Home » Eclipse Projects » JavaServer Faces » Help required on org.eclipse.osgi
Help required on org.eclipse.osgi [message #476121] Thu, 30 April 2009 08:41 Go to next message
I have written a plugin that uses some resources on runtime. These
resources are bundled within the plugin jar itself.
As some of these resources were missing at the actual runtime, I did some
investigation and found that resources from my plugin jar has been copied
to a RAD specific folder at location "C:\Program
Files\IBM\SDP\configuration\org.eclipse.osgi\bundles"
Also, the resources are not complete. That is, this folder has copied only
a few resources from my plugin, not all that I want.
This causes an inconsistent behaviour of my plugin.
Does anyone know what the underlying problem can be ??
Re: Help required on org.eclipse.osgi [message #476126 is a reply to message #476121] Thu, 30 April 2009 21:49 Go to previous message
That's beyond the scope of this newsgroup. You should post it to the
eclipse platform group.
shilpa wrote:
> to a RAD specific folder at location "C:Program
> FilesIBMSDPconfigurationorg.eclipse.osgibundles"
Re: Help required on org.eclipse.osgi [message #618754 is a reply to message #476121] Thu, 30 April 2009 21:49 Go to previous message
shilpa wrote:
Previous Topic:How to prevent some tags from showing in palette
Next Topic:Programmatically add a existing component library to a JSF project
Current Time: Sat Jul 26 20:00:21 EDT 2025
Powered by FUDForum. Page generated in 0.04385 seconds
