Home » Modeling » UML2 » Ecore 2 UML
Ecore 2 UML [message #476886] Mon, 28 January 2008 23:55 Go to next message
Is there an easy way to import an Ecore into UML2? I just need the
class diagram subset of UML, which Ecore closely resembles.
The reason I ask is because I have a bunch of Ecore models and I would
like to render them (as diagrams in my thesis) and none of Ecore diagram
tools shows the ordered attribute, however, most of the UML tools do.
Ian
Re: Ecore 2 UML [message #476887 is a reply to message #476886] Tue, 29 January 2008 02:17 Go to previous messageGo to next message
did you try the uml export in the genmodel?
-stefan
> Cheers,
> Ian
Re: Ecore 2 UML [message #476890 is a reply to message #476887] Tue, 29 January 2008 07:01 Go to previous messageGo to next message
Ian,
What about EMFT's Ecore Tools project? That lets you render a diagram
directly for the Ecore model without need for UML.
> -stefan
>> would like to render them (as diagrams in my thesis) and none of
>> Ecore diagram tools shows the ordered attribute, however, most of the
>> UML tools do.
>> Cheers,
>> Ian
Re: Ecore 2 UML [message #476896 is a reply to message #476887] Tue, 29 January 2008 13:15 Go to previous messageGo to next message
Thanks Stefan,
This is exactly what I was looking for. I thought it would be through
an import, but this makes sense too.
It also answered my question of where did the export XML schema go :-).
Ian
> -stefan
>> diagram tools shows the ordered attribute, however, most of the UML
>> tools do.
>> Cheers,
>> Ian
Re: Ecore 2 UML [message #476897 is a reply to message #476890] Tue, 29 January 2008 13:28 Go to previous messageGo to next message
I am Using Topcased Ecore and UML graphical viewers. Their Ecore tool
is GREAT! The only problem is, there ecore editor doesn't show the
{ordered} annotations, but their UML tool does. (not really a big
issue, but I know I will get asked about this if I don't include it).
Plus the export to PDF works slightly better on the UML viewer than the
Ecore one.
Once I figure out if these editors are making up the new Ecore Tools, I
will open up a feature request for this.
Ian
Ed Merks wrote:
> Ian,
>> -stefan
>>> UML tools do.
>>> Cheers,
>>> Ian
Re: Ecore 2 UML [message #477027 is a reply to message #476887] Wed, 05 March 2008 10:46 Go to previous messageGo to next message
Originally posted by: joerg.von.frantzius.artnology.com
I kept on looking for this for quite a while now, installed all features
seeming relevant, but I can't find this export (or import) feature for
converting ecore to uml2.
Could anybody please tell please what feature exactly this is part of
(e.g. "UML2 Tools"?), and how I can access it in Eclipse? Is that
right-click .ecore or .genmodel file, choose "Export..." and then there
should be "UML2" somewhere?
Thanks for any hints,
Jörg
> -stefan
>> UML tools do.
>> Cheers,
>> Ian
Re: Ecore 2 UML [message #477028 is a reply to message #477027] Wed, 05 March 2008 10:56 Go to previous messageGo to next message
Hi, Jörg,
If you have the UML2 SDK installed (not UML2Tools), then you can export a
UML model from any EMF model (*.genmodel).
Make sure that your configuration includes the
org.eclipse.uml2.uml.ecore.exporter plug-in.
Then, in the Generator editor for a *.genmodel (possibly sourced from
Ecore), select the "Generator -> Export Model..." action in the main menu
bar. In the export wizard, select the "UML model" option and proceed from
there.
HTH,
Christian
Jörg von Frantzius wrote:
> Jörg
>> -stefan
>>> UML tools do.
>>> Cheers,
>>> Ian
Re: Ecore 2 UML [message #477029 is a reply to message #477028] Wed, 05 March 2008 11:08 Go to previous messageGo to next message
There should also be an 'Export Model...' context menu item available when
the generator model is selected in the Package Explorer view...
Kenn
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:fqmfqt$ev2$1@build.eclipse.org...
> Hi, J
Re: Ecore 2 UML [message #477030 is a reply to message #477028] Wed, 05 March 2008 11:15 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Alright, I didn't look at the "Generator" menu in the main menu bar!<br>
<br>
Thanks for your answer!<br>
<br>
Christian W. Damus schrieb:
<blockquote cite="mid:fqmfqt$ev2$1@build.eclipse.org" type="cite">
<pre wrap="">Hi, Jörg,
Ecore), select the "Generator -&gt; Export Model..." action in the main menu
there.
