Home » Modeling » UML2 » dynamic EMF profiles
dynamic EMF profiles [message #476231] Thu, 27 September 2007 14:19 Go to next message
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
hi all,
I would like to statically import a known profile to my uml-model -
therefore I'd like to generate model code. I looked over the uml2 code
but couldn't find where dynamic emf is used there and how I can avoid it
for a specific profile.
- -stefan
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.7 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFG+/QyIYVWjMSpDwwRAle4AKC5gJhaFeID9BYHMy5HXNfr4/2a1wCg 1hIu
Fag/rAc/fXcVOd//S6xBXAs=
=2oib
-----END PGP SIGNATURE-----
Re: dynamic EMF profiles [message #476235 is a reply to message #476231] Fri, 28 September 2007 09:37 Go to previous messageGo to next message
Hi Stefan,
I hope I'm interpreting this question correctly - you are asking how to do
static profile definition. I just wanted to point out that with a
statically defined profiles there is no need to "define" ( create an ecore
representation attached as an annotation ) your profile in the traditional
way and therefore, dynamic EMF doesn't come into the picture ( hence the
term "statically defined" ).
There are several steps involved...
----------- Create your Profile -------------
1. Create your uml profile as you would normally ( For example, create a
stereotype called MyExtendedClass that extends uml:Class ). (see the getting
started article for details ). (Call it My.profile.uml for example)
2. ** don't do the "define" step ***
3. On your profile, apply the <<ePackage>> stereotype from the existing
Ecore profile.
4. Set the nsURI to something ... say http://www.myOrg/MyProfile
------- Generate code ---------
1. Create an EMF project as you would from any other .uml model to generate
code from but specify your profile as the source ( My.profile.uml )
2. Select the "Process All" options when loading your My.profile.uml.
3. Generate code as you would normally from the resulting .genmodel.
------- Using your profile ------
Up to this point, things were pretty easy. Here comes the tricky part...
1. Move your previously generated code for your profile to your development
environment.
2. Create a new plugin in your development environment ( say a JUnit plugin
to get started with ).
3. In your JUnit plugin test, add the line:
UMLPlugin.getEPackageNsURIToProfileLocationMap().put(http://www.myOrg.com/My
Profile, URI.createURI( ... path to My.profile.uml#_XXX")); where XXX is the
id of the profile in your model.
4. Create a resource set and load your My.profile.uml.
5. Next, Load your profile using..
Profile myProfile = UMLUtil.getProfile(MyProfilePackage.eINSTANCE,
from the already generated MyProfilePackage from the "Generate Code"
step.
6. Next, obtain your stereotype with..
Stereotype myStereotype =
myProfile.getOwnedStereotype("MyExtendedClass");
7. This is the interesting part ... Apply your stereotype as follows:
MyExtendedClass myExtendedClass =
(MyExtendedClass)myClass.applyStereotype(myStereotype);
Notice how you do not get a stereotype application but rather a type of
"MyExtendedClass".
8. Now you have full access to setting variagbles to MyExtendedClass etc.
--- how cool is that ;) ----
Note: There is an extension point exposed to help with the registration
that we are doing in step 3 but I noticed that there is a bug ( I don't
think the schema was properly exported ... that will be fixed shortly ).
- James.
"SKuhn" <kuhn@oio.de> wrote in message
news:fdgs8p$c5d$1@build.eclipse.org...
> Hash: SHA1
> hi all,
> - -stefan
> =2oib
Re: dynamic EMF profiles [message #476243 is a reply to message #476235] Fri, 28 September 2007 12:09 Go to previous messageGo to next message
Hash: SHA1
awesome, that looks really good. Thanks a lot.
Could I've found these steps in any tutorial? What's the name of the
extension point and with which version will the problem be fixed?
- -stefan
James Bruck schrieb:
> Hi Stefan,
> Ecore profile.
> environment.
> step.
> "MyExtendedClass".
> Cheers,
> - James.
