Home » Modeling » UML2 Tools » epsilon.common.dt.tool extension for UMLCreateShortcutAction
epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #475940] |
Tue, 25 November 2008 02:27  |
Can anyone please tell me how I could invoke from an EWL file the
org.eclipse.uml2.diagram.clazz.part.UMLCreateShortcutAction command?
This class is defined as an org.eclipse.core.commands.AbstractHandler
and defines a public method:
public Object execute(ExecutionEvent event) throws ExecutionException { ...
I don't know how to construct an
org.eclipse.core.commands.ExecutionEvent from the IGraphicalEditPart
'self' variable of the wizard.
Suggestions?
-- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #475945 is a reply to message #475944] |
Tue, 25 November 2008 10:48   |
Hi Nicolas,
Thanks for the feedback!
It may be something that has been fixed/broken in 3.5. I'll have to
setup 3.5 myself in order to investigate more (which may take a couple
of days). Could you please file a bug so that we can keep track of this?
In the mean time, you could use EWL by contributing an extension to the
org.eclipse.epsilon.ewl.emf.wizards extension point and starting a new
runtime workbench.
Dimitrios
Nicolas Rouquette wrote:
> Hi Dimitrios,
> I'm using the 3.5 M3 version of Eclipse, EMF/UML/UML2Tools.
> The UML2Tools APIs changed from 3.4 to 3.5M3 but Epsilon compiles &
> seems to run OK.
> The only changes I had to make were:
> org.eclipse.epsilon.dt.exeed.modelink.ModeLinkEditor.activat eEditor(IEditorPart)
> => changed from protected to public
> org.eclipse.epsilon.ewl.emf.WizardsExtensionPreferenceDialog
> => this just doesn't work as intended.
> i.e., I when I click on the Add.. button, I have a simple TitleDialog
> but nothing else to select a namespace / *.ewl file.
> When I click on the Edit... button, I get the same title dialog.
> No capability to edit the namespace/*.ewl file.
> -- Nicolas.
> Dimitrios Kolovos wrote:
>> Hi Nicolas,
>> Which version of the UML2Tools are you using? In my 0.8.0,
>> UMLCreateShortcutAction implements IObjectActionDelegate and doesn't
>> seem to be defining an execute(ExecutionEvent event) method.
>> Cheers,
>> Dimitris
>>> Suggestions?
>>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #475950 is a reply to message #475945] |
Tue, 25 November 2008 15:36   |
I've solved the problem with a patch to the UMLCreateShortcutAction that
exposes the reusable functionality for creating the shortcut as a static
method that we can invoke from an Epsilon wizard.
See bug 256496
-- Nicolas.
> Hi Nicolas,
> runtime workbench.
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> seems to run OK.
>> -- Nicolas.
>>> Hi Nicolas,
>>> Cheers,
>>> Dimitris
>>>> org.eclipse.core.commands.AbstractHandler and defines a public method:
>>>> Suggestions?
>>>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #475951 is a reply to message #475950] |
Tue, 25 November 2008 16:08  |
For details how to do this, see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256500
-- Nicolas.
> See bug 256496
> -- Nicolas.
>> Hi Nicolas,
>> the org.eclipse.epsilon.ewl.emf.wizards extension point and starting a
>> new runtime workbench.
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> seems to run OK.
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> Cheers,
>>>> Dimitris
>>>>> IGraphicalEditPart 'self' variable of the wizard.
>>>>> Suggestions?
>>>>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #623277 is a reply to message #475940] |
Tue, 25 November 2008 04:43  |
Hi Nicolas,
Dimitris
> Suggestions?
> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #623280 is a reply to message #475941] |
Tue, 25 November 2008 10:01  |
Hi Dimitrios,
seems to run OK.
-- Nicolas.
> Hi Nicolas,
> Cheers,
> Dimitris
>> Suggestions?
>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #623281 is a reply to message #475944] |
Hi Nicolas,
runtime workbench.
Dimitrios
> Hi Dimitrios,
> seems to run OK.
> -- Nicolas.
>> Hi Nicolas,
>> Cheers,
>> Dimitris
>>> Suggestions?
>>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #623287 is a reply to message #475945] |
See bug 256496
-- Nicolas.
> Hi Nicolas,
> runtime workbench.
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> seems to run OK.
>> -- Nicolas.
>>> Hi Nicolas,
>>> Cheers,
>>> Dimitris
>>>> Suggestions?
>>>> -- Nicolas.
Re: epsilon.common.dt.tool extension for UMLCreateShortcutAction [message #623289 is a reply to message #475950] |
-- Nicolas.
> See bug 256496
> -- Nicolas.
>> Hi Nicolas,
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> seems to run OK.
>>> -- Nicolas.
>>>> Hi Nicolas,
>>>> Cheers,
>>>> Dimitris
>>>>> Suggestions?
>>>>> -- Nicolas.
Current Time: Wed Jul 23 17:35:40 EDT 2025
Powered by FUDForum. Page generated in 0.26024 seconds
