Home » Modeling » UML2 » UML2 vs EMF generated code difference
UML2 vs EMF generated code difference [message #477266] Thu, 17 April 2008 15:19 Go to next message
I recently converted a meta model specified in EMF into a UML meta
model. When regenerating the code from the UML-ized model I noticed
changes in generated code for 'eInverseRemove' methods, and in some
cases they were completely absent.
After some investigation it turned out that UML code generator did not
generate case statements for derived features. Eventually I traced it
down to differences in GenFeatureFilter-s applied to
GenClassImpl.getEInverseRemoveGenFeatures method.
In EMF the filter's accept method looks like this:
public boolean accept(GenFeature genFeature)
return genFeature.isEffectiveContains() ||
(genFeature.isBidirectional() &&
(!genFeature.getReverse().isVolatile() ||
genFeature.getReverse().hasDelegateFeature())) ||
genFeature.isFeatureMapType();
while in UML2 it looks like this:
public boolean accept(GenFeature genFeature) {
return !genFeature.isDerived();
Why the different treatment of derived features in EMF and UML? Why is
it unacceptable to 'inverse remove' a derived feature in UML?
Vmir
Re: UML2 vs EMF generated code difference [message #477275 is a reply to message #477266] Mon, 21 April 2008 13:07 Go to previous messageGo to next message
Vmir,
The values of derived properties are typically obtained (computed) from the
values of other (non-derived) properties. Since such features are also
typically volatile and because the UML2 code generator can't assume how this
computation takes place, it does not generate handshaking code for them by
default (it's easier to add such behavior than to take it out). Do you have
a use case where hand-shaking code is needed for a derived feature (in the
UML metamodel, it is not)?
Kenn
"Vladimir Hirsl" <vladimirh@edgewater.ca> wrote in message
news:fu87ss$nav$1@build.eclipse.org...
> I recently converted a meta model specified in EMF into a UML meta model.
> When regenerating the code from the UML-ized model I noticed changes in
> generated code for 'eInverseRemove' methods, and in some cases they were
> completely absent.
> generate case statements for derived features. Eventually I traced it down
> Why the different treatment of derived features in EMF and UML? Why is it
> Vmir
Re: UML2 vs EMF generated code difference [message #477286 is a reply to message #477275] Mon, 28 April 2008 10:56 Go to previous messageGo to next message
Hi Kenn,
thanks for your reply.
My derived features are contained, volatile, transient and changeable
and they delegate to features of contained objects. They are really just
a different name for existing features. I expect that they should behave
the same way original features do. The reason I need them is partly for
GMF diagram tools to generate diagram code that requires less customization.
I did not understand if the difference in generated code is due to the
changed semantics of derived features in UML or due to code generation
optimization. If it is the latter I guess there should be an option in a
UML genmodel to turn the optimization on/off.
Vmir
Kenn Hussey wrote:
> Vmir,
> Kenn
>> Hi,
>> completely absent.
>> Thanks,
>> Vmir
Re: UML2 vs EMF generated code difference [message #477291 is a reply to message #477286] Tue, 29 April 2008 10:11 Go to previous message
Vladimir,
The opposites of derived features should generally be derived; if you change
the value of the derived feature on one side, it will update the feature on
which it depends, and that feature, assuming it has an opposite, will update
its opposite per the usual handshaking mechanism and in turn the opposite
derived feature should be updated with the new value. The difference is that
no events will be fired for the change of the opposite derived feature's
value, and I suspect that this is really the issue - if you're using these
derived features as the basis for GMF diagrams, you'll need all events. So,
you'll need to ensure that the list implementation you're using for these
derived, volatile features are firing all the expected events...
Kenn
news:fv4oib$s2s$1@build.eclipse.org...
> Hi Kenn,
> My derived features are contained, volatile, transient and changeable and
> they delegate to features of contained objects. They are really just a
> different name for existing features. I expect that they should behave the
> same way original features do. The reason I need them is partly for GMF
> Vmir
> Kenn Hussey wrote:
>> Vmir,
>> the values of other (non-derived) properties. Since such features are
>> also typically volatile and because the UML2 code generator can't assume
>> how this computation takes place, it does not generate handshaking code
>> for them by default (it's easier to add such behavior than to take it
>> out). Do you have a use case where hand-shaking code is needed for a
>> derived feature (in the UML metamodel, it is not)?
>> Kenn
>>> Hi,
>>> Thanks,
>>> Vmir
Re: UML2 vs EMF generated code difference [message #626433 is a reply to message #477266] Mon, 21 April 2008 13:07 Go to previous message
Vmir,
Kenn
> completely absent.
> Vmir
Re: UML2 vs EMF generated code difference [message #626444 is a reply to message #477275] Mon, 28 April 2008 10:56 Go to previous message
Hi Kenn,
Vmir
Kenn Hussey wrote:
> Vmir,
> Kenn
>> Hi,
>> completely absent.
>> Thanks,
>> Vmir
Re: UML2 vs EMF generated code difference [message #626449 is a reply to message #477286] Tue, 29 April 2008 10:11 Go to previous message
Vladimir,
Kenn
> Hi Kenn,
> Vmir
> Kenn Hussey wrote:
>> Vmir,
>> Kenn
>>> Hi,
>>> Thanks,
>>> Vmir
Previous Topic:UML templates
Next Topic:[Announce] MDT UML2 2.2.0 I200804291920 is available
Current Time: Sun Aug 31 16:22:43 EDT 2025
Powered by FUDForum. Page generated in 0.07370 seconds