> hi all,
> -stefan
iD8DBQFG/Sc6IYVWjMSpDwwRAn6gAKDUBv0w4vwx2FZvbvXIP858egxisgCf ZA/n
mcixjiqqQFrHjvu644UhsR4=
=/La/
Re: dynamic EMF profiles [message #476244 is a reply to message #476235] Fri, 28 September 2007 12:19 Go to previous messageGo to next message
Originally posted by: firstname.name.gmail.com
In the last post, on 09/28 about 03h, "James" (James Bruck) wrote:
James> This is the interesting part ... Apply your stereotype as follows
James> [...] Notice how you do not get a stereotype application but
James> rather a type of "MyExtendedClass"
hello,
I have just read this post. I think it solves a lot of my problems. I didn't
really understand how to use static profile. I thought first, that it was
possible to extend the basic UML editor to get the behavior given by a genmodel
chain from a profile.
But, from what I can understand, in order to get the expected behavior we have
to extend/define our own editor to load the profile and create the appropriate
bindings. However, I may still use my profile as usual in the UML editor (with
no behavior). Both solution produce same UML xmi files and thus I can still
interchange my files. Is it right?
thanks.
F. Lagarde
Re: dynamic EMF profiles [message #476245 is a reply to message #476243] Fri, 28 September 2007 12:59 Go to previous messageGo to next message
Unfortunately there is no detailed tutorial yet ... it is being worked on
and should be a more detailed step by step guide.
The name of the extension point is: generated_package.exsd in
org.eclipse.uml2.uml plugin. If you get the source code there is some
more documentation etc.
The extension point will be fixed in 2.2 M2 ( unfortunately 2.1.1 was just
released before I noticed the mistake ).
- James.
news:fdj912$a3j$1@build.eclipse.org...
> Hash: SHA1
> - -stefan
> > Hi Stefan,
do
ecore
traditional
getting
> > Ecore profile.
generate
part...
development
> > environment.
plugin
the
> > step.
of
> > "MyExtendedClass".
etc.
> > Cheers,
> > - James.
> > hi all,
> > -stefan
> =/La/
Re: dynamic EMF profiles [message #476247 is a reply to message #476244] Sun, 30 September 2007 06:04 Go to previous messageGo to next message
Hash: SHA1
hi François,
> I thought first, that it was possible to extend the
well, I'm not quite sure if I got this right. A genmodel chain, you mean
the auto-gen. EMF-tree editor? It already supports profiles so there
would be performance and change of generated behaviour as benefit.
Actually I asked this for a GMF editor I'm making.
> we have to extend/define our own editor to load the profile and create
> the appropriate bindings.
I hope for you not & don't think so. The editor should be able to load
the profile as normal (of course now in a runtime workbench) and the
changed behavior should work as long as you use this profile with an
eclipse based uml tool. I don't think you need to create appropriate
bindings, let us hope a registry takes care of this.
> no behavior).
no, you need to use your profile in a runtime-eclipse. That we didn't
'define' our profile might cause problems, too.
- -stefan
> hello,
> thanks.
iD8DBQFG/3S0IYVWjMSpDwwRAjJYAKDT/K51Eme0gx9bzAaTMVcjg5wbjQCf ThMS
LtZdNvd+V7GU9Dg84P+ouew=
=fNfR
Re: dynamic EMF profiles [message #476268 is a reply to message #476235] Thu, 04 October 2007 11:38 Go to previous messageGo to next message
Hash: SHA1
hi james,
is it possible to generate/create an adapter/proxy class for
"MyExtendedClass" which decorates the stereotyped classifier + the
stereotype instance?
- -stefan
> Hi Stefan,
> Ecore profile.
> environment.
> step.
> "MyExtendedClass".
> Cheers,
> - James.
> hi all,
> -stefan
iD8DBQFHBQkDIYVWjMSpDwwRApLBAKCubpp9dxa9MPDHTICuxqZZGdeccACf QavW
Ez3jM4lHwUFPcKQvU32aw+s=
=vJqO
Re: dynamic EMF profiles [message #476351 is a reply to message #476245] Tue, 09 October 2007 10:26 Go to previous messageGo to next message
--------------030401020602020103040706
Content-Type: text/plain; charset=ISO-8859-15
Hash: SHA1
hi james,
I tried to follow your instructions but didn't succeed. I attached the
sources, maybe you can take a look at it or provide a working example.
