ocl standard lib primitive types [message #475585] |
Sat, 01 September 2007 06:22  |
Hi All,
(I also send cc to mdt.uml2 beacause I don't really know who is the
right addressee of this problem)
In my uml models I use primitive types from oclstdlib.uml package
because I need them to be equipped with operations (+, -, /, =, etc).
When I load such a model and navigate in my procedure an element with
such type I get something like this:
org.eclipse.ocl.uml.impl.PrimitiveTypeImpl@151e824 (eProxyURI:
oclstdlib.uml#_alYNtqjQEdu4LJng8Rasow)
But then if I ask for owned elements (including operations) I get
empty result which can be also seen in debugger where 'operations' are
null for this type.
However when I do:
getOCLStandardLibrary().getInteger()
I receive:
org.eclipse.ocl.uml.impl.PrimitiveTypeImpl@1af8502 (name: Integer,
visibility: <unset>) (isLeaf: false, visibility: public, isAbstract:
false)
with all needed operations inside.
I suppose I load my models in a bad way so PrimitiveTypes loose their
operations. But what should I do actually to preserve them?
Thanks in advance,
Krzysztof Kaczmarski
Re: ocl standard lib primitive types [message #475852 is a reply to message #475585] |
Tue, 11 September 2007 16:23  |
Hi, Krzysztof,
Your primitive type in the first case (found by navigating the UML model)
has no operations because it is an unresolved proxy. The proxy URI looks
odd: it is a relative reference to "oclstdlib.uml" instead of an absolute
reference of the form
platform:/plugin/org.eclipse.ocl.uml/model/oclstdlib.uml.
You'll need to figure out why this is being persisted with a relative URI.
HTH,
Christian
Krzysztof Kaczmarski wrote:
> Hi All,
> null for this type.
> However when I do:
> I receive:
> false)
> Thanks in advance,
Re: ocl standard lib primitive types [message #624743 is a reply to message #475585] |
Hi, Krzysztof,
HTH,
Christian
> Hi All,
> null for this type.
> However when I do:
> I receive:
> false)
> Thanks in advance,
FUDForum. Page generated in 0.09840 seconds
