Home » Eclipse Projects » JavaServer Faces » Loop through the Mbeans in Session Scope
Loop through the Mbeans in Session Scope [message #475547] Tue, 04 March 2008 09:12 Go to next message
Originally posted by: reto.huber.alabus.com
I would like to loop through all registred MBeans (in session scope) in the
current session. Is there an easy way to do this? I don't have the name of
each Mbean to call them.
Reto
Re: Loop through the Mbeans in Session Scope [message #475548 is a reply to message #475547] Tue, 04 March 2008 09:55 Go to previous messageGo to next message
On 3/4/2008 9:12 AM, Reto Huber wrote:
> Hi
At design time or runtime?
Re: Loop through the Mbeans in Session Scope [message #475549 is a reply to message #475548] Tue, 04 March 2008 10:22 Go to previous messageGo to next message
>"Yury Kats" <ykats@us.ibm.com> wrote in message
>news:fqjnqk$vlf$1@build.eclipse.org...
>> Hi
>> the
>> of
at runtime
Re: Loop through the Mbeans in Session Scope [message #475591 is a reply to message #475549] Tue, 04 March 2008 10:45 Go to previous messageGo to next message
>>> Hi
>>> the
>>> of
> at runtime
While this a wrong forum for a runtime JSF question (better ask in Sun's or MyFaces,
depending on what implementation you use), the short answer is that there is no
public API to get a list of managed beans. JSF implementaion parses all available faces-config
files at startup, so you may take a look at how exactly that is done and where the information
is stored in the implementation you are using. Then either access the list if implementaion allows
it or parse config files yourself.
Why?
Re: Loop through the Mbeans in Session Scope [message #475595 is a reply to message #475547] Wed, 05 March 2008 04:59 Go to previous messageGo to next message
Hi Reto,
you can find the MBeans in the session context, where the key is the MBean name
from faces-config.xml:
HttpSession session = (HttpSession)
FacesContext.getCurrentInstance().getExternalContext().getSe ssion(false);
session.getAttribute ("myManagedBeanName")
But I am not sure whether all registered MBeans with session scope are created
at e.g. session start.
Best regards
Wolfgang
Reto Huber schrieb:
> Hi
> Regards,
> Reto
Re: Loop through the Mbeans in Session Scope [message #475596 is a reply to message #475595] Wed, 05 March 2008 08:22 Go to previous messageGo to next message
On 3/5/2008 4:59 AM, Wolfgang Knauf wrote:
> Hi Reto,
Yes, but OP said he didn't know the names of the beans.
This could thrown an NPE if getSession(false) didn't return a session.
A better way to access a managed bean (knowing its name) is to use JSF API
for ValueBindings (JSF 1.1) or ValueExpressions (JSF 1.2).
None of them are created at session start. Managed beans are created when they
are first referenced in an expression.
> Best regards
> Wolfgang
> Reto Huber schrieb:
>> Hi
>> Regards,
>> Reto
Re: Loop through the Mbeans in Session Scope [message #475607 is a reply to message #475596] Thu, 13 March 2008 13:09 Go to previous message
Thank you for your hints. I'm looping now through my session objects and
search for this one I need.
Map sessionMap = context.getExternalContext().getSessionMap();
Iterator it = sessionMap.entrySet().iterator();
while (it.hasNext()) {
Object obj = ((Entry)it.next()).getValue();
if(obj instanceof AesWebBoBean) {
// do something
>> created
> they
that's correct.
kindest regards,
Reto
Re: Loop through the Mbeans in Session Scope [message #617144 is a reply to message #475547] Tue, 04 March 2008 09:55 Go to previous message
> Hi
Re: Loop through the Mbeans in Session Scope [message #617147 is a reply to message #475548] Tue, 04 March 2008 10:22 Go to previous message
>> Hi
>> the
>> of
at runtime
Re: Loop through the Mbeans in Session Scope [message #617455 is a reply to message #475549] Tue, 04 March 2008 10:45 Go to previous message
>>> Hi
>>> the
>>> of
> at runtime
Why?
Re: Loop through the Mbeans in Session Scope [message #617465 is a reply to message #475547] Wed, 05 March 2008 04:59 Go to previous message
Hi Reto,
Best regards
Wolfgang
Reto Huber schrieb:
> Hi
> Regards,
> Reto
Re: Loop through the Mbeans in Session Scope [message #617468 is a reply to message #475595] Wed, 05 March 2008 08:22 Go to previous message
> Hi Reto,
> Best regards
> Wolfgang
> Reto Huber schrieb:
>> Hi
>> Regards,
>> Reto
Re: Loop through the Mbeans in Session Scope [message #617499 is a reply to message #475596] Thu, 13 March 2008 13:09 Go to previous message
// do something
>> created
> they
that's correct.
kindest regards,
Reto
Previous Topic:Trinidad support? Anywhere?
Next Topic:Asking jsf semantics validator for ISymbol created from jsf tag attribute
Current Time: Thu Jul 24 23:35:10 EDT 2025
Powered by FUDForum. Page generated in 0.10842 seconds
