Home » Modeling » UML2 » packagedElement opposite?
packagedElement opposite? [message #476022] Sat, 22 September 2007 07:38 Go to next message
I wonder why there is no opposite (and changeable) feature of
"packagedElement" im UML2.
This makes it very hard to use this UML2 metamodel in e.g. QVT
transformations, in contrast to UML1.x.
E.g. I can use "packagedElement" like this
enforce domain forward boundPackage: uml::Package {
packagedElement = comp : uml::Component {
name = 'Business Component'
to insert a component into a package.
However this would be the ideal solution (only one
ObjectTemplateExpression):
enforce domain forward comp : uml::Component {
owner = boundPackage,
Though the QVT "workaround" is not so dramatic in this example, in other
examples I have to use additionally new relation domains and
when-conditions, so inexistent opposite features is really annoying when
programming QVT.
Is it a good idea to perhaps modify the UML.ecore, add the opposite
"owner" feature on myself, regenerate model code and still expect that
the UML2 Tools editors can work with it (well I already tried, but my
Eclipse crashed)? However I do not aim an official UML2 specification
change..
Or any other idea?
Re: packagedElement opposite? [message #476195 is a reply to message #476022] Mon, 24 September 2007 12:32 Go to previous messageGo to next message
OCL (and hence, by extension, QVT) can navigate association ends that aren't
navigable and even some that don't have names.
For OCL, the implicit opposite of Package::packagedElement is
PackageableElement::package which, because "package" is a reserved word in
OCL, would be referenced as _package. (The name "package" is obtained by
taking the name of the class at the unnamed end -- Package -- and changing
the initial letter to lower case.)
I would expect, then, that in QVT you should be able to do:
_package = boundPackage,
"owner" is derived, so it makes sense that it not me modifiable, but
packagedElement is not derived, so the implied opposite "package" would
likewise be modifiable.
Christian
> programming QVT.
> change..
> Or any other idea?
Re: packagedElement opposite? [message #476219 is a reply to message #476195] Tue, 25 September 2007 18:00 Go to previous messageGo to next message
> c::package
Where do you have the information that "package" is the opposite of
packagedElement? I do not find an opposite in UML.ecore (there is no
eOpposite attribute).
Re: packagedElement opposite? [message #476220 is a reply to message #476219] Tue, 25 September 2007 18:19 Go to previous message
The UML metamodel defines the Package --> PackageableElement relationship as
a directed association. The Package end is named "packagedElement" and the
PackageableElement end is not navigable and has no name.
OCL handles this kind of situation by:
- being able to navigate non-navigable association ends
- being able to refer to unnamed association ends via an implicit name
The implicit name of the unnamed end is taken from the classifier at the
opposite end (in this case, "Package") and changing the initial letter to
lower case, thus "package".
Ecore (and EMOF) does not have an association concept, so this capability of
OCL does not apply to EssentialOCL nor to OCL on Ecore. It does apply to
UML, and the MDT UML2 API is generated from UML.merged.uml, not from
UML.ecore. In other words, UML2's metamodel is UML, not Ecore. So, this
should work once MDT OCL implements support for unnamed ends in the M3
milestone.
HTH,
Christian
exquisitus wrote:
>> Hi,
>> aren't navigable and even some that don't have names.
>> c::package
Re: packagedElement opposite? [message #624948 is a reply to message #476022] Mon, 24 September 2007 12:32 Go to previous message
Christian
> programming QVT.
> change..
> Or any other idea?
Re: packagedElement opposite? [message #625007 is a reply to message #476195] Tue, 25 September 2007 18:00 Go to previous message
> c::package
Re: packagedElement opposite? [message #625008 is a reply to message #476219] Tue, 25 September 2007 18:19 Go to previous message
milestone.
HTH,
Christian
exquisitus wrote:
>> Hi,
>> c::package
Previous Topic:Re: [UML] UML equivalent EcoreUtil.UsageCrossReferencer
Next Topic:[Announce] MDT UML2 2.1.1 is available
Current Time: Sun Aug 31 16:22:49 EDT 2025
Powered by FUDForum. Page generated in 0.06547 seconds
