Home » Eclipse Projects » Platform - User Assistance (UA) » Basic Eclipse UA questions
Basic Eclipse UA questions [message #475663] Fri, 26 June 2009 17:03 Go to next message
I apologize for the newbie questions, but I'm trying to get to know
Eclipse UA with the intent to use it to provide help for a standard
(non-Eclipse) application. I have searched a bit, but haven't found the
answers I need.
I have come so far that I have created two help books, they are stored in
eclipse/plugins/mydoc.ops and /mydoc.tech respectively. When I then start
the InfoCenter and point my web browser at localhost:8080/help/index.jsp,
I see the books Workbench User Guide, Java development user guide,
Platform Plug-in Developer Guide, JDT Plug-in Developer Guide, Plug-in
Development Environment Guide and then finally my two books MyDoc - Ops
and MyDoc - Tech.
And now for the questions:
- How can I control which books are displayed in the navigation pane? I
want to show my books only and not include the Eclipse specific books.
- How can I control the order of the books in the navigation pane?
- Can I change the initial URL from localhost:8080/help/index.jsp to for
example localhost:8080/mydoc/index.jsp?
- Is it possible to get an automatic redirect from localhost:8080 to the
correct URL? If I go to localhost:8080 now, I get an 404 telling me that
no context is matched.
My configuration is Eclipse 3.4.2 on Windows7, slimmed down for Help
purposes using the procedure in
http://help.eclipse.org/stable/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ua_help_setup_standalone.htm.
I suspect I need to work with the files in the plugins directory, so I
have included a complete list of the files at
http://pastebin.com/m58290423 (it's 800+ lines long).
Again sorry for the noob questions, hope you can help.
- Erlend Leganger
Use HELP_DATA to both hide and set ordering for books in nav frame [message #475666 is a reply to message #475663] Sat, 27 June 2009 17:39 Go to previous message
Hi Erlend,
No worries about newbie questions, that's what this group is for!
To hide and to set ordering for the books in the nav frame, use the
HELP_DATA customization preference.
Descriptions of the customization preferences available for the help
system is located here:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/ua_help_setup_preferences.htm
And details about the HELP_DATA file format are here:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/ua_help_setup_help_data.htm
For an infocenter, you'd set the plugin_customization parameter to point
to a plugin_customization.ini file, and in that file is where you set
the different customization parameters such as HELP_DATA, banner, etc.
Depending on which way you prefer, you can specify the
plugin_customization parameter on the startup command for the
infocenter, like:
-plugincustomization plugin_customization.ini
or in the plugin.xml file for your "product plug-in", like:
<plugin>
<extension id="myIC" point="org.eclipse.core.runtime.products">
<product name="%name" application="">
<property name="preferenceCustomization" value="plugin_customization.ini" />
</product>
</extension>
And the plugin_customization.ini file would have a line like:
org.eclipse.help/HELP_DATA=helpdata.xml
to point to your helpdata.xml file.
On your other questions about the URL format, I'll have to leave that
for someone else to answer.
Hope this helps,
Lee Anne
> answers I need.
> in eclipse/plugins/mydoc.ops and /mydoc.tech respectively. When I then
> start the InfoCenter and point my web browser at
> localhost:8080/help/index.jsp, I see the books Workbench User Guide,
> Java development user guide, Platform Plug-in Developer Guide, JDT
> Plug-in Developer Guide, Plug-in Development Environment Guide and then
> finally my two books MyDoc - Ops and MyDoc - Tech.
> - Erlend Leganger
Use HELP_DATA to both hide and set ordering for books in nav frame [message #623425 is a reply to message #475663] Sat, 27 June 2009 17:39 Go to previous message
Hi Erlend,
infocenter, like:
<plugin>
</product>
</extension>
Hope this helps,
Lee Anne
> answers I need.
> - Erlend Leganger
Previous Topic:intro xml - html tags inside text element
Next Topic:Why do Cheatsheets depend on the help system?
Current Time: Sat Jul 26 22:24:30 EDT 2025
Powered by FUDForum. Page generated in 0.46612 seconds
