Home » Modeling » UML2 » Re: ChildCreationExtender problem in edit plugin
Re: ChildCreationExtender problem in edit plugin [message #476975] |
Fri, 22 February 2008 10:09  |
Joel,
UML itself has not been regenerated to be extensible, so trying to take
advantage of this won't really help. I wonder if they will consider
doing so?
It seems I got the guard on the extension point completely backwards.
:-( I don't know how that slipped through. I guess because the
plugin.xml isn't regenerated. Please open a bugzilla so I can fix it
for next week's build.
Note that you have to enable this support via options on the
GenPackage. The base needs to be extensible and the derived needs to be
an extender...
Joel Greenyer wrote:
> I have a model extending UML2. I see that the ChildCreationExtenders
> extension is generated with the .edit plugin, but the corresponding
> ChildCreationExtender class does not exist.
> <extension point="org.eclipse.emf.edit.childCreationExtenders">
> <extender
> uri = "http://www.eclipse.org/uml2/2.1.0/UML"
> class =
> "...ItemProviderAdapterFactory$UMLChildCreationExtender" />
> </extension>
> I see that this is a new development as nicely explained by Ed here ;)
> http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html
> However, I have not fully understood what's wrong in this case. Is
> this feature still under development? Or should I look for some
> mistakes in my model? Or is this a UML2-specific problem?
> Thanks for helping!
> Joel
Re: ChildCreationExtender problem in edit plugin [message #476978 is a reply to message #476977] |
Fri, 22 February 2008 11:18   |
--------------000007010308060304050001
James,
Kenn says he already did it. I should have checked. That means Joel is
good to go except he needs to check the GenPackage flag to generate the
class (and since the plugin.xml already has the registration, he won't
notice my stupid bug).
James Bruck wrote:
> Hi Ed,
> Yes indeed that sounds really cool. Joel, perhaps you could raise a defect
> on the UML2 project to regenerate to be extensible and it will be looked
> into.
> Cheers,
> - James.
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:fpmojv$sih$1@build.eclipse.org...
>> Joel,
>> doing so?
>> plugin.xml isn't regenerated. Please open a bugzilla so I can fix it for
>> next week's build.
>> Note that you have to enable this support via options on the GenPackage.
>> The base needs to be extensible and the derived needs to be an extender...
>>> Hi,
>>> <extender
>>> class = "...ItemProviderAdapterFactory$UMLChildCreationExtender"
>>> </extension>
>>> However, I have not fully understood what's wrong in this case. Is this
>>> feature still under development? Or should I look for some mistakes in my
>>> Thanks for helping!
>>> Joel
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
James,<br>
<br>
is good to go except he needs to check the GenPackage flag to generate
the class (and since the plugin.xml already has the registration, he
won't notice my stupid bug).<br>
<br>
James Bruck wrote:
<blockquote cite="mid:fpmq8q$bs8$2@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
into.
- James.
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fpmojv$sih$1@build.eclipse.org">news:fpmojv$sih$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Joel,
doing so?
next week's build.
</pre>
<pre wrap="">Hi,
<extender
uri = <a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/uml2/2.1.0/UML">"http://www.eclipse.org/uml2/2.1.0/UML"</a>
</extension>
<a class="moz-txt-link-freetext" href=" http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html"> http://ed-merks.blogspot.com/2008/01/creating-children-you-d idnt-know.html</a>
Thanks for helping!
Joel
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------000007010308060304050001--
Re: ChildCreationExtender problem in edit plugin [message #476979 is a reply to message #476977] |
Actually, UML2 has been regenerated to be extensible, so you should be good
to go already (e.g. with UML2 M5).
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fpmq8q$bs8$2@build.eclipse.org...
> Hi Ed,
> defect on the UML2 project to regenerate to be extensible and it will be
> looked into.
> Cheers,
> - James.
>> Joel,
>> doing so?
>> next week's build.
>> extender...
>>> Hi,
>>> <extender
>>> </extension>
>>> Thanks for helping!
>>> Joel
Re: ChildCreationExtender problem in edit plugin [message #476981 is a reply to message #476978] |
Fri, 22 February 2008 12:41  |
Great, that does it.
Thanks.
Ed Merks wrote:
> James,
> James Bruck wrote:
>> Hi Ed,
>> into.
>> Cheers,
>> - James.
>>> Joel,
>>> doing so?
>>> next week's build.
>>>> Hi,
>>>> <extender
>>>> </extension>
>>>> Thanks for helping!
>>>> Joel
Re: ChildCreationExtender problem in edit plugin [message #626076 is a reply to message #476975] |
Fri, 22 February 2008 10:37  |
Hi Ed,
into.
- James.
> Joel,
> doing so?
> next week's build.
>> Hi,
>> <extender
>> </extension>
>> Thanks for helping!
>> Joel
Re: ChildCreationExtender problem in edit plugin [message #626077 is a reply to message #476977] |
James,
James Bruck wrote:
> Hi Ed,
> into.
> Cheers,
> - James.
>> Joel,
>> doing so?
>> next week's build.
>>> Hi,
>>> <extender
>>> </extension>
>>> Thanks for helping!
>>> Joel
<html>
<head>
</head>
James,<br>
<br>
<br>
<pre wrap="">Hi Ed,
into.
- James.
</pre>
<pre wrap="">Joel,
doing so?
next week's build.
</pre>
<pre wrap="">Hi,
<extender
</extension>
Thanks for helping!
Joel
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: ChildCreationExtender problem in edit plugin [message #626078 is a reply to message #476977] |
Kenn
> Hi Ed,
> looked into.
> Cheers,
> - James.
>> Joel,
>> doing so?
>> next week's build.
>> extender...
>>> Hi,
>>> <extender
>>> </extension>
>>> Thanks for helping!
>>> Joel
Re: ChildCreationExtender problem in edit plugin [message #626079 is a reply to message #476975] |
Fri, 22 February 2008 11:33  |
Hi, Ed,
From time to time, EMF makes enhancements that require clients like UML to
regenerate their models in order for them actually to be effective.
Can these kinds of changes be communicated in the EMF New & Noteworthy?
They might even be announced on the emf-dev mailing list. I'm not sure
that everybody follows your blog, which is a personal thing and probably
not generally considered to be an extension of the EMF documentation. :-)
Christian
Ed Merks wrote:
> Joel,
> doing so?
> an extender...
-----8<-----
Re: ChildCreationExtender problem in edit plugin [message #626080 is a reply to message #476978] |
Thanks.
Ed Merks wrote:
> James,
> James Bruck wrote:
>> Hi Ed,
>> into.
>> Cheers,
>> - James.
>>> Joel,
>>> doing so?
>>> next week's build.
>>>> Hi,
>>>> <extender
>>>> </extension>
>>>> Thanks for helping!
>>>> Joel
Current Time: Sun Jul 27 14:09:00 EDT 2025
Powered by FUDForum. Page generated in 0.05329 seconds
