k09 f+q3/3Brd0ld
avy2wI0Rt5w+XRI4ubz93Bv+6fD1q7KmdrXqZj7Xt1KqY6qeb3A5F+g555aE HduWFK9UHttP
bD2fvL315R8cnnzbZ4aLd31seONLz19/ro7rHG89fjOc29g4ppgbuX23eL6W t9/7/T8bfv03
f3/bnppz+3z9s5rDvjLpeM65UttTlEv3yqf0qXLCxWA7F4NTyNtXv/JXg70r GfvPVy9ifvPq
/p8/+fxuPv/k564f/82r5aq+qx312jOP2z+7zil5bK7+pNds6ph4zbbzmp3j Pb+GlTffOJW4
/Y/vfC1Z4JRAqVsl7f3Kpz49/O7V/c+/+Bdbu3qujo2VNx23a+VNHXv22Y1R bc+R95Q+Srx3
iLdNrp996fCVbzy7tZufe1PPn374j7aOqTJVL3SBrv/ip+uYfwE0z7OP++r5 zjHlyHWu/ddH
Xzx2vKpeTMwx/ackObeuT97uf9m7t8TtwoGPDEduOXX9uTqu860fQ7l1cbEF NcREylFufnTf
IWmOyWto3rr6iJm3ubl1na/l7ZOf/vzwa7/x1LY9Nef2+fpnc2yhY6rMrus6 1+7HVye2X1VP
9y3F5xujedx3r3zMuXYdlRcuBtu4GCzxBmy+htW8+PJf/8UL9h+7eoukuf2n q597C20/9jO/
4GxHvS7M9vXP9qOqY77W9Dn2e6fdli436+u2XG2a8bj688XhYmQf871mY851 1eE128Zrdor3
XLvNmJU39fpVq26xt0za9aRx/OqP/i/Dr/7o/3p1/1+Gx7eeX308fe1RyZva 1XGpHVOmzN85
n/zdT237FfSh9//coHa95cqbHZcWNyVv73vXI9f/M+WYfmLHPGW9Eu8dorw9 uPbdw5e+vrm1
K1Ezn2uZU8dUvdjVFd/FvesCO3TRrcXBFrnc47Zs5LZnni+Np/SEccmb+oyb ulVSrbgpcVO7
eq52dVyV6zyn5jaFVaiuKUt2vdT8SOIWM3+kcblissdQOrchefv4lT8ZPvwf f+/6Pibn5vnm
czXWmJ/teuoc17FSbem29YWgbleK1zdOfdx3ISid5ytXueFicPkXgyXegG15 +9Jf/flg7z/6
Uz8/PPGff2/4tau7+aieu3ZV39WOeh2Yx/XP+vWiy0L1fOfP0a5rTL5jvtds ShsvyMNVuVZ/
HJvj9zh9LPf3Q8zKm8qvvmXSFLPQZ+HUOTGfefvQ3f/z8J1v/Obz+5PDd/7m 6nO1f+Pqc3X8
b24c+9AP/c9R81lJ0m9/8srwO1d381H9AxMlbUqq1KP6pyZqHyNVoc+8fetb fzO49jH91PDa
KvHeIcrbm3/knw1f/Orm1q5kTT+3H1W9FHmz/4qnL459YpfSttmW2Y90Ae66 2NbxxAqnWd83
xjknj2/l7fUvedh526Q6bub2L67mPSW3EmMpvzGcffI2hrd9ji/f0rhsAXTF Mkfe9crbk7/9
R8PFx393256ac/t8/bMam1nmYqjK9XG7rq9d8xyzTX3cPs8Vh6uuL75QHLpM ugUrpg1XHZUf
BG65F2jqtVziDdiWt7/64p8O9n7Xvee3/ZVbSVxoU/Vd7divA11HHTfr+34O HXe1ndKu73y7
Dde47GPSazamDV8dXrPLfs3O8R6csvJmypp+bn4Wbuxn3t574v82vPf41f3q 4/uO/9+3nr/v
+f3bX/zZQe2qLJaH/Zm3T/zO7279CtLipuVNr8Bd+o3fiG5bx2B/5u2rf/31 4T3vfHj467/6
0+ErX/5z5468Xf2Lki+Jb/rhfz782Zc3t3Ylb+ZzvfKmjv3E1XqpghWqH7qI dq2U2OJlS4Bv
FcTVj08OXP3GyEYo3tgXz9h6Pnk7te/+67dKqhU3fQulOq5zrB9TchuSHDMH khSH8hmTH1++
bY6x8yRV3sbmK/c8LW+X/ssfDu/98O9s21Nzbp+vf1bMzDL7Z/s8fWGmjsfU dfXrOs8XR2p8
vnHG/vMD3/nScZUjLgaXezGY+18rXf9t8i/+7OnB3v/PM28d3n/1KwHe/8Rv bT0qedv62bOr
+q521Osi5rhdT/8ce1z34atvl/viMutJdXTd2Nesi0PsMV6zy33N5r6/xpy/ 6pW3UIy/cOz/
uiVu7776GDMWU6w+/tufHP7LJ35na//TL/zZlrh94fP/dfjyl76wbf/cH3yy +Mrbn//pHwyu
fcnyFvP+4ctR1H+b/LEf+hfD57+0sbX7PvOmylS9sfLmuoAOyZvr4l2SN0kW fG2mnGde4KdK
XcoLKaWuT97e8ZrHB3Uxr3Z1q6R+ro7rfOvHlNzGyFsMp1x5Kz1/cuTNJ4gp eYytq+VN/SON
d3/w49v21Jzb5+uf1XjMMulnVVfXseuaZfbzlPNCdWPic43V/vfiuo7vuI9X 6LjKExeDfV4M
uuTtz//0j69epGzff/Dun9m20PbLH/1kcOVN1Xe1o14HMcftevrnUsd1DFK7 Zqy+2O3x2K9N
Xe477uIRc4zXbJ+v2Zj34ZSVt6k+8+b7b5M//4P/l0HtMeMw69grb+q73j7w nrcPn/uD3x6+
+GeffcH++5/+rWSBC4mYKtPy9vNv/+nFf+Ytlb9dP0reztz58uFP/mrjBbsp cqpc1QsFpP/6
bq++2NJk19MXzZKw6fOk9mKkKiRyofhix5ibuJTzffKm2vi1x9+3lVf1eShX jtWxP/7L+Nz6
2JsiFZtfF0tb6Gyh8s0Bm5drDkh5leatqw9Xmym5G1NXy9uvXfrM8PPvu/yC PSXnrvP1MT02
+2d1PHRMlbnONfsy8ygdd9U1Y5BiCY3R/MuYXS9UFmrTmZOrueJisL+LQZe8 feHpzw72rr7n
LXV3taNeF7HHzdeVPsc8Zrflq2/3p+up42YbUn+uuF3HzNelXR4qi23frMdr tr/XbMx7cg0r
b1N8z5v9HyD1z09duTQ8/blPDb/wHx7akir9c+qqmPQ9b1rgUtuNydnS6kTJ 26kT3zN87i+e
EfcfOf49yTY/BTD7wnyKPpbUZkjelpbbJXFfVaxa3n7l139vWL9w6QV7Ss5d 53PshUxLMPnQ
E1cQuIwvkV3V6y2nX5e8ff6P/2CodVfvrbXGtqq4EDgEzrUqoo+FVtZcn3ez v/8t9jNv3/fj
Hxz+1dl3Dgd/+KcHJW56f/n3X/t+tztf/9bJrs+1sGmpsn+O/R051/e8xcZT c70oebv7dd87
3H1c7a8Yfuh1r7j+/MbPV4+pOlfLVjVY14rLqmKprd+QvC0ht7XxrD0eLW9K BlxSkZLzElJC
G/Gy9/5f+Z0tgeOCsI8LQpe8/cnnnhpq3dX7bK2xrTIuXrN9vF5j3/tjV95c Ylbiv02qOO2V
tynlTfVnipf+OZaXq57re95y2mvt3Ch5a23QvY0nJG+9sehhvFrelAggTvHi VAur9zz2iUHt
CFz7F4QuefujP/z0wL5MBrxm23/NxlxDxH7mTbU112feppa3GC7UKff6QN46 uE0HeSv3glnC
Lx8tb0oAahES4kiXyHd94L+wCtf472eXvH329z81sC+XAatwfb3fuq4Jclbe QkJnli3hWoQY
p3stIG+NXxyoFw/yNt0LqMZfTlre1MU/0pQuTTUx+w/vfXJQu74g5C/7bb2W XfL2h099cmBf
PgNes229VlPe66e85or5ku6UWKm7zHmKvCFvK/ucIr80pvmloeVNXfTXJCLE Ml4kz7/7Y4Pe
uSic5nWzit9HLnn7/U//9sDeFgNes+28ZmN+TwS/x6NAYUwM1Gl7zm2TN/MX DM+v/dMAdhgs
dQ6oi32EabwwLYHdUucmcd/4vWpeZCkuT33qv7A3zIC5zzUFc4A5UGIO7NC3 1i3hYoUY274Y
Jb/klznAHOhlDrhW3viLedt/MSe/5Jc5wBzInQPbVt56ecNknFwcMgeYA8wB 5sCq5wDyxkVc
7kUc5zOHmAP9zQGnvBW4JZcmIAABCEAAAk0SyLlYuu22267fzhyStybBMaii BNRcYoMABPoh
oN97ViZvH/qpvUNo7ycVjBQCEIAABJZEQP/L7tSY1RtuirzlSCLntv3XeD2X +O+DbeeZ1zH5
9X0dxQs+85b6hjSmvhK3zWe/7dw/ffHfbYkdGwQgAAEIQKA2AmO/bwl540Ks 1MU48sZcKjWX
aGd5c2llK2/v/8l/Mjyz+Zxz/8OP3DN8BoGr7XqFeCAAAQhA4CoB5G15Fzut XaAib8zB1uY0
44mf08nyFvPvLWPe3T/9W28fvrXx3PAv/+G/3Xo096cv/+SgBO7TFw8N73nT uHu6d+zYERPG
tjrqnDHnJXd09YS5+hkTW+icmLhLc4zpM2WcUnt2uVQ/pW/qQgACyyeAvMVf ZHBBNg2r0vKm
3ufI1TS5gitcS8+BUfIWeutVDUrb+Vd/eFh/5WNb++u+6+z15+r4N7713PX9 v/3354YLP/4S
qTlnuXTBveoLdCm+UYOe4SQpbql8TIil25Ta880N6bxc6R3DhnMgAIH5CaxS 3vQfx/Rj6YsC
qT0u8uu4EJXkzc6TlDepXJoXlNcxL8hDH3lYiby99eUfHJ5822eGi3d9bHjj S89ff66Of/2q
vF3fv/nc8HNv+Kej3pmlC23kbRRWccVQ4j6m19JtSu0hb2OyxDkQ6IdASN5C F8ElPvOWelFe
+mKOi/w6Lg6RtzryUPr1RXvkNWYOrETe7n/Zu7fE7cKBjwxHbjl1/bk6/pVv PLttXz/70uAV
gf1XSF3ZvAA365jl+rg6FlNH17MfXe2YQYdEUZdJ8Y6J0WYR25eLhTlmH8PU GO1+fPFJObNZ
m/lwnSuxtstTx+vi4GOaGrsUi52nmH77ueRmpBAoQ8Anb+brzfcfwnL/26RP 3vRxs9wVj/2e
acbpq6/qmO3reuZx3Q5yN8/FZ468xeTZlU9pfsdcdFJnnvkB57Y5j5Y3+w1A X/Dq2yZ9j+oz
bupWSbXipsRN7eq52tVxVf6lr29e3x9c+25R3lyiZAuTT2RcsucTFfOi3CeJ 0nHfxbUUh2s8
PikMHfeJidS/K+4Y7iFxdeUkRnR9sYzhIY0hxCu2P9d8sid1Tlum9KbEW+Yy llYg0B8Bl7y5
3hPtC6gpV95MoQpJlSR/9kV7bLvI27wXi5K82cLtu5i3pT91fiAJ8+Yd3vBW c2C0vPnermM+
8/b6lzzsvG1SHf/iVzev739x9fmbf+SfZcub/aYakjNJYsbIRehC3dWeL15J hMyLeElKfELh
k3KfdJr1fVxd44mR3JAwuiQlVoBs2QmNQZKhsblyzYmYeSr9YcHOe4h9f5fc jBgCZQjY8ub6
vWlLj37DLbHyZvbnk6bUi3CffPrasVfsXMLIheZ0F5o58mbnOiR6pty5ziPH 0+UYtrD1zYGV
yNupffdfv1VSrbjpWyjV8T/78ua2/Sd++J9nyVvqBX0N8hYasP7lmXoRHyOs 0gpRSGQkbq4x
STI6h7xJcUnyNjZXIaF3iXfomCTtZS5XaQUCENAEfLdNShdbU6y8lZQ3V/zI W50XkGPlTZJ6
qVya45TXOV/IS1t5WYm8veM1jw9K1NSubpXUz9Xxz39pY9v+Yz/0LxYvbyFJ kQTGLjeFJlVM
pb4kwYsRGakPn2j4xNHXp+t4KR4xfUqsbJkN5TFFxFPqSrngUhwCEBhHoAd5 M1dcXKts9sWg
fdHPxeK0F4sx8ha6fdZ1e+yY223J87R5hi98XXNglLxJ3/UW83b4a4+/b/iT v9rY+oybenTt
f/yXG8OZO18uypu5lO9aAbKX+s06kkyYK13SBXvMRX/MBbVvPHYsOh7p+Jgx SuP29e2TFFd7
9jglNrF8Y3lIYwiNxZ5DdmyhGFxzNDaXUr+uFT1XLDGvUepAAAJuAkuQN30h rl//5sW6+bvX
FjNXfZeo2bKGvM17kTlW3ux54ZJ0+5rJNXeQinnzDW94m3MgWd5KvZmfOvE9 w+f+4hlx/5Hj
3yPKW6mY5mjHJQRz9JvbxyriXkWfJqdV95+bM86HAASmIbBKecu9iJtCsqZo M3ecrZ8fK2+t
c2B8SE2PcyBb3mL+QYnr7fPu133vcPdxtb9i+KHXveL68xs/Xz2m6lwtC21L u8BeWry+VaJp
Lom2t7pqVqvufw7G9AEBCKQTUBcL0h0ovvLcf1iSe6EyhWhN0WbuOFs/H3lD Wlqf44zPP8ez
5S39bY8zIAABCEAAAssloAQsZ1+/cGlQu3oDtm+F0T8rOmMFkfN+tAt2ag4y T/rINa9p8my+
XyBvy71+IHIIQAACEFgBgZy/CMeuvOXIIefmyTX84MccYA7UOAf0e0+2vI29 bdL1fluyrRW8
n9MlBCAAAQh0QEB/5i11qKlfFZDaPvX7IjB2HvZFidFCoB0CxeStHSSMBAIQ gAAEICATmOsf
lsiRUKNnAshbz9ln7D0SKCZvJVfLSrbVY1IZMwQgAAEITE8AeZueMT3IBPQ8 /PVffsMwZv/U
J94jd0INCECgGgLF5K2aEVmBqO+PY4MABCAAAQiUJtCzvOV8b+QU/8F3ijZL z5ep2tPz8Fcv
vmn45FeeG7VPFRvtQgAC5QkUk7ec1bKY/54TO/Tzr/7wsP7Kx67vr/uus9t+ VuVsEIAABCAA
gVwCLcib/UXMMUxyRUmfH2rHLpP6lMpjxrXUOlPKmzk/lsqHuCHQGoFi8pYD RhI/qdzs+5FX
fGh47J4nh8fPfXx4z5GPDuuvemzbz6pc2nLeBHLOleKiHAIQgAAE6iHQiryZ RGPew2LqhLKE
vJWdw3oefuC9b95adfv7+39ma//8X28MX/r6s8Odb/3w8IP3f2D4/nPvHr77 5M8N/+gHH97a
/7d//VPD337lG7bqubZUgS47KlqDAAR8BIrJW4pg2cFI50rlZntvffkHt8Tt ybd9Zrh418eG
N770/LafVbm05bwx5ZwrxUU5BCAAAQjUQ6BFeVN0zfcx18pLyjGXGJry5rv9 MiQOvv7t2GPG
Us9sGh+JnofvetdD2+TtL7+2OXz1m89t27929Wd7V3WQt/H8ORMCcxMoJm85 gUtyJpWbfd//
sndvrbgpcbtw4CPDkVtObftZlUtb7BuTfmMw33y4xUCiSzkEIACBNgi0Lm8+ gZL+SOlbWbOP
j21HEsJQuS6T+l7SDNXz8O3v+Nlt8qYk7ZvPfHtr5e3oT39w+Ddv/KXhe37k ncM/vmN9a/8H
B98y/N3vv2/4W9/7BuRtSQkn1u4JFJO3FMGyqetz7Xvv9S9XXe571O2pf06i PuOmVtvUrsRN
7/qYKpf+iYl0q0Dolo+W3hC6f3UAAAIQgECAQA/yZr8v6z9a2lhi6pWSt1Bf IeF0ndfCBNfz
8C3r79wmb9/a/M6w8ez/2LZvPvudQe+6bPO57yBvLUwExtANgWLylkNMEj+p 3OxbSZr5mTcl
b+bPqlzaXL/8fW8WkuhJfVEOAQhAAALLJNCDvLkyI73vTbnyJq0GSuXLnGnh qPU8/ImHf3FL
3r618e3ruxI1tfJ26M0fGF61dmHYc3XF7e/9wANb+9/5vnuv1dv8NvLW4sRg TM0SKCZvKYJl
05TOlcrN9l7/koeDn3lT5dImvTH5/uLo+4uk1B/lEIAABCCwPAItypv5/hcr Qqn1QnevuN5f
zWNSX1K5bqulu2T0PHzDW9472PtTn/3CIO1f+OKXkbfl/foh4o4JFJO3HIaS nEnlZt+n9t2/
7TNuaqXN/AycKpc2Sd5cv/RT3oyk/imHAAQgAIH6CbQib+adJb4/ToakTv/h 0tWOdDulLvdl
2/d+a/dlxyfFUv/sio9Qz0PfGdJ/mwz1FJob8RFSEwIQKEmgmLylCJY9gJLf 8/aO1zw+KEHT
u/qMm/mzKo/Z7DeUlDcC6c0opn/qQAACEIBA3QRakLe6CRNdDIEp5S2mf+pA AALzEigmb/OG
Hd+b9M9J4luiJgQgAAEIQOAGAeSN2VADAUneaoiRGCAAgXIEislbzspbueHQ EgQgAAEIQGAe
AsjbPJzpJUwAeWOGQKAvAsXkrS9sjBYCEIAABHonMIe86TdpHi8PMIABc4A5 wBy4MQfUwtkO
BUQ9Wb9waWtP2Vh5S6FFXQhAAAIQWDoB5I0LSS4kmQPMAebAquZAs/KGVC79 8oj4IQABCNRJ
AHnjom1VF230y9xjDjAHsuWtzrdWooIABCAAAQhMQwB54+KppgvoX//lNwxj 9k994j3cknr1
zrOackks5CNmDmTLW60rXDlxrd9z0yDt01wS0CoEIAABCNROAHmr7wJLfVVP zEVPi3V+9eKb
hk9+5blRe4s8GFN9r09yUjYn2fJW+5vsmPiUuG1sXvHuqpwNAhCAAAT6JNCC vJnfYZp6YbVq
UbK/AFzFP0VMuh+TzxT9pPK365eWN2mMUnnueDi/7IU+PNvjmS1vOStcU77t 58T1yN07g/Km
ytkgAAEIQKBPAi3IW47wrPLi3df3FDEtRd4+8N43b626/f39P7O1f/6vN4Yv ff3Z4c63fnj4
wfs/MHz/uXcP333y54Z/9IMPb+3/27/+qeFvv/INW/XGXNhPwXpMHJzTnpSQ 07icZstbi2/d
D961c3hm46mtfWPz+V0/v/qoyqVN/XILbVK51D7lEIAABCCwGgItyptrNUtf SNmrdK5VO+mY
fcEv1XddxIWkwSzzrSqm9qnbtNv2cdFCbEqfTwBdx8deuL7rXQ9tk7e//Nrm 8NVvPrdt/9rV
n+1d1Qlx9s2JnFXbsWPkvLiLejj1wSlb3nJWuKZ8282J64E7bx4efejIcN6z q/LcDXnLJcj5
EIAABFZDoFV5c90e6BImaeXFJT3mSl9MmzF1Ym5n9MUSs/IoyZvEyyV9LonN veB++zt+dpu8
KUn75jPf3lp5O/rTHxz+zRt/afieH3nn8I/vWN/a/8HBtwx/9/vvG/7W975B lDdpjLmxc34f
skGey+Y5W95W89Y5ba/3nXhx8LZJVS5tWs7sv1zp88zjUluUQwACEIBAPQR6 k7cY4XCt0vjO
84mZb6XHXOnyXQT6Vt5MAXPFk7KaZwufNGafvEnjTL3Qfcv6O7fJ27c2vzNs PPs/tu2bz35n
0Lsu23zuO8gb/21y1K2zqXOU+pXJW84K15RvxTqu2EczlnvvuCUob6pc2kx5 M+v6jkvtUQ4B
CEAAAnUQ6Ene7FsEXStWsZKWswomrZRJq32ucYSOuUQttHoordKFxp57YfsT D//ilrx9a+Pb
13clamrl7dCbPzC8au3CsOfqitvf+4EHtva/8333Xqu3+W3kDXlD3hY4B1h5 c1wLnDm2K/iZ
N1UubcibRIhyCEAAAssk0KO8xYiLvUIWK3UxQiitvsXKm08CY27T1CtmoXhd q20p7MaI3Bve
8t7B3p/67BcGaf/CF7+MvC3wwn3MHOGcsitfq+aZLW+1r7yNuTQ4dWT3sHbu 9LB21r2rcmlD
3iRClEMAAhBYJoEW5M28dU+SEVNafKtV0i2EoVsO7TZDtzLqdkLx+2Kxx2G3 YV+QSbdZSmMO
iZyLaekLQum/Tfr6ixHhOeIvzYP22hKYnvOZLW/LfOsNR33y8K3B2yZVubQh bxIhyiEAAQgs
k0AL8tbzhU8vYx8rb73wYZzI3FLnQLa8tbjydvzQnqC8qXJpk+RNna//ciW1 RTkEIAABCNRD
AHnjom+pF33EzdxlDix/DmTLWz1vp+Uiuf3g3uBn3lQ5GwQgAAEI9EkAeVv+ xQ8XsOSQOcAc
WOocyJa3Flfejh7YNxze799VORsEIAABCPRJAHnjom+pF33EzdxlDix/DmTL W59v3YwaAhCA
AAR6JTCHvPXKlnHHE9DzMP4MakIAAksmoMU7W95aXHlbcmKJHQIQgAAEpiWA vE3Ll9bjCCBv
cZyoBYFWCCBvrWSScUAAAhCAwKwEkLdZcdOZh4Ceh7/+y28Yxuyf+sR7YAsB CCyIQDF5W9CY
CRUCEIAABCCQTQB5y0ZIAwUI6Hn4qxffNHzyK8+N2guEQRMQgMBMBIrJG7dN zpQxuoEABCAA
gSoItCBv5hdMp0LVX4WTel5ufftLsaeMw/VVPlP2N4bNVPImjVMqHzMWzoEA BGQCxeRN7mr5
Nf7lP/y3yx8EI4AABCAAgSIEWpA3BWLsRfjY84rAz4g7pf8lydsH3vvmrVW3 v7//Z7b2z//1
xvClrz87SF/SreqN2Vad/zExcw4EWiBQTN5qWXlTcUh7bOLOv/rDw/orH7u+ v+67zm77WZWz
QQACEIBAnwRalDd7VcvMrL1K51q1k47ZF/xS/dDMcrVlx6vl1LfCKK086j7M vuzntuD5OIVY
5ryC9Dx817se2iZvf/m1zeGr33xu2/61qz/bu6rj2syx5+QpZ2ycCwEIvJBA MXmrBa4kkVK5
OY5HXvGh4bF7nhweP/fx4T1HPjqsv+qxbT+rcmnL+ctUzrlSXJRDAAIQgEAe gVblzSdANi3p
PcolPlqmzEdXf/pYqI8UeYsZk6svSd6kdl3SJ8WdOiv1PHz7O352m7wpSfvm M9/eWnk7+tMf
HP7NG39p+J4feefwj+9Y39r/wcG3DH/3++8b/tb3vkGUN2mcqTFTHwIQGE+g mLylSNH4cOUz
pTikcrOHt778g1vi9uTbPjNcvOtjwxtfen7bz6pc2qQ3t9D5OedKcVEOAQhA AAJ5BHqTtxjp
cK3c+c7zyVJo9S8kej4xDPUv9SXJlzRe3/lSvykzU8/Dt6y/c5u8fWvzO8PG s/9j27757HcG
veuyzee+g7ylAKcuBFZMoJi8rXgc17uX5EwqN8dx/8vevbXipsTtwoGPDEdu ObXtZ1UubSm3
GvhutUDiJMqUQwACEJifQE/ypumatwhKMldi5S31D5wxK2W+uFx9heQtRkol +Ssxa/U8/ImH
f3FL3r618e3ruxI1tfJ26M0fGF61dmHYc3XF7e/9wANb+9/5vnuv1dv8NvJW IhG0AYGZCBST
txQpmnJsOg77r1r6F6gu9z3q2NQ/J1GfcVOrbWpX4qZ3fUyVS//EZOybm/kX xCl50TYEIAAB
CIwj0KO8me9NY9/fQvIktWlmyveHTakNSSpDfcTIq0vYUrilzkY9D9/wlvcO 9v7UZ78wSPsX
vvhl5C0VOvUhsEICxeRthWPY1rUkkVK52ZiSNPMzb0rezJ9VubS53kR8t1lI bzhSX5RDAAIQ
gMB8BFqQN9cdHy55cd1FooXElpXYNs3zfW2Espkib1L8qW3puHzv52a577kp gjmzVs9DXxvS
f5v0nRcjuaXGkDN+zoVAbwSKyVuKFE0JWYpDKjdje/1LHg5+5k2VS1uqkIX+ qif1RTkEIAAB
CMxHoAV5m4/WPD25JMwnZvNENH0vU8nb9JHTAwQgMIZAMXkb0/kU50hyJpWb MZ3ad/+2z7ip
lTbzM3CqXNokeQu90bT+hiOxoxwCEIBAzQSQt/qyg7zVlxMiggAEyhIoJm8p UlR2CNtbk77j
LSXOd7zm8UEJmt7VZ9zMn1V5zGbfVuC6fUO6pSOmH+pAAAIQgMB8BJC3+VjT k5+AtPIGOwhA
oC0CxeStLSzu0Uj/nKQHBowRAhCAAASuEZhD3vSbNI+Xt3izw4A5wBxgDlyb A2pBaod+sn7h
0qD2lC1lRSulXepCAAIQgAAEaiQwh7zVOG5iqosAK2915YNoIDA1AVbepiZM +xCAAAQg0CQB
5K3JtC5uUMjb4lJGwBDIIlBM3lh5y8oDJ0MAAhCAwMIIIG8LS1ij4ep5+Ou/ /IZhzP6pT7yn
UTIMCwJtEkDeEvKKoCbAoioEIACBxgkgb40neCHD0/PwVy++afjkV54btS9k qIQJAQhcJVBM
3qAJAQhAAAIQ6IlAC/Lm+pJlvqZmWbN4Knmzv4Dc/NLumC/nZh4tax4R7XII FJO3Hlalehjj
cqYukUIAAhBYLQHkbbX86f0aAT0PP/DeN2+tuv39/T+ztX/+rzeGL3392eHO t354+MH7PzB8
/7l3D9998ueGf/SDD2/t/9u//qnhb7/yDVv1XFtIvmLELKYOOYQABNIJFJO3 9K77PoOvHeg7
/4weAhBYPoFW5E1lwrzQtp9L31XqW72LWZ1Z/ixY/Qj0PHzXux7aJm9/+bXN 4avffG7b/rWr
P9u7qpMjb/YKnW7L9/21qydGBBBYNoFi8tbiqlTJL/w+/+oPD+uvfOz6rr7w 2/xZlS9xk/6y
JpUvcczEDAEIQEAR6EHezEybt82ZF+j2c/v3Pu8D075e9Dx8+zt+dpu8KUn7 5jPf3lp5O/rT
Hxz+zRt/afieH3nn8I/vWN/a/8HBtwx/9/vvG/7W977BK28+AfPJvvmHAPI+ bd5pvV8CxeSt
RYSSkErlJpNHXvGh4bF7nhweP/fx4T1HPjqsv+qxbT+rcmnz3X9u/5VLakf/ cnW9wab+spXq
S+UxsVIHAhCAQI0EWpI330W3a1UltEpnvr+w8jLPrNXz8C3r79wmb9/a/M6w 8ez/2LZvPvud
Qe+6bPO573jlzTcC5G2e3NILBFwEislbisgsJRXSmKRyc5xvffkHt8Ttybd9 Zrh418eGN770
/LafVbm0SSKUcotK6DYXKQ6zPCamlPaoCwEIQGApBFqXN98KWoy8LSWHLcSp 5+FPPPyLW/L2
rY1vX9+VqKmVt0Nv/sDwqrULw56rK25/7wce2Nr/zvfde63e5reRtxYmAmPo hkAxeWuRmCRn
UrnJ5P6XvXtrxU2J24UDHxmO3HJq28+qXNpCohT6K5irXfv2F9/tMNJnGex+ 7fqS3EljphwC
EIBArQRakzfF2fwdXkreeB+YdgbrefiGt7x3sPenPvuFQdq/8MUvI2/TpojW IVCUQDF5SxGZ
oiOYsDE9Jt/tirrc96hDU/+cRH3GTa22qV2Jm971MVUu/RMT1+0ruo/S8hbz pq3f6M1HOx7e
tCecoDQNAQislEDr8mbKnE/qQqtwKXeDrDSRC+9cz0PfMKT/Nuk7z3ftY98O 67tesP8YsHDM
hA+BaggUk7dqRlQwEElIpXIzFCVp5mfelLyZP6tyaZti5c0WL9cKXKykueQS eZOySjkEILBU
Ai3I21LZE/cNAlPJG4whAIE6CRSTtxSRqRPFC6OSxiSVmy2+/iUPBz/zpsql zSdCrr+OSdKU
