Re: Show entry/exit actions in state machine diagrams [message #475953 is a reply to message #474435] |
Wed, 26 November 2008 14:23   |
Originally posted by: regent.larcheveque.asc-csa.gc.ca
I have the same problem of Peter. I am using 0.9.0M3b to be sure to use
the latest & greatest features of UML2 Tools. Actually it is possible
to create and see entry/exit points in the State Diagram Editor. But
when you create a sub-machine state that refers to a state machine that
contains entry/exit points, the Diagram does not display the
sub-machine state entry/exit points. On the other side, the UML model
contains the proper information.
What do I do wrong? What should I do to be able to display sub-machine
state entry-exit points and make connection to those points from the
container state machine?
Thanks in advance.
Regent ;-)
Tatiana Fesenko wrote:
> Hi Peter,
> Entry/Exit behaviors _are_ displayed in State Machine diagram editor.
> For example, '15.32.State with compartments' diagram contains 'Typing
> Password' which has both entry and exit behaviors. This diagram is
> located in 'org.eclipse.uml2.diagram.examples.clazz' plugin in
> 'diagram/06-04-02/State Machines' folder. Peter, are entry/exit actions
> from this sample displayed correctly in your workspace? However, it's
> not possible now to create entry/exit action directly in the diagram
> editor, they should be created in uml editor.
> Best wishes,
> Tatiana.
>> Hello,
>> how can I show an entry action for my state in the state machine
>> diagram.
>> I can see the action only in the property view.
>> Kind regards
>> Peter
Re: Show entry/exit actions in state machine diagrams [message #475966 is a reply to message #475961] |
Fri, 05 December 2008 13:09  |
Ooopps. You are right. Thanks for the answer. It works now.
Regent ;-)
Sergey Gribovsky wrote:
> Hi Regent,
> Original message from Peter was about entry/exit actions (not points).
> If you want to display entry/exit point of StateMachine on submachine state,
> you should use ConnectionPointReference (UML 2.1.2, Chapter 15.3.1).
> ConnectionPointReference is implemented in frame of UML2Tools. You can
> create it using "entry/exit point" button and apply it to submachine state,
> then select corresponding entry/exit point in statemachine reference and
> ConnectionPointReference will be created.
> Best regards,
> Sergey.
> "Regent L'Archeveque" <regent.larcheveque@asc-csa.gc.ca> wrote in message
> news:ggk7n4$9sn$1@build.eclipse.org...
>> the latest & greatest features of UML2 Tools. Actually it is possible to
>> create and see entry/exit points in the State Diagram Editor. But when you
>> create a sub-machine state that refers to a state machine that contains
>> entry/exit points, the Diagram does not display the sub-machine state
>> entry/exit points. On the other side, the UML model contains the proper
>> information.
>> Thanks in advance.
>> Regent ;-)
Re: Show entry/exit actions in state machine diagrams [message #619980 is a reply to message #474434] |
Tue, 10 June 2008 05:34  |
Hi Peter,
Entry/Exit behaviors _are_ displayed in State Machine diagram editor. For
example, '15.32.State with compartments' diagram contains 'Typing Password'
which has both entry and exit behaviors. This diagram is located in 'org.eclipse.uml2.diagram.examples.clazz'
plugin in 'diagram/06-04-02/State Machines' folder. Peter, are entry/exit
actions from this sample displayed correctly in your workspace?
However, it's not possible now to create entry/exit action directly in the
diagram editor, they should be created in uml editor.
Best wishes,
Tatiana.
> Hello,
> diagram.
> Kind regards
> Peter
Re: Show entry/exit actions in state machine diagrams [message #623291 is a reply to message #474435] |
Thanks in advance.
Regent ;-)
> Hi Peter,
> Best wishes,
> Tatiana.
>> Hello,
>> diagram.
>> Kind regards
>> Peter
Re: Show entry/exit actions in state machine diagrams [message #623357 is a reply to message #475953] |
Thu, 04 December 2008 09:23  |
Hi Regent,
Sergey.
>information.
> Thanks in advance.
> Regent ;-)
Re: Show entry/exit actions in state machine diagrams [message #623362 is a reply to message #475961] |
Regent ;-)
> Hi Regent,
> Best regards,
> Sergey.
>> information.
>> Thanks in advance.
>> Regent ;-)
FUDForum. Page generated in 0.15759 seconds
