Programmatically generating Class Diagrams [message #476512] |
Wed, 03 June 2009 07:17  |
Hi everybody!
I'm building an Eclipse plugin that can be used to generate models from
code. So far i was able to generate a .uml file describing a model. The
next step would be to instantiate a class diagram from that model. Is
there a way to programmatically do that? (now i have to right click my
uml file and choose 'Instantiate Class Diagram')
Thank you
Re: Programmatically generating Class Diagrams [message #476516 is a reply to message #476514] |
Thu, 04 June 2009 04:35  |
Thank you for your response. I'll try the solution you suggested. I've all
ready checked some of the projects from org.eclipse.uml2, but I'm still an
Eclipse plugin noob and i'm still having difficulties understanding how
things are interconnected). Once again - thank you.
The plugin i'm working on is generating models from php, JavaScript and
Html code (based on Conallen's UML extensions) and it will be open source
- i think by the end of summer..
Thank you
Re: Programmatically generating Class Diagrams [message #623931 is a reply to message #476512] |
Wed, 03 June 2009 11:08  |
Hello Josip,
It's a good question you asked. Some discussion about diagram initialization
was here -- news://news.eclipse.org/6785c5267d0e8cb50ee48e39d0a@news.ecl ipse.org
We also initialize diagrams programmatically in the tests. Class TestWholeClassDiagram
from plugin org.eclipse.uml2.diagram.clazz.tests does such initialization.
Feel free to use it as a hint.
BTW, Josip, you mentioned that you generate UML from code. I wonder from
what kind of code you generate UML, is it Java or another language? Will
it be free or commercial plugin?
Tanya.
> Hi everybody!
> from code. So far i was able to generate a .uml file describing a
> model. The next step would be to instantiate a class diagram from that
> model. Is there a way to programmatically do that? (now i have to
> right click my uml file and choose 'Instantiate Class Diagram')
> Thank you
Re: Programmatically generating Class Diagrams [message #623935 is a reply to message #476514] |
Thank you
FUDForum. Page generated in 0.06852 seconds