+pmFVKnTY5HikMZMOQQgAIFaCSBvtWamr7gkeeuLBqOFQPsEislbi6gkOZPK TSan9t2/7TNu
aqXN/AycKpe2kLzZ50rSJLXFbZNSNiiHAAR6J4C89T4D6hg/8lZHHogCAnMR KCZvKSIz1+By
+yn5PW/veM3jgxI0vavPuJk/q3JpC91/XlreVHv2fe26D99n71z1JYmUxkw5 BCAAgVoJzCFv
+k2ax8tb36vHDgPmAHOAOXBtDihP2aGfrF+4NKidbToC0j8nma5nWoYABCAA gRIE5pC3EnHS
RtsEWHlrO7+MDgI2AVbeGp8TYz4P1zgShgcBCECgCAHkrQhGGskkgLxlAuR0 CCyMQDF5W9i4
CRcCEIAABCCQRQB5y8LHyYUI6Hn467/8hmHM/qlPvKdQJDQDAQjMQaCYvLX4 mbc5EkAfEIAA
BCCwTALIm5y3nM89S/9YS+69jxp6Hv7qxTcNn/zKc+L+R9/49qB3Xb8PUowS Am0QQN5WlEdk
d0Xg6RYCEIBAIQKtyJvvn1DFYJLkzPc1MzltS33GtN1SnankDc4tzRLG0hKB YvLWEhTGAgEI
QAACEJAItCBvU1+g57TPyps0A6+V63n4gfe+eWvV7e/v/5mt/fN/vTF8/kvb 97/6m83h//yZ
39za/9H3nhz+6m+e3arn2nJyFxc5tSAAgTEEiskbK0lp+OGVxovaEIAABGoj 0Lq8hb7+xbWi
FlvfV08f13kOfS2Nq05t82OuePQ8fNe7Htomb3/5tc3hL4z9q9987rq0KXFT Ave1q8fUcZ+8
mTmxc+77PljVlu+rhuZiQj8QaJlAMXlrGVLtY+NrB2rPEPFBAAItEmhB3nwX 2r4Lc5dg+S78
ddvmo1lXWlkLxeBqs9eVIj0P3/6On90mb0rM1K4k7ZvPfHvr8bYfeNP1lTd9 TIlcKIe2KJs/
u/IZkroWfw8wJgjMTaCYvLGSFE5dyS/8Pv/qDw/rr3zs+q6+8Nv8WZXPtUlv llL5XHHSDwQg
AIHSBFqRN98FuGvlK3a1JWWVxhZI3+fkXG3mfF6v9HxYVXt6Hr5l/Z3b5O1b m9/ZujVSr7Lp
x5fd9cuD2vWtk+oxVt5C8m3mh7ysajbQbw8EislbD7ByxijJrVRu9v3IKz40 PHbPk8Pj5z4+
vOfIR4f1Vz227WdVLm32X0/NN0/p3NAvb/tc5C2FJnUhAIElEWhd3lIu6FNW yaSVmRR5W9J8
mSpWPQ9/4uFf3JK3b218+/r+368+f82P/cctgVOPG89+Z9tn3pS4bTz3neLy NtVYaRcCELj2
OVe1K3fYoZ+sX7g0qD1lS5GPlHZbqSvxkcpNDm99+Qe3xO3Jt31muHjXx4Y3 vvT8tp9VubQh
bxIhyiEAAQiECfQkb7FCpYn5Vt5cf9CTxE9q0y7vbd7qefiGt7x3cO3/9bN/ tiVv//WzX9ja
zX9Yop5/4YtfnlTe+CNubzOS8U5NoJi8TR3o0tuX5EwqN8d//8vevbXipsTt woGPDEduObXt
Z1UubTFvrL4PHPtuh3DV55e2lAnKIQCBpRJoQd5Ct7fF/E43f8eHbrP03VJn ipfdX+i9xnXe
UudRbtx6Hsa0o2+V1J9z07dS+s41/9DrE2/fPHH9kTgmRupAAALyHw5ZeZth lmg5s9+M9C9D
Xe571CGqf06iPuOmVtvUrsRN7/qYKpf+iYkkb2P/Eur7C+kMiOkCAhCAwKwE WpC3WYHR2SQE
ppS3SQKmUQhAIIsAK29Z+OJPllbWpHKzJyVp5mfelLyZP6tyabP/WipJV8wt M6G/ukrxUA4B
CEBgaQSQt6VlrM14U+TN9Z8lff9tsk1ajAoCyydQTN5S5GP52NJHIPGRys0e X/+Sh4OfeVPl
0jaFvLn65LZJKROUQwACSyWAvC01c23FnSJvbY2c0UCgTwLF5K1PfPGjluRM Kjd7OrXv/m2f
cVMrbeZn4FS5tPmkKmaFzWw7tb4UF+UQgAAElkJgDnnTb9I8XvvvauwwYA4w B5gD/LfJWa4T
Sn7P2zte8/igBE3v6jNu5s+qXNokeVPn8w9LJIqUQwACPROYQ9565svY4wiw 8hbHiVoQaIUA
K28NZFL65yQNDJEhQAACEKiOAPJWXUq6DAh56zLtDLpjAsXkLeW2v455Xx86 vJgFEIAABJZN
AHlbdv5aiR55ayWTjAMCcQSKyVtcd9SCAAQgAAEItEEAeWsjj0sfBfK29AwS PwTSCBSTN1aS
0sBTGwIQgAAElk0AeVt2/lqJHnlrJZOMAwJxBJC3OE7Fa5WU3ZJtFR8oDUIA AhBolADy1mhi
FzYs5G1hCSNcCGQSKCZvmXFwOgQgAAEIQGBRBJC3RaWr2WCRt2ZTy8Ag4CRQ TN5Y/UmbYSV5
lWwrbRTUhgAEINAvAeSt39zXNHLkraZsEAsEpidQTN6mD5Ue5iDA1w7MQZk+ IACBFgggby1k
cfljQN6Wn0NGAIEUAsXkjdWfFOzDkMOr5Bd+n3/1h4f1Vz52fVdf+G3+rMpz Nt+Xgee0mXOu
FI9UntM350IAAm0RQN7ayudSR4O8LTVzxA2BcQSKydu47jlrDAFJ/KRys89H XvGh4bF7nhwe
P/fx4T1HPjqsv+qxbT+r8thNiY+5q/NKyZBu14zFdUyKVYpHKpfapxwCEOiH APLWT65rHiny
VnN2iA0C5QkUk7cUYSg/jOW1mMNLOlcqN2m99eUf3BK3J9/2meHiXR8b3vjS 89t+VuUxm096
SskQ8haTBepAAAJzEkDe5qRNXz4CyBtzAwJ9ESgmb31hW+1oJTmTys3o73/Z u7dW3JS4XTjw
keHILae2/azKpS0kaGaZvSqn23Ud963g6fbsR9VWTPtSPKVkU2JGOQQgsHwC yNvyc9jCCJC3
FrLIGCAQT6CYvKUIQ3x47dbM4aXPtW9T1OKhy32Pmqr65yTqM25qtU3tStz0 ro+pcumfmMTK
m5lNl3yZMmdn3idtvnZKHW93BjIyCEAglwDylkuQ80sQQN5KUKQNCCyHQDF5 W86Qlx+pJH5S
uUlASZr5mTclb+bPqlzaYuXN95k4+3zfLZIuucuRtCk/oycxoxwCEFg+AeRt +TlsYQTIWwtZ
ZAwQiCdQTN5ShCE+vHZr5vCSzpXKTaqvf8nDwc+8qXJpi5E3l6CZ7UqfabNv d7RFztd+7HGX
GErjphwCEOibwBzypt+kebw8wAAGzAHmAHPgxhxQ1/s7FBD1ZP3Cpa2drU4C kpxJ5eaoTu27
f9tn3NRKm/kZOFUes0n/sESSN9WHq43Q7ZXmObGSlrpSFzN26kAAAn0SmEPe +iTLqFMIsPKW
Qou6EFg+AVbeVpTDFMGyQyz5PW/veM3jgxI0vavPuJk/q/LYTboNMXTb5Nh/ JCKdpwXP9c9M
fMdix0s9CECgbwLIW9/5r2X0yFstmSAOCMxDoJi8zRMuvUxNQPrnJFP3T/sQ gAAElkIAeVtK
ptqOE3lrO7+MDgI2gWLylrOS1GNa4NVj1hkzBCDQEgHkraVsLncsyNtyc0fk EBhDoJi8jemc
cyAAAQhAAAJLJYC8LTVzbcWNvLWVT0YDAYlAMXljJUlCvb0cXmm8qA0BCECg NgLIW20Z6TMe
5K3PvDPqfgkgbyvKfa3yVmtcK0oT3UIAAhDwEkDemBw1EEDeasgCMUBgPgLF 5G2+kOkJAhCA
AAQgsHoCyNvqc0AEw9b337FBAAL9ECgmb6zYpE2aWnnVGlcaXWpDAAIQmJ4A 8jY9Y3qQCSBv
MiNqQKAlAsXkrSUojKUMAb52oAxHWoEABOokgLzVmZfeokLeess44+2dQDF5 Y8UmbSrVwqvk
F36ff/WHh/VXPnZ9V1/4bf6sytkgAAEItEIAeWslk8seB/K27PwRPQRSCRST t9SOqV8HAUki
pXJzFI+84kPDY/c8OTx+7uPDe458dFh/1WPbflblMduOHTsGc485x6yjzmWD AAQgMDUB5G1q
wrQfQwB5i6FEHQi0Q6CYvKVc5LeDb/xIauElxSGVmwTe+vIPbonbk2/7zHDx ro8Nb3zp+W0/
q3JpKyFeJdqQ4qQcAhCAAPLGHKiBAPJWQxaIAQLzESgmb/OFTE8lCUhyJpWb sdz/sndvrbgp
cbtw4CPDkVtObftZlUubT7zs4+bP9iqda9Uu5piuI8VIOQQgAAFFAHljHtRA AHmrIQvEAIH5
CBSTt5SL/PmGV29PtfDScdi3Kmo50uW+R01Y/XMS9Rk3tdqmdiVuetfHVHnM PzHxiZaZTR2f
S/ZCoqfacJ1ry2C9M4fIIACBWgggb7Vkou84kLe+88/o+yNQTN76Q9fGiCWJ lMpNCkrSzM+8
KXkzf1blqZtLqlyrbi6x08d8YuoTNm67TM0S9SHQJ4E55E2/SfN4eWulkx0G zAHmAHPg2hxQ
1+g79JP1C5cGtadsKRf5Ke22WrcWXlIcUrmZn9e/5OHgZ95UeeomyZstaObK mlnm6hd5S80G
9SEAAZPAHPIGcQhIBFh5kwhRDoG2CLDy1lY+k0cjyZlUbnZ4at/92z7jplba zM/AqfLUTboF
0mzPdyulrw3kLTUb1IcABJA35kBtBJC32jJCPBCYlkAxeUu5yJ92SMtovRZe Jb/n7R2veXxQ
gqZ39Rk382dVLm3S1wS4RMz1j0bsY9Ln6PjMm5QZyiEAAZsAK2/MiRoIIG81 ZIEYIDAfgWLy
Nl/I9LQUAjH/nCRlLHwWLYUWdSEAgakJIG9TE6b9GALIWwwl6kCgHQLF5K2W laSlpAZe6ZlC
3tKZcQYEIDAdAeRtOra0HE8AeYtnRU0ItECgmLy1AIMxQAACEIAABGIJIG+x pKg3JQHkbUq6
tA2B+ggUkzdWktKSC680XtSGAAQgUBsB5K22jPQZD/LWZ94Zdb8EkLcV5b4H eethjCuaPnQL
AQhUQAB5qyAJhLD1fU9sEIBAPwSKyVs/yBgpBCAAAQhAYLh+0Zz6hbHqD1u3 3Xbb1vepql39
bLZh/gxnCEgEkDeJEOUQaItAMXljlSVtYvTAK2eM6/fcNEh7GnFqQwACEChL gJW3sjxpbRwB
5G0cN86CwFIJFJO3pQIg7joJKHHb2Lzi3VU5GwQgAIFVEkDeVkmfvjUB5I25 AIG+CBSTt5xV
lr6QXxtti7xKfuH3I3fvDMqbKs/ZWvjagRbGkJNDzoXAqgkgb6vOAP0rAsgb 8wACfREoJm99
YWO0LgKSkErlZpsP3rVzeGbjqa19Y/P5XT+/+qjKYzclOeauzistPqXbs8c2 9RhsPrFsqQeB
ngkgbz1nv56xI2/15IJIIDAHgWLylnJhPsfAau+jRV72mGyhSRnzA3fePDz6 0JHhvGdX5TGb
T6pKypYWn5h4dJ2U/qceg91+SmwpY6YuBFojgLy1ltFljgd5W2beiBoCYwkU k7exAXBeOwRK
ytt9J14cvG1SlUtbSELMMt+qk+t4qK4Uj10eI31zjmGMWKaOmfoQaIkA8tZS Npc7FuRtubkj
cgiMIVBM3lJWVcYE2to5LfLSY7Jv8dMCost9j2aO773jlqC8qXJpixUfsx19 juvcMe1JMary
kMSN6XPsGHQsMTFTBwIQmOerAlK/hoD6l7d97QI84MEcYA60OgfU9fQONTj1 RH/3DG/OEEgh
UHLl7cyxXcHPvKlyaYsVH9/nyVy3E465hTH282Q5wjj1GCTWlEOgRwKsvPWY 9frGzMpbfTkh
IghMSYCVtynpBtpueeVNDzvnM2+njuwe1s6dHtbOundVLm0x8iZ93su1KuY7 JsXjK89deSsx
Bj7nNjZ7nNczAeSt5+zXM3bkrZ5cEAkE5iBQTN7mCJY+6iYgCalUbo7u5OFb g7dNqvKYTVop
k8RH9RGzIjZGfmI+8+br3zyeO4Yxscewpw4EWieAvLWe4WWMD3lbRp6IEgKl CBSTt5QL81LB
L7mdFnmV/J6344f2BOVNlcduvlsK9fmhWw5NsfHd/hh7W6QZb6owTTkGu+3U 2GLzQD0ItEYA
eWsto8scD/K2zLwRNQTGEigmb2MD4DwIuAjcfnBv8DNvqpwNAhCAwCoJIG+r pE/fmgDyxlyA
QF8EislbiytJU06FHnjljPHogX3D4f3+XZWzQQACEFglAeRtlfTpG3ljDkCg TwLF5K1PfIwa
AhCAAAR6JYC89Zr5usbNyltd+SAaCExNoJi85ayyTD3IGtuHV41ZISYIQAAC 8QSQt3hW1JyO
API2HVtahkCNBJC3FWWlB3nrYYwrmj50CwEIVEAAeasgCYSw9aXkbBCAQD8E islbP8gYKQQg
AAEIQGC4ftGs30hjH9Uftm677bZh/cKlrV39bJ5r/gxnCEgEkDeJEOUQaItA MXljlSVtYvTA
K2eM6/fcNEh7GnFqQwACEChLgJW3sjxpbRwB5G0cN86CwFIJFJO3pQIg7joJ KHHb2Lzi3VU5
GwQgAIFVEkDeVkmfvjUB5I25AIG+CBSTt5xVlr6QXxtti7xKfkn3I3fvDMqb Ks/Z+CLqHHqc
CwEIKALIG/OgBgLIWw1ZIAYIzEegmLzNFzI91UpAElKp3BzXg3ftDH5JtyqP 3ZSombs6r6S8
2W3HxkU9CEBg2QSQt2Xnr5XokbdWMsk4IBBHoJi8pVyYx4XWdq0WeUljksrN jD9w583Dow8d
Gc57dlUes/kkrZS82e2UajdmbNSBAARWSwB5Wy1/er9GAHljJkCgLwLF5K0v bIzWRUCSM6nc
bPO+Ey8O3japyqUtJFJmmW/lzHVcWmVD3qSsUA6BdgjMIW+x/8GSepe3/cdO eMCDOcAcaH0O
qOvqHWqQ6on+98Upb7EpF+Yp7bZat0Veekz2bYpaaHS579HM9b133BKUN1Uu bbHyZrajz3Gd
K4mZVC7FSzkEILAsAnPI27KIEO0qCLDytgrq9AmB1RFg5W117JvrWRJSqdwE cubYruBn3lS5
tMXKm+8zca5bIqe+DVMaE+UQgEA9BJC3enLRcyTIW8/ZZ+w9EigmbykX5j2C tsfcIi9pTFK5
yejUkd3D2rnTw9pZ967KpS1G3qTPrGmxM/uyj7HiJmWCcgi0SQB5azOvSxsV 8ra0jBEvBPII
FJO3vDA4uwUCkpxJ5SaDk4dvDd42qcpjNmmlTJI31UfoFkrELSYL1IFAmwSQ tzbzurRRIW9L
yxjxQiCPQDF5S7kwzwu5jbNb5FXye96OH9oTlDdVHrv5bovU54dum5T+sYnv 832xsVEPAhBY
LgHkbbm5ayly5K2lbDIWCMgEismb3BU1IBBP4PaDe4OfeVPlbBCAAARWSQB5 WyV9+tYEkDfm
AgT6IlBM3lpcSZpyKvTAK2eMRw/sGw7v9++qnA0CEIDAKgkgb6ukT9/IG3MA An0SKCZvfeJj
1BCAAAQg0CsB5K3XzNc1blbe6soH0UBgagLF5C1nlWXqQdbYPrxqzAoxQQAC EIgngLzFs6Lm
dASQt+nY0jIEaiSAvK0oKz3IW8kxlmxrRSmnWwhAoDECyFtjCV3ocJC3hSaO sCEwkkAxeRvZ
P6dBAAIQgAAEFkkAeVtk2poLGnlrLqUMCAJBAsXkjZWRtJnWA6+SYyzZVlqm qA0BCEDATQB5
Y2bUQAB5qyELxACB+QgUk7f5QqYnCEAAAhCAwOoJIG+rzwERDAPyxiyAQF8E iskbKyNpE6cH
XiXHmNPW+g/vHEK7ytz3/n/+TVoCqQ0BCHRPAHnrfgpUAQB5qyINBAGB2QgU k7fZIqYjCCQS
eMvJm4eNzSvO/eMfeWSrNSVvu/9f/zSx5WHYsWNH8By7XKofasx1rjqm99Tg pVik8tT+qA+B
1gggb61ldJnjQd6WmTeihsBYAsXkLWdlZGzwSz6vB14lx5jT1htfd8sLxO27 f/Rdg9pfdvz+
4eU/cGJL3sYKXIpw5QiRJII5bbvGULq9Jb9eiR0CLgJzyJt+k+bx8tbtgeww YA4wB5gD1+aA
ujbeoZ+sX7g0qJ0NAi0QOHX01uGZjae29o3N7ftHf+Xt0StvrlUuLThmmSk9 9jm+NlyrZzHn
mvnxyZZ0PDb2FuYCY4BASQJzyFvJeGmrTQKsvLWZV0YFAR8BVt5WNDdyVpJW FHJytyXHqNuK
fTSDfd1r/8nwg//Hbc5dlalN+sybb9XLlDeXSKWulvnaU22HVsLGlKXGnjwB OAECjRNA3hpP
8EKGh7wtJFGECYFCBIrJW6F4aAYCVRKwV6ds8ZHkTg/KVc+18uVbiXPBGXt7 I/JW5VQjqAUR
QN4WlKyGQ0XeGk4uQ4OAg0AxeSu5ytJDpnrgVesY/x+33Zk8xWJuPSyx8mYH ZkqcK4ax4mau
5MWKZzI0ToBA4wSQt8YTvJDhIW8LSRRhQqAQgWLyVigemoHApASUuJWQt5Ir by7pGyOCPnCl
xHPSxNA4BBZIAHlbYNIaDBl5azCpDAkCAQLF5K3WVZZas98Dr1rHOEbe9EqV fTujdOuheZ6e
i642Yo7Zbflu5bTn/Fh5c8Ve6+uJuCCwCgLI2yqo06dNAHljTkCgLwLF5K0v bIx2yQTGytuS
x0zsEIBAeQLIW3mmtJhOAHlLZ8YZEFgygWLyVusqS63J6YFXjWPUt00icLW+ MogLAsshgLwt
J1ctR4q8tZxdxgaBFxIoJm/AhQAEIAABCPREAHnrKdv1jhV5qzc3RAaBKQgU k7caV1mmAFaq
zR549TDGUvOBdiAAgeURQN6Wl7MWI0beWswqY4KAnwDytqLZ0YPY9DDGFU0f uoUABCoggLxV
kARCGJA3JgEE+iJQTN76wsZoIQABCECgdwLIW+8zoI7xI2915IEoIDAXgWLy xipLWsp64JUz
xvV7bhqkPY04tSEAAQiUJYC8leVJa+MIIG/juHEWBJZKoJi8LRUAcddJQInb xuYV767K2SAA
AQiskgDytkr69K0JIG/MBQj0RaCYvOWssvSF/NpoW+SlxiTtsbl+5O6dQXlT 5Tmb74urc9rk
XAhAoC8CyFtf+a51tMhbrZkhLghMQ6CYvE0THq0uiYAkpFK5OdYH79o5PLPx 1Na+sfn8rp9f
fVTlsZsSNXNX55WUN7vt2LioBwEILJvAHPKm36R5vLz1jznYYcAcYA4wB67N AXVdvUM/Wb9w
aVB7ypZyYZ7Sbqt1W+Rlj8kWpJQxP3DnzcOjDx0Zznt2VR6z+SStlLzZ7ZRq N2Zs1IEABFZL
YA55W+0I6X0JBFh5W0KWiBEC5Qiw8laOZfctlZS3+068OHjbpCqXtpBImWW+ lTPXcWmVDXmT
skI5BNohgLy1k8sljwR5W3L2iB0C6QSKyVvKqkp6mO2d0SIvPSb7NkUtNLrc 92hm+d47bgnK
myqXtlh5M9vR57jOldpD3KSMUA6Btgggb23lc6mjQd6WmjnihsA4AsXkbVz3 nNUSgZIrb2eO
7Qp+5k2VS5skW/p832fiXLdESoImlUsxUw4BCCyHAPK2nFy1HCny1nJ2GRsE XkigmLy1uJI0
5YRpkVdJeTt1ZPewdu70sHbWvatyaYuRN+kza1rs7NW5qT9LJ42NcghAYPUE kLfV54AIhq1/
XMAGAQj0Q6CYvPWDjJH6CEhCKpWb7Z48fGvwtklVHrNJkiXJm+ojdAtlzPkx cVIHAhBYHgHk
bXk5azFi5K3FrDImCPgJFJO3lAtzEsL3vElz4PihPUF5U+Wxm++2SH1+6LbJ sf/YJDY26kEA
AsslgLwtN3ctRY68tZRNxgIBmUAxeZO7ogYE4gncfnBv8DNvqpwNAhCAwCoJ IG+rpE/fmgDy
xlyAQF8EiskbK29pE6cHXjljPHpg33B4v39X5WwQgAAEVkkAeVslffpG3pgD EOiTQDF56xMf
o4YABCAAgV4JIG+9Zr6ucbPyVlc+iAYCUxMoJm85qyxTD7LG9uFVY1aICQIQ gEA8AeQtnhU1
pyOAvE3HlpYhUCMB5G1FWelB3noY44qmD91CAAIVEEDeKkgCIfBVAcwBCHRG oJi8dcaN4UIA
AhCAQOcEkLfOJ0Alw2flrZJEEAYEZiJQTN5YZUnLWA+8csa4fs9Ng7SnEac2 BCAAgbIEkLey
PGltHAHkbRw3zoLAUgkUk7elAiDuOgkocdvYvOLdVTkbBCAAgVUSQN5WSZ++ NQHkjbkAgb4I
FJO3nFWWvpBfG22LvNSYpD0214/cvTMob6qcDQIQgMAqCcwhb/pNmsfLW5/t YocBc4A5wBy4
NgfUNfcO/WT9wqVB7WwQSCEgCalUbvb14F07g1/Srcpjth07dgx6j6kfW8ds Vz2P2WLrxbRF
HQhAYPUE5pC31Y+SCGonwMpb7RkiPgiUJcDKW1me0a2liEx0oyuuaI/JlpWU MT9w583Dow8d
Gc57dlWespUWJ7u9mPZj6qSMiboQgMBqCSBvq+VP79cIIG/MBAj0RaCYvPWF jdG6CJSUt/tO
vDh426QqT9lMcXKtxoVkLKa+iiWmD3sVcKqVwRQ21IUABMYRQN7GceOssgSQ t7I8aQ0CtRMo
Jm8pqyq1Q5kjvhZ56THZtxRqqdHlvkeT+7133BKUN1WesvlWvfTx2JU0X31b 3szYYvtgZS4l
o9SFwOoJIG+rzwERsPLGHIBAbwSKyVtv4BjvCwmUXHk7c2xX8DNvqjxl862K 2cddEub6fJtL
tKQ+XII45rNzKeOmLgQgMB0B5G06trQcT4CVt3hW1IRACwSKyVuLK0lTJrhF XiXl7dSR3cPa
udPD2ln3rspTtpjVL1cd34pcSN5iz2GlLSWD1IVAfQSQt/py0mNEyFuPWWfM PRMoJm89Q2Ts
1whIQiqVmxxPHr41eNukKk/ZYuRNtSfdPhnTzlh5Q+ZSMkpdCKyeAPK2+hwQ AbdNMgcg0BuB
YvKWcmHeG2TXeFvkJX3HW8qYjx/aE5Q3VS5tvn8GErpV0beiZrcl3e7oK9fH dey+GKWxUQ4B
CKyeAPK2+hwQAfLGHIBAbwSKyVtv4BjvtARuP7g3+Jk3Vc4GAQhAYJUEkLdV 0qdvTYDbJpkL
EOiLQDF5S1lV6Quxe7TwCs+Cowf2DYf3+3dVzgYBCEBglQSQt1XSp2/kjTkA gT4JFJO3PvEx
aghAAAIQ6JUA8tZr5usaNytvdeWDaCAwNYFi8sZKUlqq4JXGi9oQgAAEaiOA vNWWkT7jQd76
zDuj7pcA8rai3CNvKwJPtxCAAAQKEUDeCoGkmSwCyFsWPk6GwOIIFJO3xY2c gCEAAQhAAAIZ
BJC3DHicWowA8lYMJQ1BYBEEiskbK0lp+YZXGi9qQwACEKiNAPJWW0b6jAd5 6zPvjLpfAsXk
rV+Eqx/5v/yH/3b1QRABBCAAgc4IzCFv+k2ax8sDDGDAHGAOMAduzAG1ELRD AVFP1i9c2tpT
NlaSwrRKfoH1+Vd/eFh/5WPX99d919ltP6tytnYJuL5IvN3RMjII1EtgDnmr d/REVgsBVt5q
yQRxQGAeAqy8zcN5S4pDm1RunvvIKz40PHbPk8Pj5z4+vOfIR4f1Vz227WdV Lm1KAOzdPEeX
Se2o8lA7dpux7el2x5xv9yGNNSamUnViWYX6Q95KZYN2IJBHAHnL48fZZQgg b2U40goElkKg
mLylyMdS4JSM0+ZjX4Cn8Hvryz+4JW5Pvu0zw8W7Pja88aXnt/2syqVNEoBU eSshWS7pksaR
Ui6NOaWtsXXtGMbENOacsfFyHgQg4CeAvDE7aiCAvNWQBWKAwHwEisnbfCEv s6eS8nb/y969
teKmxO3CgY8MR245te1nVS5tIQEwy2JEwSck+rjr0ZRDWxTN+nY9Na6QAJkr W5IMhuL2tZN6
PCWG2LZ9+Yk53z43RdKlOUU5BHojgLz1lvE6x4u81ZkXooLAVASKyVvKytFU g6m5Xc3Hdwuf
Lvc96rGpf06iPuOmVtvUrsRN7/qYKpf+iUno9r2S8uZqKyQfppxJUqiZ2HJo H0/9Obff0DyM
XXnzjSnEx+xXYhIbR82vKWKDwKoJIG+rzgD9KwLIG/MAAn0RKCZvfWFLH23J lTclaeZn3pS8
mT+rcmkrvfLmWvWJkaCQ3EkrbKbI6OexUhoSv9gVOXuFUGLuitEWLpujK0++ 1TLX2FPHEjMG
6kAAAtcIIG/MhBoIIG81ZIEYIDAfgWLyxspbOGkl5e31L3k4+Jk3VS5tPnlz rQyGRM8WKFtG
XD/nrryZfaasEvpEyCWBUtwuvjG3IIa4x/bpWlWLEWUfN2muUA4BCLgJIG/M jBoIIG81ZIEY
IDAfgWLyNl/Iy+xJklup3Bz1qX33b/uMm1ppMz8Dp8qlLVYiQnKm+4htS5IO u1y6tS+33Bd/
qgiFhNXOQw4rV7wupiFJk+pL84ZyCEDgBgHkjdlQAwHkrYYsEAME5iNQTN5S 5GO+4dXTU8nv
eXvHax4flKDpXX3GzfxZlUuba4XNJ2qrWnnT8aQIh33bYYxYuWTN147reKjP WHkzx2qv4Nnt
x94KacpebtzSfKIcAj0SQN56zHp9Y0be6ssJEUFgSgLF5G3KIGk7TED65yTw 8xMI3UrZIjdJ
xFscM2OCwFQEkLepyNJuCgHkLYUWdSGwfALF5I2Vt+VPBmkErtW6pcvAVPJW E6uUlUFpDlAO
AQjcIIC8MRtqIIC81ZAFYoDAfASKydt8IdMTBCAAAQhAYPUEkLfV54AI+KoA 5gAEeiNQTN5Y
eett6jBeCEAAAn0TQN76zn8to2flrZZMEAcE5iGAvM3DmV4gAAEIQKAxAshb Ywld6HCQt4Um
jrAhMJJAMXkb2f/woZ/aG9zHtst5EIAABCAAgSkJIG9T0qXtWALIWywp6kGg DQLF5G3sbZNK
3jaf/bZz//TFf7cldmwQgAAEIACB2gjMIW/6TZrHywMMYMAcYA4wB27MAeVe OxQQ9WT9wqWt
fY7t/T/5T4ZnNp9z7n/4kXuGzyBwc6SBPiAAAQhAIJHAHPKWGBLVOyTAyluH SWfIXRMYvfJW
6kunP/1bbx++tfHcoL6rTD2a+9OXf3JQAvfpi4eG97zptlGJGvOv7O0vSR7V ceRJUnxSeWQ3
3mpTtx8TXw0xhOKccz6sgpfE3/el4DGxUgcCLRNA3lrO7nLGhrwtJ1dECoES BLLkLRRAzG2U
