Home » Modeling » UML2 » Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477018] Mon, 03 March 2008 14:12 Go to next message
Jinhui,
This is another question for the UML2 newgroup.
Have you read the introductory articles on the UML2 documentation page
(http://wiki.eclipse.org/MDT-UML2#Articles)? They described how to work with
models and profiles both programatically and using the sample editor. I
suspect the problem you are having relates to not registering the pathmaps
for the UML library resources - see the FAQ at
http://wiki.eclipse.org/MDT-UML2-FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F.
Kenn
"Jinhui " <zhuj@in.tum.de> wrote in message
news:140c994f2ffa8aae6c53eb09bb4b9dc5$1@www.eclipse.org...
> Hello,
> another problem, I want to access the UML_Primitive_Lib, so that I can use
> the primitive types as type specification.
> I tried like this:
> URI primitiveTpyeLibURI =
> URI.createURI(XMI2UMLResource.UML_PRIMITIVE_TYPES_LIBRARY_UR I);
> Model uml2PrimitiveTypesLibrary =
> (Model)UML2Util.load(
> RESOURCE_SET,
> primitiveTpyeLibURI,
> UMLPackage.Literals.MODEL);
> actually I've tried with many URIs in different classes, but none of work
> seemed to be working(i.e. load() always return null).
> --XMI2UMLResource
> * UML_PRIMITIVE_TYPES_LIBRARY_2_1_URI
> * UML_PRIMITIVE_TYPES_LIBRARY_URI
> --UMLResource
> --UML22UMLResource
> * UML2_PRIMITIVE_TYPES_LIBRARY_URI
> Any one has any idea?
> best Regards.
> Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477019 is a reply to message #477018] Mon, 03 March 2008 15:54 Go to previous messageGo to next message
Hi Kenn,
first, sorry for misplacing the message in the MDT group. Newbie!
I tried both the two approaches mentioned in the article, neither worked.
the one as in the Profile-tutorial looks like this:
PrimitiveType primitiveType = importPrimitiveType( "Boolean");
protected static PrimitiveType importPrimitiveType(String name) {
Model umlLibrary =
(Model)load(URI.createURI(UMLResource.UML_PRIMITIVE_TYPES_LI BRARY_URI));
PrimitiveType primitiveType = (PrimitiveType)
umlLibrary.getOwnedType(name);
return primitiveType;
protected static org.eclipse.uml2.uml.Package load(URI uri) {
org.eclipse.uml2.uml.Package package_ = null;
try {
Resource resource = RESOURCE_SET.getResource(uri, true); (****)
package_ =(org.eclipse.uml2.uml.Package)EcoreUtil.getObjectByType(
resource.getContents(), UMLPackage.Literals.PACKAGE);
} catch (WrappedException we) {
return package_;
I got Exception at (****):
"Cannot create a resource for
'pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml'; a registered
resource factory is needed"
>> I suspect the problem you are having relates to not registering the
pathmaps for the UML library resources
Can you give me more hints on this?
best Regards!
Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477021 is a reply to message #477019] Mon, 03 March 2008 20:25 Go to previous messageGo to next message
Jinhui,
Its sounds like a resource factory has not been registered to hande the URI
you are trying load. The FAQ entry that I pointed you to shows how to do
this:
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);Kenn
"Jinhui" <zhuj@in.tum.de> wrote in message
news:902de8df46b383e348d19ed88a7e0b73$1@www.eclipse.org...
> Hi Kenn,
> Model umlLibrary =
> try {
> resource.getContents(), UMLPackage.Literals.PACKAGE); } catch
> return package_;
> best Regards! Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477022 is a reply to message #477021] Tue, 04 March 2008 05:36 Go to previous messageGo to next message
Hi Kenn,
Thanks for the advice.
Well, it seemed that the URI
"pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml" has to be resolved
manually, otherwise it could not be resolved by EMF. (I always got the
"MalformedURLException")
So I solved the problem like this:
* I extract the "UMLPrimitiveTypes.library.uml" from the JAR file, and
save it in my current project dir.
* and then register the the pathmap-URI with with the physical one(the one
in my project dir), and now I was able to load the primitive type lib and
get the primitive types.
