Home » Modeling » UML2 » Required Interface
Required Interface [message #475917] Tue, 18 September 2007 10:16 Go to next message
Originally posted by: nickkirtley.gmail.com
I'm having some problems (see some of my other recent posts / Connector
validation problem and ocl query, getRequireds()).
I think that both problems have one thing in common : required Interface.
I can define a provided interface from port in 2 ways: from uml2tools
component diagram and in uml2 tree editor select port and type it to an
interface.
Problem I'm having is specifying a required interface. How can I do this?
thx
nick
your help has been/is very much appreciated!!!
Re: Required Interface [message #475918 is a reply to message #475917] Tue, 18 September 2007 11:04 Go to previous messageGo to next message
Hi, Nick,
To quote from my reply of 13 September to your posting "ocl query":
AFAIK, this requires that the port's type have some kind of
usage or like dependency on the interface.
So, try creating a class and in that class a dependency on the interface
that you require. Then assign that class as your port's type.
HTH,
Christian
Nick Kirtley wrote:
> interface.
> thx
> nick
Re: Required Interface [message #476014 is a reply to message #475918] Thu, 20 September 2007 09:02 Go to previous messageGo to next message
I still haven't got it working, and by that I mean that I still have an
error regarding the connector validation saying that a connector should
connect a role end requiring and a role end providing that interface.
Secondly I still can't retrieve the required Interface using
self.getRequireds(). So it would seem that required interface is not
defined properly. I'm not sure if I have defined the dependency properly.
three questions:
a) If I already have a component,port and a provided interface, then the
provided interface is defined using type of the port. So if I change the
type of the port to define a required interface, then don't I lose the
provided interface reference?
b) could you provide a detailed explanation of how to define a component,
a port, a required and a provided interface.
c) How do I define a dependency within a class (not sure if I've done it
properly) .
Another remark: this seems like a bit of a work around, to define a
provided port i just select port type, choose interface. But for required
I have to define another class and add a dependency etc.
Re: Required Interface [message #476017 is a reply to message #476014] Thu, 20 September 2007 11:08 Go to previous messageGo to next message
Hi, Nick,
See some replies in-line, below.
Christian
Nick Kirtley wrote:
> three questions:
Specifying the interface as the type of the port is but one way to provide
an interface. Another way is to assign the port a class of some kind that
realizes the interface in question. Such a class can also depend on a
different interface. In that case, your port would both provide and
require interfaces (usually different ones, but not necessarily).
- create component C
- create owned port p in C
- create class X
- create interface I
- create interface J
- create realization relationship to I in X
- create dependency relationship to J in X
- set type of p to be X
> properly) .
If your diagramming application doesn't have tools for creating interface
realizations and/or dependencies, then try using the example tree editor
from UML2: org.eclipse.uml2.uml.editor plug-in.
Perhaps you're thinking of this backwards. The interfaces that a port
requires or provides are derived from the relationships between the port's
type and those interfaces. When modeling a component, the type of a port
is often a class in which you can model the behaviour using interactions,
state machines, etc. The interfaces that the port's type realizes or uses
determine provideds/requireds for wiring the port and/or its component to
other components, not the other way around.
Re: Required Interface [message #476018 is a reply to message #476017] Thu, 20 September 2007 11:19 Go to previous messageGo to next message
.... one small clarification.. the kind of dependency needed to obtain
required interfaces is "Usage" ....
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:fcu2ec$m6v$1@build.eclipse.org...
> Hi, Nick,
> Christian
> Nick Kirtley wrote:
> > Hi,
properly.
> > three questions:
component,
> - create class X
> > properly) .
required
Re: Required Interface [message #476025 is a reply to message #476018] Mon, 24 September 2007 06:42 Go to previous messageGo to next message
I don't see dependency, or usage when I right click class x->new child.
I added Interface realization and it works because I can retrieve the
provided interface using ocl.
What am I doing wrong?
-nick
Re: Required Interface [message #476026 is a reply to message #476025] Mon, 24 September 2007 07:12 Go to previous messageGo to next message
I've got required working, I think, I craeted a component x instead of a
class x and then I see usage in the list from new child -> packaged
element.
i then type the port with x, same as in your explanation.
