Inline editing of a operations in the classdiagram [message #476503] |
Fri, 29 May 2009 01:40  |
I just tried the UML2 tools version for Eclipse 3.5 and if I modify the
name of a operation in a class diagram directly in the diagram this
change is lost. If I do this in properties view it is working.
Shall I open a bug for this?
Best regards, Lars
Re: Inline editing of a operations in the classdiagram [message #476515 is a reply to message #476511] |
Wed, 03 June 2009 11:21  |
Hi Lars,
Yes, I agree. It could look confusing, because label shown on the diagram
is composed from values of several properties, while property sheets allow
to edit a single value only.
I think mentioning it in your article will help the users to avoid such confusion.
Tanya.
> Hi Tatiana,
> thank you for the reply. It works correctly if I use foo().
> I believe the confusing part is that the properties editor does not
> use foo() but only foo.
> I added commend to: http://www.vogella.de/articles/UML/article.html to
> explain the behavior.
> Best regards, Lars
> Tatiana Fesenko wrote:
>> Hello Lars,
>> In accordance with UML specification name of an operation should be
>> followed by round brackets. So, round brackets should always be typed
>> after a name. It's not so obvios though. Does the name change after
>> you
>> type in inplace editor something like this -- 'foo()' ?
>> Best wishes,
>> Tanya.
>>> Hi,
>>> the name of a operation in a class diagram directly in the diagram
>>> this change is lost. If I do this in properties view it is working.
>>> Best regards, Lars
Re: Inline editing of a operations in the classdiagram [message #623922 is a reply to message #476503] |
Tue, 02 June 2009 08:03  |
Hello Lars,
In accordance with UML specification name of an operation should be followed
by round brackets. So, round brackets should always be typed after a name.
Does the name change after you type in inplace editor something like this
-- 'foo()' ?
Best wishes,
Tanya.
> Best regards, Lars
Re: Inline editing of a operations in the classdiagram [message #623927 is a reply to message #476508] |
Tue, 02 June 2009 17:10  |
Hi Tatiana,
I believe the confusing part is that the properties editor does not use
foo() but only foo.
to explain the behavior.
Best regards, Lars
> Hello Lars,
> after a name. It's not so obvios though. Does the name change after you
> Best wishes,
> Tanya.
>> Hi,
>> Best regards, Lars
Re: Inline editing of a operations in the classdiagram [message #623933 is a reply to message #476511] |
Hi Lars,
Tanya.
> Hi Tatiana,
> Best regards, Lars
>> Hello Lars,
>> you
>> Best wishes,
>> Tanya.
>>> Hi,
>>> Best regards, Lars
FUDForum. Page generated in 0.06069 seconds