51/94WH9lY9t7a/7rrPXn6vj3/jWc9f3//bfnxsu/PhLRo239gvT1PhiIUjt 6nZi68X2O6ae
jqGGWOz4e4hJGqNP3lzfZTcm/5wDgaUSQN6Wmrm24kbe2sono4GARGCl8vbW l39wePJtnxku
3vWx4Y0vPX/9uTr+9avydn3/5nPDz73hn0pjcZaPvTAd1dmIk1LjG9FF8BSp /9L9udqrIQbf
OGuMrXRMUnsheZtjftAHBGolgLzVmpm+4kLe+so3o4XASuXt/pe9e0vcLhz4 yHDkllPXn6vj
X/nGs9v29bMvFSXEXAnQlc0LT1+5eVtcTB3Vtr1aZJ/nutUudPuZvYphx596 rhmfa0zmGMy+
7Lhdq2K+WO0Ehfq1mdtMY8/V57l4x8Qj5c0Xh9l2bqwSY7svX758c046HvMa 8b2eQtLrmkup
8yv0op+TO28VEHARQN6YFzUQQN5qyAIxQGA+AtnyZl/I6wtBfduk71F9xk3d KqlW3JS4qV09
V7s6rsq/9PXN6/uDa98typvrIteWnhQp8gmOKQzSRa19YRy6EA/F75M36bgk fa74XSIl1XOJ
Umw+XCKceq4vPiluX35cQuWagBJ/X77HMpbitduN4egbq08qTaYugXK95kKc Yl8jsSxT5uKY
vuf79UxPtRNA3mrPUB/xIW995JlRQkATyJY3H8qYz7y9/iUPO2+bVMe/+NXN 6/tfXH3+5h/5
Z8GsxVxE26IZkrOUi367ndAF4RLlLeai2XXBHMPbJRuxF/r6XFc/Y+Jx5c0n /z6BCUlfzByV
xjS1vEk5i5nbqfJmz69S+RzzGo7pm7cPCJhvoOp56r+uVu+Pt9122/X/7Kx+ Ntswf4Y2BCQC
yJtEiHIItEVgpfJ2at/912+VVCtu+hZKdfzPvry5bf+JH/7nWfKWcuEcIytj V7R6kjdXwkIX
9tIKkC1MLvn2TRKfhEkyFCNvqeO0pSI0l1wS6pKSGPGU+I5lFIpxjEDF/IqN iXWqvmPio04f
BFh56yPPtY8Seas9Q8QHgbIEVipv73jN44MSNbWrWyX1c3X881/a2Lb/2A/9 i8XLW6zwmVKS
esFt14/ts4TchlZlYlakpLG6xLfk+GIEyBbGWG4u0YwdrySYvphiY5PiiOk/ 9AePqcfuer3k
/gEm5Q8DZX8l09qSCCBvS8pWu7Eib+3mlpFBwEUgS96k73qLQf5rj79v+JO/ 2tj6jJt6dO1/
/Jcbw5k7Xy7Km3nLk+uv7r5bovRx3wWb1G7ogj72wjcUmzkWXyz28ZQLclf7 Ln4xcdgXzSZb
Xz8u4ZTGGduPVE/Kj2uFxyVFMePU88Su6+tDqifF7uvPPm634+s3NG7XObHH 7Be2K/c+AZyD
e8zvMer0SQB56zPvtY0aeastI8QDgWkJjJa3UmGdOvE9w+f+4hlx/5Hj3yPK W6mY5mjHtyqS
27dLBFxtxtaT4inVji1ZUr89lk/BOoXjqvtPiZW6EJiDAPI2B2X6kAggbxIh yiHQFoGVy9vd
r/ve4e7jan/F8EOve8X15zd+vnpM1blaFtqWdmFZUt58KxVT8RrTX8rLZmm5 TBlbTt1Vc1l1
/znsOBcCUxBA3qagSpupBJC3VGLUh8CyCaxc3paNj+ghAAEIQKBXAshbr5mv a9zIW135IBoI
TE0AeZuaMO1DAAIQgECTBJC3JtO6uEEhb4tLGQFDIItAlfIW8x1xWaPmZAhA AAIQgEAmAeQt
EyCnFyGAvBXBSCMQWAyBKuVtMfQIFAIQgAAEuiUwh7ylfgE49S8nf2k6zGDG HGAOLHEOqMWu
HSpw9WT9wqWtfVUbK2+rIk+/EIAABCAQS2AOeYuNhXr9EmDlrd/cM/I+CTS/ 8qa+P44NAhCA
AAQgUJoA8laaKO2NIYC8jaHGORBYLoEq5E36su+Ulbjzr/7wsP7Kx67vr/uu s9t+VuVsEIAA
BCAAgVwCyFsuQc4vQQB5K0GRNiCwHALVyFsIWYq8PfKKDw2P3fPk8Pi5jw/v OfLRYf1Vj237
WZWzQQACEIAABHIJIG+5BDm/BAHkrQRF2oDAcgg0J29vffkHt8Ttybd9Zrh4 18eGN770/Laf
VTkbBCAAAQhAIJcA8pZLkPNLEEDeSlCkDQgsh0Bz8nb/y969teKmxO3CgY8M R245te1nVR6z
7dixY9C7Wd913HdMnafK9OZrMyYe6kAAAhCAQF0EkLe68tFrNMhbr5ln3L0S qEreTLkxxUnf
Nul71MlT/5xEfcZNrbapXYmb3vUxVS79ExNTuEwBs4/bcmbXtcXNlsBeJx3j hgAEINACAeSt
hSwufwzI2/JzyAggkEKgKnnzBZ7ymTclaeZn3pS8mT+rcmnzSWSqvNmyZrcr xUE5BCAAAQjU
SwB5qzc3PUWGvPWUbcYKgeH6d1mu9HveJDmTys1Evv4lDwc/86bKpc0laeqc XHmT+qUcAhCA
AASWQwB5W06uWo4UeWs5u4wNAi8k0NzK26l992/7jJtaaTM/A6fKpa3UbZNm P742pVgohwAE
IACBOgkgb3XmpbeokLfeMs54eydQjbxJ3/UWm6h3vObxQQma3tVn3MyfVXnM VuofltgC5/on
KDHxUAcCEIAABOoigLzVlY9eo0Hees084+6VQBXyNiV86Z+TTNk3bUMAAhCA QLsEkLd2c7uk
kSFvS8oWsUIgn0Dz8paPiBYgAAEIQAACLySAvDEraiCAvNWQBWKAwHwEkLf5 WNMTBCAAAQg0
RAB5ayiZCx4K8rbg5BE6BEYQQN5GQOMUCEAAAhCAAPLGHKiBAPJWQxaIAQLz EWhe3lK+ZmA+
7PQEAQhAAAJLJzCHvOk3aR4vX/9uI1jAgjnAHGAOXB5W+j1vS38DJ34IQAAC EOiPwBzy1h9V
RpxKgJW3VGLUh8CyCbDyFsjf+j03DdK+7PQTPQQgAAEIjCWAvI0lx3klCSBv JWnSFgTqJ9C8
vOWkQInbxuYV767K2SAAAQhAoE8CyFufea9t1MhbbRkhHghMS6A5eZO+7Dvl M3CP3L0zKG+q
vKZNfQE42zwEYD0PZ3qBQM0EkLeas9NPbMhbP7lmpBBQBJqUt1BqU+Ttwbt2 Ds9sPLW1b2w+
v+vnVx9VubSpi3x7N8/RZfax0M92n1okUoUitb40Vqk8xMLFqGR8JdtS4zSZ h/IrMdHlpeOL
7Zd6EIDAeALI23h2nFmOAPJWjiUtQWAJBJqXN/uiOEXeHrjz5uHRh44M5z27 Kpc26aK8hLyN
FQApNmlsqf36+ks9HhtXigCntjlWmH39lMpF6jioDwEIjCeAvI1nx5nlCCBv 5VjSEgSWQAB5
C2TpvhMvDt42qcqlLXRRbpbZz02pM1d2VH+2OPhWgXxy5apv1nUJZcw4JQFJ lbTYcbvG6TrX
ZuqSO5eU2W25cuDi4zpPn2sz9o3VHltsfFK+KIcABPIJIG/5DGkhnwDyls+Q FiCwJALNypt9
K5u+6NUrb75HM3n33nFLUN5UubSFbqkLyZtLLGzB8l3Y5x73SZ80VlNMJJmx RS4kSNK4pfGa
suUbmy20vrG6xNmVY9f4fExy4ovtJyZ31IEABNIIIG9pvKg9DQHkbRqutAqB Wgk0K2++i/SU
2ybPHNsV/MybKpe2sStvkry5yn0X8inHQ7JpytmYVTbpHEnCJFFxrUpJsib1 aY/ZJW8xomqL
euxKmxSf748U0rykHAIQyCeAvOUzpIV8AshbPkNagMCSCCBvgWydOrJ7WDt3 elg7695VubT5
hMV10e2Tj7HSIrUntSuNLSQtvrKYNqW4JSFzMZfGmtpnSBS18MUwGNuvj0EM X+pAAAJlCCBv
ZTjSSh4B5C2PH2dDYGkEmpc3OyEpK28nD98avG1SlUtbSN7sc1Mv5O0L+JQV NpdgSIITGquW
UamOxMuMS4ondrwpY43tM1XepNym9isJbAxn6kAAAnkEkLc8fpxdhgDyVoYj rUBgKQSalDfp
u95ik3P80J6gvKlyafPd1iatDtkyZP4ckhb7djzzIt9V5uvHJ52u8cbWDbGQ 4nYJmD4WGpcZ
W2isIRmz4w4JpslHGlMox76x+eZNjDxLc5VyCEAgjQDylsaL2tMQQN6m4Uqr EKiVQHPyVhL0
7Qf3Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5S7lN0kZ99MC+ 4fB+/67K2SAA
AQhAoE8CyFufea9t1MhbbRkhHghMS6B5eZsWH61DAAIQgECvBJC3XjNf17iR t7ryQTQQmJoA
8jY1YdqHAAQgAIEmCcwhb/pNmsfLAwxgwBxgDjAHbswBdXfhDgVEPVm/cGlr b2HLuW2yhfEz
BghAAAIQmIbAHPI2TeS02hIBVt5ayiZjgYBMgJU3mRE1IAABCEAAAi8ggLwx KWoggLzVkAVi
gMB8BJqXt5yVt/V7bhqkfb5U0RMEIAABCNREAHmrKRv9xoK89Zt7Rt4ngebl LSetStw2Nq94
d1XOBgEIQAACfRJA3vrMe22jRt5qywjxQGBaAs3Jm/QF3SkrcY/cvTMob6qc bXkEpC8Vzy1f
HhEihgAExhBA3sZQ45zSBJC30kRpDwJ1E2hS3kLIU+Ttwbt2Br+kW5VLmxIB ezfP0WVSO2PK
JQnRbdr1Ys8bE1PMOT5mLlZj+Enj0+WhOGLGUaqOFG+pfmgHAhBII4C8pfGi 9jQEkLdpuNIq
BGol0Ly82Re+KfL2wJ03D48+dGQ479lVubRJF95j5EPq0ydlvvOkGGP7k+rF 9uOrtwp5c40p
dhwSj9jyufuLjYt6EOidAPLW+wyoY/zIWx15IAoIzEUAeQuQvu/Ei4O3Tapy aQtdeJtl9nNz
1ceUMddxVS7Vd7XhO+aLJSaOGB6SjITkTY/V9ejjYB+PGZ/Zvj2mmPNN0QxJ Z2reJb6UQwAC
8xFA3uZjTU9+AsgbswMCfRFoVt58t7zplTffo5n+e++4JShvqlza7DjM+iF5 c9Wzpca8vS+m
vk9CctuVZMzFKLTi6GNmj9f3symZLgmL5RYbR6g/V45zeUtzjnIIQGAeAsjb PJzpJUwAeWOG
QKAvAs3Km31BrX9OuW3yzLFdwc+8qXJpG7vyFiNjsRJit2Wv0uXKhGuMvhVC n0D6pDZFdseM
wyVoPq4uSQudb4uj2a50nnnuGDmW5iXlEIBAPgHkLZ8hLeQTQN7yGdICBJZE AHkLZOvUkd3D
2rnTw9pZ967Kpc134e1aGUyVsbH1XRJSQhYlFi6JdJ0TYuaS8rEcpH5yy0Py FjNuSSJTeFMX
AhAoTwB5K8+UFtMJIG/pzDgDAksm0Ly82clJWXk7efjW4G2TqlzaJAEoIU2p K06rlLfQ7ZIu
MXPxsZmXkjfpNswx3LhtUnqFUA6B5RJA3pabu5YiR95ayiZjgYBMoEl5k77r TcZyrcbxQ3uC
8qbKpc21wqbO8d1q6CqT5ESf4xIj+5jrdj3zfLt/1+2PPlmMYSHVscdixh8j wq54XW2aIuZi
FBuHxMclb758hbjGSG8MW+pAAALlCCBv5VjS0ngCyNt4dpwJgSUSaE7eSibh 9oN7g595U+Vs
EIAABCDQJwHkrc+81zZq5K22jBAPBKYl0Ly8pdwmaaM+emDfcHi/f1flbBCA AAQg0CcB5K3P
vNc2auSttowQDwSmJdC8vE2Lj9YhAAEIQKBXAnPIm36T5vHyAAMYMAeYA8yB G3NALVDtUEDU
k/ULl7Z2NghAAAIQgAAE3ATmkDfYQ0AiwMqbRIhyCLRFoPmVt5zbJttKNaOB AAQgAIGSBJC3
kjRpaywB5G0sOc6DwDIJNC9vy0wLUUMAAhCAQO0EkLfaM9RHfMhbH3lmlBDQ BJqXt5yVt/V7
bhqknakEAQhAAAJ9EkDe+sx7baNG3mrLCPFAYFoCzctbDj4lbhubV7y7KmeD AAQgAIE+CSBv
fea9tlEjb7VlhHggMC2B5uRN+oLulJW4R+7eGZQ3VT7F5vsy6in6mqrNKcbA F1VPlS3ahQAE
xhBA3sZQ45zSBJC30kRpDwJ1E2hS3kLIU+Ttwbt2Br+kW5VLmxYO89E8xy5X ZVOIjxRnqHyV
Y9AsbCa1Mcrhy7kQgMAyCSBvy8xba1Ejb61llPFAIEygeXmzL/JT5O2BO28e Hn3oyHDes6ty
aQtJhq9sLjGJ7aeGMcTGKuWDcghAAAKlCCBvpUjSTg4B5C2HHudCYHkEkLdA zu478eLgbZOq
XNrGCJp5TsyKnY7BVzdmVU2q4yqPlbqcMZgrb+ZtkxIj34qdlC/KIQABCMQS QN5iSVFvSgLI
25R0aRsC9RFoVt58t/rplTffo5mie++4JShvqlzaXLdFqnNixcdsPyQkuStT oc+TrXIM0m2T
vtspQ+ORckY5BCAAgRgCyFsMJepMTQB5m5ow7UOgLgLNypvGnHPb5Jlju4Kf eVPl0lZy5c1e
hbLFThLCGKFxtbHKMcTIm0suc2VWyivlEIAABJA35kANBJC3GrJADBCYjwDy FmB96sjuYe3c
6WHtrHtX5dKWIz6+VSVTTF11xoiLtPLmGqcki+qc3DHEyFtqbFLOKIcABCAQ QwB5i6FEnakJ
IG9TE6Z9CNRFoHl5s3Gn/MOSk4dvDd42qcqlLUZw7DYkYTHrp6yU+SRHkr1V jkFiEbptUsoN
5RCAAARyCCBvOfQ4txQB5K0USdqBwDIINClv0ne9xabm+KE9QXlT5dJm39Ln WykzV77MOr5b
Au2VMrOeFJMul6TNrOeKw1eujpcagyRvui8Xj1gO1IMABCAwhgDyNoYa55Qm gLyVJkp7EKib
QHPyVhL37Qf3Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5S7lN 0kZ99MC+4fB+
/67K2SAAAQhAoE8Cc8ibfpPm8fIAAxgwB5gDzIEbc0A5zg4FRD1Zv3Bpa2eD AAQgAAEIQMBN
YA55gz0EJAKsvEmEKIdAWwSaX3lrK12MBgIQgAAEaiGAvNWSib7jQN76zj+j 749A8/KWc9tk
f9OBEUMAAhCAQCwB5C2WFPWmJIC8TUmXtiFQH4Hm5a0+5EQEAQhAAAItEEDe Wsji8seAvC0/
h4wAAikEmpe3nJW39XtuGqQ9BTZ1IQABCECgHQLIWzu5XPJIkLclZ4/YIZBO oHl5S0dy4wwl
bhubV7y7KmeDAAQgAIE+CSBvfea9tlEjb7VlhHggMC2B5uRN+oLulJW4R+7e GZQ3VT7FFvvl
2Sl9219inXJuy3Ul1lJ5y2wYGwQgECaAvDFDaiCAvNWQBWKAwHwEmpS3EL4U eXvwrp3BL+lW
5dKmpcl8NM+xy1VZKWHQ7djtlWpfGrtd7mPhEsu5YjQZTZmLWFZzjTs2HupB AAJ+Asgbs6MG
AshbDVkgBgjMR6B5ebMvhlPk7YE7bx4efejIcN6zq3JpC12M+8pKX8CXbs8l ZRKHkJTWIm+u
MUzNbizLGN7UgQAEpiWAvE3Ll9bjCCBvcZyoBYFWCCBvgUzed+LFwdsmVbm0 jRE085yYFTsd
g13XtapkS5Srfd+KXWisMbdlSizscfvGpcdg9ukTQOm4NFYpFy7mrpVOOw7X Kp9rXNL8ohwC
EFgdAeRtdezp+QYB5I3ZAIG+CDQrb75b9PTKm+/RTP+9d9wSlDdVLm2hi3Tf uSmSYwqO3Z5P
TGKOj11xCkmcxMInb+a4XLG7znMJlC2u5s8psdnnuXIQw1galzS3KIcABFZL AHlbLX96v0YA
eWMmQKAvAs3Km09qUm6bPHNsV/Azb6pc2iQRc53vW+2xV9Lsi/9cYZFWobS0 jF1li2HhkzPX
CpckTS4hi2Vkt+37Y4BPOO1cheL3yaA0tyiHAARWSwB5Wy1/ekfemAMQ6JEA 8hbI+qkju4e1
c6eHtbPuXZVLW4yw2G1IqzamWLhkxD5/rLBIY/OJZ+qYQytnMbHHrLz5ZF4S 1thyU8BiZCxm
XGP4cw4EIDAfAeRtPtb05CfAyhuzAwJ9EWhe3ux0pqy8nTx8a/C2SVUubT6R sS/2zXZi5c3X
xlh5k0QlNNaxq3GuMZhtxUhOjLxJTCXhXHUc0jyjHAIQmJ8A8jY/c3p8IQHk jVkBgb4INClv
0ne9xab4+KE9QXlT5dLmu91Onyfd2ucrt2XJvi3PlCKfeOg6rrakcblkUzrH xyK0emjH6JIw
l7z5xhZqLyUXZv5inkuM7TGEpF/iTDkEIDAPAeRtHs70EiaAvDFDINAXgebk rWT6bj+4N/iZ
N1XOBgEIQAACfRKYQ970mzSPl7f+MQc7DJgDzAHmwLU5oBardugn6xcuDWpv YUu5TdIe79ED
+4bD+/27KmeDAAQgAIE+Ccwhb32SZdQpBFh5S6FFXQgsnwArb8vPISOAAAQg AIEVEEDeVgCd
Ll9AAHljUkCgLwLIW1/5ZrQQgAAEIFCIAPJWCCTNZBFA3rLwcTIEFkegeXnL uW1ycdkkYAhA
AAIQmI0A8jYbajoKEEDemB4Q6ItA8/LWVzoZLQQgAAEIzEUAeZuLNP2ECCBv zA8I9EWgeXnL
WXlbv+emQdr7mi6MFgIQgAAENAHkjblQAwHkrYYsEAME5iPQvLzloFTitrF5 xburcjYIQAAC
EOiTAPLWZ95rGzXyVltGiAcC0xJoTt6kL+hOWYl75O6dQXlT5WzzEpjiy6vt L9Ced0T0BgEI
LJUA8rbUzLUVN/LWVj4ZDQQkAk3KW2jQKfL24F07g1/SrcqlTYuB+ajOsY9L 7ehzYuuNaT+m
7ZJ1fGx0H64xlJI33Y7dXqn2S3KiLQhAoE4CyFudeektKuStt4wz3t4JNC9v 9sV4irw9cOfN
w6MPHRnOe3ZVLm0+GRgjDalikVpfGktseWy/oXqx3GJj8tWLjTW3H86HAATa I4C8tZfTJY4I
eVti1ogZAuMJIG8BdvedeHHwtklVLm0pEmLWtVfqVD+xx3RMkiCaq0+utn19 SmM2zwvVTWHj
GlNKzK6VT9f4YnKgz4vhQB0IQKBdAshbu7ld0siQtyVli1ghkE+gWXnz3ZKn V958jybSe++4
JShvqlzafLcvusRFkhlplShW1mwR8p0ntSeNXZK4FDY+IZXG4hMt6bbJEBMp DzFcqAMBCCyf
APK2/By2MALkrYUsMgYIxBNoVt58F/spt02eObYr+Jk3VS5tkpCZ5/tWfXyi YcqRFiFfeyHJ
kUTFt8Jl9x9iMUZWXe3FMHKNJ1VQffKPuEkznnII9EMAeesn1zWPFHmrOTvE BoHyBJC3ANNT
R3YPa+dOD2tn3bsql7Yx8pYqGj5RDQmTLUEu6SshKi6p9MUrHdeyaD6Gxh6S uNSVt5jYpLlA
OQQg0BYB5K2tfC51NMjbUjNH3BAYR6B5ebOxpKy8nTx8a/C2SVUubbHyNkam pNsax/SdIkih
sYekLUaEpNilsbsEzzW2VFEuIbTSnKEcAhBYBgHkbRl5aj1K5K31DDM+CGwn 0KS8Sd/1FjsJ
jh/aE5Q3VS5todvvYm9HdN0qaAqQrx1JgGLbiBExk0Os4PjYhOKKvW3SV88W x5AEurjGjk2a
F5RDAALLJzCHvOk3aR4vDzCAAXOAOcAcuDEHlO/sUEDUk/ULl7b23rfbD+4N fuZNlS9tC91K
ubSxEC8EIACBVRKYQ95WOT76XgYBVt6WkSeihEApAs2tvNlgUm6TtM89emDf cHi/f1flS9uQ
t6VljHghAIFaCSBvtWamr7iQt77yzWgh0Ly8kWIIQAACEIDAFASQtymo0mYq AeQtlRj1IbBs
AsjbsvNH9BCAAAQgsCICyNuKwNPtNgLIGxMCAn0RaF7ecm6b7GsqMFoIQAAC EEghgLyl0KLu
VASQt6nI0i4E6iTQvLzViZ2oIAABCEBg6QSQt6VnsI34kbc28sgoIBBLoHl5 y1l5W7/npkHa
Y0FTDwIQgAAE2iKAvLWVz6WOBnlbauaIGwLjCDQvb+OwXDtLidvG5hXvrsrZ IAABCECgTwLI
W595r23UyFttGSEeCExLoDl5k76gO2Ul7pG7dwblTZWzQQACEIBAnwSQtz7z XtuokbfaMkI8
EJiWQJPyFkKWIm8P3rUz+CXdqlza1Peq2bs6x3dcam9V5bHjiInP9V1zrvOW xihm7NSBAATa
IYC8tZPLJY8EeVty9ogdAukEmpc3WxRS5O2BO28eHn3oyHDes6tyafOJSqzA SO3nlsfGETuO
mPZi6pjjSq2fy4TzIQABCMQQQN5iKFFnagLI29SEaR8CdRFA3gL5uO/Ei4O3 TapyaYuVHt2O
a5VOldnt6J/N+rpequzoNkJjSRmHWdeOz4xRqmcyCcmci4WLV8w4pXxSDgEI QEATQN6YCzUQ
QN5qyAIxQGA+As3Km++WO73y5ns00d97xy1BeVPl0haSMZ/YuEQlJG8uyUkV OEn8YqXSJZp2
fFJsvrFKMhfDKBSflEvKIQABCJgEkDfmQw0EkLcaskAMEJiPQLPy5rvQT7lt 8syxXcHPvKly
aUtZsXKJhbmqJEmdvZJlx+aSRVf8rphTxuFbUfONxRRH1+pYKJ7QmH0rcpI8 SjmlHAIQgIAi
gLwxD2oggLzVkAVigMB8BJC3AOtTR3YPa+dOD2tn3bsql7YU6Zla3mJizY3X HMPYlTBp5c3X
R2x/EgfKIQABCMQQQN5iKFFnagLI29SEaR8CdRFoXt5s3CkrbycP3xq8bVKV S1uuDJVcefPF
GvNZsNhxxK6EmbFIsjam7xiJlHJHOQQgAIEQgTnkTb9J83h5a6WTHQbMAeYA c+DaHFBOs0M/
Wb9waVD7EreS3/N2/NCeoLypcmmzPysm3coXEhnX5858shR7a2BKPV//odsx XedosZJur9Rs
U+TNF0soRimHlEMAAhBwEZhD3iAPAYkAK28SIcoh0BaB5lbeSqbn9oN7g595 U+VsqyEQ+hzc
aiKiVwhAoDcCyFtvGa9zvMhbnXkhKghMRaB5eUu5TdKGfPTAvuHwfv+uytlW QwB5Ww13eoUA
BG4QQN6YDTUQQN5qyAIxQGA+As3L23wo6QkCEIAABHoigLz1lO16x4q81Zsb IoPAFASQtymo
0iYEIAABCDRPAHlrPsWLGCDytog0ESQEihFoXt5ybpssRpmGIAABCECgOQLI W3MpXeSAkLdF
po2gITCaQPPyNpoMJ0IAAhCAAAQCBJA3pkcNBJC3GrJADBCYj0Dz8paz8rZ+ z02DtM+XKnqC
AAQgAIGaCCBvNWWj31iQt35zz8j7JNC8vOWkVYnbxuYV767K2SAAAQhAoE8C yFufea9t1Mhb
bRkhHghMS6A5eSv5Jd2P3L0zKG+qnO0Ggdgv/F4yM2mMUvmSx07sEIDAdgLI GzOiBgLIWw1Z
IAYIzEegSXkL4Uu5jfLBu3YGv6RblUubupi3d3WO77jUXmp56PvQSovGFO2F 2JksSvft46z7
CeU1NUc59ecad06MnAuBVgkgb61mdlnjQt6WlS+ihUAugeblzb64TZG3B+68 eXj0oSPDec+u
yqXNd3E910V3qJ/SMcS2l1tPi9Oq5c2V+9ixSfMmtnzu/mLjoh4EeiCAvPWQ 5frHiLzVnyMi
hEBJAshbgOZ9J14cvG1SlUtbqry5VppUH3Y7rhUgXc+sK6282SJk9q/HZvZl HnOdK/Gwzw/V
l9j5xukbgxmvTwCl4y4WPoksGUdoXrhijs0D9SAAgfEEkLfx7DizHAHkrRxL WoLAEgg0K2++
29r0ypvv0UzavXfcEpQ3VS5tMRfdIdnyyYJPqELCJZVJgugbqyQ0kqCFJC1F Jl39jOUUwz02
NlO+Q8IpSbpLEn3spHlJOQQgkE8AectnSAv5BJC3fIa0AIElEWhW3mxR0T+n 3DZ55tiu4Gfe
VLm0SatH9vkhgZIu3l1iIK282W26ZNPXhi0vUj1J4iQWrpz65CwUm49TzNgl UTXLpfamjEOa
l5RDAAL5BJC3fIa0kE8AectnSAsQWBIB5C2QrVNHdg9r504Pa2fduyqXtqXJ m2s8PqG0ZWrM
KpAWnJh+Y+QtRn5jJVf1F9OeJNWucrvtWCkswVyas5RDAAJxBOaQN/0mzePl AQYwYA4wB5gD
N+aAWpDaoYCoJ+sXLm3tS9yklTWp3BzzycO3Bm+bVOXStmR5k24dzBGJkLS5 JM0nQFqCpFjn
ul2xljikeUk5BCCQT2AOecuPkhZaJ8DKW+sZZnwQ2E6gyZU36bveYifB8UN7 gvKmyqXNvnUu
5bY61+pM7u2AvjZNYbLFSrodUlo1shnFrtCF2NkyZ8tZKidTAl2rba72Ym6L DLEMCaWUA9d4
pblIOQQgUJYA8laWJ62NI4C8jePGWRBYKoHm5K1kIm4/uDf4mTdVzgYBCEAA An0SQN76zHtt
o0beassI8UBgWgLNy1vKbZI26qMH9g2H9/t3Vc4GAQhAAAJ9EkDe+sx7baNG 3mrLCPFAYFoC
zcvbtPhoHQIQgAAEeiWAvPWa+brGjbzVlQ+igcDUBJC3qQnTPgQgAAEINEkA eWsyrYsbFPK2
uJQRMASyCDQvbzm3TWaR5WQIQAACEGiaAPLWdHoXMzjkbTGpIlAIFCHQvLwV oUQjEIAABCAA
AYsA8saUqIEA8lZDFogBAvMRaF7eclbe1u+5aZD2+VJFTxCAAAQgUBMB5K2m bPQbC/LWb+4Z
eZ8Empe3nLQqcdvYvOLdVTkbBCAAAQj0SQB56zPvtY0aeastI8QDgWkJNCdv 0hd0p6zEPXL3
zqC8qXK2+QlIX/KdWz7/iOgRAhBYIgHkbYlZay9m5K29nDIiCIQINClvoQGn yNuDd+0Mfkm3
Kpc2JRL2rs7xHZfaM8slSUlpq2Rdacz2GFLHIdXX5aE4So5XakuKVzqfcghA oE4CyFudeekt
KuStt4wz3t4JNC9v9oVzirw9cOfNw6MPHRnOe3ZVLm2+C/cSF/Ql2pDiHyOL oTHbZVqwSsZh
ypur3Vq5pTCgLgQgsHoCyNvqc0AEw4C8MQsg0BcB5C2Q7/tOvDh426Qql7Yx 8mauGLlWqVwr
S7qe61xbZlwCJY3Dbj9UXxpzKJ6YsZvtx4zXjjXmfFMqXYLp61c6HsuZehCA QP0EkLf6c9RD