- -stefan
> - James.
> -stefan
>>>> Hi Stefan,
>> do
>> ecore
>> traditional
>> getting
>>>> Ecore profile.
>> generate
>> part...
>> development
>>>> environment.
>> plugin
>> the
>>>> step.
>> of
>>>> "MyExtendedClass".
>> etc.
>>>> Cheers,
>>>> - James.
>>>> hi all,
>>>> -stefan
iD8DBQFHC4+JIYVWjMSpDwwRAgDqAKDHEJnumbro1s4FDP728ilhILF63ACd FYpX
GtrTjvk9c9Cadmeg6U4A+y8=
=ov4b
Content-Type: text/x-java;
name="Bsp.java"
Content-Disposition: inline;
filename="Bsp.java"
package umlExpl;
import java.io.File;
import java.io.IOException;
import java.util.Collections;
import java.util.Map;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.uml2.common.util.UML2Util;
import org.eclipse.uml2.uml.Classifier;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.Profile;
import org.eclipse.uml2.uml.Stereotype;
import org.eclipse.uml2.uml.UMLFactory;
import org.eclipse.uml2.uml.Package;
import org.eclipse.uml2.uml.Class;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.UMLPlugin;
import org.eclipse.uml2.uml.resource.UMLResource;
import org.eclipse.uml2.uml.util.UMLUtil;
import Profile.Complex;
import Profile.POCPackage;
public class Bsp {
public static ResourceSet resourceSet = null;
* @param args
initResourceSet();
Model root = createModel("test");
Resource resource = createResource(fileURI());
resource.getContents().add(root);
Profile meinProfile = stereotypeTest();
Package myPackage = createPackage(root, "meinPacket");
Class myClass = createClass(myPackage, "meineKlasse");
// meinProfile= stdProfil();
root.applyProfile(meinProfile);
// myPackage.applyProfile(anderesProfil);
// for (Profile prof : myPackage.getAllAppliedProfiles()) {
// System.out.println(prof);
printStereos(myClass);
// Stereotype meinStereo = meinProfile.getOwnedStereotype("MitTaggedV");
Stereotype meinStereo = meinProfile.getOwnedStereotype("Complex");
UMLUtil.safeApplyStereotype(myClass, meinStereo);
// myClass.applyStereotype(andererStereo);
save(resource);
// Complex complex = (Complex) myClass.applyStereotype(meinStereo);
private static Profile stdProfil(){
Resource stdUML = resourceSet.getResource(URI.createFileURI(" /home/qn/Coden/workspace-oAW/POC_Prof/model/POC_1.profile.um l "), true);
Profile meinProfil= (org.eclipse.uml2.uml.Profile) EcoreUtil.getObjectByType(stdUML.getContents(), UMLPackage.Literals.PROFILE);
return meinProfil;
private static void muell(){
try {
.createURI(UMLResource.STANDARD_PROFILE_URI), true);
.createURI(UMLResource.ECORE_PROFILE_URI), true);
} catch (Exception e) {
// ignore
private static void printStereos(Classifier myClass) {
System.out.println("Anwendbare Stereotypen: ");
for (Stereotype stereotyp : myClass.getApplicableStereotypes()) {
System.out.println("Stereotyp: " + stereotyp);
System.out.println("Anwendbare Stereotypen ende");
private static void printStereosApplied(Classifier myClass) {
System.out.println("Angewendete Stereotypen: ");
for (Stereotype stereotyp : myClass.getAppliedStereotypes()) {
System.out.println("Angewendete: " + stereotyp);
public static void save(Resource resource){
// Print the contents of the resource to System.out.
