Home » Modeling » M2T (model-to-text transformation) » Model-To-Text-Language (MTL) Implementation
Model-To-Text-Language (MTL) Implementation [message #47648] Wed, 16 July 2008 08:04 Go to next message
Hi all,
yesterday, i've read the MTL-Spec from the OMG, which seems to be a good try
for a one-in-all solution for code generation. According to the roadmap of
the M2T-Project and complete implementation of the spec will be published in
June 2009. Is it possible to volunteer myself for testing an early alpha
version of the project, when it is released? I'm very interesting in this
implementation.
Greetings
Timothy
Re: Model-To-Text-Language (MTL) Implementation [message #47678 is a reply to message #47648] Wed, 16 July 2008 11:00 Go to previous messageGo to next message
We will build a first version in the next few weeks (august)
but you can try to checkout the following projects
" org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.engi ne "
" org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.ide. ui "
" org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.mode l "
" org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.pars er "
" org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl.comm on "
" org.eclipse.m2t/org.eclipse.mtl/plugins/org.eclipse.mtl-feat ure "
Host : dev.eclipse.org
Repository Path : /cvsroot/modeling
You need to install MDT OCL plugin
You have examples in "*.tests" projects
You can search "*.mtl" files
A Java File, and 2 ANT files are automatically created when you compile
a template that contains a "[file...]" block
You just have to rename the "*.sample" file (-> "generate.xml" for example)
Put it in the target project and call it with "External Tools > Run As >
Ant Build"
You have to change the "MODEL" and the "TARGET" values
At the moment, you need to refresh the workspace at the end of the
generation
Jonathan Musset
Timothy Marc a écrit :
> Hi all,
> implementation.
> Greetings
> Timothy
Re: Model-To-Text-Language (MTL) Implementation [message #47878 is a reply to message #47678] Thu, 17 July 2008 07:29 Go to previous messageGo to next message
Dear Jonathan,
thank you for your answer. I think, i will have the time to wait for the
build of the first version. Is that early version available for anyone, or
just for project members?
Thx
--Timothy
"Jonathan MUSSET" <jonathan.musset@obeo.fr> schrieb im Newsbeitrag
news:487E0D1B.3060504@obeo.fr...
> A Java File, and 2 ANT files are automatically created when you compile a
> example)
> Ant Build"
> generation
> Regards,
> Jonathan Musset
> Timothy Marc a
Re: Model-To-Text-Language (MTL) Implementation [message #47908 is a reply to message #47878] Thu, 17 July 2008 09:12 Go to previous messageGo to next message
Of course, it will be a public version
> Dear Jonathan,
> Thx
> --Timothy
>> Hi,
>> example)
>> Ant Build"
>> generation
>> Regards,
>> Jonathan Musset
>>> Hi all,
>>> try for a one-in-all solution for code generation. According to the
>>> roadmap of the M2T-Project and complete implementation of the spec will
>>> be published in June 2009. Is it possible to volunteer myself for testing
>>> an early alpha version of the project, when it is released? I'm very
>>> interesting in this implementation.
>>> Greetings
>>> Timothy
Re: Model-To-Text-Language (MTL) Implementation [message #48496 is a reply to message #47908] Mon, 11 August 2008 03:58 Go to previous message
You can get the last build on the website (I200808081155) :
http://www.eclipse.org/modeling/m2t/downloads/?project=mtl
Jonathan
>> Dear Jonathan,
>> the build of the first version. Is that early version available for
>> anyone, or just for project members?
>> Thx
>> --Timothy
>>> Hi,
>>> compile a template that contains a "[file...]" block
>>> example)
>>> As > Ant Build"
>>> generation
>>> Regards,
>>> Jonathan Musset
>>>> Hi all,
>>>> good try for a one-in-all solution for code generation. According to
>>>> the roadmap of the M2T-Project and complete implementation of the
>>>> spec will be published in June 2009. Is it possible to volunteer
>>>> myself for testing an early alpha version of the project, when it is
>>>> released? I'm very interesting in this implementation.
>>>> Greetings
>>>> Timothy
Previous Topic:MTL Project - first evaluation
Next Topic:JET and JET2
Current Time: Sat Sep 20 03:30:06 EDT 2025
Powered by FUDForum. Page generated in 0.05362 seconds