Is there any reason why I shouldn't use component instead of class like
you suggested?
regards,
Nick
Re: Required Interface [message #476187 is a reply to message #476026] Mon, 24 September 2007 07:43 Go to previous messageGo to next message
One other thing.
When I validate the model it says that i have to set the port to an
composite aggregation kind. Is that because now I have a composite between
port and x?
-nick
Re: Required Interface [message #476191 is a reply to message #476187] Mon, 24 September 2007 11:37 Go to previous messageGo to next message
Constraint [2] in section 9.3.11 indicates that "Port.aggregation must be
composite" which seems to make sense since if the encapsulated classifier
owning the port is deleted, so should the port. The port is an interaction
point between the owing classifier instance and its environment so the port
could not exist on its own.
- James.
"nick kirtley" <nickkirtley@gmail.com> wrote in message
news:3710996e0564478522b8e197600f30f5$1@www.eclipse.org...
> One other thing.
> port and x?
> -nick
Re: Required Interface [message #476192 is a reply to message #476026] Mon, 24 September 2007 11:39 Go to previous messageGo to next message
You can use either a component or a class.
- James.
news:3a2b985d04daa13890b8e96e9da2104b$1@www.eclipse.org...
> element.
> you suggested?
> regards,
> Nick
Re: Required Interface [message #476200 is a reply to message #476192] Mon, 24 September 2007 17:20 Go to previous messageGo to next message
hi,
Yeah but i don't see usage option for class, and i'd rather use a class,
but i suppose it doesn't really matter.
But I find it slightly 'overkill' to use a component for a port type.
regards,
Nick
Re: Required Interface [message #476209 is a reply to message #476200] Tue, 25 September 2007 05:25 Go to previous messageGo to next message
hi,
Could you also explain what's going on when I type a port with a component.
The effect is that when component requires/provides interfaces then the
port does too, but what does typing actually mean?
regards,
nick
Re: Required Interface [message #476224 is a reply to message #476209] Wed, 26 September 2007 17:27 Go to previous messageGo to next message
By typing the port you are specifying the kind of port that you are working
with.
It is a convenient way of using a similar port somewhere else ... you would
just set its type and presto, the port would know about the kinds of
required or provided interfaces that are supported. If the port did not
derive its required and provided interfaces from the type it might get
tedious to specify all requireds and provides all the time for different
ports. I believe that people at the OMG defining the spec wanted to reuse
Property concepts when talking about Ports which is why the spec has ports
as typeable items ( ports are properties ).
I would think that typing a port with a Component is open to interpretation
somewhat. According to the spec, Components "represent a modular part of a
system that encapsulates its contents .." ... so generating code from a port
typed by a component would be open to interpretation. For practical
purposes, I would tend to stick to typing ports by Class as opposed to
Component.
.... not sure if that helps :) ...
- James.
news:a6c9928f55e6007e8be041ade7c86cb0$1@www.eclipse.org...
> hi,
component.
> regards,
> nick
Re: Required Interface [message #476225 is a reply to message #476224] Thu, 27 September 2007 06:41 Go to previous messageGo to next message
hi,
I would prefer to use class as well, considering all it will do is
realize/use an interface. Using a class seems smaller/tidier.
However , I can't find the usage option for class, I've looked at all the
options when right clicking ->new child for a class. It works for
component but not for class.
You know what the problem is?
nick
Re: Required Interface [message #476227 is a reply to message #476225] Thu, 27 September 2007 09:51 Go to previous messageGo to next message
Hi, Nick,
Dependencies (including Usages) are owned by Packages, not by Classifiers.
The reason is that a dependency can have multiple clients, so none of them
can reasonably own it.
Try the new child menu of the containing package.
HTH,
Christian
nick kirtley wrote:
> hi,
> nick
Re: Required Interface [message #476228 is a reply to message #476227] Thu, 27 September 2007 10:03 Go to previous messageGo to next message
yes I can see usage within package and component.
I can't type a port with a package though.