try
resource.save(Collections.EMPTY_MAP);
catch (IOException e) {
System.out.println("Fehler "+e.toString());
public static URI fileURI(){
File file = new File("testModelle/testModell.uml");
System.out.println("Datein mit Pfad "+file.getAbsolutePath()+ " erzeugt.");
URI fileURI = URI.createFileURI(file.getAbsolutePath());
return fileURI;
public static void initResourceSet(){
resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Map<URI,URI> uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI.createURI(" jar:file:/home/qn/Coden/eclipse-oAW/plugins/org.eclipse.uml2 .uml.resources_2.1.0.v200706251652.jar!/ ");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
public static Resource createResource(URI location) {
Resource resource = resourceSet.createResource(location);
return resource;
public static Profile stereotypeTest() {
URI uri2file = URI
.createURI(" /home/qn/Coden/workspace-oAW/StaticProfile/model/default.pro file.uml ").appendFragment("_uy27sHWxEdyjl9eZlwzeuA");
//_V_rHMHW3Edyjl9eZlwzeuA
//_uy27sHWxEdyjl9eZlwzeuA sollte ok sein
System.out.println("File exists? " + new File(uri2file.path()).exists());
Resource profilResource = resourceSet.getResource(uri2file, true); //System.out.println("contains? "+resourceSet.getResources().contains(profilResource));
UMLPlugin.getEPackageNsURIToProfileLocationMap().put("de.oio.POC ",uri2file);
URI uri = URI.createURI(" /home/qn/Coden/workspace-oAW/StaticProfile/model/default.pro file.uml ");
uriMap.put(URI.createURI("de.oio.POC"), uri2file);
// uri.appendSegment("libraries").appendSegment(""));
// resourceSet.getPackageRegistry().put("de.oio.POC",POCPackage.eINSTANCE);
// System.out.println("profilResource.getURI()= "+profilResource.getURI());
Profile myProfile = UMLUtil.getProfile(POCPackage.eINSTANCE);
System.out.println("Profile == null? "+Boolean.toString(myProfile==null));
Profile meinProfil = null;
//Weg I (klappt bei mir aber zeigt nix)
//(Profile)profilResource.getAllContents().next();
//Weg II
meinProfil = (org.eclipse.uml2.uml.Profile) EcoreUtil.getObjectByType(profilResource.getContents(), UMLPackage.Literals.PROFILE);
if(true)
return meinProfil;
return myProfile;
public static Model createModel(String name) {
Model model = UMLFactory.eINSTANCE.createModel();
model.setName(name);
System.out.println("Model " + model.getQualifiedName() + " created");
return model;
public static Package createPackage(Package parentPackage, String name) {
Package newPackage = parentPackage.createNestedPackage(name);
// System.out.println("Package " + newPackage.getQualifiedName()
// + " created in " + parentPackage.getQualifiedName());
return newPackage;
public static Class createClass(Package parentPackage, String name) {
Class clazz = parentPackage.createOwnedClass(name, false);
// System.out.println("Klasse " + clazz.getQualifiedName()+" erzeugt");
return clazz;
Content-Type: text/xml;
name="default.umlprofile_diagram"
filename="default.umlprofile_diagram"
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.1/notation" xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" xmi:id="_u88r0HWxEdyjl9eZlwzeuA" type="UMLProfile" name="default.umlprofile_diagram" measurementUnit="Pixel">
<children xmi:type="notation:Node" xmi:id="_wCzgoHWxEdyjl9eZlwzeuA" type="2007">
<children xmi:type="notation:Node" xmi:id="_wC0uwHWxEdyjl9eZlwzeuA" type="5009"/>
<children xmi:type="notation:Node" xmi:id="_wC4ZIHWxEdyjl9eZlwzeuA" type="7005">
