Home » Eclipse Projects » JavaServer Faces » How metadata files generated
How metadata files generated [message #475992] Wed, 16 July 2008 17:49 Go to next message
Originally posted by: Eclipsian.eclipsian.oti
In order to integrate custom components into Eclipse, a set of metadata
files are required such as metadata for tag creation, content
assistance, attributes list and quick editors. I wonder how the
attributes metadata for Sun RI components and Trinidad are generated?
Manually? Is there such a kind of tool available? Generate metadata for
attribute sheet is tidious.
Thx
Re: How metadata files generated [message #475993 is a reply to message #475992] Wed, 16 July 2008 19:18 Go to previous messageGo to next message
As you have discovered, there is no editor to simplify the creation, or
modification, of a tag library metadata file. However, Yury Kats of IBM
has made a utility available that will generate a starting point metadata
file of all of the tag and attribute entities. You will find it attached
to: https://bugs.eclipse.org/bugs/show_bug.cgi?id=181674.
Gerry Kessler
WTP JSF Tools Team
Re: How metadata files generated [message #475994 is a reply to message #475993] Thu, 17 July 2008 13:46 Go to previous messageGo to next message
Keep in mind, it's over a year old now and hasn't been updated since.
Re: How metadata files generated [message #475995 is a reply to message #475994] Thu, 17 July 2008 17:44 Go to previous messageGo to next message
Yes. It was for WTP 2.0 not WTP 3.0.
It helps but not a lot. I wonder if it is possible to do some more work
based on EMF code in current jst.jsf.core
Re: How metadata files generated [message #475996 is a reply to message #475995] Fri, 18 July 2008 11:47 Go to previous messageGo to next message
Please create an enhancement request using Bugzilla outlining what you
want.
Re: How metadata files generated [message #475997 is a reply to message #475995] Fri, 18 July 2008 20:20 Go to previous message
Has metadata changed that much between 2.0 and 3.0? I don't think it has.
The tool would give you a skeleton XML that at the very least contains
all tags and all attributes. You can certainly get the same from the EMF model.
I was also creating actual metadata for many common attributes (id, value, rendered,
action, width etc etc). You won't get from the EMF model.
Re: How metadata files generated [message #618319 is a reply to message #475992] Wed, 16 July 2008 19:18 Go to previous message
Gerry Kessler
WTP JSF Tools Team
Re: How metadata files generated [message #618320 is a reply to message #475993] Thu, 17 July 2008 13:46 Go to previous message
Re: How metadata files generated [message #618322 is a reply to message #475994] Thu, 17 July 2008 17:44 Go to previous message
Re: How metadata files generated [message #618323 is a reply to message #475995] Fri, 18 July 2008 11:47 Go to previous message
want.
Re: How metadata files generated [message #618324 is a reply to message #475995] Fri, 18 July 2008 20:20 Go to previous message
Previous Topic:How metadata files generated
Next Topic:Contact form with attachment
Current Time: Fri Jul 25 07:35:21 EDT 2025
Powered by FUDForum. Page generated in 0.12426 seconds