hMhbD1lmjBC4QaBZefPdMqdX3nyP5uS4945bgvKmyqXNjsMlWaHVp9AqkiRh tuSZfdtSKI3D
JUDSCps9Lp+0+caYezzEXo3Hx8+WO5tbzHlm+3Ov9KXmkvoQgMA4AsjbOG6c VZYA8laWJ61B
oHYCzcqbT1RSbps8c2xX8DNvqlzapFUo1/ku6XC1kyJvLvlyCYxLLkNjjInL lQuXII2RohAr
ib1P8GPkLSZHIfGW5g3lEIBA/QTmkDf9Js3j5a3bA9lhwBxgDjAHrs0B5TQ7 9JP1C5cGtS9x
s+XMvoBPkbdTR3YPa+dOD2tn3bsqlzZJIHxSZQtPjCTFyo8pbWNXhWJWC0Nj KyVvPvmVxDSm
3K4jyVgKf2neUA4BCNRPYA55q58CEa6aACtvq84A/UNgXgLNr7zZOFPk7eTh W4O3TapyaatV
3kLyEhpTSNps4ZTEVBLUErdNpsidq78pJVOaO5RDAAJ1E0De6s5PL9Ehb71k mnFC4BqBJuVN
+q632OQfP7QnKG+qXNpibs1zSY55nik5tjz5fvbd+mf2lbrqFls/dcx2rC5B dN2mqAXUxcAu
M+tI/Um3TUr9uiQ2RnqluUQ5BCBQFwHkra589BoN8tZr5hl3rwSak7eSibz9 4N7gZ95U+VK3
WBFb6viIGwIQgMDUBJC3qQnTfgwB5C2GEnUg0A6B5uUt5TZJO61HD+wbDu/3 76p8qRvyttTM
ETcEIFALAeStlkz0HQfy1nf+GX1/BJqXt/5SyoghAAEIQGAOAsjbHJTpQyKA vEmEKIdAWwSQ
t7byyWggAAEIQGAmAsjbTKDpJkgAeWOCQKAvAs3LW85tk31NBUYLAQhAAAIp BJC3FFrUnYoA
8jYVWdqFQJ0Empe3OrETFQQgAAEILJ0A8rb0DLYRP/LWRh4ZBQRiCTQvbzkr b+v33DRIeyxo
6kEAAhCAQFsEkLe28rnU0SBvS80ccUNgHIHm5W0clmtnKXHb2Lzi3VU5GwQg AAEI9EkAeesz
77WNGnmrLSPEA4FpCTQnb9IXdKesxD1y986gvKnyVW/Sv/zPLV/1+KbuX+Iz df+0DwEILJcA
8rbc3LUUOfLWUjYZCwRkAk3KW2jYKfL24F07g1/SrcqlTcmBvatz9DHzfNex mPZDdbSchOKQ
+ihZPpUs+canYzfLbea+8Y2Jdcw5JfnSFgQgMB8B5G0+1vTkJ4C8MTsg0BeB 5uXNvphOkbcH
7rx5ePShI8N5z67Kpc13Mb8KeXPFOrdspPYXWz9Uzy4zf45tX8qzKYmxdakH AQgsmwDytuz8
tRI98tZKJhkHBOIIIG8BTvedeHHwtklVLm0heVPnmitj5s/6eUjy7DLX6pLd vh2vLTJSm1I8
psT44kldYYypL3H2jdtesbPjd43HbMseo2+FT5onlEMAAssjgLwtL2ctRoy8 tZhVxgQBP4Fm
5c13G51eefM9mqjuveOWoLypcmkLyUFI3nyrRWOPx8ZhyopLJkPlrvFI9SV+ LlFynSONLyRv
dh9SzCEhLr2Sl8KHuhCAwLwE5pA3/SbN4+UBBjBgDjAHmAM35oBymR0KiHqy fuHS1r7Ezb4t
0r6YTrlt8syxXcHPvKlyaYtZEXLdxjdG0lwCE7vy5pNdV2y2pIX6lUTIJWeS ALnKYzi7JM3H
ecwYbdmV5gblEIDAsgnMIW/LJkT0cxBg5W0OyvQBgXoINLvyZkuD/jlF3k4d 2T2snTs9rJ11
76pc2mKkopS8uWJJkbfQ+baYxLabIm8xLGN4uiTNbtsXf0wufHMLeZMySDkE 2iKAvLWVz6WO
BnlbauaIGwLjCDQvbzaWFHk7efjW4G2TqlzaxsrGmJU3l7TESlZMfzFiI0mR tKrmE0jpvFB5
zOqaS8jGjEWKU5ovlEMAAsshgLwtJ1ctR4q8tZxdxgaBFxJoUt6k73qLnQjH D+0Jypsql7aY
2xFd0qVXcfT5dh2zXVM87PqmgEi3N/raDImNL05JmGIlJ6Wea3whNnbsMTG7 6riYx8YtzR/K
IQCBegkgb/XmpqfIkLeess1YITBc//xvM595K5nU2w/uDX7mTZWztUsAAWs3 t4wMAiUIIG8l
KNJGLgHkLZcg50NgWQSaW3mz8afcJmmfe/TAvuHwfv+uytnaJIC4tZlXRgWB kgSQt5I0aWss
AeRtLDnOg8AyCTQvb8tMC1FDAAIQgEDtBJC32jPUR3zIWx95ZpQQ0ASQN+YC BCAAAQhAYAQB
5G0ENE4pTgB5K46UBiFQNYHm5S3ntsmqM0dwEIAABCCwUgLI20rx0/nzBJA3 pgIE+iLQvLz1
lU5GCwEIQAACcxFA3uYiTT8hAsgb8wMCfRFoXt5yVt7W77lpkPa+pgujhQAE IAABTQB5Yy7U
QAB5qyELxACB+Qg0L285KJW4bWxe8e6qnA0CEIAABPokgLz1mffaRo281ZYR 4oHAtASakzfp
C7pTVuIeuXtnUN5U+RI36d/gS+VLHPMUMUuccsuniJk2IQCBcgSQt3IsaWk8 AeRtPDvOhMAS
CTQpb6FEpMjbg3ftDH5JtyqXNnUBb+/qHH3MPF+62Jf6ii3X/YRii22rRL2p xp3KPjUOqX4v
nEvMAdqAwBIJIG9LzFp7MSNv7eWUEUEgRKB5ebMvsFPk7YE7bx4efejIcN6z q3Jp813g1yJv
rvglKZHGnFqe2l9s/VT2se3q8Un1TXlbIufUPFIfAr0RQN56y3id40Xe6swL UUFgKgLIW4Ds
fSdeHLxtUpVLW0gg1Llmuf3cFjxzJUmfa7dv1zFFw3W+JBWu9sbG4VqBNMch yZAZq0t+7bHE
sndJVgpH3xhS5K1WztL8phwCPROYQ970mzSPlwcYwIA5wBxgDtyYA2pBaocC op6sX7i0tS9x
0ytrvlvmdLnv0RzzvXfcEpQ3VS5tIWEJyZstKpLo2eXmzy7Bs4XDJZGh80wp tJ/HnBeKT2Ia
K3Gx7G3Jyo3f1Z5PzmLzNjY/pTin5IS6EOiFwBzy1gtLxjmeACtv49lxJgSW SICVt0DWzhzb
FfzMmyqXNmn1x3dx7RKP0CqdS8Z8Kz+xK0I+AZ4rDntMIdYuzinsY2XXJ9Wh fElx1MBZmseU
QwACLySAvDEraiCAvNWQBWKAwHwEkLcA61NHdg9r504Pa2fduyqXNunC3SUN MSs/MSsxOraY
9nxS4hpfjLxJ54VkSWJqxxrD2DU+M4ZceQuNV4pPKo+Nc2y+U3hTFwIQuEEA eWM21EAAeash
C8QAgfkINC9vNsqUf1hy8vCtwdsmVbm0xVyY64vzlJWyGHlLaS9G3lztTRlH iK1erZLqxEik
LT2xshvLV5oDMf2tirM0vymHQM8EkLees1/P2JG3enJBJBCYg0CT8iZ911ss 2OOH9gTlTZVL
W8wtcba8mT+bkiKteNnn2UJmxuLqwydntiiNjcMnKa7xj5Ey+5xY9ra8pXL0 1Td52rHoc8y+
a+MszW3KIdA7AeSt9xlQx/iRtzryQBQQmItAc/JWEtztB/cGP/OmytkgAAEI QKBPAshbn3mv
bdTIW20ZIR4ITEugeXlLuU3SRn30wL7h8H7/rsrZIAABCECgTwLIW595r23U yFttGSEeCExL
oHl5mxYfrUMAAhCAQK8EkLdeM1/XuJG3uvJBNBCYmgDyNjVh2ocABCAAgSYJ IG9NpnVxg0Le
FpcyAoZAFoHm5S3ntsksspwMAQhAAAJNE0Demk7vYgaHvC0mVQQKgSIEmpe3 IpRoBAIQgAAE
IGARQN6YEjUQQN5qyAIxQGA+As3LW87K2/o9Nw3SPl+q6AkCEIAABGoigLzV lI1+Y0He+s09
I++TQPPylpNWJW4bm1e8uypngwAEIACBPgkgb33mvbZRI2+1ZYR4IDAtgebk TfqC7pSVuEfu
3hmUN1U+1WZ/ofVU/dAuBCAAAQiMI4C8jePGWWUJIG9ledIaBGon0KS8haCn yNuDd+0Mfkm3
Kpc2JWH2bp5jltnHfW2PEbsx50hjoxwCEIBAzwSQt56zX8/Ykbd6ckEkEJiD QPPyZktLirw9
cOfNw6MPHRnOe3ZVLm0habLLzJ9Ly1bp9qRxUw4BCECgdQJzyJt+k+bx8gAD GDAHmAPMgRtz
QDnNDgVEPVm/cGlrX+Jmy1mOvN134sXB2yZVubT5pEk67lut08d1v6GVO7Ou r54UP+UQgAAE
IOAmMIe8wR4CEgFW3iRClEOgLQLNrrz5blfUcud7NNN77x23BOVNlUtbSMJc 52qpi1mV89Vx
iSErb1KmKIcABCCQRgB5S+NF7WkIIG/TcKVVCNRKoFl5M1emTPgpt02eObYr +Jk3VS5t0gqb
fX6qvLnkEHmTskI5BCAAgXwCyFs+Q1rIJ4C85TOkBQgsiQDyFsjWqSO7h7Vz p4e1s+5dlUvb
1PLm6h95k7JCOQQgAIF8AshbPkNayCeAvOUzpAUILIlA8/JmJyNl5e3k4VuD t02qcmkr9Q9L
XP/MhNsmJfqUQwACEJiOAPI2HVtajieAvMWzoiYEWiDQpLxJ3/UWm7jjh/YE 5U2VS5vvs3f6
vJh/OCJ9/s3+JyaqbVe7rnpS/JRDAAIQgICbAPLGzKiBAPJWQxaIAQLzEWhO 3kqiu/3g3uBn
3lT5Kjb++cgqqNMnBCAAge0EkDdmRA0EkLcaskAMEJiPQPPylnKbpI396IF9 w+H9/l2Vz70h
bnMTpz8IQAACrLwxB+olgLzVmxsig8AUBJqXtymg0SYEIAABCECAlTfmQA0E kLcaskAMEJiP
API2H2t6ggAEIACBhgggbw0lc8FDQd4WnDxCh8AIAs3LW85tkyN4cgoEIAAB CHRCAHnrJNGV
DxN5qzxBhAeBwgSal7fCvGgOAhCAAAQgsEUAeWMi1EAAeashC8QAgfkINC9v OStv6/fcNEj7
fKmiJwhAAAIQqIkA8lZTNvqNBXnrN/eMvE8CzctbTlqVuG1sXvHuqpwNAhCA AAT6JIC89Zn3
2kaNvNWWEeKBwLQEmpM36Qu6U1biHrl7Z1DeVDlbGwSkr2CQytugwCggAIEU AshbCi3qTkUA
eZuKLO1CoE4CTcpbCHWKvD14187gl3SrcmlTF/32bp5jlkltlSi3JWTVUuLj I3ErwcLOg/o5
FE/pPkPtrTovc46VviCwVAJzyJt+k+bx8tZnDNlhwBxgDjAHrs0B5TQ79JP1 C5cGtS9xs+XM
vghOkbcH7rx5ePShI8N5z67KpS10Eb4KkZpLCmL7kepJ5RL/2HLdj6+/ueLQ 8c7dXywn6kEA
AjcIzCFv8IaARICVN4kQ5RBoi0DzK2858nbfiRcHb5tU5dKWKgOmRPhW5VzH XfLhq6eP65Um
UxjMMtdKlDRes9xuy3WuJCmS4I7l5RtbTL5iubpij+Xry30Kf+pCAALTEkDe puVL63EEkLc4
TtSCQCsEmpU33+1veuXN92gm9t47bgnKmyqXNjsOU5RCMuOTltDxmFW+Me3a QiaN2S4PSZyP
j49Tqfglji7JsmXX/Nlsz/U8N+5U5tSHAASmJ4C8Tc+YHmQCyJvMiBoQaIlA s/Lmu/hPuW3y
zLFdwc+8qXJpi1nJcclRrFy4VtzMsdsrOLkS4RpP7CqR79wQw9A5PmGypcol iLEc7Hnk+6NA
jLyViEOab5RDAALzEUDe5mNNT34CyBuzAwJ9EUDeAvk+dWT3sHbu9LB21r2r cmmbQt5cffpk
xCUfqbLoqi+N2z4nlYNPvm0x89ULSa3ZhsQntdxuu3QcKdypCwEITEsAeZuW L63HEUDe4jhR
CwKtEGhe3uxEpay8nTx8a/C2SVUubTG3MroEJHZlyCcHpc6XpDA0fvvWwxjp tOvESt9U45Xk
zcWf2yalVwXlEGiDAPLWRh6XPgrkbekZJH4IpBFoUt6k73qLRXT80J6gvKly afPdZmdKgUty
XLfYhc6Rbme0hcInHXYsY+UtJK0msxg+MdKXyku16buNUbq90SyXxNvF3XeL pY7JzrM0xyiH
AARWQwB5Ww13et1OAHljRkCgLwLNyVvJ9N1+cG/wM2+qfKotVn6m6r/mdn2i WnPMxAYBCLRH
AHlrL6dLHBHytsSsETMExhNoXt5SbpO0MR49sG84vN+/q/KpNuTNTxZ5m2rW 0S4EIJBCAHlL
oUXdqQggb1ORpV0I1EmgeXmrEztRQQACEIDA0gkgb0vPYBvxI29t5JFRQCCW APIWS4p6EIAA
BCAAAYMA8sZ0qIEA8lZDFogBAvMRaF7ecm6bnC8N9AQBCEAAAksjgLwtLWNt xou8tZlXRgUB
H4Hm5Y3UQwACEIAABKYggLxNQZU2Uwkgb6nEqA+BZRNoXt5yVt7W77lpkPZl p5/oIQABCEBg
LAHkbSw5zitJAHkrSZO2IFA/geblLScFStw2Nq94d1XOBgEIQAACfRJA3vrM e22jRt5qywjx
QGBaAs3Jm/QF3SkrcY/cvTMob6p8lRtfJzCOvsRNKh/XK2dBAAKtEZhD3vSb NI+XBxjAgDnA
HGAO3JgDyml2KCDqyfqFS1v7EjdJzqRyc8wP3rUz+CXdqlzalAjYuzrHdUxq yy5fgmRI4zfH
NNd4dD+h2FJzkVN/rnHnxMi5EIDACwnMIW9wh4BEgJU3iRDlEGiLQJMrbyEh SJG3B+68eXj0
oSPDec+uyqXNd2FuHx9zAT/mHCne2PLYvkPjL8EgNl7XnIjNzZg+Us6JZZnS JnUhAIHpCSBv
0zOmB5kA8iYzogYEWiKAvAWyed+JFwdvm1Tl0hYrCGY9c0XIlg5dpo7b5+i6 MefH9BczNkk8
pPGnjMEel8lizNil2DRju5+xcfhWW335kvhTDgEIrJYA8rZa/vR+jQDyxkyA QF8EmpU33y1x
euXN92im/947bgnKmyqXttAFuy1mrrbMW/zs8lCZKTO26Jk/l1j9ckmUS6Zc ouaTNxebkOiN
GaOUGx+bKeKQ5hHlEIBAfQSQt/py0mNEyFuPWWfMPRNoVt5sedE/p9w2eebY ruBn3lS5tIVW
d1JWyFzt+KTJJSUhEfFJjEvAQuP1xRiSUp9ISmPwiaB0XkhcXcIrtTdlHNLc ohwCEFgtAeRt
tfzp/RoB5I2ZAIG+CCBvgXyfOrJ7WDt3elg7695VubTF3JpnthGz2uOSDJ+s +lbnYlbtpLHZ
cidJmm+cdiwxDKRVvLFMU+TOrJt6Xkz9WP7UgwAEVkMAeVsNd3rdTgB5Y0ZA oC8Czcubnc6U
lbeTh28N3japyqVtDnkLiUCqvPni9YmZVD92/OYqYil5Sx17SIp9jGMkcmwc 0tyiHAIQWC0B
5G21/On9GgHkjZkAgb4INClv0ne9xab4+KE9QXlT5dJm33YXs+Llu43Rvs0y 9lZIU0rsNrSU
mPIkjckUGalu7Pjt/sfcrhgai6+9mH5csdmiZzPxcTZ52eInibDEmnIIQGBe AsjbvLzpzU0A
eWNmQKAvAs3JW8n03X5wb/Azb6p8qRuisNTMETcEIFALAeStlkz0HQfy1nf+ GX1/BJqXt5Tb
JO30Hz2wbzi837+r8iVtrtWgJcVPrBCAAARqIoC81ZSNfmNB3vrNPSPvk0Dz 8tZnWhk1BCAA
AQhMTQB5m5ow7ccQQN5iKFEHAu0QQN7aySUjgQAEIACBGQkgbzPCpisvAeSN yQGBvgg0L285
t032NRUYLQQgAAEIpBBA3lJoUXcqAsjbVGRpFwJ1Emhe3urETlQQgAAEILB0 Asjb0jPYRvzI
Wxt5ZBQQiCXQvLzlrLyt33PTIO2xoKkHAQhAAAJtEUDe2srnUkeDvC01c8QN gXEEmpe3cViu
naXEbWPzindX5WwQgAAEINAngTnkTb9J83h568uo2WHAHGAOMAeuzQG1QLVD P1m/cGlQ+xI3
6Qu6U1biHrl7Z1DeVDlbWwSk77+TytuiwWggAIEQgTnkjQxAQCLAyptEiHII tEWguZU3Sc6k
cjO9D961M/gl3apc2szvVtPP1Tn2camdqctXLSWxnKaOU7cfimfqXJjtTz3e OcdCXxBojQDy
1lpGlzke5G2ZeSNqCIwl0Ly82Re/KfL2wJ03D48+dGQ479lVubT5Lr7t46u+ SJ+q/9h2pXpS
uZSH2HJT3lznzBWH7nvu/mI5UQ8CEBi2bltRW+otPOp96Lbbbtu6w0Xt6mez DfNnOENAIoC8
SYQoh0BbBJC3QD7vO/Hi4G2TqlzaxsibuepjX8Sb7fnquVb4zDhjzlP1Y+OI YSBJSGq5T35D
K5qu8djjTJG3GI5mLsxc2sd9cftilphTDgEITE8AeZueMT3IBJA3mRE1INAS gWblzXfbm155
8z2ayb33jluC8qbKpS10UW4LlastUyZCguOSDlv0tKi4+vXJkEseJdHyMXGJ jEtoXO2nxJcy
vlQJ9MndVPzHspbmJeUQgEA+AeQtnyEt5BNA3vIZ0gIElkSgWXmzpUP/nHLb 5Jlju4KfeVPl
0ua7+I5dIQqtBLnacAmbKW0+qXVJjNS+PfbYVaIYOXO17TvmG/PYcbsk1yex 9phL8g/FIc07
yiEAgekJIG/TM6YHmQDyJjOiBgRaIoC8BbJ56sjuYe3c6WHtrHtX5dIWkjfX uaGVILN+TL2Y
lTef5KbGLXHQIjK23ZDwxcpbDm+XvEntleDPylvMzKIOBFZDAHlbDXd63U4A eWNGQKAvAs3L
m53OlJW3k4dvDd42qcqlLVVWYqRMi5BL5mJWfqTzYtuXxm4KjyQhY8t9vCTZ Srn9MYVXaf4S
l9gcUA8CEChPAHkrz5QW0wkgb+nMOAMCSybQpLxJ3/UWm7Djh/YE5U2VS1vs bYq2IIRux7Ol
SNe1pSskEuY5Psly3QaZKhOx9X2cbAmzebvkzRW3ZhMat83RjsnF125Pkjdf HCEJdcUszTvK
IQCB6Qkgb9MzpgeZAPImM6IGBFoi0Jy8lUzO7Qf3Bj/zpsrZVkcgdCvl6qKi ZwhAoBcCyFsv
ma57nMhb3fkhOgiUJtC8vKXcJmnDPXpg33B4v39X5WyrI4C8rY49PUMAAnzP G3OgDgLIWx15
IAoIzEWgeXmbCyT9QAACEIBAXwRYeesr37WOFnmrNTPEBYFpCCBv03ClVQhA AAIQaJwA8tZ4
ghcyPORtIYkiTAgUItC8vOXcNlmIMc1AAAIQgECDBJC3BpO6wCEhbwtMGiFD IINA8/KWwYZT
IQABCEAAAl4CyBuTowYCyFsNWSAGCMxHoHl5y1l5W7/npkHa50sVPUEAAhCA QE0E5pA3/SbN
4+UBBjBgDjAHmAM35oBynB0KiHqyfuHS1t77psRtY/OKd1flbBCAAAQg0CeB OeStT7KMOoUA
K28ptKgLgeUTaG7lTfqC7pSVuEfu3hmUN1U+98YXNs9NPL2/2C8mT2+ZMyAA gZoIIG81ZaPf
WJC3fnPPyPsk0KS8hVKZIm8P3rUz+CXdqlzatGyZj+oc+7jUjj4npt4S6/g4 +ViVFKSSbZl5
Co0pJUel40vpm7oQgICfAPLG7KiBAPJWQxaIAQLzEWhe3uwL3xR5e+DOm4dH HzoynPfsqlza
fBfe9vGYC/SYOlI8c5fHxhzLSccf227MeEu2ZctbTP9SndLxSf1RDgEIxBFA 3uI4UWtaAsjb
tHxpHQK1EUDeAhm578SLg7dNqnJpi5USl8zZt0jaq3daFFz1TIkI1XO1GVNf GrdZHnOrZywn
U97MdvX59qNL9kKroDY3l4yZsfpy4mrHxWRM3n3i7xq7L78p+aMuBCDgJoC8 MTNqIIC81ZAF
YoDAfASalTffLWt65c33aKK/945bgvKmyqXNjsMlEy7Rsi/0Q1Jht+mTOVe9 mH5i+pY4mELo
quvjZJ5nS5NLhiS+LkmUVkFNKQqtgrkE0jUuqb/YPI3Ne0yuqAMBCMgEkDeZ ETWmJ4C8Tc+Y
HiBQE4Fm5c13EZ9y2+SZY7uCn3lT5dIWWlGKWfVyrS6ZY4uVg9h6LlGzBcq3 kha7yhMjUD6u
MStrIdmM6Vta2XJJoytPsbn3reSljjW0iufLmTR/KYcABPwEkDdmRw0EkLca skAMEJiPAPIW
YH3qyO5h7dzpYe2se1fl0ha6gPcJZsw5PskKiYsda6qkSGOVykMCEVrRsmUp Zow5Y4s9V6oX
m0dpHkgrdbGSJ+WHcghAII0A8pbGi9rTEEDepuFKqxColUDz8maDT1l5O3n4 1uBtk6pc2mIv
4O3Vlxxhyb3YH7M6FeIQs+rTs7xJ8pWbT58cSnOXcghAIEwAeWOG1EAAeash C8QAgfkINClv
0ne9xeI9fmhPUN5UubTZtyv6LtRVO77b50IX32b7ufVi+o8RMZd45nByjVHz knj6+Njj8P1s
HvdJrd1HKCYzRy6W9nyx67vOj2Ug5YByCEAgjQDylsaL2tMQQN6m4UqrEKiV QHPyVhL07Qf3
Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5S7lN0kZ99MC+4fB+ /67K2SAAAQhA
oE8CyFufea9t1MhbbRkhHghMS6B5eZsWH61DAAIQgECvBJC3XjNf17iRt7ry QTQQmJoA8jY1
YdqHAAQgAIEmCSBvTaZ1cYNC3haXMgKGQBaB5uUt57bJLLKcDAEIQAACTRNA 3ppO72IGh7wt
JlUECoEiBJqXtyKUaAQCEIAABCBgEZhD3vSbNI+XBxjAgDnAHGAO3JgDaoFq hwKinqxfuLS1
t7DlrLyt33PTIO0tMGIMEIAABCCQTmAOeUuPijN6I8DKW28ZZ7y9E2DlLTAD lLhtbF7x7qqc
DQIQgAAE+iSAvPWZ99pGjbzVlhHigcC0BJqTN+kLulNW4h65e2dQ3lR5T5vr S6p7Gv/cY5V4
S+Vzx0t/EOiNAPLWW8brHC/yVmdeiAoCUxFoUt5CsFLk7cG7dga/pFuVS5u6 wLZ3fY7reMkL
8pJtqZh1e6ExSTzM8tLxpfQdqusbX6lxx8Yp8Z6b39z9xXKiHgRWRQB5WxV5 +jUJIG/MBwj0
RaB5ebMvOFPk7YE7bx4efejIcN6zq3Jp813wph6X+nGVl77YNmViTDz2OaXj k2KK7U+qJ5VL
ccSWS7znisP8Y0Ns7NSDQA8EkLceslz/GJG3+nNEhBAoSQB5C9C878SLg7dN qnJpS5U0c3VH
tW1fwNvtmT+7ztXHzLbsi3GXJNhtuWLxCaPZp9mXfdw31rHxSbnQY5CkJ7Xc lxN7pc6Mz8XX
jC+UN5dM+fJlt+OKNZSX0PyK4U0dCLRMAHlrObvLGRvytpxcESkEShBoVt7s C2d9EapX3nyP
JtR777glKG+qXNpSL+B9F9euC3ZJqEKiZ58bEhaXQLrGJfXnk7KYsdkSYYuQ lAe73CWYLtF0
cZHG6ZLhUK5i6qfItE/GY/mHZDSVM/Uh0DIB5K3l7C5nbMjbcnJFpBAoQaBZ efMJQcptk2eO
7Qp+5k2VS5u0ihN7QR0jOC5BCUmOTxq0aPhWxnxj8gmz1F7q2EL9uAQslKMY OZO4+sQsJEEp
8hvi7WKbIm8l4pBeA5RDoFUCyFurmV3WuJC3ZeWLaCGQSwB5CxA8dWT3sHbu 9LB21r2rcmlb
orxJKy+STEiyI600pQqtlANXubTyNlb4YlYIY/mF5NonjD5Zd8VVKo4x/DkH Ai0QQN5ayOLy
x4C8LT+HjAACKQSalzcbRsrK28nDtwZvm1Tl0tazvEmSlnv7oS15Ui608Eg5 GVueOx5Jmn1S
HHNejLyl5iuGN3Ug0DIB5K3l7C5nbMjbcnJFpBAoQaBJeZO+6y0W3PFDe4Ly psqlzXeLn+t2
NVNGQqsuvnPN4662THkxV558tw7a7UkrQXb7JhspZjvelPikHKRKni9nUjsu iXLlJJVTaA65
uLni9K0I+uaMnTvffIplTz0ItEgAeWsxq8sbE/K2vJwRMQRyCDQnbzkw7HNv P7g3+Jk3Vc4G
AS1jNglpBQ9yEIDAsgkgb8vOXyvRI2+tZJJxQCCOQPPylnKbpI3s6IF9w+H9 /l2Vs0EAeWMO
QKBPAshbn3mvbdTIW20ZIR4ITEugeXmbFh+tQwACEIBArwSQt14zX9e4kbe6 8kE0EJiaAPI2
NWHahwAEIACBJgkgb02mdXGDQt4WlzIChkAWgeblLee2ySyynAwBCEAAAk0T mEPe9Js0j5cH
GMCAOcAcYA7cmAPKcXYoIOrJ+oVLWzsbBCAAAQhAAAJuAnPI
Re: Primitive types and Java types in XMI [message #626458 is a reply to message #477296] |
Wed, 30 April 2008 10:17  |
--------------030505080708050601040706
Stephane,
Someone with UML knowledge will need to help. By the time you get to an
Ecore with this structure, it's major task to turn your EClasses into
EDataTypes. So likely you need to do something to the UML first. There
are introductory guides for how to do these kinds of things. I assume
you've looked carefully at the UML2 documentation and the wiki?
SWT wrote:
> Ed,
> type defined in my model by the one defined in the ecore ressource, so
> that the attribute "einttest2" gets the ecore EInt type instead of my
> fake int type ?
> "einttest2" attribute, but if I had a very very large model with lots
> of attributes using this int type, it wouldn't be feasible to change
> each one manually !
> Thanks again !