<styles xmi:type="notation:DrawerStyle" xmi:id="_wC5AMHWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_wC5AMXWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_wC5AMnWxEdyjl9eZlwzeuA"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_wCzgoXWxEdyjl9eZlwzeuA" fontName="Verdana"/>
<element xmi:type="uml:Profile" href="default.profile.uml#_uy27sHWxEdyjl9eZlwzeuA"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_wCzgonWxEdyjl9eZlwzeuA"/>
</children>
<children xmi:type="notation:Node" xmi:id="_zD8WYHWxEdyjl9eZlwzeuA" type="2001">
<children xmi:type="notation:Node" xmi:id="_zD89cHWxEdyjl9eZlwzeuA" type="5001"/>
<children xmi:type="notation:Node" xmi:id="_zD9kgHWxEdyjl9eZlwzeuA" type="7001">
<children xmi:type="notation:Node" xmi:id="_M-l6gHWyEdyjl9eZlwzeuA" type="3001">
<element xmi:type="uml:Property" href="default.profile.uml#_M-XRAHWyEdyjl9eZlwzeuA"/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_M-l6gXWyEdyjl9eZlwzeuA"/>
</children>
<children xmi:type="notation:Node" xmi:id="_NyKsgHWyEdyjl9eZlwzeuA" type="3001">
<element xmi:type="uml:Property" href="default.profile.uml#_Nx8DAHWyEdyjl9eZlwzeuA"/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_NyKsgXWyEdyjl9eZlwzeuA"/>
</children>
<styles xmi:type="notation:DrawerStyle" xmi:id="_zD9kgXWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_zD9kgnWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_zD9kg3WxEdyjl9eZlwzeuA"/>
</children>
<children xmi:type="notation:Node" xmi:id="_zD-LkHWxEdyjl9eZlwzeuA" type="7002">
<styles xmi:type="notation:DrawerStyle" xmi:id="_zD-LkXWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_zD-LknWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_zD-Lk3WxEdyjl9eZlwzeuA"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_zD8WYXWxEdyjl9eZlwzeuA" fontName="Verdana"/>
<element xmi:type="uml:Stereotype" href="default.profile.uml#_zDHP8HWxEdyjl9eZlwzeuA"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_zD8WYnWxEdyjl9eZlwzeuA" x="251" y="203"/>
</children>
<children xmi:type="notation:Node" xmi:id="_1K5b0HWxEdyjl9eZlwzeuA" type="2001">
<children xmi:type="notation:Node" xmi:id="_1K5b03WxEdyjl9eZlwzeuA" type="5001"/>
<children xmi:type="notation:Node" xmi:id="_1K6C4HWxEdyjl9eZlwzeuA" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_1K6C4XWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_1K6C4nWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_1K6C43WxEdyjl9eZlwzeuA"/>
</children>
<children xmi:type="notation:Node" xmi:id="_1K6C5HWxEdyjl9eZlwzeuA" type="7002">
<styles xmi:type="notation:DrawerStyle" xmi:id="_1K6C5XWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_1K6C5nWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_1K6C53WxEdyjl9eZlwzeuA"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_1K5b0XWxEdyjl9eZlwzeuA" fontName="Verdana"/>
<element xmi:type="uml:Stereotype" href="default.profile.uml#_1K1KYHWxEdyjl9eZlwzeuA"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_1K5b0nWxEdyjl9eZlwzeuA" x="592" y="220"/>
</children>
<children xmi:type="notation:Node" xmi:id="_3fG6IHWxEdyjl9eZlwzeuA" type="2003">
<children xmi:type="notation:Node" xmi:id="_3fHhMHWxEdyjl9eZlwzeuA" type="5005"/>
<children xmi:type="notation:Node" xmi:id="_3fIIQHWxEdyjl9eZlwzeuA" type="7004">
<children xmi:type="notation:Node" xmi:id="_Hea2gHWyEdyjl9eZlwzeuA" type="3005">
<element xmi:type="uml:EnumerationLiteral" href="default.profile.uml#_HeMNAHWyEdyjl9eZlwzeuA"/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_Hea2gXWyEdyjl9eZlwzeuA"/>
