Home » Eclipse Projects » JavaServer Faces » Programmatically attach a stylesheet to JSF page being opened in WPD
Programmatically attach a stylesheet to JSF page being opened in WPD [message #475396] Fri, 18 January 2008 12:51 Go to next message
Originally posted by: xiaonewbie.hotmail.com
Hi All,
I wonder if it is possible to programmatically attach a predefined css
stylesheet to a JSF page when the page is opened in WPD. This stylesheet
affects designer view/Preview only.
Jim
Re: Programmatically attach a stylesheet to JSF page being opened in WPD [message #475397 is a reply to message #475396] Fri, 18 January 2008 16:27 Go to previous messageGo to next message
What event would you want to cause the stylesheet to be added? Can you
explain the use-case in more detail as it impacts your end-user?
--Cam
Re: Programmatically attach a stylesheet to JSF page being opened in WPD [message #475399 is a reply to message #475397] Fri, 18 January 2008 17:27 Go to previous messageGo to next message
The JSF component library I am working on has default theme (stylesheet)
defined and built-in the library. Default style for each component gets
applied in runtime via resourceManager of the component library if
styleClass is not explicitly desined as attribute. The stylesheet and
resources are wrapped inside jar file.
What I want to do is to attach stylesheet for WPD only with file url
pointing to the stylesheet placed in its plugin's directory.
>> stylesheet affects designer view/Preview only.
> --Cam
Re: Programmatically attach a stylesheet to JSF page being opened in WPD [message #475400 is a reply to message #475399] Wed, 23 January 2008 13:16 Go to previous message
John,
We need to add some similar (if not the same) functionality for the
resource servlet used by Trinidad. The general approach will likely be
some sort of per-project setting to allow URI prefixes to be mapped to
some resource handler class, which must be provided (e.g. map
"/resources/*" to "com.foo.bar.MyResourceHandler").
Please would you open an enhancement request against JSF Tools Project's
UI component[1], so we can track both your requirements and our own to
ensure the solution we provide is flexible enough to solve both use cases
(and any other use cases that we consider as we proceed)?
[1]
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Java%20S erver%20Faces
- Ian Trimble (JSF Tools Project)
> Thanks
>> --Cam
Re: Programmatically attach a stylesheet to JSF page being opened in WPD [message #616467 is a reply to message #475396] Fri, 18 January 2008 16:27 Go to previous message
--Cam
Re: Programmatically attach a stylesheet to JSF page being opened in WPD [message #616478 is a reply to message #475397] Fri, 18 January 2008 17:27 Go to previous message
> --Cam
Re: Programmatically attach a stylesheet to JSF page being opened in WPD [message #616480 is a reply to message #475399] Wed, 23 January 2008 13:16 Go to previous message
John,
[1]
> Thanks
>> --Cam
Previous Topic:Re: How to use MyFaces trinidad
Next Topic:WPE Transform Operations - Provisional API Change Alert
Current Time: Wed Jul 23 18:33:14 EDT 2025
Powered by FUDForum. Page generated in 0.03767 seconds