You said in one of the earlier posts to create usage within class x and
then to type port with x. Not to type port with package.
nick
Re: Required Interface [message #476230 is a reply to message #476228] Thu, 27 September 2007 12:48 Go to previous message
Hi, Nick,
Sorry, I guess I used some loose terminology. I should have said "create a
clientDependency of type Usage on Class X supplied by Interface Y."
Packages are not Types; you don't want to use a package as the type of your
port. The Usage that has X as a client and Y as a supplier indicates that
X uses Y, i.e., that X "requires" Y in the component terminology.
So, create in your package a Usage whose client is the Class that types your
Port and whose supplier is the Interface that you want your Port to
require. That's it. I don't think I'll be able to spell it out more
clearly.
This is all, incidentally, described fairly clearly in the UML
specification. The description of Usage even uses the word "require":
A usage is a relationship in which one element requires
another element (or set of elements) for its full
implementation or operation. In the metamodel, a Usage is
a Dependency in which the client requires the presence of
the supplier.
Christian
> nick
Re: Required Interface [message #624811 is a reply to message #475917] Tue, 18 September 2007 11:04 Go to previous message
Hi, Nick,
HTH,
Christian
Nick Kirtley wrote:
> interface.
> thx
> nick
Re: Required Interface [message #624917 is a reply to message #475918] Thu, 20 September 2007 09:02 Go to previous message
three questions:
properly) .
Re: Required Interface [message #624926 is a reply to message #476014] Thu, 20 September 2007 11:08 Go to previous message
Hi, Nick,
Christian
Nick Kirtley wrote:
> three questions:
- create class X
> properly) .
Re: Required Interface [message #624928 is a reply to message #476017] Thu, 20 September 2007 11:19 Go to previous message
> Hi, Nick,
> Christian
> Nick Kirtley wrote:
> > Hi,
properly.
> > three questions:
component,
> - create class X
> > properly) .
required
Re: Required Interface [message #624943 is a reply to message #476018] Mon, 24 September 2007 06:42 Go to previous message
-nick
Re: Required Interface [message #624944 is a reply to message #476025] Mon, 24 September 2007 07:12 Go to previous message
element.
you suggested?
regards,
Nick
Re: Required Interface [message #624945 is a reply to message #476026] Mon, 24 September 2007 07:43 Go to previous message
One other thing.
port and x?
-nick
Re: Required Interface [message #624946 is a reply to message #476187] Mon, 24 September 2007 11:37 Go to previous message
- James.
> One other thing.
> port and x?
> -nick
Re: Required Interface [message #624947 is a reply to message #476026] Mon, 24 September 2007 11:39 Go to previous message
- James.
> element.
> you suggested?
> regards,
> Nick
Re: Required Interface [message #624950 is a reply to message #476192] Mon, 24 September 2007 17:20 Go to previous message
hi,
regards,
Nick
Re: Required Interface [message #624997 is a reply to message #476200] Tue, 25 September 2007 05:25 Go to previous message
hi,
regards,
nick
Re: Required Interface [message #625012 is a reply to message #476209] Wed, 26 September 2007 17:27 Go to previous message
with.
Component.
- James.
> hi,
component.
> regards,
> nick
Re: Required Interface [message #625013 is a reply to message #476224] Thu, 27 September 2007 06:41 Go to previous message
hi,
nick
Re: Required Interface [message #625024 is a reply to message #476225] Thu, 27 September 2007 09:51 Go to previous message
Hi, Nick,
HTH,
Christian
nick kirtley wrote:
> hi,
> nick
Re: Required Interface [message #625026 is a reply to message #476227] Thu, 27 September 2007 10:03 Go to previous message
nick
Re: Required Interface [message #625030 is a reply to message #476228] Thu, 27 September 2007 12:48 Go to previous message
Hi, Nick,
clearly.
the supplier.
Christian
> nick
Previous Topic:Re: Stereotype creation
Next Topic:dynamic EMF profiles
Current Time: Sun Aug 31 12:46:54 EDT 2025
Powered by FUDForum. Page generated in 0.09604 seconds
