Home » Modeling » UML2 » Programmatically retrieving applicable profiles
Programmatically retrieving applicable profiles [message #476458] Wed, 07 November 2007 06:22 Go to next message
Originally posted by: jp.schoch.fr.ibm.com
In earlier versions of the UML2 API, I thought it was possible to
retrieve all applicable profiles for a model or package (with something
like model.getApplicableProfiles()). This seems to be no longer the
case: I can access applied profiles, and I can apply a profile, but I
just don't know how to retrieve the applicable/deployed profiles... Any
help would be greatly appreciated.
JP
Re: Programmatically retrieving applicable profiles [message #476523 is a reply to message #476458] Wed, 07 November 2007 10:36 Go to previous messageGo to next message
Are you thinking of Element::getApplicableStereotypes() or
Element::isStereotypeApplicable() perhaps?
- James.
"JP Schoch" <jp.schoch@fr.ibm.com> wrote in message
news:fgs74j$ch9$1@build.eclipse.org...
> In earlier versions of the UML2 API, I thought it was possible to retrieve
> all applicable profiles for a model or package (with something like
> model.getApplicableProfiles()). This seems to be no longer the case: I can
> access applied profiles, and I can apply a profile, but I just don't know
> how to retrieve the applicable/deployed profiles... Any help would be
> Regards
> JP
Re: Programmatically retrieving applicable profiles [message #476526 is a reply to message #476523] Mon, 12 November 2007 05:52 Go to previous messageGo to next message
No, I really want to apply a deployed profile programmatically. I know
how to retrieve a profile from my workspace and apply it, but I don't
know how to retrieve deployed profiles.
Cheers
JP
> Cheers,
> - James.
>> Regards
>> JP
Re: Programmatically retrieving applicable profiles [message #476533 is a reply to message #476526] Tue, 13 November 2007 09:24 Go to previous messageGo to next message
Hi JP,
To my knowledge there never existed a function called
model.getApplicableProfiles().
There is a function in ApplyProfileAction that looks at all the resources in
a resource set and if thre is a profile it presents it as a choice to be
chosen. You might want to look at that.
Otherwise applying a profile that is deployed or not is identical. You
need to load the profile as a resource, get at the profile therein, and then
apply it. The URL used to load the resource might be platform specific or
you may use URI converters but the process is the same.
- James.
news:fh9b7a$slm$1@build.eclipse.org...
> Cheers
> JP
>> Cheers,
>> - James.
>>> Regards
>>> JP
Re: Programmatically retrieving applicable profiles [message #476535 is a reply to message #476526] Tue, 13 November 2007 11:21 Go to previous messageGo to next message
JP,
Unfortunately, UML2 does not provide a registry of "deployed" profiles; this
is something that's typically done by an application based on UML2...
Kenn
> Cheers
> JP
>> Cheers,
>> - James.
>>> Regards
>>> JP
Re: Programmatically retrieving applicable profiles [message #476538 is a reply to message #476533] Wed, 14 November 2007 08:51 Go to previous message
James,
Thanks for your help. I had arrived at the same conclusion: I need to
load the profile as a resource.
Best Regards
JP
James Bruck wrote:
> Hi JP,
> - James.
>> Cheers
>> JP
>>> Cheers,
>>> - James.
>>>> Regards
>>>> JP
Re: Programmatically retrieving applicable profiles [message #625439 is a reply to message #476458] Wed, 07 November 2007 10:36 Go to previous message
- James.
> Regards
> JP
Re: Programmatically retrieving applicable profiles [message #625441 is a reply to message #476523] Mon, 12 November 2007 05:52 Go to previous message
Cheers
JP
> Cheers,
> - James.
>> Regards
>> JP
Re: Programmatically retrieving applicable profiles [message #625447 is a reply to message #476526] Tue, 13 November 2007 09:24 Go to previous message
Hi JP,
- James.
> Cheers
> JP
>> Cheers,
>> - James.
>>> Regards
>>> JP
Re: Programmatically retrieving applicable profiles [message #625458 is a reply to message #476526] Tue, 13 November 2007 11:21 Go to previous message
JP,
Kenn
> Cheers
> JP
>> Cheers,
>> - James.
>>> Regards
>>> JP
Re: Programmatically retrieving applicable profiles [message #625461 is a reply to message #476533] Wed, 14 November 2007 08:51 Go to previous message
James,
Best Regards
JP
James Bruck wrote:
> Hi JP,
> - James.
>> Cheers
>> JP
>>> Cheers,
>>> - James.
>>>> Regards
>>>> JP
Previous Topic:UML2 & OCL version compatibility
Next Topic:[Announce] The EclipseCon 2008 Submission Deadline is Rapidly Approaching.
Current Time: Sat Aug 30 19:49:44 EDT 2025
Powered by FUDForum. Page generated in 0.04703 seconds
