Home » Modeling » UML2 » Using UML Standard profile with static profile
Using UML Standard profile with static profile [message #477235] Fri, 11 April 2008 06:38 Go to next message
I try to build a static profile that use (inheritance) some of the
stereotypes defined in UML Standard profile.
When I create the genmodel file the "referenced generator model" are
correctly detected for UML and ECORE, not for the Standard profile.
I assume that this is due to the fact that the Standard profile is not
yet a Static profile. Have I missed something ?
Is a static version of the standard profile planned in coming releases ?
regards
Yann
Re: Using UML Standard profile with static profile [message #477236 is a reply to message #477235] Fri, 11 April 2008 12:26 Go to previous message
Hi Yann,
You are right, you cannot reference the generator model while working with
your static profile because it doesn't yet exist.
We are considering doing this in the future but it is not currently in the
plan. You can raise a bugzilla if this would be useful to you.
- James.
"Yann Tanguy" <yann.tanguy@cea.fr> wrote in message
news:ftnf6u$7ef$1@build.eclipse.org...
> I assume that this is due to the fact that the Standard profile is not yet
> regards
> Yann
Re: Using UML Standard profile with static profile [message #626394 is a reply to message #477235] Fri, 11 April 2008 12:26 Go to previous message
Hi Yann,
- James.
> regards
> Yann
Previous Topic:Using UML Standard profile with static profile
Next Topic:Initial/Default values
Current Time: Sat Aug 30 23:21:11 EDT 2025
Powered by FUDForum. Page generated in 0.04144 seconds
