Home » Modeling » UML2 » Are UUIDs required by the UML2 implementation?
Are UUIDs required by the UML2 implementation? [message #477269] Fri, 18 April 2008 15:34 Go to next message
I am trying to load a UML model that contains elements that do not have
UUIDs.
The UML metamodel extends EModelElement, which supports hierarchical URI
fragments. However, I find that references made using hierarchical URI
fragments within a UML model can't be resolved via
EModelElementImpl#eObjectForURIFragmentSegment because the UML elements
are not ENamedElements.
Is this a scenario that should work, or is it considered unsupported by
Linda
Re: Are UUIDs required by the UML2 implementation? [message #477270 is a reply to message #477269] Sat, 19 April 2008 08:18 Go to previous messageGo to next message
--------------060305090801050600060909
Linda,
Given that NamedElementImpl overrides eURIFragmentSegment to produce a
specialized fragment path, it seems to me that this corresponding
override to decode that specialized syntax is missing from NamedElementImpl:
public EObject eObjectForURIFragmentSegment(String uriFragmentSegment)
if (uriFragmentSegment.length() > 0)
// Is the first character a special character, i.e., something
other than '@'?
char firstCharacter = uriFragmentSegment.charAt(0);
if (firstCharacter != '@' && firstCharacter != '%')
// Look for trailing count.
int index = uriFragmentSegment.lastIndexOf(".");
String name = index == -1 ? uriFragmentSegment :
uriFragmentSegment.substring(0, index);
int count = 0;
if (index != -1)
try
count =
Integer.parseInt(uriFragmentSegment.substring(index + 1));
catch (NumberFormatException exception)
// Interpret it as part of the name.
name = uriFragmentSegment;
name = URI.decode(name);
// Look for a matching named element.
for (Object object : eContents())
if (object instanceof NamedElement)
NamedElement namedElement = (NamedElement)object;
if (name.equals(namedElement.getName()) && count-- == 0)
return namedElement;
return null;
return super.eObjectForURIFragmentSegment(uriFragmentSegment);
> have UUIDs.
> URI fragments. However, I find that references made using
> hierarchical URI fragments within a UML model can't be resolved via
> elements are not ENamedElements.
> Linda
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Linda,<br>
<br>
NamedElementImpl:<br>
<br>
<small>&nbsp;&nbsp;&nbsp; &nbsp; @Override<br>
&nbsp;&nbsp;&nbsp; &nbsp; public EObject eObjectForURIFragmentSegment(String
uriFragmentSegment)<br>
&nbsp;&nbsp;&nbsp; &nbsp; {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (uriFragmentSegment.length() &gt; 0)<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Is the first character a special character, i.e.,
something other than '@'?<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; //<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; char firstCharacter = uriFragmentSegment.charAt(0);<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (firstCharacter != '@' &amp;&amp; firstCharacter != '%')<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; // Look for trailing count.<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; //<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; int index = uriFragmentSegment.lastIndexOf(".");<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; String name = index == -1 ? uriFragmentSegment :
uriFragmentSegment.substring(0, index);<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; int count = 0;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if (index != -1)<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; try<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; count =
Integer.parseInt(uriFragmentSegment.substring(index + 1));<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; catch (NumberFormatException exception)<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; // Interpret it as part of the name.<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; //<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; name = uriFragmentSegment;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }<br>
<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; name = URI.decode(name);<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; // Look for a matching named element.<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; for (Object object : eContents())<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; if (object instanceof NamedElement)<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; NamedElement namedElement = (NamedElement)object;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; if (name.equals(namedElement.getName()) &amp;&amp;
count-- == 0)<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return namedElement;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; }<br>
&nbsp;&nbsp;&nbsp; &nbsp; <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; return null;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; return super.eObjectForURIFragmentSegment(uriFragmentSegment);<br>
&nbsp;&nbsp;&nbsp; &nbsp; }</small><br>
<br>
<br>
Linda Damus wrote:
<blockquote cite="mid:fuat3p$4ov$1@build.eclipse.org" type="cite">I am
UUIDs.
<br>
<br>
URI fragments.&nbsp; However, I find that references made using hierarchical
<br>
<br>
<br>
<br>
<br>
Linda
<br>
</blockquote>
<br>
</body>
</html>
--------------060305090801050600060909--
Re: Are UUIDs required by the UML2 implementation? [message #477271 is a reply to message #477270] Sat, 19 April 2008 12:20 Go to previous messageGo to next message
Thanks, Ed. Overriding the eObjectForURIFragmentSegment implementation
in NamedElementImpl does the trick! I've opened
https://bugs.eclipse.org/bugs/show_bug.cgi?id=227892.
Linda
Ed Merks wrote:
> Linda,
> @Override
> other than '@'?
> int count = 0;
> if (index != -1)
> try
> count =
> return null;
>> have UUIDs.
>> Thanks,
>> Linda
Re: Are UUIDs required by the UML2 implementation? [message #477273 is a reply to message #477271] Mon, 21 April 2008 09:13 Go to previous message
Linda, Ed, Thanks for the fix. I'll look into adding this.
- James.
"Linda Damus" <ldamus@ca.ibm.com> wrote in message
news:fud64g$8mf$1@build.eclipse.org...
> Thanks, Ed. Overriding the eObjectForURIFragmentSegment implementation in
> Regards,
> Linda
> Ed Merks wrote:
>> Linda,
>> NamedElementImpl:
>> @Override
>> uriFragmentSegment)
>> other than '@'?
>> int count = 0;
>> if (index != -1)
>> try
>> count =
>> 0)
>> return null;
>>> UUIDs.
>>> Thanks,
>>> Linda
Re: Are UUIDs required by the UML2 implementation? [message #626427 is a reply to message #477269] Sat, 19 April 2008 08:18 Go to previous message
Linda,
other than '@'?
int count = 0;
if (index != -1)
try
count =
return null;
> have UUIDs.
> Linda
<html>
<head>
</head>
Linda,<br>
<br>
<br>
<br>
count-- == 0)<br>
<br>
<br>
UUIDs.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Linda
<br>
</blockquote>
<br>
</body>
</html>
Re: Are UUIDs required by the UML2 implementation? [message #626428 is a reply to message #477270] Sat, 19 April 2008 12:20 Go to previous message
Linda
Ed Merks wrote:
> Linda,
> @Override
> other than '@'?
> int count = 0;
> if (index != -1)
> try
> count =
> return null;
>> have UUIDs.
>> Thanks,
>> Linda
Re: Are UUIDs required by the UML2 implementation? [message #626431 is a reply to message #477271] Mon, 21 April 2008 09:13 Go to previous message
- James.
> Regards,
> Linda
> Ed Merks wrote:
>> Linda,
>> NamedElementImpl:
>> @Override
>> uriFragmentSegment)
>> other than '@'?
>> int count = 0;
>> if (index != -1)
>> try
>> count =
>> 0)
>> return null;
>>> UUIDs.
>>> Thanks,
>>> Linda
Previous Topic:[Announce] MDT UML2 2.2.0 I200804200420 is available
Next Topic:comptability with enterprise architect
Current Time: Sat Aug 30 20:38:18 EDT 2025
Powered by FUDForum. Page generated in 0.04601 seconds