> Stephane
> Ed Merks wrote :
>> Stephane,
>> If I look at Ecore.uml it looks like as below, so I imagine you need
>> to apply the Ecore profile and set the Instance Class Name
>> SWT wrote:
>>> Hello all !
>>> least with Bouml) except for primitive types and java types.
>>> For instance, in Bouml, if I define a class attribute with type
>>> "int", the resulting XMI declaration becomes :
>>> <ownedAttribute xmi:type="uml:Property" name="myIntAttribute"
>>> xmi:id="BOUML_0x1f482_1" visibility="private">
>>> <type xmi:type="uml:Class" xmi:idref="BOUML_datatype_0"/>
>>> </ownedAttribute>
>>> <packagedElement xmi:type="uml:DataType" xmi:id="BOUML_datatype_0"
>>> name="int"/>
>>> After importing that into eclipse, I get an "int" class definition.
>>> If I use EMF to generate the corresponding model classes, it will
>>> result in creating a "int" class (public class int extends EObject) !
>>> Of course, I'd like to use the primitive java type int instead of
>>> this class !
>>> java.util.Date...
>>> Or should I use some transformation (xsl) on my XMI files in order
>>> to change types declarations into ECore/XML types declarations ?
>>> Maybe there's a way under Eclipse, to switch attribute types from
>>> this is a "well known newbie problem" so that someone will tell me
>>> the right thing to do in no time :)
>>> Thanks in advance !
>>> Stephane
Content-Type: multipart/related;
boundary="------------070102010605050007000306"
--------------070102010605050007000306
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Stephane,<br>
<br>
an Ecore with this structure, it's major task to turn your EClasses
into EDataTypes. So likely you need to do something to the UML first.
There are introductory guides for how to do these kinds of things. I
assume you've looked carefully at the UML2 documentation and the wiki?<br>
<br>
<br>
SWT wrote:
<blockquote cite="mid:fv9t34$jfq$1@build.eclipse.org" type="cite">Ed,
<br>
<br>
I'd really like to "apply the Ecore profile"... But I don't know how !
<br>
I attached a screenshot to illustrate my problem.
<br>
In the state exposed by the screenshot, how can I replace the "int"
fake int type ?
<br>
manually !
<br>
<br>
Thanks again !
<br>
Stephane
<br>
<br>
Ed Merks wrote :
<br>
<blockquote type="cite">Stephane,
<br>
<br>
If I look at Ecore.uml it looks like as below, so I imagine you need to
<br>
<br>
<br>
<br>
<br>
SWT wrote:
<br>
<blockquote type="cite">Hello all !
<br>
<br>
<br>
For instance, in Bouml, if I define a class attribute with type "int",
<br>
<br>
<br>
<br>
<br>
</ownedAttribute>
<br>
<br>
<br>
<br>
name="int"/>
<br>
<br>
<br>
<br>
Of course, I'd like to use the primitive java type int instead of this
class !
<br>
java.util.Date...
<br>
<br>
<br>
Or should I use some transformation (xsl) on my XMI files in order to
<br>
Maybe there's a way under Eclipse, to switch attribute types from "fake
<br>
<br>
is a "well known newbie problem" so that someone will tell me the right
<br>
<br>
Thanks in advance !
<br>
Stephane
<br>
</blockquote>
<br>
</blockquote>
<br>
<br>
<hr size="4" width="90%"><br>
<center><img src="cid:part1.00020103.06040206@ca.ibm.com"></center>
</blockquote>
<br>
</body>
</html>
Content-ID: <part1.00020103.06040206@ca.ibm.com>
Re: Primitive types and Java types in XMI [message #626466 is a reply to message #477298] |
Wed, 30 April 2008 23:24  |
------=_NextPart_000_0049_01C8AB19.5F91C560
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_004A_01C8AB19.5F91C560"
------=_NextPart_001_004A_01C8AB19.5F91C560
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
If one has a .uml model, you can use the uml editor to apply the Ecore =
profile in the following way.
1. Open up your .uml model.
2. Select the root package.
3. From the tool bar select "UML Editor > Package > Apply Profile ..."
4. Select "Ecore" the "Add".
To apply a stereotype, select the element you wish to apply the =
Stereotype to, then..
1. Select "UML Editor > Element > Apply Stereotype ..."
2. Applicable choices will be presented.
To add values to the stereotype...
1. Open up the "Properties" view.
2. Add stereotype properties.
- James.
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fv9uu2$joo$1@build.eclipse.org...
Stephane,
Someone with UML knowledge will need to help. By the time you get to =
an Ecore with this structure, it's major task to turn your EClasses into =
EDataTypes. So likely you need to do something to the UML first. There =
are introductory guides for how to do these kinds of things. I assume =
SWT wrote:=20
Ed,=20
I'd really like to "apply the Ecore profile"... But I don't know how =
!=20
I attached a screenshot to illustrate my problem.=20
In the state exposed by the screenshot, how can I replace the "int" =
type defined in my model by the one defined in the ecore ressource, so =
that the attribute "einttest2" gets the ecore EInt type instead of my =
fake int type ?=20
Of course, I can do this "by hand" in the properties of the =
"einttest2" attribute, but if I had a very very large model with lots of =
attributes using this int type, it wouldn't be feasible to change each =
one manually !=20
Thanks again !=20
Stephane=20
Ed Merks wrote :=20
Stephane,=20
If I look at Ecore.uml it looks like as below, so I imagine you =
need to apply the Ecore profile and set the Instance Class Name=20
SWT wrote:=20
Hello all !=20
I managed to import XMI 2.1 files generated by other uml tools =
(Enterprise Architect & Bouml) into eclipse, and it works well (at least =
with Bouml) except for primitive types and java types.=20
For instance, in Bouml, if I define a class attribute with type =
"int", the resulting XMI declaration becomes :=20
<ownedAttribute xmi:type=3D"uml:Property" =
name=3D"myIntAttribute" xmi:id=3D"BOUML_0x1f482_1" =
visibility=3D"private">=20
<type xmi:type=3D"uml:Class" =
xmi:idref=3D"BOUML_datatype_0"/>=20
[...]=20
</ownedAttribute>=20
Where "BOUML_datatype_0" is defined as :=20
<packagedElement xmi:type=3D"uml:DataType" =
xmi:id=3D"BOUML_datatype_0" name=3D"int"/>=20
After importing that into eclipse, I get an "int" class =
definition.=20
If I use EMF to generate the corresponding model classes, it =
will result in creating a "int" class (public class int extends EObject) =
!=20
Of course, I'd like to use the primitive java type int instead =
of this class !=20
The same kind of problem appear with other java classes such as =
java.util.Date...=20
So I'd like to know how to work around this problem... Can I do =
something with my UML tool such as using "special" stereotypes which =
would be recognized when importing into eclipse ?=20
Or should I use some transformation (xsl) on my XMI files in =
order to change types declarations into ECore/XML types declarations ?=20
Maybe there's a way under Eclipse, to switch attribute types =
from "fake classes" to ECore classes ?=20
Any advice would be really appreciated. I already tried a lot of =
different things, but I can't find any working solution... I hope this =
is a "well known newbie problem" so that someone will tell me the right =
thing to do in no time :)=20
Thanks in advance !=20
Stephane=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3157" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>If one has a .uml model, you =
can use the=20
uml editor to apply the Ecore profile in the following way.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>1. Open up your .uml =
model.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2. Select the root =
package.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>3. From the tool bar select "UML Editor =
>=20
Package > Apply Profile ..."</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>4. Select "Ecore" the =
"Add".</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>To apply a stereotype, select the =
element you wish=20
to apply the Stereotype to, then..</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>1. Select "UML Editor > Element > =
Apply Stereotype ..."</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2. Applicable choices will be=20
presented.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>To add values to the =
stereotype...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>1. Open up the "Properties"=20
view.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>2. Add stereotype =
properties.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Cheers,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>- James.</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fv9uu2$joo$1@build.eclipse.org">news:fv9uu2$joo$1@build.ecli=
pse.org</A>...</DIV>Stephane,<BR><BR>Someone=20
with UML knowledge will need to help. By the time you get to an =
Ecore=20
with this structure, it's major task to turn your EClasses into=20
EDataTypes. So likely you need to do something to the UML =
first. =20
There are introductory guides for how to do these kinds of =
things. I=20
assume you've looked carefully at the UML2 documentation and the=20
wiki?<BR><BR><BR>SWT wrote:=20
<BLOCKQUOTE cite=3Dmid:fv9t34$jfq$1@build.eclipse.org =
type=3D"cite">Ed,=20
<BR><BR>I'd really like to "apply the Ecore profile"... But I don't =
know how=20
! <BR>I attached a screenshot to illustrate my problem. <BR>In the =
state=20
exposed by the screenshot, how can I replace the "int" type defined =
in my=20
model by the one defined in the ecore ressource, so that the =
attribute=20
"einttest2" gets the ecore EInt type instead of my fake int type ? =
<BR>Of=20
course, I can do this "by hand" in the properties of the "einttest2" =
attributes=20
using this int type, it wouldn't be feasible to change each one =
manually !=20
<BR><BR>Thanks again ! <BR>Stephane <BR><BR>Ed Merks wrote : <BR>
<BLOCKQUOTE type=3D"cite">Stephane, <BR><BR>If I look at Ecore.uml =
it looks=20
like as below, so I imagine you need to apply the Ecore profile =
and set=20
the Instance Class Name <BR><BR><BR><BR><BR>SWT wrote: <BR>
<BLOCKQUOTE type=3D"cite">Hello all ! <BR><BR>I managed to import =
XMI 2.1=20
files generated by other uml tools (Enterprise Architect & =
Bouml)=20
into eclipse, and it works well (at least with Bouml) except for =
primitive types and java types. <BR>For instance, in Bouml, if I =
define=20
a class attribute with type "int", the resulting XMI declaration =
becomes=20
: <BR><BR><ownedAttribute xmi:type=3D"uml:Property"=20
<BR> <type xmi:type=3D"uml:Class"=20
xmi:idref=3D"BOUML_datatype_0"/> <BR> [...] =
<BR></ownedAttribute> <BR><BR>Where "BOUML_datatype_0" is =
defined=20
as : <BR><BR><packagedElement xmi:type=3D"uml:DataType"=20
xmi:id=3D"BOUML_datatype_0" name=3D"int"/> <BR><BR>After =
importing that=20
into eclipse, I get an "int" class definition. <BR>If I use EMF =
to=20
generate the corresponding model classes, it will result in =
creating a=20
"int" class (public class int extends EObject) ! <BR>Of course, =
I'd like=20
to use the primitive java type int instead of this class ! =
<BR>The same=20
<BR><BR>So I'd like to know how to work around this problem... =
Can I do=20
something with my UML tool such as using "special" stereotypes =
which=20
would be recognized when importing into eclipse ? <BR>Or should =
I use=20
some transformation (xsl) on my XMI files in order to change =
types=20
declarations into ECore/XML types declarations ? <BR>Maybe =
there's a way=20
under Eclipse, to switch attribute types from "fake classes" to =
ECore=20
classes ? <BR><BR>Any advice would be really appreciated. I =
already=20
tried a lot of different things, but I can't find any working=20
solution... I hope this is a "well known newbie problem" so that =
someone=20
will tell me the right thing to do in no time :) <BR><BR>Thanks =
in=20
advance ! <BR>Stephane =
<BR></BLOCKQUOTE><BR></BLOCKQUOTE><BR><BR>
<HR width=3D"90%" SIZE=3D4>
<BR>
<CENTER><IMG=20
src=3D"cid:004101c8ab3a$e6975770$682b1a09@rationalnt.ibm.com"></CENTER></=
BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_001_004A_01C8AB19.5F91C560--
Content-Type: image/png
Content-ID: <004101c8ab3a$e6975770$682b1a09@rationalnt.ibm.com>
iVBORw0KGgoAAAANSUhEUgAAA28AAAOiCAYAAADnue+WAAAAAXNSR0IArs4c 6QAAAARnQU1BAACx
jwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdw nLpRPAAAABh0RVh0
U29mdHdhcmUAUGFpbnQuTkVUIHYzLjA4ZXKc4QAA+TRJREFUeF7t/W2wHcd5 mIvi/E2lKvfjnFOp
W3V+5f5IVKkiwlIRMAMEvMqVK0pFlkvyLeX6RskxDhAhMFDgoYCQMGnY2BBg UZZpi7RMUtS2QCsy
ZFnWByRaNk3FihGZcCRbhiwxtiXblGXLtqwvK1K4NyllLnqDDfRudvfbPd0z q6f7maqptfZ0T/fb
z9trr3l2z9rrf/r0714edrBBAAIQgAAEIAABCEAAAhCAQMUE/qcdO5S8scOA OcAcYA4wB5gDzAHm
AHOAOcAcYA7UPQeQN+QVeWcOMAeYA8wB5gBzgDnAHGAOMAcWMAe88vYrj71/ +NEf/VF2GDAHmAPM
AeYAcyBjDqj30zF/yeZ9mGsQrsOYA8yBfueA773jBfJmvlmMebPhnLqXWvUv AfJUd55K5cd8PX/j
m88M7PkMzDfSsRflpfJLO8t4Hes5EztfzNftwJZNgNfsMl4nLfw+m1K01Auh BUaMIf716Hvv2CZv
+g0DsPFgl8RKTYIlxUusefNQv56/+vVvDmr/0z//CnsBBpqneuSiMG+O9vYa V/NFEjj9uv3Od74z
sJdnwGuW1+yUv3emvM5C3vqdu/Z7x3V5Q9zanhRT/kKZ8hchbY+bl/r1/KWv fGP4o8//NftEDBRf
vaeurjC3x83tpXMLCZx+3T733LMD+/QMeM32+Rqc8neIea2lZav045Tx03a9 rwnzvWNL3hC3epNV
4oWEuLWdX3uO6NfzF//qa8Mf/NFfss/EQPFWe8zqSonXNW0s93XtmiP6dbu5 uTGwz8uA1+xyX0u1
/R7U11tTCBsrb8xT/btKlLcP/dTeIbTX9sIhnhdObp+8kds2fxHoi8A//eJX hs/8wZ9v26Wc2/X5
eTu/GB6KO3/Rr/e1ddtttw0xu/ReEtOGquNqJyRvG898a2CfnwGv2Xpfs9Jr sabyGlbejv3712/7
vXPn699a9UdmfuM//adB76VzmfN72o6lVFs57WyTt9DKjLrY23z228790xf/ 3ZbYlYZNe+V+iZLb
ciyXMC+1uP3xn/71cOWpL7xgj3k9u87j2AtZhpgo/mrnL/r1vf7UG6e0+aTL /B2Q2479u1n9/N+/
9d9esP//jtw7/OtjPz7877e/adh/x08OB//9Tw2H7vrp4cg9PzMc+9GHh9e9 fn2488fOD3e/6R3D
j/zkzw9n7n+Xsx1X2xx7IW9es/W9Zpfw3qtjrGHlTcnby7//NdevzXPlzZSr 2OcpOVNtqk09ppwX
Wzf0uzrmd73uJ/d3fql21BzbWnkLXeC//yf/yfDM5nPDrf/ft1zf1c9q/8OP 3DN8BoGbZLLFTkqp
XkxudT7NR3K7zDcwU94+8amnB3vXr2cp565zeztm/nXMHnuozKyLwNX3Oir5 BhzzF1Tf72iXvH3z
v/3NYO8/df79w2/+7ueGS5/4g+Gjv/XU8K73f3T41d/43eFD//ETw/t+7fLw Sx/+zeHdH/rPw89f
/I3hP1wtO/PAu17QhqvdFo+Z+bDHFyqz6yJw9b1upWudWspXsfL2fT/+weFf nX3ncPCHf3pQ4qZ3
LXAl5O3P/vyLwxf+7M+Hz//pF4bfvfJ7wx//ydPD5/7oj4c/+MPPDb//B58d nvqvfzB85qnfHz79
mf+aLGFK2n72534h+byUnLt+76eIm+qrpvcOUd7e86bbhm9tXJM3talH9bPa n778k1sC9+mLhwZV
LwVkq3V37NgR5CCVl+YS/Lzbb719K4//8h/+2+s5JbfLftPS8vaHf/KXw+Xf +aMX7J9OyLnr/J6O
mb+o1XM9dt9xHxuVCy4G63ldxQhXzJt67hu5S96+8TdfHexdrbyd/on/MKz9 5DuH17/554dzP/3u
4Y0/84vDmx7+peEn3/a+4f63Xxze8nOPDQ/9hw8Pb3vXr16Vt194QRuudls8 Zr829Rh9x0MMeM3W
85otfV00ZXsxK2//6ofePeg99rNxKubYz7zZK2+vPnD1Oj3ji6eVXP3CL753 ePd73jf84i+9f/il
910c3veBDw0XP/Th4YOP/crwy7/ya8OvPP6R4Vd/7T8Ov/aRj46SMHPVzV7d y4ndd7dEzO/4KW+b
zLn7I2rl7cIbXzJ841vbV97Uz/Z+4cdf4p0cOcKSc26phKe0I8Urlaf0FVPX J2/nX/3hYf2Vj23t
r/uus9efq+Nmbv/bf39uCOU2JoZQnbl55MZb+/la3p767BeH//xfPrttT825 fb7+WeXMVyYdzzlX
art0uX1xri/6zV+66lhMvyofXAy2dTE4hbx9/WtfHuz9x9/63m3v85ev/FHw fV/Vd7WjXnvm7qoz
5THVt9m+/XOJvmNfs7F98Zpt6zU7x/t3zMqbErc3v/PJLYFTMf37n/6Pwx0/ 9fhw5I0fHv7tmQ8M
//upX9o67hM7aRz2Z952/7+v3UL5kdf/r1u7dL5drm9r1L94rvzeZ4K/g8bc /mh+5k09f+q3/3Br
d0ldavy2wI0Rt5w+XRI4ubz93Bv+6fD1q7KmdrXqZj7Xt1KqY6qeb3A5F+g5 55aEHduWFK9UHttP
bD2fvL315R8cnnzbZ4aLd31seONLz19/ro7rHG89fjOc29g4ppgbuX23eL6W t9/7/T8bfv03f3/b
nppz+3z9s5rDvjLpeM65UttTlEv3yqf0qXLCxWA7F4NTyNtXv/JXg70rGfvP Vy9ifvPq/p8/+fxu
Pv/k564f/82r5aq+qx312jOP2z+7zil5bK7+pNds6ph4zbbzmp3jPb+GlTff OJW4/Y/vfC1Z4JRA
qVsl7f3Kpz49/O7V/c+/+Bdbu3qujo2VNx23a+VNHXv22Y1Rbc+R95Q+Srx3 iLdNrp996fCVbzy7
tZufe1PPn374j7aOqTJVL3SBrv/ip+uYfwE0z7OP++r5zjHlyHWu/ddHXzx2 vKpeTMwx/ackObeu
T97uf9m7t8TtwoGPDEduOXX9uTqu860fQ7l1cbEFNcREylFufnTfIWmOyWto 3rr6iJm3ubl1na/l
7ZOf/vzwa7/x1LY9Nef2+fpnc2yhY6rMrus61+7HVye2X1VP9y3F5xujedx3 r3zMuXYdlRcuBtu4
GCzxBmy+htW8+PJf/8UL9h+7eoukuf2nq597C20/9jO/4GxHvS7M9vXP9qOq Y77W9Dn2e6fdli43
6+u2XG2a8bj688XhYmQf871mY8511eE128Zrdor3XLvNmJU39fpVq26xt0za 9aRx/OqP/i/Dr/7o
/3p1/1+Gx7eeX308fe1RyZva1XGpHVOmzN85n/zdT237FfSh9//coHa95cqb HZcWNyVv73vXI9f/
M+WYfmLHPGW9Eu8dorw9uPbdw5e+vrm1K1Ezn2uZU8dUvdjVFd/FvesCO3TR rcXBFrnc47Zs5LZn
ni+Np/SEccmb+oybulVSrbgpcVO7eq52dVyV6zyn5jaFVaiuKUt2vdT8SOIW M3+kcblissdQOrch
efv4lT8ZPvwff+/6Pibn5vnmczXWmJ/teuoc17FSbem29YWgbleK1zdOfdx3 ISid5ytXueFicPkX
