extents in UML [message #476882] |
Fri, 25 January 2008 11:00  |
Hi All,
Does UML's ReadExtentAction return only instances
of a given classifier or also instances of its specializations?
I cannot find this in the specification.
Thanks in advance,
Krzysztof
Re: extents in UML [message #476891 is a reply to message #476882] |
Tue, 29 January 2008 07:25  |
Hi, Krzysztof,
As I replied in the OCL newsgroup, I repeat here for the benefit (if it is
such) of the UML2 audience.
From the Semantics of Classifier metaclass in the 2.1 Superstructure:
"A Classifier may participate in generalization relationships
with other Classifiers. An instance of a specific Classifier
is also an (indirect) instance of each of the general
Classifiers."
And from the Semantics of ReadExtentAction:
"The extent of a classifier is the set of all instances of a
classifier that exist at any one time."
From these two statements, as long as the term "instance" means the same in
both, I conclude that the extent of a classifier includes the extents of
its specializations. i.e., the second alternative that you indicate in your
question.
HTH,
Christian
Krzysztof Kaczmarski wrote:
> Hi All,
> Thanks in advance,
> Krzysztof
Re: extents in UML [message #625947 is a reply to message #476882] |
Hi, Krzysztof,
Classifiers."
question.
HTH,
Christian
> Hi All,
> Thanks in advance,
> Krzysztof
FUDForum. Page generated in 0.25685 seconds
