Home » Modeling » UML2 Tools » Stereotype for associations
Stereotype for associations [message #475954] Thu, 27 November 2008 12:27 Go to next message
Originally posted by: michael.gebhart.googlemail.com
I am using MDT and want to apply stereotypes I defined to an
association. This works, but the stereotype isn't displayed. Any idea
how I can make this stereotype visible?
Greetings
Mike
Re: Stereotype for associations [message #475956 is a reply to message #475954] Tue, 02 December 2008 17:01 Go to previous messageGo to next message
Hello Michael,
You applied a stereotype to an association, but its name was not dispalyed
on the diagram as a label, right?
Let's try to figure out where is a problem together.
I applied EClass stereotype from Ecore profile to an association and it worked
completely fine, the label was displayed. Is label for EClass stereotype
displayed on your machine? Ecore stereotype is stereotype from Ecore profile,
which is provided by UML2 and automatically added to the list of available
profiles.
Besides, is there any messages in you error log?
Best wishes,
Tanya.
> Greetings
> Mike
Re: Stereotype for associations [message #475957 is a reply to message #475956] Wed, 03 December 2008 07:37 Go to previous messageGo to next message
Hello Tanya,
thanks for your help. No, also the EClass stereotype isn't displayed.
When selecting the association in the properties view it is displayed as
<<eClass>> <Association> A_src_dst. Thus, obviously the application of
the stereotype worked. But in the diagram view the stereotype isn't visible.
Greetings
Mike
Re: Stereotype for associations [message #475963 is a reply to message #475957] Thu, 04 December 2008 14:25 Go to previous messageGo to next message
Hi Mike,
As I understand, your error log is empty, is that correct?
I'm thrilled.
Could you please create simple diagram, that containes classes A and B and
an association between them. Apply EClass profile to an association and send
me both domain model and diagram files. It will allow me to know if the label
for stereotype is created or not. Depending on it we find the place where
to start debugging ;) .
Tanya.
> Hello Tanya,
> as <<eClass>> <Association> A_src_dst. Thus, obviously the application
> of the stereotype worked. But in the diagram view the stereotype isn't
> visible.
> Greetings
> Mike
Re: Stereotype for associations [message #476067 is a reply to message #475963] Mon, 08 December 2008 02:42 Go to previous messageGo to next message
Hi Tanya,
yup, no error log entries. I'll send you the files per eMail.
Thanks!
Mike
> Hi Mike,
> I'm thrilled. Could you please create simple diagram, that containes
> classes A and B and an association between them. Apply EClass profile to
> an association and send me both domain model and diagram files. It will
> allow me to know if the label for stereotype is created or not.
> Depending on it we find the place where to start debugging ;) .
> Cheers,
> Tanya.
>> Hello Tanya,
>> visible.
>> Greetings
>> Mike
Re: Stereotype for associations [message #476173 is a reply to message #476067] Mon, 05 January 2009 10:03 Go to previous messageGo to next message
have you received my files?
Greetings
Mike
Re: Stereotype for associations [message #476333 is a reply to message #476173] Mon, 02 March 2009 08:16 Go to previous message
BTW: The label of the association is displayed. But I don't see the name
of the stereotype within the diagram.
Greetings
Michael
Re: Stereotype for associations [message #623298 is a reply to message #475954] Tue, 02 December 2008 17:01 Go to previous message
Hello Michael,
profiles.
Best wishes,
Tanya.
> Greetings
> Mike
Re: Stereotype for associations [message #623300 is a reply to message #475956] Wed, 03 December 2008 07:37 Go to previous message
Hello Tanya,
Greetings
Mike
Re: Stereotype for associations [message #623359 is a reply to message #475957] Thu, 04 December 2008 14:25 Go to previous message
Hi Mike,
I'm thrilled.
Tanya.
> Hello Tanya,
> visible.
> Greetings
> Mike
Re: Stereotype for associations [message #623363 is a reply to message #475963] Mon, 08 December 2008 02:42 Go to previous message
Hi Tanya,
Thanks!
Mike
> Hi Mike,
> Cheers,
> Tanya.
>> Hello Tanya,
>> visible.
>> Greetings
>> Mike
Re: Stereotype for associations [message #623400 is a reply to message #476067] Mon, 05 January 2009 10:03 Go to previous message
Greetings
Mike
Re: Stereotype for associations [message #623615 is a reply to message #476173] Mon, 02 March 2009 08:16 Go to previous message
Greetings
Michael
Previous Topic:Creating diagram using UML2 tools APIs
Next Topic:Template binding
Current Time: Sat Jul 26 22:14:11 EDT 2025
Powered by FUDForum. Page generated in 0.53425 seconds