</children>
<children xmi:type="notation:Node" xmi:id="_LxaVsHWyEdyjl9eZlwzeuA" type="3005">
<element xmi:type="uml:EnumerationLiteral" href="default.profile.uml#_LxJ3AHWyEdyjl9eZlwzeuA"/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_LxaVsXWyEdyjl9eZlwzeuA"/>
</children>
<styles xmi:type="notation:DrawerStyle" xmi:id="_3fIIQXWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_3fIIQnWxEdyjl9eZlwzeuA"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_3fIIQ3WxEdyjl9eZlwzeuA"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_3fG6IXWxEdyjl9eZlwzeuA" fontName="Verdana"/>
<element xmi:type="uml:Enumeration" href="default.profile.uml#_3e2bcHWxEdyjl9eZlwzeuA"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_3fG6InWxEdyjl9eZlwzeuA" x="352" y="48"/>
</children>
<children xmi:type="notation:Node" xmi:id="_7ujoYHX5EdyT4bcDFauwJQ" type="2001">
<children xmi:type="notation:Node" xmi:id="_7ukPcHX5EdyT4bcDFauwJQ" type="5001"/>
<children xmi:type="notation:Node" xmi:id="_7uk2gHX5EdyT4bcDFauwJQ" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_7uk2gXX5EdyT4bcDFauwJQ"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_7uk2gnX5EdyT4bcDFauwJQ"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_7uk2g3X5EdyT4bcDFauwJQ"/>
</children>
<children xmi:type="notation:Node" xmi:id="_7uldkHX5EdyT4bcDFauwJQ" type="7002">
<styles xmi:type="notation:DrawerStyle" xmi:id="_7uldkXX5EdyT4bcDFauwJQ"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_7uldknX5EdyT4bcDFauwJQ"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_7uldk3X5EdyT4bcDFauwJQ"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_7ujoYXX5EdyT4bcDFauwJQ" fontName="Verdana"/>
<element xmi:type="uml:Stereotype" href="default.profile.uml#_7tqQgHX5EdyT4bcDFauwJQ"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_7ujoYnX5EdyT4bcDFauwJQ" x="328" y="395"/>
</children>
<styles xmi:type="notation:DiagramStyle" xmi:id="_u88r0XWxEdyjl9eZlwzeuA"/>
</notation:Diagram>
--------------030401020602020103040706--
Re: dynamic EMF profiles [message #476358 is a reply to message #476351] Wed, 10 October 2007 15:18 Go to previous messageGo to next message
Hash: SHA1
any ideas?
- -stefan
SKuhn schrieb:
> hi james,
> -stefan
>> - James.
>> -stefan
>>>>> Hi Stefan,
>>> do
>>> ecore
>>> traditional
>>> getting
>>>>> Ecore profile.
>>> generate
>>> part...
>>> development
>>>>> environment.
>>> plugin
>>> the
>>>>> step.
>>> of
>>>>> "MyExtendedClass".
>>> etc.
>>>>> Cheers,
>>>>> - James.
>>>>> hi all,
>>>>> -stefan
iD8DBQFHDSVxIYVWjMSpDwwRArn9AJ9nqf9nRjjDX8yt3H3jed3/h4uABQCe JMWs
/ZTEq/pDLyjDGUxFfIKtoQ4=
=HRVF
Re: dynamic EMF profiles [message #476359 is a reply to message #476358] Wed, 10 October 2007 18:20 Go to previous messageGo to next message
I looks like you didn't attach default.profile.uml.
You did attach some diagram of the profile though (no nsURI set up with
<<ePackage>> stereotype).
I'll post a step-by-step guide as soon as I can.
- James.
news:fej8j0$961$2@build.eclipse.org...
> Hash: SHA1
> any ideas?
> - -stefan
> SKuhn schrieb:
>> hi james,
>> -stefan
>>> on
>>> just
>>> - James.
>>> -stefan
>>>>>> Hi Stefan,
>>>>>> to
>>>> do
>>>> ecore
>>>> traditional
>>>>>> the
>>>>>> create a
>>>> getting
>>>>>> existing
>>>>>> Ecore profile.
>>>> generate
>>>> part...
>>>> development
>>>>>> environment.
>>>> plugin
>>>>>> is
>>>> the
>>>>>> Profile myProfile =
>>>>>> Code"
>>>>>> step.