HTH,
Christian
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
Jörg
SKuhn schrieb:
</pre>
<pre wrap="">did you try the uml export in the genmodel?
-stefan
Ian Bull wrote:
</pre>
<pre wrap="">Is there an easy way to import an Ecore into UML2? I just need the
UML tools do.
Ian
</pre>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
Re: Ecore 2 UML [message #477031 is a reply to message #477029] Wed, 05 March 2008 11:17 Go to previous message
<html>
<head>
</head>
OK, now that's two menu entries I hadn't seen :)<br>
<br>
I had only been looking at the general "Export..." context menu entry.
Thanks for the hint.<br>
<br>
Kenn Hussey schrieb:
<blockquote cite="mid:fqmgha$m0q$1@build.eclipse.org" type="cite">
<pre wrap="">There should also be an 'Export Model...' context menu item available when
Kenn
"Christian W. Damus" <a class="moz-txt-link-rfc2396E" href="mailto:cdamus@ca.ibm.com">&lt;cdamus@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fqmfqt$ev2$1@build.eclipse.org">news:fqmfqt$ev2$1@build.eclipse.org</a>...
</pre>
<pre wrap="">Hi, J&ouml;rg,
there.
HTH,
Christian
J&ouml;rg von Frantzius wrote:
</pre>
<pre wrap="">Hi,
J&ouml;rg
SKuhn schrieb:
</pre>
-stefan
Ian Bull wrote:
</pre>
UML tools do.
Ian
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: Ecore 2 UML [message #625943 is a reply to message #476886] Tue, 29 January 2008 02:17 Go to previous message
-stefan
> Cheers,
> Ian
Re: Ecore 2 UML [message #625946 is a reply to message #476887] Tue, 29 January 2008 07:01 Go to previous message
Ian,
> -stefan
>> UML tools do.
>> Cheers,
>> Ian
Re: Ecore 2 UML [message #625952 is a reply to message #476887] Tue, 29 January 2008 13:15 Go to previous message
Thanks Stefan,
Ian
> -stefan
>> tools do.
>> Cheers,
>> Ian
Re: Ecore 2 UML [message #625953 is a reply to message #476890] Tue, 29 January 2008 13:28 Go to previous message
Ecore one.
Ian
Ed Merks wrote:
> Ian,
>> -stefan
>>> UML tools do.
>>> Cheers,
>>> Ian
Re: Ecore 2 UML [message #626143 is a reply to message #476887] Wed, 05 March 2008 10:46 Go to previous message
Jörg
> -stefan
>> UML tools do.
>> Cheers,
>> Ian
Re: Ecore 2 UML [message #626144 is a reply to message #477027] Wed, 05 March 2008 10:56 Go to previous message
Hi, Jörg,
there.
HTH,
Christian
> Jörg
>> -stefan
>>> UML tools do.
>>> Cheers,
>>> Ian
Re: Ecore 2 UML [message #626145 is a reply to message #477028] Wed, 05 March 2008 11:08 Go to previous message
Kenn
> Hi, J
Re: Ecore 2 UML [message #626146 is a reply to message #477028] Wed, 05 March 2008 11:15 Go to previous message
<html>
<head>
</head>
<br>
<br>
there.
HTH,
Christian
</pre>
<pre wrap="">Hi,
Jörg
SKuhn schrieb:
</pre>
-stefan
Ian Bull wrote:
</pre>
UML tools do.
Ian
</pre>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: Ecore 2 UML [message #626147 is a reply to message #477029] Wed, 05 March 2008 11:17 Go to previous message
<html>
<head>
</head>
<br>
<br>
Kenn
</pre>
there.
HTH,
Christian
</pre>
<pre wrap="">Hi,
J&ouml;rg
SKuhn schrieb:
</pre>
-stefan
Ian Bull wrote:
</pre>
UML tools do.
Ian
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Previous Topic:Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY
Next Topic:[Announce] UML2 Tools at EclipseCon 2008
Current Time: Sun Jul 27 10:08:17 EDT 2025
Powered by FUDForum. Page generated in 0.16936 seconds
