Home » Eclipse Projects » JavaServer Faces » Programmatically add a existing component library to a JSF project
Programmatically add a existing component library to a JSF project [message #472958] Mon, 18 September 2006 13:54 Go to next message
I want to develope a plugin which can automatically add a existing
component library to jsf project. The component library comes with the
plugin which defines from the extension point
org.eclipse.jst.jsf.core.jsfLibraries.
If anybody knows how to add the library to the project programmatically?
William
Re: Programmatically add a existing component library to a JSF project [message #472959 is a reply to message #472958] Mon, 18 September 2006 19:12 Go to previous messageGo to next message
William,
It sounds like that you have implemented and deployed a jsfLibraries
extension. Hence, your component library is available during JSF facet
installation.
I am not sure what you mean by adding the component library to a project
pragmatically. Would you mind describing the use case more in details?
Justin
Re: Programmatically add a existing component library to a JSF project [message #472960 is a reply to message #472959] Tue, 19 September 2006 02:21 Go to previous messageGo to next message
Thanks Justin,
What I want is to either make the plugin provided component library listed
in selected library list in new project wizard page so that user doesn't
have to click > to add the component library
or set the component library selected from JSFLibrary or
JSFLibraryRegistry etc before jst.jsf install action happens.
By either way, once user selects my project facet, the component library
should be selected by default through my plugin.
I wonder if this is clear?
William
Re: Programmatically add a existing component library to a JSF project [message #472961 is a reply to message #472959] Tue, 19 September 2006 02:26 Go to previous messageGo to next message
Thanks Justin,
William
Re: Programmatically add a existing component library to a JSF project [message #472963 is a reply to message #472961] Tue, 19 September 2006 13:56 Go to previous messageGo to next message
William,
The fix for bug 146052 may not be the exact answer to your request.
But, it may covers most of the cases once your component library selection
become sticky. I.e., your component library has to be picked once in a
new workspace.
We have the concept of default for implementation library, but not for
component library. Hence, w/o anything being selected, a default
implementation is picked. But, no component library is selected by
default.
I think you are looking for the concept of default component libraries.
We will evaluate the need for a default component library.
Justin
Re: Programmatically add a existing component library to a JSF project [message #472964 is a reply to message #472963] Tue, 19 September 2006 15:06 Go to previous messageGo to next message
Thanks Justin,
The fix for 146052 is not what i need. What I want is the way of
selecting the my custom component library supplied by my plugin by
default if my facet is selected.
Thanks anyway!
Re: Programmatically add a existing component library to a JSF project [message #475027 is a reply to message #472964] Wed, 15 August 2007 23:41 Go to previous messageGo to next message
William wrote:
> Thanks Justin,
> Thanks anyway!
William,
Were you able to find a workaround to do this? I am working on a similar
kind of plugin.
Samrat Dhillon
Re: Programmatically add a existing component library to a JSF project [message #475039 is a reply to message #475027] Mon, 20 August 2007 19:41 Go to previous messageGo to next message
Hi Samrat,
Can you clarify? Is it that you want your component library to appear
automatically in the list of component libraries provided in the "JSF
Capabilities" page of the New Dynamic Project Wizard?
--Cam
Samrat Dhillon wrote:
> William wrote:
>> Thanks Justin,
>> Thanks anyway!
> William,
> kind of plugin.
> Regards
> Samrat Dhillon
Re: Programmatically add a existing component library to a JSF project [message #475040 is a reply to message #475039] Wed, 22 August 2007 03:52 Go to previous messageGo to next message
Hi Cameron,
I want to specify the location of the JSF implementation libraries
programmatically, rather than through the preference page.
I am packaging myfaces libraries inside my plugin. This plugin extends
webproject wizard. I want to specify the location programmatically so
that user does not have to configure with the change of workspace.
Samrat
Cameron Bateman wrote:
> Hi Samrat,
> --Cam
>> William wrote:
>>> Thanks Justin,
>>> Thanks anyway!
>> William,
>> similar kind of plugin.
>> Regards
>> Samrat Dhillon
Re: Programmatically add a existing component library to a JSF project [message #475041 is a reply to message #475040] Wed, 22 August 2007 12:10 Go to previous messageGo to next message
The plugin-provided library extension may be of some help
(org.eclipse.jst.jsf.core.pluginProvidedJsfLibraries). This allows you to
provide a collection name and a
PluginProvidedJSFLibraryArchiveFilesDelegate implementation that points to
the jars. The isImplementation flag needs to be set for it to appear in
the drop down box of runtimes; otherwise it will appear in the shuttle
list of component libs.
Have a look and let us know if that gets you any closer to your goal.
--Cam
> Hi Cameron,
Re: Programmatically add a existing component library to a JSF project [message #475066 is a reply to message #475041] Thu, 23 August 2007 06:01 Go to previous messageGo to next message
Hi Cameron,
Thanks a lot. I have implemented the plugin.
