Home » Modeling » UML2 » EMF validation constraint target for Stereotype changes
EMF validation constraint target for Stereotype changes [message #475865] |
Fri, 14 September 2007 04:29  |
I'm trying to create EMF validation constraints for Stereotype-related
domain-specific rules, for example a live validation to check if the just
applied Stereotype is correct, or a live validation to check the
correctness of the value entered in the Stereotype property for a UML
Element for example. I can't seem to get the live validation to trigger,
need some help on defining the target class, event and feature, or maybe
point me to the reference material for the available options.
Francis
Re: EMF validation constraint target for Stereotype changes [message #475887 is a reply to message #475865] |
Fri, 14 September 2007 07:00   |
--------------000602030702000106080303
Francis,
You've looked at the help which is also available online?
<http://help.eclipse.org/help33/index.jsp>
http://help.eclipse.org/help33/nav/25
Francis wrote:
> just applied Stereotype is correct, or a live validation to check the
> trigger, need some help on defining the target class, event and
> feature, or maybe point me to the reference material for the available
> options.
> Francis
<html>
<head>
http-equiv="Content-Type">
</head>
Francis,<br>
<br>
You've looked at the help which is also available online?<a
href="http://help.eclipse.org/help33/index.jsp"><br>
</a>
<blockquote><a href="http://help.eclipse.org/help33/index.jsp">http://help.eclipse.org/help33/index.jsp</a><br>
<a href="http://help.eclipse.org/help33/nav/25">http://help.eclipse.org/help33/nav/25</a><br>
</blockquote>
<br>
<br>
Francis wrote:
<blockquote
cite="mid:dc0b7db01b52a3075394e59391faa9b0$1@www.eclipse.org"
type="cite">Hi,
<br>
<br>
options.
<br>
<br>
<br>
Francis
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------000602030702000106080303--
Re: EMF validation constraint target for Stereotype changes [message #475888 is a reply to message #475887] |
Fri, 14 September 2007 07:53   |
Thanks Ed, but yes I already looked at the online help. I think I already
have the target class set correctly since my constraint works on batch
mode (constraint for validating the value of the stereotype property), but
I'm not sure about the feature name to use:
<target class="Activity">
<event name="Set">
<feature name="???"/>
</event>
<event name="Unset">
</event>
</target>
Ed Merks wrote:
> Francis,
> Francis wrote:
>> Hi,
>> options.
>> Thanks,
>> Francis
Re: EMF validation constraint target for Stereotype changes [message #475889 is a reply to message #475888] |
Fri, 14 September 2007 08:36   |
Francis,
I would imagine you'd use one of the features visible in the Activity
class hierarchy, i.e, the name of one of the features returned by
UML2Package.Literals.ACTIVITY.getEAllStructuralFeatures().
> already have the target class set correctly since my constraint works
> on batch mode (constraint for validating the value of the stereotype
> property), but I'm not sure about the feature name to use:
> <event name="Set">
> </event>
> </event>
> </target>
> Ed Merks wrote:
>> Francis,
>> Francis wrote:
>>> Hi,
>>> Stereotype-related domain-specific rules, for example a live
>>> validation to check if the just applied Stereotype is correct, or a
>>> live validation to check the correctness of the value entered in the
>>> Stereotype property for a UML Element for example. I can't seem to
>>> get the live validation to trigger, need some help on defining the
>>> target class, event and feature, or maybe point me to the reference
>>> Thanks,
>>> Francis
Re: EMF validation constraint target for Stereotype changes [message #475893 is a reply to message #475889] |
Fri, 14 September 2007 09:45   |
Hi, Ed, Francis,
It's not quite that simple when dealing with UML. The problem is, that
there is no change to a UML model element when a stereotype is applied to
it or when some property of a stereotype is changed. The stereotype
application is a new object in the contents of the resource which
references the element to which it is applied, not vice-versa. A UML
element only knows the stereotype applications that it has by
reverse-references in the CacheAdapter (which is an
ECrossReferenceAdapter).
What I would suggest is to use the new-in-1.1
org.eclipse.emf.validation.eventTypes extension point to define proxy
notifications for UML elements when stereotypes are applied to them:
http://help.eclipse.org/help33/topic/org.eclipse.emf.validat ion.doc/references/overview/customNotifications.html
On this extension point, you can contribute a "notification generator" that
the live validator invokes to analyze the list of Notifications being
validated, to fabricate custom notifications at a more abstract level or
whatever your application needs. Then, you can target constraints on these
new notifications in the usual way.
Using this mechanism, you can supply the "stereotype applied/unapplied"
notifications that otherwise wouldn't exist.
HTH,
Christian
Ed Merks wrote:
> Francis,
>> <event name="Set">
>> </event>
>> </event>
>> </target>
------8<------
Re: EMF validation constraint target for Stereotype changes [message #624757 is a reply to message #475865] |
Francis,
Francis wrote:
> options.
> Francis
<html>
<head>
</head>
Francis,<br>
<br>
</a>
</blockquote>
<br>
<br>
Francis wrote:
<blockquote
type="cite">Hi,
<br>
<br>
options.
<br>
<br>
<br>
Francis
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: EMF validation constraint target for Stereotype changes [message #624758 is a reply to message #475887] |
<event name="Set">
</event>
</event>
</target>
Ed Merks wrote:
> Francis,
> Francis wrote:
>> Hi,
>> options.
>> Thanks,
>> Francis
Re: EMF validation constraint target for Stereotype changes [message #624759 is a reply to message #475888] |
Francis,
> <event name="Set">
> </event>
> </event>
> </target>
> Ed Merks wrote:
>> Francis,
>> Francis wrote:
>>> Hi,
>>> Thanks,
>>> Francis
Re: EMF validation constraint target for Stereotype changes [message #624785 is a reply to message #475889] |
Hi, Ed, Francis,
HTH,
Christian
Ed Merks wrote:
> Francis,
>> <event name="Set">
>> </event>
>> </event>
>> </target>
------8<------
Current Time: Sun Aug 31 03:44:17 EDT 2025
Powered by FUDForum. Page generated in 0.05370 seconds
