Home » Modeling » UML2 » Missing source/target attribute from ActivityEdge when xmi:id different than name attribute
Missing source/target attribute from ActivityEdge when xmi:id different than name attribute [message #476350] Tue, 09 October 2007 08:48 Go to next message
Originally posted by: danjaspoja.gmail.com
I have found the following problem when creating an activity diagram
prgrammatically using Eclipse UML2 API. When specifying Action node, if
I set the name and xmi:id to be the same value and then I generate an
XML file from the model, the source and target attributes appear
correctly in the ActivityEdge tags. However, if I set name attribute to
be some value different than the value I set for xmi:id, the generated
XML edges are are randomly missing either target or source attribute.
Has anyone else encountered this behavior? Is this a programmer error or
a bug?
Thank you very much for any feedback,
Danja
Re: Missing source/target attribute from ActivityEdge when xmi:id different than name attribute [message #476354 is a reply to message #476350] Tue, 09 October 2007 13:51 Go to previous messageGo to next message
Hi Danja,
Can you demonstrate this with a JUnit test so that it can be investigated?
I would like to see exactly how you are setting the id and name.
- James.
"Danja" <danjaspoja@gmail.com> wrote in message
news:feftb8$4cq$1@build.eclipse.org...
> Hello,
> prgrammatically using Eclipse UML2 API. When specifying Action node, if I
> set the name and xmi:id to be the same value and then I generate an XML
> file from the model, the source and target attributes appear correctly in
> the ActivityEdge tags. However, if I set name attribute to be some value
> different than the value I set for xmi:id, the generated XML edges are are
> Has anyone else encountered this behavior? Is this a programmer error or a
> bug?
> Danja
Re: Missing source/target attribute from ActivityEdge when xmi:id different than name attribute [message #477074 is a reply to message #476354] Wed, 12 March 2008 05:36 Go to previous messageGo to next message
James Bruck 写道:
> Hi Danja,
> Cheers,
> - James.
>> Hello,
>> bug?
>> Danja
Hi Danja,
I am also creating an activity diagram prgrammatically using Eclipse
UML2 API.I 'd like to know how to create a ControlFlow between two
actions,how to setSource,how to setTarget for the ControlFlow.Could you
give me an example for that?
thank you very much! I am appreciated the reply.
Best Wishes!
xiaoqiang
Re: Missing source/target attribute from ActivityEdge when xmi:id different than name attribute [message #477192 is a reply to message #477074] Fri, 04 April 2008 09:46 Go to previous message
xiaoqiang,
Action is a specialization of ActivityNode and ControlFlow is a
specialization of ActivityEdge, so you would so something like this:
ControlFlow myControlFlow = (ControlFlow) myActivity.createEdge(null,
UMLPackage.Literals.CONTROL_FLOW);
controlFlow.setSource(myAction);
controlFlow.setTarget(myOtherAction);
Kenn
"xiaoqiang" <jqzhao1985@gmail.com> wrote in message
news:fr887h$as3$1@build.eclipse.org...
> James Bruck д
Re: Missing source/target attribute from ActivityEdge when xmi:id different than name attribute [message #625166 is a reply to message #476350] Tue, 09 October 2007 13:51 Go to previous message
Hi Danja,
- James.
> Hello,
> bug?
> Danja
Re: Missing source/target attribute from ActivityEdge when xmi:id different than name attribute [message #626201 is a reply to message #476354] Wed, 12 March 2008 05:36 Go to previous message
James Bruck 写道:
> Hi Danja,
> Cheers,
> - James.
>> Hello,
>> bug?
>> Danja
Hi Danja,
Best Wishes!
xiaoqiang
Re: Missing source/target attribute from ActivityEdge when xmi:id different than name attribute [message #626352 is a reply to message #477074] Fri, 04 April 2008 09:46 Go to previous message
xiaoqiang,
Kenn
> James Bruck д
Previous Topic:UML Model Editor/ Importing
Next Topic:How to model an operation with concrete instanceSpecifications as inputs and output?
Current Time: Sun Aug 31 12:58:51 EDT 2025
Powered by FUDForum. Page generated in 0.04472 seconds
