Home » Modeling » UML2 » problem with the persistence of the applied stereo type.
problem with the persistence of the applied stereo type. [message #475861] |
Thu, 13 September 2007 10:02  |
Originally posted by: rmishra.tibco.com
I am trying to apply UML stereo type on UML property .it's getting applied
properly and i can get the applied stereo type and values back too.
but when i see the XMI file , i don't see the stereo type attached---
can any body help me out --what may be the problem--
Re: problem with the persistence of the applied stereo type. [message #475864 is a reply to message #475863] |
Fri, 14 September 2007 02:25   |
i am not able to figure out where it is hiding -----
what should i do to make sure that serialization is happenning properly.
one case i observed ,if i apply stereo type just after creating the uml
property in the folowing way,
Property prop = createAttribute(dataObject.getUmlClass(),
attribute.getName(), type,
attribute.getLowerBound(),attribute.getUpperBound());
Stereotype eAttributeStrType =
profileLoader.getStereoType(model,"Attribute");
if(eAttributeStrType != null){
EObject eobject = prop.applyStereotype(eAttributeStrType);
it doesn't get serialized.
but if i create model first and then iterate thrugh the uml properties and
apply stereo type ,then it gets serialized properly.
List<Property> attributeList = clazzElement.getOwnedAttributes();
for (Property propertyElement : attributeList) {
propertyElement.applyStereotype(st);
i will be highly thankful for any kind of help.let me know if i am doing any
thing wrong with the first case.
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fcc1mj$bps$2@build.eclipse.org...
> Hi Raju,
> Stereotype applications appear at the bottom of the serialized model and
> have references back to the elements they are applied to. If you can
> programatically set stereotype values and retrieve them, then the
> information is being serialized. The information is hiding there
> somewhere
> - James.
> "Raju Mishra" <rmishra@tibco.com> wrote in message
> news:fcbfto$qr4$1@build.eclipse.org...
>> Hi,
>> applied
Re: problem with the persistence of the applied stereo type. [message #475895 is a reply to message #475864] |
Fri, 14 September 2007 09:53   |
Some comments below ...
news:fcd9g8$kf8$1@build.eclipse.org...
Did you look at the bottom of the serialized model as previously suggested?
What do you see at the bottom of the model?
.... Do you mean you just can't see the values in the serialized model or
that if you try to obtain the stereotype programmatically that they are not
correctly returned?
When you say it gets serialized properly, you mean that you can see it in
the xmi?
any
In your original posting you said that you could programatically apply
stereotypes, set values and get them back but that you could not see them in
the xmi file. If you post your model, I can point out where the
stereotypes are.
> > Hi Raju,
> > somewhere
> > - James.
> >> Hi,
> >> applied
Re: problem with the persistence of the applied stereo type. [message #475896 is a reply to message #475864] |
Raju,
Have the model elements been added to a resource before applying the
stereotypes, or are you adding all of the elements to a resource just before
saving. If the latter, you'll need to explicitly add all the stereotype
applications to the resource before saving the resource...
Kenn
> any thing wrong with the first case.
>> Hi Raju,
>> somewhere
>> - James.
>>> Hi,
>>> applied
Re: problem with the persistence of the applied stereo type. [message #475915 is a reply to message #475896] |
Tue, 18 September 2007 02:34   |
thanks a lot--
i was adding all the elements including stereo types to the model and then
adding it to the resource.This way i need to apply stereo types explicitly
to make it serialized.
if i add model to the resource and then add all the elements including
stereo types to the model ,every thing gets serialized properly.
once again thanks alot---But one thing i m wondering ,even in the first case
it should work fine.Is it a bug-----
"Kenn Hussey" <Kenn.Hussey@embarcadero.com> wrote in message
news:fce3oa$cpi$1@build.eclipse.org...
> Raju,
> before saving. If the latter, you'll need to explicitly add all the
> stereotype applications to the resource before saving the resource...
> Kenn
>> and apply stereo type ,then it gets serialized properly.
>>> Hi Raju,
>>> somewhere
>>> - James.
>>>> Hi,
>>>> applied
Re: problem with the persistence of the applied stereo type. [message #475916 is a reply to message #475895] |
Tue, 18 September 2007 02:36   |
Hi James,
It should work with the first approach also--i don't know why it doesn't
work.
Thanks for your help---
news:fce3nv$cod$2@build.eclipse.org...
> suggested?
> not
> correctly returned?
>> and
> the xmi?
> any
> in
> stereotypes are.
>> > Hi Raju,
>> > and
>> > somewhere
>> > - James.
