stereotypes with MagicDraw [message #476953] |
Tue, 19 February 2008 15:55  |
I am using Magicdraw 15.0, eclipse 3.4M4 emf v. 2.3.1 and uml2 v. 2.1.1. I
have a
UML model designed in Magicrdaw and then exported as UML2 (2.x ) EMF model.
In order to use emf and uml2 libraries as standalone I am following the
instrucitons given in:
http://dev.eclipse.org/newslists/news.eclipse.tools.uml2/msg 00833.html
My goal is to perform code generation based on the model stereotypes (using
EMF, UML2 libraries and Velocity templates). However, I am facing some
parsing
problems. The stereotypes used in classes, operations, etc, cannot be read
by
the relevant operation ( element.getAppliedStereotypes()), although they do
appear as applied stereotypes in the exported .uml2 files from Magicdraw.
It is a bug? Of Uml or Magicdraw?
Thanks in advance.
Netuh
Re: stereotypes with MagicDraw [message #476960 is a reply to message #476953] |
Wed, 20 February 2008 16:58  |
Hi Waldemar,
That seems like a rather old posting you make reference to. You might want
to have a look at the code at the bottom of this article..
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
Also, to determine if your profile is bogus or not, you might want to try to
open it up and apply it using the UML2 sample editor.
If your profile can be applied using the UML2 editor (ie. its good) and you
are still having problems with your standalone application please repost a
question and we can have a more detailed look at it.
- James.
"waldemar neto" <waldemar.neto@gmail.com> wrote in message
news:c45731130f98c0038aa0a38085f8c15e$1@www.eclipse.org...
>have a
> model.
> (using
> parsing
> by
> do
> Thanks in advance.
> Netuh
Re: stereotypes with MagicDraw [message #626059 is a reply to message #476953] |
Hi Waldemar,
- James.
>have a
> model.
> (using
> parsing
> by
> do
> Thanks in advance.
> Netuh
FUDForum. Page generated in 0.04369 seconds
