Code generated from UML with OCL [message #476644] |
Fri, 16 November 2007 15:22  |
Today I tried to generate code from a metamodel defined in UML. I ran
into a problem when I added OCL expressions that contain line breaks.
The code generator doesn't handle this well because I ended up with
invalid Java code. Here's what I get when generating code for class
Namespace from the UML metamodel.
String ...__EOCL_EXP = "result = self.member->forAll( memb |
self.member->excluding(memb)->forAll(other |
memb.isDistinguishableFrom(other, self)))";
The OCL expression is copied into the Java file as is including line
breaks, which leads to compile errors. Is this a bug, or is there a way
to get the code generator to strip line breaks from OCL expressions? If
possible, I would like to keep the OCL in my metamodel formatted for
better readability.
I use Eclipse 3.3.0, UML2 2.1.1, EMF 2.3.1.
Lutz
Re: Code generated from UML with OCL [message #476645 is a reply to message #476644] |
Mon, 19 November 2007 09:46  |
Hi Lutz,
That would indeed appear to be a bug. Please raise a defect on this and it
will be addressed.
- James.
"Lutz Wrage" <lwrage@sei.cmu.edu> wrote in message
news:fhku6d$i7j$1@build.eclipse.org...
> Today I tried to generate code from a metamodel defined in UML. I ran into
> a problem when I added OCL expressions that contain line breaks. The code
> generator doesn't handle this well because I ended up with invalid Java
> code. Here's what I get when generating code for class Namespace from the
> UML metamodel.
> breaks, which leads to compile errors. Is this a bug, or is there a way to
> better readability.
> Lutz
Re: Code generated from UML with OCL [message #625545 is a reply to message #476644] |
Hi Lutz,
will be addressed.
- James.
> UML metamodel.
> better readability.
> Lutz
FUDForum. Page generated in 0.04107 seconds