>> >> Hi,
>> >> applied
Re: problem with the persistence of the applied stereo type. [message #475919 is a reply to message #475915] |
Tue, 18 September 2007 12:02   |
Raju,
This works as designed. Stereotype applications are separate objects that
typically live at the root of the resource containing the elements they are
applied to (although they could in fact live in a separate resource),
because they are not contained within the hierarchy of UML elements (as per
the specification). Without the context of a resource to attach the object
to, when a stereotype is applied, the stereotype application isn't contained
anywhere - that's why, if you wait until later to add your model elements to
a resource, they need to be explicitly attached to the same (or different)
resource in order to be serialized.
Kenn
news:fcnrh7$iph$1@build.eclipse.org...
> thanks a lot--
> case it should work fine.Is it a bug-----
>> Raju,
>> Kenn
>>>> Hi Raju,
>>>> and
>>>> somewhere
>>>> - James.
>>>>> Hi,
>>>>> applied
Re: problem with the persistence of the applied stereo type. [message #475920 is a reply to message #475916] |
Raju,
See my reply to your other posting.
Kenn
news:fcnrls$l3d$1@build.eclipse.org...
> Hi James,
> work.
>> suggested?
>> not
>> correctly returned?
>>> and
>> the xmi?
>> any
>> in
>> stereotypes are.
>>> > Hi Raju,
>>> > and
>>> > somewhere
>>> > - James.
>>> >> Hi,
>>> >> applied
Re: problem with the persistence of the applied stereo type. [message #476007 is a reply to message #475919] |
Wed, 19 September 2007 02:43  |
Thanks kenn , i got your point---
news:fcosq5$6fh$1@build.eclipse.org...
> Raju,
> are applied to (although they could in fact live in a separate resource),
> per the specification). Without the context of a resource to attach the
> object to, when a stereotype is applied, the stereotype application isn't
> contained anywhere - that's why, if you wait until later to add your model
> elements to a resource, they need to be explicitly attached to the same
> (or different) resource in order to be serialized.
> Kenn
>> thanks a lot--
>> then adding it to the resource.This way i need to apply stereo types
>> explicitly to make it serialized.
>>> Raju,
>>> Kenn
>>>> properly.
>>>> uml property in the folowing way,
>>>> doing any thing wrong with the first case.
>>>>> Hi Raju,
>>>>> and
>>>>> somewhere
>>>>> - James.
>>>>>> Hi,
>>>>>> applied
Re: problem with the persistence of the applied stereo type. [message #624754 is a reply to message #475861] |
Thu, 13 September 2007 15:05  |
Hi Raju,
information is being serialized. The information is hiding there somewhere
- James.
Re: problem with the persistence of the applied stereo type. [message #624755 is a reply to message #475863] |
> Hi Raju,
> somewhere
> - James.
>> Hi,
>> applied
Re: problem with the persistence of the applied stereo type. [message #624787 is a reply to message #475864] |
correctly returned?
the xmi?
any
stereotypes are.
> > Hi Raju,
> > somewhere
> > - James.
> >> Hi,
> >> applied
Re: problem with the persistence of the applied stereo type. [message #624788 is a reply to message #475864] |
Raju,
Kenn
>> Hi Raju,
>> somewhere
>> - James.
>>> Hi,
>>> applied
Re: problem with the persistence of the applied stereo type. [message #624808 is a reply to message #475896] |
thanks a lot--
> Raju,
> Kenn
>>> Hi Raju,
>>> somewhere
>>> - James.
>>>> Hi,
>>>> applied
Re: problem with the persistence of the applied stereo type. [message #624809 is a reply to message #475895] |
Hi James,
work.
> suggested?
> not
> correctly returned?
>> and
> the xmi?
> any
> in
> stereotypes are.
>> > Hi Raju,
>> > and
>> > somewhere
>> > - James.
>> >> Hi,
>> >> applied
Re: problem with the persistence of the applied stereo type. [message #624812 is a reply to message #475915] |
Raju,
Kenn
> thanks a lot--
>> Raju,
>> Kenn
>>>> Hi Raju,
>>>> and
>>>> somewhere
>>>> - James.
>>>>> Hi,
>>>>> applied
Re: problem with the persistence of the applied stereo type. [message #624813 is a reply to message #475916] |
Raju,
Kenn
> Hi James,
> work.
>> suggested?
>> not
>> correctly returned?
>>> and
>> the xmi?
>> any
>> in
>> stereotypes are.
>>> > Hi Raju,
>>> > and
>>> > somewhere
>>> > - James.
>>> >> Hi,
>>> >> applied
Re: problem with the persistence of the applied stereo type. [message #624820 is a reply to message #475919] |
> Raju,
> Kenn
>> thanks a lot--
>>> Raju,
>>> Kenn
>>>> properly.
>>>>> Hi Raju,
>>>>> and
>>>>> somewhere
>>>>> - James.
>>>>>> Hi,
>>>>>> applied
Current Time: Sun Aug 31 09:54:32 EDT 2025
Powered by FUDForum. Page generated in 0.07249 seconds
