Home » Modeling » UML2 » Use profile UML
Use profile UML [message #477185] Thu, 03 April 2008 15:00 Go to next message
Originally posted by: fatma.krichen.gmail.com
Hi all,
I create correctly a profil for an extension of UML meta-model.
I want to create an editor diagram which support the new UML element
applied with our profil.
How to create the digram and Which meta model I must used (the ecore file
of profil or of the extended meta-model)?
Sorry for my poor english
Fatma
Re: Use profile UML [message #477191 is a reply to message #477185] Fri, 04 April 2008 09:40 Go to previous messageGo to next message
Originally posted by: adilanwar10.yahoo.fr
Hi Fatma,
you can use an UML editor like TopCased to edit your models, and apply the
profile which you created.
in this article you will find how to create an UML profile and how to apply
it to a model
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html
Adil
"Fatma" <fatma.krichen@gmail.com> a
Re: Use profile UML [message #477193 is a reply to message #477191] Fri, 04 April 2008 09:57 Go to previous messageGo to next message
Thank you for your help,
I know create profile and how to apply it to a model, but I want create a
diagram editor that represent metamodel with profile.
I want to know the next step to create diagram editor.
Which meta model I must used (the ecore file of profil or of the extended
meta-model)?
Fatma
Re: Use profile UML [message #477207 is a reply to message #477193] Tue, 08 April 2008 05:47 Go to previous message
use an UML editor to edit your models, since your profiled model is an UML
model.
now, if you need to create a specific diagram editor for your specific
metamodel, you have tu use the GEF framework : http://www.eclipse.org/gef/
Adil
Re: Use profile UML [message #626351 is a reply to message #477185] Fri, 04 April 2008 09:40 Go to previous message
Hi Fatma,
it to a model
Adil
Re: Use profile UML [message #626353 is a reply to message #477191] Fri, 04 April 2008 09:57 Go to previous message
meta-model)?
Fatma
Re: Use profile UML [message #626364 is a reply to message #477193] Tue, 08 April 2008 05:47 Go to previous message
model.
Adil
Previous Topic:Types that are not Classifiers
Next Topic:Operation and Interfaces
Current Time: Sun Aug 31 20:12:36 EDT 2025
Powered by FUDForum. Page generated in 0.07936 seconds