gyXegG15+9Jf/flg7z/6Uz8/PPGff2/4tau7+aieu3ZV39WOeh2Yx/XP+vWi y0L1fOfP0a5rTL5j
vtdsShsvyMNVuVZ/HJvj9zh9LPf3Q8zKm8qvvmXSFLPQZ+HUOTGfefvQ3f/z 8J1v/Obz+5PDd/7m
6nO1f+Pqc3X8b24c+9AP/c9R81lJ0m9/8srwO1d381H9AxMlbUqq1KP6pyZq HyNVoc+8fetbfzO4
9jH91PDaKvHeIcrbm3/knw1f/Orm1q5kTT+3H1W9FHmz/4qnL459YpfSttmW 2Y90Ae662NbxxAqn
Wd83xjknj2/l7fUvedh526Q6bub2L67mPSW3EmMpvzGcffI2hrd9ji/f0rhs AXTFMkfe9crbk7/9
R8PFx393256ac/t8/bMam1nmYqjK9XG7rq9d8xyzTX3cPs8Vh6uuL75QHLpM ugUrpg1XHZUfBG65
F2jqtVziDdiWt7/64p8O9n7Xvee3/ZVbSVxoU/Vd7divA11HHTfr+34OHXe1 ndKu73y7Dde47GPS
azamDV8dXrPLfs3O8R6csvJmypp+bn4Wbuxn3t574v82vPf41f3q4/uO/9+3 nr/v+f3bX/zZQe2q
LJaH/Zm3T/zO7279CtLipuVNr8Bd+o3fiG5bx2B/5u2rf/314T3vfHj467/6 0+ErX/5z5468Xf2L
ki+Jb/rhfz782Zc3t3Ylb+ZzvfKmjv3E1XqpghWqH7qIdq2U2OJlS4BvFcTV j08OXP3GyEYo3tgX
z9h6Pnk7te/+67dKqhU3fQulOq5zrB9TchuSHDMHkhSH8hmTH1++bY6x8yRV 3sbmK/c8LW+X/ssf
Du/98O9s21Nzbp+vf1bMzDL7Z/s8fWGmjsfUdfXrOs8XR2p8vnHG/vMD3/nS cZUjLgaXezGY+18r
Xf9t8i/+7OnB3v/PM28d3n/1KwHe/8RvbT0qedv62bOr+q521Osi5rhdT/8c e1z34atvl/viMutJ
dXTd2Nesi0PsMV6zy33N5r6/xpy/6pW3UIy/cOz/uiVu7776GDMWU6w+/tuf HP7LJ35na//TL/zZ
lrh94fP/dfjyl76wbf/cH3yy+Mrbn//pHwyufcnyFvP+4ctR1H+b/LEf+hfD 57+0sbX7PvOmylS9
sfLmuoAOyZvr4l2SN0kWfG2mnGde4KdKXcoLKaWuT97e8ZrHB3Uxr3Z1q6R+ ro7rfOvHlNzGyFsM
p1x5Kz1/cuTNJ4gpeYytq+VN/SONd3/w49v21Jzb5+uf1XjMMulnVVfXseua ZfbzlPNCdWPic43V
/vfiuo7vuI9X6LjKExeDfV4MuuTtz//0j69epGzff/Dun9m20PbLH/1kcOVN 1Xe1o14HMcftevrn
Usd1DFK7Zqy+2O3x2K9NXe477uIRc4zXbJ+v2Zj34ZSVt6k+8+b7b5M//4P/ l0HtMeMw69grb+q7
3j7wnrcPn/uD3x6++GeffcH++5/+rWSBC4mYKtPy9vNv/+nFf+Ytlb9dP0re ztz58uFP/mrjBbsp
cqpc1QsFpP/6bq++2NJk19MXzZKw6fOk9mKkKiRyofhix5ibuJTzffKm2vi1 x9+3lVf1eShXjtWx
P/7L+Nz62JsiFZtfF0tb6Gyh8s0Bm5drDkh5leatqw9Xmym5G1NXy9uvXfrM 8PPvu/yCPSXnrvP1
MT02+2d1PHRMlbnONfsy8ygdd9U1Y5BiCY3R/MuYXS9UFmrTmZOrueJisL+L QZe8feHpzw72rr7n
LXV3taNeF7HHzdeVPsc8Zrflq2/3p+up42YbUn+uuF3HzNelXR4qi23frMdr tr/XbMx7cg0rb1N8
z5v9HyD1z09duTQ8/blPDb/wHx7akir9c+qqmPQ9b1rgUtuNydnS6kTJ26kT 3zN87i+eEfcfOf49
yTY/BTD7wnyKPpbUZkjelpbbJXFfVaxa3n7l139vWL9w6QV7Ss5d53PshUxL MPnQE1cQuIwvkV3V
6y2nX5e8ff6P/2CodVfvrbXGtqq4EDgEzrUqoo+FVtZcn3ezv/8t9jNv3/fj Hxz+1dl3Dgd/+KcH
JW56f/n3X/t+tztf/9bJrs+1sGmpsn+O/R051/e8xcZTc70oebv7dd873H1c 7a8Yfuh1r7j+/MbP
V4+pOlfLVjVY14rLqmKprd+QvC0ht7XxrD0eLW9KBlxSkZLzElJCG/Gy9/5f +Z0tgeOCsI8LQpe8
/cnnnhpq3dX7bK2xrTIuXrN9vF5j3/tjV95cYlbiv02qOO2VtynlTfVnipf+ OZaXq57re95y2mvt
3Ch5a23QvY0nJG+9sehhvFrelAggTvHiVAur9zz2iUHtCFz7F4QuefujP/z0 wL5MBrxm23/NxlxD
xH7mTbU112feppa3GC7UKff6QN46uE0HeSv3glnCLx8tb0oAahES4kiXyHd9 4L+wCtf472eXvH32
9z81sC+XAatwfb3fuq4JclbeQkJnli3hWoQYp3stIG+NXxyoFw/yNt0LqMZf Tlre1MU/0pQuTTUx
+w/vfXJQu74g5C/7bb2WXfL2h099cmBfPgNes229VlPe66e85or5ku6UWKm7 zHmKvCFvK/ucIr80
pvmloeVNXfTXJCLEMl4kz7/7Y4PeuSic5nWzit9HLnn7/U//9sDeFgNes+28 ZmN+TwS/x6NAYUwM
1Gl7zm2TN/MXDM+v/dMAdhgsdQ6oi32EabwwLYHdUucmcd/4vWpeZCkuT33q v7A3zIC5zzUFc4A5
UGIO7NC31i3hYoUY274YJb/klznAHOhlDrhW3viLedt/MSe/5Jc5wBzInQPb Vt56ecNknFwcMgeY
A8wB5sCq5wDyxkVc7kUc5zOHmAP9zQGnvBW4JZcmIAABCEAAAk0SyLlYuu22 267fzhyStybBMaii
BNRcYoMABPohoN97ViZvH/qpvUNo7ycVjBQCEIAABJZEQP/L7tSY1Rtuirzl SCLntv3XeD2X+O+D
beeZ1zH59X0dxQs+85b6hjSmvhK3zWe/7dw/ffHfbYkdGwQgAAEIQKA2AmO/ bwl540Ks1MU48sZc
KjWXaGd5c2llK2/v/8l/Mjyz+Zxz/8OP3DN8BoGr7XqFeCAAAQhA4CoB5G15 FzutXaAib8zB1uY0
44mf08nyFvPvLWPe3T/9W28fvrXx3PAv/+G/3Xo096cv/+SgBO7TFw8N73nT uHu6d+zYERPGtjrq
nDHnJXd09YS5+hkTW+icmLhLc4zpM2WcUnt2uVQ/pW/qQgACyyeAvMVfZHBB Ng2r0vKm3ufI1TS5
gitcS8+BUfIWeutVDUrb+Vd/eFh/5WNb++u+6+z15+r4N7713PX9v/3354YL P/4SqTlnuXTBveoL
dCm+UYOe4SQpbql8TIil25Ta880N6bxc6R3DhnMgAIH5CaxS3vQfx/Rj6YsC qT0u8uu4EJXkzc6T
lDepXJoXlNcxL8hDH3lYiby99eUfHJ5822eGi3d9bHjjS89ff66Of/2qvF3f v/nc8HNv+Kej3pml
C23kbRRWccVQ4j6m19JtSu0hb2OyxDkQ6IdASN5CF8ElPvOWelFe+mKOi/w6 Lg6RtzryUPr1RXvk
NWYOrETe7n/Zu7fE7cKBjwxHbjl1/bk6/pVvPLttXz/70uAVgf1XSF3ZvAA3 65jl+rg6FlNH17Mf
Xe2YQYdEUZdJ8Y6J0WYR25eLhTlmH8PUGO1+fPFJObNZm/lwnSuxtstTx+vi 4GOaGrsUi52nmH77
ueRmpBAoQ8Anb+brzfcfwnL/26RP3vRxs9wVj/2eacbpq6/qmO3reuZx3Q5y N8/FZ468xeTZlU9p
fsdcdFJnnvkB57Y5j5Y3+w1AX/Dq2yZ9j+ozbupWSbXipsRN7eq52tVxVf6l r29e3x9c+25R3lyi
ZAuTT2RcsucTFfOi3CeJ0nHfxbUUh2s8PikMHfeJidS/K+4Y7iFxdeUkRnR9 sYzhIY0hxCu2P9d8
sid1Tlum9KbEW+YyllYg0B8Bl7y53hPtC6gpV95MoQpJlSR/9kV7bLvI27wX i5K82cLtu5i3pT91
fiAJ8+Yd3vBWc2C0vPnermM+8/b6lzzsvG1SHf/iVzev739x9fmbf+SfZcub /aYakjNJYsbIRehC
3dWeL15JhMyLeElKfELhk3KfdJr1fVxd44mR3JAwuiQlVoBs2QmNQZKhsbly zYmYeSr9YcHOe4h9
f5fcjBgCZQjY8ub6vWlLj37DLbHyZvbnk6bUi3CffPrasVfsXMLIheZ0F5o5 8mbnOiR6pty5ziPH
0+UYtrD1zYGVyNupffdfv1VSrbjpWyjV8T/78ua2/Sd++J9nyVvqBX0N8hYa sP7lmXoRHyOs0gpR
SGQkbq4xSTI6h7xJcUnyNjZXIaF3iXfomCTtZS5XaQUCENAEfLdNShdbU6y8 lZQ3V/zIW50XkGPl
TZJ6qVya45TXOV/IS1t5WYm8veM1jw9K1NSubpXUz9Xxz39pY9v+Yz/0LxYv byFJkQTGLjeFJlVM
pb4kwYsRGakPn2j4xNHXp+t4KR4xfUqsbJkN5TFFxFPqSrngUhwCEBhHoAd5 M1dcXKts9sWgfdHP
xeK0F4sx8ha6fdZ1e+yY223J87R5hi98XXNglLxJ3/UW83b4a4+/b/iTv9rY +oybenTtf/yXG8OZ
O18uypu5lO9aAbKX+s06kkyYK13SBXvMRX/MBbVvPHYsOh7p+JgxSuP29e2T FFd79jglNrF8Y3lI
YwiNxZ5DdmyhGFxzNDaXUr+uFT1XLDGvUepAAAJuAkuQN30hrl//5sW6+bvX FjNXfZeo2bKGvM17
kTlW3ux54ZJ0+5rJNXeQinnzDW94m3MgWd5KvZmfOvE9w+f+4hlx/5Hj3yPK W6mY5mjHJQRz9Jvb
xyriXkWfJqdV95+bM86HAASmIbBKecu9iJtCsqZoM3ecrZ8fK2+tc2B8SE2P cyBb3mL+QYnr7fPu
133vcPdxtb9i+KHXveL68xs/Xz2m6lwtC21Lu8BeWry+VaJpLom2t7pqVqvu fw7G9AEBCKQTUBcL
0h0ovvLcf1iSe6EyhWhN0WbuOFs/H3lDWlqf44zPP8ez5S39bY8zIAABCEAA AssloAQsZ1+/cGlQ
u3oDtm+F0T8rOmMFkfN+tAt2ag4yT/rINa9p8my+XyBvy71+IHIIQAACEFgB gZy/CMeuvOXIIefm
yTX84MccYA7UOAf0e0+2vI29bdL1fluyrRW8n9MlBCAAAQh0QEB/5i11qKlf FZDaPvX7IjB2HvZF
idFCoB0CxeStHSSMBAIQgAAEICATmOsflsiRUKNnAshbz9ln7D0SKCZvJVfL SrbVY1IZMwQgAAEI
TE8AeZueMT3IBPQ8/PVffsMwZv/UJ94jd0INCECgGgLF5K2aEVmBqO+PY4MA BCAAAQiUJtCzvOV8
b+QU/8F3ijZLz5ep2tPz8Fcvvmn45FeeG7VPFRvtQgAC5QkUk7ec1bKY/54T O/Tzr/7wsP7Kx67v
r/uus9t+VuVsEIAABCAAgVwCLcib/UXMMUxyRUmfH2rHLpP6lMpjxrXUOlPK mzk/lsqHuCHQGoFi
8pYDRhI/qdzs+5FXfGh47J4nh8fPfXx4z5GPDuuvemzbz6pc2nLeBHLOleKi HAIQgAAE6iHQiryZ
RGPew2LqhLKEvJWdw3oefuC9b95adfv7+39ma//8X28MX/r6s8Odb/3w8IP3 f2D4/nPvHr775M8N
/+gHH97a/7d//VPD337lG7bqubZUgS47KlqDAAR8BIrJW4pg2cFI50rlZntv ffkHt8Ttybd9Zrh4
18eGN770/LafVbm05bwx5ZwrxUU5BCAAAQjUQ6BFeVN0zfcx18pLyjGXGJry 5rv9MiQOvv7t2GPG
Us9sGh+JnofvetdD2+TtL7+2OXz1m89t27929Wd7V3WQt/H8ORMCcxMoJm85 gUtyJpWbfd//sndv
rbgpcbtw4CPDkVtObftZlUtb7BuTfmMw33y4xUCiSzkEIACBNgi0Lm8+gZL+ SOlbWbOPj21HEsJQ
uS6T+l7SDNXz8O3v+Nlt8qYk7ZvPfHtr5e3oT39w+Ddv/KXhe37kncM/vmN9 a/8HB98y/N3vv2/4
W9/7BuRtSQkn1u4JFJO3FMGyqetz7Xvv9S9XXe571O2pf06iPuOmVtvUrsRN 7/qYKpf+iYl0q0Do
lo+W3hC6f3UAAAIQgECAQA/yZr8v6z9a2lhi6pWSt1BfIeF0ndfCBNfz8C3r 79wmb9/a/M6w8ez/
2LZvPvudQe+6bPO57yBvLUwExtANgWLylkNMEj+p3OxbSZr5mTclb+bPqlza XL/8fW8WkuhJfVEO
AQhAAALLJNCDvLkyI73vTbnyJq0GSuXLnGnhqPU8/ImHf3FL3r618e3ruxI1 tfJ26M0fGF61dmHY
c3XF7e/9wANb+9/5vnuv1dv8NvLW4sRgTM0SKCZvKYJl05TOlcrN9l7/koeD n3lT5dImvTH5/uLo
+4uk1B/lEIAABCCwPAItypv5/hcrQqn1QnevuN5fzWNSX1K5bqulu2T0PHzD W9472PtTn/3CIO1f
+OKXkbfl/foh4o4JFJO3HIaSnEnlZt+n9t2/7TNuaqXN/AycKpc2Sd5cv/RT 3oyk/imHAAQgAIH6
CbQib+adJb4/ToakTv/h0tWOdDulLvdl2/d+a/dlxyfFUv/sio9Qz0PfGdJ/ mwz1FJob8RFSEwIQ
KEmgmLylCJY9gJLf8/aO1zw+KEHTu/qMm/mzKo/Z7DeUlDcC6c0opn/qQAAC EIBA3QRakLe6CRNd
DIEp5S2mf+pAAALzEigmb/OGHd+b9M9J4luiJgQgAAEIQOAGAeSN2VADAUne aoiRGCAAgXIEislb
zspbueHQEgQgAAEIQGAeAsjbPJzpJUwAeWOGQKAvAsXkrS9sjBYCEIAABHon MIe86TdpHi8PMIAB
c4A5wBy4MQfUwtkOBUQ9Wb9waWtP2Vh5S6FFXQhAAAIQWDoB5I0LSS4kmQPM AebAquZAs/KGVC79
8oj4IQABCNRJAHnjom1VF230y9xjDjAHsuWtzrdWooIABCAAAQhMQwB54+Kp pgvoX//lNwxj9k99
4j3cknr1zrOackks5CNmDmTLW60rXDlxrd9z0yDt01wS0CoEIAABCNROAHmr 7wJLfVVPzEVPi3V+
9eKbhk9+5blRe4s8GFN9r09yUjYn2fJW+5vsmPiUuG1sXvHuqpwNAhCAAAT6 JNCCvJnfYZp6YbVq
UbK/AFzFP0VMuh+TzxT9pPK365eWN2mMUnnueDi/7IU+PNvjmS1vOStcU77t 58T1yN07g/Kmytkg
AAEIQKBPAi3IW47wrPLi3df3FDEtRd4+8N43b626/f39P7O1f/6vN4Yvff3Z 4c63fnj4wfs/MHz/
uXcP333y54Z/9IMPb+3/27/+qeFvv/INW/XGXNhPwXpMHJzTnpSQ07icZstb i2/dD961c3hm46mt
fWPz+V0/v/qoyqVN/XILbVK51D7lEIAABCCwGgItyptrNUtfSNmrdK5VO+mY fcEv1XddxIWkwSzz
rSqm9qnbtNv2cdFCbEqfTwBdx8deuL7rXQ9tk7e//Nrm8NVvPrdt/9rVn+1d 1Qlx9s2JnFXbsWPk
vLiLejj1wSlb3nJWuKZ8282J64E7bx4efejIcN6zq/LcDXnLJcj5EIAABFZD oFV5c90e6BImaeXF
JT3mSl9MmzF1Ym5n9MUSs/IoyZvEyyV9LonNveB++zt+dpu8KUn75jPf3lp5 O/rTHxz+zRt/afie
H3nn8I/vWN/a/8HBtwx/9/vvG/7W975BlDdpjLmxc34fskGey+Y5W95W89Y5 ba/3nXhx8LZJVS5t
Ws7sv1zp88zjUluUQwACEIBAPQR6k7cY4XCt0vjO84mZb6XHXOnyXQT6Vt5M AXPFk7KaZwufNGaf
vEnjTL3Qfcv6O7fJ27c2vzNsPPs/tu2bz35n0Lsu23zuO8gb/21y1K2zqXOU +pXJW84K15RvxTqu
2EczlnvvuCUob6pc2kx5M+v6jkvtUQ4BCEAAAnUQ6Ene7FsEXStWsZKWswom rZRJq32ucYSOuUQt
tHoordKFxp57YfsTD//ilrx9a+Pb13clamrl7dCbPzC8au3CsOfqitvf+4EH tva/8333Xqu3+W3k
DXlD3hY4B1h5c1wLnDm2K/iZN1UubcibRIhyCEAAAssk0KO8xYiLvUIWK3Ux QiitvsXKm08CY27T
1CtmoXhdq20p7MaI3Bve8t7B3p/67BcGaf/CF7+MvC3wwn3MHOGcsitfq+aZ LW+1r7yNuTQ4dWT3
sHbu9LB21r2rcmlD3iRClEMAAhBYJoEW5M28dU+SEVNafKtV0i2EoVsO7TZD tzLqdkLx+2Kxx2G3
YV+QSbdZSmMOiZyLaekLQum/Tfr6ixHhOeIvzYP22hKYnvOZLW/LfOsNR33y 8K3B2yZVubQhbxIh
yiEAAQgsk0AL8tbzhU8vYx8rb73wYZzI3FLnQLa8tbjydvzQnqC8qXJpk+RN na//ciW1RTkEIAAB
CNRDAHnjom+pF33EzdxlDix/DmTLWz1vp+Uiuf3g3uBn3lQ5GwQgAAEI9EkA eVv+xQ8XsOSQOcAc
WOocyJa3Flfejh7YNxze799VORsEIAABCPRJAHnjom+pF33EzdxlDix/DmTL W59v3YwaAhCAAAR6
JTCHvPXKlnHHE9DzMP4MakIAAksmoMU7W95aXHlbcmKJHQIQgAAEpiWAvE3L l9bjCCBvcZyoBYFW
CCBvrWSScUAAAhCAwKwEkLdZcdOZh4Ceh7/+y28Yxuyf+sR7YAsBCCyIQDF5 W9CYCRUCEIAABCCQ
TQB5y0ZIAwUI6Hn4qxffNHzyK8+N2guEQRMQgMBMBIrJG7dNzpQxuoEABCAA gSoItCBv5hdMp0LV
X4WTel5ufftLsaeMw/VVPlP2N4bNVPImjVMqHzMWzoEABGQCxeRN7mr5Nf7l P/y3yx8EI4AABCAA
gSIEWpA3BWLsRfjY84rAz4g7pf8lydsH3vvmrVW3v7//Z7b2z//1xvClrz87 SF/SreqN2Vad/zEx
cw4EWiBQTN5qWXlTcUh7bOLOv/rDw/orH7u+v+67zm77WZWzQQACEIBAnwRa lDd7VcvMrL1K51q1
k47ZF/xS/dDMcrVlx6vl1LfCKK086j7MvuzntuD5OIVY5ryC9Dx817se2iZv f/m1zeGr33xu2/61
qz/bu6rj2syx5+QpZ2ycCwEIvJBAMXmrBa4kkVK5OY5HXvGh4bF7nhweP/fx 4T1HPjqsv+qxbT+r
cmnL+ctUzrlSXJRDAAIQgEAegVblzSdANi3pPcolPlqmzEdXf/pYqI8UeYsZ k6svSd6kdl3SJ8Wd
Oiv1PHz7O352m7wpSfvmM9/eWnk7+tMfHP7NG39p+J4feefwj+9Y39r/wcG3 DH/3++8b/tb3vkGU
N2mcqTFTHwIQGE+gmLylSNH4cOUzpTikcrOHt778g1vi9uTbPjNcvOtjwxtf en7bz6pc2qQ3t9D5
OedKcVEOAQhAAAJ5BHqTtxjpcK3c+c7zyVJo9S8kej4xDPUv9SXJlzRe3/lS vykzU8/Dt6y/c5u8
fWvzO8PGs/9j27757HcGveuyzee+g7ylAKcuBFZMoJi8rXgc17uX5EwqN8dx /8vevbXipsTtwoGP
DEduObXtZ1UubSm3GvhutUDiJMqUQwACEJifQE/ypumatwhKMldi5S31D5wx K2W+uFx9heQtRkol
+Ssxa/U8/ImHf3FL3r618e3ruxI1tfJ26M0fGF61dmHYc3XF7e/9wANb+9/5 vnuv1dv8NvJWIhG0
AYGZCBSTtxQpmnJsOg77r1r6F6gu9z3q2NQ/J1GfcVOrbWpX4qZ3fUyVS//E ZOybm/kXxCl50TYE
IAABCIwj0KO8me9NY9/fQvIktWlmyveHTakNSSpDfcTIq0vYUrilzkY9D9/w lvcO9v7UZ78wSPsX
vvhl5C0VOvUhsEICxeRthWPY1rUkkVK52ZiSNPMzb0rezJ9VubS53kR8t1lI bzhSX5RDAAIQgMB8
BFqQN9cdHy55cd1FooXElpXYNs3zfW2Espkib1L8qW3puHzv52a577kpgjmz Vs9DXxvSf5v0nRcj
uaXGkDN+zoVAbwSKyVuKFE0JWYpDKjdje/1LHg5+5k2VS1uqkIX+qif1RTkE IAABCMxHoAV5m4/W
PD25JMwnZvNENH0vU8nb9JHTAwQgMIZAMXkb0/kU50hyJpWbMZ3ad/+2z7ip lTbzM3CqXNokeQu9
0bT+hiOxoxwCEIBAzQSQt/qyg7zVlxMiggAEyhIoJm8pUlR2CNtbk77jLSXO d7zm8UEJmt7VZ9zM
n1V5zGbfVuC6fUO6pSOmH+pAAAIQgMB8BJC3+VjTk5+AtPIGOwhAoC0CxeSt LSzu0Uj/nKQHBowR
AhCAAASuEZhD3vSbNI+Xt3izw4A5wBxgDlybA2pBaod+sn7h0qD2lC1lRSul XepCAAIQgAAEaiQw
h7zVOG5iqosAK2915YNoIDA1AVbepiZM+xCAAAQg0CQB5K3JtC5uUMjb4lJG wBDIIlBM3lh5y8oD
J0MAAhCAwMIIIG8LS1ij4ep5+Ou//IZhzP6pT7ynUTIMCwJtEkDeEvKKoCbA oioEIACBxgkgb40n
eCHD0/PwVy++afjkV54btS9kqIQJAQhcJVBM3qAJAQhAAAIQ6IlAC/Lm+pJl vqZmWbN4Knmzv4Dc
/NLumC/nZh4tax4R7XIIFJO3HlalehjjcqYukUIAAhBYLQHkbbX86f0aAT0P P/DeN2+tuv39/T+z
tX/+rzeGL3392eHOt354+MH7PzB8/7l3D9998ueGf/SDD2/t/9u//qnhb7/y DVv1XFtIvmLELKYO
OYQABNIJFJO39K77PoOvHeg7/4weAhBYPoFW5E1lwrzQtp9L31XqW72LWZ1Z /ixY/Qj0PHzXux7a
Jm9/+bXN4avffG7b/rWrP9u7qpMjb/YKnW7L9/21qydGBBBYNoFi8tbiqlTJ L/w+/+oPD+uvfOz6
rr7w2/xZlS9xk/6yJpUvcczEDAEIQEAR6EHezEybt82ZF+j2c/v3Pu8D075e 9Dx8+zt+dpu8KUn7
5jPf3lp5O/rTHxz+zRt/afieH3nn8I/vWN/a/8HBtwx/9/vvG/7W977BK28+ AfPJvvmHAPI+bd5p
vV8CxeStRYSSkErlJpNHXvGh4bF7nhweP/fx4T1HPjqsv+qxbT+rcmnz3X9u /5VLakf/cnW9wab+
spXqS+UxsVIHAhCAQI0EWpI330W3a1UltEpnvr+w8jLPrNXz8C3r79wmb9/a /M6w8ez/2LZvPvud
Qe+6bPO573jlzTcC5G2e3NILBFwEislbisgsJRXSmKRyc5xvffkHt8Ttybd9 Zrh418eGN770/Laf
Vbm0SSKUcotK6DYXKQ6zPCamlPaoCwEIQGApBFqXN98KWoy8LSWHLcSp5+FP PPyLW/L2rY1vX9+V
qKmVt0Nv/sDwqrULw56rK25/7wce2Nr/zvfde63e5reRtxYmAmPohkAxeWuR mCRnUrnJ5P6XvXtr
xU2J24UDHxmO3HJq28+qXNpCohT6K5irXfv2F9/tMNJnGex+7fqS3EljphwC EIBArQRakzfF2fwd
XkreeB+YdgbrefiGt7x3sPenPvuFQdq/8MUvI2/TpojWIVCUQDF5SxGZoiOY sDE9Jt/tirrc96hD
U/+cRH3GTa22qV2Jm971MVUu/RMT1+0ruo/S8hbzpq3f6M1HOx7etCecoDQN AQislEDr8mbKnE/q
QqtwKXeDrDSRC+9cz0PfMKT/Nuk7z3ftY98O67tesP8YsHDMhA+BaggUk7dq RlQwEElIpXIzFCVp
5mfelLyZP6tyaZti5c0WL9cKXKykueQSeZOySjkEILBUAi3I21LZE/cNAlPJ G4whAIE6CRSTtxSR
qRPFC6OSxiSVmy2+/iUPBz/zpsqlzSdCrr+OSdKU+pmFVKnTY5HikMZMOQQg AIFaCSBvtWamr7gk
eeuLBqOFQPsEislbi6gkOZPKTSan9t2/7TNuaqXN/AycKpe2kLzZ50rSJLXF bZNSNiiHAAR6J4C8
9T4D6hg/8lZHHogCAnMRKCZvKSIz1+By+yn5PW/veM3jgxI0vavPuJk/q3Jp C91/XlreVHv2fe26
D99n71z1JYmUxkw5BCAAgVoJzCFv+k2ax8tb36vHDgPmAHOAOXBtDihP2aGf rF+4NKidbToC0j8n
ma5nWoYABCAAgRIE5pC3EnHSRtsEWHlrO7+MDgI2AVbeGp8TYz4P1zgShgcB CECgCAHkrQhGGskk
gLxlAuR0CCyMQDF5W9i4CRcCEIAABCCQRQB5y8LHyYUI6Hn467/8hmHM/qlP vKdQJDQDAQjMQaCY
vLX4mbc5EkAfEIAABCCwTALIm5y3nM89S/9YS+69jxp6Hv7qxTcNn/zKc+L+ R9/49qB3Xb8PUowS
Am0QQN5WlEdkd0Xg6RYCEIBAIQKtyJvvn1DFYJLkzPc1MzltS33GtN1Snank Dc4tzRLG0hKBYvLW
EhTGAgEIQAACEJAItCBvU1+g57TPyps0A6+V63n4gfe+eWvV7e/v/5mt/fN/ vTF8/kvb97/6m83h
//yZ39za/9H3nhz+6m+e3arn2nJyFxc5tSAAgTEEiskbK0lp+OGVxovaEIAA BGoj0Lq8hb7+xbWi
FlvfV08f13kOfS2Nq05t82OuePQ8fNe7Htomb3/5tc3hL4z9q9987rq0KXFT Ave1q8fUcZ+8mTmx
c+77PljVlu+rhuZiQj8QaJlAMXlrGVLtY+NrB2rPEPFBAAItEmhB3nwX2r4L c5dg+S78ddvmo1lX
WlkLxeBqs9eVIj0P3/6On90mb0rM1K4k7ZvPfHvr8bYfeNP1lTd9TIlcKIe2 KJs/u/IZkroWfw8w
JgjMTaCYvLGSFE5dyS/8Pv/qDw/rr3zs+q6+8Nv8WZXPtUlvllL5XHHSDwQg AIHSBFqRN98FuGvl
K3a1JWWVxhZI3+fkXG3mfF6v9HxYVXt6Hr5l/Z3b5O1bm9/ZujVSr7Lpx5fd 9cuD2vWtk+oxVt5C
8m3mh7ysajbQbw8EislbD7ByxijJrVRu9v3IKz40PHbPk8Pj5z4+vOfIR4f1 Vz227WdVLm32X0/N
N0/p3NAvb/tc5C2FJnUhAIElEWhd3lIu6FNWyaSVmRR5W9J8mSpWPQ9/4uFf 3JK3b218+/r+368+
f82P/cctgVOPG89+Z9tn3pS4bTz3neLyNtVYaRcCELj2OVe1K3fYoZ+sX7g0 qD1lS5GPlHZbqSvx
kcpNDm99+Qe3xO3Jt31muHjXx4Y3vvT8tp9VubQhbxIhyiEAAQiECfQkb7FC pYn5Vt5cf9CTxE9q
0y7vbd7qefiGt7x3cO3/9bN/tiVv//WzX9jazX9Yop5/4YtfnlTe+CNubzOS 8U5NoJi8TR3o0tuX
5EwqN8d//8vevbXipsTtwoGPDEduObXtZ1UubTFvrL4PHPtuh3DV55e2lAnK IQCBpRJoQd5Ct7fF
/E43f8eHbrP03VJnipfdX+i9xnXeUudRbtx6Hsa0o2+V1J9z07dS+s41/9Dr E2/fPHH9kTgmRupA
AALyHw5ZeZthlmg5s9+M9C9DXe571CGqf06iPuOmVtvUrsRN7/qYKpf+iYkk b2P/Eur7C+kMiOkC
AhCAwKwEWpC3WYHR2SQEppS3SQKmUQhAIIsAK29Z+OJPllbWpHKzJyVp5mfe lLyZP6tyabP/WipJ
V8wtM6G/ukrxUA4BCEBgaQSQt6VlrM14U+TN9Z8lff9tsk1ajAoCyydQTN5S 5GP52NJHIPGRys0e
X/+Sh4OfeVPl0jaFvLn65LZJKROUQwACSyWAvC01c23FnSJvbY2c0UCgTwLF 5K1PfPGjluRMKjd7
OrXv/m2fcVMrbeZn4FS5tPmkKmaFzWw7tb4UF+UQgAAElkJgDnnTb9I8Xvvv auwwYA4wB5gD/LfJ
Wa4TSn7P2zte8/igBE3v6jNu5s+qXNokeVPn8w9LJIqUQwACPROYQ9565svY 4wiw8hbHiVoQaIUA
K28NZFL65yQNDJEhQAACEKiOAPJWXUq6DAh56zLtDLpjAsXkLeW2v455Xx86 vJgFEIAABJZNAHlb
dv5aiR55ayWTjAMCcQSKyVtcd9SCAAQgAAEItEEAeWsjj0sfBfK29AwSPwTS CBSTN1aS0sBTGwIQ
gAAElk0AeVt2/lqJHnlrJZOMAwJxBJC3OE7Fa5WU3ZJtFR8oDUIAAhBolADy 1mhiFzYs5G1hCSNc
CGQSKCZvmXFwOgQgAAEIQGBRBJC3RaWr2WCRt2ZTy8Ag4CRQTN5Y/UmbYSV5 lWwrbRTUhgAEINAv
AeSt39zXNHLkraZsEAsEpidQTN6mD5Ue5iDA1w7MQZk+IACBFgggby1kcflj QN6Wn0NGAIEUAsXk
jdWfFOzDkMOr5Bd+n3/1h4f1Vz52fVdf+G3+rMpzNt+Xgee0mXOuFI9UntM3 50IAAm0RQN7ayudS
R4O8LTVzxA2BcQSKydu47jlrDAFJ/KRys89HXvGh4bF7nhweP/fx4T1HPjqs v+qxbT+r8thNiY+5
q/NKyZBu14zFdUyKVYpHKpfapxwCEOiHAPLWT65rHinyVnN2iA0C5QkUk7cU YSg/jOW1mMNLOlcq
N2m99eUf3BK3J9/2meHiXR8b3vjS89t+VuUxm096SskQ8haTBepAAAJzEkDe 5qRNXz4CyBtzAwJ9
ESgmb31hW+1oJTmTys3o73/Zu7dW3JS4XTjwkeHILae2/azKpS0kaGaZvSqn 23Ud963g6fbsR9VW
TPtSPKVkU2JGOQQgsHwCyNvyc9jCCJC3FrLIGCAQT6CYvKUIQ3x47dbM4aXP tW9T1OKhy32Pmqr6
5yTqM25qtU3tStz0ro+pcumfmMTKm5lNl3yZMmdn3idtvnZKHW93BjIyCEAg lwDylkuQ80sQQN5K
UKQNCCyHQDF5W86Qlx+pJH5SuUlASZr5mTclb+bPqlzaYuXN95k4+3zfLZIu ucuRtCk/oycxoxwC
EFg+AeRt+TlsYQTIWwtZZAwQiCdQTN5ShCE+vHZr5vCSzpXKTaqvf8nDwc+8 qXJpi5E3l6CZ7Uqf
abNvd7RFztd+7HGXGErjphwCEOibwBzypt+kebw8wAAGzAHmAHPgxhxQ1/s7 FBD1ZP3Cpa2drU4C
kpxJ5eaoTu27f9tn3NRKm/kZOFUes0n/sESSN9WHq43Q7ZXmObGSlrpSFzN2 6kAAAn0SmEPe+iTL
qFMIsPKWQou6EFg+AVbeVpTDFMGyQyz5PW/veM3jgxI0vavPuJk/q/LYTboN MXTb5Nh/JCKdpwXP
9c9MfMdix0s9CECgbwLIW9/5r2X0yFstmSAOCMxDoJi8zRMuvUxNQPrnJFP3 T/sQgAAElkIAeVtK
