Home » Modeling » UML2 » [UML2] Empty list of stereotypes
[UML2] Empty list of stereotypes [message #476688] Thu, 29 November 2007 12:44 Go to next message
I have a model and a profile, both stored together in one file. In the
UML Model Editor inside Eclipse, I can browse the file like intended.
But when I try to load the file programmaticaly, I can not see the
applied stereotype. The following code produces no exceptions or warnings:
EPackage.Registry.INSTANCE.put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).
put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource =
resourceSet.getResource(URI.createFileURI(
"models/example.uml"), true);
Object obj = EcoreUtil.getObjectByType(resource.getContents(),
UMLPackage.Literals.MODEL);
Model model = (Model) obj;
if(model != null) {
System.out.println(model.toString());
System.out.println(model.getAppliedStereotypes().toString()) ;
What's wrong with the code? I think the model/profile file must be
correct, because the UML Model Editor shows the expected structure.
Sebastian
My model/profile file:
<xmi:XMI xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:SysML=" http://saab_approach1/schemas/SysML/_lUh30524EdytSYwcMVoawA/ 0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML"
xsi:schemaLocation=" http://saab_approach1/schemas/SysML/_lUh30524EdytSYwcMVoawA/ 0
#_lXz26J24EdytSYwcMVoawA">
<uml:Model xmi:id="_lXqEUJ24EdytSYwcMVoawA" name="Model1">
<packagedElement xmi:type="uml:Package"
xmi:id="_lXz1p524EdytSYwcMVoawA" name="Package1"/>
<packagedElement xmi:type="uml:Profile"
xmi:id="_lXz25p24EdytSYwcMVoawA" name="SysML"
metaclassReference="_lXz27J24EdytSYwcMVoawA">
<eAnnotations xmi:id="_lXz25524EdytSYwcMVoawA"
source="http://www.eclipse.org/uml2/2.0.0/UML">
<contents xmi:type="ecore:EPackage"
xmi:id="_lXz26J24EdytSYwcMVoawA" name="SysML"
nsURI=" http://saab_approach1/schemas/SysML/_lUh30524EdytSYwcMVoawA/ 0"
nsPrefix="SysML">
<eClassifiers xmi:type="ecore:EClass"
xmi:id="_lXz26Z24EdytSYwcMVoawA" name="SysML">
<eAnnotations xmi:id="_lXz26p24EdytSYwcMVoawA"
references="_lXz27Z24EdytSYwcMVoawA"/>
<eStructuralFeatures xmi:type="ecore:EReference"
xmi:id="_lXz26524EdytSYwcMVoawA" name="base_Model" ordered="false"
lowerBound="1">
<eType xmi:type="ecore:EClass"
href="http://www.eclipse.org/uml2/2.1.0/UML#//Model"/>
</eStructuralFeatures>
</eClassifiers>
</contents>
</eAnnotations>
<packagedElement xmi:type="uml:Extension"
xmi:id="_lXz4Yp24EdytSYwcMVoawA" name="Model_SysML"
memberEnd="_lXz4Y524EdytSYwcMVoawA _lXz27p24EdytSYwcMVoawA">
<ownedEnd xmi:type="uml:ExtensionEnd"
xmi:id="_lXz4Y524EdytSYwcMVoawA" name="extension_SysML"
type="_lXz27Z24EdytSYwcMVoawA" aggregation="composite"
association="_lXz4Yp24EdytSYwcMVoawA"/>
</packagedElement>
<elementImport xmi:id="_lXz27J24EdytSYwcMVoawA">
<importedElement xmi:type="uml:Class"
href="http://www.eclipse.org/uml2/2.1.0/UML#Model"/>
</elementImport>
<packagedElement xmi:type="uml:Stereotype"
xmi:id="_lXz27Z24EdytSYwcMVoawA" name="SysML">
<ownedAttribute xmi:id="_lXz27p24EdytSYwcMVoawA"
name="base_Model" association="_lXz4Yp24EdytSYwcMVoawA">
<type xmi:type="uml:Class"
</ownedAttribute>
</packagedElement>
</packagedElement>
<profileApplication xmi:id="_lXz4n524EdytSYwcMVoawA"
appliedProfile="_lXz25p24EdytSYwcMVoawA">
<eAnnotations xmi:id="_lXz4oJ24EdytSYwcMVoawA"
references="_lXz26J24EdytSYwcMVoawA"/>
</profileApplication>
</uml:Model>
<SysML:SysML xmi:id="_lXz4pZ24EdytSYwcMVoawA"
base_Model="_lXqEUJ24EdytSYwcMVoawA"/>
</xmi:XMI>
Re: [UML2] Empty list of stereotypes [message #476691 is a reply to message #476688] Fri, 30 November 2007 13:54 Go to previous messageGo to next message
Interesting model, it seems you did not create a metamodel reference to uml
(at least I can't see it). My editor is having a hard time showing the kind
of element you want your stereotype to extend but the Ecore representation
seems to be fine (which is what matters). (I also cannot see the metamodel
reference).
