Home » Eclipse Projects » JavaServer Faces » Extending the HTMLEditor with custom operations
Extending the HTMLEditor with custom operations [message #475820] Sun, 20 April 2008 19:41 Go to next message
For our product I am writing a plugin that extends the HTMLEditor with
support for some refactoring operations on the DOM tree. For example, the
plugin contains a button to insert a <span /> element with some attributes
at the selected caret position. This works fairly well and most of the
functionality is in place. I have a couple of questions and very much
appreciate your opinion.
1) I have been looking for WYSIWYG editors based on Eclipse, but this JSF
editor seems to be the best available foundation. Is it the right
approach to extend this editor, or are there better alternatives. One
problem is that most of the API classes seem to be marked as internal and
don't seem to be recommended to be used by third-party plugins.
2) For operations that manipulate the document, I am directly changing the
(XML API) Document with calls such as element.appendChild(). Is this the
recommended way? If yes, how can I bundle multiple steps (such as
appending and then deleting elements) into a single workspace Operation so
that the user can undo them. I have tried to create an IUndoableOperation
but it seems to be split into multiple undoable steps.
3) How can I change syntax high-lighting so that certain HTML attributes
have a different color in the source code?
4) How can I add my own items to the code-completion of the source-code
editor?
Thanks a lot!
Hans
Re: Extending the HTMLEditor with custom operations [message #475821 is a reply to message #475820] Mon, 21 April 2008 18:30 Go to previous messageGo to next message
Hi Hans,
I am glad you are interested in extending the Web Page Editor. As an
adopter, you should raise bugs on the API's that you would like to use
which are marked internal. This will help us to do the necessary work to
declare them as API in a future release. Please take a look at the WTP API
policy described here: http://wiki.eclipse.org/WTP_API_Policy . You can
use the following link to add an enhancement request:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Java%20S erver%20Faces
Please also note that the focus of the JSF Tools Team is to improve the
editor to support JSF development and as such we have no resource working
on improving the editor to better support editing of HTML pages. We
encourage the community to contribute such enhancements to the project.
Raghu Srinivasan
Project Lead - JSF Tools Project
Re: Extending the HTMLEditor with custom operations [message #475822 is a reply to message #475821] Wed, 23 April 2008 10:06 Go to previous messageGo to next message
Originally posted by: chlache.talita.org
I too am looking into the Webpage Editor.
You are rendering the Html/Css yourself, are'nt you?
The code is quite complicated and i am having a hard time to understand what you do, so i just ask:
How do you do that? What are the core rendering classes?
What do think about SWT Composer? Why are'nt you using Mozilla?
Thanks in advance
Andreas Chlache
Raghu Srinivasan wrote:
> Hi Hans,
> API policy described here: http://wiki.eclipse.org/WTP_API_Policy . You
> can use the following link to add an enhancement request:
> working on improving the editor to better support editing of HTML pages.
> We encourage the community to contribute such enhancements to the project.
> Thanks
> Raghu Srinivasan
Re: Extending the HTMLEditor with custom operations [message #475823 is a reply to message #475820] Wed, 23 April 2008 13:21 Go to previous messageGo to next message
This question is better asked on WTP forum since the shared model that
underlies the XML editors (and therefore implementation of the XML API
classes you are using) are owned by WST (web standard tools).
Windows->Preferences->Web->HTML Files->Editor->Syntax Coloring. In terms of
more specific questions, the more general WTP forum would be better since they
own the SSE (structured source editor) which is what you see your source in.
> editor?
This depends on the source type (HTML vs. JSP etc.) and what you want to
add. There are several layers which the WTP forum can help you with. If
you need help specifically with adding content-assist for JSF elements,
attributes and EL, we can give more help here if you give me specifics.
--Cam
Re: Extending the HTMLEditor with custom operations [message #475824 is a reply to message #475822] Wed, 23 April 2008 13:29 Go to previous message
Yes, we have an extensible framework of what we call "tag converters" that
take a source tag (i.e. h:outputText) and produce HTML/CSS. The design
pane then renders it.
Can you be more specific about what part of the rendering you interested
since, as you rightly point out, it is a little complicated. If you have
a specific example of something you'd like to do, it would probably be
helpful to walk you through it.
I haven't looked at SWT composer. We certainly have the ability to target
other HTML renderers/editors (we already do this with the Preview tab).
The main difficulty is being able to support input languages that are
non-HTML, since we need to first approximate the rendering _and_ maintain
enough bridging information that when you edit the HTML visually, we can
map this back to the original format.
If you have requirements in this area, please launch enhancement requests
at bugs.eclipse.org so that we track and address.
--Cam
Re: Extending the HTMLEditor with custom operations [message #617721 is a reply to message #475820] Mon, 21 April 2008 18:30 Go to previous message
Hi Hans,
Raghu Srinivasan
Re: Extending the HTMLEditor with custom operations [message #617722 is a reply to message #475821] Wed, 23 April 2008 10:06 Go to previous message
Thanks in advance
Andreas Chlache
> Hi Hans,
> Thanks
> Raghu Srinivasan
Re: Extending the HTMLEditor with custom operations [message #617723 is a reply to message #475820] Wed, 23 April 2008 13:21 Go to previous message
> editor?
--Cam
Re: Extending the HTMLEditor with custom operations [message #617724 is a reply to message #475822] Wed, 23 April 2008 13:29 Go to previous message
--Cam
Previous Topic:Extending the HTMLEditor with custom operations
Next Topic:standard JSF to iceFaces
Current Time: Sun Jul 27 09:32:12 EDT 2025
Powered by FUDForum. Page generated in 0.03877 seconds
