Home » Modeling » UML2 » Resource from non UML2 uml model
Resource from non UML2 uml model [message #477066] |
Tue, 11 March 2008 20:31  |
Originally posted by: pfuriani.uci.edu
Resource resource = RESOURCE_SET.getResource(uri, true);
This is the line I use to create a resouce for a .uml file. This works
properly when the .uml file was created with the UML2 editor. However, when
the .uml file is created with a different UML program, Altova to be
specific, I notice that the "contents" array of the Resource object is
empty. So next when i call,
Package thePackage =
(Package)EcoreUtil.getObjectByType(resource.getContents(),
UMLPackage.Literals.PACKAGE);
,then "thePackage" is "null" because the contents of the Resource are
empty. I don't understand why the Resource contents only get filled in with
..uml files created with the UML2 editor and not by .uml files created by a
different editor. Its important that I can create a Resource from uml models
made by other programs besides UML2.
Re: Resource from non UML2 uml model [message #477145 is a reply to message #477097] |
Thu, 27 March 2008 11:17   |
Sorry for the delayed response. I've taken a look at your model, and as it
turns out, I think this is a problem with the way content type recognition
is being done by EMF - there's nothing wrong with your model, but I think
what's happening is that the document isn't being recognized as a UML
document because the first "real" element in the document is an
xmi:Documentation element (instead of an element from the UML namespace).
Please open a Bugzilla request against EMF and attach your sample model as a
test case; in the meantime, you can work around the problem by removing the
documentation element (or moving it to later in the file).
Kenn
"PFuriani" <pfuriani@uci.edu> wrote in message
news:frc848$sav$1@build.eclipse.org...
> Here is the file that I am trying. I created this in Altova and used
> their export as .xmi feature.
> "Kenn Hussey" <Kenn.Hussey@embarcadero.com> wrote in message
> news:fr7hfr$8ml$1@build.eclipse.org...
>> Load UML resources from other tools will only work if the structure of
>> those
>> files corresponds to the structure (schema) used by UML2. Can you provide
>> a
>> sample of one of the resources you're trying to load?
>> Kenn
>> news:fr782p$5g6$1@build.eclipse.org...
>>> when the .uml file is created with a different UML program, Altova to be
>>> with .uml files created with the UML2 editor and not by .uml files
>>> created
>>> by a different editor. Its important that I can create a Resource from
>>> uml
>>> models made by other programs besides UML2.
Re: Resource from non UML2 uml model [message #477230 is a reply to message #477145] |
Wed, 09 April 2008 14:54  |
I've gone ahead and submitted the bug for you -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=226322.
Kenn
news:fsgdr2$g8p$1@build.eclipse.org...
> a test case; in the meantime, you can work around the problem by removing
> the documentation element (or moving it to later in the file).
> Kenn
>>> those
>>> provide a
>>> Kenn
>>>> be
>>>> created
>>>> uml
Re: Resource from non UML2 uml model [message #626198 is a reply to message #477066] |
Tue, 11 March 2008 23:08  |
Load UML resources from other tools will only work if the structure of those
files corresponds to the structure (schema) used by UML2. Can you provide a
Kenn
> with .uml files created with the UML2 editor and not by .uml files created
> by a different editor. Its important that I can create a Resource from uml
Re: Resource from non UML2 uml model [message #626226 is a reply to message #477071] |
Thu, 13 March 2008 18:02  |
Here is the file that I am trying. I created this in Altova and used their
> those
> a
> Kenn
>> created
>> uml
Re: Resource from non UML2 uml model [message #626279 is a reply to message #477097] |
Kenn
>> those
>> a
>> Kenn
>>> created
>>> uml
Re: Resource from non UML2 uml model [message #626388 is a reply to message #477145] |
Kenn
> Kenn
>>> those
>>> provide a
>>> Kenn
>>>> be
>>>> created
>>>> uml
Current Time: Sun Aug 31 13:50:03 EDT 2025
Powered by FUDForum. Page generated in 0.04902 seconds
