Home » Modeling » UML2 » Error after applying the stereotype EClass to a Class
Error after applying the stereotype EClass to a Class [message #477219] Wed, 09 April 2008 10:52 Go to next message
Originally posted by: markus.heintz.iese.fhg.de
After applying the sterotype eClass to a UML class, I get the following
error message when I validate the UML model:
The required feature 'base_Interface' of 'EClass -> <<eClass>> <Class> X '
must be set
The required feature 'base_DataType' of 'EClass -> <<eClass>> <Class> X '
must be set
where 'X' is the name of the class.
I tried two things:
1) - I created a UML model using the UML Editor and the diagram editor
- Then I applied the UML Ecore Profile to the model using the UML
Editor
- Then I applied the sterotype EPackage to the root package element.
- Validating the model now shows no error
- When I apply the sterotype EClass to a plain UML class I get the
above mentioned
error messages after validating the model
2) - I exported a valid core ecore model to a UML model. When I validate
the UML model I get the above error messages for every UML class
Since I'm still exploring the UML2 tools and EMF I wonder if I forgot to do
something or made a mistake.
Can anybody give me a hint why I get this error messages?
Thanks a lot
Markus
Re: Error after applying the stereotype EClass to a Class [message #477223 is a reply to message #477219] Wed, 09 April 2008 11:17 Go to previous message
Hi Markus,
What you are seeing is "OK". It came up recently in another post
concerning validation of superstructure.uml see "Package merge" from
3/30/2008.
It has to do with the EClass stereotype extending multiple metaclasses,
thereby creating several required features "base_xxx". Their lower bound
is 1, not 0 so they are required to be set from an Ecore validation
perspective. We really want to say that exactly one of those "base_xxx"
get set so we would in theory either need an OCL constraint indicating that,
or the lower bound should be changed to 0 ( which is not supported from a
UML perspective ).
I will look into addressing this problem but in the meantime, you can
double check that at most one "base_xxx" is getting set and ignore the
warning for now.
- James.
"Markus Heintz" <markus.heintz@iese.fhg.de> wrote in message
news:ftil7h$ar3$1@build.eclipse.org...
> Hi
> must be set
> must be set
> I tried two things:
> Editor
> above mentioned
> validate the UML model I get the above error messages for every UML class
> do something or made a mistake.
> Thanks a lot
> Markus
Re: Error after applying the stereotype EClass to a Class [message #626381 is a reply to message #477219] Wed, 09 April 2008 11:17 Go to previous message
Hi Markus,
3/30/2008.
UML perspective ).
warning for now.
- James.
> Hi
> must be set
> must be set
> I tried two things:
> Editor
> above mentioned
> Thanks a lot
> Markus
Previous Topic:Re: Derive constraints
Next Topic:xmi Id in Dependency
Current Time: Sun Aug 31 13:18:50 EDT 2025
Powered by FUDForum. Page generated in 0.05010 seconds
