Stereotype property typed with other stereotype [message #476667] |
Fri, 23 November 2007 16:34  |
Originally posted by: luciananegri81.yahoo.it
I have extend the UML Metamodel (it is .Ecore file)
with a stereotype where the type of stereotype property
is another stereotype and evaluate
from another.
How must I add the classes in my metamodel?
Luciana
Re: Stereotype property typed with other stereotype [message #476678 is a reply to message #476670] |
Tue, 27 November 2007 20:46   |
Hi Luciana,
If the Stereotype that you wish to set as the type of the property in
question is in the same profile, then you should see it as an option when
you try to set the type from the editor.
Currently, setting the type to a stereotype in a separate profile is not
supported.
And, yes, you can apply any number of stereotypes to an element ( discussed
in section 18 of the UML superstructure spec ).
- James
"Luciana" <luciananegri81@yahoo.it> wrote in message
news:b3a086b9c4710bcbe05bcf3ffd1fd7ca$1@www.eclipse.org...
> Hi James, about the last sentency I wanted to say as I add the metaclasses
> which represent the stereotype in UML Metamodel and particulary how set
> (in the graphical interface "sample ecore model editor") the value of the
> property typed by other stereotype.
> I don't succeed in understanding the mechanism, however I see the article
> that you have recommended me.
> I want to also ask you another thing: is it possible to extend one
> metaclass whit two different stereotype? If it's possible, when (in the
> model) I instance the class which stereotype I must use?
> Thank you very much
> Luciana.
Re: Stereotype property typed with other stereotype [message #625570 is a reply to message #476669] |
Mon, 26 November 2007 12:49  |
Hi James,
about the last sentency I wanted to say as I add the metaclasses which
represent the stereotype in UML Metamodel and particulary how set (in the
graphical interface "sample ecore model editor") the value of the property
Thank you very much
Luciana.
Re: Stereotype property typed with other stereotype [message #625578 is a reply to message #476670] |
Hi Luciana,
supported.
- James
> Thank you very much
> Luciana.
FUDForum. Page generated in 0.04902 seconds