It is not immediately obvious why the editor works and your code snippet
doesn't. I believe you are running in a stand-alone application (otherwise
there would be no need to register the items you have registered).
Try looking at the code snippet in this article (near the end):
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
You might have overlooked registering some goodies.
If after trying the code in the above mentioned article still doesn't work,
then we can go through this step by step.
- James.
"bfeater" <sgebhardt1@gmx.de> wrote in message
news:fimtpb$lq9$1@build.eclipse.org...
> I have a model and a profile, both stored together in one file. In the UML
> Model Editor inside Eclipse, I can browse the file like intended. But when
> I try to load the file programmaticaly, I can not see the applied
> Resource resource =
> if(model != null) {
> Best regards,
> Sebastian
> <xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
> nsPrefix="SysML">
> lowerBound="1">
> </eClassifiers>
> </contents>
> </eAnnotations>
> </packagedElement>
> </elementImport>
> <ownedAttribute xmi:id="_lXz27p24EdytSYwcMVoawA" name="base_Model"
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </uml:Model>
> </xmi:XMI>
Re: [UML2] Empty list of stereotypes [message #476693 is a reply to message #476691] Mon, 03 December 2007 05:58 Go to previous message
Thanks for your repley.
Changing the instruction
URI.createFileURI("infile.uml");
to
URI.createFileURI(new java.io.File("infile.uml").getAbsolutePath());
makes the code working. The problem seems to be something with the path
resolution. Using the absolute path the profile (in the same file) is found.
James Bruck schrieb:
> reference).
> Cheers,
> - James.
>> Hi,
>> Resource resource =
>> if(model != null) {
>> Best regards,
>> Sebastian
>> <?xml version="1.0" encoding="UTF-8"?>
>> nsPrefix="SysML">
>> lowerBound="1">
>> </eClassifiers>
>> </contents>
>> </eAnnotations>
>> </packagedElement>
>> </elementImport>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </uml:Model>
>> </xmi:XMI>
Re: [UML2] Empty list of stereotypes [message #625662 is a reply to message #476688] Fri, 30 November 2007 13:54 Go to previous message
reference).
- James.
> Resource resource =
> if(model != null) {
> Best regards,
> Sebastian
> nsPrefix="SysML">
> lowerBound="1">
> </eClassifiers>
> </contents>
> </eAnnotations>
> </packagedElement>
> </elementImport>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </uml:Model>
> </xmi:XMI>
Re: [UML2] Empty list of stereotypes [message #625664 is a reply to message #476691] Mon, 03 December 2007 05:58 Go to previous message
to
> reference).
> Cheers,
> - James.
>> Hi,
>> Resource resource =
>> if(model != null) {
>> Best regards,
>> Sebastian
>> nsPrefix="SysML">
>> lowerBound="1">
>> </eClassifiers>
>> </contents>
>> </eAnnotations>
>> </packagedElement>
>> </elementImport>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </uml:Model>
>> </xmi:XMI>
Previous Topic:UML2 / Sequence diagram / MessageKind
Next Topic:How to make XML simple types available for UML models?.
Current Time: Fri Aug 29 18:08:37 EDT 2025
Powered by FUDForum. Page generated in 0.03491 seconds
