Home » Modeling » UML2 » How to programmatically add an element as an owned element of another
How to programmatically add an element as an owned element of another [message #476536] |
Wed, 14 November 2007 05:48  |
Given a new element (E.g., a CreateObjectAction), and an existing element
(E.g., Activity), I need to set the CreateObjectAction as a child or owned
element of the Activity. I tried using
Activity.getOwnedElements().add(theCreateObjectAction) and also
allOwnedElements().add() but I get a UnsupportedOperationException. Need
help on the right API to use.
Francis
Re: How to programmatically add an element as an owned element of another [message #476542 is a reply to message #476536] |
Wed, 14 November 2007 23:19   |
Francis,
The ownedElement and allOwnedElement features are derived unions, and hence,
by definition, read-only. Try using Activity#createNode(String, EClass), or
if the action has already been created, you could add to the list returned
from Activity#getNodes().
Kenn
"Francis" <fgavino@gmail.com> wrote in message
news:48051760056b57a633176dcb8d74db34$1@www.eclipse.org...
> Francis
Re: How to programmatically add an element as an owned element of another [message #476635 is a reply to message #476542] |
Thu, 15 November 2007 15:55  |
Francis,
To figure out if the collection you would like to add items to is derived
( and you actually have a life and don't want to figure this out from the
superstructure spec) then you can have a quick look at the interface at the
getter for the '@model' tag where derived=true. Derived unions calculate
their values from other properties that are defined to subset it. You can
also find subset information in the interface ( new in the M3 milestone ).
- James.
"Kenn Hussey" <Kenn.Hussey@embarcadero.com> wrote in message
news:fhghbv$anl$1@build.eclipse.org...
> Francis,
> hence, by definition, read-only. Try using Activity#createNode(String,
> EClass), or if the action has already been created, you could add to the
> list returned from Activity#getNodes().
> Kenn
>> Hi,
>> owned element of the Activity. I tried using
>> Thanks,
>> Francis
Re: How to programmatically add an element as an owned element of another [message #625464 is a reply to message #476536] |
Francis,
Kenn
> Francis
Re: How to programmatically add an element as an owned element of another [message #625473 is a reply to message #476542] |
Francis,
- James.
> Francis,
> Kenn
>> Hi,
>> Thanks,
>> Francis
Current Time: Sat Aug 30 22:35:11 EDT 2025
Powered by FUDForum. Page generated in 0.03230 seconds
