Home » Eclipse Projects » Platform - User Assistance (UA) » Link to a file outside the plugins folder
| Link to a file outside the plugins folder [message #475609] |
Tue, 02 June 2009 17:37  |
Hi There,
I was wondering if it was at all possible to render content from a file
that is located outside of any plugin. For example, if I wanted my TOC to
refer to file that was located alongside the eclipse.exe executable in the
root 'eclipse' folder, is there any way to do this - either via dynamic
content producers, filters, or even Javascript?
Mark.
| Re: Link to a file outside the plugins folder [message #475617 is a reply to message #475610] |
Wed, 03 June 2009 09:30   |
Thanks, Curtis. This is what I was playing with yesterday. I guess the
problem is, all of my doc plugins currently declare a binding on the
'org.eclipse.help.dynamic' content producer and it looks like you can only
have one producer per plugin. Hmm...maybe I could isolate it in another
plugin and contribute to anchors.
Do you know if there is an example anywhere of a Java-based content
producer? What class is behind 'org.eclipse.help.dynamic'? I've been
looking but haven't been able to find the extension declared anywhere.
Mark.
Chris Goldthorpe wrote:
> A content producer would be the best way to do this. Anything you can
> write in Java can be done in a content producer. As you have probably
> already figured out the paths in the URLs used by the help system are
> always interpreted as referring to a plug-in and do not represent
> physical locations on the file system.
> Mark Melvin wrote:
>> Hi There,
>> to refer to file that was located alongside the eclipse.exe executable
>> in the root 'eclipse' folder, is there any way to do this - either via
>> dynamic content producers, filters, or even Javascript?
>> Thanks,
>> Mark.
| Re: Link to a file outside the plugins folder [message #475620 is a reply to message #475617] |
Wed, 03 June 2009 10:07   |
OK, a little elbow grease has shown that opening a file outside of a
plugin is actually very easy. I guess all I need to sort out is the
'single content producer' limitation.
Mark.
> Mark.
>> Mark Melvin wrote:
>>> Hi There,
>>> Thanks,
>>> Mark.
| Re: Link to a file outside the plugins folder [message #475623 is a reply to message #475620] |
Wed, 03 June 2009 10:42   |
Hi Curtis,
Debugging the source and playing around a bit seems to indicate to me
that, despite what the docs say, in Eclipse 3.5 binding to
"org.eclipse.help.dynamic" is no longer required for xhtml content. Is
this true, or am I missing something? Is there a bug I can CC myself on
that covers this?
Mark.
> Mark.
>> Thanks,
>> Mark.
>>> Mark Melvin wrote:
>>>> Hi There,
>>>> Thanks,
>>>> Mark.
| Re: Link to a file outside the plugins folder [message #475631 is a reply to message #475626] |
Wed, 03 June 2009 18:08  |
Oops. Sorry, Chris! :S
Too many emails, bug reports, etc. going on...
Yes, it seems a little weird that it is documented all over the place,
even in bug reports, but it doesn't appear to be required at all. I did
try to go back and look at the CVS commit logs to see if there was any
explanation as to where this came from (or when it disappeared) and came
up empty.
If anyone knows the story behind it I'd love to hear about it. I'll file
a bug about removing it from the documentation.
Mark.
> I'm guessing the question was intended for me and not Curtis. I'm not
> sure why that binding would be required. As far as I can tell everything
> including search works fine without it. I just did a search in the help
> source files and found no matches for "org.eclipse.help.dynamic" except
> in the tests which also implies that it is not needed.
> Mark Melvin wrote:
>> Hi Curtis,
>> that covers this?
>> Mark.
| Re: Link to a file outside the plugins folder [message #623386 is a reply to message #475609] |
Tue, 02 June 2009 17:44  |
Mark Melvin wrote:
> Hi There,
> Mark.
| Re: Link to a file outside the plugins folder [message #623390 is a reply to message #475610] |
Mark.
> Mark Melvin wrote:
>> Hi There,
>> Thanks,
>> Mark.
| Re: Link to a file outside the plugins folder [message #623392 is a reply to message #475617] |
Mark.
> Mark.
>> Mark Melvin wrote:
>>> Hi There,
>>> Thanks,
>>> Mark.
| Re: Link to a file outside the plugins folder [message #623394 is a reply to message #475620] |
Hi Curtis,
that covers this?
Mark.
> Mark.
>> Thanks,
>> Mark.
>>> Mark Melvin wrote:
>>>> Hi There,
>>>> Thanks,
>>>> Mark.
| Re: Link to a file outside the plugins folder [message #623398 is a reply to message #475623] |
Wed, 03 June 2009 16:38  |
Mark Melvin wrote:
> Hi Curtis,
> that covers this?
> Mark.
| Re: Link to a file outside the plugins folder [message #623405 is a reply to message #475626] |
up empty.
Mark.
> Mark Melvin wrote:
>> Hi Curtis,
>> that covers this?
>> Mark.
Current Time: Sun Nov 09 10:06:11 EST 2025
Powered by FUDForum. Page generated in 0.05450 seconds