ptqOE3lrO7+MDgI2gWLylrOS1GNa4NVj1hkzBCDQEgHkraVsLncsyNtyc0fk EBhDoJi8jemccyAA
AQhAAAJLJYC8LTVzbcWNvLWVT0YDAYlAMXljJUlCvb0cXmm8qA0BCECgNgLI W20Z6TMe5K3PvDPq
fgkgbyvKfa3yVmtcK0oT3UIAAhDwEkDemBw1EEDeasgCMUBgPgLF5G2+kOkJ AhCAAAQgsHoCyNvq
c0AEw9b337FBAAL9ECgmb6zYpE2aWnnVGlcaXWpDAAIQmJ4A8jY9Y3qQCSBv MiNqQKAlAsXkrSUo
jKUMAb52oAxHWoEABOokgLzVmZfeokLeess44+2dQDF5Y8UmbSrVwqvkF36f f/WHh/VXPnZ9V1/4
bf6sytkgAAEItEIAeWslk8seB/K27PwRPQRSCRSTt9SOqV8HAUkipXJzFI+8 4kPDY/c8OTx+7uPD
e458dFh/1WPbflblMduOHTsGc485x6yjzmWDAAQgMDUB5G1qwrQfQwB5i6FE HQi0Q6CYvKVc5LeD
b/xIauElxSGVmwTe+vIPbonbk2/7zHDxro8Nb3zp+W0/q3JpKyFeJdqQ4qQc AhCAAPLGHKiBAPJW
QxaIAQLzESgmb/OFTE8lCUhyJpWbsdz/sndvrbgpcbtw4CPDkVtObftZlUub T7zs4+bP9iqda9Uu
5piuI8VIOQQgAAFFAHljHtRAAHmrIQvEAIH5CBSTt5SL/PmGV29PtfDScdi3 Kmo50uW+R01Y/XMS
9Rk3tdqmdiVuetfHVHnMPzHxiZaZTR2fS/ZCoqfacJ1ry2C9M4fIIACBWggg b7Vkou84kLe+88/o
+yNQTN76Q9fGiCWJlMpNCkrSzM+8KXkzf1blqZtLqlyrbi6x08d8YuoTNm67 TM0S9SHQJ4E55E2/
SfN4eWulkx0GzAHmAHPg2hxQ1+g79JP1C5cGtadsKRf5Ke22WrcWXlIcUrmZ n9e/5OHgZ95Ueeom
yZstaObKmlnm6hd5S80G9SEAAZPAHPIGcQhIBFh5kwhRDoG2CLDy1lY+k0cj yZlUbnZ4at/92z7j
plbazM/AqfLUTboF0mzPdyulrw3kLTUb1IcABJA35kBtBJC32jJCPBCYlkAx eUu5yJ92SMtovRZe
Jb/n7R2veXxQgqZ39Rk382dVLm3S1wS4RMz1j0bsY9Ln6PjMm5QZyiEAAZsA K2/MiRoIIG81ZIEY
IDAfgWLyNl/I9LQUAjH/nCRlLHwWLYUWdSEAgakJIG9TE6b9GALIWwwl6kCg HQLF5K2WlaSlpAZe
6ZlC3tKZcQYEIDAdAeRtOra0HE8AeYtnRU0ItECgmLy1AIMxQAACEIAABGIJ IG+xpKg3JQHkbUq6
tA2B+ggUkzdWktKSC680XtSGAAQgUBsB5K22jPQZD/LWZ94Zdb8EkLcV5b4H eethjCuaPnQLAQhU
QAB5qyAJhLD1fU9sEIBAPwSKyVs/yBgpBCAAAQhAYLh+0Zz6hbHqD1u33Xbb 1vepql39bLZh/gxn
CEgEkDeJEOUQaItAMXljlSVtYvTAK2eM6/fcNEh7GnFqQwACEChLgJW3sjxp bRwB5G0cN86CwFIJ
FJO3pQIg7joJKHHb2Lzi3VU5GwQgAIFVEkDeVkmfvjUB5I25AIG+CBSTt5xV lr6QXxtti7xKfuH3
I3fvDMqbKs/ZWvjagRbGkJNDzoXAqgkgb6vOAP0rAsgb8wACfREoJm99YWO0 LgKSkErlZpsP3rVz
eGbjqa19Y/P5XT+/+qjKYzclOeauzistPqXbs8c29RhsPrFsqQeBngkgbz1n v56xI2/15IJIIDAH
gWLylnJhPsfAau+jRV72mGyhSRnzA3fePDz60JHhvGdX5TGbT6pKypYWn5h4 dJ2U/qceg91+Smwp
Y6YuBFojgLy1ltFljgd5W2beiBoCYwkUk7exAXBeOwRKytt9J14cvG1SlUtb SELMMt+qk+t4qK4U
j10eI31zjmGMWKaOmfoQaIkA8tZSNpc7FuRtubkjcgiMIVBM3lJWVcYE2to5 LfLSY7Jv8dMCost9
j2aO773jlqC8qXJpixUfsx19juvcMe1JMarykMSN6XPsGHQsMTFTBwIQmOer AlK/hoD6l7d97QI8
4MEcYA60OgfU9fQONTj1RH/3DG/OEEghUHLl7cyxXcHPvKlyaYsVH9/nyVy3 E465hTH282Q5wjj1
GCTWlEOgRwKsvPWY9frGzMpbfTkhIghMSYCVtynpBtpueeVNDzvnM2+njuwe 1s6dHtbOundVLm0x
8iZ93su1KuY7JsXjK89deSsxBj7nNjZ7nNczAeSt5+zXM3bkrZ5cEAkE5iBQ TN7mCJY+6iYgCalU
bo7u5OFbg7dNqvKYTVopk8RH9RGzIjZGfmI+8+br3zyeO4Yxscewpw4EWieA vLWe4WWMD3lbRp6I
EgKlCBSTt5QL81LBL7mdFnmV/J6344f2BOVNlcduvlsK9fmhWw5NsfHd/hh7 W6QZb6owTTkGu+3U
2GLzQD0ItEYAeWsto8scD/K2zLwRNQTGEigmb2MD4DwIuAjcfnBv8DNvqpwN AhCAwCoJIG+rpE/f
mgDyxlyAQF8EislbiytJU06FHnjljPHogX3D4f3+XZWzQQACEFglAeRtlfTp G3ljDkCgTwLF5K1P
fIwaAhCAAAR6JYC89Zr5usbNyltd+SAaCExNoJi85ayyTD3IGtuHV41ZISYI QAAC8QSQt3hW1JyO
API2HVtahkCNBJC3FWWlB3nrYYwrmj50CwEIVEAAeasgCYSw9aXkbBCAQD8E islbP8gYKQQgAAEI
QGC4ftGs30hjH9Uftm677bZh/cKlrV39bJ5r/gxnCEgEkDeJEOUQaItAMXlj lSVtYvTAK2eM6/fc
NEh7GnFqQwACEChLgJW3sjxpbRwB5G0cN86CwFIJFJO3pQIg7joJKHHb2Lzi 3VU5GwQgAIFVEkDe
VkmfvjUB5I25AIG+CBSTt5xVlr6QXxtti7xKfkn3I3fvDMqbKs/Z+CLqHHqc CwEIKALIG/OgBgLI
Ww1ZIAYIzEegmLzNFzI91UpAElKp3BzXg3ftDH5JtyqP3ZSombs6r6S82W3H xkU9CEBg2QSQt2Xn
r5XokbdWMsk4IBBHoJi8pVyYx4XWdq0WeUljksrNjD9w583Dow8dGc57dlUe s/kkrZS82e2Uajdm
bNSBAARWSwB5Wy1/er9GAHljJkCgLwLF5K0vbIzWRUCSM6ncbPO+Ey8O3jap yqUtJFJmmW/lzHVc
WmVD3qSsUA6BdgjMIW+x/8GSepe3/cdOeMCDOcAcaH0OqOvqHWqQ6on+98Up b7EpF+Yp7bZat0Ve
ekz2bYpaaHS579HM9b133BKUN1UubbHyZrajz3GdK4mZVC7FSzkEILAsAnPI 27KIEO0qCLDytgrq
9AmB1RFg5W117JvrWRJSqdwEcubYruBn3lS5tMXKm+8zca5bIqe+DVMaE+UQ gEA9BJC3enLRcyTI
W8/ZZ+w9EigmbykX5j2CtsfcIi9pTFK5yejUkd3D2rnTw9pZ967KpS1G3qTP rGmxM/uyj7HiJmWC
cgi0SQB5azOvSxsV8ra0jBEvBPIIFJO3vDA4uwUCkpxJ5SaDk4dvDd42qcpj NmmlTJI31UfoFkrE
LSYL1IFAmwSQtzbzurRRIW9LyxjxQiCPQDF5S7kwzwu5jbNb5FXye96OH9oT lDdVHrv5bovU54du
m5T+sYnv832xsVEPAhBYLgHkbbm5ayly5K2lbDIWCMgEismb3BU1IBBP4PaD e4OfeVPlbBCAAARW
SQB5WyV9+tYEkDfmAgT6IlBM3lpcSZpyKvTAK2eMRw/sGw7v9++qnA0CEIDA Kgkgb6ukT9/IG3MA
An0SKCZvfeJj1BCAAAQg0CsB5K3XzNc1blbe6soH0UBgagLF5C1nlWXqQdbY PrxqzAoxQQACEIgn
gLzFs6LmdASQt+nY0jIEaiSAvK0oKz3IW8kxlmxrRSmnWwhAoDECyFtjCV3o cJC3hSaOsCEwkkAx
eRvZP6dBAAIQgAAEFkkAeVtk2poLGnlrLqUMCAJBAsXkjZWRtJnWA6+SYyzZ VlqmqA0BCEDATQB5
Y2bUQAB5qyELxACB+QgUk7f5QqYnCEAAAhCAwOoJIG+rzwERDAPyxiyAQF8E iskbKyNpE6cHXiXH
mNPW+g/vHEK7ytz3/n/+TVoCqQ0BCHRPAHnrfgpUAQB5qyINBAGB2QgUk7fZ IqYjCCQSeMvJm4eN
zSvO/eMfeWSrNSVvu/9f/zSx5WHYsWNH8By7XKofasx1rjqm99TgpVik8tT+ qA+B1gggb61ldJnj
Qd6WmTeihsBYAsXkLWdlZGzwSz6vB14lx5jT1htfd8sLxO27f/Rdg9pfdvz+ 4eU/cGJL3sYKXIpw
5QiRJII5bbvGULq9Jb9eiR0CLgJzyJt+k+bx8tbtgewwYA4wB5gD1+aAujbe oZ+sX7g0qJ0NAi0Q
OHX01uGZjae29o3N7ftHf+Xt0StvrlUuLThmmSk99jm+NlyrZzHnmvnxyZZ0 PDb2FuYCY4BASQJz
yFvJeGmrTQKsvLWZV0YFAR8BVt5WNDdyVpJWFHJytyXHqNuKfTSDfd1r/8nw g//Hbc5dlalN+syb
b9XLlDeXSKWulvnaU22HVsLGlKXGnjwBOAECjRNA3hpP8EKGh7wtJFGECYFC BIrJW6F4aAYCVRKw
V6ds8ZHkTg/KVc+18uVbiXPBGXt7I/JW5VQjqAURQN4WlKyGQ0XeGk4uQ4OA g0AxeSu5ytJDpnrg
VesY/x+33Zk8xWJuPSyx8mYHZkqcK4ax4mau5MWKZzI0ToBA4wSQt8YTvJDh IW8LSRRhQqAQgWLy
VigemoHApASUuJWQt5Irby7pGyOCPnClxHPSxNA4BBZIAHlbYNIaDBl5azCp DAkCAQLF5K3WVZZa
s98Dr1rHOEbe9EqVfTujdOuheZ6ei642Yo7Zbflu5bTn/Fh5c8Ve6+uJuCCw CgLI2yqo06dNAHlj
TkCgLwLF5K0vbIx2yQTGytuSx0zsEIBAeQLIW3mmtJhOAHlLZ8YZEFgygWLy VusqS63J6YFXjWPU
t00icLW+MogLAsshgLwtJ1ctR4q8tZxdxgaBFxIoJm/AhQAEIAABCPREAHnr Kdv1jhV5qzc3RAaB
KQgUk7caV1mmAFaqzR549TDGUvOBdiAAgeURQN6Wl7MWI0beWswqY4KAnwDy tqLZ0YPY9DDGFU0f
uoUABCoggLxVkARCGJA3JgEE+iJQTN76wsZoIQABCECgdwLIW+8zoI7xI291 5IEoIDAXgWLyxipL
Wsp64JUzxvV7bhqkPY04tSEAAQiUJYC8leVJa+MIIG/juHEWBJZKoJi8LRUA cddJQInbxuYV767K
2SAAAQiskgDytkr69K0JIG/MBQj0RaCYvOWssvSF/NpoW+SlxiTtsbl+5O6d QXlT5Tmb74urc9rk
XAhAoC8CyFtf+a51tMhbrZkhLghMQ6CYvE0THq0uiYAkpFK5OdYH79o5PLPx 1Na+sfn8rp9ffVTl
sZsSNXNX55WUN7vt2LioBwEILJvAHPKm36R5vLz1jznYYcAcYA4wB67NAXVd vUM/Wb9waVB7ypZy
YZ7Sbqt1W+Rlj8kWpJQxP3DnzcOjDx0Zznt2VR6z+SStlLzZ7ZRqN2Zs1IEA BFZLYA55W+0I6X0J
BFh5W0KWiBEC5Qiw8laOZfctlZS3+068OHjbpCqXtpBImWW+lTPXcWmVDXmT skI5BNohgLy1k8sl
jwR5W3L2iB0C6QSKyVvKqkp6mO2d0SIvPSb7NkUtNLrc92hm+d47bgnKmyqX tlh5M9vR57jOldpD
3KSMUA6Btgggb23lc6mjQd6WmjnihsA4AsXkbVz3nNUSgZIrb2eO7Qp+5k2V S5skW/p832fiXLdE
SoImlUsxUw4BCCyHAPK2nFy1HCny1nJ2GRsEXkigmLy1uJI05YRpkVdJeTt1 ZPewdu70sHbWvaty
aYuRN+kza1rs7NW5qT9LJ42NcghAYPUEkLfV54AIhq1/XMAGAQj0Q6CYvPWD jJH6CEhCKpWb7Z48
fGvwtklVHrNJkiXJm+ojdAtlzPkxcVIHAhBYHgHkbXk5azFi5K3FrDImCPgJ FJO3lAtzEsL3vElz
4PihPUF5U+Wxm++2SH1+6LbJsf/YJDY26kEAAsslgLwtN3ctRY68tZRNxgIB mUAxeZO7ogYE4gnc
fnBv8DNvqpwNAhCAwCoJIG+rpE/fmgDyxlyAQF8EiskbK29pE6cHXjljPHpg 33B4v39X5WwQgAAE
VkkAeVslffpG3pgDEOiTQDF56xMfo4YABCAAgV4JIG+9Zr6ucbPyVlc+iAYC UxMoJm85qyxTD7LG
9uFVY1aICQIQgEA8AeQtnhU1pyOAvE3HlpYhUCMB5G1FWelB3noY44qmD91C AAIVEEDeKkgCIfBV
AcwBCHRGoJi8dcaN4UIAAhCAQOcEkLfOJ0Alw2flrZJEEAYEZiJQTN5YZUnL WA+8csa4fs9Ng7Sn
Eac2BCAAgbIEkLeyPGltHAHkbRw3zoLAUgkUk7elAiDuOgkocdvYvOLdVTkb BCAAgVUSQN5WSZ++
NQHkjbkAgb4IFJO3nFWWvpBfG22LvNSYpD0214/cvTMob6qcDQIQgMAqCcwh b/pNmsfLW5/tYocB
c4A5wBy4NgfUNfcO/WT9wqVB7WwQSCEgCalUbvb14F07g1/Srcpjth07dgx6 j6kfW8dsVz2P2WLr
xbRFHQhAYPUE5pC31Y+SCGonwMpb7RkiPgiUJcDKW1me0a2liEx0oyuuaI/J lpWUMT9w583Dow8d
Gc57dlWespUWJ7u9mPZj6qSMiboQgMBqCSBvq+VP79cIIG/MBAj0RaCYvPWF jdG6CJSUt/tOvDh4
26QqT9lMcXKtxoVkLKa+iiWmD3sVcKqVwRQ21IUABMYRQN7GceOssgSQt7I8 aQ0CtRMoJm8pqyq1
Q5kjvhZ56THZtxRqqdHlvkeT+7133BKUN1WesvlWvfTx2JU0X31b3szYYvtg ZS4lo9SFwOoJIG+r
zwERsPLGHIBAbwSKyVtv4BjvCwmUXHk7c2xX8DNvqjxl862K2cddEub6fJtL tKQ+XII45rNzKeOm
LgQgMB0B5G06trQcT4CVt3hW1IRACwSKyVuLK0lTJrhFXiXl7dSR3cPaudPD 2ln3rspTtpjVL1cd
34pcSN5iz2GlLSWD1IVAfQSQt/py0mNEyFuPWWfMPRMoJm89Q2Ts1whIQiqV mxxPHr41eNukKk/Z
YuRNtSfdPhnTzlh5Q+ZSMkpdCKyeAPK2+hwQAbdNMgcg0BuBYvKWcmHeG2TX eFvkJX3HW8qYjx/a
E5Q3VS5tvn8GErpV0beiZrcl3e7oK9fHdey+GKWxUQ4BCKyeAPK2+hwQAfLG HIBAbwSKyVtv4Bjv
tARuP7g3+Jk3Vc4GAQhAYJUEkLdV0qdvTYDbJpkLEOiLQDF5S1lV6Quxe7Tw Cs+Cowf2DYf3+3dV
zgYBCEBglQSQt1XSp2/kjTkAgT4JFJO3PvExaghAAAIQ6JUA8tZr5usaNytv deWDaCAwNYFi8sZK
Ulqq4JXGi9oQgAAEaiOAvNWWkT7jQd76zDuj7pcA8rai3CNvKwJPtxCAAAQK EUDeCoGkmSwCyFsW
Pk6GwOIIFJO3xY2cgCEAAQhAAAIZBJC3DHicWowA8lYMJQ1BYBEEiskbK0lp +YZXGi9qQwACEKiN
APJWW0b6jAd56zPvjLpfAsXkrV+Eqx/5v/yH/3b1QRABBCAAgc4IzCFv+k2a x8sDDGDAHGAOMAdu
zAG1ELRDAVFP1i9c2tpTNlaSwrRKfoH1+Vd/eFh/5WPX99d919ltP6tytnYJ uL5IvN3RMjII1Etg
Dnmrd/REVgsBVt5qyQRxQGAeAqy8zcN5S4pDm1RunvvIKz40PHbPk8Pj5z4+ vOfIR4f1Vz227WdV
Lm1KAOzdPEeXSe2o8lA7dpux7el2x5xv9yGNNSamUnViWYX6Q95KZYN2IJBH AHnL48fZZQggb2U4
0goElkKgmLylyMdS4JSM0+ZjX4Cn8Hvryz+4JW5Pvu0zw8W7Pja88aXnt/2s yqVNEoBUeSshWS7p
ksaRUi6NOaWtsXXtGMbENOacsfFyHgQg4CeAvDE7aiCAvNWQBWKAwHwEisnb fCEvs6eS8nb/y969
teKmxO3CgY8MR245te1nVS5tIQEwy2JEwSck+rjr0ZRDWxTN+nY9Na6QAJkr W5IMhuL2tZN6PCWG
2LZ9+Yk53z43RdKlOUU5BHojgLz1lvE6x4u81ZkXooLAVASKyVvKytFUg6m5 Xc3HdwufLvc96rGp
f06iPuOmVtvUrsRN7/qYKpf+iUno9r2S8uZqKyQfppxJUqiZ2HJoH0/9Obff 0DyMXXnzjSnEx+xX
YhIbR82vKWKDwKoJIG+rzgD9KwLIG/MAAn0RKCZvfWFLH23JlTclaeZn3pS8 mT+rcmkrvfLmWvWJ
kaCQ3EkrbKbI6OexUhoSv9gVOXuFUGLuitEWLpujK0++1TLX2FPHEjMG6kAA AtcIIG/MhBoIIG81
ZIEYIDAfgWLyxspbOGkl5e31L3k4+Jk3VS5tPnlzrQyGRM8WKFtGXD/nrryZ faasEvpEyCWBUtwu
vjG3IIa4x/bpWlWLEWUfN2muUA4BCLgJIG/MjBoIIG81ZIEYIDAfgWLyNl/I y+xJklup3Bz1qX33
b/uMm1ppMz8Dp8qlLVYiQnKm+4htS5IOu1y6tS+33Bd/qgiFhNXOQw4rV7wu piFJk+pL84ZyCEDg
BgHkjdlQAwHkrYYsEAME5iNQTN5S5GO+4dXTU8nveXvHax4flKDpXX3GzfxZ lUuba4XNJ2qrWnnT
8aQIh33bYYxYuWTN147reKjPWHkzx2qv4Nntx94KacpebtzSfKIcAj0SQN56 zHp9Y0be6ssJEUFg
SgLF5G3KIGk7TED65yTw8xMI3UrZIjdJxFscM2OCwFQEkLepyNJuCgHkLYUW dSGwfALF5I2Vt+VP
BmkErtW6pcvAVPJWE6uUlUFpDlAOAQjcIIC8MRtqIIC81ZAFYoDAfASKydt8 IdMTBCAAAQhAYPUE
kLfV54AI+KoA5gAEeiNQTN5Yeett6jBeCEAAAn0TQN76zn8to2flrZZMEAcE 5iGAvM3DmV4gAAEI
QKAxAshbYwld6HCQt4UmjrAhMJJAMXkb2f/woZ/aG9zHtst5EIAABCAAgSkJ IG9T0qXtWALIWywp
6kGgDQLF5G3sbZNK3jaf/bZz//TFf7cldmwQgAAEIACB2gjMIW/6TZrHywMM YMAcYA4wB27MAeVe
OxQQ9WT9wqWtfY7t/T/5T4ZnNp9z7n/4kXuGzyBwc6SBPiAAAQhAIJHAHPKW GBLVOyTAyluHSWfI
XRMYvfJW6kunP/1bbx++tfHcoL6rTD2a+9OXf3JQAvfpi4eG97zptlGJGvOv 7O0vSR7VceRJUnxS
eWQ33mpTtx8TXw0xhOKccz6sgpfE3/el4DGxUgcCLRNA3lrO7nLGhrwtJ1dE CoESBLLkLRRAzG2U
51/94WH9lY9t7a/7rrPXn6vj3/jWc9f3//bfnxsu/PhLRo239gvT1PhiIUjt 6nZi68X2O6aejqGG
WOz4e4hJGqNP3lzfZTcm/5wDgaUSQN6Wmrm24kbe2sono4GARGCl8vbWl39w ePJtnxku3vWx4Y0v
PX/9uTr+9avydn3/5nPDz73hn0pjcZaPvTAd1dmIk1LjG9FF8BSp/9L9udqr IQbfOGuMrXRMUnsh
eZtjftAHBGolgLzVmpm+4kLe+so3o4XASuXt/pe9e0vcLhz4yHDkllPXn6vj X/nGs9v29bMvFSXE
XAnQlc0LT1+5eVtcTB3Vtr1aZJ/nutUudPuZvYphx596rhmfa0zmGMy+7Lhd q2K+WO0Ehfq1mdtM
Y8/V57l4x8Qj5c0Xh9l2bqwSY7svX758c046HvMa8b2eQtLrmkup8yv0op+T O28VEHARQN6YFzUQ
QN5qyAIxQGA+AtnyZl/I6wtBfduk71F9xk3dKqlW3JS4qV09V7s6rsq/9PXN 6/uDa98typvrIteW
nhQp8gmOKQzSRa19YRy6EA/F75M36bgkfa74XSIl1XOJUmw+XCKceq4vPilu X35cQuWagBJ/X77H
MpbitduN4egbq08qTaYugXK95kKcYl8jsSxT5uKYvuf79UxPtRNA3mrPUB/x IW995JlRQkATyJY3
H8qYz7y9/iUPO2+bVMe/+NXN6/tfXH3+5h/5Z8GsxVxE26IZkrOUi367ndAF 4RLlLeai2XXBHMPb
JRuxF/r6XFc/Y+Jx5c0n/z6BCUlfzByVxjS1vEk5i5nbqfJmz69S+RzzGo7p m7cPCJhvoOp56r+u
Vu+Pt9122/X/7Kx+Ntswf4Y2BCQCyJtEiHIItEVgpfJ2at/912+VVCtu+hZK dfzPvry5bf+JH/7n
WfKWcuEcIytjV7R6kjdXwkIX9tIKkC1MLvn2TRKfhEkyFCNvqeO0pSI0l1wS 6pKSGPGU+I5lFIpx
jEDF/IqNiXWqvmPio04fBFh56yPPtY8Seas9Q8QHgbIEVipv73jN44MSNbWr WyX1c3X881/a2Lb/
2A/9i8XLW6zwmVKSesFt14/ts4TchlZlYlakpLG6xLfk+GIEyBbGWG4u0Ywd rySYvphiY5PiiOk/
9AePqcfuer3k/gEm5Q8DZX8l09qSCCBvS8pWu7Eib+3mlpFBwEUgS96k73qL Qf5rj79v+JO/2tj6
jJt6dO1//Jcbw5k7Xy7Km3nLk+uv7r5bovRx3wWb1G7ogj72wjcUmzkWXyz2 8ZQLclf7Ln4xcdgX
zSZbXz8u4ZTGGduPVE/Kj2uFxyVFMePU88Su6+tDqifF7uvPPm634+s3NG7X ObHH7Be2K/c+AZyD
e8zvMer0SQB56zPvtY0aeastI8QDgWkJjJa3UmGdOvE9w+f+4hlx/5Hj3yPK W6mY5mjHtyqS27dL
BFxtxtaT4inVji1ZUr89lk/BOoXjqvtPiZW6EJiDAPI2B2X6kAggbxIhyiHQ FoGVy9vdr/ve4e7j
an/F8EOve8X15zd+vnpM1blaFtqWdmFZUt58KxVT8RrTX8rLZmm5TBlbTt1V c1l1/znsOBcCUxBA
3qagSpupBJC3VGLUh8CyCaxc3paNj+ghAAEIQKBXAshbr5mva9zIW135IBoI TE0AeZuaMO1DAAIQ
gECTBJC3JtO6uEEhb4tLGQFDIItAlfIW8x1xWaPmZAhAAAIQgEAmAeQtEyCn FyGAvBXBSCMQWAyB
KuVtMfQIFAIQgAAEuiUwh7ylfgE49S8nf2k6zGDGHGAOLHEOqMWuHSpw9WT9 wqWtfVUbK2+rIk+/
EIAABCAQS2AOeYuNhXr9EmDlrd/cM/I+CTS/8qa+P44NAhCAAAQgUJoA8laa KO2NIYC8jaHGORBY
LoEq5E36su+Ulbjzr/7wsP7Kx67vr/uus9t+VuVsEIAABCAAgVwCyFsuQc4v QQB5K0GRNiCwHALV
yFsIWYq8PfKKDw2P3fPk8Pi5jw/vOfLRYf1Vj237WZWzQQACEIAABHIJIG+5 BDm/BAHkrQRF2oDA
cgg0J29vffkHt8Ttybd9Zrh418eGN770/LafVTkbBCAAAQhAIJcA8pZLkPNL EEDeSlCkDQgsh0Bz
8nb/y969teKmxO3CgY8MR245te1nVR6z7dixY9C7Wd913HdMnafK9OZrMyYe 6kAAAhCAQF0EkLe6
8tFrNMhbr5ln3L0SqEreTLkxxUnfNul71MlT/5xEfcZNrbapXYmb3vUxVS79 ExNTuEwBs4/bcmbX
tcXNlsBeJx3jhgAEINACAeSthSwufwzI2/JzyAggkEKgKnnzBZ7ymTclaeZn 3pS8mT+rcmnzSWSq
vNmyZrcrxUE5BCAAAQjUSwB5qzc3PUWGvPWUbcYKgeH6d1mu9HveJDmTys1E vv4lDwc/86bKpc0l
aeqcXHmT+qUcAhCAAASWQwB5W06uWo4UeWs5u4wNAi8k0NzK26l992/7jJta aTM/A6fKpa3UbZNm
P742pVgohwAEIACBOgkgb3XmpbeokLfeMs54eydQjbxJ3/UWm6h3vObxQQma 3tVn3MyfVXnMVuof
ltgC5/onKDHxUAcCEIAABOoigLzVlY9eo0Hees084+6VQBXyNiV86Z+TTNk3 bUMAAhCAQLsEkLd2
c7ukkSFvS8oWsUIgn0Dz8paPiBYgAAEIQAACLySAvDEraiCAvNWQBWKAwHwE kLf5WNMTBCAAAQg0
RAB5ayiZCx4K8rbg5BE6BEYQQN5GQOMUCEAAAhCAAPLGHKiBAPJWQxaIAQLz EWhe3lK+ZmA+7PQE
AQhAAAJLJzCHvOk3aR4vX/9uI1jAgjnAHGAOXB5W+j1vS38DJ34IQAACEOiP wBzy1h9VRpxKgJW3
VGLUh8CyCbDyFsjf+j03DdK+7PQTPQQgAAEIjCWAvI0lx3klCSBvJWnSFgTq J9C8vOWkQInbxuYV
767K2SAAAQhAoE8CyFufea9t1MhbbRkhHghMS6A5eZO+7DvlM3CP3L0zKG+q vKZNfQE42zwEYD0P
Z3qBQM0EkLeas9NPbMhbP7lmpBBQBJqUt1BqU+Ttwbt2Ds9sPLW1b2w+v+vn Vx9VubSpi3x7N8/R
Zfax0M92n1okUoUitb40Vqk8xMLFqGR8JdtS4zSZh/IrMdHlpeOL7Zd6EIDA eALI23h2nFmOAPJW
jiUtQWAJBJqXN/uiOEXeHrjz5uHRh44M5z27Kpc26aK8hLyNFQApNmlsqf36 +ks9HhtXigCntjlW
mH39lMpF6jioDwEIjCeAvI1nx5nlCCBv5VjSEgSWQAB5C2TpvhMvDt42qcql LXRRbpbZz02pM1d2
VH+2OPhWgXxy5apv1nUJZcw4JQFJlbTYcbvG6TrXZuqSO5eU2W25cuDi4zpP n2sz9o3VHltsfFK+
KIcABPIJIG/5DGkhnwDyls+QFiCwJALNypt9K5u+6NUrb75HM3n33nFLUN5U ubSFbqkLyZtLLGzB
8l3Y5x73SZ80VlNMJJmxRS4kSNK4pfGasuUbmy20vrG6xNmVY9f4fExy4ovt JyZ31IEABNIIIG9p
vKg9DQHkbRqutAqBWgk0K2++i/SU2ybPHNsV/MybKpe2sStvkry5yn0X8inH Q7JpytmYVTbpHEnC
JFFxrUpJsib1aY/ZJW8xomqLeuxKmxSf748U0rykHAIQyCeAvOUzpIV8Ashb PkNagMCSCCBvgWyd
OrJ7WDt3elg7695VubT5hMV10e2Tj7HSIrUntSuNLSQtvrKYNqW4JSFzMZfG mtpnSBS18MUwGNuv
j0EMX+pAAAJlCCBvZTjSSh4B5C2PH2dDYGkEmpc3OyEpK28nD98avG1SlUtb SN7sc1Mv5O0L+JQV
NpdgSIITGquWUamOxMuMS4ondrwpY43tM1XepNym9isJbAxn6kAAAnkEkLc8 fpxdhgDyVoYjrUBg
KQSalDfpu95ik3P80J6gvKlyafPd1iatDtkyZP4ckhb7djzzIt9V5uvHJ52u 8cbWDbGQ4nYJmD4W
GpcZW2isIRmz4w4JpslHGlMox76x+eZNjDxLc5VyCEAgjQDylsaL2tMQQN6m 4UqrEKiVQHPyVhL0
7Qf3Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5S7lN0kZ99MC+ 4fB+/67K2SAAAQhA
oE8CyFufea9t1MhbbRkhHghMS6B5eZsWH61DAAIQgECvBJC3XjNf17iRt7ry QTQQmJoA8jY1YdqH
AAQgAIEmCcwhb/pNmsfLAwxgwBxgDjAHbswBdXfhDgVEPVm/cGlrb2HLuW2y hfEzBghAAAIQmIbA
HPI2TeS02hIBVt5ayiZjgYBMgJU3mRE1IAABCEAAAi8ggLwxKWoggLzVkAVi gMB8BJqXt5yVt/V7
bhqkfb5U0RMEIAABCNREAHmrKRv9xoK89Zt7Rt4ngeblLSetStw2Nq94d1XO BgEIQAACfRJA3vrM
e22jRt5qywjxQGBaAs3Jm/QF3SkrcY/cvTMob6qcbXkEpC8Vzy1fHhEihgAE xhBA3sZQ45zSBJC3
0kRpDwJ1E2hS3kLIU+Ttwbt2Br+kW5VLmxIBezfP0WVSO2PKJQnRbdr1Ys8b E1PMOT5mLlZj+Enj
0+WhOGLGUaqOFG+pfmgHAhBII4C8pfGi9jQEkLdpuNIqBGol0Ly82Re+KfL2 wJ03D48+dGQ479lV
ubRJF95j5EPq0ydlvvOkGGP7k+rF9uOrtwp5c40pdhwSj9jyufuLjYt6EOid APLW+wyoY/zIWx15
IAoIzEUAeQuQvu/Ei4O3TapyaQtdeJtl9nNz1ceUMddxVS7Vd7XhO+aLJSaO GB6SjITkTY/V9ejj
YB+PGZ/Zvj2mmPNN0QxJZ2reJb6UQwAC8xFA3uZjTU9+AsgbswMCfRFoVt58 t7zplTffo5n+e++4
JShvqlza7DjM+iF5c9Wzpca8vS+mvk9CctuVZMzFKLTi6GNmj9f3symZLgmL 5RYbR6g/V45zeUtz
jnIIQGAeAsjbPJzpJUwAeWOGQKAvAs3Km31BrX9OuW3yzLFdwc+8qXJpG7vy FiNjsRJit2Wv0uXK
hGuMvhVCn0D6pDZFdseMwyVoPq4uSQudb4uj2a50nnnuGDmW5iXlEIBAPgHk LZ8hLeQTQN7yGdIC
BJZEAHkLZOvUkd3D2rnTw9pZ967Kpc134e1aGUyVsbH1XRJSQhYlFi6JdJ0T YuaS8rEcpH5yy0Py
FjNuSSJTeFMXAhAoTwB5K8+UFtMJIG/pzDgDAksm0Ly82clJWXk7efjW4G2T qlzaJAEoIU2pK06r
lLfQ7ZIuMXPxsZmXkjfpNswx3LhtUnqFUA6B5RJA3pabu5YiR95ayiZjgYBM oEl5k77rTcZyrcbx
Q3uC8qbKpc21wqbO8d1q6CqT5ESf4xIj+5jrdj3zfLt/1+2PPlmMYSHVscdi xh8jwq54XW2aIuZi
FBuHxMclb758hbjGSG8MW+pAAALlCCBv5VjS0ngCyNt4dpwJgSUSaE7eSibh 9oN7g595U+VsEIAA
BCDQJwHkrc+81zZq5K22jBAPBKYl0Ly8pdwmaaM+emDfcHi/f1flbBCAAAQg 0CcB5K3PvNc2auSt
towQDwSmJdC8vE2Lj9YhAAEIQKBXAnPIm36T5vHyAAMYMAeYA8yBG3NALVDt UEDUk/ULl7Z2NghA
AAIQgAAE3ATmkDfYQ0AiwMqbRIhyCLRFoPmVt5zbJttKNaOBAAQgAIGSBJC3 kjRpaywB5G0sOc6D
wDIJNC9vy0wLUUMAAhCAQO0EkLfaM9RHfMhbH3lmlBDQBJqXt5yVt/V7bhqk nakEAQhAAAJ9EkDe
