Home » Modeling » UML2 » Re: Can't convert correctly uml2 to ecore
Re: Can't convert correctly uml2 to ecore [message #476450] Fri, 02 November 2007 12:03 Go to next message
Emanuele,
How is String defined in the model? It sounds like it might just be a
class when it needs to be a data type. It's better to ask about this on
the UML2 newsgroup, which I've added to the "to" list of the reply...
manux wrote:
> Hi to everyone!
> I'm converting a uml model, drawn with Omondo UML, in ecore format.
> The problem arises when in the model there is an attribute with type
> String. For example a class A has an attribute att of type String. The
> attribute att, when the transit of the uml model to ecore is done, is
> trasformed in a reference. So:
> _ Anyone has experience with this trouble? _ Is/Are there some
> article(s) about the mapping between datatype in UML and Ecore?
> Thank you
> Emanuele
> Remove the _nospam from the email address
Re: Can't convert correctly uml2 to ecore [message #476451 is a reply to message #476450] Fri, 02 November 2007 15:29 Go to previous messageGo to next message
Originally posted by: zappasan_nospam.gmail.com
Ed,
in Omondo I specify the string with the java.lang.String class. Probably,
like you've just suggested, the problem is this. But, at the moment, is
the only way that I've found for specify a string attribute.
Emanuele
Remove _nospam from the e-mail address
Re: Can't convert correctly uml2 to ecore [message #476452 is a reply to message #476451] Sun, 04 November 2007 04:42 Go to previous message
Hi Emanuele,
it works with <Primitive Type> uml::String
manux schrieb:
> Ed,
> Probably, like you've just suggested, the problem is this. But, at the
> moment, is the only way that I've found for specify a string attribute.
> Emanuele
Re: Can't convert correctly uml2 to ecore [message #625423 is a reply to message #476450] Fri, 02 November 2007 15:29 Go to previous message
Ed,
Emanuele
Re: Can't convert correctly uml2 to ecore [message #625426 is a reply to message #476451] Sun, 04 November 2007 04:42 Go to previous message
Hi Emanuele,
manux schrieb:
> Ed,
> Emanuele
Previous Topic:Re: Can't convert correctly uml2 to ecore
Next Topic:problem while starting eclipse
Current Time: Sun Aug 31 20:10:26 EDT 2025
Powered by FUDForum. Page generated in 0.26847 seconds
