Home » Modeling » UML2 Tools » Setting Line Width
Setting Line Width [message #476567] Sun, 28 June 2009 22:20 Go to next message
How do you set the line width in a UML class diagram. When I select a line
and then select the menu item for Line Width all the choices (One Point, Two
Points etc) are disabled. I am running on Windows. Thanks
Re: Setting Line Width [message #476572 is a reply to message #476567] Tue, 30 June 2009 14:08 Go to previous message
Hello David,
Thank you for pointing to the problem. It repeats on my machine too.
I've submitted bug #282051 'Cannot change LineWidth'. I am inverstigating
it now.
Best wishes,
Tanya.
> line and then select the menu item for Line Width all the choices (One
> Point, Two Points etc) are disabled. I am running on Windows. Thanks
Re: Setting Line Width [message #624510 is a reply to message #476567] Tue, 30 June 2009 14:08 Go to previous message
Hello David,
it now.
Best wishes,
Tanya.
Previous Topic:Re: i can't specify type for parameter to add
Next Topic:Re: i can't specify type for parameter to add
Current Time: Sat Jul 26 12:54:54 EDT 2025
Powered by FUDForum. Page generated in 0.05751 seconds
