Home » Modeling » UML2 » New features of UML2 - Generics, ... (EclipseCon 2008)
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #477168 is a reply to message #477166] |
Tue, 01 April 2008 16:57   |
Originally posted by: comouraf-lixo.yahoo.fr
Hi, James,
Somehow I couldn't go to the end of the static profile definition example
from your presentation. After having generated the sources, I added the
....uml2.uml.generated_package extension to the plugin.xml (of the model
related plugin). But this extension point does not offer the options "uri"
and "location", as seen in the figure. All it permits is to add a new
"generic", which offers a text field called "body". What did I do wrong?
César
"James Bruck" <jbruck@ca.ibm.com> a écrit dans le message de
news:fsr9vt$n3t$3@build.eclipse.org...
> Hi Ekke,
> I tried to reply with the presentation attached but it seems that I
> exceeded the posting size limit.
> I will post the long talk, tutorial and OMG presentation on the UML2 Wiki
> shortly.
> (The presentation was #170 and the tutorial was #172 at EclipseCon2008)
> You can also get it from here:
> https://eclipsecon.greenmeetingsystems.com/submissions/view/ 170
> Thanks for coming out!
> - James.
> "ekke" <ekkehard@gentz-software.de> wrote in message
> news:a81624f3bb3342e0b1be64c810fc16aa$1@www.eclipse.org...
>> at EclipseCon2008 I visited this session from James Bruck.
>> I didn't found the presentation as download -
>> is it anywhere to find ?
>> thanks
>> ekke
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #477178 is a reply to message #477173] |
Wed, 02 April 2008 17:36   |
------=_NextPart_000_0017_01C8951A.700C6D10
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=response
Hi, James,
I think there must be something wrong but with my eclipse installation,
since the extension point generated_package from the uml2 plugin is not
being correctly accessed. I can see it in the list of extension points, but
its schema is not accessible (e.g. if I click on the link "open extension
point schema" or "show extension point description" for example, I get an
error message reporting that both schema and description cannot be found).
If I do the same to the generated_package extension point from the ecore, it
works fine.
So I'm sure there is a problem, but I don't know exactly what it is. :-(
Thank you anyway,
C
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #477180 is a reply to message #477178] |
Thu, 03 April 2008 10:20   |
What version of UML are you using?
Try with the latest M6 version.
- James.
"kaiserlautern" <comouraf-lixo@yahoo.fr> wrote in message
news:ft0ua5$54f$1@build.eclipse.org...
> Hi, James,
> but
> it
> works fine.
> Thank you anyway,
> C
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #626310 is a reply to message #477166] |
Hi, James,
César
> Hi Ekke,
> shortly.
> - James.
>> thanks
>> ekke
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #626338 is a reply to message #477173] |
format=flowed;
reply-type=response
Hi, James,
works fine.
Thank you anyway,
C
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #626340 is a reply to message #477178] |
- James.
> Hi, James,
> but
> it
> works fine.
> Thank you anyway,
> C
Current Time: Sun Aug 31 14:21:58 EDT 2025
Powered by FUDForum. Page generated in 0.04531 seconds
