Home » Eclipse Projects » JavaServer Faces » sortable, editable, dataTable component
sortable, editable, dataTable component [message #475538] Fri, 29 February 2008 04:14 Go to next message
I need to put the database data in a sortable and editable table but can't
find the appropriate component in a pallete, or adjust the dataTable
because. In a JCreator I added documentation of classes, so I'm looking for
some sort of thing for components and classes in Eclipse.
Re: sortable, editable, dataTable component [message #475539 is a reply to message #475538] Fri, 29 February 2008 14:23 Go to previous messageGo to next message
Can explain in more detail what you are trying to do? It's not clear what
you are asking.
--Cam
Re: sortable, editable, dataTable component [message #475540 is a reply to message #475538] Fri, 29 February 2008 14:53 Go to previous messageGo to next message
Eclipse doesn't provide any JSF components beyond those standard components
available in the core jsf (f: and h: tags). It is up to you to pick a component
set available on the market -- once you made a choice, downloaded the appropriate
jars and added them to your project, then those components will become available
on the palette for you to use.
The standard dataTable (h:dataTable) doesn't have out of the box support
for sorting, so you should look around what's available and what meets your needs.
There are many good free and for-fee JSF component libraries out there.
Re: sortable, editable, dataTable component [message #475541 is a reply to message #475540] Mon, 03 March 2008 01:54 Go to previous messageGo to next message
"Yury Kats" <ykats@us.ibm.com> wrote in message
news:fq9nnv$gjb$1@build.eclipse.org...
>> can't
>> for
> components
> component
> appropriate
> available
> your needs.
And what free library do you suggest ? I was looking Trinidad but, as a
newbie, I need examples and help implemented in Eclipse to easy choose the
component characteristic.
Re: sortable, editable, dataTable component [message #475542 is a reply to message #475541] Mon, 03 March 2008 01:55 Go to previous messageGo to next message
"Mario" <mzupan@vup.hr> wrote in message
news:fqg7c4$98e$1@build.eclipse.org...
>>> can't
>>> for
>> components
>> component
>> appropriate
>> available
>> your needs.
And Trinidad documentation is poor.
Re: sortable, editable, dataTable component [message #475544 is a reply to message #475542] Mon, 03 March 2008 05:31 Go to previous message
Almost all JSF taglibs (richfaces, tomahawk, trinidad, icefaces and so on)
provide h:dataTable equivalent with sorting and/or navigation support.
Different taglibs are compared here [1] (this comparision is about AJAX
support mainly, but usable as taglib functionality overview nonetheless)
Web page editor palette is automatically populated from TLD files of used
taglibs in the page being edited. Components descriptions are loaded from
there too. Generally, displayed descriptions should be enough to choose
component from the list. I see no point in including whole component
documentation there :)
If you want to change descriptions text, then you should consider altering
TLDs of taglibs you use.
[1] http://www.jsfmatrix.net/
P.S. I would advise using trinidad tr:table, but since you find it's
documentation poor, you may try using richfaces or icefaces. Maybe you'll
have more luck there.
Re: sortable, editable, dataTable component [message #617126 is a reply to message #475538] Fri, 29 February 2008 14:23 Go to previous message
you are asking.
--Cam
Re: sortable, editable, dataTable component [message #617127 is a reply to message #475538] Fri, 29 February 2008 14:53 Go to previous message
Re: sortable, editable, dataTable component [message #617130 is a reply to message #475540] Mon, 03 March 2008 01:54 Go to previous message
>> can't
>> for
> components
> component
> appropriate
> available
> your needs.
Re: sortable, editable, dataTable component [message #617132 is a reply to message #475541] Mon, 03 March 2008 01:55 Go to previous message
>>> can't
>>> for
>> components
>> component
>> appropriate
>> available
>> your needs.
Re: sortable, editable, dataTable component [message #617136 is a reply to message #475542] Mon, 03 March 2008 05:31 Go to previous message
Previous Topic:Deleting cookies in internal browser
Next Topic:Reporting problems from AbstractContextSymbolFactory
Current Time: Fri Jul 25 23:39:05 EDT 2025
Powered by FUDForum. Page generated in 0.05948 seconds
