Home » Modeling » UML2 Tools » Re: Problems with creating simple UML2 class diagram
Re: Problems with creating simple UML2 class diagram [message #475885] Mon, 24 November 2008 09:46 Go to next message
Milan,
I assume you're using the UML2 Tools component? If so, please direct your
question to the eclipse.modeling.mdt.uml2tools newsgroup (copied).
Kenn
"Milan Milanovich" <milanmilanovich@yahoo.com> wrote in message
news:2f918f1afe7fde060fa0e23cd164112c$1@www.eclipse.org...
> I need to create simple UML2 diagram with Eclipse Ganymede UML2 (2.2.1)
> plug-in. But, I have two problems. First, I cannot find Date and Double as
> Primitive types ? Second, when I draw association between two classes, I
> cannot change names of their association ends ?
> Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #475927 is a reply to message #475885] Mon, 24 November 2008 10:11 Go to previous messageGo to next message
Yes Kenn, that's right. Thank you.
Milan
Kenn Hussey wrote:
> Milan,
> Kenn
>> Hi,
>> Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #475928 is a reply to message #475927] Mon, 24 November 2008 13:50 Go to previous messageGo to next message
Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #475929 is a reply to message #475928] Mon, 24 November 2008 15:47 Go to previous messageGo to next message
Hello Milan,
> First, I cannot find Date and Double as Primitive types ?
There are at least two libraries, where Date and Double are defined, - Java
Primitive Types and XML Primitive Types. In order to import them into your
diagram:
1) Load required library (e.g. JavaPrimitiveTypes):
Invoke 'Load resource' action from the context menu of the diagram, choose
library file, e.g. org.eclipse.uml2.uml.resources/libraries/JavaPrimitiveType.l ibrary.uml
2) Create element import element using ElementImport palette entry. In the
label-inplace type JavaPrimitiveTypes::Date or use code-assist.
> between two classes, I cannot change names of their association ends ?
You can change a name of an association end directly in the diagram editor
using label-inplaces, source/target ends are names 'src' and 'dst' by default.
Alternatively, you can edit them in SourceEnd/TargetEnd tabs of the properties
view.
Please, let me know if you have any other questions or problems.
Best wishes,
Tanya.
> Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #475932 is a reply to message #475929] Mon, 24 November 2008 17:17 Go to previous messageGo to next message
Dear Tanya,
thank you on answer.
Tatiana Fesenko wrote:
> Hello Milan,
> diagram:
> library file, e.g.
I tried this, but I just have org.eclipse.uml2.uml.resources.jar in my
eclipse/plugins directory, I cannot access JavaPrimitiveType.library.uml
file in "Load resource" way ?
default.
properties
> view.
O.K. I found it.
Best regards, Milan
> Best wishes,
> Tanya.
>> Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #475933 is a reply to message #475932] Mon, 24 November 2008 17:27 Go to previous messageGo to next message
Dear Tanya,
one more thing, how can I define stereotype on a class ?
Thanks, Milan
Re: Problems with creating simple UML2 class diagram [message #475934 is a reply to message #475933] Mon, 24 November 2008 17:44 Go to previous messageGo to next message
Dear Tanya,
sorry I forgot to ask also, how to add multiplicity to association end ?
Milan
Re: Problems with creating simple UML2 class diagram [message #475935 is a reply to message #475932] Mon, 24 November 2008 17:47 Go to previous messageGo to next message
Milan,
'Load Resource...' dialog processes URIs, thus just type 'platform:/plugin/org.eclipse.uml2.uml.resources/libraries/E corePrimitiveTypes.library.uml'
string and that will help.
Tanya.
> Dear Tanya,
>> Hello Milan,
>> - Java
>> your
>> diagram:
>> choose
>> library file, e.g.
> JavaPrimitiveType.library.uml file in "Load resource" way ?
>> In the label-inplace type JavaPrimitiveTypes::Date or use
>> code-assist.
>> editor using label-inplaces, source/target ends are names 'src' and
>> 'dst' by
> default.
> properties
>> view.
> O.K. I found it.
> Best regards, Milan
>> Best wishes,
>> Tanya.
>>> Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #475936 is a reply to message #475934] Mon, 24 November 2008 18:11 Go to previous messageGo to next message
Milan,
You can edit edit multiplicity of an Association
- via label-inplace editors as described here - news://news.eclipse.org/80ef43406b188c93cfab395b00c@news.ecl ipse.org,
- or in SourceEnd/TargetEnd tabs in the properties view.
Tanya.
> Dear Tanya,
> Milan
Re: Problems with creating simple UML2 class diagram [message #475937 is a reply to message #475933] Mon, 24 November 2008 18:14 Go to previous messageGo to next message
Milan,
Working with Profiles in UML2 Tools, including a section how to create a
stereotype and how to apply a stereotype, is described here - http://wiki.eclipse.org/MDT-UML2Tools_How_To_Use_UML_Profile s.
Tanya.
> Dear Tanya,
> Thanks, Milan
Re: Problems with creating simple UML2 class diagram [message #475942 is a reply to message #475935] Tue, 25 November 2008 06:19 Go to previous messageGo to next message
Dear Tanya,
yes, but in this way I get EDate type and not Date type ?
Milan Milanovic
Re: Problems with creating simple UML2 class diagram [message #475943 is a reply to message #475936] Tue, 25 November 2008 06:42 Go to previous messageGo to next message
Dear Tanya,
this newslink seams broken? I get error.
Milan
Re: Problems with creating simple UML2 class diagram [message #475946 is a reply to message #475937] Tue, 25 November 2008 11:10 Go to previous messageGo to next message
Dear Tanya,
there is no figures on this page, links are broken ?
