Re: JSF app no longer deploys class files [message #475404] |
Mon, 04 February 2008 12:03  |
David Karr wrote:
> I have no idea how it got into this state, but after recreating the
> application from scratch (just copying the source files over after
> creating the skeleton), I see the differences in the metadata files that
> make the difference. In the
> ".settings/org.eclipse.wst.common.component" file, I needed to have the
> following line:
> <wb-resource deploy-path="/WEB-INF/classes" source-path="/src"/>
> If this happens again, if it's less practical to recreate the project,
> at least I might be able to fix it by adding this line.
> I would think it would be a good idea to document the schemas for these
> metadata files. I couldn't find any documentation on this file, or
> others like it. I'm sure I just didn't know where to look.
Those files are probably not documented; they're not intended for user
modification as they are internal "state" of the WST tools.
Eric
Re: JSF app no longer deploys class files [message #475530 is a reply to message #475407] |
Mon, 04 February 2008 17:35   |
David Carver wrote:
> Eric, I would hope that there is some documentation somewhere about
> those files and what they are used for. Regardless if they are intended
> for user modification or not, documenting the usage of those files is
> important.
This is open source - if the WST development team didn't have reason,
motivation, time,...whatever... to document them, someone will have to
either a) open a bug report asking for it, b) do the work and submit it,
or c) both.
>>> project, at least I might be able to fix it by adding this line.
>>> these metadata files. I couldn't find any documentation on this
>>> file, or others like it. I'm sure I just didn't know where to look.
>> Eric
Re: JSF app no longer deploys class files [message #616505 is a reply to message #475404] |
Mon, 04 February 2008 12:12  |
The problem with amazing tools like Eclipse is that sometimes they don't
work properly. If the plugin somehow gets the internal state confused,
unless I know the hidden information about the structure of these files,
my only recourse is to just start over. If the structure of these files
was documented in a reasonable place, I'd at least have a chance of being
able to fix it without having to start over. If I make a mistake and the
result doesn't work, I'm no worse off than I was in the first place.
Re: JSF app no longer deploys class files [message #616509 is a reply to message #475404] |
Mon, 04 February 2008 12:31  |
important.
>> these metadata files. I couldn't find any documentation on this file,
> Eric
Re: JSF app no longer deploys class files [message #617106 is a reply to message #475407] |
> important.
or c) both.
>> Eric
FUDForum. Page generated in 0.05537 seconds