+sx7baNG3mrLCPFAYFoCzctbDj4lbhubV7y7KmeDAAQgAIE+CSBvfea9tlEj b7VlhHggMC2B5uRN
+oLulJW4R+7eGZQ3VT7F5vsy6in6mqrNKcbAF1VPlS3ahQAExhBA3sZQ45zS BJC30kRpDwJ1E2hS
3kLIU+Ttwbt2Br+kW5VLmxYO89E8xy5XZVOIjxRnqHyVY9AsbCa1Mcrhy7kQ gMAyCSBvy8xba1Ej
b61llPFAIEygeXmzL/JT5O2BO28eHn3oyHDes6tyaQtJhq9sLjGJ7aeGMcTG KuWDcghAAAKlCCBv
pUjSTg4B5C2HHudCYHkEkLdAzu478eLgbZOqXNrGCJp5TsyKnY7BVzdmVU2q 4yqPlbqcMZgrb+Zt
kxIj34qdlC/KIQABCMQSQN5iSVFvSgLI25R0aRsC9RFoVt58t/rplTffo5mi e++4JShvqlzaXLdF
qnNixcdsPyQkuStToc+TrXIM0m2TvtspQ+ORckY5BCAAgRgCyFsMJepMTQB5 m5ow7UOgLgLNypvG
nHPb5Jlju4KfeVPl0lZy5c1ehbLFThLCGKFxtbHKMcTIm0suc2VWyivlEIAA BJA35kANBJC3GrJA
DBCYjwDyFmB96sjuYe3c6WHtrHtX5dKWIz6+VSVTTF11xoiLtPLmGqcki+qc 3DHEyFtqbFLOKIcA
BCAQQwB5i6FEnakJIG9TE6Z9CNRFoHl5s3Gn/MOSk4dvDd42qcqlLUZw7DYk YTHrp6yU+SRHkr1V
jkFiEbptUsoN5RCAAARyCCBvOfQ4txQB5K0USdqBwDIINClv0ne9xabm+KE9 QXlT5dJm39LnWykz
V77MOr5bAu2VMrOeFJMul6TNrOeKw1eujpcagyRvui8Xj1gO1IMABCAwhgDy NoYa55QmgLyVJkp7
EKibQHPyVhL37Qf3Bj/zpsrZIAABCECgTwLIW595r23UyFttGSEeCExLoHl5 S7lN0kZ99MC+4fB+
/67K2SAAAQhAoE8Cc8ibfpPm8fIAAxgwB5gDzIEbc0A5zg4FRD1Zv3Bpa2eD AAQgAAEIQMBNYA55
gz0EJAKsvEmEKIdAWwSaX3lrK12MBgIQgAAEaiGAvNWSib7jQN76zj+j749A 8/KWc9tkf9OBEUMA
AhCAQCwB5C2WFPWmJIC8TUmXtiFQH4Hm5a0+5EQEAQhAAAItEEDeWsji8seA vC0/h4wAAikEmpe3
nJW39XtuGqQ9BTZ1IQABCECgHQLIWzu5XPJIkLclZ4/YIZBOoHl5S0dy4wwl bhubV7y7KmeDAAQg
AIE+CSBvfea9tlEjb7VlhHggMC2B5uRN+oLulJW4R+7eGZQ3VT7FFvvl2Sl9 219inXJuy3Ul1lJ5
y2wYGwQgECaAvDFDaiCAvNWQBWKAwHwEmpS3EL4UeXvwrp3BL+lW5dKmpcl8 NM+xy1VZKWHQ7djt
lWpfGrtd7mPhEsu5YjQZTZmLWFZzjTs2HupBAAJ+Asgbs6MGAshbDVkgBgjM R6B5ebMvhlPk7YE7
bx4efejIcN6zq3JpC12M+8pKX8CXbs8lZRKHkJTWIm+uMUzNbizLGN7UgQAE piWAvE3Ll9bjCCBv
cZyoBYFWCCBvgUzed+LFwdsmVbm0jRE085yYFTsdg13XtapkS5Srfd+KXWis MbdlSizscfvGpcdg
9ukTQOm4NFYpFy7mrpVOOw7XKp9rXNL8ohwCEFgdAeRtdezp+QYB5I3ZAIG+ CDQrb75b9PTKm+/R
TP+9d9wSlDdVLm2hi3TfuSmSYwqO3Z5PTGKOj11xCkmcxMInb+a4XLG7znMJ lC2u5s8psdnnuXIQ
w1galzS3KIcABFZLAHlbLX96v0YAeWMmQKAvAs3Km09qUm6bPHNsV/Azb6pc 2iQRc53vW+2xV9Ls
i/9cYZFWobS0jF1li2HhkzPXCpckTS4hi2Vkt+37Y4BPOO1cheL3yaA0tyiH AARWSwB5Wy1/ekfe
mAMQ6JEA8hbI+qkju4e1c6eHtbPuXZVLW4yw2G1IqzamWLhkxD5/rLBIY/OJ Z+qYQytnMbHHrLz5
ZF4S1thyU8BiZCxmXGP4cw4EIDAfAeRtPtb05CfAyhuzAwJ9EWhe3ux0pqy8 nTx8a/C2SVUubT6R
sS/2zXZi5c3Xxlh5k0QlNNaxq3GuMZhtxUhOjLxJTCXhXHUc0jyjHAIQmJ8A 8jY/c3p8IQHkjVkB
gb4INClv0ne9xab4+KE9QXlT5dLmu91Onyfd2ucrt2XJvi3PlCKfeOg6rrak cblkUzrHxyK0emjH
6JIwl7z5xhZqLyUXZv5inkuM7TGEpF/iTDkEIDAPAeRtHs70EiaAvDFDINAX gebkrWT6bj+4N/iZ
N1XOBgEIQAACfRKYQ970mzSPl7f+MQc7DJgDzAHmwLU5oBardugn6xcuDWpv YUu5TdIe79ED+4bD
+/27KmeDAAQgAIE+Ccwhb32SZdQpBFh5S6FFXQgsnwArb8vPISOAAAQgAIEV EEDeVgCdLl9AAHlj
UkCgLwLIW1/5ZrQQgAAEIFCIAPJWCCTNZBFA3rLwcTIEFkegeXnLuW1ycdkk YAhAAAIQmI0A8jYb
ajoKEEDemB4Q6ItA8/LWVzoZLQQgAAEIzEUAeZuLNP2ECCBvzA8I9EWgeXnL WXlbv+emQdr7mi6M
FgIQgAAENAHkjblQAwHkrYYsEAME5iPQvLzloFTitrF5xburcjYIQAACEOiT APLWZ95rGzXyVltG
iAcC0xJoTt6kL+hOWYl75O6dQXlT5WzzEpjiy6vtL9Ced0T0BgEILJUA8rbU zLUVN/LWVj4ZDQQk
Ak3KW2jQKfL24F07g1/SrcqlTYuB+ajOsY9L7ehzYuuNaT+m7ZJ1fGx0H64x lJI33Y7dXqn2S3Ki
LQhAoE4CyFudeektKuStt4wz3t4JNC9v9sV4irw9cOfNw6MPHRnOe3ZVLm0+ GRgjDalikVpfGkts
eWy/oXqx3GJj8tWLjTW3H86HAATaI4C8tZfTJY4IeVti1ogZAuMJIG8Bdved eHHwtklVLm0pEmLW
tVfqVD+xx3RMkiCaq0+utn19SmM2zwvVTWHjGlNKzK6VT9f4YnKgz4vhQB0I QKBdAshbu7ld0siQ
tyVli1ghkE+gWXnz3ZKnV958jybSe++4JShvqlzafLcvusRFkhlplShW1mwR 8p0ntSeNXZK4FDY+
IZXG4hMt6bbJEBMpDzFcqAMBCCyfAPK2/By2MALkrYUsMgYIxBNoVt58F/sp t02eObYr+Jk3VS5t
kpCZ5/tWfXyiYcqRFiFfeyHJkUTFt8Jl9x9iMUZWXe3FMHKNJ1VQffKPuEkz nnII9EMAeesn1zWP
FHmrOTvEBoHyBJC3ANNTR3YPa+dOD2tn3bsql7Yx8pYqGj5RDQmTLUEu6Ssh Ki6p9MUrHdeyaD6G
xh6SuNSVt5jYpLlAOQQg0BYB5K2tfC51NMjbUjNH3BAYR6B5ebOxpKy8nTx8 a/C2SVUubbHyNkam
pNsax/SdIkihsYekLUaEpNilsbsEzzW2VFEuIbTSnKEcAhBYBgHkbRl5aj1K 5K31DDM+CGwn0KS8
Sd/1FjsJjh/aE5Q3VS5todvvYm9HdN0qaAqQrx1JgGLbiBExk0Os4PjYhOKK vW3SV88Wx5AEurjG
jk2aF5RDAALLJzCHvOk3aR4vDzCAAXOAOcAcuDEHlO/sUEDUk/ULl7b23rfb D+4NfuZNlS9tC91K
ubSxEC8EIACBVRKYQ95WOT76XgYBVt6WkSeihEApAs2tvNlgUm6TtM89emDf cHi/f1flS9uQt6Vl
jHghAIFaCSBvtWamr7iQt77yzWgh0Ly8kWIIQAACEIDAFASQtymo0mYqAeQt lRj1IbBsAsjbsvNH
9BCAAAQgsCICyNuKwNPtNgLIGxMCAn0RaF7ecm6b7GsqMFoIQAACEEghgLyl 0KLuVASQt6nI0i4E
6iTQvLzViZ2oIAABCEBg6QSQt6VnsI34kbc28sgoIBBLoHl5y1l5W7/npkHa Y0FTDwIQgAAE2iKA
vLWVz6WOBnlbauaIGwLjCDQvb+OwXDtLidvG5hXvrsrZIAABCECgTwLIW595 r23UyFttGSEeCExL
oDl5k76gO2Ul7pG7dwblTZWzQQACEIBAnwSQtz7zXtuokbfaMkI8EJiWQJPy FkKWIm8P3rUz+CXd
qlza1Peq2bs6x3dcam9V5bHjiInP9V1zrvOWxihm7NSBAATaIYC8tZPLJY8E eVty9ogdAukEmpc3
WxRS5O2BO28eHn3oyHDes6tyafOJSqzASO3nlsfGETuOmPZi6pjjSq2fy4Tz IQABCMQQQN5iKFFn
agLI29SEaR8CdRFA3gL5uO/Ei4O3TapyaYuVHt2Oa5VOldnt6J/N+rpequzo NkJjSRmHWdeOz4xR
qmcyCcmci4WLV8w4pXxSDgEIQEATQN6YCzUQQN5qyAIxQGA+As3Km++WO73y 5ns00d97xy1BeVPl
0haSMZ/YuEQlJG8uyUkVOEn8YqXSJZp2fFJsvrFKMhfDKBSflEvKIQABCJgE kDfmQw0EkLcaskAM
EJiPQLPy5rvQT7lt8syxXcHPvKlyaUtZsXKJhbmqJEmdvZJlx+aSRVf8rphT xuFbUfONxRRH1+pY
KJ7QmH0rcpI8SjmlHAIQgIAigLwxD2oggLzVkAVigMB8BJC3AOtTR3YPa+dO D2tn3bsql7YU6Zla
3mJizY3XHMPYlTBp5c3XR2x/EgfKIQABCMQQQN5iKFFnagLI29SEaR8CdRFo Xt5s3CkrbycP3xq8
bVKVS1uuDJVcefPFGvNZsNhxxK6EmbFIsjam7xiJlHJHOQQgAIEQgTnkTb9J 83h5a6WTHQbMAeYA
c+DaHFBOs0M/Wb9waVD7EreS3/N2/NCeoLypcmmzPysm3coXEhnX5858shR7 a2BKPV//odsxXedo
sZJur9RsU+TNF0soRimHlEMAAhBwEZhD3iAPAYkAK28SIcoh0BaB5lbeSqbn 9oN7g595U+VsqyEQ
+hzcaiKiVwhAoDcCyFtvGa9zvMhbnXkhKghMRaB5eUu5TdKGfPTAvuHwfv+u ytlWQwB5Ww13eoUA
BG4QQN6YDTUQQN5qyAIxQGA+As3L23wo6QkCEIAABHoigLz1lO16x4q81Zsb IoPAFASQtymo0iYE
IAABCDRPAHlrPsWLGCDytog0ESQEihFoXt5ybpssRpmGIAABCECgOQLIW3Mp XeSAkLdFpo2gITCa
QPPyNpoMJ0IAAhCAAAQCBJA3pkcNBJC3GrJADBCYj0Dz8paz8rZ+z02DtM+X KnqCAAQgAIGaCCBv
NWWj31iQt35zz8j7JNC8vOWkVYnbxuYV767K2SAAAQhAoE8CyFufea9t1Mhb bRkhHghMS6A5eSv5
Jd2P3L0zKG+qnO0Ggdgv/F4yM2mMUvmSx07sEIDAdgLIGzOiBgLIWw1ZIAYI zEegSXkL4Uu5jfLB
u3YGv6RblUubupi3d3WO77jUXmp56PvQSovGFO2F2JksSvft46z7CeU1NUc5 9ecad06MnAuBVgkg
b61mdlnjQt6WlS+ihUAugeblzb64TZG3B+68eXj0oSPDec+uyqXNd3E910V3 qJ/SMcS2l1tPi9Oq
5c2V+9ixSfMmtnzu/mLjoh4EeiCAvPWQ5frHiLzVnyMihEBJAshbgOZ9J14c vG1SlUtbqry5VppU
H3Y7rhUgXc+sK6282SJk9q/HZvZlHnOdK/Gwzw/Vl9j5xukbgxmvTwCl4y4W PoksGUdoXrhijs0D
9SAAgfEEkLfx7DizHAHkrRxLWoLAEgg0K2++29r0ypvv0UzavXfcEpQ3VS5t MRfdIdnyyYJPqELC
JZVJgugbqyQ0kqCFJC1FJl39jOUUwz02NlO+Q8IpSbpLEn3spHlJOQQgkE8A ectnSAv5BJC3fIa0
AIElEWhW3mxR0T+n3DZ55tiu4GfeVLm0SatH9vkhgZIu3l1iIK282W26ZNPX hi0vUj1J4iQWrpz6
5CwUm49TzNglUTXLpfamjEOal5RDAAL5BJC3fIa0kE8AectnSAsQWBIB5C2Q rVNHdg9r504Pa2fd
uyqXtqXJm2s8PqG0ZWrMKpAWnJh+Y+QtRn5jJVf1F9OeJNWucrvtWCkswVya s5RDAAJxBOaQN/0m
zePlAQYwYA4wB5gDN+aAWpDaoYCoJ+sXLm3tS9yklTWp3BzzycO3Bm+bVOXS tmR5k24dzBGJkLS5
JM0nQFqCpFjnul2xljikeUk5BCCQT2AOecuPkhZaJ8DKW+sZZnwQ2E6gyZU3 6bveYifB8UN7gvKm
yqXNvnUu5bY61+pM7u2AvjZNYbLFSrodUlo1shnFrtCF2NkyZ8tZKidTAl2r ba72Ym6LDLEMCaWU
A9d4pblIOQQgUJYA8laWJ62NI4C8jePGWRBYKoHm5K1kIm4/uDf4mTdVzgYB CEAAAn0SQN76zHtt
o0beassI8UBgWgLNy1vKbZI26qMH9g2H9/t3Vc4GAQhAAAJ9EkDe+sx7baNG 3mrLCPFAYFoCzcvb
tPhoHQIQgAAEeiWAvPWa+brGjbzVlQ+igcDUBJC3qQnTPgQgAAEINEkAeWsy rYsbFPK2uJQRMASy
CDQvbzm3TWaR5WQIQAACEGiaAPLWdHoXMzjkbTGpIlAIFCHQvLwVoUQjEIAA BCAAAYsA8saUqIEA
8lZDFogBAvMRaF7eclbe1u+5aZD2+VJFTxCAAAQgUBMB5K2mbPQbC/LWb+4Z eZ8Empe3nLQqcdvY
vOLdVTkbBCAAAQj0SQB56zPvtY0aeastI8QDgWkJNCdv0hd0p6zEPXL3zqC8 qXK2+QlIX/KdWz7/
iOgRAhBYIgHkbYlZay9m5K29nDIiCIQINClvoQGnyNuDd+0Mfkm3Kpc2JRL2 rs7xHZfaM8slSUlp
q2Rdacz2GFLHIdXX5aE4So5XakuKVzqfcghAoE4CyFudeektKuStt4wz3t4J NC9v9oVzirw9cOfN
w6MPHRnOe3ZVLm2+C/cSF/Ql2pDiHyOLoTHbZVqwSsZhypur3Vq5pTCgLgQg sHoCyNvqc0AEw4C8
MQsg0BcB5C2Q7/tOvDh426Qql7Yx8mauGLlWqVwrS7qe61xbZlwCJY3Dbj9U XxpzKJ6YsZvtx4zX
jjXmfFMqXYLp61c6HsuZehCAQP0EkLf6c9RDhMhbD1lmjBC4QaBZefPdMqdX 3nyP5uS4945bgvKm
yqXNjsMlWaHVp9AqkiRhtuSZfdtSKI3DJUDSCps9Lp+0+caYezzEXo3Hx8+W O5tbzHlm+3Ov9KXm
kvoQgMA4AsjbOG6cVZYA8laWJ61BoHYCzcqbT1RSbps8c2xX8DNvqlzapFUo 1/ku6XC1kyJvLvly
CYxLLkNjjInLlQuXII2RohArib1P8GPkLSZHIfGW5g3lEIBA/QTmkDf9Js3j 5a3bA9lhwBxgDjAH
rs0B5TQ79JP1C5cGtS9xs+XMvoBPkbdTR3YPa+dOD2tn3bsqlzZJIHxSZQtP jCTFyo8pbWNXhWJW
C0NjKyVvPvmVxDSm3K4jyVgKf2neUA4BCNRPYA55q58CEa6aACtvq84A/UNg XgLNr7zZOFPk7eTh
W4O3TapyaatV3kLyEhpTSNps4ZTEVBLUErdNpsidq78pJVOaO5RDAAJ1E0De 6s5PL9Ehb71kmnFC
4BqBJuVN+q632OQfP7QnKG+qXNpibs1zSY55nik5tjz5fvbd+mf2lbrqFls/ dcx2rC5BdN2mqAXU
xcAuM+tI/Um3TUr9uiQ2RnqluUQ5BCBQFwHkra589BoN8tZr5hl3rwSak7eS ibz94N7gZ95U+VK3
WBFb6viIGwIQgMDUBJC3qQnTfgwB5C2GEnUg0A6B5uUt5TZJO61HD+wbDu/3 76p8qRvyttTMETcE
IFALAeStlkz0HQfy1nf+GX1/BJqXt/5SyoghAAEIQGAOAsjbHJTpQyKAvEmE KIdAWwSQt7byyWgg
AAEIQGAmAsjbTKDpJkgAeWOCQKAvAs3LW85tk31NBUYLAQhAAAIpBJC3FFrU nYoA8jYVWdqFQJ0E
mpe3OrETFQQgAAEILJ0A8rb0DLYRP/LWRh4ZBQRiCTQvbzkrb+v33DRIeyxo 6kEAAhCAQFsEkLe2
8rnU0SBvS80ccUNgHIHm5W0clmtnKXHb2Lzi3VU5GwQgAAEI9EkAeesz77WN GnmrLSPEA4FpCTQn
b9IXdKesxD1y986gvKnyVW/Sv/zPLV/1+KbuX+Izdf+0DwEILJcA8rbc3LUU OfLWUjYZCwRkAk3K
W2jYKfL24F07g1/SrcqlTcmBvatz9DHzfNexmPZDdbSchOKQ+ihZPpUs+can YzfLbea+8Y2Jdcw5
JfnSFgQgMB8B5G0+1vTkJ4C8MTsg0BeB5uXNvphOkbcH7rx5ePShI8N5z67K pc13Mb8KeXPFOrds
pPYXWz9Uzy4zf45tX8qzKYmxdakHAQgsmwDytuz8tRI98tZKJhkHBOIIIG8B TvedeHHwtklVLm0h
eVPnmitj5s/6eUjy7DLX6pLdvh2vLTJSm1I8psT44kldYYypL3H2jdtesbPj d43HbMseo2+FT5on
lEMAAssjgLwtL2ctRoy8tZhVxgQBP4Fm5c13G51eefM9mqjuveOWoLypcmkL yUFI3nyrRWOPx8Zh
yopLJkPlrvFI9SV+LlFynSONLyRvdh9SzCEhLr2Sl8KHuhCAwLwE5pA3/SbN 4+UBBjBgDjAHmAM3
5oBymR0KiHqyfuHS1r7Ezb4t0r6YTrlt8syxXcHPvKlyaYtZEXLdxjdG0lwC E7vy5pNdV2y2pIX6
lUTIJWeSALnKYzi7JM3HecwYbdmV5gblEIDAsgnMIW/LJkT0cxBg5W0OyvQB gXoINLvyZkuD/jlF
3k4d2T2snTs9rJ1176pc2mKkopS8uWJJkbfQ+baYxLabIm8xLGN4uiTNbtsX f0wufHMLeZMySDkE
2iKAvLWVz6WOBnlbauaIGwLjCDQvbzaWFHk7efjW4G2TqlzaxsrGmJU3l7TE SlZMfzFiI0mRtKrm
E0jpvFB5zOqaS8jGjEWKU5ovlEMAAsshgLwtJ1ctR4q8tZxdxgaBFxJoUt6k 73qLnQjHD+0Jypsq
l7aY2xFd0qVXcfT5dh2zXVM87PqmgEi3N/raDImNL05JmGIlJ6Wea3whNnbs MTG76riYx8YtzR/K
IQCBegkgb/XmpqfIkLeess1YITBc//xvM595K5nU2w/uDX7mTZWztUsAAWs3 t4wMAiUIIG8lKNJG
LgHkLZcg50NgWQSaW3mz8afcJmmfe/TAvuHwfv+uytnaJIC4tZlXRgWBkgSQ t5I0aWssAeRtLDnO
g8AyCTQvb8tMC1FDAAIQgEDtBJC32jPUR3zIWx95ZpQQ0ASQN+YCBCAAAQhA YAQB5G0ENE4pTgB5
K46UBiFQNYHm5S3ntsmqM0dwEIAABCCwUgLI20rx0/nzBJA3pgIE+iLQvLz1 lU5GCwEIQAACcxFA
3uYiTT8hAsgb8wMCfRFoXt5yVt7W77lpkPa+pgujhQAEIAABTQB5Yy7UQAB5 qyELxACB+Qg0L285
KJW4bWxe8e6qnA0CEIAABPokgLz1mffaRo281ZYR4oHAtASakzfpC7pTVuIe uXtnUN5U+RI36d/g
S+VLHPMUMUuccsuniJk2IQCBcgSQt3IsaWk8AeRtPDvOhMASCTQpb6FEpMjb g3ftDH5JtyqXNnUB
b+/qHH3MPF+62Jf6ii3X/YRii22rRL2pxp3KPjUOqX4vnEvMAdqAwBIJIG9L zFp7MSNv7eWUEUEg
RKB5ebMvsFPk7YE7bx4efejIcN6zq3Jp813g1yJvrvglK
Re: Primitive types and Java types in XMI [message #626524 is a reply to message #477302] |
Mon, 05 May 2008 04:11  |
Originally posted by: swt.magellium.fr
Yes thank you, this way seems to be the best one.
But it works only for standard primitive types.
I also need to export java types !
For instance, in order to export an attribute which type is "date", and
to have it imported into eclipse, the XMI should be something like :
<ownedAttribute xmi:id="whatever" name="attributeName"
aggregation="composite">
<type xmi:type="uml:PrimitiveType"
href="pathmap://UML_METAMODELS/Ecore.metamodel.uml#EDate"/>
</ownedAttribute>
I don't know how to achieve this using Bouml...
Note that this is more a Bouml problem than an Eclipse (mdt/emf) problem
so I think I won't continue spamming messages on these newsgroups.
Thank you Ed, James and Bruno!
bruno pagès a écrit :
> there is a simplest way to solve (part of) your problem : to use a Bouml
> release greater or equal to the 4.2.1 to produce forms like
> href="http://schema.omg.org/spec/UML/2.1/uml.xml#Integer"/>
> Of course I recommend you to use the last release (4.3.1)
> Best regards
> Bruno
Re: Primitive types and Java types in XMI [message #626532 is a reply to message #477346] |
Mon, 05 May 2008 09:28  |
Bruno,
The primitive types supported by Ecore are available in the Ecore primitive
types model library
(pathmap://UML_LIBRARIES/EcorePrimitiveTypes.library.uml). I'm not sure how
you would make reference to the types in this library via the tool you're
using, however (not having ever used it)...
Kenn
"SWT" <swt@magellium.fr> wrote in message
news:481EC116.2040004@magellium.fr...
> For instance, in order to export an attribute which type is "date", and to
> </ownedAttribute>
> bruno pag
Re: Primitive types and Java types in XMI [message #626538 is a reply to message #477353] |
Tue, 06 May 2008 03:00  |
Originally posted by: bouml.free.fr
Thanks, but Bouml doesn't know Ecore. I take into account Eclipse in XMI
import/export (Eclipse isn't compatible with standard XMI) but there are
limits ;-)
Furthermore Stephane wants to XMI export the non primitive type Date into
a Ecore primitive type, this can't be done in a 'natural' way.
I will have to do 'something' in Bouml to allow to ask for special
class/datatype XMI export, and Stephane will have to configure Bouml to
use this new feature
Best regards
Re: Primitive types and Java types in XMI [message #626541 is a reply to message #477359] |
Wed, 07 May 2008 08:05  |
For the moment, I solved the problem thanks to Bruno : I modified
Bouml's XMI export code.
Whenever the exporter founds an attribute's type name which starts with
the string "ECore", it creates the following XMI tag :
href="pathmap://UML_METAMODELS/Ecore.metamodel.uml#XXXX"/>
Where XXXX is the second part of the type name.
For instance, if I want to use EDate, I just have to use "ECoreEDate" as
type name under my Bouml model :)
PS : For people who use Enterprise Architect (v7.1b829 or later) and
wish to use their models under Eclipse, I strongly suggest to do the
following :
1) Export the EA model (I didn't try with packages but it should work)
using XMI 2.1 (you should disable "full EA roundtrip", check "Exclude EA
tagged value", and uncheck "Export diagrams", I know it works this way).
2) Create a new project under Bouml, import the XMI you just created
using EA (tools->import xmi 2.1).
3) Clean the model (remove EA empty packages, etc.)
4) Generate a new XMI 2.1 using Bouml (check "use PrimitiveType rather
than DataType" and "Generate for Eclipse".
5) You can use the XMI under eclipse !
This way you'll avoid many problem that you may encounter when trying to
directly import the XMIs generated by EA into eclipse...
@Bruno : I can send you the new XMI Generator "plug out" with my changes
if you want (I just added 2 lines of code...) and an explanation on how
to properly declare the types under EA before sending XMIs to Bouml...
(But that will be next week, sorry)
Stephane
> limits ;-)
> into a Ecore primitive type, this can't be done in a 'natural' way.
> Best regards
Re: Primitive types and Java types in XMI [message #626542 is a reply to message #477362] |
Wed, 07 May 2008 09:57  |
Stephane,
That was my point - you could/should be using
" pathmap://UML_LIBRARIES/EcorePrimitiveTypes.library.uml#XXXX" instead of
referencing the Ecore metamodel. Another alternative to chaning the could
would be to adding mappings to the URI converter (before loading the
resource) which will map the URIs produced by Bouml to the URIs expected by
UML2...
Kenn
news:48219B27.1050306@magellium.fr...
> For the moment, I solved the problem thanks to Bruno : I modified Bouml's
> XMI export code.
> PS : For people who use Enterprise Architect (v7.1b829 or later) and wish
> to use their models under Eclipse, I strongly suggest to do the following
> 2) Create a new project under Bouml, import the XMI you just created using
> if you want (I just added 2 lines of code...) and an explanation on how to
> Stephane
> Bruno Pag
Re: Primitive types and Java types in XMI [message #626550 is a reply to message #477362] |
Sat, 10 May 2008 03:43  |
> @Bruno : I can send you the new XMI Generator "plug out" with my changes if
I can easily imagine the modifications made in my XMI generator, and sorry
but I am not interested by how to properly declare the types under EA !
Your management of EA and Bouml is very strange and a little bit "usine à
gaz", for me you have two better solutions :
- you give money to use EA, ask them to perform some changes, or
- stop to use EA and use Bouml for free
Bruno
Current Time: Sat Jul 26 21:32:29 EDT 2025
Powered by FUDForum. Page generated in 0.71763 seconds
