Arrange All for Activity [message #476375] |
Wed, 15 April 2009 10:57  |
the PackageAsFrame Node in the Class Diagram has a Arrange All Methode
for the nested Elements. Is it possible to add the same Methode to a
Activity?
Thank you
Peter
Re: Arrange All for Activity [message #476377 is a reply to message #476376] |
Fri, 17 April 2009 10:03  |
Thanks Tanya,
I´m looking forward to this feature.
Peter
> Hello Peter,
> "Arrange All" action for Activity sounds as a helpful feature.
> I submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=272689 into
> bugzilla. You can track it for the update.
> Now you can select needed elements and then arrange them using 'Arrange
> Selection' action from taskbar. You can select elements manully or using
> 'Select All' action.
> Best wishes,
> Tanya.
>> Hi,
>> Activity?
>> Thank you
>> Peter
Re: Arrange All for Activity [message #623689 is a reply to message #476375] |
Fri, 17 April 2009 09:21  |
Hello Peter,
I submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=272689 into bugzilla.
Now you can select needed elements and then arrange them using 'Arrange Selection'
action from taskbar. You can select elements manully or using 'Select All'
action.
Best wishes,
Tanya.
> Activity?
> Thank you
> Peter
Re: Arrange All for Activity [message #623691 is a reply to message #476376] |
Thanks Tanya,
Peter
> Hello Peter,
> Best wishes,
> Tanya.
>> Hi,
>> Activity?
>> Thank you
>> Peter
FUDForum. Page generated in 0.08131 seconds