Milan
Re: Problems with creating simple UML2 class diagram [message #475947 is a reply to message #475943] Tue, 25 November 2008 15:02 Go to previous messageGo to next message
Hi Milan,
I created a corresponding FAQ at UML2 Tools Wiki: http://wiki.eclipse.org/MDT-UML2Tools_FAQ#How_can_I_change_m ultiplicity_of_an_Association_End.3F
Tanya.
> Dear Tanya,
> Milan
Re: Problems with creating simple UML2 class diagram [message #475948 is a reply to message #475942] Tue, 25 November 2008 15:08 Go to previous messageGo to next message
Hi Milan,
So type
'platform:/plugin/org.eclipse.uml2.uml.resources/libraries/J avaPrimitiveTypes.library.uml'
, or
'platform:/plugin/org.eclipse.uml2.uml.resources/libraries/X MLPrimitiveTypes.library.uml'
or any other URI.
Tanya.
> Dear Tanya,
> Milan Milanovic
Re: Problems with creating simple UML2 class diagram [message #475949 is a reply to message #475946] Tue, 25 November 2008 15:10 Go to previous messageGo to next message
Thanks for noticing the problem, Milan.
I don't see images either. I'll inverstigate the case.
Tanya.
> Dear Tanya,
> Milan
Re: Problems with creating simple UML2 class diagram [message #475952 is a reply to message #475947] Tue, 25 November 2008 16:45 Go to previous message
Dear Tanya,
thank you for link.
I want just to note that SourceEnd tab doesn't exist for Association.
Regards, Milan.
> Hi Milan,
> Tanya.
>> Dear Tanya,
>> Milan
Re: Problems with creating simple UML2 class diagram [message #623179 is a reply to message #475885] Mon, 24 November 2008 10:11 Go to previous message
Milan
Kenn Hussey wrote:
> Milan,
> Kenn
>> Hi,
>> Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #623180 is a reply to message #475927] Mon, 24 November 2008 13:50 Go to previous message
Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #623181 is a reply to message #475928] Mon, 24 November 2008 15:47 Go to previous message
Hello Milan,
diagram:
view.
Best wishes,
Tanya.
> Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #623184 is a reply to message #475929] Mon, 24 November 2008 17:17 Go to previous message
Dear Tanya,
> Hello Milan,
> diagram:
> library file, e.g.
default.
properties
> view.
O.K. I found it.
Best regards, Milan
> Best wishes,
> Tanya.
>> Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #623186 is a reply to message #475932] Mon, 24 November 2008 17:27 Go to previous message
Dear Tanya,
Thanks, Milan
Re: Problems with creating simple UML2 class diagram [message #623187 is a reply to message #475933] Mon, 24 November 2008 17:44 Go to previous message
Dear Tanya,
Milan
Re: Problems with creating simple UML2 class diagram [message #623189 is a reply to message #475932] Mon, 24 November 2008 17:47 Go to previous message
Milan,
Tanya.
> Dear Tanya,
>> Hello Milan,
>> - Java
>> your
>> diagram:
>> choose
>> library file, e.g.
>> code-assist.
>> 'dst' by
> default.
> properties
>> view.
> O.K. I found it.
> Best regards, Milan
>> Best wishes,
>> Tanya.
>>> Thx, Milan
Re: Problems with creating simple UML2 class diagram [message #623191 is a reply to message #475934] Mon, 24 November 2008 18:11 Go to previous message
Milan,
Tanya.
> Dear Tanya,
> Milan
Re: Problems with creating simple UML2 class diagram [message #623193 is a reply to message #475933] Mon, 24 November 2008 18:14 Go to previous message
Milan,
Tanya.
> Dear Tanya,
> Thanks, Milan
Re: Problems with creating simple UML2 class diagram [message #623278 is a reply to message #475935] Tue, 25 November 2008 06:19 Go to previous message
Dear Tanya,
Milan Milanovic
Re: Problems with creating simple UML2 class diagram [message #623279 is a reply to message #475936] Tue, 25 November 2008 06:42 Go to previous message
Dear Tanya,
Milan
Re: Problems with creating simple UML2 class diagram [message #623282 is a reply to message #475937] Tue, 25 November 2008 11:10 Go to previous message
Dear Tanya,
Milan
Re: Problems with creating simple UML2 class diagram [message #623283 is a reply to message #475943] Tue, 25 November 2008 15:02 Go to previous message
Hi Milan,
Tanya.
> Dear Tanya,
> Milan
Re: Problems with creating simple UML2 class diagram [message #623285 is a reply to message #475942] Tue, 25 November 2008 15:08 Go to previous message
Hi Milan,
So type
, or
or any other URI.
Tanya.
> Dear Tanya,
> Milan Milanovic
Re: Problems with creating simple UML2 class diagram [message #623286 is a reply to message #475946] Tue, 25 November 2008 15:10 Go to previous message
Tanya.
> Dear Tanya,
> Milan
Re: Problems with creating simple UML2 class diagram [message #623290 is a reply to message #475947] Tue, 25 November 2008 16:45 Go to previous message
Dear Tanya,
thank you for link.
Regards, Milan.
> Hi Milan,
> Tanya.
>> Dear Tanya,
>> Milan
Previous Topic:epsilon.common.dt.tool extension for UMLCreateShortcutAction
Next Topic:Stereotype for associations
Current Time: Wed Jul 23 21:39:56 EDT 2025
Powered by FUDForum. Page generated in 0.52212 seconds