>>>>>> follows:
>>>>>> type
>>>> of
>>>>>> "MyExtendedClass".
>>>> etc.
>>>>>> registration
>>>>>> don't
>>>>>> shortly ).
>>>>>> Cheers,
>>>>>> - James.
>>>>>> hi all,
>>>>>> code
>>>>>> it
>>>>>> -stefan
> =HRVF
Re: dynamic EMF profiles [message #476383 is a reply to message #476358] Thu, 11 October 2007 05:05 Go to previous messageGo to next message
Hello Stefan,
I succeeded with this, adapt it to your case first.
String s =
" D:\\workspace\\eclipse-europa\\TestProfile\\model\\MyProfile .profile.uml ";
ResourceSet set = new ResourceSetImpl();
set.getPackageRegistry().put(MyProfilePackage.eNS_URI,
MyProfilePackage.eINSTANCE);
set.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
set.getResourceFactoryRegistry().getExtensionToFactoryMap(). put(UMLResource.FILE_EXTENSION,
Map uriMap = set.getURIConverter().getURIMap();
URI uri =
URI.createURI(" jar:file:/C:/Tools/eclipse-europa-modeling/eclipse/plugins/o rg.eclipse.uml2.uml.resources_2.1.0.v200706251652.jar!/ ");
Resource res = set.getResource(URI.createFileURI(s), true);
Profile myProfile = (org.eclipse.uml2.uml.Profile)
EcoreUtil.getObjectByType(res.getContents(), UMLPackage.Literals.PROFILE);
Stereotype myStereotype = myProfile.getOwnedStereotype("MyStereotype");
org.eclipse.uml2.uml.Package myPackage =
UMLFactory.eINSTANCE.createPackage();
myPackage.applyProfile(myProfile);
org.eclipse.uml2.uml.Class myClass = UMLFactory.eINSTANCE.createClass();
myClass.setPackage(myPackage);
myClass.setName("Class");
MyStereotype myExtendedClass = (MyStereotype)
myExtendedClass.setAttribute(true);
System.out.println(myClass.getName()); // > Class
System.out.println(myExtendedClass.isAttribute()); // > true
Re: dynamic EMF profiles [message #476385 is a reply to message #476268] Thu, 11 October 2007 05:37 Go to previous message
Hello Stefan,
But what if a stereotype extend 2 metaclasses and each metaclass has
different attributes?
- With one decorator for both, you would have some attributes without
value.
- With two decorators, one for each metaclass, the handle of the types
would not be very appealing (to me, -particular opinion-)
I think I'd rather a get method in the stereotype class returning the
metaclass instance, because now we have to keep the reference to both: the
metaclass instance and the stereotype instance. It could return the common
supertype of the metaclasses (EObject or Object in the worst case).
Maybe also a method to query which metaclass is actually extending.
What do you think?
Re: dynamic EMF profiles [message #625042 is a reply to message #476231] Fri, 28 September 2007 09:37 Go to previous message
Hi Stefan,
Ecore profile.
environment.
step.
"MyExtendedClass".
- James.
> Hash: SHA1
> hi all,
> - -stefan
> =2oib
Re: dynamic EMF profiles [message #625054 is a reply to message #476235] Fri, 28 September 2007 12:09 Go to previous message
Hash: SHA1
- -stefan
> Hi Stefan,
> Ecore profile.
> environment.
> step.
> "MyExtendedClass".
> Cheers,
> - James.
> hi all,
> -stefan
=/La/
Re: dynamic EMF profiles [message #625056 is a reply to message #476235] Fri, 28 September 2007 12:19 Go to previous message
hello,
thanks.
F. Lagarde
Re: dynamic EMF profiles [message #625057 is a reply to message #476243] Fri, 28 September 2007 12:59 Go to previous message
- James.
> Hash: SHA1
> - -stefan
> > Hi Stefan,
do
ecore
traditional
getting
> > Ecore profile.
generate
part...
development
> > environment.
plugin
the
> > step.
of
> > "MyExtendedClass".
etc.
> > Cheers,
> > - James.