Jinhui
The code looks like this:
ResourceSet RESOURCE_SET = new
RESOURCE_SET.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
RESOURCE_SET.getResourceFactoryRegistry().getExtensionToFact oryMap().put(UMLResource.FILE_EXTENSION,
Map uriMap = RESOURCE_SET.getURIConverter().getURIMap();
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "uml",
new UMLResourceFactoryImpl());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*",
new XMIResourceFactoryImpl());
URIConverter.URI_MAP.put(URI.createURI("pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml"),
URI.createFileURI(System.getProperty("user.dir") +
"/Model_Libs/UMLPrimitiveTypes.library.uml"));
Resource resource =
RESOURCE_SET.getResource(URI.createURI(UMLResource.UML_PRIMI TIVE_TYPES_LIBRARY_URI),
true);
Kenn Hussey wrote:
> Jinhui,
> this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477023 is a reply to message #477022] Tue, 04 March 2008 10:53 Go to previous messageGo to next message
Jinhui,
What string did you try using for the base JAR URL? I've done this many
times in the past (as per the FAQ) and never had a problem...
Kenn
news:0026a798a8951e2cfe35598bcf00db2e$1@www.eclipse.org...
> Hi Kenn,
> So I solved the problem like this: * I extract the
> "UMLPrimitiveTypes.library.uml" from the JAR file, and save it in my
> Jinhui
> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "*", new
> Resource resource =
> true);
> Kenn Hussey wrote:
>> Jinhui,
>> URI you are trying load. The FAQ entry that I pointed you to shows how to
>> do this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477024 is a reply to message #477023] Tue, 04 March 2008 13:58 Go to previous messageGo to next message
Hi Kenn,
yes, you're right, after setting the correct base JAR URL, the "FAQ-way"
worked well.
Previously I was wondering, if I could avoid setting it to a specific
directory of mine, because this could be different on others' machine, and
my app is supposed to run on many machines.
regards.
Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477666 is a reply to message #477022] Fri, 08 August 2008 11:16 Go to previous messageGo to next message
Hello there!
I have a problem with the same code, also trying to load resources from
a standalone application.
The code above gives me a
java.lang.ClassCastException:
org.eclipse.uml2.uml.internal.resource.UMLResourceFactoryImp l cannot be
cast to org.eclipse.emf.ecore.resource.Resource$Factory
which seems strange, since UMLResourceFactoryImpl implements
Resource.Factory ...
I use the plugin versions EMF SDK 2.4 (2008/06/09) and UML2 2.1.0
(2008/05/13). Are these incompatible? They are the latest available
versions ...
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477667 is a reply to message #477666] Fri, 08 August 2008 14:41 Go to previous messageGo to next message
UML2 2.2.0 is dependent on EMF 2.4. It looks like you have incompatible
versions.
The download page indicates all the proper depencies ...
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2
- James
"Werner Schindling" <w.schindling@netconomy.et> wrote in message
news:g7ho0p$i4j$1@build.eclipse.org...
> Hello there!
> I have a problem with the same code, also trying to load resources from a
> versions ...
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #477668 is a reply to message #477667] Mon, 11 August 2008 03:39 Go to previous message
You were right, my Tomcat used the wrong libs.
Werner
> versions.
> - James
>> Hello there!
>> versions ...
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #626123 is a reply to message #477018] Mon, 03 March 2008 15:54 Go to previous message
Hi Kenn,
Model umlLibrary =
try {
return package_;
best Regards!
Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #626125 is a reply to message #477019] Mon, 03 March 2008 20:25 Go to previous message
Jinhui,
this:
> Hi Kenn,
> Model umlLibrary =
> try {
> return package_;
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #626126 is a reply to message #477021] Tue, 04 March 2008 05:36 Go to previous message
Hi Kenn,
Jinhui
Resource resource =
true);
Kenn Hussey wrote:
> Jinhui,
> this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #626127 is a reply to message #477022] Tue, 04 March 2008 10:53 Go to previous message
Jinhui,
Kenn
> Hi Kenn,
> Jinhui
> Resource resource =
> true);
> Kenn Hussey wrote:
>> Jinhui,
>> do this:
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #626128 is a reply to message #477023] Tue, 04 March 2008 13:58 Go to previous message
Hi Kenn,
worked well.
regards.
Jinhui
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #626858 is a reply to message #477022] Fri, 08 August 2008 11:16 Go to previous message
Hello there!
versions ...
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #626859 is a reply to message #477666] Fri, 08 August 2008 14:41 Go to previous message
versions.
- James
> Hello there!
> versions ...
Re: [UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY [message #626860 is a reply to message #477667] Mon, 11 August 2008 03:39 Go to previous message
Werner
> versions.
> - James
>> Hello there!
>> versions ...
Previous Topic:LiteralSpecification
Next Topic:Programatic Selection of NamedElement in UMLEditor
Current Time: Wed Jul 23 14:16:53 EDT 2025
Powered by FUDForum. Page generated in 0.06453 seconds
