Home » Modeling » UML2 » Ecore 2 UML
Ecore 2 UML [message #476886] |
Mon, 28 January 2008 23:55  |
Is there an easy way to import an Ecore into UML2? I just need the
class diagram subset of UML, which Ecore closely resembles.
The reason I ask is because I have a bunch of Ecore models and I would
like to render them (as diagrams in my thesis) and none of Ecore diagram
tools shows the ordered attribute, however, most of the UML tools do.
Ian
Re: Ecore 2 UML [message #476897 is a reply to message #476890] |
Tue, 29 January 2008 13:28   |
I am Using Topcased Ecore and UML graphical viewers. Their Ecore tool
is GREAT! The only problem is, there ecore editor doesn't show the
{ordered} annotations, but their UML tool does. (not really a big
issue, but I know I will get asked about this if I don't include it).
Plus the export to PDF works slightly better on the UML viewer than the
Ecore one.
Once I figure out if these editors are making up the new Ecore Tools, I
will open up a feature request for this.
Ian
Ed Merks wrote:
> Ian,
> What about EMFT's Ecore Tools project? That lets you render a diagram
> directly for the Ecore model without need for UML.
> SKuhn wrote:
>> did you try the uml export in the genmodel?
>> -stefan
>>> would like to render them (as diagrams in my thesis) and none of
>>> Ecore diagram tools shows the ordered attribute, however, most of the
>>> UML tools do.
>>> Cheers,
>>> Ian
Re: Ecore 2 UML [message #477027 is a reply to message #476887] |
Wed, 05 March 2008 10:46   |
Originally posted by: joerg.von.frantzius.artnology.com
I kept on looking for this for quite a while now, installed all features
seeming relevant, but I can't find this export (or import) feature for
converting ecore to uml2.
Could anybody please tell please what feature exactly this is part of
(e.g. "UML2 Tools"?), and how I can access it in Eclipse? Is that
right-click .ecore or .genmodel file, choose "Export..." and then there
should be "UML2" somewhere?
Thanks for any hints,
Jörg
> -stefan
>> UML tools do.
>> Cheers,
>> Ian
Re: Ecore 2 UML [message #477028 is a reply to message #477027] |
Wed, 05 March 2008 10:56   |
Hi, Jörg,
If you have the UML2 SDK installed (not UML2Tools), then you can export a
UML model from any EMF model (*.genmodel).
Make sure that your configuration includes the
org.eclipse.uml2.uml.ecore.exporter plug-in.
Then, in the Generator editor for a *.genmodel (possibly sourced from
Ecore), select the "Generator -> Export Model..." action in the main menu
bar. In the export wizard, select the "UML model" option and proceed from
there.
HTH,
Christian
Jörg von Frantzius wrote:
> Jörg
>> -stefan
>>> UML tools do.
>>> Cheers,
>>> Ian
Re: Ecore 2 UML [message #477030 is a reply to message #477028] |
Wed, 05 March 2008 11:15   |
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Alright, I didn't look at the "Generator" menu in the main menu bar!<br>
<br>
Thanks for your answer!<br>
<br>
Christian W. Damus schrieb:
<blockquote cite="mid:fqmfqt$ev2$1@build.eclipse.org" type="cite">
<pre wrap="">Hi, Jörg,
there.
HTH,
Christian
</pre>
<blockquote type="cite">
<pre wrap="">Hi,
Jörg
SKuhn schrieb:
</pre>
<pre wrap="">did you try the uml export in the genmodel?
-stefan
Ian Bull wrote:
</pre>
<pre wrap="">Is there an easy way to import an Ecore into UML2? I just need the
UML tools do.
Ian
</pre>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
Re: Ecore 2 UML [message #477031 is a reply to message #477029] |
Wed, 05 March 2008 11:17  |
<html>
<head>
</head>
OK, now that's two menu entries I hadn't seen :)<br>
<br>
I had only been looking at the general "Export..." context menu entry.
Thanks for the hint.<br>
<br>
Kenn Hussey schrieb:
<blockquote cite="mid:fqmgha$m0q$1@build.eclipse.org" type="cite">
<pre wrap="">There should also be an 'Export Model...' context menu item available when
the generator model is selected in the Package Explorer view...
Kenn
"Christian W. Damus" <a class="moz-txt-link-rfc2396E" href="mailto:cdamus@ca.ibm.com"><cdamus@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fqmfqt$ev2$1@build.eclipse.org">news:fqmfqt$ev2$1@build.eclipse.org</a>...
</pre>
there.
HTH,
Christian
</pre>
<pre wrap="">Hi,
Jörg
SKuhn schrieb:
</pre>
-stefan
Ian Bull wrote:
</pre>
UML tools do.
Ian
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: Ecore 2 UML [message #625943 is a reply to message #476886] |
Tue, 29 January 2008 02:17  |
-stefan
> Cheers,
> Ian
Re: Ecore 2 UML [message #625946 is a reply to message #476887] |
Tue, 29 January 2008 07:01  |
Ian,
> -stefan
>> UML tools do.
>> Cheers,
>> Ian
Re: Ecore 2 UML [message #625952 is a reply to message #476887] |
Tue, 29 January 2008 13:15  |
Thanks Stefan,
This is exactly what I was looking for. I thought it would be through
an import, but this makes sense too.
It also answered my question of where did the export XML schema go :-).
Ian
> -stefan
>> diagram tools shows the ordered attribute, however, most of the UML
>> tools do.
>> Cheers,
>> Ian
Re: Ecore 2 UML [message #625953 is a reply to message #476890] |
Ecore one.
Ian
Ed Merks wrote:
> Ian,
>> -stefan
>>> UML tools do.
>>> Cheers,
>>> Ian
Re: Ecore 2 UML [message #626143 is a reply to message #476887] |
Jörg
> -stefan
>> UML tools do.
>> Cheers,
>> Ian
Re: Ecore 2 UML [message #626144 is a reply to message #477027] |
Hi, Jörg,
there.
HTH,
Christian
> Jörg
>> -stefan
>>> UML tools do.
>>> Cheers,
>>> Ian
Re: Ecore 2 UML [message #626146 is a reply to message #477028] |
<html>
<head>
</head>
<br>
<br>
there.
HTH,
Christian
</pre>
<pre wrap="">Hi,
Jörg
SKuhn schrieb:
</pre>
-stefan
Ian Bull wrote:
</pre>
UML tools do.
Ian
</pre>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Re: Ecore 2 UML [message #626147 is a reply to message #477029] |
<html>
<head>
</head>
<br>
<br>
Kenn
</pre>
there.
HTH,
Christian
</pre>
<pre wrap="">Hi,
Jörg
SKuhn schrieb:
</pre>
-stefan
Ian Bull wrote:
</pre>
UML tools do.
Ian
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</body>
</html>
Current Time: Wed Jul 23 23:32:42 EDT 2025
Powered by FUDForum. Page generated in 0.52522 seconds