> > hi all,
> > -stefan
> =/La/
Re: dynamic EMF profiles [message #625059 is a reply to message #476244] Sun, 30 September 2007 06:04 Go to previous message
Hash: SHA1
hi François,
> no behavior).
- -stefan
> hello,
> thanks.
=fNfR
Re: dynamic EMF profiles [message #625082 is a reply to message #476235] Thu, 04 October 2007 11:38 Go to previous message
Hash: SHA1
hi james,
- -stefan
> Hi Stefan,
> Ecore profile.
> environment.
> step.
> "MyExtendedClass".
> Cheers,
> - James.
> hi all,
> -stefan
=vJqO
Re: dynamic EMF profiles [message #625163 is a reply to message #476245] Tue, 09 October 2007 10:26 Go to previous message
Hash: SHA1
hi james,
- -stefan
> - James.
> -stefan
>>>> Hi Stefan,
>> do
>> ecore
>> traditional
>> getting
>>>> Ecore profile.
>> generate
>> part...
>> development
>>>> environment.
>> plugin
>> the
>>>> step.
>> of
>>>> "MyExtendedClass".
>> etc.
>>>> Cheers,
>>>> - James.
>>>> hi all,
>>>> -stefan
=ov4b
name="Bsp.java"
filename="Bsp.java"
package umlExpl;
public class Bsp {
* @param args
initResourceSet();
save(resource);
return meinProfil;
try {
// ignore
try
return fileURI;
return resource;
URI uri2file = URI
//Weg II
if(true)
return meinProfil;
return myProfile;
return model;
return newPackage;
return clazz;
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</notation:Diagram>
Re: dynamic EMF profiles [message #625170 is a reply to message #476351] Wed, 10 October 2007 15:18 Go to previous message
Hash: SHA1
any ideas?
- -stefan
SKuhn schrieb:
> hi james,
> -stefan
>> - James.
>> -stefan
>>>>> Hi Stefan,
>>> do
>>> ecore
>>> traditional
>>> getting
>>>>> Ecore profile.
>>> generate
>>> part...
>>> development
>>>>> environment.
>>> plugin
>>> the
>>>>> step.
>>> of
>>>>> "MyExtendedClass".
>>> etc.
>>>>> Cheers,
>>>>> - James.
>>>>> hi all,
>>>>> -stefan
=HRVF
Re: dynamic EMF profiles [message #625171 is a reply to message #476358] Wed, 10 October 2007 18:20 Go to previous message
- James.
> Hash: SHA1
> any ideas?
> - -stefan
> SKuhn schrieb:
>> hi james,
>> -stefan
>>> on
>>> just
>>> - James.
>>> -stefan
>>>>>> Hi Stefan,
>>>>>> to
>>>> do
>>>> ecore
>>>> traditional
>>>>>> the
>>>>>> create a
>>>> getting
>>>>>> existing
>>>>>> Ecore profile.
>>>> generate
>>>> part...
>>>> development
>>>>>> environment.
>>>> plugin
>>>>>> is
>>>> the
>>>>>> Profile myProfile =
>>>>>> Code"
>>>>>> step.
>>>>>> follows:
>>>>>> type
>>>> of
>>>>>> "MyExtendedClass".
>>>> etc.
>>>>>> registration
>>>>>> don't
>>>>>> shortly ).
>>>>>> Cheers,
>>>>>> - James.
>>>>>> hi all,
>>>>>> code
>>>>>> it
>>>>>> -stefan
> =HRVF
Re: dynamic EMF profiles [message #625175 is a reply to message #476358] Thu, 11 October 2007 05:05 Go to previous message
Hello Stefan,
String s =
URI uri =
Re: dynamic EMF profiles [message #625177 is a reply to message #476268] Thu, 11 October 2007 05:37 Go to previous message
Hello Stefan,
value.
What do you think?
Previous Topic:Stereotype Application very slow
Next Topic:Loop Node and Conditional Node
Current Time: Sun Aug 31 12:51:39 EDT 2025
Powered by FUDForum. Page generated in 0.42508 seconds
