Home » Modeling » UML2 » xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ?
xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ? [message #476889] |
Tue, 29 January 2008 04:32  |
is it possible to use EMF / UML2 to downgrade an UML 2.0/2.1 model serialized as XMI 2.1 to a UML 1.3 model serialized as XMI 1.1 ?
The original model consists of an XMI, UML, and EMX file.
I can correctly load the XMI file and show the XMI version using getXMIVersion().
Unfortunately, setXMIVersion() only seems to change the XMI version field, it doens't instruct EMF/UML2 to write XMI 1.1 ...
I stumbled over http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html#_Migration
but that seems more appropriate for UML 2.0 -> UML 2.1.1 conversions?
An alternative would be to write an XSLT script which extracts/converts the part I need.
Rene
Re: xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ? [message #476895 is a reply to message #476894] |
Tue, 29 January 2008 09:56  |
James Bruck wrote:
> Hi Rene,
> Downgrading from UML 2.0 to UML 1.3 is not supported by this opensource
> project so if you need this capability you will have to extract the
> information yourself.
Ok ...
> Keep in mind that the UML metamodel has changed quite dramatically between
> those versions. If you intend to do this migration I would expect there to
> be a loss of data.
I expect some data loss too, but not all data is important for the task at hand.
> Also have a look at
> http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 1_Migration_Guide/guide.html
> in addition to the one you found
> Cheers,
> - James.
> "Rene Ladan" <r.c.ladan@tue.nl> wrote in message
> news:fnmrqq$qa$1@build.eclipse.org...
>> Hi,
>> getXMIVersion().
>> I stumbled over
>> the part I need.
>> Thanks,
>> Rene
Re: xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ? [message #625951 is a reply to message #476894] |
James Bruck wrote:
> Hi Rene,
Ok ...
> be a loss of data.
> Also have a look at
> Cheers,
> - James.
>> Hi,
>> getXMIVersion().
>> I stumbled over
>> the part I need.
>> Thanks,
>> Rene
Current Time: Sun Jul 27 15:37:07 EDT 2025
Powered by FUDForum. Page generated in 0.04826 seconds