Samrat Dhillon
> to provide a collection name and a
> to the jars. The isImplementation flag needs to be set for it to appear
> in the drop down box of runtimes; otherwise it will appear in the
> shuttle list of component libs.
> --Cam
>> Hi Cameron,
Re: Programmatically add a existing component library to a JSF project [message #476119 is a reply to message #475066] Thu, 30 April 2009 08:02 Go to previous messageGo to next message
Cameron,
I have implemented extension point
org.eclipse.jst.jsf.core.pluginProvidedJsfLibraries to add a few libraries
when a new project is created using my library name.
It works fine when I launch an eclipse using my Plugin.xml for testing.
but when I actually install the plugin, it throws an error and the jars
doesn't get added. I feel the problem is in the way I am exporting or
installing the plugin.
The error message is -
Failed while installing JavaServer Faces 1.1.
assertion failed: Path for IClasspathEntry must be absolute:
file:C:/Program
Files/IBM/SDPShared/plugins/plugins/com.hsbc.glti.jsf.taglib metadata.jhx_1.0.0.jar!/lib/commons-beanutils-1.7.0.jar
Can you suggest some documentation which provides a clear picture of
exporting and packaging the plugin? or if u know any solution to this
problem
Re: Programmatically add a existing component library to a JSF project [message #476127 is a reply to message #476119] Thu, 30 April 2009 21:52 Go to previous message
Off the top of my head, this looks like the "jar inside jar" problem that
some Eclipse file location APIs have. What happens if you export the
plugin in exploded form rather than jar form?
I should also note that in Galileo, the jsf libraries provider mechanism
is deprecated. Going forward, JSF runtime and component libraries need to
be provided through the new facet library provider mechanism.
Cameron
shilpa wrote:
> Cameron,
> file:C:/Program
> problem
Re: Programmatically add a existing component library to a JSF project [message #607617 is a reply to message #472958] Mon, 18 September 2006 19:12 Go to previous message
William,
installation.
Justin
Re: Programmatically add a existing component library to a JSF project [message #607618 is a reply to message #472959] Tue, 19 September 2006 02:21 Go to previous message
Thanks Justin,
William
Re: Programmatically add a existing component library to a JSF project [message #607619 is a reply to message #472959] Tue, 19 September 2006 02:26 Go to previous message
Thanks Justin,
William
Re: Programmatically add a existing component library to a JSF project [message #607623 is a reply to message #472961] Tue, 19 September 2006 13:56 Go to previous message
William,
new workspace.
default.
Justin
Re: Programmatically add a existing component library to a JSF project [message #607626 is a reply to message #472963] Tue, 19 September 2006 15:06 Go to previous message
Thanks Justin,
Thanks anyway!
Re: Programmatically add a existing component library to a JSF project [message #614180 is a reply to message #472964] Wed, 15 August 2007 23:41 Go to previous message
William wrote:
> Thanks Justin,
> Thanks anyway!
William,
kind of plugin.
Samrat Dhillon
Re: Programmatically add a existing component library to a JSF project [message #614218 is a reply to message #475027] Mon, 20 August 2007 19:41 Go to previous message
Hi Samrat,
--Cam
> William wrote:
>> Thanks Justin,
>> Thanks anyway!
> William,
> kind of plugin.
> Regards
> Samrat Dhillon
Re: Programmatically add a existing component library to a JSF project [message #614222 is a reply to message #475039] Wed, 22 August 2007 03:52 Go to previous message
Hi Cameron,
Samrat
> Hi Samrat,
> --Cam
>> William wrote:
>>> Thanks Justin,
>>> Thanks anyway!
>> William,
>> Regards
>> Samrat Dhillon
Re: Programmatically add a existing component library to a JSF project [message #614226 is a reply to message #475040] Wed, 22 August 2007 12:10 Go to previous message
--Cam
> Hi Cameron,
Re: Programmatically add a existing component library to a JSF project [message #614402 is a reply to message #475041] Thu, 23 August 2007 06:01 Go to previous message
Hi Cameron,
Samrat Dhillon
> --Cam
>> Hi Cameron,
Re: Programmatically add a existing component library to a JSF project [message #618747 is a reply to message #475066] Thu, 30 April 2009 08:02 Go to previous message
Cameron,
file:C:/Program
problem
Re: Programmatically add a existing component library to a JSF project [message #618755 is a reply to message #476119] Thu, 30 April 2009 21:52 Go to previous message
Cameron
shilpa wrote:
> Cameron,
> file:C:/Program
> problem
Previous Topic:Help required on org.eclipse.osgi
Next Topic:Announce: Non-breaking API change in IElementEdit due to bug 267962
Current Time: Wed Jul 23 08:44:27 EDT 2025
Powered by FUDForum. Page generated in 0.07951 seconds
