Home » Modeling » UML2 » ConvertToMetamodelAction makes classifiers private
ConvertToMetamodelAction makes classifiers private [message #476985] |
Mon, 25 February 2008 10:41  |
In using the UML Editor for metamodeling, I find that the "Convert to
Metamodel" action in the editor menu correctly stereotypes my classes as
<<metaclass>> but it also reduces the visibility of my enumerations and
other data types to private.
I see in the action, the UMLSwitch::caseClassifier(Classifier) method is
override to make all non-metaclasses private. This is OK for associations,
but I'd like users of my metamodel to be able to reference my data types.
Why should these have private visibility? Will badness ensue if I change
them back to public visibility?
Christian
Re: ConvertToMetamodelAction makes classifiers private [message #476995 is a reply to message #476985] |
Wed, 27 February 2008 09:17   |
Christian,
This action was originally written to meet the needs of the UML2 metamodel
itself, and is only provided as a sample. In UML, the primitive types are
part of a separate library, so the ones defined in the metamodel are marked
as private to hide them from clients (so as not to cause confusion).
Generally speaking, however, I believe it's intended that types (data types,
primitive types, enumerations, etc.) associated with a profile and "made
available" by applying the profile are maintained in separate libraries, but
of course this is only a guideline and has no semantic force:
It should be possible to define a UML extension that combines profiles and
model libraries (including template libraries) into a single logical unit.
However, within such a unit, for definitional clarity and for ease of
interchange (e.g., 'reference by name'), it should still be possible to keep
the libraries and the profiles distinct from each other.
If you open a Bugzilla report, we could look into changing the action so
that only the associations are made private by default (in which case we
would have to manually make the four primitive types in UML private)...
Kenn
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:fpunjr$1gu$1@build.eclipse.org...
> associations,
> Christian
Re: ConvertToMetamodelAction makes classifiers private [message #477000 is a reply to message #476995] |
Wed, 27 February 2008 09:51   |
Hi, Kenn,
Yes, I had figured that the UML primitive types should be private in the
metamodel, because they are defined as a separate model library. I was
actually surprised to find that the UML specification merges this library
instead of merely importing it (with private visibility). Seems like an
issue for the RTF ...
I'm not sure, though, that one can argue that data types are intended
generally to be defined in model libraries. The UML metamodel, itself,
doesn't do this with its various Enumerations, nor do other standard
metamodels such as OCL or standard profiles such as the UML Testing
Profile.
In any case, I understand this action is contributed by the examples (I was
surprised to find it), and it is quite convenient. It's not difficult to
re-publish the elements that it makes private post facto. However, in case
there should be interest in promoting this action into the SDK in support
of metamodellers like me, find https://bugs.eclipse.org/220558 with a patch
attached.
Christian
Kenn Hussey wrote:
> Christian,
> marked as private to hide them from clients (so as not to cause
> confusion). Generally speaking, however, I believe it's intended that
> types (data types, primitive types, enumerations, etc.) associated with a
> profile and "made available" by applying the profile are maintained in
> separate libraries, but of course this is only a guideline and has no
> semantic force: It should be possible to define a UML extension that
> combines profiles and model libraries (including template libraries) into
> a single logical unit. However, within such a unit, for definitional
> clarity and for ease of interchange (e.g., 'reference by name'), it should
> still be possible to keep the libraries and the profiles distinct from
> each other.
> Cheers,
> Kenn
-----8<-----
Re: ConvertToMetamodelAction makes classifiers private [message #477001 is a reply to message #477000] |
Wed, 27 February 2008 10:15  |
Thanks, we'll address this enhancement ASAP.
Kenn
news:fq3tdi$efb$1@build.eclipse.org...
> Hi, Kenn,
> Profile.
> was
> case
> patch
> attached.
> Christian
> Kenn Hussey wrote:
>> Christian,
>> metamodel
>> should
>> each other.
>> Cheers,
>> Kenn
> -----8<-----
Re: ConvertToMetamodelAction makes classifiers private [message #626098 is a reply to message #476985] |
Christian,
Kenn
> associations,
> Christian
Re: ConvertToMetamodelAction makes classifiers private [message #626103 is a reply to message #476995] |
Hi, Kenn,
Profile.
attached.
Christian
Kenn Hussey wrote:
> Christian,
> each other.
> Cheers,
> Kenn
-----8<-----
Re: ConvertToMetamodelAction makes classifiers private [message #626104 is a reply to message #477000] |
Kenn
> Hi, Kenn,
> Profile.
> was
> case
> patch
> attached.
> Christian
> Kenn Hussey wrote:
>> Christian,
>> metamodel
>> should
>> each other.
>> Cheers,
>> Kenn
> -----8<-----
Current Time: Wed Jul 23 15:32:35 EDT 2025
Powered by FUDForum. Page generated in 0.08705 seconds
