Home » Modeling » UML2 » Declare an array type
Declare an array type [message #476673] Tue, 27 November 2007 15:25 Go to next message
Originally posted by: luciananegri81.yahoo.it
I have add in Uml Metamodel (written through graphical interface
'Sample Ecore Model Editor') a metaclass where EAttribute is an Array
data type. Is it possible? How can I do?
Luciana
Re: Declare an array type [message #476674 is a reply to message #476673] Tue, 27 November 2007 15:58 Go to previous messageGo to next message
Luciana,
In Ecore itself you'd just define an EDataType whose instance class in
an array. E.g., the instance type of EByteArray is "byte[]". You
might define MyStringArray to have type "java.lang.String[]". I'm not
sure how to do that in UML...
Luciana wrote:
> Thanks
> Luciana
Re: Declare an array type [message #476675 is a reply to message #476674] Tue, 27 November 2007 16:33 Go to previous messageGo to next message
Hi Ed,
in the metamodel I have only type <java.lan.string> and not
<java.lang.string[]>. Can I import the latter in any way?
thank you
Luciana
Re: Declare an array type [message #476676 is a reply to message #476675] Tue, 27 November 2007 17:17 Go to previous messageGo to next message
Luciana,
I'm not even sure if you're talking about Ecore or UML. In either case,
I think you need to define your own EDataType or whatever it is in UML
because I don't think it will just exist for you already.
Luciana wrote:
> Hi Ed,
> thank you
> Luciana
Re: Declare an array type [message #476677 is a reply to message #476676] Tue, 27 November 2007 17:57 Go to previous messageGo to next message
I'm talking about Ecore.
I have try to declare a metaclass with an EReference with
molteplicity 0..* of type MyArray, but when I istance the model
I can't insert the value.
Now, I try to repeat everything.
Thank you very much.
Luciana
Re: Declare an array type [message #476681 is a reply to message #476677] Wed, 28 November 2007 08:21 Go to previous messageGo to next message
--------------040508080200050305080605
Luciana,
An EReference's eType must be an EClass so it sounds to me like you need
an EAttribute. Note also that by default, the EDataType you define
based on an array type will serialize using java.io.Serializeable which
is not human readable, so likely you will want to specialize the
createMyArrayFromString and converterMyArrayToString methods to use a
human readable result. Note that it's best to ask about Ecore on the
EMF newsgroup.
news://news.eclipse.org/eclipse.tools.emf
Luciana wrote:
> molteplicity 0..* of type MyArray, but when I istance the model I
> Luciana
<html>
<head>
http-equiv="Content-Type">
</head>
Luciana,<br>
<br>
need an EAttribute.
Re: Declare an array type [message #476685 is a reply to message #476681] Wed, 28 November 2007 11:06 Go to previous message
Thank you very much,
I will also ask about Ecore in EMF newsgroup.
Luciana
Re: Declare an array type [message #625574 is a reply to message #476673] Tue, 27 November 2007 15:58 Go to previous message
Luciana,
Luciana wrote:
> Thanks
> Luciana
Re: Declare an array type [message #625575 is a reply to message #476674] Tue, 27 November 2007 16:33 Go to previous message
Hi Ed,
thank you
Luciana
Re: Declare an array type [message #625576 is a reply to message #476675] Tue, 27 November 2007 17:17 Go to previous message
Luciana,
Luciana wrote:
> Hi Ed,
> thank you
> Luciana
Re: Declare an array type [message #625577 is a reply to message #476676] Tue, 27 November 2007 17:57 Go to previous message
Luciana
Re: Declare an array type [message #625652 is a reply to message #476677] Wed, 28 November 2007 08:21 Go to previous message
Luciana,
EMF newsgroup.
Luciana wrote:
> Luciana
<html>
<head>
</head>
Luciana,<br>
<br>
need an EAttribute.
Re: Declare an array type [message #625656 is a reply to message #476681] Wed, 28 November 2007 11:06 Go to previous message
Luciana
Previous Topic:New version of Groovy EMFBuilder supports UML2 models
Next Topic:[Announce] MDT UML2 2.2.0 I200711291020 is available
Current Time: Sat Jul 19 00:05:06 EDT 2025
Powered by FUDForum. Page generated in 0.25836 seconds
